path: root/kernel/kgdb.c
2010-05-20Move kernel/kgdb.c to kernel/debug/debug_core.cJason Wessel
Move kgdb.c in preparation to separate the gdbstub from the debug core and exception handling. CC: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-04-02kgdb: Turn off tracing while in the debuggerJason Wessel
The kernel debugger should turn off kernel tracing any time the debugger is active and restore it on resume. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-02kgdb: use atomic_inc and atomic_dec instead of atomic_setJason Wessel
Memory barriers should be used for the kgdb cpu synchronization. The atomic_set() does not imply a memory barrier. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-04-02kgdb: eliminate kgdb_wait(), all cpus enter the same wayJason Wessel
This is a kgdb architectural change to have all the cpus (master or slave) enter the same function. A cpu that hits an exception (wants to be the master cpu) will call kgdb_handle_exception() from the trap handler and then invoke a kgdb_roundup_cpu() to synchronize the other cpus and bring them into the kgdb_handle_exception() as well. A slave cpu will enter kgdb_handle_exception() from the kgdb_nmicallback() and set the exception state to note that the processor is a slave. Previously the salve cpu would have called kgdb_wait(). This change allows the debug core to change cpus without resuming the system in order to inspect arch specific cpu information. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-04-02kgdb: have ebin2mem call probe_kernel_write onceJason Wessel
Rather than call probe_kernel_write() one byte at a time, process the whole buffer locally and pass the entire result in one go. This way, architectures that need to do special handling based on the length can do so, or we only end up calling memcpy() once. [sonic.zhang@analog.com: Reported original problem and preliminary patch] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-02-04Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Handle futex value corruption gracefully futex: Handle user space corruption gracefully futex_lock_pi() key refcnt fix softlockup: Add sched_clock_tick() to avoid kernel warning on kgdb resume
2010-02-01softlockup: Add sched_clock_tick() to avoid kernel warning on kgdb resumeJason Wessel
When CONFIG_HAVE_UNSTABLE_SCHED_CLOCK is set, sched_clock() gets the time from hardware such as the TSC on x86. In this configuration kgdb will report a softlock warning message on resuming or detaching from a debug session. Sequence of events in the problem case: 1) "cpu sched clock" and "hardware time" are at 100 sec prior to a call to kgdb_handle_exception() 2) Debugger waits in kgdb_handle_exception() for 80 sec and on exit the following is called ... touch_softlockup_watchdog() --> __raw_get_cpu_var(touch_timestamp) = 0; 3) "cpu sched clock" = 100s (it was not updated, because the interrupt was disabled in kgdb) but the "hardware time" = 180 sec 4) The first timer interrupt after resuming from kgdb_handle_exception updates the watchdog from the "cpu sched clock" update_process_times() { ... run_local_timers() --> softlockup_tick() --> check (touch_timestamp == 0) (it is "YES" here, we have set "touch_timestamp = 0" at kgdb) --> __touch_softlockup_watchdog() ***(A)--> reset "touch_timestamp" to "get_timestamp()" (Here, the "touch_timestamp" will still be set to 100s.) ... scheduler_tick() ***(B)--> sched_clock_tick() (update "cpu sched clock" to "hardware time" = 180s) ... } 5) The Second timer interrupt handler appears to have a large jump and trips the softlockup warning. update_process_times() { ... run_local_timers() --> softlockup_tick() --> "cpu sched clock" - "touch_timestamp" = 180s-100s > 60s --> printk "soft lockup error messages" ... } note: ***(A) reset "touch_timestamp" to "get_timestamp(this_cpu)" Why is "touch_timestamp" 100 sec, instead of 180 sec? When CONFIG_HAVE_UNSTABLE_SCHED_CLOCK is set, the call trace of get_timestamp() is: get_timestamp(this_cpu) -->cpu_clock(this_cpu) -->sched_clock_cpu(this_cpu) -->__update_sched_clock(sched_clock_data, now) The __update_sched_clock() function uses the GTOD tick value to create a window to normalize the "now" values. So if "now" value is too big for sched_clock_data, it will be ignored. The fix is to invoke sched_clock_tick() to update "cpu sched clock" in order to recover from this state. This is done by introducing the function touch_softlockup_watchdog_sync(). This allows kgdb to request that the sched clock is updated when the watchdog thread runs the first time after a resume from kgdb. [yong.zhang0@gmail.com: Use per cpu instead of an array] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Dongdong Deng <Dongdong.Deng@windriver.com> Cc: kgdb-bugreport@lists.sourceforge.net Cc: peterz@infradead.org LKML-Reference: <1264631124-4837-2-git-send-email-jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-30x86, hw_breakpoints, kgdb: Fix kgdb to use hw_breakpoint APIJason Wessel
