path: root/kernel/lockdep.c
2009-10-09lockdep: Use cpu_clock() for lockstatPeter Zijlstra
Some tracepoint magic (TRACE_EVENT(lock_acquired)) relies on the fact that lock hold times are positive and uses div64 on that. That triggered a build warning on MIPS, and probably causes bad output in certain circumstances as well. Make it truly positive. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1254818502.21044.112.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23lockdep: use new arch_is_kernel_data()Mike Frysinger
This allows lockdep to locate symbols that are in arch-specific data sections (such as data in Blackfin on-chip SRAM regions). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Robin Getz <rgetz@blackfin.uclinux.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-29lockdep: Remove recursion stattisticsMing Lei
Since lockdep has introduced BFS to avoid recursion, statistics for recursion does not make any sense now. So remove them. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: a.p.zijlstra@chello.nl LKML-Reference: <1251542879-5211-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix memory usage info of BFSMing Lei
The unit is KB, so sizeof(struct circular_queue) should be divided by 1024. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: davem@davemloft.net Cc: Ming Lei <tom.leiming@gmail.com> Cc: a.p.zijlstra@chello.nl LKML-Reference: <1249220616-7190-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Reintroduce generation count to make BFS fasterMing Lei
We still can apply DaveM's generation count optimization to BFS, based on the following idea: - before doing each BFS, increase the global generation id by 1 - if one node in the graph has been visited, mark it as visited by storing the current global generation id into the node's dep_gen_id field - so we can decide if one node has been visited already, by comparing the node's dep_gen_id with the global generation id. By applying DaveM's generation count optimization to current implementation of BFS, we gain the following advantages: - we save MAX_LOCKDEP_ENTRIES/8 bytes memory; - we remove the bitmap_zero(bfs_accessed, MAX_LOCKDEP_ENTRIES); in each BFS, which is very time-consuming since MAX_LOCKDEP_ENTRIES may be very large.(16384UL) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "David S. Miller" <davem@davemloft.net> LKML-Reference: <1248274089-6358-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Deal with many similar locksPeter Zijlstra
spin_lock_nest_lock() allows to take many instances of the same class, this can easily lead to overflow of MAX_LOCK_DEPTH. To avoid this overflow, we'll stop accounting instances but start reference counting the class in the held_lock structure. [ We could maintain a list of instances, if we'd move the hlock stuff into __lock_acquired(), but that would require significant modifications to the current code. ] We restrict this mode to spin_lock_nest_lock() only, because it degrades the lockdep quality due to lost of instance. For lockstat this means we don't track lock statistics for any but the first lock in the series. Currently nesting is limited to 11 bits because that was the spare space available in held_lock. This yields a 2048 instances maximium. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Introduce lockdep_assert_held()Peter Zijlstra
Add a lockdep helper to validate that we indeed are the owner of a lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix style nitsPeter Zijlstra
fixes a few comments and whitespaces that annoyed me. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix backtracesPeter Zijlstra
Truncate stupid -1 entries in backtraces. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1248096665.15751.8816.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: BFS cleanupPeter Zijlstra
Some cleanups of the lockdep code after the BFS series: - Remove the last traces of the generation id - Fixup comment style - Move the bfs routines into lockdep.c - Cleanup the bfs routines [ tom.leiming@gmail.com: Fix crash ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-11-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Add statistics info for max bfs queue depthMing Lei
Add BFS statistics to the existing lockdep stats. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-10-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Update memory usage introduced by BFSMing Lei
Also account the BFS memory usage. Signed-off-by: Ming Lei <tom.leiming@gmail.com> [ fix build for !PROVE_LOCKING ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-9-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Implement lockdep_count_*ward_deps by BFSMing Lei
Implement lockdep_count_{for,back}ward using BFS. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-8-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Introduce print_shortest_lock_dependenciesMing Lei
Since the shortest lock dependencies' path may be obtained by BFS, we print the shortest one by print_shortest_lock_dependencies(). Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-7-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Implement find_usage_*wards by BFSMing Lei
