path: root/kernel/futex.c
2015-07-20futex: Make should_fail_futex() statickbuild test robot
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: kbuild-all@01.org Cc: tipbuild@zytor.com Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Brian Silverman <bsilver16384@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-20futex: Fault/error injection capabilitiesDavidlohr Bueso
Although futexes are well known for being a royal pita, we really have very little debugging capabilities - except for relying on tglx's eye half the time. By simply making use of the existing fault-injection machinery, we can improve this situation, allowing generating artificial uaddress faults and deadlock scenarios. Of course, when this is disabled in production systems, the overhead for failure checks is practically zero -- so this is very cheap at the same time. Future work would be nice to now enhance trinity to make use of this. There is a special tunable 'ignore-private', which can filter out private futexes. Given the tsk->make_it_fail filter and this option, pi futexes can be narrowed down pretty closely. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Link: http://lkml.kernel.org/r/1435645562-975-3-git-send-email-dave@stgolabs.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-20futex: Enhance comments in futex_lock_pi() for blocking pathsDavidlohr Bueso
... serves a bit better to clarify between blocking and non-blocking code paths. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Link: http://lkml.kernel.org/r/1435645562-975-2-git-send-email-dave@stgolabs.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-24Merge branch 'sched-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Thomas Gleixner: "These locking updates depend on the alreay merged sched/core branch: - Lockless top waiter wakeup for rtmutex (Davidlohr) - Reduce hash bucket lock contention for PI futexes (Sebastian) - Documentation update (Davidlohr)" * 'sched-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/rtmutex: Update stale plist comments futex: Lower the lock contention on the HB lock during wake up locking/rtmutex: Implement lockless top-waiter wakeup
2015-06-22Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "A rather largish update for everything time and timer related: - Cache footprint optimizations for both hrtimers and timer wheel - Lower the NOHZ impact on systems which have NOHZ or timer migration disabled at runtime. - Optimize run time overhead of hrtimer interrupt by making the clock offset updates smarter - hrtimer cleanups and removal of restrictions to tackle some problems in sched/perf - Some more leap second tweaks - Another round of changes addressing the 2038 problem - First step to change the internals of clock event devices by introducing the necessary infrastructure - Allow constant folding for usecs/msecs_to_jiffies() - The usual pile of clockevent/clocksource driver updates The hrtimer changes contain updates to sched, perf and x86 as they depend on them plus changes all over the tree to cleanup API changes and redundant code, which got copied all over the place. The y2038 changes touch s390 to remove the last non 2038 safe code related to boot/persistant clock" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) clocksource: Increase dependencies of timer-stm32 to limit build wreckage timer: Minimize nohz off overhead timer: Reduce timer migration overhead if disabled timer: Stats: Simplify the flags handling timer: Replace timer base by a cpu index timer: Use hlist for the timer wheel hash buckets timer: Remove FIFO "guarantee" timers: Sanitize catchup_timer_jiffies() usage hrtimer: Allow hrtimer::function() to free the timer seqcount: Introduce raw_write_seqcount_barrier() seqcount: Rename write_seqcount_barrier() hrtimer: Fix hrtimer_is_queued() hole hrtimer: Remove HRTIMER_STATE_MIGRATE selftest: Timers: Avoid signal deadlock in leap-a-day timekeeping: Copy the shadow-timekeeper over the real timekeeper last clockevents: Check state instead of mode in suspend/resume path selftests: timers: Add leap-second timer edge testing to leap-a-day.c ntp: Do leapsecond adjustment in adjtimex read path time: Prevent early expiry of hrtimers[CLOCK_REALTIME] at the leap second edge ntp: Introduce and use SECS_PER_DAY macro instead of 86400 ...
