path: root/kernel/params.c
2011-05-19params.c: Use new strtobool function to process boolean inputsJonathan Cameron
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19module: deal with alignment issues in built-in module versionsDmitry Torokhov
On m68k natural alignment is 2-byte boundary but we are trying to align structures in __modver section on sizeof(void *) boundary. This causes trouble when we try to access elements in this section in array-like fashion when create "version" attributes for built-in modules. Moreover, as DaveM said, we can't reliably put structures into independent objects, put them into a special section, and then expect array access over them (via the section boundaries) after linking the objects together to just "work" due to variable alignment choices in different situations. The only solution that seems to work reliably is to make an array of plain pointers to the objects in question and put those pointers in the special section. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-24module: show version information for built-in modules in sysfsDmitry Torokhov
Currently only drivers that are built as modules have their versions shown in /sys/module/<module_name>/version, but this information might also be useful for built-in drivers as well. This especially important for drivers that do not define any parameters - such drivers, if built-in, are completely invisible from userspace. This patch changes MODULE_VERSION() macro so that in case when we are compiling built-in module, version information is stored in a separate section. Kernel then uses this data to create 'version' sysfs attribute in the same fashion it creates attributes for module parameters. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-11param: locking for kernel parametersRusty Russell
There may be cases (most obviously, sysfs-writable charp parameters) where a module needs to prevent sysfs access to parameters. Rather than express this in terms of a big lock, the functions are expressed in terms of what they protect against. This is clearer, esp. if the implementation changes to a module-level or even param-level lock. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: make param sections const.Rusty Russell
Since this section can be read-only (they're in .rodata), they should always have been const. Minor flow-through various functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: use free hook for charp (fix leak of charp parameters)Rusty Russell
Instead of using a "I kmalloced this" flag, we keep track of the kmalloced strings and use that list to check if we need to kfree (in practice, the list is very short). This means that kparams can be const again, and plugs a leak. This is important for drivers/usb/gadget/nokia.c which gets modprobe/rmmod'ed frequently on the N9000. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Cc: Artem Bityutskiy <dedekind1@gmail.com> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: add a free hook to kernel_param_ops.Rusty Russell
This allows us to generalize the KPARAM_KMALLOCED flag, by calling a function on every parameter when a module is unloaded. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: use ops in struct kernel_param, rather than get and set fns directlyRusty Russell
This is more kernel-ish, saves some space, and also allows us to expand the ops without breaking all the callers who are happy for the new members to be NULL. The few places which defined their own param types are changed to the new scheme (more which crept in recently fixed in following patches). Since we're touching them anyway, we change get() and set() to take a const struct kernel_param (which they really are). This causes some harmless warnings until we fix them (in following patches). To reduce churn, module_param_call creates the ops struct so the callers don't have to change (and casts the functions to reduce warnings). The modern version which takes an ops struct is called module_param_cb. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Alessandro Rubini <rubini@ipvvis.unipv.it> Cc: Michal Januszewski <spock@gentoo.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-kernel@vger.kernel.org Cc: linux-input@vger.kernel.org Cc: linux-fbdev-devel@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-11param: move the EXPORT_SYMBOL to after the definitions.Rusty Russell
This is modern style, and good to do before we start changing things. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11params: don't hand NULL values to param.set callbacks.Rusty Russell
An audit by Dongdong Deng revealed that most driver-author-written param calls don't handle val == NULL (which happens when parameters are specified with no =, eg "foo" instead of "foo=1"). The only real case to use this is boolean, so handle it specially for that case and remove a source of bugs for everyone else. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dongdong Deng <dongdong.deng@windriver.com> Cc: Américo Wang <xiyou.wangcong@gmail.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-07sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on dynamic attributesEric W. Biederman
