path: root/kernel/jump_label.c
2011-12-09jump_label: jump_label_inc may return before the code is patchedGleb Natapov
commit bbbf7af4bf8fc69bc751818cf30521080fa47dcb upstream. If cpu A calls jump_label_inc() just after atomic_add_return() is called by cpu B, atomic_inc_not_zero() will return value greater then zero and jump_label_inc() will return to a caller before jump_label_update() finishes its job on cpu B. Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-29jump_label: Fix jump_label update for modulesXiao Guangrong
The jump labels entries for modules do not stop at __stop__jump_table, but after mod->jump_entries + mod_num_jump_entries. By checking the wrong end point, module trace events never get enabled. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Tested-by: Avi Kivity <avi@redhat.com> Tested-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Link: http://lkml.kernel.org/r/4E00038B.2060404@cn.fujitsu.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25jump_label: Check entries limit in __jump_label_updateJiri Olsa
When iterating the jump_label entries array (core or modules), the __jump_label_update function peeks over the last entry. The reason is that the end of the for loop depends on the key value of the processed entry. Thus when going through the last array entry, we will touch the memory behind the array limit. This bug probably will never be triggered, since most likely the memory behind the jump_label entries will be accesable and the entry->key will be different than the expected value. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Jason Baron <jbaron@redhat.com> Link: http://lkml.kernel.org/r/20110510104346.GC1899@jolsa.brq.redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-04-04jump label: Introduce static_branch() interfaceJason Baron
Introduce: static __always_inline bool static_branch(struct jump_label_key *key); instead of the old JUMP_LABEL(key, label) macro. In this way, jump labels become really easy to use: Define: struct jump_label_key jump_key; Can be used as: if (static_branch(&jump_key)) do unlikely code enable/disale via: jump_label_inc(&jump_key); jump_label_dec(&jump_key); that's it! For the jump labels disabled case, the static_branch() becomes an atomic_read(), and jump_label_inc()/dec() are simply atomic_inc(), atomic_dec() operations. We show testing results for this change below. Thanks to H. Peter Anvin for suggesting the 'static_branch()' construct. Since we now require a 'struct jump_label_key *key', we can store a pointer into the jump table addresses. In this way, we can enable/disable jump labels, in basically constant time. This change allows us to completely remove the previous hashtable scheme. Thanks to Peter Zijlstra for this re-write. Testing: I ran a series of 'tbench 20' runs 5 times (with reboots) for 3 configurations, where tracepoints were disabled. jump label configured in avg: 815.6 jump label *not* configured in (using atomic reads) avg: 800.1 jump label *not* configured in (regular reads) avg: 803.4 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110316212947.GA8792@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Suggested-by: H. Peter Anvin <hpa@linux.intel.com> Tested-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-29jump label: Make arch_jump_label_text_poke_early() optionalSteven Rostedt
Some archs do not need to do anything special for jump labels on startup (like MIPS). This patch adds a weak function stub for arch_jump_label_text_poke_early(); Cc: Jason Baron <jbaron@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: David Daney <ddaney@caviumnetworks.com> Suggested-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1286218615-24011-2-git-send-email-ddaney@caviumnetworks.com> LKML-Reference: <20101015201037.703989993@goodmis.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-28jump label: Fix deadlock b/w jump_label_mutex vs. text_mutexJason Baron
register_kprobe() downs the 'text_mutex' and then calls jump_label_text_reserved(), which downs the 'jump_label_mutex'. However, the jump label code takes those mutexes in the reverse order. Fix by requiring the caller of jump_label_text_reserved() to do the jump label locking via the newly added: jump_label_lock(), jump_label_unlock(). Currently, kprobes is the only user of jump_label_text_reserved(). Reported-by: Ingo Molnar <mingo@elte.hu> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <759032c48d5e30c27f0bba003d09bffa8e9f28bb.1285965957.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-28jump label: Fix module __init section raceJason Baron
Jump label uses is_module_text_address() to ensure that the module __init sections are valid before updating them. However, between the check for a valid module __init section and the subsequent jump label update, the module's __init section could be freed out from under us. We fix this potential race by adding a notifier callback to the MODULE_STATE_LIVE state. This notifier is called *after* the __init section has been run but before it is going to be freed. In the callback, the jump label code zeros the key value for any __init jump code within the module, and we add a check for a non-zero key value when we update jump labels. In this way we require no additional data structures. Thanks to Mathieu Desnoyers for pointing out this race condition. Reported-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <c6f037b7598777668025ceedd9294212fd95fa34.1285965957.git.jbaron@redhat.com> [ Renamed remove_module_init() to remove_jump_label_module_init() as suggested by Masami Hiramatsu. ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-22jump label: Add jump_label_text_reserved() to reserve jump pointsJason Baron
Add a jump_label_text_reserved(void *start, void *end), so that other pieces of code that want to modify kernel text, can first verify that jump label has not reserved the instruction. Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <06236663a3a7b1c1f13576bb9eccb6d9c17b7bfe.1284733808.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-22jump label: Base patch for jump labelJason Baron
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline assembly gcc mechanism, we can now branch to labels from an 'asm goto' statment. This allows us to create a 'no-op' fastpath, which can subsequently be patched with a jump to the slowpath code. This is useful for code which might be rarely used, but which we'd like to be able to call, if needed. Tracepoints are the current usecase that these are being implemented for. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com> [ cleaned up some formating ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