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
2015-06-19futex: Lower the lock contention on the HB lock during wake upSebastian Andrzej Siewior
wake_futex_pi() wakes the task before releasing the hash bucket lock (HB). The first thing the woken up task usually does is to acquire the lock which requires the HB lock. On SMP Systems this leads to blocking on the HB lock which is released by the owner shortly after. This patch rearranges the unlock path by first releasing the HB lock and then waking up the task. [ tglx: Fixed up the rtmutex unlock path ] Originally-from: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Link: http://lkml.kernel.org/r/20150617083350.GA2433@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-19locking/arch: Rename set_mb() to smp_store_mb()Peter Zijlstra
Since set_mb() is really about an smp_mb() -- not a IO/DMA barrier like mb() rename it to match the recent smp_load_acquire() and smp_store_release(). Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-08futex: Implement lockless wakeupsDavidlohr Bueso
Given the overall futex architecture, any chance of reducing hb->lock contention is welcome. In this particular case, using wake-queues to enable lockless wakeups addresses very much real world performance concerns, even cases of soft-lockups in cases of large amounts of blocked tasks (which is not hard to find in large boxes, using but just a handful of futex). At the lowest level, this patch can reduce latency of a single thread attempting to acquire hb->lock in highly contended scenarios by a up to 2x. At lower counts of nr_wake there are no regressions, confirming, of course, that the wake_q handling overhead is practically non existent. For instance, while a fair amount of variation, the extended pef-bench wakeup benchmark shows for a 20 core machine the following avg per-thread time to wakeup its share of tasks: nr_thr ms-before ms-after 16 0.0590 0.0215 32 0.0396 0.0220 48 0.0417 0.0182 64 0.0536 0.0236 80 0.0414 0.0097 96 0.0672 0.0152 Naturally, this can cause spurious wakeups. However there is no core code that cannot handle them afaict, and furthermore tglx does have the point that other events can already trigger them anyway. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Chris Mason <clm@fb.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: George Spelvin <linux@horizon.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1430494072-30283-3-git-send-email-dave@stgolabs.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-22futex: Remove bogus hrtimer_active() checkThomas Gleixner
The check for hrtimer_active() after starting the timer is pointless. If the timer is inactive it has expired already and therefor the task pointer is already NULL. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203502.985825453@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-02-24Merge tag 'v4.0-rc1' into locking/core, to refresh the tree before merging ↵Ingo Molnar
new changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-18locking/futex: Check PF_KTHREAD rather than !p->mm to filter out kthreadsOleg Nesterov
attach_to_pi_owner() checks p->mm to prevent attaching to kthreads and this looks doubly wrong: 1. It should actually check PF_KTHREAD, kthread can do use_mm(). 2. If this task is not kthread and it is actually the lock owner we can wrongly return -EPERM instead of -ESRCH or retry-if-EAGAIN. And note that this wrong EPERM is the likely case unless the exiting task is (auto)reaped quickly, we check ->mm before PF_EXITING. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mateusz Guzik <mguzik@redhat.com> Link: http://lkml.kernel.org/r/20150202140536.GA26406@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-19futex: Fix argument handling in futex_lock_pi() callsMichael Kerrisk
This patch fixes two separate buglets in calls to futex_lock_pi(): * Eliminate unused 'detect' argument * Change unused 'timeout' argument of FUTEX_TRYLOCK_PI to NULL The 'detect' argument of futex_lock_pi() seems never to have been used (when it was included with the initial PI mutex implementation in Linux 2.6.18, all checks against its value were disabled by ANDing against 0 (i.e., if (detect... && 0)), and with commit 778e9a9c3e7193ea9f434f382947155ffb59c755, any mention of this argument in futex_lock_pi() went way altogether. Its presence now serves only to confuse readers of the code, by giving the impression that the futex() FUTEX_LOCK_PI operation actually does use the 'val' argument. This patch removes the argument. The futex_lock_pi() call that corresponds to FUTEX_TRYLOCK_PI includes 'timeout' as one of its arguments. This misleads the reader into thinking that the FUTEX_TRYLOCK_PI operation does employ timeouts for some sensible purpose; but it does not. Indeed, it cannot, because the checks at the start of sys_futex() exclude FUTEX_TRYLOCK_PI from the set of operations that do copy_from_user() on the timeout argument. So, in the FUTEX_TRYLOCK_PI futex_lock_pi() call it would be simplest to change 'timeout' to 'NULL'. This patch does that. Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Reviewed-by: Darren Hart <darren@dvhart.com> Link: http://lkml.kernel.org/r/54B96646.8010200@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-26futex: Fix a race condition between REQUEUE_PI and task deathBrian Silverman
free_pi_state and exit_pi_state_list both clean up futex_pi_state's. exit_pi_state_list takes the hb lock first, and most callers of free_pi_state do too. requeue_pi doesn't, which means free_pi_state can free the pi_state out from under exit_pi_state_list. For example: task A | task B exit_pi_state_list | pi_state = | curr->pi_state_list->next | | futex_requeue(requeue_pi=1) | // pi_state is the same as | // the one in task A | free_pi_state(pi_state) | list_del_init(&pi_state->list) | kfree(pi_state) list_del_init(&pi_state->list) | Move the free_pi_state calls in requeue_pi to before it drops the hb locks which it's already holding. [ tglx: Removed a pointless free_pi_state() call and the hb->lock held debugging. The latter comes via a seperate patch ] Signed-off-by: Brian Silverman <bsilver16384@gmail.com> Cc: austin.linux@gmail.com Cc: darren@dvhart.com Cc: peterz@infradead.org Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1414282837-23092-1-git-send-email-bsilver16384@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-26futex: Mention key referencing differences between shared and private futexesDavidlohr Bueso
