path: root/kernel/futex.c
2012-01-11futex: Fix uninterruptible loop due to gate_areaHugh Dickins
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream. It was found (by Sasha) that if you use a futex located in the gate area we get stuck in an uninterruptible infinite loop, much like the ZERO_PAGE issue. While looking at this problem, PeterZ realized you'll get into similar trouble when hitting any install_special_pages() mapping. And are there still drivers setting up their own special mmaps without page->mapping, and without special VM or pte flags to make get_user_pages fail? In most cases, if page->mapping is NULL, we do not need to retry at all: Linus points out that even /proc/sys/vm/drop_caches poses no problem, because it ends up using remove_mapping(), which takes care not to interfere when the page reference count is raised. But there is still one case which does need a retry: if memory pressure called shmem_writepage in between get_user_pages_fast dropping page table lock and our acquiring page lock, then the page gets switched from filecache to swapcache (and ->mapping set to NULL) whatever the refcount. Fault it back in to get the page->mapping needed for key->shared.inode. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I04a763aed3c611460ef4888d14a1f5101e8373bc Reviewed-on: http://git-master/r/74198 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-08-04Merge branch 'linus' into core/urgentIngo Molnar
2011-07-26futex: Fix regression with read only mappingsShawn Bohrer
commit 7485d0d3758e8e6491a5c9468114e74dc050785d (futexes: Remove rw parameter from get_futex_key()) in 2.6.33 fixed two problems: First, It prevented a loop when encountering a ZERO_PAGE. Second, it fixed RW MAP_PRIVATE futex operations by forcing the COW to occur by unconditionally performing a write access get_user_pages_fast() to get the page. The commit also introduced a user-mode regression in that it broke futex operations on read-only memory maps. For example, this breaks workloads that have one or more reader processes doing a FUTEX_WAIT on a futex within a read only shared file mapping, and a writer processes that has a writable mapping issuing the FUTEX_WAKE. This fixes the regression for valid futex operations on RO mappings by trying a RO get_user_pages_fast() when the RW get_user_pages_fast() fails. This change makes it necessary to also check for invalid use cases, such as anonymous RO mappings (which can never change) and the ZERO_PAGE which the commit referenced above was written to address. This patch does restore the original behavior with RO MAP_PRIVATE mappings, which have inherent user-mode usage problems and don't really make sense. With this patch performing a FUTEX_WAIT within a RO MAP_PRIVATE mapping will be successfully woken provided another process updates the region of the underlying mapped file. However, the mmap() man page states that for a MAP_PRIVATE mapping: It is unspecified whether changes made to the file after the mmap() call are visible in the mapped region. So user-mode users attempting to use futex operations on RO MAP_PRIVATE mappings are depending on unspecified behavior. Additionally a RO MAP_PRIVATE mapping could fail to wake up in the following case. Thread-A: call futex(FUTEX_WAIT, memory-region-A). get_futex_key() return inode based key. sleep on the key Thread-B: call mprotect(PROT_READ|PROT_WRITE, memory-region-A) Thread-B: write memory-region-A. COW happen. This process's memory-region-A become related to new COWed private (ie PageAnon=1) page. Thread-B: call futex(FUETX_WAKE, memory-region-A). get_futex_key() return mm based key. IOW, we fail to wake up Thread-A. Once again doing something like this is just silly and users who do something like this get what they deserve. While RO MAP_PRIVATE mappings are nonsensical, checking for a private mapping requires walking the vmas and was deemed too costly to avoid a userspace hang. This Patch is based on Peter Zijlstra's initial patch with modifications to only allow RO mappings for futex operations that need VERIFY_READ access. Reported-by: David Oliver <david@rgmadvisors.com> Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: peterz@infradead.org Cc: eric.dumazet@gmail.com Cc: zvonler@rgmadvisors.com Cc: hughd@google.com Link: http://lkml.kernel.org/r/1309450892-30676-1-git-send-email-sbohrer@rgmadvisors.com Cc: stable@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-07-25mm/futex: fix futex writes on archs with SW tracking of dirty & youngBenjamin Herrenschmidt
