patch 62f0f61e6673e67151a7c8c0f9a09c7ea43fe2b5 in mainline
Relative hrtimers with a large timeout value might end up as negative
timer values, when the current time is added in hrtimer_start().
This in turn is causing the clockevents_set_next() function to set an
huge timeout and sleep for quite a long time when we have a clock
source which is capable of long sleeps like HPET. With PIT this almost
goes unnoticed as the maximum delta is ~27ms. The non-hrt/nohz code
sorts this out in the next timer interrupt, so we never noticed that
problem which has been there since the first day of hrtimers.
This bug became more apparent in 2.6.24 which activates HPET on more
hardware.
Since nonboot CPUs are now disabled after tasks and devices have been
frozen and the CPU hotplug infrastructure is used for this purpose, we need
special CPU hotplug notifications that will help the CPU-hotplug-aware
subsystems distinguish normal CPU hotplug events from CPU hotplug events
related to a system-wide suspend or resume operation in progress. This
patch introduces such notifications and causes them to be used during
suspend and resume transitions. It also changes all of the
CPU-hotplug-aware subsystems to take these notifications into consideration
(for now they are handled in the same way as the corresponding "normal"
ones).
[oleg@tv-sign.ru: cleanups]
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Other symbols of the hrtimers API are already exported.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Fix miscellaneous networking compilation errors.
(*) Export ktime_add_ns() for modules.
(*) wext_proc_init() should have an ANSI declaration.
Get rid of the manual clock source selection mess and use ktime. Also
use a scalar representation, which allows to clean up pkt_sched.h a bit
more and results in less ktime_to_ns() calls in most cases.
The PSCHED_US2JIFFIE/PSCHED_JIFFIE2US macros are implemented quite
inefficient by this patch, following patches will convert all qdiscs
to hrtimers and get rid of them entirely.
Soeren Sonnenburg reported that upon resume he is getting
this backtrace:
[<c0119637>] smp_apic_timer_interrupt+0x57/0x90
[<c0142d30>] retrigger_next_event+0x0/0xb0
[<c0104d30>] apic_timer_interrupt+0x28/0x30
[<c0140068>] __kfifo_put+0x8/0x90
[<c0130fe5>] on_each_cpu+0x35/0x60
[<c0143538>] clock_was_set+0x18/0x20
[<c0135cdc>] timekeeping_resume+0x7c/0xa0
[<c02aabe1>] __sysdev_resume+0x11/0x80
[<c02ab0c7>] sysdev_resume+0x47/0x80
[<c02b0b05>] device_power_up+0x5/0x10
it turns out that on resume we mistakenly re-enable interrupts too
early. Do the timer retrigger only on the current CPU.
Acked-by: Soeren Sonnenburg <kernel@nn7.de>
hrtimer_start() incorrectly set the 'reprogram' flag to enqueue_hrtimer(),
which should only be 1 if the hrtimer is queued to the current CPU.
Doing otherwise could result in a reprogramming of the current CPU's
clockevents device, with a timer that is not queued to it - resulting in a
bogus next expiry value.
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
commit f4304ab21513b834c8fe3403927c60c2b81a72d7 (HZ free NTP) moved the
access to wall_to_monotonic in hrtimer_get_softirq_time() out of the
xtime_lock protection.
Move it back into the seq_lock section.
Acked-by: John Stultz <johnstul@us.ibm.com>
hrtimer_forward() does not check for the possible overflow of
timer->expires. This can happen on 64 bit machines with large interval
values and results currently in an endless loop in the softirq because the
expiry value becomes negative and therefor the timer is expired all the
time.
Check for this condition and set the expiry value to the max. expiry time
in the future. The fix should be applied to stable kernel series as well.
Cc: <stable@kernel.org>
The TIMER_SOFTIRQ runs the hrtimers during bootup until a usable
clocksource and clock event sources are registered. The switch to high
resolution mode happens inside of the TIMER_SOFTIRQ, but runs the softirq
afterwards. That way the tick emulation timer, which was set up in the
switch to highres might be executed in the softirq context, which is a BUG.
The rbtree has not to be touched by the softirq after the highres switch.
This BUG was observed by Andres Salomon, who provided the information to
debug it.
Return early from the softirq, when the switch was sucessful.
