[ Upstream commit c9484b986ef03492357fddd50afbdd02929cfa72 ]
Patch series "kcov: fix unexpected faults".
These patches fix a few issues where KCOV code could trigger recursive
faults, discovered while debugging a patch enabling KCOV for arch/arm:
* On CONFIG_PREEMPT kernels, there's a small race window where
__sanitizer_cov_trace_pc() can see a bogus kcov_area.
* Lazy faulting of the vmalloc area can cause mutual recursion between
fault handling code and __sanitizer_cov_trace_pc().
* During the context switch, switching the mm can cause the kcov_area to
be transiently unmapped.
These are prerequisites for enabling KCOV on arm, but the issues
themsevles are generic -- we just happen to avoid them by chance rather
than design on x86-64 and arm64.
This patch (of 3):
For kernels built with CONFIG_PREEMPT, some C code may execute before or
after the interrupt handler, while the hardirq count is zero. In these
cases, in_task() can return true.
A task can be interrupted in the middle of a KCOV_DISABLE ioctl while it
resets the task's kcov data via kcov_task_init(). Instrumented code
executed during this period will call __sanitizer_cov_trace_pc(), and as
in_task() returns true, will inspect t->kcov_mode before trying to write
to t->kcov_area.
In kcov_init_task() we update t->kcov_{mode,area,size} with plain stores,
which may be re-ordered, torn, etc. Thus __sanitizer_cov_trace_pc() may
see bogus values for any of these fields, and may attempt to write to
memory which is not mapped.
Let's avoid this by using WRITE_ONCE() to set t->kcov_mode, with a
barrier() to ensure this is ordered before we clear t->kov_{area,size}.
This ensures that any code execute while kcov_init_task() is preempted
will either see valid values for t->kcov_{area,size}, or will see that
t->kcov_mode is KCOV_MODE_DISABLED, and bail out without touching
t->kcov_area.
Link: http://lkml.kernel.org/r/20180504135535.53744-2-mark.rutland@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
commit a77660d231f8b3d84fd23ed482e0964f7aa546d6 upstream.
Currently KCOV_ENABLE does not check if the current task is already
associated with another kcov descriptor. As the result it is possible
to associate a single task with more than one kcov descriptor, which
later leads to a memory leak of the old descriptor. This relation is
really meant to be one-to-one (task has only one back link).
Extend validation to detect such misuse.
Link: http://lkml.kernel.org/r/20180122082520.15716-1-dvyukov@google.com
Fixes: 5c9a8750a640 ("kernel: add kcov code coverage")
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reported-by: Shankara Pailoor <sp3485@columbia.edu>
Cc: syzbot <syzkaller@googlegroups.com>
In __sanitizer_cov_trace_pc we use task_struct and fields within it, but
as we haven't included <linux/sched.h>, it is not guaranteed to be
defined. While we usually happen to acquire the definition through a
transitive include, this is fragile (and hasn't been true in the past,
causing issues with backports).
Include <linux/sched.h> to avoid any fragility.
[mark.rutland@arm.com: rewrote changelog]
Link: http://lkml.kernel.org/r/1481007384-27529-1-git-send-email-wangkefeng.wang@huawei.com
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: James Morse <james.morse@arm.com>
in_interrupt() returns a nonzero value when we are either in an
interrupt or have bh disabled via local_bh_disable(). Since we are
interested in only ignoring coverage from actual interrupts, do a proper
check instead of just calling in_interrupt().
As a result of this change, kcov will start to collect coverage from
within local_bh_disable()/local_bh_enable() sections.
Link: http://lkml.kernel.org/r/1476115803-20712-1-git-send-email-andreyknvl@google.com
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Nicolai Stange <nicstange@gmail.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Since commit 49d200deaa68 ("debugfs: prevent access to removed files'
private data"), a debugfs file's file_operations methods get proxied
through lifetime aware wrappers.
However, only a certain subset of the file_operations members is supported
by debugfs and ->mmap isn't among them -- it appears to be NULL from the
VFS layer's perspective.
