commit e8f241893dfbbebe2813c01eac54f263e6a5e59c upstream.
irq_modify_status starts by clearing the trigger settings from
irq_data before applying the new settings, but doesn't restore them,
leaving them to IRQ_TYPE_NONE.
That's pretty confusing to the potential request_irq() that could
follow. Instead, snapshot the settings before clearing them, and restore
them if the irq_modify_status() invocation was not changing the trigger.
Fixes: 1e2a7d78499e ("irqdomain: Don't set type when mapping an IRQ")
Reported-and-tested-by: jeffy <jeffy.chen@rock-chips.com>
Cc: Jon Hunter <jonathanh@nvidia.com>
Link: http://lkml.kernel.org/r/20170818095345.12378-1-marc.zyngier@arm.com
commit 2c4569ca26986d18243f282dd727da27e9adae4c upstream.
irq_set_chained_handler_and_data() sets up the chained interrupt and then
stores the handler data.
That's racy against an immediate interrupt which gets handled before the
store of the handler data happened. The handler will dereference a NULL
pointer and crash.
Cure it by storing handler data before installing the chained handler.
Reported-by: Borislav Petkov <bp@alien8.de>
Fixes the following sparse warning:
kernel/irq/chip.c:786:1: warning:
symbol '__irq_do_set_handler' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Link: http://lkml.kernel.org/r/1474817799-18676-1-git-send-email-weiyj.lk@gmail.com
Merge urgent fixes so pending patches for 4.9 can be applied.
There is no point in trying to configure the trigger of a chained
interrupt if no trigger information has been configured. At best
this is ignored, and at the worse this confuses the underlying
irqchip (which is likely not to handle such a thing), and
unnecessarily alarms the user.
Only apply the configuration if type is not IRQ_TYPE_NONE.
Fixes: 1e12c4a9393b ("genirq: Correctly configure the trigger on chained interrupts")
Reported-and-tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Link: https://lkml.kernel.org/r/CAMuHMdVW1eTn20=EtYcJ8hkVwohaSuH_yQXrY2MGBEvZ8fpFOg@mail.gmail.com
Link: http://lkml.kernel.org/r/1474274967-15984-1-git-send-email-marc.zyngier@arm.com
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/core
Merge the first drop of irqchip updates for 4.9 from Marc Zyngier:
- ACPI IORT core code
- IORT support for the GICv3 ITS
- A few of GIC cleanups
Some callers of __irq_set_trigger() masks all flags except trigger mode
flags. This is unnecessary, ase __irq_set_trigger() already does this
before usage of flags.
[ tglx: Moved the flag mask and adjusted comment. Removed the hunk in
enable_percpu_irq() as it is required there ]
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com>
Link: http://lkml.kernel.org/r/20160719095408.13778-1-kuleshovmail@gmail.com
The percpu_devid handler is not robust against spurious interrupts. If a
spurious interrupt happens and no action is installed then the handler
crashes with a NULL pointer dereference.
Add a sanity check for this and log the wreckage once in dmesg.
Reported-by: Majun <majun258@huawei.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: guohanjun@huawei.com
Cc: dingtianhong@huawei.com
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1609021436160.5647@nanos
Commit 1e2a7d78499e ("irqdomain: Don't set type when mapping an IRQ")
moved the trigger configuration call from the irqdomain mapping to
the interrupt being actually requested.
This patch failed to handle the case where we configure a chained
interrupt, which doesn't get requested through the usual path.
In order to solve this, let's call __irq_set_trigger just before
starting the cascade interrupt. Special care must be taken to
make the flow handler stick, as the .irq_set_type method could
have reset it (it doesn't know we're dealing with a chained
interrupt).
Based on an initial patch by Jon Hunter.
