path: root/kernel/module.c
2014-11-14modules, lock around setting of MODULE_STATE_UNFORMEDPrarit Bhargava
commit d3051b489aa81ca9ba62af366149ef42b8dae97c upstream. A panic was seen in the following sitation. There are two threads running on the system. The first thread is a system monitoring thread that is reading /proc/modules. The second thread is loading and unloading a module (in this example I'm using my simple dummy-module.ko). Note, in the "real world" this occurred with the qlogic driver module. When doing this, the following panic occurred: ------------[ cut here ]------------ kernel BUG at kernel/module.c:3739! invalid opcode: 0000 [#1] SMP Modules linked in: binfmt_misc sg nfsv3 rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw igb gf128mul glue_helper iTCO_wdt iTCO_vendor_support ablk_helper ptp sb_edac cryptd pps_core edac_core shpchp i2c_i801 pcspkr wmi lpc_ich ioatdma mfd_core dca ipmi_si nfsd ipmi_msghandler auth_rpcgss nfs_acl lockd sunrpc xfs libcrc32c sr_mod cdrom sd_mod crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt i2c_algo_bit drm_kms_helper ttm isci drm libsas ahci libahci scsi_transport_sas libata i2c_core dm_mirror dm_region_hash dm_log dm_mod [last unloaded: dummy_module] CPU: 37 PID: 186343 Comm: cat Tainted: GF O-------------- 3.10.0+ #7 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013 task: ffff8807fd2d8000 ti: ffff88080fa7c000 task.ti: ffff88080fa7c000 RIP: 0010:[<ffffffff810d64c5>] [<ffffffff810d64c5>] module_flags+0xb5/0xc0 RSP: 0018:ffff88080fa7fe18 EFLAGS: 00010246 RAX: 0000000000000003 RBX: ffffffffa03b5200 RCX: 0000000000000000 RDX: 0000000000001000 RSI: ffff88080fa7fe38 RDI: ffffffffa03b5000 RBP: ffff88080fa7fe28 R08: 0000000000000010 R09: 0000000000000000 R10: 0000000000000000 R11: 000000000000000f R12: ffffffffa03b5000 R13: ffffffffa03b5008 R14: ffffffffa03b5200 R15: ffffffffa03b5000 FS: 00007f6ae57ef740(0000) GS:ffff88101e7a0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000404f70 CR3: 0000000ffed48000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffffffffa03b5200 ffff8810101e4800 ffff88080fa7fe70 ffffffff810d666c ffff88081e807300 000000002e0f2fbf 0000000000000000 ffff88100f257b00 ffffffffa03b5008 ffff88080fa7ff48 ffff8810101e4800 ffff88080fa7fee0 Call Trace: [<ffffffff810d666c>] m_show+0x19c/0x1e0 [<ffffffff811e4d7e>] seq_read+0x16e/0x3b0 [<ffffffff812281ed>] proc_reg_read+0x3d/0x80 [<ffffffff811c0f2c>] vfs_read+0x9c/0x170 [<ffffffff811c1a58>] SyS_read+0x58/0xb0 [<ffffffff81605829>] system_call_fastpath+0x16/0x1b Code: 48 63 c2 83 c2 01 c6 04 03 29 48 63 d2 eb d9 0f 1f 80 00 00 00 00 48 63 d2 c6 04 13 2d 41 8b 0c 24 8d 50 02 83 f9 01 75 b2 eb cb <0f> 0b 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 41 RIP [<ffffffff810d64c5>] module_flags+0xb5/0xc0 RSP <ffff88080fa7fe18> Consider the two processes running on the system. CPU 0 (/proc/modules reader) CPU 1 (loading/unloading module) CPU 0 opens /proc/modules, and starts displaying data for each module by traversing the modules list via fs/seq_file.c:seq_open() and fs/seq_file.c:seq_read(). For each module in the modules list, seq_read does op->start() <-- this is a pointer to m_start() op->show() <- this is a pointer to m_show() op->stop() <-- this is a pointer to m_stop() The m_start(), m_show(), and m_stop() module functions are defined in kernel/module.c. The m_start() and m_stop() functions acquire and release the module_mutex respectively. ie) When reading /proc/modules, the module_mutex is acquired and released for each module. m_show() is called with the module_mutex held. It accesses the module struct data and attempts to write out module data. It is in this code path that the above BUG_ON() warning is encountered, specifically m_show() calls static char *module_flags(struct module *mod, char *buf) { int bx = 0; BUG_ON(mod->state == MODULE_STATE_UNFORMED); ... The other thread, CPU 1, in unloading the module calls the syscall delete_module() defined in kernel/module.c. The module_mutex is acquired for a short time, and then released. free_module() is called without the module_mutex. free_module() then sets mod->state = MODULE_STATE_UNFORMED, also without the module_mutex. Some additional code is called and then the module_mutex is reacquired to remove the module from the modules list: /* Now we can delete it from the lists */ mutex_lock(&module_mutex); stop_machine(__unlink_module, mod, NULL); mutex_unlock(&module_mutex); This is the sequence of events that leads to the panic. CPU 1 is removing dummy_module via delete_module(). It acquires the module_mutex, and then releases it. CPU 1 has NOT set