I haven't reproduced it myself but the fail scenario is that on such machines (notably ARM and some embedded powerpc), if you manage to hit that futex path on a writable page whose dirty bit has gone from the PTE, you'll livelock inside the kernel from what I can tell. It will go in a loop of trying the atomic access, failing, trying gup to "fix it up", getting succcess from gup, go back to the atomic access, failing again because dirty wasn't fixed etc... So I think you essentially hang in the kernel. The scenario is probably rare'ish because affected architecture are embedded and tend to not swap much (if at all) so we probably rarely hit the case where dirty is missing or young is missing, but I think Shan has a piece of SW that can reliably reproduce it using a shared writable mapping & fork or something like that. On archs who use SW tracking of dirty & young, a page without dirty is effectively mapped read-only and a page without young unaccessible in the PTE. Additionally, some architectures might lazily flush the TLB when relaxing write protection (by doing only a local flush), and expect a fault to invalidate the stale entry if it's still present on another processor. The futex code assumes that if the "in_atomic()" access -EFAULT's, it can "fix it up" by causing get_user_pages() which would then be equivalent to taking the fault. However that isn't the case. get_user_pages() will not call handle_mm_fault() in the case where the PTE seems to have the right permissions, regardless of the dirty and young state. It will eventually update those bits ... in the struct page, but not in the PTE. Additionally, it will not handle the lazy TLB flushing that can be required by some architectures in the fault case. Basically, gup is the wrong interface for the job. The patch provides a more appropriate one which boils down to just calling handle_mm_fault() since what we are trying to do is simulate a real page fault. The futex code currently attempts to write to user memory within a pagefault disabled section, and if that fails, tries to fix it up using get_user_pages(). This doesn't work on archs where the dirty and young bits are maintained by software, since they will gate access permission in the TLB, and will not be updated by gup(). In addition, there's an expectation on some archs that a spurious write fault triggers a local TLB flush, and that is missing from the picture as well. I decided that adding those "features" to gup() would be too much for this already too complex function, and instead added a new simpler fixup_user_fault() which is essentially a wrapper around handle_mm_fault() which the futex code can call. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix some nits Darren saw, fiddle comment layout] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Shan Hai <haishan.bai@gmail.com> Tested-by: Shan Hai <haishan.bai@gmail.com> Cc: David Laight <David.Laight@ACULAB.COM> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <darren.hart@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08plist: Remove the need to supply locks to plist headsDima Zavin
This was legacy code brought over from the RT tree and is no longer necessary. Signed-off-by: Dima Zavin <dima@android.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-15futex: Set FLAGS_HAS_TIMEOUT during futex_wait restart setupDarren Hart
The FLAGS_HAS_TIMEOUT flag was not getting set, causing the restart_block to restart futex_wait() without a timeout after a signal. Commit b41277dc7a18ee332d in 2.6.38 introduced the regression by accidentally removing the the FLAGS_HAS_TIMEOUT assignment from futex_wait() during the setup of the restart block. Restore the originaly behavior. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=32922 Reported-by: Tim Smith <tsmith201104@yahoo.com> Reported-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Kacur <jkacur@redhat.com> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/%3Cdaac0eb3af607f72b9a4d3126b2ba8fb5ed3b883.1302820917.git.dvhart%40linux.intel.com%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix WARN_ON() test for UP WARN_ON_SMP(): Allow use in if() statements on UP x86, dumpstack: Use %pB format specifier for stack trace vsprintf: Introduce %pB format specifier lockdep: Remove unused 'factor' variable from lockdep_stats_show()
2011-03-25futex: Fix WARN_ON() test for UPSteven Rostedt
An update of the futex code had a WARN_ON(!spin_is_locked(q->lock_ptr)) But on UP, spin_is_locked() is always false, and will trigger this warning, and even worse, it will exit the function without doing the necessary work. Converting this to a WARN_ON_SMP() fixes the problem. Reported-by: Richard Weinberger <richard@nod.at> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <20110317192208.682654502@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtmutex: tester: Remove the remaining BKL leftovers lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause rtmutex: Simplify PI algorithm and make highest prio task get lock rwsem: Remove redundant asmregparm annotation rwsem: Move duplicate function prototypes to linux/rwsem.h rwsem: Unify the duplicate rwsem_is_locked() inlines rwsem: Move duplicate init macros and functions to linux/rwsem.h rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h x86: Cleanup rwsem_count_t typedef rwsem: Cleanup includes locking: Remove deprecated lock initializers cred: Replace deprecated spinlock initialization kthread: Replace deprecated spinlock initialization xtensa: Replace deprecated spinlock initialization um: Replace deprecated spinlock initialization sparc: Replace deprecated spinlock initialization mips: Replace deprecated spinlock initialization cris: Replace deprecated spinlock initialization alpha: Replace deprecated spinlock initialization rtmutex-tester: Remove BKL tests
