path: root/kernel/kmod.c
2010-01-11kmod: fix resource leak in call_usermodehelper_pipe()Masami Hiramatsu
Fix resource (write-pipe file) leak in call_usermodehelper_pipe(). When call_usermodehelper_exec() fails, write-pipe file is opened and call_usermodehelper_pipe() just returns an error. Since it is hard for caller to determine whether the error occured when opening the pipe or executing the helper, the caller cannot close the pipe by themselves. I've found this resoruce leak when testing coredump. You can check how the resource leaks as below; $ echo "|nocommand" > /proc/sys/kernel/core_pattern $ ulimit -c unlimited $ while [ 1 ]; do ./segv; done &> /dev/null & $ cat /proc/meminfo (<- repeat it) where segv.c is; //----- int main () { char *p = 0; *p = 1; } //----- This patch closes write-pipe file if call_usermodehelper_exec() failed. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-10security: report the module name to security_module_requestEric Paris
For SELinux to do better filtering in userspace we send the name of the module along with the AVC denial when a program is denied module_request. Example output: type=SYSCALL msg=audit(11/03/2009 10:59:43.510:9) : arch=x86_64 syscall=write success=yes exit=2 a0=3 a1=7fc28c0d56c0 a2=2 a3=7fffca0d7440 items=0 ppid=1727 pid=1729 auid=unset uid=root gid=root euid=root suid=root fsuid=root egid=root sgid=root fsgid=root tty=(none) ses=unset comm=rpc.nfsd exe=/usr/sbin/rpc.nfsd subj=system_u:system_r:nfsd_t:s0 key=(null) type=AVC msg=audit(11/03/2009 10:59:43.510:9) : avc: denied { module_request } for pid=1729 comm=rpc.nfsd kmod="net-pf-10" scontext=system_u:system_r:nfsd_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=system Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-11Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (105 commits) ring-buffer: only enable ring_buffer_swap_cpu when needed ring-buffer: check for swapped buffers in start of committing tracing: report error in trace if we fail to swap latency buffer tracing: add trace_array_printk for internal tracers to use tracing: pass around ring buffer instead of tracer tracing: make tracing_reset safe for external use tracing: use timestamp to determine start of latency traces tracing: Remove mentioning of legacy latency_trace file from documentation tracing/filters: Defer pred allocation, fix memory leak tracing: remove users of tracing_reset tracing: disable buffers and synchronize_sched before resetting tracing: disable update max tracer while reading trace tracing: print out start and stop in latency traces ring-buffer: disable all cpu buffers when one finds a problem ring-buffer: do not count discarded events ring-buffer: remove ring_buffer_event_discard ring-buffer: fix ring_buffer_read crossing pages ring-buffer: remove unnecessary cpu_relax ring-buffer: do not swap buffers during a commit ring-buffer: do not reset while in a commit ...