dummy_module->state to MODULE_STATE_UNFORMED yet. CPU 0, which is reading the /proc/modules, acquires the module_mutex and acquires a pointer to the dummy_module which is still in the modules list. CPU 0 calls m_show for dummy_module. The check in m_show() for MODULE_STATE_UNFORMED passed for dummy_module even though it is being torn down. Meanwhile CPU 1, which has been continuing to remove dummy_module without holding the module_mutex, now calls free_module() and sets dummy_module->state to MODULE_STATE_UNFORMED. CPU 0 now calls module_flags() with dummy_module and ... static char *module_flags(struct module *mod, char *buf) { int bx = 0; BUG_ON(mod->state == MODULE_STATE_UNFORMED); and BOOM. Acquire and release the module_mutex lock around the setting of MODULE_STATE_UNFORMED in the teardown path, which should resolve the problem. Testing: In the unpatched kernel I can panic the system within 1 minute by doing while (true) do insmod dummy_module.ko; rmmod dummy_module.ko; done and while (true) do cat /proc/modules; done in separate terminals. In the patched kernel I was able to run just over one hour without seeing any issues. I also verified the output of panic via sysrq-c and the output of /proc/modules looks correct for all three states for the dummy_module. dummy_module 12661 0 - Unloading 0xffffffffa03a5000 (OE-) dummy_module 12661 0 - Live 0xffffffffa03bb000 (OE) dummy_module 14015 1 - Loading 0xffffffffa03a5000 (OE+) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07module: remove warning about waiting module removal.Rusty Russell
commit 79465d2fd48e68940c2bdecddbdecd45bbba06fe upstream. We remove the waiting module removal in commit 3f2b9c9cdf38 (September 2013), but it turns out that modprobe in kmod (< version 16) was asking for waiting module removal. No one noticed since modprobe would check for 0 usage immediately before trying to remove the module, and the race is unlikely. However, it means that anyone running old (but not ancient) kmod versions is hitting the printk designed to see if anyone was running "rmmod -w". All reports so far have been false positives, so remove the warning. Fixes: 3f2b9c9cdf389e303b2273679af08aab5f153517 Reported-by: Valerio Vanni <valerio.vanni@inwind.it> Cc: Elliott, Robert (Server Storage) <Elliott@hp.com> Acked-by: Lucas De Marchi <lucas.de.marchi@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ftrace/module: Hardcode ftrace_module_init() call into load_module()Steven Rostedt (Red Hat)
commit a949ae560a511fe4e3adf48fa44fefded93e5c2b upstream. A race exists between module loading and enabling of function tracer. CPU 1 CPU 2 ----- ----- load_module() module->state = MODULE_STATE_COMING register_ftrace_function() mutex_lock(&ftrace_lock); ftrace_startup() update_ftrace_function(); ftrace_arch_code_modify_prepare() set_all_module_text_rw(); <enables-ftrace> ftrace_arch_code_modify_post_process() set_all_module_text_ro(); [ here all module text is set to RO, including the module that is loading!! ] blocking_notifier_call_chain(MODULE_STATE_COMING); ftrace_init_module() [ tries to modify code, but it's RO, and fails! ftrace_bug() is called] When this race happens, ftrace_bug() will produces a nasty warning and all of the function tracing features will be disabled until reboot. The simple solution is to treate module load the same way the core kernel is treated at boot. To hardcode the ftrace function modification of converting calls to mcount into nops. This is done in init/main.c there's no reason it could not be done in load_module(). This gives a better control of the changes and doesn't tie the state of the module to its notifiers as much. Ftrace is special, it needs to be treated as such. The reason this would work, is that the ftrace_module_init() would be called while the module is in MODULE_STATE_UNFORMED, which is ignored by the set_all_module_text_ro() call. Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-21module: Add missing newline in printk call.Tetsuo Handa
Add missing \n and also follow commit bddb12b3 "kernel/module.c: use pr_foo()". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-11-15Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Mainly boring here, too. rmmod --wait finally removed, though" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix bogus 'exported twice' warnings. init: fix in-place parameter modification regression asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visible kernel: add support for init_array constructors modpost: Optionally ignore secondary errors seen if a single module build fails module: remove rmmod --wait option.