Update our documentation as of fix 76835b0ebf8 (futex: Ensure get_futex_key_refs() always implies a barrier). Explicitly state that we don't do key referencing for private futexes. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Matteo Franchin <Matteo.Franchin@arm.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Link: http://lkml.kernel.org/r/1414121220.817.0.camel@linux-t7sj.site Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-18futex: Ensure get_futex_key_refs() always implies a barrierCatalin Marinas
Commit b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up) changes the futex code to avoid taking a lock when there are no waiters. This code has been subsequently fixed in commit 11d4616bd07f (futex: revert back to the explicit waiter counting code). Both the original commit and the fix-up rely on get_futex_key_refs() to always imply a barrier. However, for private futexes, none of the cases in the switch statement of get_futex_key_refs() would be hit and the function completes without a memory barrier as required before checking the "waiters" in futex_wake() -> hb_waiters_pending(). The consequence is a race with a thread waiting on a futex on another CPU, allowing the waker thread to read "waiters == 0" while the waiter thread to have read "futex_val == locked" (in kernel). Without this fix, the problem (user space deadlocks) can be seen with Android bionic's mutex implementation on an arm64 multi-cluster system. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Matteo Franchin <Matteo.Franchin@arm.com> Fixes: b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up) Acked-by: Davidlohr Bueso <dave@stgolabs.net> Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: <stable@vger.kernel.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-12futex: Unlock hb->lock in futex_wait_requeue_pi() error pathThomas Gleixner
futex_wait_requeue_pi() calls futex_wait_setup(). If futex_wait_setup() succeeds it returns with hb->lock held and preemption disabled. Now the sanity check after this does: if (match_futex(&q.key, &key2)) { ret = -EINVAL; goto out_put_keys; } which releases the keys but does not release hb->lock. So we happily return to user space with hb->lock held and therefor preemption disabled. Unlock hb->lock before taking the exit route. Reported-by: Dave "Trinity" Jones <davej@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409112318500.4178@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21futex: Simplify futex_lock_pi_atomic() and make it more robustThomas Gleixner
futex_lock_pi_atomic() is a maze of retry hoops and loops. Reduce it to simple and understandable states: First step is to lookup existing waiters (state) in the kernel. If there is an existing waiter, validate it and attach to it. If there is no existing waiter, check the user space value If the TID encoded in the user space value is 0, take over the futex preserving the owner died bit. If the TID encoded in the user space value is != 0, lookup the owner task, validate it and attach to it. Reduces text size by 128 bytes on x8664. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Kees Cook <kees@outflux.net> Cc: wad@chromium.org Cc: Darren Hart <darren@dvhart.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1406131137020.5170@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21futex: Split out the first waiter attachment from lookup_pi_state()Thomas Gleixner
We want to be a bit more clever in futex_lock_pi_atomic() and separate the possible states. Split out the code which attaches the first waiter to the owner into a separate function. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Kees Cook <kees@outflux.net> Cc: wad@chromium.org Link: http://lkml.kernel.org/r/20140611204237.271300614@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21futex: Split out the waiter check from lookup_pi_state()Thomas Gleixner
We want to be a bit more clever in futex_lock_pi_atomic() and separate the possible states. Split out the waiter verification into a separate function. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Kees Cook <kees@outflux.net> Cc: wad@chromium.org Link: http://lkml.kernel.org/r/20140611204237.180458410@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21futex: Use futex_top_waiter() in lookup_pi_state()Thomas Gleixner
No point in open coding the same function again. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Kees Cook <kees@outflux.net> Cc: wad@chromium.org Link: http://lkml.kernel.org/r/20140611204237.092947239@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21futex: Make unlock_pi more robustThomas Gleixner
The kernel tries to atomically unlock the futex without checking whether there is kernel state associated to the futex. So if user space manipulated the user space value, this will leave kernel internal state around associated to the owner task. For robustness sake, lookup first whether there are waiters on the futex. If there are waiters, wake the top priority waiter with all the proper sanity checks applied. If there are no waiters, do the atomic release. We do not have to preserve the waiters bit in this case, because a potentially incoming waiter is blocked on the hb->lock and will acquire the futex atomically. We neither have to preserve the owner died bit. The caller is the owner and it was supposed to cleanup the mess. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Kees Cook <kees@outflux.net> Cc: wad@chromium.org Link: http://lkml.kernel.org/r/20140611204237.016987332@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21rtmutex: Confine deadlock logic to futexThomas Gleixner
