path: root/kernel/irq/handle.c
2011-06-03irq: Handle spurios irq detection for threaded irqsSebastian Andrzej Siewior
The detection of spurios interrupts is currently limited to first level handler. In force-threaded mode we never notice if the threaded irq does not feel responsible. This patch catches the return value of the threaded handler and forwards it to the spurious detector. If the primary handler returns only IRQ_WAKE_THREAD then the spourious detector ignores it because it gets called again from the threaded handler. [ tglx: Report the erroneous return value early and bail out ] Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Link: http://lkml.kernel.org/r/1306824972-27067-2-git-send-email-sebastian@breakpoint.cc Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29genirq: Remove compat codeThomas Gleixner
2011-03-28genirq: Remove handle_IRQ_eventThomas Gleixner
Last user gone. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_dataThomas Gleixner
We really need these flags for some of the interrupt chips. Move it from internal state to irq_data and provide proper accessors. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Daney <ddaney@caviumnetworks.com>
2011-02-25genirq: Prepare the handling of shared oneshot interruptsThomas Gleixner
For level type interrupts we need to track how many threads are on flight to avoid useless interrupt storms when not all thread handlers have finished yet. Keep track of the woken threads and only unmask when there are no more threads in flight. Yes, I'm lazy and using a bitfield. But not only because I'm lazy, the main reason is that it's way simpler than using a refcount. A refcount based solution would need to keep track of various things like crashing the irq thread, spurious interrupts coming in, disables/enables, free_irq() and some more. The bitfield keeps the tracking simple and makes things just work. It's also nicely confined to the thread code pathes and does not require additional checks all over the place. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110223234956.388095876@linutronix.de>
2011-02-25genirq: Make warning in handle_percpu_event usefulThomas Gleixner
The WARN_ON_ONCE in handle_percpu_event() which emits a warning when an action handler returns with interrupts enabled is not really useful. It does not reveal the interrupt number and handler function which caused it. Make it WARN_ONCE() and add the information. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-22genirq: Use the correct variable for note_interruptThomas Gleixner
note_interrupt wants to be called with the combined result of all handlers called, not with the last one. If it's a shared interrupt then the last handler might return IRQ_NONE often enough to trigger the spurious dectector which turns off a perfectly fine working interrupt line. Bug was introduced in commit 1277a532(genirq: Simplify handle_irq_event()). Yes, I really messed up there. First the variable ret should not have been named differently to avoid similarity with retval. Second it should have been declared in the do {} loop. Rename it to res and move it into the do {} loop and vanish under a huge brown paperbag. Reported-bisected-tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Force wrapped access to desc->status in core codeThomas Gleixner
Force the usage of wrappers by another nasty CPP substitution. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Move IRQ_PENDING flag to coreThomas Gleixner
Keep status in sync until all users are fixed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Add IRQ_INPROGRESS to coreThomas Gleixner
We need to maintain the flag for now in both fields status and istate. Add a CONFIG_GENERIC_HARDIRQS_NO_COMPAT switch to allow testing w/o the status one. Wrap the access to status IRQ_INPROGRESS in a inline which can be turned of with CONFIG_GENERIC_HARDIRQS_NO_COMPAT along with the define. There is no reason that anything outside of core looks at this. That needs some modifications, but we'll get there. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Simplify handle_irq_event()Thomas Gleixner
Now that all core users are converted one layer can go. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Implement handle_irq_event()Thomas Gleixner
Core code replacement for the ugly camel case. It contains all the code which is shared in all handlers. clear status flags set INPROGRESS flag unlock call action chain note_interrupt lock clr INPROGRESS flag Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Warn when handler enables interruptsThomas Gleixner
We run all handlers with interrupts disabled and expect them not to enable them. Warn when we catch one who does. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2010-10-12genirq: Distangle kernel/irq/handle.cThomas Gleixner
kernel/irq/handle.c has become a dumpground for random code in random order. Split out the irq descriptor management and the dummy irq_chip implementation into separate files. Cleanup the include maze while at it. No code change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide config option to disable deprecated codeThomas Gleixner
This option covers now the old chip functions and the irq_desc data fields which are moving to struct irq_data. More stuff will follow. Pretty handy for testing a conversion, whether something broke or not. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->startup()Thomas Gleixner
Wrap the old chip function startup() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.635152961@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->disable()/shutdown()Thomas Gleixner