2013-11-13kernel/module.c: use pr_foo()Andrew Morton
kernel/module.c uses a mix of printk(KERN_foo and pr_foo(). Convert it all to pr_foo and make the offered cleanups. Not sure what to do about the printk(KERN_DEFAULT). We don't have a pr_default(). Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Cc: Frantisek Hrbata <fhrbata@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-17kernel: add support for init_array constructorsFrantisek Hrbata
This adds the .init_array section as yet another section with constructors. This is needed because gcc could add __gcov_init calls to .init_array or .ctors section, depending on gcc (and binutils) version . v2: - reuse mod->ctors for .init_array section for modules, because gcc uses .ctors or .init_array, but not both at the same time v3: - fail to load if that does happen somehow. Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-09-23module: remove rmmod --wait option.Rusty Russell
The option to wait for a module reference count to reach zero was in the initial module implementation, but it was never supported in modprobe (you had to use rmmod --wait). After discussion with Lucas, It has been deprecated (with a 10 second sleep) in kmod for the last year. This finally removes it: the flag will evoke a printk warning and a normal (non-blocking) remove attempt. Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "Unfortunately, this merge window it'll have a be a lot of small piles - my fault, actually, for not keeping #for-next in anything that would resemble a sane shape ;-/ This pile: assorted fixes (the first 3 are -stable fodder, IMO) and cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last components) + several long-standing patches from various folks. There definitely will be a lot more (starting with Miklos' check_submount_and_drop() series)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) direct-io: Handle O_(D)SYNC AIO direct-io: Implement generic deferred AIO completions add formats for dentry/file pathnames kvm eventfd: switch to fdget powerpc kvm: use fdget switch fchmod() to fdget switch epoll_ctl() to fdget switch copy_module_from_fd() to fdget git simplify nilfs check for busy subtree ibmasmfs: don't bother passing superblock when not needed don't pass superblock to hypfs_{mkdir,create*} don't pass superblock to hypfs_diag_create_files don't pass superblock to hypfs_vm_create_files() oprofile: get rid of pointless forward declarations of struct super_block oprofilefs_create_...() do not need superblock argument oprofilefs_mkdir() doesn't need superblock argument don't bother with passing superblock to oprofile_create_stats_files() oprofile: don't bother with passing superblock to ->create_files() don't bother passing sb to oprofile_create_files() coh901318: don't open-code simple_read_from_buffer() ...
2013-09-03switch copy_module_from_fd() to fdgetAl Viro
2013-09-03module: Fix mod->mkobj.kobj potentially freed too earlyLi Zhong
DEBUG_KOBJECT_RELEASE helps to find the issue attached below. After some investigation, it seems the reason is: The mod->mkobj.kobj(ffffffffa01600d0 below) is freed together with mod itself in free_module(). However, its children still hold references to it, as the delay caused by DEBUG_KOBJECT_RELEASE. So when the child(holders below) tries to decrease the reference count to its parent in kobject_del(), BUG happens as it tries to access already freed memory. This patch tries to fix it by waiting for the mod->mkobj.kobj to be really released in the module removing process (and some error code paths). [ 1844.175287] kobject: 'holders' (ffff88007c1f1600): kobject_release, parent ffffffffa01600d0 (delayed) [ 1844.178991] kobject: 'notes' (ffff8800370b2a00): kobject_release, parent ffffffffa01600d0 (delayed) [ 1845.180118] kobject: 'holders' (ffff88007c1f1600): kobject_cleanup, parent ffffffffa01600d0 [ 1845.182130] kobject: 'holders' (ffff88007c1f1600): auto cleanup kobject_del [ 1845.184120] BUG: unable to handle kernel paging request at ffffffffa01601d0 [ 1845.185026] IP: [<ffffffff812cda81>] kobject_put+0x11/0x60 [ 1845.185026] PGD 1a13067 PUD 1a14063 PMD 7bd30067 PTE 0 [ 1845.185026] Oops: 0000 [#1] PREEMPT [ 1845.185026] Modules linked in: xfs libcrc32c [last unloaded: kprobe_example] [ 1845.185026] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G O 3.11.0-rc6-next-20130819+ #1 [ 1845.185026] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 1845.185026] Workqueue: events kobject_delayed_cleanup [ 1845.185026] task: ffff88007ca51f00 ti: ffff88007ca5c000 task.ti: ffff88007ca5c000 [ 1845.185026] RIP: 0010:[<ffffffff812cda81>] [<ffffffff812cda81>] kobject_put+0x11/0x60 [ 1845.185026] RSP: 0018:ffff88007ca5dd08 EFLAGS: 00010282 [ 1845.185026] RAX: 0000000000002000 RBX: ffffffffa01600d0 RCX: ffffffff8177d638 [ 1845.185026] RDX: ffff88007ca5dc18 RSI: 0000000000000000 RDI: ffffffffa01600d0 [ 1845.185026] RBP: ffff88007ca5dd18 R08: ffffffff824e9810 R09: ffffffffffffffff [ 1845.185026] R10: ffff8800ffffffff