path: root/kernel/posix-timers.c
2008-04-30signals: join send_sigqueue() with send_group_sigqueue()Oleg Nesterov
We export send_sigqueue() and send_group_sigqueue() for the only user, posix_timer_event(). This is a bit silly, because both are just trivial helpers on top of do_send_sigqueue() and because the we pass the unused .si_signo parameter. Kill them both, rename do_send_sigqueue() to send_sigqueue(), and export it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18kernel: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-14hrtimer: check relative timeouts for overflowThomas Gleixner
Various user space callers ask for relative timeouts. While we fixed that overflow issue in hrtimer_start(), the sites which convert relative user space values to absolute timeouts themself were uncovered. Instead of putting overflow checks into each place add a function which does the sanity checking and convert all affected callers to use it. Thanks to Frans Pop, who reported the problem and tested the fixes. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Tested-by: Frans Pop <elendil@planet.nl>
2008-02-10hrtimer: fix *rmtp handling in hrtimer_nanosleep()Oleg Nesterov
Spotted by Pavel Emelyanov and Alexey Dobriyan. hrtimer_nanosleep() sets restart_block->arg1 = rmtp, but this rmtp points to the local variable which lives in the caller's stack frame. This means that if sys_restart_syscall() actually happens and it is interrupted as well, we don't update the user-space variable, but write into the already dead stack frame. Introduced by commit 04c227140fed77587432667a574b14736a06dd7f hrtimer: Rework hrtimer_nanosleep to make sys_compat_nanosleep easier Change the callers to pass "__user *rmtp" to hrtimer_nanosleep(), and change hrtimer_nanosleep() to use copy_to_user() to actually update *rmtp. Small problem remains. man 2 nanosleep states that *rtmp should be written if nanosleep() was interrupted (it says nothing whether it is OK to update *rmtp if nanosleep returns 0), but (with or without this patch) we can dirty *rem even if nanosleep() returns 0. NOTE: this patch doesn't change compat_sys_nanosleep(), because it has other bugs. Fixed by the next patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Pavel Emelyanov <xemul@sw.ru> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Toyo Abe <toyoa@mvista.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> include/linux/hrtimer.h | 2 - kernel/hrtimer.c | 51 +++++++++++++++++++++++++----------------------- kernel/posix-timers.c | 14 +------------ 3 files changed, 30 insertions(+), 37 deletions(-)
2008-02-08Use find_task_by_vpid in posix timersPavel Emelyanov
All the functions that need to lookup a task by pid in posix timers obtain this pid from a user space, and thus this value refers to a task in the same namespace, as the current task lives in. So the proper behavior is to call find_task_by_vpid() here. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: new timerfd APIDavide Libenzi
This is the new timerfd API as it is implemented by the following patch: int timerfd_create(int clockid, int flags); int timerfd_settime(int ufd, int flags, const struct itimerspec *utmr, struct itimerspec *otmr); int timerfd_gettime(int ufd, struct itimerspec *otmr); The timerfd_create() API creates an un-programmed timerfd fd. The "clockid" parameter can be either CLOCK_MONOTONIC or CLOCK_REALTIME. The timerfd_settime() API give new settings by the timerfd fd, by optionally retrieving the previous expiration time (in case the "otmr" parameter is not NULL). The time value specified in "utmr" is absolute, if the TFD_TIMER_ABSTIME bit is set in the "flags" parameter. Otherwise it's a relative time. The timerfd_gettime() API returns the next expiration time of the timer, or {0, 0} if the timerfd has not been set yet. Like the previous timerfd API implementation, read(2) and poll(2) are supported (with the same interface). Here's a simple test program I used to exercise the new timerfd APIs: http://www.xmailserver.org/timerfd-test2.c [akpm@linux-foundation.org: coding-style cleanups] [akpm@linux-foundation.org: fix ia64 build] [akpm@linux-foundation.org: fix m68k build] [akpm@linux-foundation.org: fix mips build] [akpm@linux-foundation.org: fix alpha, arm, blackfin, cris, m68k, s390, sparc and sparc64 builds] [heiko.carstens@de.ibm.com: fix s390] [akpm@linux-foundation.org: fix powerpc build] [akpm@linux-foundation.org: fix sparc64 more] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03kernel/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Isolate some explicit usage of task->tgidPavel Emelyanov
With pid namespaces this field is now dangerous to use explicitly, so hide it behind the helpers. Also the pid and pgrp fields o task_struct and signal_struct are to be deprecated. Unfortunately this patch cannot be sent right now as this leads to tons of warnings, so start isolating them, and deprecate later. Actually the p->tgid == pid has to be changed to has_group_leader_pid(), but Oleg pointed out that in case of posix cpu timers this is the same, and thread_group_leader() is more preferable. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18hrtimer: Rework hrtimer_nanosleep to make sys_compat_nanosleep easierAnton Blanchard
Pull the copy_to_user out of hrtimer_nanosleep and into the callers (common_nsleep, sys_nanosleep) in preparation for converting compat_sys_nanosleep to use hrtimers. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17SLAB_PANIC more (proc, posix-timers, shmem)Alexey Dobriyan
These aren't modular, so SLAB_PANIC is OK. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14more low-hanging fruits - kernel, fs, lib signednessAl Viro
