path: root/kernel/module.c
2012-11-26module: fix out-by-one error in kallsymsRusty Russell
commit 59ef28b1f14899b10d6b2682c7057ca00a9a3f47 upstream. Masaki found and patched a kallsyms issue: the last symbol in a module's symtab wasn't transferred. This is because we manually copy the zero'th entry (which is always empty) then copy the rest in a loop starting at 1, though from src[0]. His fix was minimal, I prefer to rewrite the loops in more standard form. There are two loops: one to get the size, and one to copy. Make these identical: always count entry 0 and any defined symbol in an allocated non-init section. This bug exists since the following commit was introduced. module: reduce symbol table for loaded modules (v2) commit: 4a4962263f07d14660849ec134ee42b63e95ea9a LKML: http://lkml.org/lkml/2012/10/24/27 Reported-by: Masaki Kimura <masaki.kimura.kz@hitachi.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21module: taint kernel when lve module is loadedMatthew Garrett
commit c99af3752bb52ba3aece5315279a57a477edfaf1 upstream. Cloudlinux have a product called lve that includes a kernel module. This was previously GPLed but is now under a proprietary license, but the module continues to declare MODULE_LICENSE("GPL") and makes use of some EXPORT_SYMBOL_GPL symbols. Forcibly taint it in order to avoid this. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Alex Lyashkov <umka@cloudlinux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-26module: Remove module size limitSasha Levin
Module size was limited to 64MB, this was legacy limitation due to vmalloc() which was removed a while ago. Limiting module size to 64MB is both pointless and affects real world use cases. Cc: Tim Abbott <tim.abbott@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-26module: move __module_get and try_module_get() out of line.Steven Rostedt
With the preempt, tracepoint and everything, it's getting a bit chubby. For an Ubuntu-based config: Before: $ size -t `find * -name '*.ko'` | grep TOTAL 56199906 3870760 1606616 61677282 3ad1ee2 (TOTALS) $ size vmlinux text data bss dec hex filename 8509342 850368 3358720 12718430 c2115e vmlinux After: $ size -t `find * -name '*.ko'` | grep TOTAL 56183760 3867892 1606616 61658268 3acd49c (TOTALS) $ size vmlinux text data bss dec hex filename 8501842 849088 3358720 12709650 c1ef12 vmlinux Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (made all out-of-line)
2012-03-26params: <level>_initcall-like kernel parametersPawel Moll
This patch adds a set of macros that can be used to declare kernel parameters to be parsed _before_ initcalls at a chosen level are executed. We rename the now-unused "flags" field of struct kernel_param as the level. It's signed, for when we use this for early params as well, in future. Linker macro collating init calls had to be modified in order to add additional symbols between levels that are later used by the init code to split the calls into blocks. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-26module: add kernel param to force disable module loadDave Young
Sometimes we need to test a kernel of same version with code or config option changes. We already have sysctl to disable module load, but add a kernel parameter will be more convenient. Since modules_disabled is int, so here use bint type in core_param. TODO: make sysctl accept bool and change modules_disabled to bool Signed-off-by: Dave Young <dyoung@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-15error: implicit declaration of function 'module_flags_taint'Kevin Winchester
Recent changes to kernel/module.c caused the following compile error: kernel/module.c: In function ‘show_taint’: kernel/module.c:1024:2: error: implicit declaration of function ‘module_flags_taint’ [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors Correct this error by moving the definition of module_flags_taint outside of the #ifdef CONFIG_MODULE_UNLOAD section. Signed-off-by: Kevin Winchester <kjwinchester@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13modules: sysfs - export: taint, coresize, initsizeKay Sievers
Recent tools do not want to use /proc to retrieve module information. A few values are currently missing from sysfs to replace the information available in /proc/modules. This adds /sys/module/*/{coresize,initsize,taint} attributes. TAINT_PROPRIETARY_MODULE (P) and TAINT_OOT_MODULE (O) flags are both always shown now, and do no longer exclude each other, also in /proc/modules. Replace the open-coded sysfs attribute initializers with the __ATTR() macro. Add the new attributes to Documentation/ABI. Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-13module: replace DEBUGP with pr_debugJim Cromie
