path: root/kernel/kexec_core.c
2019-11-24kexec: Allocate decrypted control pages for kdump if SME is enabledLianbo Jiang
[ Upstream commit 9cf38d5559e813cccdba8b44c82cc46ba48d0896 ] When SME is enabled in the first kernel, it needs to allocate decrypted pages for kdump because when the kdump kernel boots, these pages need to be accessed decrypted in the initial boot stage, before SME is enabled. [ bp: clean up text. ] Signed-off-by: Lianbo Jiang <lijiang@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Tom Lendacky <thomas.lendacky@amd.com> Cc: kexec@lists.infradead.org Cc: tglx@linutronix.de Cc: mingo@redhat.com Cc: hpa@zytor.com Cc: akpm@linux-foundation.org Cc: dan.j.williams@intel.com Cc: bhelgaas@google.com Cc: baiyaowei@cmss.chinamobile.com Cc: tiwai@suse.de Cc: brijesh.singh@amd.com Cc: dyoung@redhat.com Cc: bhe@redhat.com Cc: jroedel@suse.de Link: https://lkml.kernel.org/r/20180930031033.22110-3-lijiang@redhat.com Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-10-07kexec: bail out upon SIGKILL when allocating memory.Tetsuo Handa
commit 7c3a6aedcd6aae0a32a527e68669f7dd667492d1 upstream. syzbot found that a thread can stall for minutes inside kexec_load() after that thread was killed by SIGKILL [1]. It turned out that the reproducer was trying to allocate 2408MB of memory using kimage_alloc_page() from kimage_load_normal_segment(). Let's check for SIGKILL before doing memory allocation. [1] https://syzkaller.appspot.com/bug?id=a0e3436829698d5824231251fad9d8e998f94f5e Link: http://lkml.kernel.org/r/993c9185-d324-2640-d061-bed2dd18b1f7@I-love.SAKURA.ne.jp Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-by: syzbot <syzbot+8ab2d0f39fb79fe6ca40@syzkaller.appspotmail.com> Cc: Eric Biederman <ebiederm@xmission.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-18x86/mm, kexec: Allow kexec to be used with SMETom Lendacky
Provide support so that kexec can be used to boot a kernel when SME is enabled. Support is needed to allocate pages for kexec without encryption. This is needed in order to be able to reboot in the kernel in the same manner as originally booted. Additionally, when shutting down all of the CPUs we need to be sure to flush the caches and then halt. This is needed when booting from a state where SME was not active into a state where SME is active (or vice-versa). Without these steps, it is possible for cache lines to exist for the same physical location but tagged both with and without the encryption bit. This can cause random memory corruption when caches are flushed depending on which cacheline is written last. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: <kexec@lists.infradead.org> Cc: Alexander Potapenko <glider@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Brijesh Singh <brijesh.singh@amd.com> Cc: Dave Young <dyoung@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Toshimitsu Kani <toshi.kani@hpe.com> Cc: kasan-dev@googlegroups.com Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-efi@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/b95ff075db3e7cd545313f2fb609a49619a09625.1500319216.git.thomas.lendacky@amd.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-12kdump: protect vmcoreinfo data under the crash memoryXunlei Pang
Currently vmcoreinfo data is updated at boot time subsys_initcall(), it has the risk of being modified by some wrong code during system is running. As a result, vmcore dumped may contain the wrong vmcoreinfo. Later on, when using "crash", "makedumpfile", etc utility to parse this vmcore, we probably will get "Segmentation fault" or other unexpected errors. E.g. 1) wrong code overwrites vmcoreinfo_data; 2) further crashes the system; 3) trigger kdump, then we obviously will fail to recognize the crash context correctly due to the corrupted vmcoreinfo. Now except for vmcoreinfo, all the crash data is well protected(including the cpu note which is fully updated in the crash path, thus its correctness is guaranteed). Given that vmcoreinfo data is a large chunk prepared for kdump, we better protect it as well. To solve this, we relocate and copy vmcoreinfo_data to the crash memory when kdump is loading via kexec syscalls. Because the whole crash memory will be protected by existing arch_kexec_protect_crashkres() mechanism, we naturally protect vmcoreinfo_data from write(even read) access under kernel direct mapping after kdump is loaded. Since kdump is usually loaded at the very early stage after boot, we can trust the correctness of the vmcoreinfo data copied. On the other hand, we still need to operate the vmcoreinfo safe copy when crash happens to generate vmcoreinfo_note again, we rely on vmap() to map out a new kernel virtual address and update to use this new one instead in the following crash_save_vmcoreinfo(). BTW, we do not touch vmcoreinfo_note, because it will be fully updated using the protected vmcoreinfo_data after crash which is surely correct just like the cpu crash note. Link: http://lkml.kernel.org/r/1493281021-20737-3-git-send-email-xlpang@redhat.com Signed-off-by: Xunlei Pang <xlpang@redhat.com> Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Young <dyoung@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Hari Bathini <hbathini@linux.vnet.ibm.com> Cc: Juergen Gross <jgross@suse.com> Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-06-30objtool, x86: Add several functions and files to the objtool whitelistJosh Poimboeuf