2009-09-02CRED: Add some configurable debugging [try #6]David Howells
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking for credential management. The additional code keeps track of the number of pointers from task_structs to any given cred struct, and checks to see that this number never exceeds the usage count of the cred struct (which includes all references, not just those from task_structs). Furthermore, if SELinux is enabled, the code also checks that the security pointer in the cred struct is never seen to be invalid. This attempts to catch the bug whereby inode_has_perm() faults in an nfsd kernel thread on seeing cred->security be a NULL pointer (it appears that the credential struct has been previously released): http://www.kerneloops.org/oops.php?number=252883 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-17tracing/events: Add module tracepointsLi Zefan
Add trace points to trace module_load, module_free, module_get, module_put and module_request, and use trace_event facility to get the trace output. Here's the sample output: TASK-PID CPU# TIMESTAMP FUNCTION | | | | | <...>-42 [000] 1.758380: module_request: fb0 wait=1 call_site=fb_open ... <...>-60 [000] 3.269403: module_load: scsi_wait_scan <...>-60 [000] 3.269432: module_put: scsi_wait_scan call_site=sys_init_module refcnt=0 <...>-61 [001] 3.273168: module_free: scsi_wait_scan ... <...>-1021 [000] 13.836081: module_load: sunrpc <...>-1021 [000] 13.840589: module_put: sunrpc call_site=sys_init_module refcnt=-1 <...>-1027 [000] 13.848098: module_get: sunrpc call_site=try_module_get refcnt=0 <...>-1027 [000] 13.848308: module_get: sunrpc call_site=get_filesystem refcnt=1 <...>-1027 [000] 13.848692: module_put: sunrpc call_site=put_filesystem refcnt=0 ... modprobe-2587 [001] 1088.437213: module_load: trace_events_sample F modprobe-2587 [001] 1088.437786: module_put: trace_events_sample call_site=sys_init_module refcnt=0 Note: - the taints flag can be 'F', 'C' and/or 'P' if mod->taints != 0 - the module refcnt is percpu, so it can be negative in a specific cpu Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <4A891B3C.5030608@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-14security: introducing security_request_moduleEric Paris
Calling request_module() will trigger a userspace upcall which will load a new module into the kernel. This can be a dangerous event if the process able to trigger request_module() is able to control either the modprobe binary or the module binary. This patch adds a new security hook to request_module() which can be used by an LSM to control a processes ability to call request_module(). Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-08headers: mnt_namespace.h reduxAlexey Dobriyan
Fix various silly problems wrt mnt_namespace.h: - exit_mnt_ns() isn't used, remove it - done that, sched.h and nsproxy.h inclusions aren't needed - mount.h inclusion was need for vfsmount_lock, but no longer - remove mnt_namespace.h inclusion from files which don't use anything from mnt_namespace.h Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-26kmod: Release sub_info on cred allocation failure.Tetsuo Handa
call_usermodehelper_setup() forgot to kfree(sub_info) when prepare_usermodehelper_creds() failed. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31module: create a request_module_nowait()Arjan van de Ven
There seems to be a common pattern in the kernel where drivers want to call request_module() from inside a module_init() function. Currently this would deadlock. As a result, several drivers go through hoops like scheduling things via kevent, or creating custom work queues (because kevent can deadlock on them). This patch changes this to use a request_module_nowait() function macro instead, which just fires the modprobe off but doesn't wait for it, and thus avoids the original deadlock entirely. On my laptop this already results in one less kernel thread running.. (Includes Jiri's patch to use enum umh_wait) Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (bool-ified) Cc: Jiri Slaby <jirislaby@gmail.com>
2009-03-30cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALLRusty Russell
Impact: cleanup (Thanks to Al Viro for reminding me of this, via Ingo) CPU_MASK_ALL is the (deprecated) "all bits set" cpumask, defined as so: #define CPU_MASK_ALL (cpumask_t) { { ... } } Taking the address of such a temporary is questionable at best, unfortunately 321a8e9d (cpumask: add CPU_MASK_ALL_PTR macro) added CPU_MASK_ALL_PTR: #define CPU_MASK_ALL_PTR (&CPU_MASK_ALL) Which formalizes this practice. One day gcc could bite us over this usage (though we seem to have gotten away with it so far). So replace everywhere which used &CPU_MASK_ALL or CPU_MASK_ALL_PTR with the modern "cpu_all_mask" (a real const struct cpumask *). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Reported-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Mike Travis <travis@sgi.com>