[dilinger@debian.org: add debug warning]
[akpm@linux-foundation.org: make debug warning compile]
Cc: Andres Salomon <dilinger@debian.org>
Signed-off-by: Andres Salomon <dilinger@debian.org>
Doing something like this on a two cpu system
# echo 0 > /sys/devices/system/cpu/cpu0/online
# echo 1 > /sys/devices/system/cpu/cpu0/online
# echo 0 > /sys/devices/system/cpu/cpu1/online
will give me this:
[ INFO: possible circular locking dependency detected ]
2.6.21-rc2-g562aa1d4-dirty #7
bash/1282 is trying to acquire lock:
(&cpu_base->lock_key){.+..}, at: [<000000000005f17e>] hrtimer_cpu_notify+0xc6/0x240
but task is already holding lock:
(&cpu_base->lock_key#2){.+..}, at: [<000000000005f174>] hrtimer_cpu_notify+0xbc/0x240
which lock already depends on the new lock.
This happens because we have the following code in kernel/hrtimer.c:
migrate_hrtimers(int cpu)
old_base = &per_cpu(hrtimer_bases, cpu);
new_base = &get_cpu_var(hrtimer_bases);
spin_lock(&new_base->lock);
spin_lock(&old_base->lock);
Which means the spinlocks are taken in an order which depends on which cpu
gets shut down from which other cpu. Therefore lockdep complains that there
might be an ABBA deadlock. Since migrate_hrtimers() gets only called on
cpu hotplug it's safe to assume that it isn't executed concurrently on a
The same problem exists in kernel/timer.c: migrate_timers().
As pointed out by Christian Borntraeger one possible solution to avoid
the locking order complaints would be to make sure that the locks are
always taken in the same order. E.g. by taking the lock of the cpu with
the lower number first.
To achieve this we introduce two new spinlock functions double_spin_lock
and double_spin_unlock which lock or unlock two locks in a given order.
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: John Stultz <johnstul@us.ibm.com>
Cc: Christian Borntraeger <cborntra@de.ibm.com>
Add /proc/timer_stats support: debugging feature to profile timer expiration.
Both the starting site, process/PID and the expiration function is captured.
This allows the quick identification of timer event sources in a system.
Sample output:
# echo 1 > /proc/timer_stats
# cat /proc/timer_stats
Timer Stats Version: v0.1
Sample period: 4.010 s
24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
11, 0 swapper sk_reset_timer (tcp_delack_timer)
6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn)
17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
4, 2050 pcscd do_nanosleep (hrtimer_wakeup)
5, 4179 sshd sk_reset_timer (tcp_write_timer)
4, 2248 yum-updatesd schedule_timeout (process_timeout)
18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
3, 0 swapper sk_reset_timer (tcp_delack_timer)
1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer)
2, 1 swapper e1000_up (e1000_watchdog)
1, 1 init schedule_timeout (process_timeout)
100 total events, 25.24 events/sec
[ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ]
[bunk@stusta.de: nr_entries can become static]
Cc: john stultz <johnstul@us.ibm.com>
Cc: Andi Kleen <ak@suse.de>
Implement high resolution timers on top of the hrtimers infrastructure and the
clockevents / tick-management framework. This provides accurate timers for
all hrtimer subsystem users.
With Ingo Molnar <mingo@elte.hu>
Add functions to provide dynamic ticks and high resolution timers. The code
which keeps track of jiffies and handles the long idle periods is shared
between tick based and high resolution timer based dynticks. The dyntick
functionality can be disabled on the kernel commandline. Provide also the
infrastructure to support high resolution timers.
Architectures register their clock event devices, in the clock events core.
Users of the clockevents core can get clock event devices for their use. The
clockevents core code provides notification mechanisms for various clock
related management events.
This allows to control the clock event devices without the architectures
having to worry about the details of function assignment. This is also a
preliminary for high resolution timers and dynamic ticks to allow the core
code to control the clock functionality without intrusive changes to the
architecture code.
[Fixes-by: Ingo Molnar <mingo@elte.hu>]
Reintroduce ktimers feature "optimized away" by the ktimers review process:
remove the curr_timer pointer from the cpu-base and use the hrtimer state.
No functional changes.
multiple hrtimer states to enable the running of hrtimers without holding the
cpu-base-lock.
(The "optimized" rbtree hack carried only 2 states worth of information and we
need 4 for high resolution timers and dynamic ticks.)
Build-fixes-from: Andrew Morton <akpm@osdl.org>
Improve kernel/hrtimers.c locking: use a per-CPU base with a lock to control
locking of all clocks belonging to a CPU. This simplifies code that needs to
lock all clocks at once. This makes life easier for high-res timers and
dyntick.