This behaviour breaks the /sys/kernel/debug/kcov file introduced
concurrently with commit 5c9a8750a640 ("kernel: add kcov code coverage").
Since that file never gets removed, there is no file removal race and thus,
a lifetime checking proxy isn't needed.
Avoid the proxying for /sys/kernel/debug/kcov by creating it via
debugfs_create_file_unsafe() rather than debugfs_create_file().
Fixes: 49d200deaa68 ("debugfs: prevent access to removed files' private data")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Profiling 'if' statements in __sanitizer_cov_trace_pc() leads to
unbound recursion and crash:
__sanitizer_cov_trace_pc() ->
ftrace_likely_update ->
__sanitizer_cov_trace_pc() ...
Define DISABLE_BRANCH_PROFILING to disable this tracer.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Kcov causes the compiler to add a call to __sanitizer_cov_trace_pc() in
every basic block. Ftrace patches in a call to _mcount() to each
function it has annotated.
Letting these mechanisms annotate each other is a bad thing. Break the
loop by adding 'notrace' to __sanitizer_cov_trace_pc() so that ftrace
won't try to patch this code.
This patch lets arm64 with KCOV and STACK_TRACER boot.
Signed-off-by: James Morse <james.morse@arm.com>
Cc: Alexander Potapenko <glider@google.com>
kcov provides code coverage collection for coverage-guided fuzzing
(randomized testing). Coverage-guided fuzzing is a testing technique
that uses coverage feedback to determine new interesting inputs to a
system. A notable user-space example is AFL
(http://lcamtuf.coredump.cx/afl/). However, this technique is not
widely used for kernel testing due to missing compiler and kernel
support.
kcov does not aim to collect as much coverage as possible. It aims to
collect more or less stable coverage that is function of syscall inputs.
To achieve this goal it does not collect coverage in soft/hard
interrupts and instrumentation of some inherently non-deterministic or
non-interesting parts of kernel is disbled (e.g. scheduler, locking).
Currently there is a single coverage collection mode (tracing), but the
API anticipates additional collection modes. Initially I also
implemented a second mode which exposes coverage in a fixed-size hash
table of counters (what Quentin used in his original patch). I've
dropped the second mode for simplicity.
This patch adds the necessary support on kernel side. The complimentary
compiler support was added in gcc revision 231296.
We've used this support to build syzkaller system call fuzzer, which has
found 90 kernel bugs in just 2 months:
https://github.com/google/syzkaller/wiki/Found-Bugs
We've also found 30+ bugs in our internal systems with syzkaller.
Another (yet unexplored) direction where kcov coverage would greatly
help is more traditional "blob mutation". For example, mounting a
random blob as a filesystem, or receiving a random blob over wire.
Why not gcov. Typical fuzzing loop looks as follows: (1) reset
coverage, (2) execute a bit of code, (3) collect coverage, repeat. A
typical coverage can be just a dozen of basic blocks (e.g. an invalid
input). In such context gcov becomes prohibitively expensive as
reset/collect coverage steps depend on total number of basic
blocks/edges in program (in case of kernel it is about 2M). Cost of
kcov depends only on number of executed basic blocks/edges. On top of
that, kernel requires per-thread coverage because there are always
background threads and unrelated processes that also produce coverage.
With inlined gcov instrumentation per-thread coverage is not possible.
kcov exposes kernel PCs and control flow to user-space which is
insecure. But debugfs should not be mapped as user accessible.
Based on a patch by Quentin Casasnovas.
[akpm@linux-foundation.org: make task_struct.kcov_mode have type `enum kcov_mode']
[akpm@linux-foundation.org: unbreak allmodconfig]
[akpm@linux-foundation.org: follow x86 Makefile layout standards]
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: Tavis Ormandy <taviso@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Kees Cook <keescook@google.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: David Drysdale <drysdale@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Jiri Slaby <jslaby@suse.cz>