2011-03-14futex: Deobfuscate handle_futex_death()Thomas Gleixner
handle_futex_death() uses futex_atomic_cmpxchg_inatomic() without disabling page faults. That's ok, but totally non obvious. We don't hold locks so we actually can and want to fault here, because the get_user() before futex_atomic_cmpxchg_inatomic() does not guarantee a R/W mapping. We could just add a big fat comment to explain this, but actually changing the code so that the functionality is entirely clear is better. Use the helper function which disables page faults around the futex_atomic_cmpxchg_inatomic() and handle a fault with a call to fault_in_user_writeable() as all other places in the futex code do as well. Pointed-out-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Darren Hart <darren@dvhart.com> Cc: Michel Lespinasse <walken@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> LKML-Reference: <alpine.LFD.2.00.1103141126590.2787@localhost6.localdomain6> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-12Merge branch 'tip/futex/devel' of ↵Thomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-rt into core/futexes futex,plist: Pass the real head of the priority list to plist_del() futex,plist: Remove debug lock assignment from plist_node plist: Shrink struct plist_head plist: Add priority list test
2011-03-11futex,plist: Remove debug lock assignment from plist_nodeLai Jiangshan
The original code uses &plist_node->plist as the fake head of the priority list for plist_del(), these debug locks in the fake head are needed for CONFIG_DEBUG_PI_LIST. But now we always pass the real head to plist_del(), the debug locks in plist_node will not be used, so we remove these assignments. Acked-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4D10797E.7040803@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-11futex,plist: Pass the real head of the priority list to plist_del()Lai Jiangshan
Some plist_del()s in kernel/futex.c are passed a faked head of the priority list. It does not fail because the current code does not require the real head in plist_del(). The current code of plist_del() just uses the head for checking, so it will not cause a bad result even when we use a faked head. But it is undocumented usage: /** * plist_del - Remove a @node from plist. * * @node: &struct plist_node pointer - entry to be removed * @head: &struct plist_head pointer - list head */ The document says that the @head is the "list head" head of the priority list. In futex code, several places use "plist_del(&q->list, &q->list.plist);", they pass a fake head. We need to fix them all. Thanks to Darren Hart for many suggestions. Acked-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4D11984A.5030203@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-11futex: Sanitize cmpxchg_futex_value_locked APIMichel Lespinasse
The cmpxchg_futex_value_locked API was funny in that it returned either the original, user-exposed futex value OR an error code such as -EFAULT. This was confusing at best, and could be a source of livelocks in places that retry the cmpxchg_futex_value_locked after trying to fix the issue by running fault_in_user_writeable(). This change makes the cmpxchg_futex_value_locked API more similar to the get_futex_value_locked one, returning an error code and updating the original value through a reference argument. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile] Acked-by: Tony Luck <tony.luck@intel.com> [ia64] Acked-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Michal Simek <monstr@monstr.eu> [microblaze] Acked-by: David Howells <dhowells@redhat.com> [frv] Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311024851.GC26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-11futex: Avoid redudant evaluation of task_pid_vnr()Thomas Gleixner
The result is not going to change under us, so no need to reevaluate this over and over. Seems to be a leftover from the mechanical mass conversion of task->pid to task_pid_vnr(tsk). Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-10futex: Update futex_wait_setup comments about lockingMichel Lespinasse
Reviving a cleanup I had done about a year ago as part of a larger futex_set_wait proposal. Over the years, the locking of the hashed futex queue got improved, so that some of the "rare but normal" race conditions described in comments can't actually happen anymore. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Darren Hart <dvhltc@us.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110307020750.GA31188@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rtmutex: Simplify PI algorithm and make highest prio task get lockLai Jiangshan