The deadlock logic is only required for futexes. Remove the extra arguments for the public functions and also for the futex specific ones which get always called with deadlock detection enabled. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
2014-06-08Merge branch 'next' (accumulated 3.16 merge window patches) into masterLinus Torvalds
Now that 3.15 is released, this merges the 'next' branch into 'master', bringing us to the normal situation where my 'master' branch is the merge window. * accumulated work in next: (6809 commits) ufs: sb mutex merge + mutex_destroy powerpc: update comments for generic idle conversion cris: update comments for generic idle conversion idle: remove cpu_idle() forward declarations nbd: zero from and len fields in NBD_CMD_DISCONNECT. mm: convert some level-less printks to pr_* MAINTAINERS: adi-buildroot-devel is moderated MAINTAINERS: add linux-api for review of API/ABI changes mm/kmemleak-test.c: use pr_fmt for logging fs/dlm/debug_fs.c: replace seq_printf by seq_puts fs/dlm/lockspace.c: convert simple_str to kstr fs/dlm/config.c: convert simple_str to kstr mm: mark remap_file_pages() syscall as deprecated mm: memcontrol: remove unnecessary memcg argument from soft limit functions mm: memcontrol: clean up memcg zoneinfo lookup mm/memblock.c: call kmemleak directly from memblock_(alloc|free) mm/mempool.c: update the kmemleak stack trace for mempool allocations lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations mm: introduce kmemleak_update_trace() mm/kmemleak.c: use %u to print ->checksum ...
2014-06-05futex: Make lookup_pi_state more robustThomas Gleixner
The current implementation of lookup_pi_state has ambigous handling of the TID value 0 in the user space futex. We can get into the kernel even if the TID value is 0, because either there is a stale waiters bit or the owner died bit is set or we are called from the requeue_pi path or from user space just for fun. The current code avoids an explicit sanity check for pid = 0 in case that kernel internal state (waiters) are found for the user space address. This can lead to state leakage and worse under some circumstances. Handle the cases explicit: Waiter | pi_state | pi->owner | uTID | uODIED | ? [1] NULL | --- | --- | 0 | 0/1 | Valid [2] NULL | --- | --- | >0 | 0/1 | Valid [3] Found | NULL | -- | Any | 0/1 | Invalid [4] Found | Found | NULL | 0 | 1 | Valid [5] Found | Found | NULL | >0 | 1 | Invalid [6] Found | Found | task | 0 | 1 | Valid [7] Found | Found | NULL | Any | 0 | Invalid [8] Found | Found | task | ==taskTID | 0/1 | Valid [9] Found | Found | task | 0 | 0 | Invalid [10] Found | Found | task | !=taskTID | 0/1 | Invalid [1] Indicates that the kernel can acquire the futex atomically. We came came here due to a stale FUTEX_WAITERS/FUTEX_OWNER_DIED bit. [2] Valid, if TID does not belong to a kernel thread. If no matching thread is found then it indicates that the owner TID has died. [3] Invalid. The waiter is queued on a non PI futex [4] Valid state after exit_robust_list(), which sets the user space value to FUTEX_WAITERS | FUTEX_OWNER_DIED. [5] The user space value got manipulated between exit_robust_list() and exit_pi_state_list() [6] Valid state after exit_pi_state_list() which sets the new owner in the pi_state but cannot access the user space value. [7] pi_state->owner can only be NULL when the OWNER_DIED bit is set. [8] Owner and user space value match [9] There is no transient state which sets the user space TID to 0 except exit_robust_list(), but this is indicated by the FUTEX_OWNER_DIED bit. See [4] [10] There is no transient state which leaves owner and user space TID out of sync. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kees Cook <keescook@chromium.org> Cc: Will Drewry <wad@chromium.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05futex: Always cleanup owner tid in unlock_piThomas Gleixner
If the owner died bit is set at futex_unlock_pi, we currently do not cleanup the user space futex. So the owner TID of the current owner (the unlocker) persists. That's observable inconsistant state, especially when the ownership of the pi state got transferred. Clean it up unconditionally. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kees Cook <keescook@chromium.org> Cc: Will Drewry <wad@chromium.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05futex: Validate atomic acquisition in futex_lock_pi_atomic()Thomas Gleixner
We need to protect the atomic acquisition in the kernel against rogue user space which sets the user space futex to 0, so the kernel side acquisition succeeds while there is existing state in the kernel associated to the real owner. Verify whether the futex has waiters associated with kernel state. If it has, return -EINVAL. The state is corrupted already, so no point in cleaning it up. Subsequent calls will fail as well. Not our problem. [ tglx: Use futex_top_waiter() and explain why we do not need to try restoring the already corrupted user space state. ] Signed-off-by: Darren Hart <dvhart@linux.intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Will Drewry <wad@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05futex-prevent-requeue-pi-on-same-futex.patch futex: Forbid uaddr == uaddr2 ↵Thomas Gleixner
in futex_requeue(..., requeue_pi=1) If uaddr == uaddr2, then we have broken the rule of only requeueing from a non-pi futex to a pi futex with this call. If we attempt this, then dangling pointers may be left for rt_waiter resulting in an exploitable condition. This change brings futex_requeue() in line with futex_wait_requeue_pi() which performs the same check as per commit 6f7b0a2a5c0f ("futex: Forbid uaddr == uaddr2 in futex_wait_requeue_pi()") [ tglx: Compare the resulting keys as well, as uaddrs might be different depending on the mapping ] Fixes CVE-2014-3153. Reported-by: Pinkie Pie Signed-off-by: Will Drewry <wad@chromium.org> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
