path: root/kernel/power/main.c
2008-08-27ftrace: disable tracing for suspend to ramSteven Rostedt
I've been painstakingly debugging the issue with suspend to ram and ftraced. The 2.6.28 code does not have this issue, but since the mcount recording is not going to be in 27, this must be solved for the ftrace daemon version. The resume from suspend to ram would reboot because it was triple faulting. Debugging further, I found that calling the mcount function itself was not an issue, but it would fault when it incremented preempt_count. preempt_count is on the tasks info structure that is on the low memory address of the task's stack. For some reason, it could not write to it. Resuming out of suspend to ram does quite a lot of funny tricks to get to work, so it is not surprising at all that simply doing a preempt_disable() would cause a fault. Thanks to Rafael for suggesting to add a "while (1);" to find the place in resuming that is causing the fault. I would place the loop somewhere in the code, compile and reboot and see if it would either reboot (hit the fault) or simply hang (hit the loop). Doing this over and over again, I narrowed it down that it was happening in enable_nonboot_cpus. At this point, I found that it is easier to simply disable tracing around the suspend code, instead of searching for the particular function that can not handle doing a preempt_disable. This patch disables the tracer as it suspends and reenables it on resume. I tested this patch on my Laptop, and it can resume fine with the patch. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26pm selftest: rtc paranoiaDavid Brownell
Cope with a quirk of some RTCs (notably ACPI ones) which aren't guaranteed to implement oneshot behavior when they woke the system from sleeep: forcibly disable the alarm, just in case. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24pm: boot time suspend selftestDavid Brownell
Boot-time test for system suspend states (STR or standby). The generic RTC framework triggers wakeup alarms, which are used to exit those states. - Measures some aspects of suspend time ... this uses "jiffies" until someone converts it to use a timebase that works properly even while timer IRQs are disabled. - Triggered by a command line parameter. By default nothing even vaguely troublesome will happen, but "test_suspend=mem" will give you a brief STR test during system boot. (Or you may need to use "test_suspend=standby" instead, if your hardware needs that.) This isn't without problems. It fires early enough during boot that for example both PCMCIA and MMC stacks have misbehaved. The workaround in those cases was to boot without such media cards inserted. [matthltc@us.ibm.com: fix compile failure in boot time suspend selftest] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pavel Machek <pavel@suse.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12Suspend-related patches for 2.6.27Rafael J. Wysocki
ACPI PM: Add possibility to change suspend sequence There are some systems out there that don't work correctly with our current suspend/hibernation code ordering. Provide a workaround for these systems allowing them to pass 'acpi_sleep=old_ordering' in the kernel command line so that it will use the pre-ACPI 2.0 ("old") suspend code ordering. Unfortunately, this requires us to add a platform hook to the resuming of devices for recovering the platform in case one of the device drivers' .suspend() routines returns error code. Namely, ACPI 1.0 specifies that _PTS should be called before suspending devices, but _WAK still should be called before resuming them in order to undo the changes made by _PTS. However, if there is an error during suspending devices, they are automatically resumed without returning control to the PM core, so the _WAK has to be called from within device_resume() in that cases. The patch also reorders and refactors the ACPI suspend/hibernation code to avoid duplication as far as reasonably possible. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10Introduce new top level suspend and hibernation callbacksRafael J. Wysocki
Introduce 'struct pm_ops' and 'struct pm_ext_ops' ('ext' meaning 'extended') representing suspend and hibernation operations for bus types, device classes, device types and device drivers. Modify the PM core to use 'struct pm_ops' and 'struct pm_ext_ops' objects, if defined, instead of the ->suspend(), ->resume(), ->suspend_late(), and ->resume_early() callbacks (the old callbacks will be considered as legacy and gradually phased out). The main purpose of doing this is to separate suspend (aka S2RAM and standby) callbacks from hibernation callbacks in such a way that the new callbacks won't take arguments and the semantics of each of them will be clearly specified. This has been requested for multiple times by many people, including Linus himself, and the reason is that within the current scheme if ->resume() is called, for example, it's difficult to say why it's been called (ie. is it a resume from RAM or from hibernation or a suspend/hibernation failure etc.?). The second purpose is to make the suspend/hibernation callbacks more flexible so that device drivers can handle more than they can within the current scheme. For example, some drivers may need to prevent new children of the device from being registered before their ->suspend() callbacks are executed or they may want to carry out some operations requiring the availability of some other devices, not directly bound via the parent-child relationship, in order to prepare for the execution of ->suspend(), etc. Ultimately, we'd like to stop using the freezing of tasks for suspend and therefore the drivers' suspend/hibernation code will have to take care of the handling of the user space during suspend/hibernation. That, in turn, would be difficult within the current scheme, without the new ->prepare() and ->complete() callbacks. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-02-01Suspend: Invoke suspend notifications after console switchJohannes Berg