Wrap the old chip functions disable() and shutdown() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.532070631@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->enable()Thomas Gleixner
Wrap the old chip function enable() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.437159182@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->ack()Thomas Gleixner
Wrap the old chip function ack() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.142624725@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->unmask()Thomas Gleixner
Wrap the old chip function unmask() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.043608928@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->mask()Thomas Gleixner
Wrap the old chip function mask() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121841.940355859@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Add new functions to dummy chipsThomas Gleixner
The compat functions go away when the core code is converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Convert core code to irq_dataThomas Gleixner
Convert all references in the core code to orq, chip, handler_data, chip_data, msi_desc, affinity to irq_data.* Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Create irq_dataThomas Gleixner
Low level chip functions need access to irq_desc->handler_data, irq_desc->chip_data and irq_desc->msi_desc. We hand down the irq number to the low level functions, so they need to lookup irq_desc. With sparse irq this means a radix tree lookup. We could hand down irq_desc itself, but low level chip functions have no need to fiddle with it directly and we want to restrict access to irq_desc further. Preparatory patch for new chip functions. Note, that the ugly anon union/struct is there to avoid a full tree wide clean up for now. This is not going to last 3 years like __do_IRQ() Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121841.645542300@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-04-13genirq: Run irq handlers with interrupts disabledIngo Molnar
Running interrupt handlers with interrupts enabled can cause stack overflows. That has been observed with multiqueue NICs delivering all their interrupts to a single core. We might band aid that somehow by checking the interrupt stacks, but the real safe fix is to run the irq handlers with interrupts disabled. Drivers for whacky hardware still can reenable them in the handler itself, if the need arises. (They do already due to lockdep) The risk of doing this is rather low: - lockdep already enforces this - CONFIG_NOHZ has shaken out the drivers which relied on jiffies updates - time keeping is not longer sensitive to the timer interrupt being delayed Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Miller <davem@davemloft.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Linus Torvalds <torvalds@osdl.org> LKML-Reference: <20100326000405.758579387@linutronix.de>
2010-02-17sparseirq: Use radix_tree instead of ptrs arrayYinghai Lu
Use radix_tree irq_desc_tree instead of irq_desc_ptrs. -v2: according to Eric and cyrill to use radix_tree_lookup_slot and radix_tree_replace_slot Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-32-git-send-email-yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-17sparseirq: Change irq_desc_ptrs to staticYinghai Lu
Add replace_irq_desc() instead of poking at the array directly. -v2: remove unneeded boundary check in replace_irq_desc Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-31-git-send-email-yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-17irq: Remove unnecessary bootmem codeYinghai Lu
mem_init is moved early already. Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-29-git-send-email-yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-08-29irq: Make sure irq_desc for legacy irq get correct node settingYinghai Lu
when there is no ram on node 0. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> LKML-Reference: <4A95C32D.5040605@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-12irq: slab alloc for default irq_affinityYinghai Lu
Ingo had [ 0.000000] ------------[ cut here ]------------ [ 0.000000] WARNING: at mm/bootmem.c:537 alloc_arch_preferred_bootmem+0x2b/0x71() [ 0.000000] Hardware name: System Product Name [ 0.000000] Modules linked in: [ 0.000000] Pid: 0, comm: swapper Tainted: G W 2.6.30-tip-03087-g0bb2618-dirty #52506 [ 0.000000] Call Trace: [ 0.000000] [<81032588>] warn_slowpath_common+0x60/0x90 [ 0.000000] [<810325c5>] warn_slowpath_null+0xd/0x10 [ 0.000000] [<819d1bc0>] alloc_arch_preferred_bootmem+0x2b/0x71 [ 0.000000] [<819d1c31>] ___alloc_bootmem_nopanic+0x2b/0x9a [ 0.000000] [<81050a0a>] ? lock_release+0xac/0xb2 [ 0.000000] [<819d1d4c>] ___alloc_bootmem+0xe/0x2d [ 0.000000] [<819d1e9f>] __alloc_bootmem+0xa/0xc [ 0.000000] [<819d7c63>] alloc_bootmem_cpumask_var+0x21/0x26 [ 0.000000] [<819d0cc8>] early_irq_init+0x15/0x10d [ 0.000000] [<819bb75a>] start_kernel+0x167/0x326 [ 0.000000] [<819bb06b>] __init_begin+0x6b/0x70 [ 0.000000] ---[ end trace 4eaa2a86a8e2da23 ]--- [ 0.000000] NR_IRQS:2304 nr_irqs:424 [ 0.000000] CPU 0 irqstacks, hard=821e6000 soft=821e7000 we need to update init_irq_default_affinity Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11irq: use kcalloc() instead of the bootmem allocatorPekka Enberg
