path: root/kernel/ksysfs.c
2007-10-15sched: group scheduling, sysfs tunablesDhaval Giani
Add tunables in sysfs to modify a user's cpu share. A directory is created in sysfs for each new user in the system. /sys/kernel/uids/<uid>/cpu_share Reading this file returns the cpu shares granted for the user. Writing into this file modifies the cpu share for the user. Only an administrator is allowed to modify a user's cpu share. Ex: # cd /sys/kernel/uids/ # cat 512/cpu_share 1024 # echo 2048 > 512/cpu_share # cat 512/cpu_share 2048 # Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-20FRV: Fix linkage problemsDavid Howells
Make it possible to use __start_notes and __stop_notes without getting a GPREL overflow error from the FRV linker. Small variables that would otherwise be in .data or .bss may, depending on the arch, be placed in special sections (.sdata or .sbss) that permit single instruction references on fixed instruction width machines. __start_notes and __stop_notes aren't really char variables, and certainly don't refer to data in .data or .bss. Making them type "void" fools the compiler into not assuming anything about them. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Add /sys/kernel/notesRoland McGrath
This patch adds the /sys/kernel/notes magic file. Reading this delivers the contents of the kernel's .notes section. This lets userland easily glean any detailed information about the running kernel's build that was stored there at compile time. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[PATCH] Add a sysfs file to determine if a kexec kernel is loadedJeff Moyer
Create two files in /sys/kernel, kexec_loaded and kexec_crash_loaded. Each file contains a simple boolean value indicating whether the relevant kernel has been loaded into memory. The motivation for this is geared around support. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fix build error if CONFIG_SYSFS=nAndrew Morton
uevent_seqnum and uevent_helper are only defined if CONFIG_HOTPLUG=y, CONFIG_NET=n. (I stole this back from Greg's tree - it makes allnoconfig work). Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] kobject: fix build error if CONFIG_SYSFS=nJun'ichi Nomura
Moving uevent_seqnum and uevent_helper to kobject_uevent.c because they are used even if CONFIG_SYSFS=n while kernel/ksysfs.c is built only if CONFIG_SYSFS=y, Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] kdump: export per cpu crash notes pointer through sysfsVivek Goyal
- Kexec on panic functionality allocates memory for saving cpu registers in case of system crash event. Address of this allocated memory needs to be exported to user space, which is used by kexec-tools. - Previously, a single /sys/kernel/crash_notes entry was being exported as memory allocated was a single continuous array. Now memory allocation being dyanmic and per cpu based, address of per cpu buffer is exported through "/sys/devices/system/cpu/cpuX/crash_notes" Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] kobject_uevent CONFIG_NET=n fixakpm@osdl.org
lib/lib.a(kobject_uevent.o)(.text+0x25f): In function `kobject_uevent': : undefined reference to `__alloc_skb' lib/lib.a(kobject_uevent.o)(.text+0x2a1): In function `kobject_uevent': : undefined reference to `skb_over_panic' lib/lib.a(kobject_uevent.o)(.text+0x31d): In function `kobject_uevent': : undefined reference to `skb_over_panic' lib/lib.a(kobject_uevent.o)(.text+0x356): In function `kobject_uevent': : undefined reference to `netlink_broadcast' lib/lib.a(kobject_uevent.o)(.init.text+0x9): In function `kobject_uevent_init': : undefined reference to `netlink_kernel_create' make: *** [.tmp_vmlinux1] Error 1 Netlink is unconditionally enabled if CONFIG_NET, so that's OK. kobject_uevent.o is compiled even if !CONFIG_HOTPLUG, which is lazy. Let's compound the sin. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] add uevent_helper control in /sys/kernel/Kay Sievers
This deprecates the /proc/sys/kernel/hotplug file, as all this stuff should be in /sys some day, right? :) In /sys/kernel/ we have now uevent_seqnum and uevent_helper. The seqnum is no longer used by udev, as the version for this kernel depends on netlink which events will never get out-of-order. Recent udev versions disable the /sbin/hotplug helper with an init script, cause it leads to OOM on big boxes by running hundreds of shells in parallel. It should be done now by: echo "" > /sys/kernel/uevent_helper (Note that "-n" does not work, cause neighter proc nor sysfs support truncate().) Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-25[PATCH] Kdump: Export crash notes section address through sysfsVivek Goyal
o Following patch exports kexec global variable "crash_notes" to user space through sysfs as kernel attribute in /sys/kernel. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