Use more flexible pr_debug. This allows: echo "module module +p" > /dbg/dynamic_debug/control to turn on debug messages when needed. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-13module: struct module_ref should contains long fieldsEric Dumazet
module_ref contains two "unsigned int" fields. Thats now too small, since some machines can open more than 2^32 files. Check commit 518de9b39e8 (fs: allow for more than 2^31 files) for reference. We can add an aligned(2 * sizeof(unsigned long)) attribute to force alloc_percpu() allocating module_ref areas in single cache lines. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Tejun Heo <tj@kernel.org> CC: Robin Holt <holt@sgi.com> CC: David Miller <davem@davemloft.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-13module: Fix performance regression on modules with large symbol tablesKevin Cernekee
Looking at /proc/kallsyms, one starts to ponder whether all of the extra strtab-related complexity in module.c is worth the memory savings. Instead of making the add_kallsyms() loop even more complex, I tried the other route of deleting the strmap logic and naively copying each string into core_strtab with no consideration for consolidating duplicates. Performance on an "already exists" insmod of nvidia.ko (runs add_kallsyms() but does not actually initialize the module): Original scheme: 1.230s With naive copying: 0.058s Extra space used: 35k (of a 408k module). Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <73defb5e4bca04a6431392cc341112b1@localhost>
2012-01-13module: Add comments describing how the "strmap" logic worksKevin Cernekee
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-07module,bug: Add TAINT_OOT_MODULE flag for modules not built in-treeBen Hutchings
Use of the GPL or a compatible licence doesn't necessarily make the code any good. We already consider staging modules to be suspect, and this should also be true for out-of-tree modules which may receive very little review. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Reviewed-by: Dave Jones <davej@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (patched oops-tracing.txt)
2011-11-07module: Enable dynamic debugging regardless of taintBen Hutchings
Dynamic debugging is currently disabled for tainted modules, except for TAINT_CRAP. This prevents use of dynamic debugging for out-of-tree modules once the next patch is applied. This condition was apparently intended to avoid a crash if a force- loaded module has an incompatible definition of dynamic debug structures. However, a administrator that forces us to load a module is claiming that it *is* compatible even though it fails our version checks. If they are mistaken, there are any number of ways the module could crash the system. As a side-effect, proprietary and other tainted modules can now use dynamic_debug. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-10Tracepoint: Dissociate from module mutexMathieu Desnoyers
Copy the information needed from struct module into a local module list held within tracepoint.c from within the module coming/going notifier. This vastly simplifies locking of tracepoint registration / unregistration, because we don't have to take the module mutex to register and unregister tracepoints anymore. Steven Rostedt ran into dependency problems related to modules mutex vs kprobes mutex vs ftrace mutex vs tracepoint mutex that seems to be hard to fix without removing this dependency between tracepoint and module mutex. (note: it should be investigated whether kprobes could benefit of being dissociated from the modules mutex too.) This also fixes module handling of tracepoint list iterators, because it was expecting the list to be sorted by pointer address. Given we have control on our own list now, it's OK to sort this list which has tracepoints as its only purpose. The reason why this sorting is required is to handle the fact that seq files (and any read() operation from user-space) cannot hold the tracepoint mutex across multiple calls, so list entries may vanish between calls. With sorting, the tracepoint iterator becomes usable even if the list don't contain the exact item pointed to by the iterator anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Jason Baron <jbaron@redhat.com> CC: Ingo Molnar <mingo@elte.hu> CC: Lai Jiangshan <laijs@cn.fujitsu.com> CC: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Thomas Gleixner <tglx@linutronix.de> CC: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20110810191839.GC8525@Krystal Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-24module: add /sys/module/<name>/uevent filesKay Sievers