This patch uses BFS to implement find_usage_*wards(),which was originally writen by DFS. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-6-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Implement check_noncircular() by BFSMing Lei
This patch uses BFS to implement check_noncircular() and prints the generated shortest circle if exists. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-5-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Introduce match function to BFSMing Lei
1,introduce match() to BFS in order to make it usable to match different pattern; 2,also rename some functions to make them more suitable. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-4-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Improve implementation of BFSMing Lei
1,replace %MAX_CIRCULAR_QUE_SIZE with &(MAX_CIRCULAR_QUE_SIZE-1) since we define MAX_CIRCULAR_QUE_SIZE as power of 2; 2,use bitmap to mark if a lock is accessed in BFS in order to clear it quickly, because we may search a graph many times. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-3-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Print the shortest dependency chain if finding a circleMing Lei
Currently lockdep will print the 1st circle detected if it exists when acquiring a new (next) lock. This patch prints the shortest path from the next lock to be acquired to the previous held lock if a circle is found. The patch still uses the current method to check circle, and once the circle is found, breadth-first search algorithem is used to compute the shortest path from the next lock to the previous lock in the forward lock dependency graph. Printing the shortest path will shorten the dependency chain, and make troubleshooting for possible circular locking easier. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-2-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-17lockdep: more robust lockdep_map init sequencePeter Zijlstra
Steven Rostedt reported: > OK, I think I figured this bug out. This is a lockdep issue with respect > to tracepoints. > > The trace points in lockdep are called all the time. Outside the lockdep > logic. But if lockdep were to trigger an error / warning (which this run > did) we might be in trouble. For new locks, like the dentry->d_lock, that > are created, they will not get a name: > > void lockdep_init_map(struct lockdep_map *lock, const char *name, > struct lock_class_key *key, int subclass) > { > if (unlikely(!debug_locks)) > return; > > When a problem is found by lockdep, debug_locks becomes false. Thus we > stop allocating names for locks. This dentry->d_lock I had, now has no > name. Worse yet, I have CONFIG_DEBUG_VM set, that scrambles non > initialized memory. Thus, when the trace point was hit, it had junk for > the lock->name, and the machine crashed. Ah, nice catch. I think we should put at least the name in regardless. Ensure we at least initialize the trivial entries of the depmap so that they can be relied upon, even when lockdep itself decided to pack up and go home. [ Impact: fix lock tracing after lockdep warnings. ] Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1239954049.23397.4156.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-10tracing/lockdep: report the time waited for a lockFrederic Weisbecker
While trying to optimize the new lock on reiserfs to replace the bkl, I find the lock tracing very useful though it lacks something important for performance (and latency) instrumentation: the time a task waits for a lock. That's what this patch implements: bash-4816 [000] 202.652815: lock_contended: lock_contended: &sb->s_type->i_mutex_key bash-4816 [000] 202.652819: lock_acquired: &rq->lock (0.000 us) <...>-4787 [000] 202.652825: lock_acquired: &rq->lock (0.000 us) <...>-4787 [000] 202.652829: lock_acquired: &rq->lock (0.000 us) bash-4816 [000] 202.652833: lock_acquired: &sb->s_type->i_mutex_key (16.005 us) As shown above, the "lock acquired" field is followed by the time it has been waiting for the lock. Usually, a lock contended entry is followed by a near lock_acquired entry with a non-zero time waited. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1238975373-15739-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: add stack dumps to asserts hrtimer: fix rq->lock inversion (again)
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-31lockdep: add stack dumps to assertsPeter Zijlstra
Have a better idea about exactly which loc causes a lockdep limit overflow. Often it's a bug or inefficiency in that subsystem. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1237376327.5069.253.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31Merge branch 'linus' into locking-for-linusIngo Molnar
Conflicts: lib/Kconfig.debug
2009-03-30lockdep: fix deadlock in lockdep_trace_allocPeter Zijlstra
Heiko reported that we grab the graph lock with irqs enabled. Fix this by providng the same wrapper as all other lockdep entry functions have. Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <npiggin@suse.de> LKML-Reference: <1237544000.24626.52.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13Merge branch 'core/locking' into tracing/ftraceIngo Molnar