These are the non-static sysfs attributes that exist on my test machine. Fix them to use sysfs_attr_init or sysfs_bin_attr_init as appropriate. It simply requires making a sysfs attribute present to see this. So this is a little bit tedious but otherwise not too bad. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07kobject: Constify struct kset_uevent_opsEmese Revfy
Constify struct kset_uevent_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-06includecheck fix for kernel/params.cJaswinder Singh Rajput
Fix the following 'make includecheck' warning: kernel/params.c: linux/string.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-05Remove redundant trailing semicolons from macrosEdward Z. Yang
Signed-off-by: Edward Z. Yang <ezyang@ksplice.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29param: fix setting arrays of boolRusty Russell
We create a dummy struct kernel_param on the stack for parsing each array element, but we didn't initialize the flags word. This matters for arrays of type "bool", where the flag indicates if it really is an array of bools or unsigned int (old-style). Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2009-10-29param: fix NULL comparison on oomRusty Russell
kp->arg is always true: it's the contents of that pointer we care about. Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2009-10-29param: fix lots of bugs with writing charp params from sysfs, by leaking mem.Rusty Russell
e180a6b7759a "param: fix charp parameters set via sysfs" fixed the case where charp parameters written via sysfs were freed, leaving drivers accessing random memory. Unfortunately, storing a flag in the kparam struct was a bad idea: it's rodata so setting it causes an oops on some archs. But that's not all: 1) module_param_array() on charp doesn't work reliably, since we use an uninitialized temporary struct kernel_param. 2) there's a fundamental race if a module uses this parameter and then it's changed: they will still access the old, freed, memory. The simplest fix (ie. for 2.6.32) is to never free the memory. This prevents all these problems, at cost of a memory leak. In practice, there are only 18 places where a charp is writable via sysfs, and all are root-only writable. Reported-by: Takashi Iwai <tiwai@suse.de> Cc: Sitsofe Wheeler <sitsofe@yahoo.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2009-09-25param: allow whitespace as kernel parameter separatorPeter Oberparleiter
Some boot mechanisms require that kernel parameters are stored in a separate file which is loaded to memory without further processing (e.g. the "Load from FTP" method on s390). When such a file contains newline characters, the kernel parameter preceding the newline might not be correctly parsed (due to the newline being stuck to the end of the actual parameter value) which can lead to boot failures. This patch improves kernel command line usability in such a situation by allowing generic whitespace characters as separators between kernel parameters. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12module_param: allow 'bool' module_params to be bool, not just int.Rusty Russell
Impact: API cleanup For historical reasons, 'bool' parameters must be an int, not a bool. But there are around 600 users, so a conversion seems like useless churn. So we use __same_type() to distinguish, and handle both cases. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12module_param: split perm field into flags and permRusty Russell
Impact: cleanup Rather than hack KPARAM_KMALLOCED into the perm field, separate it out. Since the perm field was 32 bits and only needs 16, we don't add bloat. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12module_param: invbool should take a 'bool', not an 'int'Rusty Russell
It takes an 'int' for historical reasons, and there are only two users: simply switch it over to bool. The other user (uvesafb.c) will get a (harmless-on-x86) warning until the next patch is applied. Cc: Brad Douglas <brad@neruo.com> Cc: Michal Januszewski <spock@gentoo.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-31param: fix charp parameters set via sysfsRusty Russell
Impact: fix crash on reading from /sys/module/.../ieee80211_default_rc_algo The module_param type "charp" simply sets a char * pointer in the module to the parameter in the commandline string: this is why we keep the (mangled) module command line around. But when set via sysfs (as about 11 charp parameters can be) this memory is freed on the way out of the write(). Future reads hit random mem. So we kstrdup instead: we have to check we're not in early commandline parsing, and we have to note when we've used it so we can reliably kfree the parameter when it's next overwritten, and also on module unload. (Thanks to Randy Dunlap for CONFIG_SYSFS=n fixes) Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> Diagnosed-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-10-23Fix compile warning in kernel/params.cLinus Torvalds
Move free_module_param_attrs() into the CONFIG_MODULES section, since it's only used inside there. Thus avoiding the warning kernel/params.c:514: warning: 'free_module_param_attrs' defined but not used Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-22core_param() for genuinely core kernel parametersRusty Russell