Reported-by: John Stultz <john.stultz@linaro.org>
Reported-by: Linus Walleij <linus.walleij@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Acked-by: Jon Hunter <jonathanh@nvidia.com>
This adds a software irq handler for controllers that multiplex
interrupts from multiple devices, but don't know which device generated
the interrupt. For these devices, the irq handler that demuxes must
check every action for every software irq using the same h/w irq in order
to find out which device generated the interrupt. This will inevitably
trigger spurious interrupt detection if we are noting the irq.
The new irq handler does not track the handling for spurious interrupt
detection. An irq that uses this also won't get stats tracked since it
didn't generate the interrupt, nor added to randomness since they are
not random.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: linux-pci@vger.kernel.org
Cc: Jon Derrick <jonathan.derrick@intel.com>
Link: http://lkml.kernel.org/r/1466200821-29159-1-git-send-email-keith.busch@intel.com
Some IRQ chips may be located in a power domain outside of the CPU
subsystem and hence will require device specific runtime power
management. In order to support such IRQ chips, add a pointer for a
device structure to the irq_chip structure, and if this pointer is
populated by the IRQ chip driver and CONFIG_PM is selected in the kernel
configuration, then the pm_runtime_get/put APIs for this chip will be
called when an IRQ is requested/freed, respectively.
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Export irq_chip_*_parent(), irq_domain_create_hierarchy(),
irq_domain_set_hwirq_and_chip(), irq_domain_reset_irq_data(),
irq_domain_alloc/free_irqs_parent()
So gpio drivers can be built as modules. First user: gpio-xgene-sb
Signed-off-by: Quan Nguyen <qnguyen@apm.com>
Cc: Phong Vo <pvo@apm.com>
Cc: patches@apm.com
Cc: Loc Ho <lho@apm.com>
Cc: Keyur Chudgar <kchudgar@apm.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Link: https://lists.01.org/pipermail/kbuild-all/2016-February/017914.html
Link: http://lkml.kernel.org/r/1457017012-10628-1-git-send-email-qnguyen@apm.com
The Linux kernel already has the concept of IRQ domain, wherein a
component can expose a set of IRQs which are managed by a particular
interrupt controller chip or other subsystem. The PCI driver exposes
the notion of an IRQ domain for Message-Signaled Interrupts (MSI) from
PCI Express devices. This patch exposes the functions which are
necessary for creating a MSI IRQ domain within a module.
[ tglx: Split it into x86 and core irq parts ]
Signed-off-by: Jake Oshins <jakeo@microsoft.com>
Cc: gregkh@linuxfoundation.org
Cc: kys@microsoft.com
Cc: devel@linuxdriverproject.org
Cc: olaf@aepfle.de
Cc: apw@canonical.com
Cc: vkuznets@redhat.com
Cc: haiyangz@microsoft.com
Cc: marc.zyngier@arm.com
Cc: bhelgaas@google.com
Link: http://lkml.kernel.org/r/1449769983-12948-4-git-send-email-jakeo@microsoft.com
In case of a wakeup interrupt, irq_pm_check_wakeup disables the interrupt
and marks it pending and suspended, disables it and notifies the pm core
about the wake event. The interrupt gets handled later once the system
is resumed.
However the irq stats is updated twice: once when it's disabled waiting
for the system to resume and later when it's handled, resulting in wrong
counting of the wakeup interrupt when waking up the system.
This patch updates the interrupt count so that it's updated only when
the interrupt gets handled. It's already handled correctly in
handle_edge_irq and handle_edge_eoi_irq.
Reported-by: Manoil Claudiu <claudiu.manoil@freescale.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Link: http://lkml.kernel.org/r/1446661957-1019-1-git-send-email-sudeep.holla@arm.com
If an irq chip does not implement the irq_disable callback, then we
use a lazy approach for disabling the interrupt. That means that the
interrupt is marked disabled, but the interrupt line is not
immediately masked in the interrupt chip. It only becomes masked if
the interrupt is raised while it's marked disabled. We use this to avoid
possibly expensive mask/unmask operations for common case operations.
Unfortunately there are devices which do not allow the interrupt to be
disabled easily at the device level. They are forced to use
disable_irq_nosync(). This can result in taking each interrupt twice.