In the 2.6.33 kernel, the hw_breakpoint API is now used for the performance event counters. The hw_breakpoint_handler() now consumes the hw breakpoints that were previously set by kgdb arch specific code. In order for kgdb to work in conjunction with this core API change, kgdb must use some of the low level functions of the hw_breakpoint API to install, uninstall, and deal with hw breakpoint reservations. The kgdb core required a change to call kgdb_disable_hw_debug anytime a slave cpu enters kgdb_wait() in order to keep all the hw breakpoints in sync as well as to prevent hitting a hw breakpoint while kgdb is active. During the architecture specific initialization of kgdb, it will pre-allocate 4 disabled (struct perf event **) structures. Kgdb will use these to manage the capabilities for the 4 hw breakpoint registers, per cpu. Right now the hw_breakpoint API does not have a way to ask how many breakpoints are available, on each CPU so it is possible that the install of a breakpoint might fail when kgdb restores the system to the run state. The intent of this patch is to first get the basic functionality of hw breakpoints working and leave it to the person debugging the kernel to understand what hw breakpoints are in use and what restrictions have been imposed as a result. Breakpoint constraints will be dealt with in a future patch. While atomic, the x86 specific kgdb code will call arch_uninstall_hw_breakpoint() and arch_install_hw_breakpoint() to manage the cpu specific hw breakpoints. The net result of these changes allow kgdb to use the same pool of hw_breakpoints that are used by the perf event API, but neither knows about future reservations for the available hw breakpoint slots. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: kgdb-bugreport@lists.sourceforge.net Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: torvalds@linux-foundation.org LKML-Reference: <1264719883-7285-2-git-send-email-jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-11kgdb: Always process the whole breakpoint list on activate or deactivateJason Wessel
This patch fixes 2 edge cases in using kgdb in conjunction with gdb. 1) kgdb_deactivate_sw_breakpoints() should process the entire array of breakpoints. The failure to do so results in breakpoints that you cannot remove, because a break point can only be removed if its state flag is set to BP_SET. The easy way to duplicate this problem is to plant a break point in a kernel module and then unload the kernel module. 2) kgdb_activate_sw_breakpoints() should process the entire array of breakpoints. The failure to do so results in missed breakpoints when a breakpoint cannot be activated. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2009-12-11kgdb: continue and warn on signal passing from gdbJason Wessel
On some architectures for the segv trap, gdb wants to pass the signal back on continue. For kgdb this is not the default behavior, because it can cause the kernel to crash if you arbitrarily pass back a exception outside of kgdb. Instead of causing instability, pass a message back to gdb about the supported kgdb signal passing and execute a standard kgdb continue operation. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2009-12-11kgdb: allow for cpu switch when single steppingJason Wessel
The kgdb core should not assume that a single step operation of a kernel thread will complete on the same CPU. The single step flag is set at the "thread" level and it is possible in a multi cpu system that a kernel thread can get scheduled on another cpu the next time it is run. As a further safety net in case a slave cpu is hung, the debug master cpu will try 100 times before giving up and assuming control of the slave cpus is no longer possible. It is more useful to be able to get some information out of kgdb instead of spinning forever. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2009-12-11kgdb: Read buffer overflowJason Wessel
Roel Kluin reported an error found with Parfait. Where we want to ensure that that kgdb_info[-1] never gets accessed. Also check to ensure any negative tid does not exceed the size of the shadow CPU array, else report critical debug context because it is an internal kgdb failure. Reported-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2009-11-04sched: Remove unused __schedule() declarationHiroshi Shimamoto
__schedule() had been removed. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4AF129C8.3030008@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-15sysrq, intel_fb: fix sysrq g collisionJason Wessel
Commit 79e539453b34e35f39299a899d263b0a1f1670bd introduced a regression where you cannot use sysrq 'g' to enter kgdb. The solution is to move the intel fb sysrq over to V for video instead of G for graphics. The SMP VOYAGER code to register for the sysrq-v is not anywhere to be found in the mainline kernel, so the comments in the code were cleaned up as well. This patch also cleans up the sysrq definitions for kgdb to make it generic for the kernel debugger, such that the sysrq 'g' can be used in the future to enter a gdbstub or another kernel debugger. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-10-06kgdb: call touch_softlockup_watchdog on resumeJason Wessel