In order to fix APM emulation it is necessary to enable apm-emulation notifications for suspends triggered in various ways via the suspend notifiers. However, this will cause the systems using APM emulation to lock up between X being needed to switch away from the VT and X already waiting for resume in the APM ioctl. This patch moves the console switch (if enabled) before the suspend notification (and after the resume notification) to avoid this issue. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Suspend: Add config option to disable the freezer if architecture wants thatJohannes Berg
This patch makes the freezer optional for suspend to allow the system to work (or not work) like the original PMU suspend. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Suspend: Introduce begin() and end() callbacksRafael J. Wysocki
On ACPI systems the target state set by acpi_pm_set_target() is reset by acpi_pm_finish(), but that need not be called if the suspend fails.  All platforms that use the .set_target() global suspend callback are affected by analogous issues. For this reason, we need an additional global suspend callback that will reset the target state regardless of whether or not the suspend is successful.  Also, it is reasonable to rename the .set_target() callback, since it will be used for a different purpose on ACPI systems (due to ACPI 1.0x code ordering requirements). Introduce the global suspend callback .end() to be executed at the end of the suspend sequence and rename the .set_target() global suspend callback to .begin(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01suspend: fix ia64 allmodconfig buildRafael J. Wysocki
kernel/power/main.c:488: error: ‘pm_test_attr’ undeclared here (not in a function) Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Suspend: Use common prefix in messagesRafael J. Wysocki
Make suspend messages start with one common prefix "PM: ". Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Suspend: Fix comment in main.cRafael J. Wysocki
Fix a comment in kernel/power/main.c so that it doesn't contain lines longer that 80 characters. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Suspend: Fix compilation warning for CONFIG_SUSPEND unsetRafael J. Wysocki
Suspend: Make debug facility depend on CONFIG_SUSPEND Make the new suspend debug facility code depend on CONFIG_SUSPEND, as appropriate, to remove the compiler warning printed when CONFIG_PM is set and CONFIG_SUSPEND is not set. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PM: Convert PM notifiers to out-of-line codeAlan Stern
This patch (as1008b) converts the PM notifier routines from inline calls to out-of-line code. It also prevents pm_chain_head from being created when CONFIG_PM_SLEEP isn't enabled, and EXPORTs the notifier registration and unregistration routines. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01suspend: build fix responding to 2.6.25 kset changeRafael J. Wysocki
2008-02-01Suspend: Testing facility (rev. 2)Rafael J. Wysocki
Introduce sysfs attribute /sys/power/pm_test allowing one to test the suspend core code.  Namely, writing one of the strings: freezer devices platform processors core to this file causes the suspend code to work in one of the test modes defined as follows: freezer - test the freezing of processes devices - test the freezing of processes and suspending of devices platform - test the freezing of processes, suspending of devices and platform global   control methods(*) processors - test the freezing of processes, suspending of devices, platform global   control methods and the disabling of nonboot CPUs core - test the freezing of processes, suspending of devices, platform global   control methods, the disabling of nonboot CPUs and suspending of   platform/system devices (*) These are ACPI global control methods on ACPI systems Then, if a suspend is started by normal means, the suspend core will perform its normal operations up to the point indicated by given test level.  Next, it will wait for 5 seconds and carry out the resume operations needed to transition the system back to the fully functional state. Writing "none" to /sys/power/pm_test turns the testing off. When open for reading, /sys/power/pm_test contains a space-separated list of all available tests (including "none" that represents the normal functionality) in which the current test level is indicated by square brackets. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-01-24driver core: make /sys/power a kobjectGreg Kroah-Hartman
/sys/power should not be a kset, that's overkill. This patch renames it to power_kset and fixes up all usages of it in the tree. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver Core: switch all dynamic ksets to kobj_sysfs_opsKay Sievers
Switch all dynamically created ksets, that export simple attributes, to kobj_attribute from subsys_attribute. Struct subsys_attribute will be removed. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mike Halcrow <mhalcrow@us.ibm.com> Cc: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/power to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename power_subsys to power_kset to catch all users of the variable and we properly export it so that people don't have to guess that it really is present in the system. The pseries code is wierd, why is it createing /sys/power if CONFIG_PM is disabled? Oh well, stupid big boxes ignoring config options... Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-11PM: ACPI and APM must not be enabled at the same timeLen Brown
ACPI and APM used "pm_active" to guarantee that they would not be simultaneously active. But pm_active was recently moved under CONFIG_PM_LEGACY, so that without CONFIG_PM_LEGACY, pm_active became a NOP -- allowing ACPI and APM to both be simultaneously enabled. This caused unpredictable results, including boot hangs. Further, the code under CONFIG_PM_LEGACY is scheduled for removal. So replace pm_active with pm_flags. pm_flags depends only on CONFIG_PM, which is present for both CONFIG_APM and CONFIG_ACPI. http://bugzilla.kernel.org/show_bug.cgi?id=9194 Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2007-10-18freezer: do not sync filesystems from freeze_processesRafael J. Wysocki