In preparation for an objtool rewrite which will have broader checks, whitelist functions and files which cause problems because they do unusual things with the stack. These whitelists serve as a TODO list for which functions and files don't yet have undwarf unwinder coverage. Eventually most of the whitelists can be removed in favor of manual CFI hint annotations or objtool improvements. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/7f934a5d707a574bda33ea282e9478e627fb1829.1498659915.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-05-08ia64: reuse append_elf_note() and final_note() functionsHari Bathini
Get rid of multiple definitions of append_elf_note() & final_note() functions. Reuse these functions compiled under CONFIG_CRASH_CORE Also, define Elf_Word and use it instead of generic u32 or the more specific Elf64_Word. Link: http://lkml.kernel.org/r/149035342324.6881.11667840929850361402.stgit@hbathini.in.ibm.com Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com> Acked-by: Dave Young <dyoung@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08crash: move crashkernel parsing and vmcore related code under CONFIG_CRASH_COREHari Bathini
Patch series "kexec/fadump: remove dependency with CONFIG_KEXEC and reuse crashkernel parameter for fadump", v4. Traditionally, kdump is used to save vmcore in case of a crash. Some architectures like powerpc can save vmcore using architecture specific support instead of kexec/kdump mechanism. Such architecture specific support also needs to reserve memory, to be used by dump capture kernel. crashkernel parameter can be a reused, for memory reservation, by such architecture specific infrastructure. This patchset removes dependency with CONFIG_KEXEC for crashkernel parameter and vmcoreinfo related code as it can be reused without kexec support. Also, crashkernel parameter is reused instead of fadump_reserve_mem to reserve memory for fadump. The first patch moves crashkernel parameter parsing and vmcoreinfo related code under CONFIG_CRASH_CORE instead of CONFIG_KEXEC_CORE. The second patch reuses the definitions of append_elf_note() & final_note() functions under CONFIG_CRASH_CORE in IA64 arch code. The third patch removes dependency on CONFIG_KEXEC for firmware-assisted dump (fadump) in powerpc. The next patch reuses crashkernel parameter for reserving memory for fadump, instead of the fadump_reserve_mem parameter. This has the advantage of using all syntaxes crashkernel parameter supports, for fadump as well. The last patch updates fadump kernel documentation about use of crashkernel parameter. This patch (of 5): Traditionally, kdump is used to save vmcore in case of a crash. Some architectures like powerpc can save vmcore using architecture specific support instead of kexec/kdump mechanism. Such architecture specific support also needs to reserve memory, to be used by dump capture kernel. crashkernel parameter can be a reused, for memory reservation, by such architecture specific infrastructure. But currently, code related to vmcoreinfo and parsing of crashkernel parameter is built under CONFIG_KEXEC_CORE. This patch introduces CONFIG_CRASH_CORE and moves the above mentioned code under this config, allowing code reuse without dependency on CONFIG_KEXEC. There is no functional change with this patch. Link: http://lkml.kernel.org/r/149035338104.6881.4550894432615189948.stgit@hbathini.in.ibm.com Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com> Acked-by: Dave Young <dyoung@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk updates from Petr Mladek: - Add Petr Mladek, Sergey Senozhatsky as printk maintainers, and Steven Rostedt as the printk reviewer. This idea came up after the discussion about printk issues at Kernel Summit. It was formulated and discussed at lkml[1]. - Extend a lock-less NMI per-cpu buffers idea to handle recursive printk() calls by Sergey Senozhatsky[2]. It is the first step in sanitizing printk as discussed at Kernel Summit. The change allows to see messages that would normally get ignored or would cause a deadlock. Also it allows to enable lockdep in printk(). This already paid off. The testing in linux-next helped to discover two old problems that were hidden before[3][4]. - Remove unused parameter by Sergey Senozhatsky. Clean up