The softlockup watchdog needs to be touched when resuming the from the kgdb stopped state to avoid the printk that a CPU is stuck if the debugger was active for longer than the softlockup threshold. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-26kgdb, x86, arm, mips, powerpc: ignore user space single steppingJason Wessel
On the x86 arch, user space single step exceptions should be ignored if they occur in the kernel space, such as ptrace stepping through a system call. First check if it is kgdb that is executing a single step, then ensure it is not an accidental traversal into the user space, while in kgdb, any other time the TIF_SINGLESTEP is set, kgdb should ignore the exception. On x86, arm, mips and powerpc, the kgdb_contthread usage was inconsistent with the way single stepping is implemented in the kgdb core. The arch specific stub should always set the kgdb_cpu_doing_single_step correctly if it is single stepping. This allows kgdb to correctly process an instruction steps if ptrace happens to be requesting an instruction step over a system call. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-26kgdb: could not write to the last of valid memory with kgdbAtsuo Igarashi
On the ARM architecture, kgdb will crash the kernel if the last byte of valid memory is written due to a flush_icache_range flushing beyond the memory boundary. Signed-off-by: Atsuo Igarashi <atsuo_igarashi@tripeaks.co.jp> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-08-01kgdb: fix gdb serial thread queriesJason Wessel
The command "info threads" did not work correctly with kgdb. It would result in a silent kernel hang if used. This patach addresses several problems. - Fix use of deprecated NR_CPUS - Fix kgdb to not walk linearly through the pid space - Correctly implement shadow pids - Change the threads per query to a #define - Fix kgdb_hex2long to work with negated values The threads 0 and -1 are reserved to represent the current task. That means that CPU 0 will start with a shadow thread id of -2, and CPU 1 will have a shadow thread id of -3, etc... From the debugger you can switch to a shadow thread to see what one of the other cpus was doing, however it is not possible to execute run control operations on any other cpu execept the cpu executing the kgdb_handle_exception(). Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-08-01kgdb: fix kgdb_validate_break_address to perform a mem writeJason Wessel
A regression to the kgdb core was found in the case of using the CONFIG_DEBUG_RODATA kernel option. When this option is on, a breakpoint cannot be written into any readonly memory page. When an external debugger requests a breakpoint to get set, the kgdb_validate_break_address() was only checking to see if the address to place the breakpoint was readable and lacked a write check. This patch changes the validate routine to try reading (via the breakpoint set request) and also to try immediately writing the break point. If either fails, an error is correctly returned and the debugger behaves correctly. Then an end user can make the descision to use hardware breakpoints. Also update the documentation to reflect that using CONFIG_DEBUG_RODATA will inhibit the use of software breakpoints. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-06-24kgdb: sparse fixJason Wessel
- Fix warning reported by sparse kernel/kgdb.c:1502:6: warning: symbol 'kgdb_console_write' was not declared. Should it be static? Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-05-28kgdb: use common ascii helpers and put_unaligned_be32 helperHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-05-14lib: create common ascii hex arrayHarvey Harrison
Add a common hex array in hexdump.c so everyone can use it. Add a common hi/lo helper to avoid the shifting masking that is done to get the upper and lower nibbles of a byte value. Pull the pack_hex_byte helper from kgdb as it is opencoded many places in the tree that will be consolidated. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05kgdb: fix signedness mixmatches, add statics, add declaration to headerHarvey Harrison
Noticed by sparse: arch/x86/kernel/kgdb.c:556:15: warning: symbol 'kgdb_arch_pc' was not declared. Should it be static? kernel/kgdb.c:149:8: warning: symbol 'kgdb_do_roundup' was not declared. Should it be static? kernel/kgdb.c:193:22: warning: symbol 'kgdb_arch_pc' was not declared. Should it be static? kernel/kgdb.c:712:5: warning: symbol 'remove_all_break' was not declared. Should it be static? Related to kgdb_hex2long: arch/x86/kernel/kgdb.c:371:28: warning: incorrect type in argument 2 (different signedness) arch/x86/kernel/kgdb.c:371:28: expected long *long_val arch/x86/kernel/kgdb.c:371:28: got unsigned long *<noident> kernel/kgdb.c:469:27: warning: incorrect type in argument 2 (different signedness) kernel/kgdb.c:469:27: expected long *long_val kernel/kgdb.c:469:27: got unsigned long *<noident> kernel/kgdb.c:470:27: warning: incorrect type in argument 2 (different signedness) kernel/kgdb.c:470:27: expected long *long_val