path: root/kernel/lockdep_proc.c
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11lockdep: Avoid /proc/lockdep & lock_stat infinite outputTim Pepper
Both /proc/lockdep and /proc/lock_stat output may loop infinitely. When a read() requests an amount of data smaller than the amount of data that the seq_file's foo_show() outputs, the output starts looping and outputs the "stuck" element's data infinitely. There may be multiple sequential calls to foo_start(), foo_next()/foo_show(), and foo_stop() for a single open with sequential read of the file. The _start() does not have to start with the 0th element and _show() might be called multiple times in a row for the same element for a given open/read of the seq_file. Also header output should not be happening in _start(). All output should be in _show(), which SEQ_START_TOKEN is meant to help. Having output in _start() may also negatively impact seq_file's seq_read() and traverse() accounting. Signed-off-by: Tim Pepper <lnxninja@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Ingo Molnar <mingo@elte.hu> Cc: Al Viro <viro@ftp.linux.org.uk>
2007-07-31Fix leak on /proc/lockdep_statsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: better class name representationPeter Zijlstra
optionally add class->name_version and class->subclass to the class name Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: measure lock bouncingPeter Zijlstra
__acquire | lock _____ | \ | __contended | | | wait | _______/ |/ | __acquired | __release | unlock We measure acquisition and contention bouncing. This is done by recording a cpu stamp in each lock instance. Contention bouncing requires the cpu stamp to be set on acquisition. Hence we move __acquired into the generic path. __acquired is then used to measure acquisition bouncing by comparing the current cpu with the old stamp before replacing it. __contended is used to measure contention bouncing (only useful for preemptable locks) [akpm@linux-foundation.org: cleanups] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockdep: various fixesPeter Zijlstra
- update the copyright notices - use the default hash function - fix a thinko in a BUILD_BUG_ON - add a WARN_ON to spot inconsitent naming - fix a termination issue in /proc/lock_stat [akpm@linux-foundation.org: cleanups] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: human readability tweaksPeter Zijlstra
Present all this fancy new lock statistics information: *warning, _wide_ output ahead* (output edited for purpose of brevity) # cat /proc/lock_stat lock_stat version 0.1 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- class name contentions waittime-min waittime-max waittime-total acquisitions holdtime-min holdtime-max holdtime-total ----------------------------------------------------------------------------------------------------------------------------------------------------------------- &inode->i_mutex: 14458 6.57 398832.75 2469412.23 6768876 0.34 11398383.65 339410830.89 --------------- &inode->i_mutex 4486 [<ffffffff802a08f9>] pipe_wait+0x86/0x8d &inode->i_mutex 0 [<ffffffff802a01e8>] pipe_write_fasync+0x29/0x5d &inode->i_mutex 0 [<ffffffff802a0e18>] pipe_read+0x74/0x3a5 &inode->i_mutex 0 [<ffffffff802a1a6a>] do_lookup+0x81/0x1ae ................................................................................................................................................................. &inode->i_data.tree_lock-W: 491 0.27 62.47 493.89 2477833 0.39 468.89 1146584.25 &inode->i_data.tree_lock-R: 65 0.44 4.27 48.78 26288792 0.36 184.62 10197458.24 -------------------------- &inode->i_data.tree_lock 46 [<ffffffff80277095>] __do_page_cache_readahead+0x69/0x24f &inode->i_data.tree_lock 31 [<ffffffff8026f9fb>] add_to_page_cache+0x31/0xba &inode->i_data.tree_lock 0 [<ffffffff802770ee>] __do_page_cache_readahead+0xc2/0x24f &inode->i_data.tree_lock 0 [<ffffffff8026f6e4>] find_get_page+0x1a/0x58 ................................................................................................................................................................. proc_inum_idr.lock: 0 0.00 0.00 0.00 36 0.00 65.60 148.26 proc_subdir_lock: 0 0.00 0.00 0.00 3049859 0.00 106.81 1563212.42 shrinker_rwsem-W: 0 0.00 0.00 0.00 5 0.00 1.73 3.68 shrinker_rwsem-R: 0 0.00 0.00 0.00 633 2.57 246.57 10909.76 'contentions' and 'acquisitions' are the number of such events measured (since the last reset). The waittime- and holdtime- (min, max, total) numbers are presented in microseconds. If there are any contention points, the lock class is presented in the block format (as i_mutex and tree_lock above), otherwise a single line of output is presented. The output is sorted on absolute number of contentions (read + write), this should get the worst offenders presented first, so that: # grep : /proc/lock_stat | head will quickly show who's bad. The stats can be reset using: # echo 0 > /proc/lock_stat [bunk@stusta.de: make 2 functions static] [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockdep: reduce the ifdefferyPeter Zijlstra
Move code around to get fewer but larger #ifdef sections. Break some in-function #ifdefs out into their own functions. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Fix apparent typo CONFIG_LOCKDEP_DEBUGRobert P. J. Day
Replace the apparent typo CONFIG_LOCKDEP_DEBUG with the correct CONFIG_DEBUG_LOCKDEP. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] lockdep: add graph depth information to /proc/lockdepJason Baron
Generate locking graph information into /proc/lockdep, for lock hierarchy documentation and visualization purposes. sample output: c089fd5c OPS: 138 FD: 14 BD: 1 --..: &tty->termios_mutex -> [c07a3430] tty_ldisc_lock -> [c07a37f0] &port_lock_key -> [c07afdc0] &rq->rq_lock_key#2 The lock classes listed are all the first-hop lock dependencies that lockdep has seen so far. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: procfsIngo Molnar
Lock validator /proc/lockdep and /proc/lockdep_stats support. (FIXME: should go into debugfs) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
