path: root/kernel/jump_label.c
2012-08-06jump_label: Export jump_label_rate_limit()Gleb Natapov
CC: Jason Baron <jbaron@redhat.com> CC: Ingo Molnar <mingo@elte.hu> CC: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-02-28static keys: Inline the static_key_enabled() functionJason Baron
In the jump label enabled case, calling static_key_enabled() results in a function call. The function returns the results of a compare, so it really doesn't need the overhead of a full function call. Let's make it 'static inline' for both the jump label enabled and disabled cases. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: a.p.zijlstra@chello.nl Cc: rostedt@goodmis.org Cc: mathieu.desnoyers@polymtl.ca Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/201202281849.q1SIn1p2023270@int-mx10.intmail.prod.int.phx2.redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-24static keys: Introduce 'struct static_key', static_key_true()/false() and ↵Ingo Molnar
static_key_slow_[inc|dec]() So here's a boot tested patch on top of Jason's series that does all the cleanups I talked about and turns jump labels into a more intuitive to use facility. It should also address the various misconceptions and confusions that surround jump labels. Typical usage scenarios: #include <linux/static_key.h> struct static_key key = STATIC_KEY_INIT_TRUE; if (static_key_false(&key)) do unlikely code else do likely code Or: if (static_key_true(&key)) do likely code else do unlikely code The static key is modified via: static_key_slow_inc(&key); ... static_key_slow_dec(&key); The 'slow' prefix makes it abundantly clear that this is an expensive operation. I've updated all in-kernel code to use this everywhere. Note that I (intentionally) have not pushed through the rename blindly through to the lowest levels: the actual jump-label patching arch facility should be named like that, so we want to decouple jump labels from the static-key facility a bit. On non-jump-label enabled architectures static keys default to likely()/unlikely() branches. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: a.p.zijlstra@chello.nl Cc: mathieu.desnoyers@efficios.com Cc: davem@davemloft.net Cc: ddaney.cavm@gmail.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20120222085809.GA26397@elte.hu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-22jump label: Fix compiler warningJason Baron
While cross-compiling on sparc64, I found: kernel/jump_label.c: In function 'jump_label_update': kernel/jump_label.c:447:40: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] Fix by casting to 'unsigned long'. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: rostedt@goodmis.org Cc: mathieu.desnoyers@efficios.com Cc: davem@davemloft.net Cc: ddaney.cavm@gmail.com Cc: a.p.zijlstra@chello.nl Link: http://lkml.kernel.org/r/08026cbc6df80619cae833ef1ebbbc43efab69ab.1329851692.git.jbaron@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-22jump label: Add a WARN() if jump label key count goes negativeJason Baron
The count on a jump label key should never go negative. Add a WARN() to check for this condition. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: rostedt@goodmis.org Cc: mathieu.desnoyers@efficios.com Cc: davem@davemloft.net Cc: ddaney.cavm@gmail.com Cc: a.p.zijlstra@chello.nl Link: http://lkml.kernel.org/r/3c68556121be4d1920417a3fe367da1ec38246b4.1329851692.git.jbaron@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-27Merge remote-tracking branch 'tip/perf/core' into kvm-updates/3.3Avi Kivity
* tip/perf/core: (66 commits) perf, x86: Expose perf capability to other modules perf, x86: Implement arch event mask as quirk x86, perf: Disable non available architectural events jump_label: Provide jump_label_key initializers jump_label, x86: Fix section mismatch perf, core: Rate limit perf_sched_events jump_label patching perf: Fix enable_on_exec for sibling events perf: Remove superfluous arguments perf, x86: Prefer fixed-purpose counters when scheduling perf, x86: Fix event scheduler for constraints with overlapping counters perf, x86: Implement event scheduler helper functions perf: Avoid a useless pmu_disable() in the perf-tick x86/tools: Add decoded instruction dump mode x86: Update instruction decoder to support new AVX formats x86/tools: Fix insn_sanity message outputs x86/tools: Fix instruction decoder message output x86: Fix instruction decoder to handle grouped AVX instructions x86/tools: Fix Makefile to build all test tools perf test: Soft errors shouldn't stop the "Validate PERF_RECORD_" test perf test: Validate PERF_RECORD_ events and perf_sample fields ... Signed-off-by: Avi Kivity <avi@redhat.com> * commit 'b3d9468a8bd218a695e3a0ff112cd4efd27b670a': (66 commits) perf, x86: Expose perf capability to other modules perf, x86: Implement arch event mask as quirk x86, perf: Disable non available architectural events jump_label: Provide jump_label_key initializers jump_label, x86: Fix section mismatch perf, core: Rate limit perf_sched_events jump_label patching perf: Fix enable_on_exec for sibling events perf: Remove superfluous arguments perf, x86: Prefer fixed-purpose counters when scheduling perf, x86: Fix event scheduler for constraints with overlapping counters perf, x86: Implement event scheduler helper functions perf: Avoid a useless pmu_disable() in the perf-tick x86/tools: Add decoded instruction dump mode x86: Update instruction decoder to support new AVX formats x86/tools: Fix insn_sanity message outputs x86/tools: Fix instruction decoder message output x86: Fix instruction decoder to handle grouped AVX instructions x86/tools: Fix Makefile to build all test tools perf test: Soft errors shouldn't stop the "Validate PERF_RECORD_" test perf test: Validate PERF_RECORD_ events and perf_sample fields ...
