commit 80c503e0e68fbe271680ab48f0fe29bc034b01b7 upstream.
The __torture_print_stats() function in locktorture.c carefully
initializes local variable "min" to statp[0].n_lock_acquired, but
then compares it to statp[i].n_lock_fail. Given that the .n_lock_fail
field should normally be zero, and given the initialization, it seems
reasonable to display the maximum and minimum number acquisitions
instead of miscomputing the maximum and minimum number of failures.
This commit therefore switches from failures to acquisitions.
And this turns out to be not only a day-zero bug, but entirely my
own fault. I hate it when that happens!
Fixes: 0af3fe1efa53 ("locktorture: Add a lock-torture kernel module")
Reported-by: Will Deacon <will@kernel.org>
Signed-off-by: Paul E. McKenney <paulmck@kernel.org>
Acked-by: Will Deacon <will@kernel.org>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Josh Triplett <josh@joshtriplett.org>
[ Upstream commit 2ce77d16db4240dd2e422fc0a5c26d3e2ec03446 ]
Things can explode for locktorture if the user does combinations
of nwriters_stress=0 nreaders_stress=0. Fix this by not assuming
we always want to torture writer threads.
Reported-by: Jeremy Linton <jeremy.linton@arm.com>
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Jeremy Linton <jeremy.linton@arm.com>
Tested-by: Jeremy Linton <jeremy.linton@arm.com>
commit f4dbba591945dc301c302672adefba9e2ec08dc5 upstream.
When running locktorture module with the below commands with kmemleak enabled:
$ modprobe locktorture torture_type=rw_lock_irq
$ rmmod locktorture
The below kmemleak got caught:
root@10:~# echo scan > /sys/kernel/debug/kmemleak
[ 323.197029] kmemleak: 2 new suspected memory leaks (see /sys/kernel/debug/kmemleak)
root@10:~# cat /sys/kernel/debug/kmemleak
unreferenced object 0xffffffc07592d500 (size 128):
comm "modprobe", pid 368, jiffies 4294924118 (age 205.824s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 c3 7b 02 00 00 00 00 00 .........{......
00 00 00 00 00 00 00 00 d7 9b 02 00 00 00 00 00 ................
backtrace:
[<ffffff80081e5a88>] create_object+0x110/0x288
[<ffffff80086c6078>] kmemleak_alloc+0x58/0xa0
[<ffffff80081d5acc>] __kmalloc+0x234/0x318
[<ffffff80006fa130>] 0xffffff80006fa130
[<ffffff8008083ae4>] do_one_initcall+0x44/0x138
[<ffffff800817e28c>] do_init_module+0x68/0x1cc
[<ffffff800811c848>] load_module+0x1a68/0x22e0
[<ffffff800811d340>] SyS_finit_module+0xe0/0xf0
[<ffffff80080836f0>] el0_svc_naked+0x24/0x28
[<ffffffffffffffff>] 0xffffffffffffffff
unreferenced object 0xffffffc07592d480 (size 128):
00 00 00 00 00 00 00 00 3b 6f 01 00 00 00 00 00 ........;o......
00 00 00 00 00 00 00 00 23 6a 01 00 00 00 00 00 ........#j......
backtrace:
[<ffffff80006fa22c>] 0xffffff80006fa22c
It is because cxt.lwsa and cxt.lrsa don't get freed in module_exit, so free
them in lock_torture_cleanup() and free writer_tasks if reader_tasks is
failed at memory allocation.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: 石洋 <yang.s@alibaba-inc.com>
This commit replaces an #ifdef with IS_ENABLED(), saving five lines.
Cc: corbet@lwn.net
Cc: dave@stgolabs.net
Cc: dhowells@redhat.com
Cc: linux-doc@vger.kernel.org
Cc: will.deacon@arm.com
Link: http://lkml.kernel.org/r/1461691328-5429-4-git-send-email-paulmck@linux.vnet.ibm.com
It has been found that paths that invoke cleanups through
lock_torture_cleanup() can trigger NULL pointer dereferencing
bugs during the statistics printing phase. This is mainly
because we should not be calling into statistics before we are
sure things have been set up correctly.
Specifically, early checks (and the need for handling this in
the cleanup call) only include parameter checks and basic
statistics allocation. Once we start write/read kthreads
we then consider the test as started. As such, update the function
in question to check for cxt.lwsa writer stats, if not set,
we either have a bogus parameter or -ENOMEM situation and
therefore only need to deal with general torture calls.
Reported-and-tested-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Cc: bobby.prani@gmail.com
Cc: dipankar@in.ibm.com
Cc: dvhart@linux.intel.com
Cc: edumazet@google.com
Cc: fweisbec@gmail.com
Cc: jiangshanlai@gmail.com
Cc: josh@joshtriplett.org
Cc: mathieu.desnoyers@efficios.com
Cc: oleg@redhat.com
Cc: rostedt@goodmis.org
Link: http://lkml.kernel.org/r/1460476038-27060-2-git-send-email-paulmck@linux.vnet.ibm.com
[ Improved the changelog. ]
For the case of rtmutex torturing we will randomly call into the
boost() handler, including upon module exiting when the tasks are
deboosted before stopping. In such cases the task may or may not have
already been boosted, and therefore the NULL being explicitly passed
can occur anywhere. Currently we only assume that the task will is
at a higher prio, and in consequence, dereference a NULL pointer.