R11: dead4ead00000001 R12: ffffffff81a95040 [ 1845.185026] R13: ffff88007b27a960 R14: ffff88007c1f1600 R15: 0000000000000000 [ 1845.185026] FS: 0000000000000000(0000) GS:ffffffff81a23000(0000) knlGS:0000000000000000 [ 1845.185026] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1845.185026] CR2: ffffffffa01601d0 CR3: 0000000037207000 CR4: 00000000000006b0 [ 1845.185026] Stack: [ 1845.185026] ffff88007c1f1600 ffff88007c1f1600 ffff88007ca5dd38 ffffffff812cdb7e [ 1845.185026] 0000000000000000 ffff88007c1f1640 ffff88007ca5dd68 ffffffff812cdbfe [ 1845.185026] ffff88007c974800 ffff88007c1f1640 ffff88007ff61a00 0000000000000000 [ 1845.185026] Call Trace: [ 1845.185026] [<ffffffff812cdb7e>] kobject_del+0x2e/0x40 [ 1845.185026] [<ffffffff812cdbfe>] kobject_delayed_cleanup+0x6e/0x1d0 [ 1845.185026] [<ffffffff81063a45>] process_one_work+0x1e5/0x670 [ 1845.185026] [<ffffffff810639e3>] ? process_one_work+0x183/0x670 [ 1845.185026] [<ffffffff810642b3>] worker_thread+0x113/0x370 [ 1845.185026] [<ffffffff810641a0>] ? rescuer_thread+0x290/0x290 [ 1845.185026] [<ffffffff8106bfba>] kthread+0xda/0xe0 [ 1845.185026] [<ffffffff814ff0f0>] ? _raw_spin_unlock_irq+0x30/0x60 [ 1845.185026] [<ffffffff8106bee0>] ? kthread_create_on_node+0x130/0x130 [ 1845.185026] [<ffffffff8150751a>] ret_from_fork+0x7a/0xb0 [ 1845.185026] [<ffffffff8106bee0>] ? kthread_create_on_node+0x130/0x130 [ 1845.185026] Code: 81 48 c7 c7 28 95 ad 81 31 c0 e8 9b da 01 00 e9 4f ff ff ff 66 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb 48 83 ec 08 48 85 ff 74 1d <f6> 87 00 01 00 00 01 74 1e 48 8d 7b 38 83 6b 38 01 0f 94 c0 84 [ 1845.185026] RIP [<ffffffff812cda81>] kobject_put+0x11/0x60 [ 1845.185026] RSP <ffff88007ca5dd08> [ 1845.185026] CR2: ffffffffa01601d0 [ 1845.185026] ---[ end trace 49a70afd109f5653 ]--- Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-08-20kernel/module.c: use scnprintf() instead of sprintf()Chen Gang
For some strings, they are permitted to be larger than PAGE_SIZE, so need use scnprintf() instead of sprintf(), or it will cause issue. One case is: if a module version is crazy defined (length more than PAGE_SIZE), 'modinfo' command is still OK (print full contents), but for "cat /sys/modules/'modname'/version", will cause issue in kernel. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-08-20module: Add NOARG flag for ops with param_set_bool_enable_only() set functionSteven Rostedt
The ops that uses param_set_bool_enable_only() as its set function can easily handle being used without an argument. There's no reason to fail the loading of the module if it does not have one. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-07-10Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Nothing interesting. Except the most embarrassing bugfix ever. But let's ignore that" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: cleanup call chain. module: do percpu allocation after uniqueness check. No, really! modules: don't fail to load on unknown parameters. ABI: Clarify when /sys/module/MODULENAME is created There is no /sys/parameters module: don't modify argument of module_kallsyms_lookup_name()
2013-07-03module: cleanup call chain.Rusty Russell
Fold alloc_module_percpu into percpu_modalloc(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-07-03module: do percpu allocation after uniqueness check. No, really!Rusty Russell
v3.8-rc1-5-g1fb9341 was supposed to stop parallel kvm loads exhausting percpu memory on large machines: Now we have a new state MODULE_STATE_UNFORMED, we can insert the module into the list (and thus guarantee its uniqueness) before we allocate the per-cpu region. In my defence, it didn't actually say the patch did this. Just that we "can". This patch actually *does* it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Jim Hull <jim.hull@hp.com> Cc: stable@kernel.org # 3.8
2013-07-02modules: don't fail to load on unknown parameters.Rusty Russell
Although parameters are supposed to be part of the kernel API, experimental parameters are often removed. In addition, downgrading a kernel might cause previously-working modules to fail to load. On balance, it's probably better to warn, and load the module anyway. This may let through a typo, but at least the logs will show it. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-07-02module: don't modify argument of module_kallsyms_lookup_name()Mathias Krause
If we pass a pointer to a const string in the form "module:symbol" module_kallsyms_lookup_name() will try to split the string at the colon, i.e., will try to modify r/o data. That will, in fact, fail on a kernel with enabled CONFIG_DEBUG_RODATA. Avoid modifying the passed string in module_kallsyms_lookup_name(), modify find_module_all() instead to pass it the module name length. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-05-17kmemleak: No need for scanning specific module sectionsSteven Rostedt