2011-12-27jump-label: export jump_label_inc/jump_label_decXiao Guangrong
Export these two symbols, they will be used by KVM mmu audit Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-06jump_label: Provide jump_label_key initializersPeter Zijlstra
Provide two initializers for jump_label_key that initialize it enabled or disabled. Also modify all jump_label code to allow for jump_labels to be initialized enabled. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jason Baron <jbaron@redhat.com> Link: http://lkml.kernel.org/n/tip-p40e3yj21b68y03z1yv825e7@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-06jump_label, x86: Fix section mismatchPeter Zijlstra
WARNING: arch/x86/kernel/built-in.o(.text+0x4c71): Section mismatch in reference from the function arch_jump_label_transform_static() to the function .init.text:text_poke_early() The function arch_jump_label_transform_static() references the function __init text_poke_early(). This is often because arch_jump_label_transform_static lacks a __init annotation or the annotation of text_poke_early is wrong. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jason Baron <jbaron@redhat.com> Link: http://lkml.kernel.org/n/tip-9lefe89mrvurrwpqw5h8xm8z@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-06perf, core: Rate limit perf_sched_events jump_label patchingGleb Natapov
jump_lable patching is very expensive operation that involves pausing all cpus. The patching of perf_sched_events jump_label is easily controllable from userspace by unprivileged user. When te user runs a loop like this: "while true; do perf stat -e cycles true; done" ... the performance of my test application that just increments a counter for one second drops by 4%. This is on a 16 cpu box with my test application using only one of them. An impact on a real server doing real work will be worse. Performance of KVM PMU drops nearly 50% due to jump_lable for "perf record" since KVM PMU implementation creates and destroys perf event frequently. This patch introduces a way to rate limit jump_label patching and uses it to fix the above problem. I believe that as jump_label use will spread the problem will become more common and thus solving it in a generic code is appropriate. Also fixing it in the perf code would result in moving jump_label accounting logic to perf code with all the ifdefs in case of JUMP_LABEL=n kernel. With this patch all details are nicely hidden inside jump_label code. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111127155909.GO2557@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05jump_label: jump_label_inc may return before the code is patchedGleb Natapov
If cpu A calls jump_label_inc() just after atomic_add_return() is called by cpu B, atomic_inc_not_zero() will return value greater then zero and jump_label_inc() will return to a caller before jump_label_update() finishes its job on cpu B. Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com Cc: stable@vger.kernel.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-11-11Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core
2011-11-07jump_label: jump_label_inc may return before the code is patchedGleb Natapov
2011-10-25jump-label: initialize jump-label subsystem much earlierJeremy Fitzhardinge
Initialize jump_labels much, much earlier, so they're available for use during system setup. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2011-10-25jump_label: add arch_jump_label_transform_static() to optimise non-live code ↵Jeremy Fitzhardinge
updates When updating a newly loaded module, the code is definitely not yet executing on any processor, so it can be updated with no need for any heavyweight synchronization. This patch adds arch_jump_label_static() which is implemented as arch_jump_label_transform() by default, but architectures can override it if it avoids, say, a call to stop_machine(). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Jason Baron <jbaron@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2011-10-25jump_label: if a key has already been initialized, don't nop it outJeremy Fitzhardinge
If a key has been enabled before jump_label_init() is called, don't nop it out. This removes arch_jump_label_text_poke_early() (which can only nop out a site) and uses arch_jump_label_transform() instead. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Jason Baron <jbaron@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2011-06-29jump_label: Fix jump_label update for modulesXiao Guangrong
The jump labels entries for modules do not stop at __stop__jump_table, but after mod->jump_entries + mod_num_jump_entries. By checking the wrong end point, module trace events never get enabled. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Tested-by: Avi Kivity <avi@redhat.com> Tested-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Link: http://lkml.kernel.org/r/4E00038B.2060404@cn.fujitsu.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25jump_label: Check entries limit in __jump_label_updateJiri Olsa