after a past change. [1] http://lkml.kernel.org/r/1481798878-31898-1-git-send-email-pmladek@suse.com [2] http://lkml.kernel.org/r/20161227141611.940-1-sergey.senozhatsky@gmail.com [3] http://lkml.kernel.org/r/20170215044332.30449-1-sergey.senozhatsky@gmail.com [4] http://lkml.kernel.org/r/20170217015932.11898-1-sergey.senozhatsky@gmail.com * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: printk: drop call_console_drivers() unused param printk: convert the rest to printk-safe printk: remove zap_locks() function printk: use printk_safe buffers in printk printk: report lost messages in printk safe/nmi contexts printk: always use deferred printk when flush printk_safe lines printk: introduce per-cpu safe_print seq buffer printk: rename nmi.c and exported api printk: use vprintk_func in vprintk() MAINTAINERS: Add printk maintainers
2017-02-08printk: rename nmi.c and exported apiSergey Senozhatsky
A preparation patch for printk_safe work. No functional change. - rename nmi.c to print_safe.c - add `printk_safe' prefix to some (which used both by printk-safe and printk-nmi) of the exported functions. Link: http://lkml.kernel.org/r/20161227141611.940-3-sergey.senozhatsky@gmail.com Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Calvin Owens <calvinowens@fb.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-01-11kexec: Switch to __pa_symbolLaura Abbott
__pa_symbol is the correct api to get the physical address of kernel symbols. Switch to it to allow for better debug checking. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2016-12-14kexec: add cond_resched into kimage_alloc_crash_control_pageszhong jiang
A soft lookup will occur when I run trinity in syscall kexec_load. the corresponding stack information is as follows. BUG: soft lockup - CPU#6 stuck for 22s! [trinity-c6:13859] Kernel panic - not syncing: softlockup: hung tasks CPU: 6 PID: 13859 Comm: trinity-c6 Tainted: G O L ----V------- 3.10.0-327.28.3.35.zhongjiang.x86_64 #1 Hardware name: Huawei Technologies Co., Ltd. Tecal BH622 V2/BC01SRSA0, BIOS RMIBV386 06/30/2014 Call Trace: <IRQ> dump_stack+0x19/0x1b panic+0xd8/0x214 watchdog_timer_fn+0x1cc/0x1e0 __hrtimer_run_queues+0xd2/0x260 hrtimer_interrupt+0xb0/0x1e0 ? call_softirq+0x1c/0x30 local_apic_timer_interrupt+0x37/0x60 smp_apic_timer_interrupt+0x3f/0x60 apic_timer_interrupt+0x6d/0x80 <EOI> ? kimage_alloc_control_pages+0x80/0x270 ? kmem_cache_alloc_trace+0x1ce/0x1f0 ? do_kimage_alloc_init+0x1f/0x90 kimage_alloc_init+0x12a/0x180 SyS_kexec_load+0x20a/0x260 system_call_fastpath+0x16/0x1b the first time allocation of control pages may take too much time because crash_res.end can be set to a higher value. we need to add cond_resched to avoid the issue. The patch have been tested and above issue is not appear. Link: http://lkml.kernel.org/r/1481164674-42775-1-git-send-email-zhongjiang@huawei.com Signed-off-by: zhong jiang <zhongjiang@huawei.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Xunlei Pang <xpang@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14kexec: export the value of phys_base instead of symbol addressBaoquan He
Currently in x86_64, the symbol address of phys_base is exported to vmcoreinfo. Dave Anderson complained this is really useless for his Crash implementation. Because in user-space utility Crash and Makedumpfile which exported vmcore information is mainly used for, value of phys_base is needed to covert virtual address of exported kernel symbol to physical address. Especially init_level4_pgt, if we want to access and go over the page table to look up a PA corresponding to VA, firstly we need calculate page_dir = SYMBOL(init_level4_pgt) - __START_KERNEL_map + phys_base; Now in Crash and Makedumpfile, we have to analyze the vmcore elf program header to get value of phys_base. As Dave said, it would be preferable if it were readily availabl in vmcoreinfo rather than depending upon the PT_LOAD semantics. Hence in this patch change to export the value of phys_base instead of its virtual address. And people also complained that KERNEL_IMAGE_SIZE exporting is x86_64 only, should be moved into arch dependent function arch_crash_save_vmcoreinfo. Do the moving in this patch. Link: http://lkml.kernel.org/r/1478568596-30060-2-git-send-email-bhe@redhat.com Signed-off-by: Baoquan He <bhe@redhat.com> Cc: Thomas Garnier <thgarnie@google.com> Cc: Baoquan He <bhe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Xunlei Pang <xlpang@redhat.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Kees Cook <keescook@chromium.org> Cc: Eugene Surovegin <surovegin@google.com> Cc: Dave Young <dyoung@redhat.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Atsushi Kumagai <ats-kumagai@wm.jp.nec.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Pratyush Anand <panand@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02kexec: add restriction on kexec_load() segment sizeszhong jiang
