path: root/kernel/kmod.c
2005-10-30[PATCH] Keys: Get rid of warning in kmod.c if keys disabledDavid Howells
The attached patch gets rid of a "statement without effect" warning when CONFIG_KEYS is disabled by making use of the return value of key_get(). The compiler will optimise all of this away when keys are disabled. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] Keys: Pass session keyring to call_usermodehelper()David Howells
The attached patch makes it possible to pass a session keyring through to the process spawned by call_usermodehelper(). This allows patch 3/3 to pass an authorisation key through to /sbin/request-key, thus permitting better access controls when doing just-in-time key creation. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