[ optimization change from Andrew Morton <akpm@osdl.org> ]
- hrtimers did not use the hrtimer_restart enum and relied on the implict
int representation. Fix the prototypes and the functions using the enums.
- Use seperate name spaces for the enumerations
- Convert hrtimer_restart macro to inline function
- Add comments
[akpm@osdl.org: fix input driver]
Cc: Dmitry Torokhov <dtor@mail.ru>
For CONFIG_NO_HZ we need to calculate the next timer wheel event based on a
given jiffie value. Extend the existing code to allow the extra 'now'
argument. Provide a compability function for the existing implementations to
call the function with now == jiffies. (This also solves the racyness of the
original code vs. jiffies changing during the iteration.)
No functional changes to existing users of this infrastructure.
[ remove WARN_ON() that triggered on s390, by Carsten Otte <cotte@de.ibm.com> ]
[ made new helper static, Adrian Bunk <bunk@stusta.de> ]
Persistent clock support: do proper timekeeping across suspend/resume.
[bunk@stusta.de: cleanup]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Cc: Adrian Bunk <bunk@stusta.de>
Distangle the NTP update from HZ. This is necessary for dynamic tick enabled
kernels.
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in
source files, including:
* make multi-line initial descriptions single line
* denote some function names, constants and structs as such
* change erroneous opening '/*' to '/**' in a few places
* reword some text for clarity
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
time in compatibility mode
The clock_nanosleep() function does not return the time remaining when the
sleep is interrupted by a signal.
This patch creates a new call out, compat_clock_nanosleep_restart(), which
handles returning the remaining time after a sleep is interrupted. This
patch revives clock_nanosleep_restart(). It is now accessed via the new
call out. The compat_clock_nanosleep_restart() is used for compatibility
access.
Since this is implemented in compatibility mode the normal path is
virtually unaffected - no real performance impact.
Signed-off-by: Toyo Abe <toyoa@mvista.com>
Cc: Roland McGrath <roland@redhat.com>
The percpu variable is used incorrectly in switch_hrtimer_base().
Signed-off-by: Jan Blunck <jblunck@suse.de>
Few of the callback functions and notifier blocks that are associated with cpu
notifications incorrectly have __devinit and __devinitdata. They should be
__cpuinit and __cpuinitdata instead.
It makes no functional difference but wastes text area when CONFIG_HOTPLUG is
enabled and CONFIG_HOTPLUG_CPU is not.
This patch fixes all those instances.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Cc: Ashok Raj <ashok.raj@intel.com>
cleanup: remove task_t and convert all the uses to struct task_struct. I
introduced it for the scheduler anno and it was a mistake.
Conversion was mostly scripted, the result was reviewed and all
secondary whitespace and style impact (if any) was fixed up by hand.
Teach special (recursive) locking code to the lock validator. Has no effect
on non-lockdep kernels.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch reverts notifier_block changes made in 2.6.17
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a
band-aid solution to solve that problem. In the process, i undid all the
changes you both were making to ensure that these notifiers were available
only at init time (unless CONFIG_HOTPLUG_CPU is defined).
We deferred the real fix to 2.6.18. Here is a set of patches that fixes the
XFS problem cleanly and makes the cpu notifiers available only at init time
If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run
time.
This patch reverts the notifier_call changes made in 2.6.17
Fix kernel-doc formatting in ktime.h and hrtimer.[ch] files.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
There are several instances of per_cpu(foo, raw_smp_processor_id()), which
is semantically equivalent to __get_cpu_var(foo) but without the warning
that smp_processor_id() can give if CONFIG_DEBUG_PREEMPT is enabled. For
those architectures with optimized per-cpu implementations, namely ia64,
powerpc, s390, sparc64 and x86_64, per_cpu() turns into more and slower
code than __get_cpu_var(), so it would be preferable to use __get_cpu_var
on those platforms.
This defines a __raw_get_cpu_var(x) macro which turns into per_cpu(x,
raw_smp_processor_id()) on architectures that use the generic per-cpu
implementation, and turns into __get_cpu_var(x) on the architectures that
have an optimized per-cpu implementation.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
* git://git.infradead.org/~dwmw2/rbtree-2.6:
[RBTREE] Switch rb_colour() et al to en_US spelling of 'color' for consistency
Update UML kernel/physmem.c to use rb_parent() accessor macro
[RBTREE] Update hrtimers to use rb_parent() accessor macro.