Instead of enforcing the non lazy mode on all interrupts of a irq
chip, provide a settings flag, which can be set by the driver for that
particular interrupt line.
Reported-and-tested-by: Duc Dang <dhdang@apm.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1510092348370.6097@nanos
When a CPU is offlined all interrupts that have an action are migrated to
other still online CPUs. However, if the interrupt has chained handler
installed this is not done. Chained handlers are used by GPIO drivers which
support interrupts, for instance.
When the affinity is not corrected properly we end up in situation where
most interrupts are not arriving to the online CPUs anymore. For example on
Intel Braswell system which has SD-card card detection signal connected to
a GPIO the IO-APIC routing entries look like below after CPU1 is offlined:
pin30, enabled , level, low , V(52), IRR(0), S(0), logical , D(03), M(1)
pin31, enabled , level, low , V(42), IRR(0), S(0), logical , D(03), M(1)
pin32, enabled , level, low , V(62), IRR(0), S(0), logical , D(03), M(1)
pin5b, enabled , level, low , V(72), IRR(0), S(0), logical , D(03), M(1)
The problem here is that the destination mask still contains both CPUs even
if CPU1 is already offline. This means that the IO-APIC still routes
interrupts to the other CPU as well.
We solve the problem by providing a default action for chained interrupts.
This action allows the migration code to correct affinity (as it finds
desc->action != NULL).
Also make the default action handler to emit a warning if for some reason a
chained handler ends up calling it.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: http://lkml.kernel.org/r/1444039935-30475-1-git-send-email-mika.westerberg@linux.intel.com
Actually, we always use the first irq action of the @desc->action
chain, so remove the second parameter from handle_irq_event_percpu()
which makes the code more tidy.
Signed-off-by: Huang Shijie <shijie.huang@arm.com>
Reviewed-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/1441160695-19809-1-git-send-email-shijie.huang@arm.com
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
MSI descriptors are per-irq instead of per irqchip, so move it into
struct irq_common_data.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Kevin Cernekee <cernekee@gmail.com>
Link: http://lkml.kernel.org/r/1433145945-789-35-git-send-email-jiang.liu@linux.intel.com
Handler data (handler_data) is per-irq instead of per irqchip, so move
it into struct irq_common_data.
Link: http://lkml.kernel.org/r/1433145945-789-13-git-send-email-jiang.liu@linux.intel.com
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
This helper is required for irq chips which do not implement a
irq_set_type callback and need to call down the irq domain hierarchy
for the actual trigger type change.
This helper is required to fix further wreckage caused by the
conversion of TI OMAP to hierarchical irq domains and therefor tagged
for stable.
[ tglx: Massaged changelog ]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: <linux@arm.linux.org.uk>
Cc: <nsekhar@ti.com>
Cc: <jason@lakedaemon.net>
Cc: <balbi@ti.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: <tony@atomide.com>
Cc: <marc.zyngier@arm.com>
Cc: stable@vger.kernel.org # 4.1
Link: http://lkml.kernel.org/r/1439554830-19502-3-git-send-email-grygorii.strashko@ti.com
irq_chip_retrigger_hierarchy() returns -ENOSYS if it was not able to
find at least one .irq_retrigger() callback implemented in the IRQ
domain hierarchy.
That's wrong, because check_irq_resend() expects a 0 return value from
the callback in case that the hardware assisted resend was not
possible. If the return value is non zero the core code assumes
hardware resend success and the software resend is not invoked.
This results in lost interrupts on platforms where none of the parent
irq chips in the hierarchy implements the retrigger callback.
This is observable on TI OMAP, where the hierarchy is:
ARM GIC <- OMAP wakeupgen <- TI Crossbar
Return 0 instead so the software resend mechanism gets invoked.
Fixes: 85f08c17de26 ('genirq: Introduce helper functions...')