Userspace wants to manage module parameters with udev rules. This currently only works for loaded modules, but not for built-in ones. To allow access to the built-in modules we need to re-trigger all module load events that happened before any userspace was running. We already do the same thing for all devices, subsystems(buses) and drivers. This adds the currently missing /sys/module/<name>/uevent files to all module entries. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (split & trivial fix)
2011-07-24module: change attr callbacks to take struct module_kobjectKay Sievers
This simplifies the next patch, where we have an attribute on a builtin module (ie. module == NULL). Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (split into 2)
2011-07-24modules: add default loader hook implementationsJonas Bonn
The module loader code allows architectures to hook into the code by providing a small number of entry points that each arch must implement. This patch provides __weakly linked generic implementations of these entry points for architectures that don't need to do anything special. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-23Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (970 commits) staging: usbip: replace usbip_u{dbg,err,info} and printk with dev_ and pr_ staging:iio: Trivial kconfig reorganization and uniformity improvements. staging:iio:documenation partial update. staging:iio: use pollfunc allocation helpers in remaining drivers. staging:iio:max1363 misc cleanups and use of for_each_bit_set to simplify event code spitting out. staging:iio: implement an iio_info structure to take some of the constant elements out of iio_dev. staging:iio:meter:ade7758: Use private data space from iio_allocate_device staging:iio:accel:lis3l02dq make write_reg_8 take value not a pointer to value. staging:iio: ring core cleanups + check if read_last available in lis3l02dq staging:iio:core cleanup: squash tiny wrappers and use dev_set_name to handle creation of event interface name. staging:iio: poll func allocation clean up. staging:iio:ad7780 trivial unused header cleanup. staging:iio:adc: AD7780: Use private data space from iio_allocate_device + trivial fixes staging:iio:adc:AD7780: Convert to new channel registration method staging:iio:adc: AD7606: Drop dev_data in favour of iio_priv() staging:iio:adc: AD7606: Consitently use indio_dev staging:iio: Rip out helper for software rings. staging:iio:adc:AD7298: Use private data space from iio_allocate_device staging:iio: rationalization of different buffer implementation hooks. staging:iio:imu:adis16400 avoid allocating rx, tx, and state separately from iio_dev. ... Fix up trivial conflicts in - drivers/staging/intel_sst/intelmid.c: patches applied in both branches - drivers/staging/rt2860/common/cmm_data_{pci,usb}.c: removed vs spelling - drivers/staging/usbip/vhci_sysfs.c: trivial header file inclusion
2011-05-19module: Use binary search in lookup_symbol()Alessio Igor Bogani
The function is_exported() with its helper function lookup_symbol() are used to verify if a provided symbol is effectively exported by the kernel or by the modules. Now that both have their symbols sorted we can replace a linear search with a binary search which provide a considerably speed-up. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19module: Use the binary search for symbols resolutionAlessio Igor Bogani
Takes advantage of the order and locates symbols using binary search. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Dirk Behme <dirk.behme@googlemail.com>
2011-05-19module: each_symbol_section instead of each_symbolRusty Russell
Instead of having a callback function for each symbol in the kernel, have a callback for each array of symbols. This eases the logic when we move to sorted symbols and binary search. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
2011-05-19module: split unset_section_ro_nx function.Jan Glauber
Split the unprotect function into a function per section to make the code more readable and add the missing static declaration. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19module: undo module RONX protection correctly.Jan Glauber
While debugging I stumbled over two problems in the code that protects module pages. First issue is that disabling the protection before freeing init or unload of a module is not symmetric with the enablement. For instance, if pages are set to RO the page range from module_core to module_core + core_ro_size is protected. If a module is unloaded the page range from module_core to module_core + core_size is set back to RW. So pages that were not set to RO are also changed to RW. This is not critical but IMHO it should be symmetric. Second issue is that while set_memory_rw & set_memory_ro are used for RO/RW changes only set_memory_nx is involved for NX/X. One would await that the inverse function is called when the NX protection should be removed, which is not the case here, unless I'm missing something. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19module: zero mod->init_ro_size after init is freed.Jan Glauber