[RBTREE] Add explicit alignment to sizeof(long) for struct rb_node.
[RBTREE] Merge colour and parent fields of struct rb_node.
[RBTREE] Remove dead code in rb_erase()
[RBTREE] Update JFFS2 to use rb_parent() accessor macro.
[RBTREE] Update eventpoll.c to use rb_parent() accessor macro.
[RBTREE] Update key.c to use rb_parent() accessor macro.
[RBTREE] Update ext3 to use rb_parent() accessor macro.
[RBTREE] Change rbtree off-tree marking in I/O schedulers.
[RBTREE] Add accessor macros for colour and parent fields of rb_node
I want to use the hrtimer's in the netem (Network Emulator) qdisc. But the
necessary symbols aren't exported for module use.
Also needed by SystemTap.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Cc: "Stone, Joshua I" <joshua.i.stone@intel.com>
Few of the notifier_chain_register() callers use __init in the definition
of notifier_call. It is incorrect as the function definition should be
available after the initializations (they do not unregister them during
initializations).
This patch fixes all such usages to _not_ have the notifier_call __init
section.
Few of the notifier_chain_register() callers use __devinitdata in the
definition of notifier_block data structure. It is incorrect as the
data structure should be available after the initializations (they do
not unregister them during initializations).
This was leading to an oops when notifier_chain_register() call is
invoked for those callback chains after initialization.
This patch fixes all such usages to _not_ have the notifier_block data
structure in the init data section.
Also switch it to use the same method of using off-tree nodes as
everyone else now does -- set them to point to themselves.
Add a cpu_relax() to the hand-coded spinwait in hrtimer_cancel().
Signed-off-by: Joe Korty <joe.korty@ccur.com>
run_hrtimer_queue()
It seems that run_hrtimer_queue() is calling get_softirq_time() more
often than it needs to.
With this patch, it only calls get_softirq_time() if there's a
pending timer.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Replace the nanosleep private sleeper functionality by the generic hrtimer
sleeper.
The removal of the data field in the hrtimer structure enforces the
embedding of the timer into another data structure. nanosleep now uses a
private implementation of the most common used timer callback function
(simple task wakeup).
In order to avoid the reimplentation of such functionality all over the
place a generic hrtimer_sleeper functionality is created.
The nanosleep cleanup allows to remove the data field of hrtimer. The
callback function can use container_of() to get it's own data. Since the
hrtimer structure is anyway embedded in other structures, this adds no
overhead.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
nsec_t predates ktime_t and has mostly been superseded by it. In the few
places that are left it's better to make it explicit that we're dealing with
64 bit values here.
Remove the state field and encode this information in the rb_node similiar to
normal timer.
nanosleep is the only user of the expired state, so let it manage this itself,
which makes the hrtimer code a bit simpler. The remaining time is also only
calculated if requested.
Pass current time to hrtimer_forward(). This allows to use the softirq time
in the timer base when the forward function is called from the timer callback.
Other places pass current time with a call to timer->base->get_time().
The hrtimer softirq is called from the timer softirq every tick. Retrieve the
current time from xtime and wall_to_monotonic instead of calling
base->get_time() for each timer base. Store the time in the base structure
and provide a hook once clock source abstractions are in place and to keep the
code open for new base clocks.
Based on a patch from: Roman Zippel <zippel@linux-m68k.org>
Also from Thomas Gleixner <tglx@linutronix.de>
Function next_timer_interrupt() got broken with a recent patch
6ba1b91213e81aa92b5cf7539f7d2a94ff54947c as sys_nanosleep() was moved to
hrtimer. This broke things as next_timer_interrupt() did not check hrtimer
tree for next event.
Function next_timer_interrupt() is needed with dyntick (CONFIG_NO_IDLE_HZ,
VST) implementations, as the system can be in idle when next hrtimer event
was supposed to happen. At least ARM and S390 currently use
next_timer_interrupt().
CONFIG_TIME_LOW_RES is a temporary way for architectures to signal that
they simply return xtime in do_gettimeoffset(). In this corner-case we
want to round up by resolution when starting a relative timer, to avoid
short timeouts. This will go away with the GTOD framework.
At some point we added credits to people who actively helped to bring
k/hr-timers along. This was lost in the big code revamp. Add it back.
