path: root/kernel/irq
2014-06-30genirq: Sanitize spurious interrupt detection of threaded irqsThomas Gleixner
commit 1e77d0a1ed7417d2a5a52a7b8d32aea1833faa6c upstream. Till reported that the spurious interrupt detection of threaded interrupts is broken in two ways: - note_interrupt() is called for each action thread of a shared interrupt line. That's wrong as we are only interested whether none of the device drivers felt responsible for the interrupt, but by calling multiple times for a single interrupt line we account IRQ_NONE even if one of the drivers felt responsible. - note_interrupt() when called from the thread handler is not serialized. That leaves the members of irq_desc which are used for the spurious detection unprotected. To solve this we need to defer the spurious detection of a threaded interrupt to the next hardware interrupt context where we have implicit serialization. If note_interrupt is called with action_ret == IRQ_WAKE_THREAD, we check whether the previous interrupt requested a deferred check. If not, we request a deferred check for the next hardware interrupt and return. If set, we check whether one of the interrupt threads signaled success. Depending on this information we feed the result into the spurious detector. If one primary handler of a shared interrupt returns IRQ_HANDLED we disable the deferred check of irq threads on the same line, as we have found at least one device driver who cared. Reported-by: Till Straumann <strauman@slac.stanford.edu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Austin Schuh <austin@peloton-tech.com> Cc: Oliver Hartkopp <socketcan@hartkopp.net> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz> Cc: Marc Kleine-Budde <mkl@pengutronix.de> Cc: linux-can@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1303071450130.22263@ionos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07genirq: Allow forcing cpu affinity of interruptsThomas Gleixner
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream. The current implementation of irq_set_affinity() refuses rightfully to route an interrupt to an offline cpu. But there is a special case, where this is actually desired. Some of the ARM SoCs have per cpu timers which require setting the affinity during cpu startup where the cpu is not yet in the online mask. If we can't do that, then the local timer interrupt for the about to become online cpu is routed to some random online cpu. The developers of the affected machines tried to work around that issue, but that results in a massive mess in that timer code. We have a yet unused argument in the set_affinity callbacks of the irq chips, which I added back then for a similar reason. It was never required so it got not used. But I'm happy that I never removed it. That allows us to implement a sane handling of the above scenario. So the affected SoC drivers can add the required force handling to their interrupt chip, switch the timer code to irq_force_affinity() and things just work. This does not affect any existing user of irq_set_affinity(). Tagged for stable to allow a simple fix of the affected SoC clock event drivers. Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Tomasz Figa <t.figa@samsung.com>, Cc: Daniel Lezcano <daniel.lezcano@linaro.org>, Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-arm-kernel@lists.infradead.org, Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-27genirq: Include missing header file in irqdomain.cRashika Kheria
Include appropriate header file include/linux/of_irq.h in kernel/irq/irqdomain.c because it contains prototype definition of function define in kernel/irq/irqdomain.c. This eliminates the following warning in kernel/irq/irqdomain.c: kernel/irq/irqdomain.c:468:14: warning: no previous prototype for ‘irq_create_of_mapping’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Link: http://lkml.kernel.org/r/eb89aebea7ff1a46122918ac389ebecf8248be9a.1393493276.git.rashika.kheria@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-27genirq: Remove racy waitqueue_active checkChuansheng Liu
We hit one rare case below: T1 calling disable_irq(), but hanging at synchronize_irq() always; The corresponding irq thread is in sleeping state; And all CPUs are in idle state; After analysis, we found there is one possible scenerio which causes T1 is waiting there forever: CPU0 CPU1 synchronize_irq() wait_event() spin_lock() atomic_dec_and_test(&threads_active) insert the __wait into queue spin_unlock() if(waitqueue_active) atomic_read(&threads_active) wake_up() Here after inserted the __wait into queue on CPU0, and before test if queue is empty on CPU1, there is no barrier, it maybe cause it is not visible for CPU1 immediately, although CPU0 has updated the queue list. It is similar for CPU0 atomic_read() threads_active also. So we'd need one smp_mb() before waitqueue_active.that, but removing the waitqueue_active() check solves it as wel l and it makes things simple and clear. Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com> Cc: Xiaoming Wang <xiaoming.wang@intel.com> Link: http://lkml.kernel.org/r/1393212590-32543-1-git-send-email-chuansheng.liu@intel.com Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-15Merge branches 'irq-urgent-for-linus' and 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq update from Thomas Gleixner: "Fix from the urgent branch: a trivial oneliner adding the missing Kconfig dependency curing build failures which have been discovered by several build robots. The update in the irq-core branch provides a new function in the irq/devres code, which is a prerequisite for driver developers to get rid of boilerplate code all over the place. Not a bugfix, but it has zero impact on the current kernel due to the lack of users. It's simpler to provide the infrastructure to interested parties via your tree than fulfilling the wishlist of driver maintainers on which particular commit or tag this should be based on" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=n * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add devm_request_any_context_irq()
2014-02-11genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=nPaul Gortmaker
In allmodconfig builds for sparc and any other arch which does not set CONFIG_SPARSE_IRQ, the following will be seen at modpost: CC [M] lib/cpu-notifier-error-inject.o CC [M] lib/pm-notifier-error-inject.o ERROR: "irq_to_desc" [drivers/gpio/gpio-mcp23s08.ko] undefined! make[2]: *** [__modpost] Error 1 This happens because commit 3911ff30f5 ("genirq: export handle_edge_irq() and irq_to_desc()") added one export for it, but there were actually two instances of it, in an if/else clause for CONFIG_SPARSE_IRQ. Add the second one. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: stable@vger.kernel.org # 3.4+ Link: http://lkml.kernel.org/r/1392057610-11514-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-09genirq: Add devm_request_any_context_irq()Stephen Boyd
Some drivers use request_any_context_irq() but there isn't a devm_* function for it. Add one so that these drivers don't need to explicitly free the irq on driver detach. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: linux-arm-kernel@lists.infradead.org Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Link: http://lkml.kernel.org/r/1388709460-19222-3-git-send-email-sboyd@codeaurora.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-05genirq: Generic irq chip requires IRQ_DOMAINNitin A Kamble
The generic_chip.c uses interfaces from irq_domain.c which is controlled by the IRQ_DOMAIN config option, but there is no Kconfig dependency so the build can fail: linux/kernel/irq/generic-chip.c:400:11: error: 'irq_domain_xlate_onetwocell' undeclared here (not in a function) Select IRQ_DOMAIN when GENERIC_IRQ_CHIP is selected. Signed-off-by: Nitin A Kamble <nitin.a.kamble@intel.com> Link: http://lkml.kernel.org/r/1391129410-54548-2-git-send-email-nitin.a.kamble@intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org # 3.11+
2013-12-02Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: - Correction of fuzzy and fragile IRQ_RETVAL macro - IRQ related resume fix affecting only XEN - ARM/GIC fix for chained GIC controllers * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: Gic: fix boot for chained gics irq: Enable all irqs unconditionally in irq_resume genirq: Correct fuzzy and fragile IRQ_RETVAL() definition
2013-11-25irq: Enable all irqs unconditionally in irq_resumeLaxman Dewangan
When the system enters suspend, it disables all interrupts in suspend_device_irqs(), including the interrupts marked EARLY_RESUME. On the resume side things are different. The EARLY_RESUME interrupts are reenabled in sys_core_ops->resume and the non EARLY_RESUME interrupts are reenabled in the normal system resume path. When suspend_noirq() failed or suspend is aborted for any other reason, we might omit the resume side call to sys_core_ops->resume() and therefor the interrupts marked EARLY_RESUME are not reenabled and stay disabled forever. To solve this, enable all irqs unconditionally in irq_resume() regardless whether interrupts marked EARLY_RESUMEhave been already enabled or not. This might try to reenable already enabled interrupts in the non failure case, but the only affected platform is XEN and it has been confirmed that it does not cause any side effects. [ tglx: Massaged changelog. ] Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Pavel Machek <pavel@ucw.cz> Cc: <ian.campbell@citrix.com> Cc: <rjw@rjwysocki.net> Cc: <len.brown@intel.com> Cc: <gregkh@linuxfoundation.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1385388587-16442-1-git-send-email-ldewangan@nvidia.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-11-19Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq cleanups from Ingo Molnar: "This is a multi-arch cleanup series from Thomas Gleixner, which we kept to near the end of the merge window, to not interfere with architecture updates. This series (motivated by the -rt kernel) unifies more aspects of IRQ handling and generalizes PREEMPT_ACTIVE" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: preempt: Make PREEMPT_ACTIVE generic sparc: Use preempt_schedule_irq ia64: Use preempt_schedule_irq m32r: Use preempt_schedule_irq hardirq: Make hardirq bits generic m68k: Simplify low level interrupt handling code genirq: Prevent spurious detection for unconditionally polled interrupts