In current rtmutex, the pending owner may be boosted by the tasks in the rtmutex's waitlist when the pending owner is deboosted or a task in the waitlist is boosted. This boosting is unrelated, because the pending owner does not really take the rtmutex. It is not reasonable. Example. time1: A(high prio) onwers the rtmutex. B(mid prio) and C (low prio) in the waitlist. time2 A release the lock, B becomes the pending owner A(or other high prio task) continues to run. B's prio is lower than A, so B is just queued at the runqueue. time3 A or other high prio task sleeps, but we have passed some time The B and C's prio are changed in the period (time2 ~ time3) due to boosting or deboosting. Now C has the priority higher than B. ***Is it reasonable that C has to boost B and help B to get the rtmutex? NO!! I think, it is unrelated/unneed boosting before B really owns the rtmutex. We should give C a chance to beat B and win the rtmutex. This is the motivation of this patch. This patch *ensures* only the top waiter or higher priority task can take the lock. How? 1) we don't dequeue the top waiter when unlock, if the top waiter is changed, the old top waiter will fail and go to sleep again. 2) when requiring lock, it will get the lock when the lock is not taken and: there is no waiter OR higher priority than waiters OR it is top waiter. 3) In any time, the top waiter is changed, the top waiter will be woken up. The algorithm is much simpler than before, no pending owner, no boosting for pending owner. Other advantage of this patch: 1) The states of a rtmutex are reduced a half, easier to read the code. 2) the codes become shorter. 3) top waiter is not dequeued until it really take the lock: they will retain FIFO when it is stolen. Not advantage nor disadvantage 1) Even we may wakeup multiple waiters(any time when top waiter changed), we hardly cause "thundering herd", the number of wokenup task is likely 1 or very little. 2) two APIs are changed. rt_mutex_owner() will not return pending owner, it will return NULL when the top waiter is going to take the lock. rt_mutex_next_owner() always return the top waiter. will not return NULL if we have waiters because the top waiter is not dequeued. I have fixed the code that use these APIs. need updated after this patch is accepted 1) Document/* 2) the testcase scripts/rt-tester/t4-l2-pi-deboost.tst Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4D3012D5.4060709@cn.fujitsu.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-15Merge branches 'core-fixes-for-linus', 'x86-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: avoid pointless blocked-task warnings rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter status rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi() * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc: Add missing Kconfig dependencies x86, mrst: Set correct APB timer IRQ affinity for secondary cpu x86: tsc: Fix calibration refinement conditionals to avoid divide by zero x86, ia64, acpi: Clean up x86-ism in drivers/acpi/numa.c * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timekeeping: Make local variables static time: Rename misnamed minsec argument of clocks_calc_mult_shift() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Remove syscall_exit_fields tracing: Only process module tracepoints once perf record: Add "nodelay" mode, disabled by default perf sched: Fix list of events, dropping unsupported ':r' modifier Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return" perf top: Fix annotate segv perf evsel: Fix order of event list deletion
2011-01-13thp: update futex compound knowledgeAndrea Arcangeli
Futex code is smarter than most other gup_fast O_DIRECT code and knows about the compound internals. However now doing a put_page(head_page) will not release the pin on the tail page taken by gup-fast, leading to all sort of refcounting bugchecks. Getting a stable head_page is a little tricky. page_head = page is there because if this is not a tail page it's also the page_head. Only in case this is a tail page, compound_head is called, otherwise it's guaranteed unnecessary. And if it's a tail page compound_head has to run atomically inside irq disabled section __get_user_pages_fast before returning. Otherwise ->first_page won't be a stable pointer. Disableing irq before __get_user_page_fast and releasing irq after running compound_head is needed because if __get_user_page_fast returns == 1, it means the huge pmd is established and cannot go away from under us. pmdp_splitting_flush_notify in __split_huge_page_splitting will have to wait for local_irq_enable before the IPI delivery can return. This means __split_huge_page_refcount can't be running from under us, and in turn when we run compound_head(page) we're not reading a dangling pointer from tailpage->first_page. Then after we get to stable head page, we are always safe to call compound_lock and after taking the compound lock on head page we can finally re-check if the page returned by gup-fast is still a tail page. in which case we're set and we didn't need to split the hugepage in order to take a futex on it. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-11rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi()Steven Rostedt
The comment about why rt_mutex_next_owner() can return NULL in wake_futex_pi() is not the normal case. Tracing the cause of why this occurs is more likely that waiter simply timedout. But because it originally caused contention with the futex, the owner will go into the kernel when it unlocks the lock. Then it will hit this code path and rt_mutex_next_owner() will return NULL. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-10futex: Add futex_q static initializerDarren Hart