I hit the following issue when run trinity in my system. The kernel is 3.4 version, but mainline has the same issue. The root cause is that the segment size is too large so the kerenl spends too long trying to allocate a page. Other cases will block until the test case quits. Also, OOM conditions will occur. Call Trace: __alloc_pages_nodemask+0x14c/0x8f0 alloc_pages_current+0xaf/0x120 kimage_alloc_pages+0x10/0x60 kimage_alloc_control_pages+0x5d/0x270 machine_kexec_prepare+0xe5/0x6c0 ? kimage_free_page_list+0x52/0x70 sys_kexec_load+0x141/0x600 ? vfs_write+0x100/0x180 system_call_fastpath+0x16/0x1b The patch changes sanity_check_segment_list() to verify that the usage by all segments does not exceed half of memory. [akpm@linux-foundation.org: fix for kexec-return-error-number-directly.patch, update comment] Link: http://lkml.kernel.org/r/1469625474-53904-1-git-send-email-zhongjiang@huawei.com Signed-off-by: zhong jiang <zhongjiang@huawei.com> Suggested-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Dave Young <dyoung@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02kexec: add a kexec_crash_loaded() functionPetr Tesarik
Provide a wrapper function to be used by kernel code to check whether a crash kernel is loaded. It returns the same value that can be seen in /sys/kernel/kexec_crash_loaded by userspace programs. I'm exporting the function, because it will be used by Xen, and it is possible to compile Xen modules separately to enable the use of PV drivers with unmodified bare-metal kernels. Link: http://lkml.kernel.org/r/20160713121955.14969.69080.stgit@hananiah.suse.cz Signed-off-by: Petr Tesarik <ptesarik@suse.com> Cc: Juergen Gross <jgross@suse.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Eric Biederman <ebiederm@xmission.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dave Young <dyoung@redhat.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02kexec: allow architectures to override boot mappingRussell King
kexec physical addresses are the boot-time view of the system. For certain ARM systems (such as Keystone 2), the boot view of the system does not match the kernel's view of the system: the boot view uses a special alias in the lower 4GB of the physical address space. To cater for these kinds of setups, we need to translate between the boot view physical addresses and the normal kernel view physical addresses. This patch extracts the current transation points into linux/kexec.h, and allows an architecture to override the functions. Due to the translations required, we unfortunately end up with six translation functions, which are reduced down to four that the architecture can override. [akpm@linux-foundation.org: kexec.h needs asm/io.h for phys_to_virt()] Link: http://lkml.kernel.org/r/E1b8koP-0004HZ-Vf@rmk-PC.armlinux.org.uk Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Keerthy <j-keerthy@ti.com> Cc: Pratyush Anand <panand@redhat.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Young <dyoung@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02kdump: arrange for paddr_vmcoreinfo_note() to return phys_addr_tRussell King
On PAE systems (eg, ARM LPAE) the vmcore note may be located above 4GB physical on 32-bit architectures, so we need a wider type than "unsigned long" here. Arrange for paddr_vmcoreinfo_note() to return a phys_addr_t, thereby allowing it to be located above 4GB. This makes no difference for kexec-tools, as they already assume a 64-bit type when reading from this file. Link: http://lkml.kernel.org/r/E1b8koK-0004HS-K9@rmk-PC.armlinux.org.uk Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Pratyush Anand <panand@redhat.com> Acked-by: Baoquan He <bhe@redhat.com> Cc: Keerthy <j-keerthy@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Young <dyoung@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02kexec: ensure user memory sizes do not wrapRussell King
Ensure that user memory sizes do not wrap around when validating the user input, which can lead to the following input validation working incorrectly. [akpm@linux-foundation.org: fix it for kexec-return-error-number-directly.patch] Link: http://lkml.kernel.org/r/E1b8koF-0004HM-5x@rmk-PC.armlinux.org.uk Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Pratyush Anand <panand@redhat.com> Acked-by: Baoquan He <bhe@redhat.com> Cc: Keerthy <j-keerthy@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Young <dyoung@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02kexec: return error number directlyMinfei Huang
This is a cleanup patch to make kexec more clear to return error number directly. The variable result is useless, because there is no other function's return value assignes to it. So remove it. Link: http://lkml.kernel.org/r/1464179273-57668-1-git-send-email-mnghuan@gmail.com Signed-off-by: Minfei Huang <mnghuan@gmail.com> Cc: Dave Young <dyoung@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Xunlei Pang <xlpang@redhat.com> Cc: Atsushi Kumagai <ats-kumagai@wm.jp.nec.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23s390/kexec: consolidate crash_map/unmap_reserved_pages() and ↵Xunlei Pang