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-13genirq: Prevent spurious detection for unconditionally polled interruptsThomas Gleixner
On a 68k platform a couple of interrupts are demultiplexed and "polled" from a top level interrupt. Unfortunately there is no way to determine which of the sub interrupts raised the top level interrupt, so all of the demultiplexed interrupt handlers need to be invoked. Given a high enough frequency this can trigger the spurious interrupt detection mechanism, if one of the demultiplex interrupts returns IRQ_NONE continuously. But this is a false positive as the polling causes this behaviour and not buggy hardware/software. Introduce IRQ_POLLED which can be set at interrupt chip setup time via irq_set_status_flags(). The flag excludes the interrupt from the spurious detector and from all core polling activities. Reported-and-tested-by: Michael Schmitz <schmitzmic@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1311061149250.23353@ionos.tec.linutronix.de
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-10-28genirq: Set the irq thread policy without checking CAP_SYS_NICEThomas Pfaff
In commit ee23871389 ("genirq: Set irq thread to RT priority on creation") we moved the assigment of the thread's priority from the thread's function into __setup_irq(). That function may run in user context for instance if the user opens an UART node and then driver calls requests in the ->open() callback. That user may not have CAP_SYS_NICE and so the irq thread won't run with the SCHED_OTHER policy. This patch uses sched_setscheduler_nocheck() so we omit the CAP_SYS_NICE check which is otherwise required for the SCHED_OTHER policy. [bigeasy: Rewrite the changelog] Signed-off-by: Thomas Pfaff <tpfaff@pcs.com> Cc: Ivo Sieben <meltedpianoman@gmail.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1381489240-29626-1-git-send-email-bigeasy@linutronix.de Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-10-24of/irq: simplify args to irq_create_of_mappingGrant Likely
All the callers of irq_create_of_mapping() pass the contents of a struct of_phandle_args structure to the function. Since all the callers already have an of_phandle_args pointer, why not pass it directly to irq_create_of_mapping()? Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-18irq: Fix some trivial typos in commentsXie XiuQi
Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com> [jkosina@suse.cz: fix 'explicitly', noticed by Randy Dunlap] Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-13Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: - core fix for missing round up in the generic irq chip implementation - new irq chip for MOXA SoCs - a few fixes and cleanups in the irqchip drivers * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: Add support for MOXA ART SoCs genirq: generic chip: Use DIV_ROUND_UP to calculate numchips irqchip: nvic: Fix wrong num_ct argument for irq_alloc_domain_generic_chips() irqchip: sun4i: Staticize sun4i_irq_ack() irqchip: vt8500: Staticize local symbols
2013-07-13Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "MIPS updates: - All the things that didn't make 3.10. - Removes the Windriver PPMC platform. Nobody will miss it. - Remove a workaround from kernel/irq/irqdomain.c which was there exclusivly for MIPS. Patch by Grant Likely. - More small improvments for the SEAD 3 platform - Improvments on the BMIPS / SMP support for the BCM63xx series. - Various cleanups of dead leftovers. - Platform support for the Cavium Octeon-based EdgeRouter Lite. Two large KVM patchsets didn't make it for this pull request because their respective authors are vacationing" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits) MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions MIPS: SEAD3: Disable L2 cache on SEAD-3. MIPS: BCM63xx: Enable second core SMP on BCM6328 if available MIPS: BCM63xx: Add SMP support to prom.c MIPS: define write{b,w,l,q}_relaxed MIPS: Expose missing pci_io{map,unmap} declarations MIPS: Malta: Update GCMP detection. Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET" MIPS: APSP: Remove <asm/kspd.h> SSB: Kconfig: Amend SSB_EMBEDDED dependencies MIPS: microMIPS: Fix improper definition of ISA exception bit. MIPS: Don't try to decode microMIPS branch instructions where they cannot exist. MIPS: Declare emulate_load_store_microMIPS as a static function. MIPS: Fix typos and cleanup comment MIPS: Cleanup indentation and whitespace MIPS: BMIPS: support booting from physical CPU other than 0 MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS MIPS: GIC: Fix gic_set_affinity infinite loop MIPS: Don't save/restore OCTEON wide multiplier state on syscalls. ...