Reset mod->init_ro_size to zero after the init part of a module is unloaded. Otherwise we need to check if module->init is NULL in the unprotect functions in the next patch. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19minor ANSI prototype sparse fixDaniel J Blueman
Fix function prototype to be ANSI-C compliant, consistent with other function prototypes, addressing a sparse warning. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-25modules: Enabled dynamic debugging for staging modulesRoland Vossen
Driver modules from the staging directory are marked 'tainted' by module.c. Subsequently, tainted modules are denied dynamic debugging. This is unwanted behavior, since staging modules should be able to use the dynamic debugging mechanism. Please merge this also into the staging-linus branch. Signed-off-by: Roland Vossen <rvossen@broadcom.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-22printk: use %pK for /proc/kallsyms and /proc/modulesKees Cook
In an effort to reduce kernel address leaks that might be used to help target kernel privilege escalation exploits, this patch uses %pK when displaying addresses in /proc/kallsyms, /proc/modules, and /sys/module/*/sections/*. Note that this changes %x to %p, so some legitimately 0 values in /proc/kallsyms would have changed from 00000000 to "(null)". To avoid this, "(null)" is not used when using the "K" format. Anything that was already successfully parsing "(null)" in addition to full hex digits should have no problem with this change. (Thanks to Joe Perches for the suggestion.) Due to the %x to %p, "void *" casts are needed since these addresses are already "unsigned long" everywhere internally, due to their starting life as ELF section offsets. Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: Eugene Teo <eugene@redhat.com> Cc: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-03tracepoints: Fix section alignment using pointer arrayMathieu Desnoyers
Make the tracepoints more robust, making them solid enough to handle compiler changes by not relying on anything based on compiler-specific behavior with respect to structure alignment. Implement an approach proposed by David Miller: use an array of const pointers to refer to the individual structures, and export this pointer array through the linker script rather than the structures per se. It will consume 32 extra bytes per tracepoint (24 for structure padding and 8 for the pointers), but are less likely to break due to compiler changes. History: commit 7e066fb8 tracepoints: add DECLARE_TRACE() and DEFINE_TRACE() added the aligned(32) type and variable attribute to the tracepoint structures to deal with gcc happily aligning statically defined structures on 32-byte multiples. One attempt was to use a 8-byte alignment for tracepoint structures by applying both the variable and type attribute to tracepoint structures definitions and declarations. It worked fine with gcc 4.5.1, but broke with gcc 4.4.4 and 4.4.5. The reason is that the "aligned" attribute only specify the _minimum_ alignment for a structure, leaving both the compiler and the linker free to align on larger multiples. Because tracepoint.c expects the structures to be placed as an array within each section, up-alignment cause NULL-pointer exceptions due to the extra unexpected padding. (this patch applies on top of -tip) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: David S. Miller <davem@davemloft.net> LKML-Reference: <20110126222622.GA10794@Krystal> CC: Frederic Weisbecker <fweisbec@gmail.com> CC: Ingo Molnar <mingo@elte.hu> CC: Thomas Gleixner <tglx@linutronix.de> CC: Andrew Morton <akpm@linux-foundation.org> CC: Peter Zijlstra <peterz@infradead.org> CC: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-12-23module: Move RO/NX module protection to after ftrace module updateSteven Rostedt
The commit: 84e1c6bb38eb318e456558b610396d9f1afaabf0 x86: Add RO/NX protection for loadable kernel modules Broke the function tracer with this output: ------------[ cut here ]------------ WARNING: at kernel/trace/ftrace.c:1014 ftrace_bug+0x114/0x171() Hardware name: Precision WorkStation 470 Modules linked in: i2c_core(+) Pid: 86, comm: modprobe Not tainted 2.6.37-rc2+ #68 Call Trace: [<ffffffff8104e957>] warn_slowpath_common+0x85/0x9d [<ffffffffa00026db>] ? __process_new_adapter+0x7/0x34 [i2c_core] [<ffffffffa00026db>] ? __process_new_adapter+0x7/0x34 [i2c_core] [<ffffffff8104e989>] warn_slowpath_null+0x1a/0x1c [<ffffffff810a9dfe>] ftrace_bug+0x114/0x171 [<ffffffffa00026db>] ? __process_new_adapter+0x7/0x34 [i2c_core] [<ffffffff810aa0db>] ftrace_process_locs+0x1ae/0x274 [<ffffffffa00026db>] ? __process_new_adapter+0x7/0x34 [i2c_core] [<ffffffff810aa29e>] ftrace_module_notify+0x39/0x44 [<ffffffff814405cf>] notifier_call_chain+0x37/0x63 [<ffffffff8106e054>] __blocking_notifier_call_chain+0x46/0x5b [<ffffffff8106e07d>] blocking_notifier_call_chain+0x14/0x16 [<ffffffff8107ffde>] sys_init_module+0x73/0x1f3 [<ffffffff8100acf2>] system_call_fastpath+0x16/0x1b ---[ end trace 2aff4f4ca53ec746 ]--- ftrace faulted on writing [<ffffffffa00026db>] __process_new_adapter+0x7/0x34 [i2c_core] The cause was that the module text was set to read only before ftrace could convert the calls to mcount to nops. Thus, the conversions failed due to not being able to write to the text locations. The simple fix is to move setting the module to read only after the module notifiers are called (where ftrace sets the module mcounts to nops). Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-12-23Merge commit 'v2.6.37-rc7' into x86/securityIngo Molnar
2010-11-18x86: Add RO/NX protection for loadable kernel modulesmatthieu castet
This patch is a logical extension of the protection provided by CONFIG_DEBUG_RODATA to LKMs. The protection is provided by splitting module_core and module_init into three logical parts each and setting appropriate page access permissions for each individual section: 1. Code: RO+X 2. RO data: RO+NX 3. RW data: RW+NX In order to achieve proper protection, layout_sections() have been modified to align each of the three parts mentioned above onto page boundary. Next, the corresponding page access permissions are set right before successful exit from load_module(). Further, free_module() and sys_init_module have been modified to set module_core and module_init as RW+NX right before calling module_free(). By default, the original section layout and access flags are preserved. When compiled with CONFIG_DEBUG_SET_MODULE_RONX=y, the patch will page-align each group of sections to ensure that each page contains only one type of content and will enforce RO/NX for each group of pages. -v1: Initial proof-of-concept patch. -v2: The patch have been re-written to reduce the number of #ifdefs and to make it architecture-agnostic. Code formatting has also been corrected. -v3: Opportunistic RO/NX protection is now unconditional. Section page-alignment is enabled when CONFIG_DEBUG_RODATA=y. -v4: Removed most macros and improved coding style. -v5: Changed page-alignment and RO/NX section size calculation -v6: Fixed comments. Restricted RO/NX enforcement to x86 only -v7: Introduced CONFIG_DEBUG_SET_MODULE_RONX, added calls to set_all_modules_text_rw() and set_all_modules_text_ro() in ftrace -v8: updated for compatibility with linux 2.6.33-rc5 -v9: coding style fixes -v10: more coding style fixes -v11: minor adjustments for -tip -v12: minor adjustments for v2.6.35-rc2-tip -v13: minor adjustments for v2.6.37-rc1-tip Signed-off-by: Siarhei Liakh <sliakh.lkml@gmail.com> Signed-off-by: Xuxian Jiang <jiang@cs.ncsu.edu> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Andi Kleen <ak@muc.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CE2F914.9070106@free.fr> [ minor cleanliness edits, -v14: build failure fix ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-10tracing: Fix module use of trace_bprintk()Steven Rostedt
On use of trace_printk() there's a macro that determines if the format is static or a variable. If it is static, it defaults to __trace_bprintk() otherwise it uses __trace_printk(). A while ago, Lai Jiangshan added __trace_bprintk(). In that patch, we discussed a way to allow modules to use it. The difference between __trace_bprintk() and __trace_printk() is that for faster processing, just the format and args are stored in the trace instead of running it through a sprintf function. In order to do this, the format used by the __trace_bprintk() had to be persistent. See commit 1ba28e02a18cbdbea123836f6c98efb09cbf59ec The problem comes with trace_bprintk() where the module is unloaded. The pointer left in the buffer is still pointing to the format. To solve this issue, the formats in the module were copied into kernel core. If the same format was used, they would use the same copy (to prevent memory leak). This all worked well until we tried to merge everything. At the time this was written, Lai Jiangshan, Frederic Weisbecker, Ingo Molnar and myself were all touching the same code. When this was merged, we lost the part of it that was in module.c. This kept out the copying of the formats and unloading the module could cause bad pointers left in the ring buffer. This patch adds back (with updates required for current kernel) the module code that sets up the necessary pointers. Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-27(trivial) Fix compiler warning in kernel/modules.cMichał Mirosław