As kmemleak now scans all module sections that are allocated, writable and non executable, there's no need to scan individual sections that might reference data. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2013-05-17kmemleak: Scan all allocated, writeable and not executable module sectionsSteven Rostedt
Instead of just picking data sections by name (names that start with .data, .bss or .ref.data), use the section flags and scan all sections that are allocated, writable and not executable. Which should cover all sections of a module that might reference data. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> [catalin.marinas@arm.com: removed unused 'name' variable] [catalin.marinas@arm.com: collapsed 'if' blocks] Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2013-04-17module: don't unlink the module until we've removed all exposure.Rusty Russell
Otherwise we get a race between unload and reload of the same module: the new module doesn't see the old one in the list, but then fails because it can't register over the still-extant entries in sysfs: [ 103.981925] ------------[ cut here ]------------ [ 103.986902] WARNING: at fs/sysfs/dir.c:536 sysfs_add_one+0xab/0xd0() [ 103.993606] Hardware name: CrownBay Platform [ 103.998075] sysfs: cannot create duplicate filename '/module/pch_gbe' [ 104.004784] Modules linked in: pch_gbe(+) [last unloaded: pch_gbe] [ 104.011362] Pid: 3021, comm: modprobe Tainted: G W 3.9.0-rc5+ #5 [ 104.018662] Call Trace: [ 104.021286] [<c103599d>] warn_slowpath_common+0x6d/0xa0 [ 104.026933] [<c1168c8b>] ? sysfs_add_one+0xab/0xd0 [ 104.031986] [<c1168c8b>] ? sysfs_add_one+0xab/0xd0 [ 104.037000] [<c1035a4e>] warn_slowpath_fmt+0x2e/0x30 [ 104.042188] [<c1168c8b>] sysfs_add_one+0xab/0xd0 [ 104.046982] [<c1168dbe>] create_dir+0x5e/0xa0 [ 104.051633] [<c1168e78>] sysfs_create_dir+0x78/0xd0 [ 104.056774] [<c1262bc3>] kobject_add_internal+0x83/0x1f0 [ 104.062351] [<c126daf6>] ? kvasprintf+0x46/0x60 [ 104.067231] [<c1262ebd>] kobject_add_varg+0x2d/0x50 [ 104.072450] [<c1262f07>] kobject_init_and_add+0x27/0x30 [ 104.078075] [<c1089240>] mod_sysfs_setup+0x80/0x540 [ 104.083207] [<c1260851>] ? module_bug_finalize+0x51/0xc0 [ 104.088720] [<c108ab29>] load_module+0x1429/0x18b0 We can teardown sysfs first, then to be sure, put the state in MODULE_STATE_UNFORMED so it's ignored while we deconstruct it. Reported-by: Veaceslav Falico <vfalico@redhat.com> Tested-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-20module: fix symbol versioning with symbol prefixesJames Hogan
Fix symbol versioning on architectures with symbol prefixes. Although the build was free from warnings the actual modules still wouldn't load as the ____versions table contained unprefixed symbol names, which were being compared against the prefixed symbol names when checking the symbol versions. This is fixed by modifying modpost to add the symbol prefix to the ____versions table it outputs (Modules.symvers still contains unprefixed symbol names). The check_modstruct_version() function is also fixed as it checks the version of the unprefixed "module_layout" symbol which would no longer work. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jonathan Kliegman <kliegs@chromium.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (use VMLINUX_SYMBOL_STR)
2013-03-15CONFIG_SYMBOL_PREFIX: cleanup.Rusty Russell
We have CONFIG_SYMBOL_PREFIX, which three archs define to the string "_". But Al Viro broke this in "consolidate cond_syscall and SYSCALL_ALIAS declarations" (in linux-next), and he's not the first to do so. Using CONFIG_SYMBOL_PREFIX is awkward, since we usually just want to prefix it so something. So various places define helpers which are defined to nothing if CONFIG_SYMBOL_PREFIX isn't set: 1) include/asm-generic/unistd.h defines __SYMBOL_PREFIX. 2) include/asm-generic/vmlinux.lds.h defines VMLINUX_SYMBOL(sym) 3) include/linux/export.h defines MODULE_SYMBOL_PREFIX. 4) include/linux/kernel.h defines SYMBOL_PREFIX (which differs from #7) 5) kernel/modsign_certificate.S defines ASM_SYMBOL(sym) 6) scripts/modpost.c defines MODULE_SYMBOL_PREFIX 7) scripts/Makefile.lib defines SYMBOL_PREFIX on the commandline if CONFIG_SYMBOL_PREFIX is set, so that we have a non-string version for pasting. (arch/h8300/include/asm/linkage.h defines SYMBOL_NAME(), too). Let's solve this properly: 1) No more generic prefix, just CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX. 2) Make linux/export.h usable from asm. 3) Define VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR(). 4) Make everyone use them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> (metag)
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26switch vfs_getattr() to struct pathAl Viro
2013-01-21module: clean up load_module a little more.Rusty Russell
1fb9341ac34825aa40354e74d9a2c69df7d2c304 made our locking in load_module more complicated: we grab the mutex once to insert the module in the list, then again to upgrade it once it's formed. Since the locking is self-contained, it's neater to do this in separate functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-21taint: add explicit flag to show whether lock dep is still OK.Rusty Russell