There are a lot of one-liner uses of __setup() in the kernel: they're cumbersome and not queryable (definitely not settable) via /sys. Yet it's ugly to simplify them to module_param(), because by default that inserts a prefix of the module name (usually filename). So, introduce a "core_param". The parameter gets no prefix, but appears in /sys/module/kernel/parameters/ (if non-zero perms arg). I thought about using the name "core", but that's more common than "kernel". And if you create a module called "kernel", you will die a horrible death. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-10-22param: Fix duplicate module prefixesRusty Russell
Instead of insisting each new module_param sysfs entry is unique, handle the case where it already exists (for builtin modules). The current code assumes that all identical prefixes are together in the section: true for normal uses, but not necessarily so if someone overrides MODULE_PARAM_PREFIX. More importantly, it's not true with the new "core_param()" code which uses "kernel" as a prefix. This simplifies the caller for the builtin case, at a slight loss of efficiency (we do the lookup every time to see if the directory exists). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22module: check kernel param length at compile time, not runtimeRusty Russell
The kparam code tries to handle over-length parameter prefixes at runtime. Not only would I bet this has never been tested, it's not clear that truncating names is a good idea either. So let's check at compile time. We need to move the #define to moduleparam.h to do this, though. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-08Add new string functions strict_strto* and convert kernel params to use themYi Yang
Currently, for every sysfs node, the callers will be responsible for implementing store operation, so many many callers are doing duplicate things to validate input, they have the same mistakes because they are calling simple_strtol/ul/ll/uul, especially for module params, they are just numeric, but you can echo such values as 0x1234xxx, 07777888 and 1234aaa, for these cases, module params store operation just ignores succesive invalid char and converts prefix part to a numeric although input is acctually invalid. This patch tries to fix the aforementioned issues and implements strict_strtox serial functions, kernel/params.c uses them to strictly validate input, so module params will reject such values as 0x1234xxxx and returns an error: write error: Invalid argument Any modules which export numeric sysfs node can use strict_strtox instead of simple_strtox to reject any invalid input. Here are some test results: Before applying this patch: [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0x1000 > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0x1000g > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0x1000gggggggg > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 010000 > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0100008 > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 010000aaaaa > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# After applying this patch: [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0x1000 > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0x1000g > /sys/module/e1000/parameters/copybreak -bash: echo: write error: Invalid argument [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo 0x1000gggggggg > /sys/module/e1000/parameters/copybreak -bash: echo: write error: Invalid argument [root@yangyi-dev /]# echo 010000 > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# echo 0100008 > /sys/module/e1000/parameters/copybreak -bash: echo: write error: Invalid argument [root@yangyi-dev /]# echo 010000aaaaa > /sys/module/e1000/parameters/copybreak -bash: echo: write error: Invalid argument [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# echo -n 4096 > /sys/module/e1000/parameters/copybreak [root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak 4096 [root@yangyi-dev /]# [akpm@linux-foundation.org: fix compiler warnings] [akpm@linux-foundation.org: fix off-by-one found by tiwai@suse.de] Signed-off-by: Yi Yang <yi.y.yang@intel.com> Cc: Greg KH <greg@kroah.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Takashi Iwai <tiwai@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kernel/params.c: remove sparse-warning (different signedness)Richard Knutsson
Fixing: CHECK kernel/params.c kernel/params.c:329:41: warning: incorrect type in argument 8 (different signedness) kernel/params.c:329:41: expected int *num kernel/params.c:329:41: got unsigned int * Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-29module: fix the module name length in param_sysfs_builtinDenis Cheng
the original code use KOBJ_NAME_LEN for built-in module name length, that's defined to 20 in linux/kobject.h, but this is not enough appearntly, many module names are longer than this; #define KOBJ_NAME_LEN 20 another macro is MODULE_NAME_LEN defined in linux/module.h, I think this is enough for module names: #define MODULE_NAME_LEN (64 - sizeof(unsigned long)) Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-24Modules: remove unneeded release functionGreg Kroah-Hartman
Now that kobjects properly clean up their name structures, no matter if they have a release function or not, we can drop this empty module kobject release function too (it was needed prior to this because of the way we handled static kobject names, we based the fact that if a release function was present, then we could safely free the name string, now we are more smart about things and only free names we have previously set.) Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: convert kernel/params.c to use kobject_init/add_ng()Greg Kroah-Hartman