2007-08-22posix-timers: fix creation raceOleg Nesterov
sys_timer_create() sets ->it_process and unlocks ->siglock, then checks tmr->it_sigev_notify to define if get_task_struct() is needed. We already passed ->it_id to the caller, another thread can delete this timer and free its memory in between. As a minimal fix, move this code under ->siglock, sys_timer_delete() takes it too before calling release_posix_timer(). A proper serialization would be to take ->it_lock, we add a partly initialized timer on posix_timers_id, not good. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22posix-timers: fix deletion raceThomas Gleixner
timer_delete does: lock_timer(); timer->it_process = NULL; unlock_timer(); release_posix_timer(); timer->it_process is checked in lock_timer() to prevent access to a timer, which is on the way to be deleted, but the check happens after idr_lock is dropped. This allows release_posix_timer() to delete the timer before the lock code can check the timer: CPU 0 CPU 1 lock_timer(); timer->it_process = NULL; unlock_timer(); lock_timer() spin_lock(idr_lock); timer = idr_find(); spin_lock(timer->lock); spin_unlock(idr_lock); release_posix_timer(); spin_lock(idr_lock); idr_remove(timer); spin_unlock(idr_lock); free_timer(timer); if (timer->......) Change the locking to prevent this. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-21posix-timers: Prevent softirq starvation by small intervals and SIG_IGNThomas Gleixner
posix-timers which deliver an ignored signal are currently rearmed in the timer softirq: This is necessary because the timer needs to be delivered again when SIG_IGN is removed. This is not a problem, when the interval is reasonable. With high resolution timers enabled one might arm a posix timer with a very small interval and ignore the signal. This might lead to a softirq starvation when the interval is so small that the timer is requeued onto the softirq pending list right away. This problem was pointed out by Jan Kiszka. Thanks Jan ! The correct solution would be to stop the timer, when the signal is ignored and rearm it when SIG_IGN is removed. Unfortunately this requires modification in sigaction and involves non trivial sighand locking. It's too late in the release cycle for such a change. For now we just keep the timer running and enforce that the timer only fires every jiffie. This does not break anything as we keep the overrun counter correct. It adds a little inaccuracy to the timer_gettime() interface, but... The more complex change is necessary anyway to fix another short coming of the current implementation, which I discovered while looking at this problem: A pending signal is discarded when SIG_IGN is set. In case that a posixtimer signal is pending then it is discarded as well, but when SIG_IGN is removed later nothing rearms the timer. This is not new, it's that way since posix timers have been merged. So nothing to worry about right now. I have a working solution to fix all of this, but the impact is too large for both stable and 2.6.22. I'm going to send it out for review in the next days. This should go into 2.6.21.stable as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kiszka <jan.kiszka@web.de> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Stable Team <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] hrtimers: add high resolution timer supportThomas Gleixner
Implement high resolution timers on top of the hrtimers infrastructure and the clockevents / tick-management framework. This provides accurate timers for all hrtimer subsystem users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] hrtimers: namespace and enum cleanupThomas Gleixner
- hrtimers did not use the hrtimer_restart enum and relied on the implict int representation. Fix the prototypes and the functions using the enums. - Use seperate name spaces for the enumerations - Convert hrtimer_restart macro to inline function - Add comments No functional changes. [akpm@osdl.org: fix input driver] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-29[PATCH] posix-timers: Fix clock_nanosleep() doesn't return the remaining ↵Toyo Abe
time in compatibility mode The clock_nanosleep() function does not return the time remaining when the sleep is interrupted by a signal. This patch creates a new call out, compat_clock_nanosleep_restart(), which handles returning the remaining time after a sleep is interrupted. This patch revives clock_nanosleep_restart(). It is now accessed via the new call out. The compat_clock_nanosleep_restart() is used for compatibility access. Since this is implemented in compatibility mode the normal path is virtually unaffected - no real performance impact. Signed-off-by: Toyo Abe <toyoa@mvista.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] hrtimers: remove data fieldRoman Zippel
The nanosleep cleanup allows to remove the data field of hrtimer. The callback function can use container_of() to get it's own data. Since the hrtimer structure is anyway embedded in other structures, this adds no overhead. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] hrtimers: posix-timer: cleanup common_timer_get()Roman Zippel
Cleanup common_timer_get() a little. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] hrtimers: pass current time to hrtimer_forward()Roman Zippel
Pass current time to hrtimer_forward(). This allows to use the softirq time in the timer base when the forward function is called from the timer callback. Other places pass current time with a call to timer->base->get_time(). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: kernel/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] posix-timers: fix requeue accounting when signal is ignoredRoman Zippel