Fix up all callers as they were before, with make one change: an unsigned module taints the kernel, but doesn't turn off lockdep. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-21module: printk message when module signature fail taints kernel.Rusty Russell
Reported-by: Chris Samuel <chris@csamuel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-20module: fix missing module_mutex unlockLinus Torvalds
Commit 1fb9341ac348 ("module: put modules in list much earlier") moved some of the module initialization code around, and in the process changed the exit paths too. But for the duplicate export symbol error case the change made the ddebug_cleanup path jump to after the module mutex unlock, even though it happens with the mutex held. Rusty has some patches to split this function up into some helper functions, hopefully the mess of complex goto targets will go away eventually. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-20Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module fixes and a virtio block fix from Rusty Russell: "Various minor fixes, but a slightly more complex one to fix the per-cpu overload problem introduced recently by kvm id changes." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: put modules in list much earlier. module: add new state MODULE_STATE_UNFORMED. module: prevent warning when finit_module a 0 sized file virtio-blk: Don't free ida when disk is in use
2013-01-16module, async: async_synchronize_full() on module init iff async is usedTejun Heo
If the default iosched is built as module, the kernel may deadlock while trying to load the iosched module on device probe if the probing was running off async. This is because async_synchronize_full() at the end of module init ends up waiting for the async job which initiated the module loading. async A modprobe 1. finds a device 2. registers the block device 3. request_module(default iosched) 4. modprobe in userland 5. load and init module 6. async_synchronize_full() Async A waits for modprobe to finish in request_module() and modprobe waits for async A to finish in async_synchronize_full(). Because there's no easy to track dependency once control goes out to userland, implementing properly nested flushing is difficult. For now, make module init perform async_synchronize_full() iff module init has queued async jobs as suggested by Linus. This avoids the described deadlock because iosched module doesn't use async and thus wouldn't invoke async_synchronize_full(). This is hacky and incomplete. It will deadlock if async module loading nests; however, this works around the known problem case and seems to be the best of bad options. For more details, please refer to the following thread. http://thread.gmane.org/gmane.linux.kernel/1420814 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alex Riesen <raa.lkml@gmail.com> Tested-by: Ming Lei <ming.lei@canonical.com> Tested-by: Alex Riesen <raa.lkml@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-12module: put modules in list much earlier.Rusty Russell
Prarit's excellent bug report: > In recent Fedora releases (F17 & F18) some users have reported seeing > messages similar to > > [ 15.478160] kvm: Could not allocate 304 bytes percpu data > [ 15.478174] PERCPU: allocation failed, size=304 align=32, alloc from > reserved chunk failed > > during system boot. In some cases, users have also reported seeing this > message along with a failed load of other modules. > > What is happening is systemd is loading an instance of the kvm module for > each cpu found (see commit e9bda3b). When the module load occurs the kernel > currently allocates the modules percpu data area prior to checking to see > if the module is already loaded or is in the process of being loaded. If > the module is already loaded, or finishes load, the module loading code > releases the current instance's module's percpu data. Now we have a new state MODULE_STATE_UNFORMED, we can insert the module into the list (and thus guarantee its uniqueness) before we allocate the per-cpu region. Reported-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Prarit Bhargava <prarit@redhat.com>
2013-01-12module: add new state MODULE_STATE_UNFORMED.Rusty Russell
You should never look at such a module, so it's excised from all paths which traverse the modules list. We add the state at the end, to avoid gratuitous ABI break (ksplice). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-03module: prevent warning when finit_module a 0 sized fileSasha Levin
If we try to finit_module on a file sized 0 bytes vmalloc will scream and spit out a warning. Since modules have to be bigger than 0 bytes anyways we can just check that beforehand and avoid the warning. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-17kernel: remove reference to feature-removal-schedule.txtTao Ma
