path: root/kernel/irq/Makefile
2014-11-23genirq: Add generic msi irq domain supportJiang Liu
Implement the basic functions for MSI interrupt support with hierarchical interrupt domains. [ tglx: Extracted and combined from several patches ] Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Yingjoe Chen <yingjoe.chen@mediatek.com> Cc: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-07-28irq: add irq_domain translation infrastructureGrant Likely
This patch adds irq_domain infrastructure for translating from hardware irq numbers to linux irqs. This is particularly important for architectures adding device tree support because the current implementation (excluding PowerPC and SPARC) cannot handle translation for more than a single interrupt controller. irq_domain supports device tree translation for any number of interrupt controllers. This patch converts x86, Microblaze, ARM and MIPS to use irq_domain for device tree irq translation. x86 is untested beyond compiling it, irq_domain is enabled for MIPS and Microblaze, but the old behaviour is preserved until the core code is modified to actually register an irq_domain yet. On ARM it works and is required for much of the new ARM device tree board support. PowerPC has /not/ been converted to use this new infrastructure. It is still missing some features before it can replace the virq infrastructure already in powerpc (see documentation on irq_domain_map/unmap for details). Followup patches will add the missing pieces and migrate PowerPC to use irq_domain. SPARC has its own method of managing interrupts from the device tree and is unaffected by this change. Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-02genirq: Make generic irq chip depend on CONFIG_GENERIC_IRQ_CHIPThomas Gleixner
Only compile it in when there are users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arm-kernel@lists.infradead.org
2011-04-23genirq: Implement a generic interrupt chipThomas Gleixner
Implement a generic interrupt chip, which is configurable and is able to handle the most common irq chip implementations. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arm-kernel@lists.infradead.org Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Tony Lindgren <tony@atomide.com> Tested-by; Kevin Hilman <khilman@ti.com>
2010-10-12genirq: Remove the now unused sparse irq leftoversThomas Gleixner
The move_irq_desc() function was only used due to the problem that the allocator did not free the old descriptors. So the descriptors had to be moved in create_irq_nr(). That's history. The code would have never been able to move active interrupt descriptors on affinity settings. That can be done in a completely different way w/o all this horror. Remove all of it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Distangle kernel/irq/handle.cThomas Gleixner
kernel/irq/handle.c has become a dumpground for random code in random order. Split out the irq descriptor management and the dummy irq_chip implementation into separate files. Cleanup the include maze while at it. No code change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2009-05-01x86/irq: use move_irq_desc() in create_irq_nr()Yinghai Lu
move_irq_desc() will try to move irq_desc to the home node if the allocated one is not correct, in create_irq_nr(). ( This can happen on devices that are on different nodes that are using MSI, when drivers are loaded and unloaded randomly. ) v2: fix non-smp build v3: add NUMA_IRQ_DESC to eliminate #ifdefs [ Impact: improve irq descriptor locality on NUMA systems ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <49F95EAE.2050903@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-28x86/irq: remove leftover code from NUMA_MIGRATE_IRQ_DESCYinghai Lu
The original feature of migrating irq_desc dynamic was too fragile and was causing problems: it caused crashes on systems with lots of cards with MSI-X when user-space irq-balancer was enabled. We now have new patches that create irq_desc according to device numa node. This patch removes the leftover bits of the dynamic balancer. [ Impact: remove dead code ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <49F654AF.8000808@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-30PM: Introduce functions for suspending and resuming device interruptsRafael J. Wysocki
Introduce helper functions allowing us to prevent device drivers from getting any interrupts (without disabling interrupts on the CPU) during suspend (or hibernation) and to make them start to receive interrupts again during the subsequent resume. These functions make it possible to keep timer interrupts enabled while the "late" suspend and "early" resume callbacks provided by device drivers are being executed. In turn, this allows device drivers' "late" suspend and "early" resume callbacks to sleep, execute ACPI callbacks etc. The functions introduced here will be used to rework the handling of interrupts during suspend (hibernation) and resume. Namely, interrupts will only be disabled on the CPU right before suspending sysdevs, while device drivers will be prevented from receiving interrupts, with the help of the new helper function, before their "late" suspend callbacks run (and analogously during resume). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-12-17x86, sparseirq: move irq_desc according to smp_affinity, v7Yinghai Lu
Impact: improve NUMA handling by migrating irq_desc on smp_affinity changes if CONFIG_NUMA_MIGRATE_IRQ_DESC is set: - make irq_desc to go with affinity aka irq_desc moving etc - call move_irq_desc in irq_complete_move() - legacy irq_desc is not moved, because they are allocated via static array for logical apic mode, need to add move_desc_in_progress_in_same_domain, otherwise it will not be moved ==> also could need two phases to get irq_desc moved. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-29[PATCH] genirq: add irq-chip supportThomas Gleixner
Enable platforms to use the irq-chip and irq-flow abstractions: allow setting of the chip, the type and provide highlevel handlers for common irq-flows. [rostedt@goodmis.org: misroute-irq: Don't call desc->chip->end because of edge interrupts] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add genirq sw IRQ-retriggerThomas Gleixner
Enable platforms that do not have a hardware-assisted hardirq-resend mechanism to resend them via a softirq-driven IRQ emulation mechanism. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] build kernel/irq/migration.c only if CONFIG_GENERIC_PENDING_IRQ is setChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] irq: uninline migration functionsAndrew Morton
Uninline some massive IRQ migration functions. Put them in the new kernel/irq/migration.c. Cc: Andi Kleen <ak@muc.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