The futex_q struct has grown considerably over the last couple years. I believe it now merits a static initializer to avoid uninitialized data errors (having spent more time than I care to admit debugging an uninitialized q.bitset in an experimental new op code). With the key initializer built in, several of the FUTEX_KEY_INIT calls can be removed. V2: use a static variable instead of an init macro. use a C99 initializer and don't rely on variable ordering in the struct. V3: make futex_q_init const Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: John Kacur <jkacur@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1289252428-18383-1-git-send-email-dvhart@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-11-10futex: Replace fshared and clockrt with combined flagsDarren Hart
In the early days we passed the mmap sem around. That became the "int fshared" with the fast gup improvements. Then we added "int clockrt" in places. This patch unifies these options as "flags". [ tglx: Split out the stale fshared cleanup ] Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: John Kacur <jkacur@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1289250609-16304-1-git-send-email-dvhart@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-11-10futex: Cleanup stale fshared flag interfacesThomas Gleixner
The fast GUP changes stopped using the fshared flag in put_futex_keys(), but we kept the interface the same. Cleanup all stale users. This patch is split out from Darren Harts combo patch which also combines various flags. This way the changes are clearly separated. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Darren Hart <dvhart@linux.intel.com> LKML-Reference: <1289250609-16304-1-git-send-email-dvhart@linux.intel.com>
2010-11-10futex: Address compiler warnings in exit_robust_listDarren Hart
Since commit 1dcc41bb (futex: Change 3rd arg of fetch_robust_entry() to unsigned int*) some gcc versions decided to emit the following warning: kernel/futex.c: In function ‘exit_robust_list’: kernel/futex.c:2492: warning: ‘next_pi’ may be used uninitialized in this function The commit did not introduce the warning as gcc should have warned before that commit as well. It's just gcc being silly. The code path really can't result in next_pi being unitialized (or should not), but let's keep the build clean. Annotate next_pi as an uninitialized_var. [ tglx: Addressed the same issue in futex_compat.c and massaged the changelog ] Signed-off-by: Darren Hart <dvhart@linux.intel.com> Tested-by: Matt Fleming <matt@console-pimps.org> Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: John Kacur <jkacur@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1288897200-13008-1-git-send-email-dvhart@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-21Merge branch 'futexes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix kernel-doc notation & typos futex: Add lock context annotations futex: Mark restart_block.futex.uaddr[2] __user futex: Change 3rd arg of fetch_robust_entry() to unsigned int*
2010-10-19futex: Fix errors in nested key ref-countingDarren Hart
futex_wait() is leaking key references due to futex_wait_setup() acquiring an additional reference via the queue_lock() routine. The nested key ref-counting has been masking bugs and complicating code analysis. queue_lock() is only called with a previously ref-counted key, so remove the additional ref-counting from the queue_(un)lock() functions. Also futex_wait_requeue_pi() drops one key reference too many in unqueue_me_pi(). Remove the key reference handling from unqueue_me_pi(). This was paired with a queue_lock() in futex_lock_pi(), so the count remains unchanged. Document remaining nested key ref-counting sites. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Reported-and-tested-by: Matthieu Fertré<matthieu.fertre@kerlabs.com> Reported-by: Louis Rilling<louis.rilling@kerlabs.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: John Kacur <jkacur@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <4CBB17A8.70401@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2010-10-14futex: Fix kernel-doc notation & typosRandy Dunlap
Convert futex_requeue() function parameters to use @name kernel-doc notation and add @fshared & @cmpval to prevent kernel-doc warnings. Add @list to struct futex_q. Fix a few typos. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <20101013110234.89b06043.randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-18futex: Add lock context annotationsNamhyung Kim
queue_lock/unlock/me() and unqueue_me_pi() grab/release spinlocks but are missing proper annotations. Add them. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <dvhltc@us.ibm.com> LKML-Reference: <1284468228-8723-3-git-send-email-namhyung@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-18futex: Mark restart_block.futex.uaddr[2] __userNamhyung Kim