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: <balbi@ti.com>
Link: http://lkml.kernel.org/r/1439554830-19502-2-git-send-email-grygorii.strashko@ti.com
The following warning is emitted for make xmldocs:
Warning(.//kernel/irq/chip.c:1009): No description found for parameter 'vcpu_info'
Warning(.//kernel/irq/chip.c:1009): Excess function parameter 'dest' description in 'irq_chip_set_vcpu_affinity_parent'
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Link: http://lkml.kernel.org/r/1438164576-5945-1-git-send-email-standby24x7@gmail.com
Only required for the slow path. Retrieve it from irq descriptor if
necessary.
[ tglx: Split out from combo patch. Left [try_]misrouted_irq()
untouched as there is no win in the slow path ]
Link: http://lkml.kernel.org/r/1433391238-19471-19-git-send-email-jiang.liu@linux.intel.com
It's only required for debug output and can be retrieved from the irq
descriptor if necessary.
[ tglx: Split out from combo patch ]
It's only used in the software resend case and can be retrieved from
irq_desc if necessary.
Link: http://lkml.kernel.org/r/1433391238-19471-18-git-send-email-jiang.liu@linux.intel.com
The first parameter 'irq' is never used by
kstat_incr_irqs_this_cpu(). Remove it.
Link: http://lkml.kernel.org/r/1433391238-19471-16-git-send-email-jiang.liu@linux.intel.com
Driver authors seem to get the ordering of irq_set_chained_handler()
and irq_set_handler_data() wrong - ordering the former before the
latter. This opens a race window where, if there is an interrupt
pending, the handler will be called between these two calls,
potentially resulting in an oops.
Provide a single interface to set both of these together, especially
as that's commonly what is required.
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Link: http://lkml.kernel.org/r/E1Z4yzs-0002Rw-4B@rmk-PC.arm.linux.org.uk
Pull in the branch which can be consumed by x86 to build their changes
on top.
With Posted-Interrupts support in Intel CPU and IOMMU, an external
interrupt from assigned-devices could be directly delivered to a
virtual CPU in a virtual machine. Instead of hacking KVM and Intel
IOMMU drivers, we propose a platform independent interface to target
an interrupt to a specific virtual CPU in a virtual machine, or set
virtual CPU affinity for an interrupt.
By adopting this new interface and the hierarchy irqdomain, we could
easily support posted-interrupts on Intel platforms, and also provide
flexible enough interfaces for other platforms to support similar
features.
Here is the usage scenario for this interface:
Guest update MSI/MSI-X interrupt configuration
-->QEMU and KVM handle this
-->KVM call this interface (passing posted interrupts descriptor
and guest vector)
-->irq core will transfer the control to IOMMU
-->IOMMU will do the real work of updating IRTE (IRTE has new
format for VT-d Posted-Interrupts)
Signed-off-by: Feng Wu <feng.wu@intel.com>
Link: http://lkml.kernel.org/r/1432026437-16560-2-git-send-email-feng.wu@intel.com
Add helper irq_chip_enable_parent and irq_chip_disable_parent. The
helper implement the default behavior in case irq_enable or irq_disable
is not implemented for the parent interrupt chip, which is calling the
irq_mask or irq_unmask respectively.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Cc: linux@arm.linux.org.uk
Cc: u.kleine-koenig@pengutronix.de
Cc: olof@lixom.net
Cc: arnd@arndb.de
Cc: daniel.lezcano@linaro.org
Cc: mark.rutland@arm.com
Cc: pawel.moll@arm.com
Cc: robh+dt@kernel.org
Cc: ijc+devicetree@hellion.org.uk
Cc: galak@codeaurora.org
Cc: mcoquelin.stm32@gmail.com
Cc: shawn.guo@linaro.org
Cc: kernel@pengutronix.de
Cc: jason@lakedaemon.net
Link: http://lkml.kernel.org/r/1431769465-26867-3-git-send-email-stefan@agner.ch
This proves to be useful with stacked domains, when the current
domain doesn't implement wake-up, but expect the parent to do so.