Fixes the following problem: [ 0.000000] Experimental hierarchical RCU init done. [ 0.000000] NR_IRQS:4352 nr_irqs:256 [ 0.000000] ------------[ cut here ]------------ [ 0.000000] WARNING: at mm/bootmem.c:537 alloc_arch_preferred_bootmem+0x40/0x7e() [ 0.000000] Hardware name: To Be Filled By O.E.M. [ 0.000000] Pid: 0, comm: swapper Not tainted 2.6.30-tip-02161-g7a74539-dirty #59709 [ 0.000000] Call Trace: [ 0.000000] [<ffffffff823f8c8e>] ? alloc_arch_preferred_bootmem+0x40/0x7e [ 0.000000] [<ffffffff81067168>] warn_slowpath_common+0x88/0xcb [ 0.000000] [<ffffffff810671d2>] warn_slowpath_null+0x27/0x3d [ 0.000000] [<ffffffff823f8c8e>] alloc_arch_preferred_bootmem+0x40/0x7e [ 0.000000] [<ffffffff823f9307>] ___alloc_bootmem_nopanic+0x4e/0xec [ 0.000000] [<ffffffff823f93c5>] ___alloc_bootmem+0x20/0x61 [ 0.000000] [<ffffffff823f962e>] __alloc_bootmem+0x1e/0x34 [ 0.000000] [<ffffffff823f757c>] early_irq_init+0x6d/0x118 [ 0.000000] [<ffffffff823e0140>] ? early_idt_handler+0x0/0x71 [ 0.000000] [<ffffffff823e0cf7>] start_kernel+0x192/0x394 [ 0.000000] [<ffffffff823e0140>] ? early_idt_handler+0x0/0x71 [ 0.000000] [<ffffffff823e02ad>] x86_64_start_reservations+0xb4/0xcf [ 0.000000] [<ffffffff823e0000>] ? __init_begin+0x0/0x140 [ 0.000000] [<ffffffff823e0420>] x86_64_start_kernel+0x158/0x17b [ 0.000000] ---[ end trace a7919e7f17c0a725 ]--- [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2002.510 MHz processor. [ 0.004000] Console: colour VGA+ 80x25 Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11irq/cpumask: make memoryless node zero happyYinghai Lu
Don't hardcode to node zero for early boot IRQ setup memory allocations. [ penberg@cs.helsinki.fi: minor cleanups ] Cc: Ingo Molnar <mingo@elte.hu> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-05-23sparseirq: Allow early irq_desc allocationPaul Mundt
Presently non-legacy IRQs have their irq_desc allocated with kzalloc_node(). This assumes that all callers of irq_to_desc_node_alloc() will be sufficiently late in the boot process that kmalloc is available. While porting sparseirq support to sh this blew up immediately, as at the time that we register the CPU's interrupt vector map only bootmem is available. Check slab_is_available() to work out which path to use. [ Impact: fix SH early boot crash with sparseirq enabled ] Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> LKML-Reference: <20090522014008.GA2806@linux-sh.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-12Merge branch 'x86/apic' into irq/numaIngo Molnar
Merge reason: both topics modify the APIC code but were able to do it in parallel so far. An upcoming patch generates a conflict so merge them to avoid the conflict. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-01Revert "genirq: assert that irq handlers are indeed running in hardirq context"Thomas Gleixner
This reverts commit 044d408409cc4e1bc75c886e27ca85c270db104c. The commit added a warning when handle_IRQ_event() is called outside of hard interrupt context. This breaks the generic tasklet based interrupt resend mechanism which is used when the hardware has no way to retrigger the interrupt. So we get a warning for a use case which is correct and worked for years. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-04-29tracing: fix build failure on s390Heiko Carstens
"tracing: create automated trace defines" causes this compile error on s390, as reported by Sachin Sant against linux-next: kernel/built-in.o: In function `__do_softirq': (.text+0x1c680): undefined reference to `__tracepoint_softirq_entry' This happens because the definitions of the softirq tracepoints were moved from kernel/softirq.c to kernel/irq/handle.c. Since s390 doesn't support generic hardirqs handle.c doesn't get compiled and the definitions are missing. So move the tracepoints to softirq.c again. [ Impact: fix build failure on s390 ] Reported-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: fweisbec@gmail.com LKML-Reference: <20090429135139.5fac79b8@osiris.boeblingen.de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-28x86/irq: change irq_desc_alloc() to take node instead of cpuYinghai Lu
This simplifies the node awareness of the code. All our allocators only deal with a NUMA node ID locality not with CPU ids anyway - so there's no need to maintain (and transform) a CPU id all across the IRq layer. v2: keep move_irq_desc related [ Impact: cleanup, prepare IRQ code to be NUMA-aware ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@goop.org> LKML-Reference: <49F65536.2020300@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-28x86/irq: remove leftover code from NUMA_MIGRATE_IRQ_DESCYinghai Lu
The original feature of migrating irq_desc dynamic was too fragile and was causing problems: it caused crashes on systems with lots of cards with MSI-X when user-space irq-balancer was enabled. We now have new patches that create irq_desc according to device numa node. This patch removes the leftover bits of the dynamic balancer. [ Impact: remove dead code ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <49F654AF.8000808@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-28irq, cpumask: correct CPUMASKS_OFFSTACK typo and fix falloutYinghai Lu
CPUMASKS_OFFSTACK is not defined anywhere (it is CPUMASK_OFFSTACK). It is a typo and init_allocate_desc_masks() is called before it set affinity to all cpus... Split init_alloc_desc_masks() into all_desc_masks() and init_desc_masks(). Also use CPUMASK_OFFSTACK in alloc_desc_masks(). [ Impact: fix smp_affinity copying/setup when moving irq_desc between CPUs ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> LKML-Reference: <49F6546E.3040406@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-06Merge branch 'linus' into irq/threadedIngo Molnar
Conflicts: include/linux/irq.h kernel/irq/handle.c
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24genirq: threaded irq handlers review fixupsThomas Gleixner
Delta patch to address the review comments. - Implement warning when IRQ_WAKE_THREAD is requested and no thread handler installed - coding style fixes Pointed-out-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