arch_kexec_protect(unprotect)_crashkres() Commit 3f625002581b ("kexec: introduce a protection mechanism for the crashkernel reserved memory") is a similar mechanism for protecting the crash kernel reserved memory to previous crash_map/unmap_reserved_pages() implementation, the new one is more generic in name and cleaner in code (besides, some arch may not be allowed to unmap the pgtable). Therefore, this patch consolidates them, and uses the new arch_kexec_protect(unprotect)_crashkres() to replace former crash_map/unmap_reserved_pages() which by now has been only used by S390. The consolidation work needs the crash memory to be mapped initially, this is done in machine_kdump_pm_init() which is after reserve_crashkernel(). Once kdump kernel is loaded, the new arch_kexec_protect_crashkres() implemented for S390 will actually unmap the pgtable like before. Signed-off-by: Xunlei Pang <xlpang@redhat.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Minfei Huang <mhuang@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23kexec: introduce a protection mechanism for the crashkernel reserved memoryXunlei Pang
For the cases that some kernel (module) path stamps the crash reserved memory(already mapped by the kernel) where has been loaded the second kernel data, the kdump kernel will probably fail to boot when panic happens (or even not happens) leaving the culprit at large, this is unacceptable. The patch introduces a mechanism for detecting such cases: 1) After each crash kexec loading, it simply marks the reserved memory regions readonly since we no longer access it after that. When someone stamps the region, the first kernel will panic and trigger the kdump. The weak arch_kexec_protect_crashkres() is introduced to do the actual protection. 2) To allow multiple loading, once 1) was done we also need to remark the reserved memory to readwrite each time a system call related to kdump is made. The weak arch_kexec_unprotect_crashkres() is introduced to do the actual protection. The architecture can make its specific implementation by overriding arch_kexec_protect_crashkres() and arch_kexec_unprotect_crashkres(). Signed-off-by: Xunlei Pang <xlpang@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Young <dyoung@redhat.com> Cc: Minfei Huang <mhuang@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20printk/nmi: flush NMI messages on the system panicPetr Mladek
In NMI context, printk() messages are stored into per-CPU buffers to avoid a possible deadlock. They are normally flushed to the main ring buffer via an IRQ work. But the work is never called when the system calls panic() in the very same NMI handler. This patch tries to flush NMI buffers before the crash dump is generated. In this case it does not risk a double release and bails out when the logbuf_lock is already taken. The aim is to get the messages into the main ring buffer when possible. It makes them better accessible in the vmcore. Then the patch tries to flush the buffers second time when other CPUs are down. It might be more aggressive and reset logbuf_lock. The aim is to get the messages available for the consequent kmsg_dump() and console_flush_on_panic() calls. The patch causes vprintk_emit() to be called even in NMI context again. But it is done via printk_deferred() so that the console handling is skipped. Consoles use internal locks and we could not prevent a deadlock easily. They are explicitly called later when the crash dump is not generated, see console_flush_on_panic(). Signed-off-by: Petr Mladek <pmladek@suse.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Daniel Thompson <daniel.thompson@linaro.org> Cc: David Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Jiri Kosina <jkosina@suse.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm: rename _count, field of the struct page, to _refcountJoonsoo Kim
Many developers already know that field for reference count of the struct page is _count and atomic type. They would try to handle it directly and this could break the purpose of page reference count tracepoint. To prevent direct _count modification, this patch rename it to _refcount and add warning message on the code. After that, developer who need to handle reference count will find that field should not be accessed directly. [akpm@linux-foundation.org: fix comments, per Vlastimil] [akpm@linux-foundation.org: Documentation/vm/transhuge.txt too] [sfr@canb.auug.org.au: sync ethernet driver changes] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Sunil Goutham <sgoutham@cavium.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Manish Chopra <manish.chopra@qlogic.com> Cc: Yuval Mintz <yuval.mintz@qlogic.com> Cc: Tariq Toukan <tariqt@mellanox.com> Cc: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-28kexec: export OFFSET(page.compound_head) to find out compound tail pageAtsushi Kumagai