kernel/kgdb.c:470:27: got unsigned long *<noident> kernel/kgdb.c:894:27: warning: incorrect type in argument 2 (different signedness) kernel/kgdb.c:894:27: expected long *long_val kernel/kgdb.c:894:27: got unsigned long *<noident> kernel/kgdb.c:895:27: warning: incorrect type in argument 2 (different signedness) kernel/kgdb.c:895:27: expected long *long_val kernel/kgdb.c:895:27: got unsigned long *<noident> kernel/kgdb.c:1127:28: warning: incorrect type in argument 2 (different signedness) kernel/kgdb.c:1127:28: expected long *long_val kernel/kgdb.c:1127:28: got unsigned long *<noident> kernel/kgdb.c:1132:25: warning: incorrect type in argument 2 (different signedness) kernel/kgdb.c:1132:25: expected long *long_val kernel/kgdb.c:1132:25: got unsigned long *<noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-04-17kgdb: always use icache flush for sw breakpointsJason Wessel
On the ppc 4xx architecture the instruction cache must be flushed as well as the data cache. This patch just makes it generic for all architectures where CACHE_FLUSH_IS_SAFE is set to 1. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: fix SMP NMI kgdb_handle_exception exit raceJason Wessel
Fix the problem of protecting the kgdb handle_exception exit which had an NMI race condition, while trying to restore normal system operation. There was a small window after the master processor sets cpu_in_debug to zero but before it has set kgdb_active to zero where a non-master processor in an SMP system could receive an NMI and re-enter the kgdb_wait() loop. As long as the master processor sets the cpu_in_debug before sending the cpu roundup the cpu_in_debug variable can also be used to guard against the race condition. The kgdb_wait() function no longer needs to check kgdb_active because it is done in the arch specific code and handled along with the nmi traps at the low level. This also allows kgdb_wait() to exit correctly if it was entered for some unknown reason due to a spurious NMI that could not be handled by the arch specific code. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: fix several kgdb regressionsJason Wessel
kgdb core fixes: - Check to see that mm->mmap_cache is not null before calling flush_cache_range(), else on arch=ARM it will cause a fatal fault. - Breakpoints should only be restored if they are in the BP_ACTIVE state. - Fix a typo in comments to "kgdb_register_io_module" x86 kgdb fixes: - Fix the x86 arch handler such that on a kill or detach that the appropriate cleanup on the single stepping flags gets run. - Add in the DIE_NMIWATCHDOG call for x86_64 - Touch the nmi watchdog before returning the system to normal operation after performing any kind of kgdb operation, else the possibility exists to trigger the watchdog. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: fix optional arch functions and probe_kernel_*Jason Wessel
Fix two regressions dealing with the kgdb core. 1) kgdb_skipexception and kgdb_post_primary_code are optional functions that are only required on archs that need special exception fixups. 2) The kernel address space scope must be set on any probe_kernel_* function or archs such as ARCH=arm will not allow access to the kernel memory space. As an example, it is required to allow the full kernel address space is when you the kernel debugger to inspect a system call. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: add x86 HW breakpointsJason Wessel
Add HW breakpoints into the arch specific portion of x86 kgdb. In the current x86 kernel.org kernels HW breakpoints are changed out in lazy fashion because there is no infrastructure around changing them when changing to a kernel task or entering the kernel mode via a system call. This lazy approach means that if a user process uses HW breakpoints the kgdb will loose out. This is an acceptable trade off because the developer debugging the kernel is assumed to know what is going on system wide and would be aware of this trade off. There is a minor bug fix to the kgdb core so as to correctly call the hw breakpoint functions with a valid value from the enum. There is also a minor change to the x86_64 startup code when using early HW breakpoints. When the debugger is connected, the cpu startup code must not zero out the HW breakpoint registers or you cannot hit the breakpoints you are interested in, in the first place. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: print breakpoint removed on exceptionJason Wessel
If kgdb does remove a breakpoint that had a problem on the recursion check, it should also print the address of the breakpoint. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: clocksource watchdogJason Wessel
In order to not trip the clocksource watchdog, kgdb must touch the clocksource watchdog on the return to normal system run state. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: coreJason Wessel
kgdb core code. Handles the protocol and the arch details. [ mingo@elte.hu: heavily modified, simplified and cleaned up. ] [ xemul@openvz.org: use find_task_by_pid_ns ] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
