path: root/kernel/groups.c
2016-10-07cred: simpler, 1D supplementary groupsAlexey Dobriyan
Current supplementary groups code can massively overallocate memory and is implemented in a way so that access to individual gid is done via 2D array. If number of gids is <= 32, memory allocation is more or less tolerable (140/148 bytes). But if it is not, code allocates full page (!) regardless and, what's even more fun, doesn't reuse small 32-entry array. 2D array means dependent shifts, loads and LEAs without possibility to optimize them (gid is never known at compile time). All of the above is unnecessary. Switch to the usual trailing-zero-len-array scheme. Memory is allocated with kmalloc/vmalloc() and only as much as needed. Accesses become simpler (LEA 8(gi,idx,4) or even without displacement). Maximum number of gids is 65536 which translates to 256KB+8 bytes. I think kernel can handle such allocation. On my usual desktop system with whole 9 (nine) aux groups, struct group_info shrinks from 148 bytes to 44 bytes, yay! Nice side effects: - "gi->gid[i]" is shorter than "GROUP_AT(gi, i)", less typing, - fix little mess in net/ipv4/ping.c should have been using GROUP_AT macro but this point becomes moot, - aux group allocation is persistent and should be accounted as such. Link: http://lkml.kernel.org/r/20160817201927.GA2096@p183.telecom.by Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15kernel: conditionally support non-root users, groups and capabilitiesIulia Manda
There are a lot of embedded systems that run most or all of their functionality in init, running as root:root. For these systems, supporting multiple users is not necessary. This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for non-root users, non-root groups, and capabilities optional. It is enabled under CONFIG_EXPERT menu. When this symbol is not defined, UID and GID are zero in any possible case and processes always have all capabilities. The following syscalls are compiled out: setuid, setregid, setgid, setreuid, setresuid, getresuid, setresgid, getresgid, setgroups, getgroups, setfsuid, setfsgid, capget, capset. Also, groups.c is compiled out completely. In kernel/capability.c, capable function was moved in order to avoid adding two ifdef blocks. This change saves about 25 KB on a defconfig build. The most minimal kernels have total text sizes in the high hundreds of kB rather than low MB. (The 25k goes down a bit with allnoconfig, but not that much. The kernel was booted in Qemu. All the common functionalities work. Adding users/groups is not possible, failing with -ENOSYS. Bloat-o-meter output: add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Iulia Manda <iulia.manda21@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-09userns: Don't allow setgroups until a gid mapping has been setablishedEric W. Biederman
setgroups is unique in not needing a valid mapping before it can be called, in the case of setgroups(0, NULL) which drops all supplemental groups. The design of the user namespace assumes that CAP_SETGID can not actually be used until a gid mapping is established. Therefore add a helper function to see if the user namespace gid mapping has been established and call that function in the setgroups permission check. This is part of the fix for CVE-2014-8989, being able to drop groups without privilege using user namespaces. Cc: stable@vger.kernel.org Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-12-05groups: Consolidate the setgroups permission checksEric W. Biederman
Today there are 3 instances of setgroups and due to an oversight their permission checking has diverged. Add a common function so that they may all share the same permission checking code. This corrects the current oversight in the current permission checks and adds a helper to avoid this in the future. A user namespace security fix will update this new helper, shortly. Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-04-03kernel/groups.c: remove return value of set_groupsWang YanQing
After commit 6307f8fee295 ("security: remove dead hook task_setgroups"), set_groups will always return zero, so we could just remove return value of set_groups. This patch reduces code size, and simplfies code to use set_groups, because we don't need to check its return value any more. [akpm@linux-foundation.org: remove obsolete claims from set_groups() comment] Signed-off-by: Wang YanQing <udknight@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-30userns: Kill nsown_capable it makes the wrong thing easyEric W. Biederman
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and CAP_SETGID. For the existing users it doesn't noticably simplify things and from the suggested patches I have seen it encourages people to do the wrong thing. So remove nsown_capable. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-05-03userns: Convert in_group_p and in_egroup_p to use kgid_tEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-03userns: Convert group_info values from gid_t to kgid_t.Eric W. Biederman
As a first step to converting struct cred to be all kuid_t and kgid_t values convert the group values stored in group_info to always be kgid_t values. Unless user namespaces are used this change should have no effect. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09kernel/groups.c: fix integer overflow in groups_searchJerome Marchand
gid_t is a unsigned int. If group_info contains a gid greater than MAX_INT, groups_search() function may look on the wrong side of the search tree. This solves some unfair "permission denied" problems. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12security: remove dead hook task_setgroupsEric Paris
Unused hook. Remove. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-16groups: move code to kernel/groups.cAlexey Dobriyan
Move supplementary groups implementation to kernel/groups.c . kernel/sys.c already accumulated quite a few random stuff. Do strictly copy/paste + add required headers to compile. Compile-tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