2009-01-06kmod: fix varargs kernel-docRandy Dunlap
Fix varargs kernel-doc format in kmod.c: Use @... instead of @varargs. Warning(kernel/kmod.c:67): Excess function parameter or struct member 'varargs' description in 'request_module' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14KEYS: Alter use of key instantiation link-to-keyring argumentDavid Howells
Alter the use of the key instantiation and negation functions' link-to-keyring arguments. Currently this specifies a keyring in the target process to link the key into, creating the keyring if it doesn't exist. This, however, can be a problem for copy-on-write credentials as it means that the instantiating process can alter the credentials of the requesting process. This patch alters the behaviour such that: (1) If keyctl_instantiate_key() or keyctl_negate_key() are given a specific keyring by ID (ringid >= 0), then that keyring will be used. (2) If keyctl_instantiate_key() or keyctl_negate_key() are given one of the special constants that refer to the requesting process's keyrings (KEY_SPEC_*_KEYRING, all <= 0), then: (a) If sys_request_key() was given a keyring to use (destringid) then the key will be attached to that keyring. (b) If sys_request_key() was given a NULL keyring, then the key being instantiated will be attached to the default keyring as set by keyctl_set_reqkey_keyring(). (3) No extra link will be made. Decision point (1) follows current behaviour, and allows those instantiators who've searched for a specifically named keyring in the requestor's keyring so as to partition the keys by type to still have their named keyrings. Decision point (2) allows the requestor to make sure that the key or keys that get produced by request_key() go where they want, whilst allowing the instantiator to request that the key is retained. This is mainly useful for situations where the instantiator makes a secondary request, the key for which should be retained by the initial requestor: +-----------+ +--------------+ +--------------+ | | | | | | | Requestor |------->| Instantiator |------->| Instantiator | | | | | | | +-----------+ +--------------+ +--------------+ request_key() request_key() This might be useful, for example, in Kerberos, where the requestor requests a ticket, and then the ticket instantiator requests the TGT, which someone else then has to go and fetch. The TGT, however, should be retained in the keyrings of the requestor, not the first instantiator. To make this explict an extra special keyring constant is also added. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: module: remove CONFIG_KMOD in comment after #endif remove CONFIG_KMOD from fs remove CONFIG_KMOD from drivers Manually fix conflict due to include cleanups in drivers/md/md.c
2008-10-16pm: rework disabling of user mode helpers during suspend/hibernationRafael J. Wysocki
We currently use a PM notifier to disable user mode helpers before suspend and hibernation and to re-enable them during resume. However, this is not an ideal solution, because if any drivers want to upload firmware into memory before suspend, they have to use a PM notifier for this purpose and there is no guarantee that the ordering of PM notifiers will be as expected (ie. the notifier that disables user mode helpers has to be run after the driver's notifier used for uploading the firmware). For this reason, it seems better to move the disabling and enabling of user mode helpers to separate functions that will be called by the PM core as necessary. [akpm@linux-foundation.org: remove unneeded ifdefs] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Alan Stern <stern@rowland.harvard.edu> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-17module: remove CONFIG_KMOD in comment after #endifRusty Russell
2008-07-25call_usermodehelper(): increase reliabilityKOSAKI Motohiro
Presently call_usermodehelper_setup() uses GFP_ATOMIC. but it can return NULL _very_ easily. GFP_ATOMIC is needed only when we can't sleep. and, GFP_KERNEL is robust and better. thus, I add gfp_mask argument to call_usermodehelper_setup(). So, its callers pass the gfp_t as below: call_usermodehelper() and call_usermodehelper_keys(): depend on 'wait' argument. call_usermodehelper_pipe(): always GFP_KERNEL because always run under process context. orderly_poweroff(): pass to GFP_ATOMIC because may run under interrupt context. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: "Paul Menage" <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: NONBLOCK in pipeUlrich Drepper