This patch fixes the case of a rmmod locktorture exploding while
pounding on the rtmutex lock (partial trace):
task: ffff88081026cf80 ti: ffff880816120000 task.ti: ffff880816120000
RSP: 0018:ffff880816123eb0 EFLAGS: 00010206
RAX: ffff88081026cf80 RBX: ffff880816bfa630 RCX: 0000000000160d1b
RDX: 0000000000000000 RSI: 0000000000000202 RDI: 0000000000000000
RBP: ffff88081026cf80 R08: 000000000000001f R09: ffff88017c20ca80
R10: 0000000000000000 R11: 000000000048c316 R12: ffffffffa05d1840
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88203f880000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 0000000001c0a000 CR4: 00000000000406e0
Stack:
ffffffffa05d141d ffff880816bfa630 ffffffffa05d1922 ffff88081e70c2c0
ffff880816bfa630 ffffffff81095fed 0000000000000000 ffffffff8107bf60
ffff880816bfa630 ffffffff00000000 ffff880800000000 ffff880816123f08
Call Trace:
[<ffffffff81095fed>] kthread+0xbd/0xe0
[<ffffffff815cf40f>] ret_from_fork+0x3f/0x70
This patch ensures that if the random state pointer is not NULL and current
is not boosted, then do nothing.
RIP: 0010:[<ffffffffa05c6185>] [<ffffffffa05c6185>] torture_random+0x5/0x60 [torture]
[<ffffffffa05d141d>] torture_rtmutex_boost+0x1d/0x90 [locktorture]
[<ffffffffa05d1922>] lock_torture_writer+0xe2/0x170 [locktorture]
Cc: oleg@redhat.com
Link: http://lkml.kernel.org/r/1460476038-27060-1-git-send-email-paulmck@linux.vnet.ibm.com
'torture.2015.10.06a' into HEAD
doc.2015.10.06a: Documentation updates.
percpu-rwsem.2015.10.06a: Optimization of per-CPU reader-writer semaphores.
torture.2015.10.06a: Torture-test updates.
The locktorture module has a list of torture types, and specifying
a type not on this list is supposed to cleanly fail the module load.
Unfortunately, the "fail" happens without the "cleanly". This commit
therefore adds the needed clean-up after an incorrect torture_type.
This commit adds percpu_rwsem tests based on the earlier rwsem tests.
Real time mutexes is one of the few general primitives
that we do not have in locktorture. Address this -- a few
considerations:
o To spice things up, enable competing thread(s) to become
rt, such that we can stress different prio boosting paths
in the rtmutex code. Introduce a ->task_boost callback,
only used by rtmutex-torturer. Tasks will boost/deboost
around every 50k (arbitrarily) lock/unlock operations.
o Hold times are similar to what we have for other locks:
only occasionally having longer hold times (per ~200k ops).
So we roughly do two full rt boost+deboosting ops with
short hold times.
The locktorture long delays are in milliseconds rather than microseconds,
so this commit changes the name of the corresponding variable from
longdelay_us to longdelay_ms.
Reported-by: Ben Goodwyn <bgoodwyn@softnas.com>
torture_rwlock_read_unlock_irq() must use read_unlock_irqrestore()
instead of write_unlock_irqrestore().
Use read_unlock_irqrestore() instead of write_unlock_irqrestore().
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Remove some unnecessary ones and explicitly include rwsem.h
... trigger an error if so.
Its quite easy to get mixed up with the names -- 'torture_spinlock_irq'
is not actually a valid spinlock name.
Add a "rw_lock" torture test to stress kernel rwlocks and their irq
variant. Reader critical regions are 5x longer than writers. As such
a similar ratio of lock acquisitions is seen in the statistics. In the
case of massive contention, both hold the lock for 1/10 of a second.
The amount of global variables is getting pretty ugly. Group variables
related to the execution (ie: not parameters) in a new context structure.
We can easily do so with our new reader lock support. Just an arbitrary
design default: readers have higher (5x) critical region latencies than
writers: 50 ms and 10 ms, respectively.
Most of it is based on what we already have for writers. This allows
readers to be very independent (and thus configurable), enabling
future module parameters to control things such as rw distribution.
Furthermore, readers have their own delaying function, allowing us
to test different rw critical region latencies, and stress locking
internals. Similarly, statistics, for now will only serve for the
number of lock acquisitions -- as opposed to writers, readers have
no failure detection.
In addition, introduce a new nreaders_stress module parameter. The
default number of readers will be the same number of writers threads.