2014-05-19futex: Prevent attaching to kernel threadsThomas Gleixner
We happily allow userspace to declare a random kernel thread to be the owner of a user space PI futex. Found while analysing the fallout of Dave Jones syscall fuzzer. We also should validate the thread group for private futexes and find some fast way to validate whether the "alleged" owner has RW access on the file which backs the SHM, but that's a separate issue. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Clark Williams <williams@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Carlos ODonell <carlos@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: http://lkml.kernel.org/r/20140512201701.194824402@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2014-05-19futex: Add another early deadlock detection checkThomas Gleixner
Dave Jones trinity syscall fuzzer exposed an issue in the deadlock detection code of rtmutex: http://lkml.kernel.org/r/20140429151655.GA14277@redhat.com That underlying issue has been fixed with a patch to the rtmutex code, but the futex code must not call into rtmutex in that case because - it can detect that issue early - it avoids a different and more complex fixup for backing out If the user space variable got manipulated to 0x80000000 which means no lock holder, but the waiters bit set and an active pi_state in the kernel is found we can figure out the recursive locking issue by looking at the pi_state owner. If that is the current task, then we can safely return -EDEADLK. The check should have been added in commit 59fa62451 (futex: Handle futex_pi OWNER_DIED take over correctly) already, but I did not see the above issue caused by user space manipulation back then. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Darren Hart <darren@dvhart.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Clark Williams <williams@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Carlos ODonell <carlos@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: http://lkml.kernel.org/r/20140512201701.097349971@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-12futex: update documentation for ordering guaranteesDavidlohr Bueso
Commits 11d4616bd07f ("futex: revert back to the explicit waiter counting code") and 69cd9eba3886 ("futex: avoid race between requeue and wake") changed some of the finer details of how we think about futexes. One was a late fix and the other a consequence of overlooking the whole requeuing logic. The first change caused our documentation to be incorrect, and the second made us aware that we need to explicitly add more details to it. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-09futex: avoid race between requeue and wakeLinus Torvalds
Jan Stancek reported: "pthread_cond_broadcast/4-1.c testcase from openposix testsuite (LTP) occasionally fails, because some threads fail to wake up. Testcase creates 5 threads, which are all waiting on same condition. Main thread then calls pthread_cond_broadcast() without holding mutex, which calls: futex(uaddr1, FUTEX_CMP_REQUEUE_PRIVATE, 1, 2147483647, uaddr2, ..) This immediately wakes up single thread A, which unlocks mutex and tries to wake up another thread: futex(uaddr2, FUTEX_WAKE_PRIVATE, 1) If thread A manages to call futex_wake() before any waiters are requeued for uaddr2, no other thread is woken up" The ordering constraints for the hash bucket waiter counting are that the waiter counts have to be incremented _before_ getting the spinlock (because the spinlock acts as part of the memory barrier), but the "requeue" operation didn't honor those rules, and nobody had even thought about that case. This fairly simple patch just increments the waiter count for the target hash bucket (hb2) when requeing a futex before taking the locks. It then decrements them again after releasing the lock - the code that actually moves the futex(es) between hash buckets will do the additional required waiter count housekeeping. Reported-and-tested-by: Jan Stancek <jstancek@redhat.com> Acked-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org # 3.14 Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-31Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Ingo Molnar: "The biggest change is the MCS spinlock generalization changes from Tim Chen, Peter Zijlstra, Jason Low et al. There's also lockdep fixes/enhancements from Oleg Nesterov, in particular a false negative fix related to lockdep_set_novalidate_class() usage" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits) locking/mutex: Fix debug checks locking/mutexes: Add extra reschedule point locking/mutexes: Introduce cancelable MCS lock for adaptive spinning locking/mutexes: Unlock the mutex without the wait_lock locking/mutexes: Modify the way optimistic spinners are queued locking/mutexes: Return false if task need_resched() in mutex_can_spin_on_owner() locking: Move mcs_spinlock.h into kernel/locking/ m68k: Skip futex_atomic_cmpxchg_inatomic() test futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() test Revert "sched/wait: Suppress Sparse 'variable shadowing' warning" lockdep: Change lockdep_set_novalidate_class() to use _and_name lockdep: Change mark_held_locks() to check hlock->check instead of lockdep_no_validate lockdep: Don't create the wrong dependency on hlock->check == 0 lockdep: Make held_lock->check and "int check" argument bool locking/mcs: Allow architecture specific asm files to be used for contended case locking/mcs: Order the header files in Kbuild of each architecture in alphabetical order sched/wait: Suppress Sparse 'variable shadowing' warning hung_task/Documentation: Fix hung_task_warnings description locking/mcs: Allow architectures to hook in to contended paths locking/mcs: Micro-optimize the MCS code, add extra comments ...