PageAnon() always look at head page to check PAGE_MAPPING_ANON and tail page's page->mapping has just a poisoned data since commit 1c290f642101 ("mm: sanitize page->mapping for tail pages"). If makedumpfile checks page->mapping of a compound tail page to distinguish anonymous page as usual, it must fail in newer kernel. So it's necessary to export OFFSET(page.compound_head) to avoid checking compound tail pages. The problem is that unnecessary hugepages won't be removed from a dump file in kernels 4.5.x and later. This means that extra disk space would be consumed. It's a problem, but not critical. Signed-off-by: Atsushi Kumagai <ats-kumagai@wm.jp.nec.com> Acked-by: Dave Young <dyoung@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-28kexec: update VMCOREINFO for compound_order/dtorAtsushi Kumagai
makedumpfile refers page.lru.next to get the order of compound pages for page filtering. However, now the order is stored in page.compound_order, hence VMCOREINFO should be updated to export the offset of page.compound_order. The fact is, page.compound_order was introduced already in kernel 4.0, but the offset of it was the same as page.lru.next until kernel 4.3, so this was not actual problem. The above can be said also for page.lru.prev and page.compound_dtor, it's necessary to detect hugetlbfs pages. Further, the content was changed from direct address to the ID which means dtor. The problem is that unnecessary hugepages won't be removed from a dump file in kernels 4.4.x and later. This means that extra disk space would be consumed. It's a problem, but not critical. Signed-off-by: Atsushi Kumagai <ats-kumagai@wm.jp.nec.com> Acked-by: Dave Young <dyoung@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-30kexec: Set IORESOURCE_SYSTEM_RAM for System RAMToshi Kani
Set proper ioresource flags and types for crash kernel reservation areas. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Dave Young <dyoung@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Baoquan He <bhe@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Minfei Huang <mnfhuang@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: kexec@lists.infradead.org Cc: linux-arch@vger.kernel.org Cc: linux-mm <linux-mm@kvack.org> Link: http://lkml.kernel.org/r/1453841853-11383-8-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-20kernel/kexec_core.c: use list_for_each_entry_safe in kimage_free_page_listGeliang Tang
Use list_for_each_entry_safe() instead of list_for_each_safe() to simplify the code. Signed-off-by: Geliang Tang <geliangtang@163.com> Cc: Dave Young <dyoung@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Acked-by: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-19kexec: Fix race between panic() and crash_kexec()Hidehiro Kawai
Currently, panic() and crash_kexec() can be called at the same time. For example (x86 case): CPU 0: oops_end() crash_kexec() mutex_trylock() // acquired nmi_shootdown_cpus() // stop other CPUs CPU 1: panic() crash_kexec() mutex_trylock() // failed to acquire smp_send_stop() // stop other CPUs infinite loop If CPU 1 calls smp_send_stop() before nmi_shootdown_cpus(), kdump fails. In another case: CPU 0: oops_end() crash_kexec() mutex_trylock() // acquired <NMI> io_check_error() panic() crash_kexec() mutex_trylock() // failed to acquire infinite loop Clearly, this is an undesirable result. To fix this problem, this patch changes crash_kexec() to exclude others by using the panic_cpu atomic. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Baoquan He <bhe@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jonathan Corbet <corbet@lwn.net> Cc: kexec@lists.infradead.org Cc: linux-doc@vger.kernel.org Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Minfei Huang <mnfhuang@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Seth Jennings <sjenning@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: x86-ml <x86@kernel.org> Link: http://lkml.kernel.org/r/20151210014630.25437.94161.stgit@softrs Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-11-06kexec: use file name as the output message prefixMinfei Huang
kexec output message misses the prefix "kexec", when Dave Young split the kexec code. Now, we use file name as the output message prefix. Currently, the format of output message: [ 140.290795] SYSC_kexec_load: hello, world [ 140.291534] kexec: sanity_check_segment_list: hello, world Ideally, the format of output message: [ 30.791503] kexec: SYSC_kexec_load, Hello, world [ 79.182752] kexec_core: sanity_check_segment_list, Hello, world Remove the custom prefix "kexec" in output message. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Acked-by: Dave Young <dyoung@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-21kexec/crash: Say which char is the unrecognizedBorislav Petkov