Writer threads are interleaved with readers. Documentation is updated,
respectively.
When performing module cleanups by calling torture_cleanup() the
'torture_type' string in nullified However, callers are not necessarily
done, and might still need to reference the variable. This impacts
both rcutorture and locktorture, causing printing things like:
[ 94.226618] (null)-torture: Stopping lock_torture_writer task
[ 94.226624] (null)-torture: Stopping lock_torture_stats task
Thus delay this operation until the very end of the cleanup process.
The consequence (which shouldn't matter for this kid of program) is,
of course, that we delay the window between rmmod and modprobing,
for instance in module_torture_begin().
The statistics structure can serve well for both reader and writer
locks, thus simply rename some fields that mention 'write' and leave
the declaration of lwsa.
Regular locks are very different than locks with debugging. For instance
for mutexes, debugging forces to only take the slowpaths. As such, the
locktorture module should take this into account when printing related
information -- specifically when printing user passed parameters, it seems
the right place for such info.
Add a "mutex_lock" torture test. The main difference with the already
existing spinlock tests is that the latency of the critical region
is much larger. We randomly delay for (arbitrarily) either 500 ms or,
otherwise, 25 ms. While this can considerably reduce the amount of
writes compared to non blocking locks, if run long enough it can have
the same torturous effect. Furthermore it is more representative of
mutex hold times and can stress better things like thrashing.
... to just 'torture_runnable'. It follows other variable naming
and is shorter.
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull scheduler updates from Ingo Molnar:
"The main scheduling related changes in this cycle were:
- various sched/numa updates, for better performance
- tree wide cleanup of open coded nice levels
- nohz fix related to rq->nr_running use
- cpuidle changes and continued consolidation to improve the
kernel/sched/idle.c high level idle scheduling logic. As part of
this effort I pulled cpuidle driver changes from Rafael as well.
- standardized idle polling amongst architectures
- continued work on preparing better power/energy aware scheduling
- sched/rt updates
- misc fixlets and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (49 commits)
sched/numa: Decay ->wakee_flips instead of zeroing
sched/numa: Update migrate_improves/degrades_locality()
sched/numa: Allow task switch if load imbalance improves
sched/rt: Fix 'struct sched_dl_entity' and dl_task_time() comments, to match the current upstream code
sched: Consolidate open coded implementations of nice level frobbing into nice_to_rlimit() and rlimit_to_nice()
sched: Initialize rq->age_stamp on processor start
sched, nohz: Change rq->nr_running to always use wrappers
sched: Fix the rq->next_balance logic in rebalance_domains() and idle_balance()
sched: Use clamp() and clamp_val() to make sys_nice() more readable
sched: Do not zero sg->cpumask and sg->sgp->power in build_sched_groups()
sched/numa: Fix initialization of sched_domain_topology for NUMA
sched: Call select_idle_sibling() when not affine_sd
sched: Simplify return logic in sched_read_attr()
sched: Simplify return logic in sched_copy_attr()
sched: Fix exec_start/task_hot on migrated tasks
arm64: Remove TIF_POLLING_NRFLAG
metag: Remove TIF_POLLING_NRFLAG
sched/idle: Make cpuidle_idle_call() void
sched/idle: Reflow cpuidle_idle_call()
sched/idle: Delay clearing the polling bit
The torture tests are designed to run in isolation, but do not enforce
this isolation. This commit therefore checks for concurrent torture
tests, and refuses to start new tests while old tests are running.
The locktorture module references CONFIG_LOCK_TORTURE_TEST_RUNNABLE,
which does not exist. Which is a good thing, because otherwise
randconfig testing could enable both rcutorture and locktorture
concurrently, which the torture tests are not set up for. This
commit therefore removes the reference, so that test is runnable
immediately only when inserted as a module.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
The current lock_torture_writer() spends too much time sleeping and not
enough time hammering locks, as in an eight-CPU test will often only be
utilizing a CPU or two. This commit therefore makes lock_torture_writer()
sleep less and hammer more.
Replace various -20/+19 hardcoded nice values with MIN_NICE/MAX_NICE.
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/ff13819fd09b7a5dba5ab5ae797f2e7019bdfa17.1394532288.git.yangds.fnst@cn.fujitsu.com
Cc: devel@driverdev.osuosl.org
Cc: devicetree@vger.kernel.org
Cc: fcoe-devel@open-fcoe.org
Cc: linux390@de.ibm.com
Cc: linux-mm@kvack.org
Cc: linux-s390@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: nbd-general@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: openipmi-developer@lists.sourceforge.net
Cc: qla2xxx-upstream@qlogic.com
[ Consolidated the patches, twiddled the changelog. ]
This commit adds a maximally broken locking primitive in which
lock acquisition and release are both no-ops.
This commit adds the locking counterpart to rcutorture.
[ paulmck: Make n_lock_torture_errors and torture_spinlock static
as suggested by Fengguang Wu. ]
