path: root/kernel/irq/devres.c
2010-02-11devres/irq: Fix devm_irq_match commentJean Delvare
Fix the reference (in comment). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-05devres: typo fix s/dev/devm/Baruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24genirq: add support for threaded interrupts to devresArjan van de Ven
Some devices use devres_request_irq() for to install their interrupt handler. Add support for threaded interrupts to devres as well. [tglx - simplified and adapted to latest threadirq version] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-29kernel: explicitly include required header files under kernel/Robert P. J. Day
Following an experimental deletion of the unnecessary directive #include <linux/slab.h> from the header file <linux/percpu.h>, these files under kernel/ were exposed as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit includes were added where necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-28rip some includes from linux/interrupt.hAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-07[PATCH] irq-devres: fix failure path of devm_request_irq()Tejun Heo
devres should be deallocated with devres_free() not kfree(). This bug corrupts slab on IRQ request failure. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