In commit 9c0ece069b32 ("Get rid of Documentation/feature-removal.txt"), Linus removed feature-removal-schedule.txt from Documentation, but there is still some reference to this file. So remove them. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-14modules: don't hand 0 to vmalloc.Rusty Russell
In commit d0a21265dfb5fa8a David Rientjes unified various archs' module_alloc implementation (including x86) and removed the graduitous shortcut for size == 0. Then, in commit de7d2b567d040e3b, Joe Perches added a warning for zero-length vmallocs, which can happen without kallsyms on modules with no init sections (eg. zlib_deflate). Fix this once and for all; the module code has to handle zero length anyway, so get it right at the caller and remove the now-gratuitous checks within the arch-specific module_alloc implementations. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42608 Reported-by: Conrad Kostecki <ConiKost@gmx.de> Cc: David Rientjes <rientjes@google.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-14module: Remove a extra null character at the top of module->strtab.Satoru Takeuchi
There is a extra null character('\0') at the top of module->strtab for each module. Commit 59ef28b introduced this bug and this patch fixes it. Live dump log of the current linus git kernel(HEAD is 2844a4870): ============================================================================ crash> mod | grep loop ffffffffa01db0a0 loop 16689 (not loaded) [CONFIG_KALLSYMS] crash> module.core_symtab ffffffffa01db0a0 core_symtab = 0xffffffffa01db320crash> rd 0xffffffffa01db320 12 ffffffffa01db320: 0000005500000001 0000000000000000 ....U........... ffffffffa01db330: 0000000000000000 0002007400000002 ............t... ffffffffa01db340: ffffffffa01d8000 0000000000000038 ........8....... ffffffffa01db350: 001a00640000000e ffffffffa01daeb0 ....d........... ffffffffa01db360: 00000000000000a0 0002007400000019 ............t... ffffffffa01db370: ffffffffa01d8068 000000000000001b h............... crash> module.core_strtab ffffffffa01db0a0 core_strtab = 0xffffffffa01dbb30 "" crash> rd 0xffffffffa01dbb30 4 ffffffffa01dbb30: 615f70616d6b0000 66780063696d6f74 ..kmap_atomic.xf ffffffffa01dbb40: 73636e75665f7265 72665f646e696600 er_funcs.find_fr ============================================================================ We expect Just first one byte of '\0', but actually first two bytes are '\0'. Here is The relationship between symtab and strtab. symtab_idx strtab_idx symbol ----------------------------------------------- 0 0x1 "\0" # startab_idx should be 0 1 0x2 "kmap_atomic" 2 0xe "xfer_funcs" 3 0x19 "find_fr..." By applying this patch, it becomes as follows. symtab_idx strtab_idx symbol ----------------------------------------------- 0 0x0 "\0" # extra byte is removed 1 0x1 "kmap_atomic" 2 0xd "xfer_funcs" 3 0x18 "find_fr..." Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Cc: Masaki Kimura <masaki.kimura.kz@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-14security: introduce kernel_module_from_file hookKees Cook
Now that kernel module origins can be reasoned about, provide a hook to the LSMs to make policy decisions about the module file. This will let Chrome OS enforce that loadable kernel modules can only come from its read-only hash-verified root filesystem. Other LSMs can, for example, read extended attributes for signatures, etc. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-14module: add flags arg to sys_finit_module()Rusty Russell
Thanks to Michael Kerrisk for keeping us honest. These flags are actually useful for eliminating the only case where kmod has to mangle a module's internals: for overriding module versioning. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Kees Cook <keescook@chromium.org>
2012-12-14module: add syscall to load module from fdKees Cook
As part of the effort to create a stronger boundary between root and kernel, Chrome OS wants to be able to enforce that kernel modules are being loaded only from our read-only crypto-hash verified (dm_verity) root filesystem. Since the init_module syscall hands the kernel a module as a memory blob, no reasoning about the origin of the blob can be made. Earlier proposals for appending signatures to kernel modules would not be useful in Chrome OS, since it would involve adding an additional set of keys to our kernel and builds for no good reason: we already trust the contents of our root filesystem. We don't need to verify those kernel modules a second time. Having to do signature checking on module loading would slow us down and be redundant. All we need to know is where a module is coming from so we can say yes/no to loading it. If a file descriptor is used as the source of a kernel module, many more things can be reasoned about. In Chrome OS's case, we could enforce that the module lives on the filesystem we expect it to live on. In the case of IMA (or other LSMs), it would be possible, for example, to examine extended attributes that may contain signatures over the contents of the module. This introduces a new syscall (on x86), similar to init_module, that has only two arguments. The first argument is used as a file descriptor to the module and the second argument is a pointer to the NULL terminated string of module arguments. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (merge fixes)