Link: https://lkml.kernel.org/r/1426088629-15377-2-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
With the introduction of stacked domains, we have the issue that,
depending on where in the stack this is called, __irq_set_handler
will succeed or fail: If this is called from the inner irqchip,
__irq_set_handler() will fail, as it will look at the outer domain
as the (desc->irq_data.chip == &no_irq_chip) test fails (we haven't
set the top level yet).
This patch implements the following: "If there is at least one
valid irqchip in the domain, it will probably sort itself out".
This is clearly not ideal, but it is far less confusing then
crashing because the top-level domain is not up yet.
[ tglx: Added comment and a protection against chained interrupts in
that context ]
Cc: Yingjoe Chen <yingjoe.chen@mediatek.com>
Link: http://lkml.kernel.org/r/1416048553-29289-3-git-send-email-marc.zyngier@arm.com
Add callback irq_compose_msi_msg to struct irq_chip, which will be used
to support stacked irqchip.
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Yijing Wang <wangyijing@huawei.com>
Add more helper function for stacked irq_chip to just call parent's
function.
Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: Gran Likely <grant.likely@linaro.org>
Cc: Boris BREZILLON <boris.brezillon@free-electrons.com>
Cc: <srv_heupstream@mediatek.com>
Cc: <yingjoe.chen@gmail.com>
Cc: <hc.yen@mediatek.com>
Cc: <eddie.huang@mediatek.com>
Cc: <nathan.chung@mediatek.com>
Cc: <yh.chen@mediatek.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Link: http://lkml.kernel.org/r/1415893029-2971-3-git-send-email-yingjoe.chen@mediatek.com
Now we already support hierarchy irq_data, so introduce several helpers
to support stacked irq_chips.
We plan to use hierarchy irqdomain to suppport CPU vector assignment,
interrupt remapping controller, IO-APIC controller, MSI interrupt
and hypertransport interrupt etc on x86 platforms. So extend irqdomain
interfaces to support hierarchy irqdomain.
There are already many clients of current irqdomain interfaces.
To minimize the changes, we choose to introduce new version 2 interfaces
to support hierarchy instead of extending existing irqdomain interfaces.
According to Thomas's suggestion, the most important design decision is
to build hierarchy struct irq_data to support hierarchy irqdomain, so
hierarchy irqdomain related data could be saved in struct irq_data.
With support of hierarchy irq_data, we could also support stacked
irq_chips. This is most useful in case of set_affinity().
The new hierarchy irqdomain introduces following interfaces:
1) irq_domain_alloc_irqs()/irq_domain_free_irqs(): allocate/release IRQ
and related resources.
2) __irq_domain_alloc_irqs(): a special version to support legacy IRQs.
3) irq_domain_activate_irq()/irq_domain_deactivate_irq(): program
interrupt controllers to activate/deactivate interrupt.
There are also several help functions to ease irqdomain implemenations:
1) irq_domain_get_irq_data(): get irq_data associated with a specific
irqdomain.
2) irq_domain_set_hwirq_and_chip(): save irqdomain specific data into
irq_data.
3) irq_domain_alloc_irqs_parent()/irq_domain_free_irqs_parent(): invoke
parent irqdomain's alloc/free callbacks.
We also changed irq_startup()/irq_shutdown() to invoke
irq_domain_activate_irq()/irq_domain_deactivate_irq() to program
interrupt controller when start/stop interrupts.
[ tglx: Folded parts of the later patch series in ]
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
* pm-genirq:
PM / genirq: Document rules related to system suspend and interrupts
PCI / PM: Make PCIe PME interrupts wake up from suspend-to-idle
x86 / PM: Set IRQCHIP_SKIP_SET_WAKE for IOAPIC IRQ chip objects
genirq: Simplify wakeup mechanism
genirq: Mark wakeup sources as armed on suspend
genirq: Create helper for flow handler entry check
genirq: Distangle edge handler entry
genirq: Avoid double loop on suspend
genirq: Move MASK_ON_SUSPEND handling into suspend_device_irqs()
genirq: Make use of pm misfeature accounting
genirq: Add sanity checks for PM options on shared interrupt lines
genirq: Move suspend/resume logic into irq/pm code
PM / sleep: Mechanism for aborting system suspends unconditionally
Currently we suspend wakeup interrupts by lazy disabling them and
check later whether the interrupt has fired, but that's not sufficient
for suspend to idle as there is no way to check that once we
transitioned into the CPU idle state.