2013-07-06Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull irqdomain refactoring from Grant Likely: "This is the long awaited simplification of irqdomain. It gets rid of the different types of irq domains and instead both linear and tree mappings can be supported in a single domain. Doing this removes a lot of special case code and makes irq domains simpler to understand overall" * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux: irq: fix checkpatch error irqdomain: Include hwirq number in /proc/interrupts irqdomain: make irq_linear_revmap() a fast path again irqdomain: remove irq_domain_generate_simple() irqdomain: Refactor irq_domain_associate_many() irqdomain: Beef up debugfs output irqdomain: Clean up aftermath of irq_domain refactoring irqdomain: Eliminate revmap type irqdomain: merge linear and tree reverse mappings. irqdomain: Add a name field irqdomain: Replace LEGACY mapping with LINEAR irqdomain: Relax failure path on setting up mappings
2013-07-05genirq: generic chip: Use DIV_ROUND_UP to calculate numchipsAxel Lin
The number of interrupts in a domain may be not divisible by the number of interrupts each chip handles. Integer division may truncate the result, thus use DIV_ROUND_UP to count numchips. Seems all users of irq_alloc_domain_generic_chips() in current code do not have this issue. I just found the issue while reading the code. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Arnd Bergmann <arnd@arndb.de> Link: http://lkml.kernel.org/r/1373015592.18252.2.camel@phoenix Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-02Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core irq changes from Ingo Molnar: "The main changes: - generic-irqchip driver additions, cleanups and fixes - 3 new irqchip drivers: ARMv7-M NVIC, TB10x and Marvell Orion SoCs - irq_get_trigger_type() simplification and cross-arch cleanup - various cleanups, simplifications - documentation updates" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) softirq: Use _RET_IP_ genirq: Add the generic chip to the genirq docbook genirq: generic-chip: Export some irq_gc_ functions genirq: Fix can_request_irq() for IRQs without an action irqchip: exynos-combiner: Staticize combiner_init irqchip: Add support for ARMv7-M NVIC irqchip: Add TB10x interrupt controller driver irqdomain: Use irq_get_trigger_type() to get IRQ flags MIPS: octeon: Use irq_get_trigger_type() to get IRQ flags arm: orion: Use irq_get_trigger_type() to get IRQ flags mfd: stmpe: use irq_get_trigger_type() to get IRQ flags mfd: twl4030-irq: Use irq_get_trigger_type() to get IRQ flags gpio: mvebu: Use irq_get_trigger_type() to get IRQ flags genirq: Add irq_get_trigger_type() to get IRQ flags genirq: Irqchip: document gcflags arg of irq_alloc_domain_generic_chips genirq: Set irq thread to RT priority on creation irqchip: Add support for Marvell Orion SoCs genirq: Add kerneldoc for irq_disable. genirq: irqchip: Add mask to block out invalid irqs genirq: Generic chip: Add linear irq domain support ...