This converts the code to use the new kobject functions, cleaning up the logic in doing so. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/module to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename module_subsys to module_kset to catch all users of the variable. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-23[SCSI] sysfs: add filter function to groupsJames Bottomley
This patch allows the various users of attribute_groups to selectively allow the appearance of group attributes. The primary consumer of this will be the transport classes in which we currently have elaborate attribute selection algorithms to do this same thing. Acked-by: Greg KH <greg@kroah.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-12-22Modules: fix memory leak of module namesGreg Kroah-Hartman
Due to the change in kobject name handling, the module kobject needs to have a null release function to ensure that the name it previously set will be properly cleaned up. All of this wierdness goes away in 2.6.25 with the rework of the kobject name and cleanup logic, but this is required for 2.6.24. Thanks to Alexey Dobriyan for finding the problem, and to Kay Sievers for pointing out the simple way to fix it after I tried many complex ways. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-14fix param_sysfs_builtin name length checkJan Kiszka
Commit faf8c714f4508207a9c81cc94dafc76ed6680b44 caused a regression: parameter names longer than MAX_KBUILD_MODNAME will now be rejected, although we just need to keep the module name part that short. This patch restores the old behaviour while still avoiding that memchr is called with its length parameter larger than the total string length. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18param_sysfs_builtin memchr argument fixDave Young
If memchr argument is longer than strlen(kp->name), there will be some weird result. It will casuse duplicate filenames in sysfs for the "nousb". kernel warning messages are as bellow: sysfs: duplicate filename 'usbcore' can not be created WARNING: at fs/sysfs/dir.c:416 sysfs_add_one() [<c01c4750>] sysfs_add_one+0xa0/0xe0 [<c01c4ab8>] create_dir+0x48/0xb0 [<c01c4b69>] sysfs_create_dir+0x29/0x50 [<c024e0fb>] create_dir+0x1b/0x50 [<c024e3b6>] kobject_add+0x46/0x150 [<c024e2da>] kobject_init+0x3a/0x80 [<c053b880>] kernel_param_sysfs_setup+0x50/0xb0 [<c053b9ce>] param_sysfs_builtin+0xee/0x130 [<c053ba33>] param_sysfs_init+0x23/0x60 [<c024d062>] __next_cpu+0x12/0x20 [<c052aa30>] kernel_init+0x0/0xb0 [<c052aa30>] kernel_init+0x0/0xb0 [<c052a856>] do_initcalls+0x46/0x1e0 [<c01bdb12>] create_proc_entry+0x52/0x90 [<c0158d4c>] register_irq_proc+0x9c/0xc0 [<c01bda94>] proc_mkdir_mode+0x34/0x50 [<c052aa30>] kernel_init+0x0/0xb0 [<c052aa92>] kernel_init+0x62/0xb0 [<c0104f83>] kernel_thread_helper+0x7/0x14 ======================= kobject_add failed for usbcore with -EEXIST, don't try to register things with the same name in the same directory. [<c024e466>] kobject_add+0xf6/0x150 [<c053b880>] kernel_param_sysfs_setup+0x50/0xb0 [<c053b9ce>] param_sysfs_builtin+0xee/0x130 [<c053ba33>] param_sysfs_init+0x23/0x60 [<c024d062>] __next_cpu+0x12/0x20 [<c052aa30>] kernel_init+0x0/0xb0 [<c052aa30>] kernel_init+0x0/0xb0 [<c052a856>] do_initcalls+0x46/0x1e0 [<c01bdb12>] create_proc_entry+0x52/0x90 [<c0158d4c>] register_irq_proc+0x9c/0xc0 [<c01bda94>] proc_mkdir_mode+0x34/0x50 [<c052aa30>] kernel_init+0x0/0xb0 [<c052aa92>] kernel_init+0x62/0xb0 [<c0104f83>] kernel_thread_helper+0x7/0x14 ======================= Module 'usbcore' failed to be added to sysfs, error number -17 The system will be unstable now. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17constify string/array kparam tracking structuresJan Beulich
.. in an effort to make read-only whatever can be made, so that CONFIG_DEBUG_RODATA can catch as many issues as possible. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30modules: better error messages when modules fail to load due to a sysfs problem.Greg Kroah-Hartman
This helps people when debugging problems like the ones that were in the recent -mm releases. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08kernel/params.c: fix lying comment for param_array()Bert Wesarg
This fixes the comment for the function param_array. Which lies that it only *temporarily* mangle the input string @val. Signed-off-by: Bert Wesarg <wesarg@informatik.uni-halle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-12[PATCH] fix kernel oops with badly formatted module optionRandy Dunlap
Catch malformed kernel parameter usage of "param = value". Spaces are not supported, but don't cause a kernel fault on such usage, just report an error. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-23Revert "Driver core: let request_module() send a /sys/modules/kmod/-uevent"Greg Kroah-Hartman
This reverts commit c353c3fb0700a3c17ea2b0237710a184232ccd7f. It turns out that we end up with a loop trying to load the unix module and calling netfilter to do that. Will redo the patch later to not have this loop. Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