2014-03-20futex: revert back to the explicit waiter counting codeLinus Torvalds
Srikar Dronamraju reports that commit b0c29f79ecea ("futexes: Avoid taking the hb->lock if there's nothing to wake up") causes java threads getting stuck on futexes when runing specjbb on a power7 numa box. The cause appears to be that the powerpc spinlocks aren't using the same ticket lock model that we use on x86 (and other) architectures, which in turn result in the "spin_is_locked()" test in hb_waiters_pending() occasionally reporting an unlocked spinlock even when there are pending waiters. So this reinstates Davidlohr Bueso's original explicit waiter counting code, which I had convinced Davidlohr to drop in favor of figuring out the pending waiters by just using the existing state of the spinlock and the wait queue. Reported-and-tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Original-code-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-03futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() testHeiko Carstens
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there is no runtime check necessary, allow to skip the test within futex_init(). This allows to get rid of some code which would always give the same result, and also allows the compiler to optimize a couple of if statements away. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-01-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: - Add the initial implementation of SCHED_DEADLINE support: a real-time scheduling policy where tasks that meet their deadlines and periodically execute their instances in less than their runtime quota see real-time scheduling and won't miss any of their deadlines. Tasks that go over their quota get delayed (Available to privileged users for now) - Clean up and fix preempt_enable_no_resched() abuse all around the tree - Do sched_clock() performance optimizations on x86 and elsewhere - Fix and improve auto-NUMA balancing - Fix and clean up the idle loop - Apply various cleanups and fixes * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (60 commits) sched: Fix __sched_setscheduler() nice test sched: Move SCHED_RESET_ON_FORK into attr::sched_flags sched: Fix up attr::sched_priority warning sched: Fix up scheduler syscall LTP fails sched: Preserve the nice level over sched_setscheduler() and sched_setparam() calls sched/core: Fix htmldocs warnings sched/deadline: No need to check p if dl_se is valid sched/deadline: Remove unused variables sched/deadline: Fix sparse static warnings m68k: Fix build warning in mac_via.h sched, thermal: Clean up preempt_enable_no_resched() abuse sched, net: Fixup busy_loop_us_clock() sched, net: Clean up preempt_enable_no_resched() abuse sched/preempt: Fix up missed PREEMPT_NEED_RESCHED folding sched/preempt, locking: Rework local_bh_{dis,en}able() sched/clock, x86: Avoid a runtime condition in native_sched_clock() sched/clock: Fix up clear_sched_clock_stable() sched/clock, x86: Use a static_key for sched_clock_stable sched/clock: Remove local_irq_disable() from the clocks sched/clock, x86: Rewrite cyc2ns() to avoid the need to disable IRQs ...