Building with CONFIG_KALLSYMS=n gives following warning: /mnt/src/linux-git/kernel/module.c: In function ‘post_relocation’: /mnt/src/linux-git/kernel/module.c:2534:2: warning: passing argument 2 of ‘add_kallsyms’ discards qualifiers from pointer target type /mnt/src/linux-git/kernel/module.c:2038:13: note: expected ‘struct load_info *’ but argument is of type ‘const struct load_info *’ Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-08Merge commit 'v2.6.36-rc7' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/module.c Merge reason: Resolve the conflict, pick up fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22jump label: Base patch for jump labelJason Baron
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline assembly gcc mechanism, we can now branch to labels from an 'asm goto' statment. This allows us to create a 'no-op' fastpath, which can subsequently be patched with a jump to the slowpath code. This is useful for code which might be rarely used, but which we'd like to be able to call, if needed. Tracepoints are the current usecase that these are being implemented for. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com> [ cleaned up some formating ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-05module: cleanup comments, remove noinlineRusty Russell
On my (32-bit x86) machine, sys_init_module() uses 124 bytes of stack once load_module() is inlined. This effectively reverts ffb4ba76 which inlined it due to stack pressure. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: group post-relocation functions into post_relocation()Rusty Russell
This simply hoists more code out of load_module; we also put the identification of the extable and dynamic debug table in with the others in find_module_sections(). We move the taint check to the actual add/remove of the dynamic debug info: this is certain (find_module_sections is too early). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Yehuda Sadeh <yehuda@hq.newdream.net>
2010-08-05module: move module args strndup_user to just before useRusty Russell
Instead of copying and allocating the args and storing it in load_info, we can just allocate them right before we need them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: pass load_info into other functionsRusty Russell
Pass the struct load_info into all the other functions in module loading. This neatens things and makes them more consistent. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: fix sysfs cleanup for !CONFIG_SYSFSRusty Russell
Restore the stub module_remove_modinfo_attrs, remove the now-unused !CONFIG_SYSFS module_sysfs_init. Also, rename mod_kobject_remove() to mod_sysfs_teardown() as it is the logical counterpart to mod_sysfs_setup now. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: sysfs cleanupRusty Russell
We change the sysfs functions to take struct load_info, and call them all in mod_sysfs_setup(). We also clean up the #ifdefs a little. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: layout_and_allocateRusty Russell
layout_and_allocate() does everything up to and including the final struct module placement inside the allocated module memory. We have to store the symbol layout information in our struct load_info though. This avoids the nasty code we had before where 'mod' pointed first to the version inside the temporary allocation containing the entire file, then later was moved to point to the real struct module: now the main code only ever sees the final module address. (Includes fix for the Tony Luck-found Linus-diagnosed failure path error). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: fix crash in get_ksymbol() when oopsing in module initRusty Russell
Andrew had the sole pleasure of tickling this bug in linux-next; when we set up "info->strtab" it's pointing into the temporary copy of the module. For most uses that is fine, but kallsyms keeps a pointer around during module load (inside mod->strtab). If we oops for some reason inside a module's init function, kallsyms will use the mod->strtab pointer into the now-freed temporary module copy. (Later oopses work fine: after init we overwrite mod->strtab to point to a compacted core-only strtab). Reported-by: Andrew "Grumpy" Morton <akpm@linux-foundation.org> Signed-off-by: Rusty "Buggy" Russell <rusty@rustcorp.com.au> Tested-by: Andrew "Happy" Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: kallsyms functions take struct load_infoRusty Russell
Simple refactor causes us to lift struct definition to top of file. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05module: refactor out section header rewriting: FIX modversionsRusty Russell
We can't do the find_sec after removing the SHF_ALLOC flags; it won't find the sections. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