2012-10-31module: fix out-by-one error in kallsymsRusty Russell
Masaki found and patched a kallsyms issue: the last symbol in a module's symtab wasn't transferred. This is because we manually copy the zero'th entry (which is always empty) then copy the rest in a loop starting at 1, though from src[0]. His fix was minimal, I prefer to rewrite the loops in more standard form. There are two loops: one to get the size, and one to copy. Make these identical: always count entry 0 and any defined symbol in an allocated non-init section. This bug exists since the following commit was introduced. module: reduce symbol table for loaded modules (v2) commit: 4a4962263f07d14660849ec134ee42b63e95ea9a LKML: http://lkml.org/lkml/2012/10/24/27 Reported-by: Masaki Kimura <masaki.kimura.kz@hitachi.com> Cc: stable@kernel.org
2012-10-19MODSIGN: Move the magic string to the end of a module and eliminate the searchDavid Howells
Emit the magic string that indicates a module has a signature after the signature data instead of before it. This allows module_sig_check() to be made simpler and faster by the elimination of the search for the magic string. Instead we just need to do a single memcmp(). This works because at the end of the signature data there is the fixed-length signature information block. This block then falls immediately prior to the magic number. From the contents of the information block, it is trivial to calculate the size of the signature data and thus the size of the actual module data. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-10MODSIGN: Add FIPS policyDavid Howells
If we're in FIPS mode, we should panic if we fail to verify the signature on a module or we're asked to load an unsigned module in signature enforcing mode. Possibly FIPS mode should automatically enable enforcing mode. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10module: signature checking hookRusty Russell
We do a very simple search for a particular string appended to the module (which is cache-hot and about to be SHA'd anyway). There's both a config option and a boot parameter which control whether we accept or fail with unsigned modules and modules that are signed with an unknown key. If module signing is enabled, the kernel will be tainted if a module is loaded that is unsigned or has a signature for which we don't have the key. (Useful feedback and tweaks by David Howells <dhowells@redhat.com>) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28module: wait when loading a module which is currently initializing.Rusty Russell
The original module-init-tools module loader used a fnctl lock on the .ko file to avoid attempts to simultaneously load a module. Unfortunately, you can't get an exclusive fcntl lock on a read-only fd, making this not work for read-only mounted filesystems. module-init-tools has a hacky sleep-and-loop for this now. It's not that hard to wait in the kernel, and only return -EEXIST once the first module has finished loading (or continue loading the module if the first one failed to initialize for some reason). It's also consistent with what we do for dependent modules which are still loading. Suggested-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28module: fix symbol waiting when module fails before initRusty Russell
We use resolve_symbol_wait(), which blocks if the module containing the symbol is still loading. However: 1) The module_wq we use is only woken after calling the modules' init function, but there are other failure paths after the module is placed in the linked list where we need to do the same thing. 2) wake_up() only wakes one waiter, and our waitqueue is shared by all modules, so we need to wake them all. 3) wake_up_all() doesn't imply a memory barrier: I feel happier calling it after we've grabbed and dropped the module_mutex, not just after the state assignment. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28module: taint kernel when lve module is loadedMatthew Garrett
Cloudlinux have a product called lve that includes a kernel module. This was previously GPLed but is now under a proprietary license, but the module continues to declare MODULE_LICENSE("GPL") and makes use of some EXPORT_SYMBOL_GPL symbols. Forcibly taint it in order to avoid this. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Alex Lyashkov <umka@cloudlinux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2012-05-23Guard check in module loader against integer overflowDavid Howells
The check: if (len < hdr->e_shoff + hdr->e_shnum * sizeof(Elf_Shdr)) may not work if there's an overflow in the right-hand side of the condition. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