2014-01-16futexes: Fix futex_hashsize initializationHeiko Carstens
"futexes: Increase hash table size for better performance" introduces a new alloc_large_system_hash() call. alloc_large_system_hash() however may allocate less memory than requested, e.g. limited by MAX_ORDER. Hence pass a pointer to alloc_large_system_hash() which will contain the hash shift when the function returns. Afterwards correctly set futex_hashsize. Fixes a crash on s390 where the requested allocation size was 4MB but only 1MB was allocated. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Jason Low <jason.low2@hp.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Link: http://lkml.kernel.org/r/20140116135450.GA4345@osiris Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13rtmutex: Turn the plist into an rb-treePeter Zijlstra
Turn the pi-chains from plist to rb-tree, in the rt_mutex code, and provide a proper comparison function for -deadline and -priority tasks. This is done mainly because: - classical prio field of the plist is just an int, which might not be enough for representing a deadline; - manipulating such a list would become O(nr_deadline_tasks), which might be to much, as the number of -deadline task increases. Therefore, an rb-tree is used, and tasks are queued in it according to the following logic: - among two -priority (i.e., SCHED_BATCH/OTHER/RR/FIFO) tasks, the one with the higher (lower, actually!) prio wins; - among a -priority and a -deadline task, the latter always wins; - among two -deadline tasks, the one with the earliest deadline wins. Queueing and dequeueing functions are changed accordingly, for both the list of a task's pi-waiters and the list of tasks blocked on a pi-lock. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Dario Faggioli <raistlin@linux.it> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-again-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1383831828-15501-10-git-send-email-juri.lelli@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13futexes: Avoid taking the hb->lock if there's nothing to wake upDavidlohr Bueso
In futex_wake() there is clearly no point in taking the hb->lock if we know beforehand that there are no tasks to be woken. While the hash bucket's plist head is a cheap way of knowing this, we cannot rely 100% on it as there is a racy window between the futex_wait call and when the task is actually added to the plist. To this end, we couple it with the spinlock check as tasks trying to enter the critical region are most likely potential waiters that will be added to the plist, thus preventing tasks sleeping forever if wakers don't acknowledge all possible waiters. Furthermore, the futex ordering guarantees are preserved, ensuring that waiters either observe the changed user space value before blocking or is woken by a concurrent waker. For wakers, this is done by relying on the barriers in get_futex_key_refs() -- for archs that do not have implicit mb in atomic_inc(), we explicitly add them through a new futex_get_mm function. For waiters we rely on the fact that spin_lock calls already update the head counter, so spinners are visible even if the lock hasn't been acquired yet. For more details please refer to the updated comments in the code and related discussion: https://lkml.org/lkml/2013/11/26/556 Special thanks to tglx for careful review and feedback. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Scott Norton <scott.norton@hp.com> Cc: Tom Vaden <tom.vaden@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Jason Low <jason.low2@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1389569486-25487-5-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13futexes: Document multiprocessor ordering guaranteesThomas Gleixner
That's essential, if you want to hack on futexes. Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Scott Norton <scott.norton@hp.com> Cc: Tom Vaden <tom.vaden@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Jason Low <jason.low2@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1389569486-25487-4-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13futexes: Increase hash table size for better performanceDavidlohr Bueso
Currently, the futex global hash table suffers from its fixed, smallish (for today's standards) size of 256 entries, as well as its lack of NUMA awareness. Large systems, using many futexes, can be prone to high amounts of collisions; where these futexes hash to the same bucket and lead to extra contention on the same hb->lock. Furthermore, cacheline bouncing is a reality when we have multiple hb->locks residing on the same cacheline and different futexes hash to adjacent buckets. This patch keeps the current static size of 16 entries for small systems, or otherwise, 256 * ncpus (or larger as we need to round the number to a power of 2). Note that this number of CPUs accounts for all CPUs that can ever be available in the system, taking into consideration things like hotpluging. While we do impose extra overhead at bootup by making the hash table larger, this is a one time thing, and does not shadow the benefits of this patch. Furthermore, as suggested by tglx, by cache aligning the hash buckets we can avoid access across cacheline boundaries and also avoid massive cache line bouncing if multiple cpus are hammering away at different hash buckets which happen to reside in the same cache line. Also, similar to other core kernel components (pid, dcache, tcp), by using alloc_large_system_hash() we benefit from its NUMA awareness and thus the table is distributed among the nodes instead of in a single one. For a custom microbenchmark that pounds on the uaddr hashing -- making the wait path fail at futex_wait_setup() returning -EWOULDBLOCK for large amounts of futexes, we can see the following benefits on a 80-core, 8-socket 1Tb server: +---------+--------------------+------------------------+-----------------------+-------------------------------+ | threads | baseline (ops/sec) | aligned-only (ops/sec) | large table (ops/sec) | large table+aligned (ops/sec) | +---------+--------------------+------------------------+-----------------------+-------------------------------+ |     512 |              32426 | 50531  (+55.8%)        | 255274  (+687.2%)     | 292553  (+802.2%)             | |     256 |              65360 | 99588  (+52.3%)        | 443563  (+578.6%)     | 508088  (+677.3%)             | |     128 |             125635 | 200075 (+59.2%)        | 742613  (+491.1%)     | 835452  (+564.9%)             | |      80 |             193559 | 323425 (+67.1%)        | 1028147 (+431.1%)     | 1130304 (+483.9%)             | |      64 |             247667 | 443740 (+79.1%)        | 997300  (+302.6%)     | 1145494 (+362.5%)             | |      32 |             628412 | 721401 (+14.7%)        | 965996  (+53.7%)      | 1122115 (+78.5%)              | +---------+--------------------+------------------------+-----------------------+-------------------------------+ Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Waiman Long <Waiman.Long@hp.com> Reviewed-and-tested-by: Jason Low <jason.low2@hp.