@uaddr and @uaddr2 fields in restart_block.futex are user pointers. Add __user and remove unnecessary casts. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <dvhltc@us.ibm.com> LKML-Reference: <1284468228-8723-2-git-send-email-namhyung@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-18futex: Change 3rd arg of fetch_robust_entry() to unsigned int*Namhyung Kim
Sparse complains: kernel/futex.c:2495:59: warning: incorrect type in argument 3 (different signedness) Make 3rd argument of fetch_robust_entry() 'unsigned int'. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <dvhltc@us.ibm.com> LKML-Reference: <1284468228-8723-1-git-send-email-namhyung@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-30futex: futex_find_get_task remove credentails checkMichal Hocko
futex_find_get_task is currently used (through lookup_pi_state) from two contexts, futex_requeue and futex_lock_pi_atomic. None of the paths looks it needs the credentials check, though. Different (e)uids shouldn't matter at all because the only thing that is important for shared futex is the accessibility of the shared memory. The credentail check results in glibc assert failure or process hang (if glibc is compiled without assert support) for shared robust pthread mutex with priority inheritance if a process tries to lock already held lock owned by a process with a different euid: pthread_mutex_lock.c:312: __pthread_mutex_lock_full: Assertion `(-(e)) != 3 || !robust' failed. The problem is that futex_lock_pi_atomic which is called when we try to lock already held lock checks the current holder (tid is stored in the futex value) to get the PI state. It uses lookup_pi_state which in turn gets task struct from futex_find_get_task. ESRCH is returned either when the task is not found or if credentials check fails. futex_lock_pi_atomic simply returns if it gets ESRCH. glibc code, however, doesn't expect that robust lock returns with ESRCH because it should get either success or owner died. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Darren Hart <dvhltc@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Nick Piggin <npiggin@suse.de> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-03futex: Handle futex value corruption gracefullyThomas Gleixner
The WARN_ON in lookup_pi_state which complains about a mismatch between pi_state->owner->pid and the pid which we retrieved from the user space futex is completely bogus. The code just emits the warning and then continues despite the fact that it detected an inconsistent state of the futex. A conveniant way for user space to spam the syslog. Replace the WARN_ON by a consistency check. If the values do not match return -EINVAL and let user space deal with the mess it created. This also fixes the missing task_pid_vnr() when we compare the pi_state->owner pid with the futex value. Reported-by: Jermome Marchand <jmarchan@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Darren Hart <dvhltc@us.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org>
2010-02-03futex: Handle user space corruption gracefullyThomas Gleixner
If the owner of a PI futex dies we fix up the pi_state and set pi_state->owner to NULL. When a malicious or just sloppy programmed user space application sets the futex value to 0 e.g. by calling pthread_mutex_init(), then the futex can be acquired again. A new waiter manages to enqueue itself on the pi_state w/o damage, but on unlock the kernel dereferences pi_state->owner and oopses. Prevent this by checking pi_state->owner in the unlock path. If pi_state->owner is not current we know that user space manipulated the futex value. Ignore the mess and return -EINVAL. This catches the above case and also the case where a task hijacks the futex by setting the tid value and then tries to unlock it. Reported-by: Jermome Marchand <jmarchan@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Darren Hart <dvhltc@us.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org>
2010-02-03futex_lock_pi() key refcnt fixMikael Pettersson
This fixes a futex key reference count bug in futex_lock_pi(), where a key's reference count is incremented twice but decremented only once, causing the backing object to not be released. If the futex is created in a temporary file in an ext3 file system, this bug causes the file's inode to become an "undead" orphan, which causes an oops from a BUG_ON() in ext3_put_super() when the file system is unmounted. glibc's test suite is known to trigger this, see <http://bugzilla.kernel.org/show_bug.cgi?id=14256>. The bug is a regression from 2.6.28-git3, namely Peter Zijlstra's 38d47c1b7075bd7ec3881141bb3629da58f88dab "[PATCH] futex: rely on get_user_pages() for shared futexes". That commit made get_futex_key() also increment the reference count of the futex key, and updated its callers to decrement the key's reference count before returning. Unfortunately the normal exit path in futex_lock_pi() wasn't corrected: the reference count is incremented by get_futex_key() and queue_lock(), but the normal exit path only decrements once, via unqueue_me_pi(). The fix is to put_futex_key() after unqueue_me_pi(), since 2.6.31 this is easily done by 'goto out_put_key' rather than 'goto out'. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Darren Hart <dvhltc@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org>