So we change the mechanism in the following way:
1) Leave the wakeup interrupts enabled across suspend
2) Add a check to irq_may_run() which is called at the beginning of
each flow handler whether the interrupt is an armed wakeup source.
This check is basically free as it just extends the existing check
for IRQD_IRQ_INPROGRESS. So no new conditional in the hot path.
If the IRQD_WAKEUP_ARMED flag is set, then the interrupt is
disabled, marked as pending/suspended and the pm core is notified
about the wakeup event.
[ rjw: syscore.c and put irq_pm_check_wakeup() into pm.c ]
All flow handlers - except the per cpu ones - check for an interrupt
in progress and an eventual concurrent polling on another cpu.
Create a helper function for the repeated code pattern.
If the interrupt is disabled or has no action, then we should not call
the poll check. Separate the checks.
[ARM specific]
These are generally replaced with raw_cpu_ptr. However, in
gic_get_percpu_base() we immediately dereference the pointer. This is
equivalent to a raw_cpu_read. So use that operation there.
Cc: nicolas.pitre@linaro.org
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Christoph Lameter <cl@linux.com>
Export handle_fasteoi_irq to be able to use it in e.g. the Zynq gpio driver
since commit 6dd859508336 ("gpio: zynq: Fix IRQ handlers").
This fixes the following link issue:
ERROR: "handle_fasteoi_irq" [drivers/gpio/gpio-zynq.ko] undefined!
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Cc: Vincent Stehle <vincent.stehle@laposte.net>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Link: http://lkml.kernel.org/r/1408663880-29179-1-git-send-email-vincent.stehle@laposte.net
We want to get rid of the public interface.
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Tested-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/20140507154340.061990194@linutronix.de
The flag is necessary for interrupt chips which require an ACK/EOI
after the handler has run. In case of threaded handlers this needs to
happen after the threaded handler has completed before the unmask of
the interrupt.
The flag is only unseful in combination with the handle_fasteoi_irq
flow control handler.
It can be combined with the flag IRQCHIP_EOI_IF_HANDLED, so the EOI is
not issued when the interrupt is disabled or in progress.
Tested-by: Hans de Goede <hdegoede@redhat.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Cc: linux-sunxi@googlegroups.com
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Link: http://lkml.kernel.org/r/1394733834-26839-2-git-send-email-hdegoede@redhat.com
Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com>
[jkosina@suse.cz: fix 'explicitly', noticed by Randy Dunlap]
Document the lazy disable functionality. comment based on changelog of
d209a699a0b975ad
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Cc: balbi@ti.com
Link: http://lkml.kernel.org/r/1368181290-1583-1-git-send-email-andreas.fenkart@streamunlimited.com
The MSI specification has several constraints in comparison with
MSI-X, most notable of them is the inability to configure MSIs
independently. As a result, it is impossible to dispatch
interrupts from different queues to different CPUs. This is
largely devalues the support of multiple MSIs in SMP systems.
Also, a necessity to allocate a contiguous block of vector
numbers for devices capable of multiple MSIs might cause a
considerable pressure on x86 interrupt vector allocator and
could lead to fragmentation of the interrupt vectors space.
This patch overcomes both drawbacks in presense of IRQ remapping
and lets devices take advantage of multiple queues and per-IRQ
affinity assignments.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Link: http://lkml.kernel.org/r/c8bd86ff56b5fc118257436768aaa04489ac0a4c.1353324359.git.agordeev@redhat.com