It is helpful when the crashkernel cmdline parsing routines actually say which character is the unrecognized one. Make them do so. Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Dave Young <dyoung@redhat.com> Reviewed-by: Joerg Roedel <jroedel@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Baoquan He <bhe@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: jerry_hoemann@hp.com Link: http://lkml.kernel.org/r/1445246268-26285-8-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-10kexec: export KERNEL_IMAGE_SIZE to vmcoreinfoBaoquan He
In x86_64, since v2.6.26 the KERNEL_IMAGE_SIZE is changed to 512M, and accordingly the MODULES_VADDR is changed to 0xffffffffa0000000. However, in v3.12 Kees Cook introduced kaslr to randomise the location of kernel. And the kernel text mapping addr space is enlarged from 512M to 1G. That means now KERNEL_IMAGE_SIZE is variable, its value is 512M when kaslr support is not compiled in and 1G when kaslr support is compiled in. Accordingly the MODULES_VADDR is changed too to be: #define MODULES_VADDR (__START_KERNEL_map + KERNEL_IMAGE_SIZE) So when kaslr is compiled in and enabled, the kernel text mapping addr space and modules vaddr space need be adjusted. Otherwise makedumpfile will collapse since the addr for some symbols is not correct. Hence KERNEL_IMAGE_SIZE need be exported to vmcoreinfo and got in makedumpfile to help calculate MODULES_VADDR. Signed-off-by: Baoquan He <bhe@redhat.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: align crash_notes allocation to make it be inside one physical pageBaoquan He
People reported that crash_notes in /proc/vmcore were corrupted and this cause crash kdump failure. With code debugging and log we got the root cause. This is because percpu variable crash_notes are allocated in 2 vmalloc pages. Currently percpu is based on vmalloc by default. Vmalloc can't guarantee 2 continuous vmalloc pages are also on 2 continuous physical pages. So when 1st kernel exports the starting address and size of crash_notes through sysfs like below: /sys/devices/system/cpu/cpux/crash_notes /sys/devices/system/cpu/cpux/crash_notes_size kdump kernel use them to get the content of crash_notes. However the 2nd part may not be in the next neighbouring physical page as we expected if crash_notes are allocated accross 2 vmalloc pages. That's why nhdr_ptr->n_namesz or nhdr_ptr->n_descsz could be very huge in update_note_header_size_elf64() and cause note header merging failure or some warnings. In this patch change to call __alloc_percpu() to passed in the align value by rounding crash_notes_size up to the nearest power of two. This makes sure the crash_notes is allocated inside one physical page since sizeof(note_buf_t) in all ARCHS is smaller than PAGE_SIZE. Meanwhile add a BUILD_BUG_ON to break compile if size is bigger than PAGE_SIZE since crash_notes definitely will be in 2 pages. That need be avoided, and need be reported if it's unavoidable. [akpm@linux-foundation.org: use correct comment layout] Signed-off-by: Baoquan He <bhe@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Dave Young <dyoung@redhat.com> Cc: Lisa Mitchell <lisa.mitchell@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: remove unnecessary test in kimage_alloc_crash_control_pages()Minfei Huang
Transforming PFN(Page Frame Number) to struct page is never failure, so we can simplify the code logic to do the image->control_page assignment directly in the loop, and remove the unnecessary conditional judgement. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Acked-by: Dave Young <dyoung@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: split kexec_load syscall from kexec core codeDave Young
There are two kexec load syscalls, kexec_load another and kexec_file_load. kexec_file_load has been splited as kernel/kexec_file.c. In this patch I split kexec_load syscall code to kernel/kexec.c. And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and use kexec_file_load only, or vice verse. The original requirement is from Ted Ts'o, he want kexec kernel signature being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use kexec_load syscall can bypass the checking. Vivek Goyal proposed to create a common kconfig option so user can compile in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects KEXEC_CORE so that old config files still work. Because there's general code need CONFIG_KEXEC_CORE, so I updated all the architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects KEXEC_CORE in arch Kconfig. Also updated general kernel code with to kexec_load syscall. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