2010-01-13futexes: Remove rw parameter from get_futex_key()KOSAKI Motohiro
Currently, futexes have two problem: A) The current futex code doesn't handle private file mappings properly. get_futex_key() uses PageAnon() to distinguish file and anon, which can cause the following bad scenario: 1) thread-A call futex(private-mapping, FUTEX_WAIT), it sleeps on file mapping object. 2) thread-B writes a variable and it makes it cow. 3) thread-B calls futex(private-mapping, FUTEX_WAKE), it wakes up blocked thread on the anonymous page. (but it's nothing) B) Current futex code doesn't handle zero page properly. Read mode get_user_pages() can return zero page, but current futex code doesn't handle it at all. Then, zero page makes infinite loop internally. The solution is to use write mode get_user_page() always for page lookup. It prevents the lookup of both file page of private mappings and zero page. Performance concerns: Probaly very little, because glibc always initialize variables for futex before to call futex(). It means glibc users never see the overhead of this patch. Compatibility concerns: This patch has few compatibility issues. After this patch, FUTEX_WAIT require writable access to futex variables (read-only mappings makes EFAULT). But practically it's not a problem, glibc always initalizes variables for futexes explicitly - nobody uses read-only mappings. Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <dvhltc@us.ibm.com> Cc: <stable@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Ulrich Drepper <drepper@gmail.com> LKML-Reference: <20100105162633.45A2.A69D9226@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14rtmutes: Convert rtmutex.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14sched: Convert pi_lock to raw_spinlockThomas Gleixner
2009-12-14plist: Make plist debugging raw_spinlock awareThomas Gleixner
plists are used with spinlocks and raw_spinlocks. Change the plist debugging to handle both types. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-08futex: Take mmap_sem for get_user_pages in fault_in_user_writeableAndi Kleen
get_user_pages() must be called with mmap_sem held. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: stable@kernel.org Cc: Andrew Morton <akpm@linuxfoundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: Darren Hart <dvhltc@us.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20091208121942.GA21298@basil.fritz.box> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-28futex: Fix spurious wakeup for requeue_pi reallyThomas Gleixner
The requeue_pi path doesn't use unqueue_me() (and the racy lock_ptr == NULL test) nor does it use the wake_list of futex_wake() which where the reason for commit 41890f2 (futex: Handle spurious wake up) See debugging discussing on LKML Message-ID: <4AD4080C.20703@us.ibm.com> The changes in this fix to the wait_requeue_pi path were considered to be a likely unecessary, but harmless safety net. But it turns out that due to the fact that for unknown $@#!*( reasons EWOULDBLOCK is defined as EAGAIN we built an endless loop in the code path which returns correctly EWOULDBLOCK. Spurious wakeups in wait_requeue_pi code path are unlikely so we do the easy solution and return EWOULDBLOCK^WEAGAIN to user space and let it deal with the spurious wakeup. Cc: Darren Hart <dvhltc@us.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: John Stultz <johnstul@linux.vnet.ibm.com> Cc: Dinakar Guniguntala <dino@in.ibm.com> LKML-Reference: <4AE23C74.1090502@us.ibm.com> Cc: stable@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-16futex: Move drop_futex_key_refs out of spinlock'ed regionDarren Hart
When requeuing tasks from one futex to another, the reference held by the requeued task to the original futex location needs to be dropped eventually. Dropping the reference may ultimately lead to a call to "iput_final" and subsequently call into filesystem- specific code - which may be non-atomic. It is therefore safer to defer this drop operation until after the futex_hash_bucket spinlock has been dropped. Originally-From: Helge Bahmann <hcb@chaoticmind.net> Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Cc: <stable@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Dinakar Guniguntala <dino@in.ibm.com> Cc: John Stultz <johnstul@linux.vnet.ibm.com> Cc: Sven-Thorsten Dietrich <sdietrich@novell.com> Cc: John Kacur <jkacur@redhat.com> LKML-Reference: <4AD7A298.5040802@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-14futex: Check for NULL keys in match_futexDarren Hart
If userspace tries to perform a requeue_pi on a non-requeue_pi waiter, it will find the futex_q->requeue_pi_key to be NULL and OOPS. Check for NULL in match_futex() instead of doing explicit NULL pointer checks on all call sites. While match_futex(NULL, NULL) returning false is a little odd, it's still correct as we expect valid key references. Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Dinakar Guniguntala <dino@in.ibm.com> CC: John Stultz <johnstul@us.ibm.com> Cc: stable@kernel.org LKML-Reference: <4AD60687.10306@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-13futex: Handle spurious wake upThomas Gleixner