2013-06-28genirq: Add the generic chip to the genirq docbookThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Randy Dunlap <rdunlap@infradead.org>
2013-06-28genirq: generic-chip: Export some irq_gc_ functionsFabio Estevam
When building imx_v6_v7_defconfig with imx-drm drivers selected as modules, we get the following build errors: ERROR: "irq_gc_mask_clr_bit" [drivers/staging/imx-drm/ipu-v3/imx-ipu-v3.ko] undefined! ERROR: "irq_gc_mask_set_bit" [drivers/staging/imx-drm/ipu-v3/imx-ipu-v3.ko] undefined! ERROR: "irq_gc_ack_set_bit" [drivers/staging/imx-drm/ipu-v3/imx-ipu-v3.ko] undefined! Export the required functions to avoid this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: shawn.guo@linaro.org Cc: kernel@pengutronix.de Link: http://lkml.kernel.org/r/1372389789-7048-1-git-send-email-festevam@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-28genirq: Fix can_request_irq() for IRQs without an actionBen Hutchings
Commit 02725e7471b8 ('genirq: Use irq_get/put functions'), inadvertently changed can_request_irq() to return 0 for IRQs that have no action. This causes pcibios_lookup_irq() to select only IRQs that already have an action with IRQF_SHARED set, or to fail if there are none. Change can_request_irq() to return 1 for IRQs that have no action (if the first two conditions are met). Reported-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> Tested-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> (against 3.2) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: 709647@bugs.debian.org Cc: stable@vger.kernel.org # 2.6.39+ Link: http://bugs.debian.org/709647 Link: http://lkml.kernel.org/r/1372383630.23847.40.camel@deadeye.wl.decadent.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-25irqdomain: Use irq_get_trigger_type() to get IRQ flagsJavier Martinez Canillas
Use irq_get_trigger_type() to get the IRQ trigger type flags instead calling irqd_get_trigger_type(irq_desc_get_irq_data(virq)) Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/1371228049-27080-8-git-send-email-javier.martinez@collabora.co.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-24genirq: Irqchip: document gcflags arg of irq_alloc_domain_generic_chipsJames Hogan
Commit 088f40b7b027dad6519712ff224a5798dd62a204 ("genirq: Generic chip: Add linear irq domain support") missed kerneldoc for the gcflags argument of irq_alloc_domain_generic_chips(). Add it now. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Link: http://lkml.kernel.org/r/1371564513-4327-1-git-send-email-james.hogan@imgtec.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-24irq: fix checkpatch errorKefeng Wang
ERROR: space required before the open parenthesis '(' WARNING: Prefer pr_warn(... to pr_warning(... Just fix above 2 issue. Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-24irqdomain: Include hwirq number in /proc/interruptsGrant Likely
Add the hardware interrupt number to the output of /proc/interrupts. It is often important to have access to the hardware interrupt number because it identifies exactly how an interrupt signal is wired up to the interrupt controller. This is especially important when using irq_domains since irq numbers get dynamically allocated in that case, and have no relation to the actual hardware number. Note: This output is currently conditional on whether or not the irq_domain pointer is set; however hwirq could still be used without irq_domain. It may be worthwhile to always output the hwirq number regardless of the domain pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Olof Johansson <olof@lixom.net> Cc: Ben Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-06-24irqdomain: make irq_linear_revmap() a fast path againGrant Likely
Over the years, irq_linear_revmap() gained tests and checks to make sure callers were using it safely, which while important, also make it less of a fast path. After the irqdomain refactoring done recently, it is now possible to make irq_linear_revmap() a fast path again. This patch moves irq_linear_revmap() to the header file and makes it a static inline so that interrupt controller drivers using a linear mapping can decode the virq from a hwirq in just a couple of instructions. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-24irqdomain: remove irq_domain_generate_simple()Grant Likely
Nobody calls it; remove the function Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-24irqdomain: Refactor irq_domain_associate_many()Grant Likely