When the posix-timer signal is ignored then the timer is rearmed by the callback function. The requeue pending accounting has to be fixed up else the state might be wrong. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] kernel/posix-timers.c: remove do_posix_clock_notimer_create()Adrian Bunk
This function is neither used nor has any real contents. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: set correct initial expiry time for relative SIGEV_NONE timersThomas Gleixner
The expiry time for relative timers with SIGEV_NONE set was never updated to the correct value. Pointed out by George Anzinger. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: cleanups and simplificationsGeorge Anzinger
Clean up the interface to hrtimers by changing the init code to pass the mode as well as the clock. This allow the init code to select the correct base and eliminates extra timer re-init code in posix-timers. We also simplify the restart interface nanosleep use. Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: fix possible use of NULL pointer in posix-timersThomas Gleixner
Fixup the conversion of posix-timers to hrtimers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: convert posix timers completelyThomas Gleixner
- convert posix-timers.c to use hrtimers - remove the now obsolete abslist code Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: switch clock_nanosleep to hrtimer nanosleep APIThomas Gleixner
Switch clock_nanosleep to use the new nanosleep functions in hrtimer.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: create and use timespec_valid macroThomas Gleixner
add timespec_valid(ts) [returns false if the timespec is denorm] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: make clockid_t arguments constThomas Gleixner
add const arguments to the posix-timers.h API functions Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: remove duplicate div_long_long_rem implementationThomas Gleixner
make posix-timers.c use the generic calc64.h facility Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] timespec: normalize off by one errorsGeorge Anzinger
It would appear that the timespec normalize code has an off by one error. Found in three places. Thanks to Ben for spotting. Signed-off-by: George Anzinger<george@mvista.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] posix-timers: use schedule_timeout() in common_nsleep()Oleg Nesterov
common_nsleep() reimplements schedule_timeout_interruptible() for unknown reason. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[PATCH] Call exit_itimers from do_exit, not __exit_signalRoland McGrath
When I originally moved exit_itimers into __exit_signal, that was the only place where we could reliably know it was the last thread in the group dying, without races. Since then we've gotten the signal_struct.live counter, and do_exit can reliably do group-wide cleanup work. This patch moves the call to do_exit, where it's made without locks. This avoids the deadlock issues that the old __exit_signal code's comment talks about, and the one that Oleg found recently with process CPU timers. [ This replaces e03d13e985d48ac4885382c9e3b1510c78bd047f, which is why it was just reverted. ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fix send_sigqueue() vs thread exit raceOleg Nesterov
posix_timer_event() first checks that the thread (SIGEV_THREAD_ID case) does not have PF_EXITING flag, then it calls send_sigqueue() which locks task list. But if the thread exits in between the kernel will oops (->sighand == NULL after __exit_sighand). This patch moves the PF_EXITING check into the send_sigqueue(), it must be done atomically under tasklist_lock. When send_sigqueue() detects exiting thread it returns -1. In that case posix_timer_event will send the signal to thread group. Also, this patch fixes task_struct use-after-free in posix_timer_event. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] revert "timer exit cleanup"Andrew Morton
Revert this June 17 patch: it broke persistence of timers across execve(). Cc: Roland McGrath <roland@redhat.com> Cc: george anzinger <george@mvista.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] posix timers: fix normalization problemGeorge Anzinger
(We found this (after a customer complained) and it is in the kernel.org kernel. Seems that for CLOCK_MONOTONIC absolute timers and clock_nanosleep calls both the request time and wall_to_monotonic are subtracted prior to the normalize resulting in an overflow in the existing normalize test. This causes the result to be shifted ~4 seconds ahead instead of ~2 seconds back in time.) The normalize code in posix-timers.c fails when the tv_nsec member is ~1.2 seconds negative. This can happen on absolute timers (and clock_nanosleeps) requested on CLOCK_MONOTONIC (both the request time and wall_to_monotonic are subtracted resulting in the possibility of a number close to -2 seconds.) This fix uses the set_normalized_timespec() (which does not have an overflow problem) to fix the problem and as a side effect makes the code cleaner. Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] posix-timers: use try_to_del_timer_sync()Oleg Nesterov
sys_timer_settime/sys_timer_delete needs to delete k_itimer->real.timer synchronously while holding ->it_lock, which is also locked in posix_timer_fn. This patch removes timer_active/set_timer_inactive which plays with timer_list's internals in favour of using try_to_del_timer_sync(), which was introduced in the previous patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[PATCH] timer exit cleanupIngo Molnar
Do all timer zapping in exit_itimers. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