This patch adds O_NONBLOCK support to pipe2. It is minimally more involved than the patches for eventfd et.al but still trivial. The interfaces of the create_write_pipe and create_read_pipe helper functions were changed and the one other caller as well. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_pipe2 # ifdef __x86_64__ # define __NR_pipe2 293 # elif defined __i386__ # define __NR_pipe2 331 # else # error "need __NR_pipe2" # endif #endif int main (void) { int fds[2]; if (syscall (__NR_pipe2, fds, 0) == -1) { puts ("pipe2(0) failed"); return 1; } for (int i = 0; i < 2; ++i) { int fl = fcntl (fds[i], F_GETFL); if (fl == -1) { puts ("fcntl failed"); return 1; } if (fl & O_NONBLOCK) { printf ("pipe2(0) set non-blocking mode for fds[%d]\n", i); return 1; } close (fds[i]); } if (syscall (__NR_pipe2, fds, O_NONBLOCK) == -1) { puts ("pipe2(O_NONBLOCK) failed"); return 1; } for (int i = 0; i < 2; ++i) { int fl = fcntl (fds[i], F_GETFL); if (fl == -1) { puts ("fcntl failed"); return 1; } if ((fl & O_NONBLOCK) == 0) { printf ("pipe2(O_NONBLOCK) does not set non-blocking mode for fds[%d]\n", i); return 1; } close (fds[i]); } puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22remove CONFIG_KMOD from core kernel codeJohannes Berg
Always compile request_module when the kernel allows modules. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19generic: use new set_cpus_allowed_ptr functionMike Travis
* Use new set_cpus_allowed_ptr() function added by previous patch, which instead of passing the "newly allowed cpus" cpumask_t arg by value, pass it by pointer: -int set_cpus_allowed(struct task_struct *p, cpumask_t new_mask) +int set_cpus_allowed_ptr(struct task_struct *p, const cpumask_t *new_mask) * Modify CPU_MASK_ALL Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-14Dont touch fs_struct in usermodehelperJan Blunck
This test seems to be unnecessary since we always have rootfs mounted before calling a usermodehelper. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-17Fix unbalanced helper_lock in kernel/kmod.cNigel Cunningham
call_usermodehelper_exec() has an exit path that can leave the helper_lock() call at the top of the routine unbalanced. The attached patch fixes this issue. Signed-off-by: Nigel Cunningham <nigel@tuxonice.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11Restore call_usermodehelper_pipe() behaviourMichael Ellerman
The semantics of call_usermodehelper_pipe() used to be that it would fork the helper, and wait for the kernel thread to be started. This was implemented by setting sub_info.wait to 0 (implicitly), and doing a wait_for_completion(). As part of the cleanup done in 0ab4dc92278a0f3816e486d6350c6652a72e06c8, call_usermodehelper_pipe() was changed to pass 1 as the value for wait to call_usermodehelper_exec(). This is equivalent to setting sub_info.wait to 1, which is a change from the previous behaviour. Using 1 instead of 0 causes __call_usermodehelper() to start the kernel thread running wait_for_helper(), rather than directly calling ____call_usermodehelper(). The end result is that the calling kernel code blocks until the user mode helper finishes. As the helper is expecting input on stdin, and now no one is writing anything, everything locks up (observed in do_coredump). The fix is to change the 1 to UMH_WAIT_EXEC (aka 0), indicating that we want to wait for the kernel thread to be started, but not for the helper to finish. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26kernel-doc fix for kmod.cRandy Dunlap
Fix kmod.c: Warning(linux-2.6.23-rc1//kernel/kmod.c:364): No description found for parameter 'envp' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: prevent frozen user mode helpers from failing the freezing of tasksRafael J. Wysocki
At present, if a user mode helper is running while usermodehelper_pm_callback() is executed, the helper may be frozen and the completion in call_usermodehelper_exec() won't be completed until user space processes are thawed. As a result, the freezing of kernel threads may fail, which is not desirable. Prevent this from happening by introducing a counter of running user mode helpers and allowing usermodehelper_pm_callback() to succeed for action = PM_HIBERNATION_PREPARE or action = PM_SUSPEND_PREPARE only if there are no helpers running. [Namely, usermodehelper_pm_callback() waits for at most RUNNING_HELPERS_TIMEOUT for the number of running helpers to become zero and fails if that doesn't happen.] Special thanks to Uli Luckas <u.luckas@road.de>, Pavel Machek <pavel@ucw.cz> and Oleg Nesterov <oleg@tv-sign.ru> for reviewing the previous versions of this patch and for very useful comments. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Uli Luckas <u.luckas@road.de> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: disable usermode helper before hibernation and suspendRafael J. Wysocki
Use a hibernation and suspend notifier to disable the user mode helper before a hibernation/suspend and enable it after the operation. [akpm@linux-foundation.org: build fix] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18usermodehelper: Tidy up waitingJeremy Fitzhardinge
Rather than using a tri-state integer for the wait flag in call_usermodehelper_exec, define a proper enum, and use that. I've preserved the integer values so that any callers I've missed should still work OK. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com>