Originally, irq_domain_associate_many() was designed to unwind the mapped irqs on a failure of any individual association. However, that proved to be a problem with certain IRQ controllers. Some of them only support a subset of irqs, and will fail when attempting to map a reserved IRQ. In those cases we want to map as many IRQs as possible, so instead it is better for irq_domain_associate_many() to make a best-effort attempt to map irqs, but not fail if any or all of them don't succeed. If a caller really cares about how many irqs got associated, then it should instead go back and check that all of the irqs is cares about were mapped. The original design open-coded the individual association code into the body of irq_domain_associate_many(), but with no longer needing to unwind associations, the code becomes simpler to split out irq_domain_associate() to contain the bulk of the logic, and irq_domain_associate_many() to be a simple loop wrapper. This patch also adds a new error check to the associate path to make sure it isn't called for an irq larger than the controller can handle, and adds locking so that the irq_domain_mutex is held while setting up a new association. v3: Fixup missing change to irq_domain_add_tree() v2: Fixup x86 warning. irq_domain_associate_many() no longer returns an error code, but reports errors to the printk log directly. In the majority of cases we don't actually want to fail if there is a problem, but rather log it and still try to boot the system. Signed-off-by: Grant Likely <grant.likely@linaro.org> irqdomain: Fix flubbed irq_domain_associate_many refactoring commit d39046ec72, "irqdomain: Refactor irq_domain_associate_many()" was missing the following hunk which causes a boot failure on anything using irq_domain_add_tree() to allocate an irq domain. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Michael Neuling <mikey@neuling.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>, Cc: Thomas Gleixner <tglx@linutronix.de>, Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2013-06-18irq/generic-chip: fix a few kernel-doc entriesUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-06-18irqdomain: Remove temporary MIPS workaround codeGrant Likely
The MIPS interrupt controllers are all registering their own irq_domains now. Drop the MIPS specific code because it is no longer needed. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/5458/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-06-11genirq: Set irq thread to RT priority on creationIvo Sieben
When a threaded irq handler is installed the irq thread is initially created on normal scheduling priority. Only after the irq thread is woken up it sets its priority to RT_FIFO MAX_USER_RT_PRIO/2 itself. This means that interrupts that occur directly after the irq handler is installed will be handled on a normal scheduling priority instead of the realtime priority that one would expect. Fix this by setting the RT priority on creation of the irq_thread. Signed-off-by: Ivo Sieben <meltedpianoman@gmail.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1370254322-17240-1-git-send-email-meltedpianoman@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-10irqdomain: Beef up debugfs outputGrant Likely
This patch increases the amount of output produced by the irq_domain_mapping debugfs file by first listing all of the registered irq domains at the beginning of the output, and then by including all mapped IRQs in the output, not just the active ones. It is very useful when debugging irqdomain issues to be able to see the entire list of mapped irqs, not just the ones that happen to be connected to devices. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: Clean up aftermath of irq_domain refactoringGrant Likely
After refactoring the irqdomain code, there are a number of API functions that are merely empty wrappers around core code. Drop those wrappers out of the C file and replace them with static inlines in the header. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: Eliminate revmap typeGrant Likely
The NOMAP irq_domain type is only used by a handful of interrupt controllers and it unnecessarily complicates the code by adding special cases on how to look up mappings and different revmap functions are used for each type which need to validate the correct type is passed to it before performing the reverse map. Eliminating the revmap_type and making a single reverse mapping function simplifies the code. It also shouldn't be any slower than having separate revmap functions because the type of the revmap needed to be checked anyway. The linear and tree revmap types were already merged in a previous patch. This patch rolls the NOMAP or direct mapping behaviour into the same domain code making is possible for an irq domain to do any mapping type; linear, tree or direct; and that the mapping will be transparent to the interrupt controller driver. With this change, direct mappings will get stored in the linear or tree mapping for consistency. Reverse mapping from the hwirq to virq will go through the normal lookup process. However, any controller using a direct mapping can take advantage of knowing that hwirq==virq for any mapped interrupts skip doing a revmap lookup when handling IRQs. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: merge linear and tree reverse mappings.Grant Likely