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Scott Norton <scott.norton@hp.com> Cc: Tom Vaden <tom.vaden@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Link: http://lkml.kernel.org/r/1389569486-25487-3-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13futexes: Clean up various detailsJason Low
- Remove unnecessary head variables. - Delete unused parameter in queue_unlock(). Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jason Low <jason.low2@hp.com> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Scott Norton <scott.norton@hp.com> Cc: Tom Vaden <tom.vaden@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1389569486-25487-2-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-12futex: move user address verification up to common codeLinus Torvalds
When debugging the read-only hugepage case, I was confused by the fact that get_futex_key() did an access_ok() only for the non-shared futex case, since the user address checking really isn't in any way specific to the private key handling. Now, it turns out that the shared key handling does effectively do the equivalent checks inside get_user_pages_fast() (it doesn't actually check the address range on x86, but does check the page protections for being a user page). So it wasn't actually a bug, but the fact that we treat the address differently for private and shared futexes threw me for a loop. Just move the check up, so that it gets done for both cases. Also, use the 'rw' parameter for the type, even if it doesn't actually matter any more (it's a historical artifact of the old racy i386 "page faults from kernel space don't check write protections"). Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12futex: fix handling of read-only-mapped hugepagesLinus Torvalds
The hugepage code had the exact same bug that regular pages had in commit 7485d0d3758e ("futexes: Remove rw parameter from get_futex_key()"). The regular page case was fixed by commit 9ea71503a8ed ("futex: Fix regression with read only mappings"), but the transparent hugepage case (added in a5b338f2b0b1: "thp: update futex compound knowledge") case remained broken. Found by Dave Jones and his trinity tool. Reported-and-tested-by: Dave Jones <davej@fedoraproject.org> Cc: stable@kernel.org # v2.6.38+ Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mel Gorman <mgorman@suse.de> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-06locking: Move the rtmutex code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-p9ijt8div0hwldexwfm4nlhj@git.kernel.org [ Fixed build failure in kernel/rcu/tree_plugin.h. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-25futex: Use freezable blocking callColin Cross
Avoid waking up every thread sleeping in a futex_wait call during suspend and resume by calling a freezable blocking call. Previous patches modified the freezer to avoid sending wakeups to threads that are blocked in freezable blocking calls. This call was selected to be converted to a freezable call because it doesn't hold any locks or release any resources when interrupted that might be needed by another freezing task or a kernel driver during suspend, and is a common site where idle userspace tasks are blocked. Signed-off-by: Colin Cross <ccross@android.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: arve@android.com Cc: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Link: http://lkml.kernel.org/r/1367458508-9133-8-git-send-email-ccross@android.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-25futex: Take hugepages into account when generating futex_keyZhang Yi
The futex_keys of process shared futexes are generated from the page offset, the mapping host and the mapping index of the futex user space address. This should result in an unique identifier for each futex. Though this is not true when futexes are located in different subpages of an hugepage. The reason is, that the mapping index for all those futexes evaluates to the index of the base page of the hugetlbfs mapping. So a futex at offset 0 of the hugepage mapping and another one at offset PAGE_SIZE of the same hugepage mapping have identical futex_keys. This happens because the futex code blindly uses page->index. Steps to reproduce the bug: 1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0 and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs mapping. The mutexes must be initialized as PTHREAD_PROCESS_SHARED because PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as their keys solely depend on the user space address. 2. Lock mutex1 and mutex2 3. Create thread1 and in the thread function lock mutex1, which results in thread1 blocking on the locked mutex1. 4. Create thread2 and in the thread function lock mutex2, which results in thread2 blocking on the locked mutex2. 5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2 still blocks on mutex2 because the futex_key points to mutex1. To solve this issue we need to take the normal page index of the page which contains the futex into account, if the futex is in an hugetlbfs mapping. In other words, we calculate the normal page mapping index of the subpage in the hugetlbfs mapping. Mappings which are not based on hugetlbfs are not affected and still use page->index. Thanks to Mel Gorman who provided a patch for adding proper evaluation functions to the hugetlbfs code to avoid exposing hugetlbfs specific details to the futex code. [ tglx: Massaged changelog ] Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn> Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn> Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn> Reviewed-by: 'Mel Gorman' <mgorman@suse.de> Acked-by: 'Darren Hart' <dvhart@linux.intel.com> Cc: 'Peter Zijlstra' <peterz@infradead.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