2009-03-05lockdep: remove duplicate CONFIG_DEBUG_LOCKDEP definitionsDavid Rientjes
Impact: cleanup The atomic debug modifiers are already defined in kernel/lockdep_internals.h. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <alpine.DEB.2.00.0903050222160.30401@chino.kir.corp.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04tracing: add lockdep tracepoints for lock acquire/releasePeter Zijlstra
Augment the traces with lock names when lockdep is available: 1) | down_read_trylock() { 1) | _spin_lock_irqsave() { 1) | /* lock_acquire: &sem->wait_lock */ 1) 4.201 us | } 1) | _spin_unlock_irqrestore() { 1) | /* lock_release: &sem->wait_lock */ 1) 3.523 us | } 1) | /* lock_acquire: try read &mm->mmap_sem */ 1) + 13.386 us | } 1) 1.635 us | find_vma(); 1) | handle_mm_fault() { 1) | __do_fault() { 1) | filemap_fault() { 1) | find_lock_page() { 1) | find_get_page() { 1) | /* lock_acquire: read rcu_read_lock */ 1) | /* lock_release: rcu_read_lock */ 1) 5.697 us | } 1) 8.158 us | } 1) + 11.079 us | } 1) | _spin_lock() { 1) | /* lock_acquire: __pte_lockptr(page) */ 1) 3.949 us | } 1) 1.460 us | page_add_file_rmap(); 1) | _spin_unlock() { 1) | /* lock_release: __pte_lockptr(page) */ 1) 3.115 us | } 1) | unlock_page() { 1) 1.421 us | page_waitqueue(); 1) 1.220 us | __wake_up_bit(); 1) 6.519 us | } 1) + 34.328 us | } 1) + 37.452 us | } 1) | up_read() { 1) | /* lock_release: &mm->mmap_sem */ 1) | _spin_lock_irqsave() { 1) | /* lock_acquire: &sem->wait_lock */ 1) 3.865 us | } 1) | _spin_unlock_irqrestore() { 1) | /* lock_release: &sem->wait_lock */ 1) 8.562 us | } 1) + 17.370 us | } Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: =?ISO-8859-1?Q?T=F6r=F6k?= Edwin <edwintorok@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1236166375.5330.7209.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04lockdep: remove extra "irq" stringPeter Zijlstra
Impact: clarify lockdep printk text print_irq_inversion_bug() gets handed state strings of the form "HARDIRQ", "SOFTIRQ", "RECLAIM_FS" and appends "-irq-{un,}safe" to them, which is either redudant for *IRQ or confusing in the RECLAIM_FS case. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1236175192.5330.7585.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04lockdep: fix incorrect state namePeter Zijlstra
In the recent mark_lock_irq() rework a bug snuck in that would report the state of write locks causing irq inversion under a read lock as a read lock. Fix this by masking the read bit of the state when validating write dependencies. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1236172646.5330.7450.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-15lockdep: build fix for !PROVE_LOCKINGPeter Zijlstra
The __GFP_FS annotations fail to build with CONFIG_LOCKDEP=y, CONFIG_PROVE_LOCKING=n, ammend that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: use stringify.hPeter Zijlstra
Arnd pointed out we have the stringify macro magic already in-kernel. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: simplify check_prev_add_irq()Peter Zijlstra
Remove the manual state iteration thingy. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: get_user_chars() redoPeter Zijlstra
Generic, states independent, get_user_chars(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: simplify get_user_chars()Peter Zijlstra
there's too much repetition of code.. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: add comments to mark_lock_irq()Peter Zijlstra
re-add some of the comments that got lost in the refactoring. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: remove macro usage from mark_held_locks()Peter Zijlstra
Now that we have nice numerical relations for the states, remove the macro magics. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: fully reduce mark_lock_irq()Peter Zijlstra
Now what its only two functions, they again look rather similar. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: merge the !_READ mark_lock_irq() helpersPeter Zijlstra
These two are also remakably similar Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: merge the _READ mark_lock_irq() helpersPeter Zijlstra
The _READ helpers show remarkable similarity, merge them. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: simplify mark_lock_irq() helpers #3Peter Zijlstra
Kill another argument Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: further simplify mark_lock_irq() helpersPeter Zijlstra
take away another parameter Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: simplify the mark_lock_irq() helpersPeter Zijlstra
In order to unify them, take some arguments away Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: split up mark_lock_irq()Peter Zijlstra
split mark_lock_irq() into 4 simple helper functions Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: generate usage stringsPeter Zijlstra
generate the usage strings XXX capital invasion :-( Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: simplify mark_lock()Peter Zijlstra
remove the state iteration Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