When iterating the jump_label entries array (core or modules), the __jump_label_update function peeks over the last entry. The reason is that the end of the for loop depends on the key value of the processed entry. Thus when going through the last array entry, we will touch the memory behind the array limit. This bug probably will never be triggered, since most likely the memory behind the jump_label entries will be accesable and the entry->key will be different than the expected value. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Jason Baron <jbaron@redhat.com> Link: http://lkml.kernel.org/r/20110510104346.GC1899@jolsa.brq.redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-04-04jump label: Introduce static_branch() interfaceJason Baron
Introduce: static __always_inline bool static_branch(struct jump_label_key *key); instead of the old JUMP_LABEL(key, label) macro. In this way, jump labels become really easy to use: Define: struct jump_label_key jump_key; Can be used as: if (static_branch(&jump_key)) do unlikely code enable/disale via: jump_label_inc(&jump_key); jump_label_dec(&jump_key); that's it! For the jump labels disabled case, the static_branch() becomes an atomic_read(), and jump_label_inc()/dec() are simply atomic_inc(), atomic_dec() operations. We show testing results for this change below. Thanks to H. Peter Anvin for suggesting the 'static_branch()' construct. Since we now require a 'struct jump_label_key *key', we can store a pointer into the jump table addresses. In this way, we can enable/disable jump labels, in basically constant time. This change allows us to completely remove the previous hashtable scheme. Thanks to Peter Zijlstra for this re-write. Testing: I ran a series of 'tbench 20' runs 5 times (with reboots) for 3 configurations, where tracepoints were disabled. jump label configured in avg: 815.6 jump label *not* configured in (using atomic reads) avg: 800.1 jump label *not* configured in (regular reads) avg: 803.4 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110316212947.GA8792@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Suggested-by: H. Peter Anvin <hpa@linux.intel.com> Tested-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-29jump label: Make arch_jump_label_text_poke_early() optionalSteven Rostedt
Some archs do not need to do anything special for jump labels on startup (like MIPS). This patch adds a weak function stub for arch_jump_label_text_poke_early(); Cc: Jason Baron <jbaron@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: David Daney <ddaney@caviumnetworks.com> Suggested-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1286218615-24011-2-git-send-email-ddaney@caviumnetworks.com> LKML-Reference: <20101015201037.703989993@goodmis.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-28jump label: Fix deadlock b/w jump_label_mutex vs. text_mutexJason Baron
register_kprobe() downs the 'text_mutex' and then calls jump_label_text_reserved(), which downs the 'jump_label_mutex'. However, the jump label code takes those mutexes in the reverse order. Fix by requiring the caller of jump_label_text_reserved() to do the jump label locking via the newly added: jump_label_lock(), jump_label_unlock(). Currently, kprobes is the only user of jump_label_text_reserved(). Reported-by: Ingo Molnar <mingo@elte.hu> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <759032c48d5e30c27f0bba003d09bffa8e9f28bb.1285965957.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-28jump label: Fix module __init section raceJason Baron
Jump label uses is_module_text_address() to ensure that the module __init sections are valid before updating them. However, between the check for a valid module __init section and the subsequent jump label update, the module's __init section could be freed out from under us. We fix this potential race by adding a notifier callback to the MODULE_STATE_LIVE state. This notifier is called *after* the __init section has been run but before it is going to be freed. In the callback, the jump label code zeros the key value for any __init jump code within the module, and we add a check for a non-zero key value when we update jump labels. In this way we require no additional data structures. Thanks to Mathieu Desnoyers for pointing out this race condition. Reported-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <c6f037b7598777668025ceedd9294212fd95fa34.1285965957.git.jbaron@redhat.com> [ Renamed remove_module_init() to remove_jump_label_module_init() as suggested by Masami Hiramatsu. ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-22jump label: Add jump_label_text_reserved() to reserve jump pointsJason Baron
Add a jump_label_text_reserved(void *start, void *end), so that other pieces of code that want to modify kernel text, can first verify that jump label has not reserved the instruction. Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <06236663a3a7b1c1f13576bb9eccb6d9c17b7bfe.1284733808.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-22jump label: Base patch for jump labelJason Baron
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline assembly gcc mechanism, we can now branch to labels from an 'asm goto' statment. This allows us to create a 'no-op' fastpath, which can subsequently be patched with a jump to the slowpath code. This is useful for code which might be rarely used, but which we'd like to be able to call, if needed. Tracepoints are the current usecase that these are being implemented for. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com> [ cleaned up some formating ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