2007-07-18usermodehelper: split setup from executionJeremy Fitzhardinge
Rather than having hundreds of variations of call_usermodehelper for various pieces of usermode state which could be set up, split the info allocation and initialization from the actual process execution. This means the general pattern becomes: info = call_usermodehelper_setup(path, argv, envp); /* basic state */ call_usermodehelper_<SET EXTRA STATE>(info, stuff...); /* extra state */ call_usermodehelper_exec(info, wait); /* run process and free info */ This patch introduces wrappers for all the existing calling styles for call_usermodehelper_*, but folds their implementations into one. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: David Howells <dhowells@redhat.com> Cc: Bj?rn Steinbrink <B.Steinbrink@gmx.de> Cc: Randy Dunlap <randy.dunlap@oracle.com>
2007-05-09wait_for_helper: remove unneeded do_sigaction()Oleg Nesterov
allow_signal(SIGCHLD) does all necessary job, no need to call do_sigaction() prior to. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09____call_usermodehelper: don't flush_signals()Oleg Nesterov
____call_usermodehelper() has no reason for flush_signals(). It is a fresh forked process which is going to exec a user-space application or exit on failure. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix kevent's childs priority greedinessJan Engelhardt
Fix kevent's childs priority greediness. Such tasks were always scheduled at nice level -5 and, at that time, udev stole us the CPU time with -5. Already posted at http://lkml.org/lkml/2005/1/10/85 [akpm@linux-foundation.org: add comment] Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-23Revert "Driver core: let request_module() send a /sys/modules/kmod/-uevent"Greg Kroah-Hartman
This reverts commit c353c3fb0700a3c17ea2b0237710a184232ccd7f. It turns out that we end up with a loop trying to load the unix module and calling netfilter to do that. Will redo the patch later to not have this loop. Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23make kernel/kmod.c:kmod_mk staticAdrian Bunk
This patch makes the needlessly global struct kmod_mk static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16Driver core: let request_module() send a /sys/modules/kmod/-ueventKay Sievers
On recent systems, calls to /sbin/modprobe are handled by udev depending on the kind of device the kernel has discovered. This patch creates an uevent for the kernels internal request_module(), to let udev take control over the request, instead of forking the binary directly by the kernel. The direct execution of /sbin/modprobe can be disabled by setting: /sys/module/kmod/mod_request_helper (/proc/sys/kernel/modprobe) to an empty string, the same way /proc/sys/kernel/hotplug is disabled on an udev system. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-13[PATCH] x86-64: Allow to run a program when a machine check event is detectedAndi Kleen
When a machine check event is detected (including a AMD RevF threshold overflow event) allow to run a "trigger" program. This allows user space to react to such events sooner. The trigger is configured using a new trigger entry in the machinecheck sysfs interface. It is currently shared between all CPUs. I also fixed the AMD threshold handler to run the machine check polling code immediately to actually log any events that might have caused the threshold interrupt. Also added some documentation for the mce sysfs interface. Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-08[PATCH] rename struct namespace to struct mnt_namespaceKirill Korotaev
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with other namespaces being developped for the containers : pid, uts, ipc, etc. 'namespace' variables and attributes are also renamed to 'mnt_ns' Signed-off-by: Kirill Korotaev <dev@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-28[PATCH] fix create_write_pipe() error checkAkinobu Mita
The return value of create_write_pipe()/create_read_pipe() should be checked by IS_ERR(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-02[PATCH] introduce kernel_execveArnd Bergmann
The use of execve() in the kernel is dubious, since it relies on the __KERNEL_SYSCALLS__ mechanism that stores the result in a global errno variable. As a first step of getting rid of this, change all users to a global kernel_execve function that returns a proper error code. This function is a terrible hack, and a later patch removes it again after the kernel syscalls are gone. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Support piping into commands in /proc/sys/kernel/core_patternAndi Kleen