Keeping them separate makes irq_domain more complex and adds a lot of code (as proven by the diffstat). Merging them simplifies the whole scheme. This change makes it so both the tree and linear methods can be used by the same irq_domain instance. If the hwirq is less than the ->linear_size, then the linear map is used to reverse map the hwirq. Otherwise the radix tree is used. The test for which map to use is no more expensive that the existing code, so the performance of fast path is preserved. It also means that complex interrupt controllers can use both the linear map and a tree in the same domain. This may be useful for an interrupt controller with a base set of core irqs and a large number of GPIOs which might be used as irqs. The linear map could cover the core irqs, and the tree used for thas irqs. The linear map could cover the core irqs, and the tree used for the gpios. v2: Drop reorganization of revmap data Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2013-06-10irqdomain: Add a name fieldGrant Likely
This patch adds a name field to the irq_domain structure to help mere mortals understand the mappings between irq domains and virqs. It also converts a number of places that have open-coded some kind of fudging an irqdomain name to use the new field. This means a more consistent display of names in irq domain log messages and debugfs output. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-10irqdomain: Replace LEGACY mapping with LINEARGrant Likely
The LEGACY mapping unnecessarily complicates the irqdomain code and can easily be implemented with a linear mapping. By ripping it out and replacing it with the LINEAR mapping the object size of irqdomain.c shrinks by about 330 bytes (ARMv7) which offsets the additional allocation required by the linear map. It also makes it possible for current LEGACY map users to pre-allocate irq_descs for a subset of the hwirqs and dynamically allocate the rest as needed. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <rob.herring@calxeda.com>
2013-06-10irqdomain: Relax failure path on setting up mappingsGrant Likely
Commit 98aa468e, "irqdomain: Support for static IRQ mapping and association" introduced an API for directly associating blocks of hwirqs to linux irqs. However, if any irq in that block failed to map (say if the mapping functions returns an error because the irq is already mapped) then the whole thing will fail and roll back. This is probably too aggressive since there are valid reasons why a mapping may fail. ie. Firmware may have a particular IRQ marked as unusable. This patch drops the error path out of irq_domain_associate(). If a mapping fails, then it is simply skipped. There is no reason to fail the entire allocation. v2: Still output an information message on failed mappings and make sure attempted mapping gets cleared out of the irq_data structure. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-06-10Merge remote-tracking branch 'tip/irq/for-arm' into irqdomain/nextGrant Likely
2013-06-08irqdomain: document the simple domain first_irqLinus Walleij
The first_irq needs to be zero to get a linear domain and that comes with special semantics. We want to simplify this going forward but some documentation never hurts. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-08kernel/irq/irqdomain.c: before use 'irq_data', need check it whether valid.Chen Gang
Since irq_data may be NULL, if so, we WARN_ON(), and continue, 'hwirq' which related with 'irq_data' has to initialize later, or it will cause issue. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-08irqdomain: export irq_domain_add_simpleArnd Bergmann
All other irq_domain_add_* functions are exported already, and apparently this one got left out by mistake, which causes build errors for ARM allmodconfig kernels: ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-rcar.ko] undefined! ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-em.ko] undefined! Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-05-29genirq: Add kerneldoc for irq_disable.Andreas Fenkart
Document the lazy disable functionality. comment based on changelog of d209a699a0b975ad Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Cc: balbi@ti.com Link: http://lkml.kernel.org/r/1368181290-1583-1-git-send-email-andreas.fenkart@streamunlimited.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-05-29genirq: irqchip: Add mask to block out invalid irqsGrant Likely
Some controllers have irqs that aren't wired up and must never be used. For the generic chip attached to an irq_domain this provides a mask that can be used to block out particular irqs so that they never get mapped. Signed-off-by: Grant Likely <grant.likely@linaro.org> Link: http://lkml.kernel.org/r/1369793454-19197-2-git-send-email-grant.likely@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