The futex code does not handle spurious wake up in futex_wait and futex_wait_requeue_pi. The code assumes that any wake up which was not caused by futex_wake / requeue or by a timeout was caused by a signal wake up and returns one of the syscall restart error codes. In case of a spurious wake up the signal delivery code which deals with the restart error codes is not invoked and we return that error code to user space. That causes applications which actually check the return codes to fail. Blaise reported that on preempt-rt a python test program run into a exception trap. -rt exposed that due to a built in spurious wake up accelerator :) Solve this by checking signal_pending(current) in the wake up path and handle the spurious wake up case w/o returning to user space. Reported-by: Blaise Gassend <blaise@willowgarage.com> Debugged-by: Darren Hart <dvhltc@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@kernel.org LKML-Reference: <new-submission>
2009-10-08Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: fix requeue_pi key imbalance futex: Fix typo in FUTEX_WAIT/WAKE_BITSET_PRIVATE definitions rcu: Place root rcu_node structure in separate lockdep class rcu: Make hot-unplugged CPU relinquish its own RCU callbacks rcu: Move rcu_barrier() to rcutree futex: Move exit_pi_state() call to release_mm() futex: Nullify robust lists after cleanup futex: Fix locking imbalance panic: Fix panic message visibility by calling bust_spinlocks(0) before dying rcu: Replace the rcu_barrier enum with pointer to call_rcu*() function rcu: Clean up code based on review feedback from Josh Triplett, part 4 rcu: Clean up code based on review feedback from Josh Triplett, part 3 rcu: Fix rcu_lock_map build failure on CONFIG_PROVE_LOCKING=y rcu: Clean up code to address Ingo's checkpatch feedback rcu: Clean up code based on review feedback from Josh Triplett, part 2 rcu: Clean up code based on review feedback from Josh Triplett
2009-10-07futex: fix requeue_pi key imbalanceDarren Hart
If futex_wait_requeue_pi() wakes prior to requeue, we drop the reference to the source futex_key twice, once in handle_early_requeue_pi_wakeup() and once on our way out. Remove the drop from the handle_early_requeue_pi_wakeup() and keep the get/drops together in futex_wait_requeue_pi(). Reported-by: Helge Bahmann <hcb@chaoticmind.net> Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Cc: Helge Bahmann <hcb@chaoticmind.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Dinakar Guniguntala <dino@in.ibm.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: stable-2.6.31 <stable@kernel.org> LKML-Reference: <4ACCE21E.5030805@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-05futex: Fix locking imbalanceThomas Gleixner
Rich reported a lock imbalance in the futex code: http://bugzilla.kernel.org/show_bug.cgi?id=14288 It's caused by the displacement of the retry_private label in futex_wake_op(). The code unlocks the hash bucket locks in the error handling path and retries without locking them again which makes the next unlock fail. Move retry_private so we lock the hash bucket locks when we retry. Reported-by: Rich Ercolany <rercola@acm.jhu.edu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <dvhltc@us.ibm.com> Cc: stable-2.6.31 <stable@kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24futex: Add memory barrier commentary to futex_wait_queue_me()Darren Hart
The memory barrier semantics of futex_wait_queue_me() are non-obvious. Add some commentary to try and clarify it. Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Dinakar Guniguntala <dino@in.ibm.com> Cc: John Stultz <johnstul@us.ibm.com> LKML-Reference: <20090924185447.694.38948.stgit@Aeon> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22futex: Fix wakeup race by setting TASK_INTERRUPTIBLE before queue_me()Darren Hart
PI futexes do not use the same plist_node_empty() test for wakeup. It was possible for the waiter (in futex_wait_requeue_pi()) to set TASK_INTERRUPTIBLE after the waker assigned the rtmutex to the waiter. The waiter would then note the plist was not empty and call schedule(). The task would not be found by any subsequeuent futex wakeups, resulting in a userspace hang. By moving the setting of TASK_INTERRUPTIBLE to before the call to queue_me(), the race with the waker is eliminated. Since we no longer call get_user() from within queue_me(), there is no need to delay the setting of TASK_INTERRUPTIBLE until after the call to queue_me(). The FUTEX_LOCK_PI operation is not affected as futex_lock_pi() relies entirely on the rtmutex code to handle schedule() and wakeup. The requeue PI code is affected because the waiter starts as a non-PI waiter and is woken on a PI futex. Remove the crusty old comment about holding spinlocks() across get_user() as we no longer do that. Correct the locking statement with a description of why the test is performed. Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Dinakar Guniguntala <dino@in.ibm.com> Cc: John Stultz <johnstul@us.ibm.com> LKML-Reference: <20090922053038.8717.97838.stgit@Aeon> Signed-off-by: Ingo Molnar <mingo@elte.hu>