Using the infrastructure created in previous patches implement support to pipe core dumps into programs. This is done by overloading the existing core_pattern sysctl with a new syntax: |program When the first character of the pattern is a '|' the kernel will instead threat the rest of the pattern as a command to run. The core dump will be written to the standard input of that program instead of to a file. This is useful for having automatic core dump analysis without filling up disks. The program can do some simple analysis and save only a summary of the core dump. The core dump proces will run with the privileges and in the name space of the process that caused the core dump. I also increased the core pattern size to 128 bytes so that longer command lines fit. Most of the changes comes from allowing core dumps without seeks. They are fairly straight forward though. One small incompatibility is that if someone had a core pattern previously that started with '|' they will get suddenly new behaviour. I think that's unlikely to be a real problem though. Additional background: > Very nice, do you happen to have a program that can accept this kind of > input for crash dumps? I'm guessing that the embedded people will > really want this functionality. I had a cheesy demo/prototype. Basically it wrote the dump to a file again, ran gdb on it to get a backtrace and wrote the summary to a shared directory. Then there was a simple CGI script to generate a "top 10" crashes HTML listing. Unfortunately this still had the disadvantage to needing full disk space for a dump except for deleting it afterwards (in fact it was worse because over the pipe holes didn't work so if you have a holey address map it would require more space). Fortunately gdb seems to be happy to handle /proc/pid/fd/xxx input pipes as cores (at least it worked with zsh's =(cat core) syntax), so it would be likely possible to do it without temporary space with a simple wrapper that calls it in the right way. I ran out of time before doing that though. The demo prototype scripts weren't very good. If there is really interest I can dig them out (they are currently on a laptop disk on the desk with the laptop itself being in service), but I would recommend to rewrite them for any serious application of this and fix the disk space problem. Also to be really useful it should probably find a way to automatically fetch the debuginfos (I cheated and just installed them in advance). If nobody else does it I can probably do the rewrite myself again at some point. My hope at some point was that desktops would support it in their builtin crash reporters, but at least the KDE people I talked too seemed to be happy with their user space only solution. Alan sayeth: I don't believe that piping as such as neccessarily the right model, but the ability to intercept and processes core dumps from user space is asked for by many enterprise users as well. They want to know about, capture, analyse and process core dumps, often centrally and in automated form. [akpm@osdl.org: loff_t != unsigned long] Signed-off-by: Andi Kleen <ak@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Create call_usermodehelper_pipe()Andi Kleen
A new member in the ever growing family of call_usermode* functions is born. The new call_usermodehelper_pipe() function allows to pipe data to the stdin of the called user mode progam and behaves otherwise like the normal call_usermodehelp() (except that it always waits for the child to finish) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix ____call_usermodehelper errors being silently ignoredBjörn Steinbrink
If ____call_usermodehelper fails, we're not interested in the child process' exit value, but the real error, so let's stop wait_for_helper from overwriting it in that case. Issue discovered by Benedikt Böhm while working on a Linux-VServer usermode helper. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] bug fix in kernel/kmod.cKenneth Lee
I think there is a bug in kmod.c: In __call_usermodehelper(), when kernel_thread(wait_for_helper, ...) return success, since wait_for_helper() might call complete() at any time, the sub_info should not be used any more. Normally wait_for_helper() take a long time to finish, you may not get problem for most of the case. But if you remove /sbin/modprobe, it may become easier for you to get a oop in khelper. Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate on-stack completionsIngo Molnar
lockdep needs to have the waitqueue lock initialized for on-stack waitqueues implicitly initialized by DECLARE_COMPLETION(). Annotate on-stack completions accordingly. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] wait_for_helper: trivial style cleanupOleg Nesterov
Use NULL instead of (... *)0 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Keys: Get rid of warning in kmod.c if keys disabledDavid Howells
The attached patch gets rid of a "statement without effect" warning when CONFIG_KEYS is disabled by making use of the return value of key_get(). The compiler will optimise all of this away when keys are disabled. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