The syncing of filesystems from within the freezer is generally not needed. Also, if there's an ext3 filesystem loopback-mounted from a FUSE one, the syncing results in writes to it and deadlocks. Similarly, it will deadlock if FUSE implements sync. Change freeze_processes() so that it doesn't execute sys_sync() and make the suspend and hibernation code path sync filesystems independently of the freezer. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18PM: Make suspend_ops staticRafael J. Wysocki
The variable suspend_ops representing the set of global platform-specific suspend-related operations, used by the PM core, need not be exported outside of kernel/power/main.c .  Make it static. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18PM: Rework struct platform_suspend_opsRafael J. Wysocki
There is no reason why the .prepare() and .finish() methods in 'struct platform_suspend_ops' should take any arguments, since architectures don't use these methods' argument in any practically meaningful way (ie. either the target system sleep state is conveyed to the platform by .set_target(), or there is only one suspend state supported and it is indicated to the PM core by .valid(), or .prepare() and .finish() aren't defined at all).  There also is no reason why .finish() should return any result. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18PM: Rename struct pm_ops and related thingsRafael J. Wysocki
The name of 'struct pm_ops' suggests that it is related to the power management in general, but in fact it is only related to suspend.  Moreover, its name should indicate what this structure is used for, so it seems reasonable to change it to 'struct platform_suspend_ops'.  In that case, the name of the global variable of this type used by the PM core and the names of related functions should be changed accordingly. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18make kernel/power/main.c:suspend_enter() staticAdrian Bunk
suspend_enter() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Introduce CONFIG_SUSPEND for suspend-to-Ram and standbyRafael J. Wysocki
Introduce CONFIG_SUSPEND representing the ability to enter system sleep states, such as the ACPI S3 state, and allow the user to choose SUSPEND and HIBERNATION independently of each other. Make HOTPLUG_CPU be selected automatically if SUSPEND or HIBERNATION has been chosen and the kernel is intended for SMP systems. Also, introduce CONFIG_PM_SLEEP which is automatically selected if CONFIG_SUSPEND or CONFIG_HIBERNATION is set and use it to select the code needed for both suspend and hibernation. The top-level power management headers and the ACPI code related to suspend and hibernation are modified to use the new definitions (the changes in drivers/acpi/sleep/main.c are, mostly, moving code to reduce the number of ifdefs). There are many other files in which CONFIG_PM can be replaced with CONFIG_PM_SLEEP or even with CONFIG_SUSPEND, but they can be updated in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATIONRafael J. Wysocki
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid confusion (among other things, with CONFIG_SUSPEND introduced in the next patch). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Integrate beeping flag with existing acpi_sleep flagsPavel Machek
Move "debug during resume from s2ram" into the variable we already use for real-mode flags to simplify code. It also closes nasty trap for the user in acpi_sleep_setup; order of parameters actually mattered there, acpi_sleep=s3_bios,s3_mode doing something different from acpi_sleep=s3_mode,s3_bios. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Optional beeping during resume from suspend to RAMNigel Cunningham
Add a feature allowing the user to make the system beep during a resume from suspend to RAM, on x86_64 and i386. This is useful for the users with broken resume from RAM, so that they can verify if the control reaches the kernel after a wake-up event. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Reduce code duplication between main.c and user.cRafael J. Wysocki
The SNAPSHOT_S2RAM ioctl code is outdated and it should not duplicate the suspend code in kernel/power/main.c. Fix that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: introduce hibernation and suspend notifiersRafael J. Wysocki
Make it possible to register hibernation and suspend notifiers, so that subsystems can perform hibernation-related or suspend-related operations that should not be carried out by device drivers' .suspend() and .resume() routines. [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-01PM: introduce set_target method in pm_opsRafael J. Wysocki
Commit 52ade9b3b97fd3bea42842a056fe0786c28d0555 changed the suspend code ordering to execute pm_ops->prepare() after the device model per-device .suspend() calls in order to fix some ACPI-related issues. Unfortunately, it broke the at91 platform which assumed that pm_ops->prepare() would be called before suspending devices. at91 used pm_ops->prepare() to get notified of the target system sleep state, so that it could use this information while suspending devices. However, with the current suspend code ordering pm_ops->prepare() is called too late for this purpose. Thus, at91 needs an additional method in 'struct pm_ops' that will be used for notifying the platform of the target system sleep state. Moreover, in the future such a method will also be needed by ACPI. This patch adds the .set_target() method to 'struct pm_ops' and makes the suspend code call it, if implemented, before executing the device model per-device .suspend() calls. It also modifies the at91 code to use pm_ops->set_target() instead of pm_ops->prepare(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17swsusp: fix sysfs interfaceRafael J. Wysocki
The sysfs files /sys/power/disk and /sys/power/state do not work as documented, since they allow the user to write only a few initial characters of the input string to trigger the option (eg. 'echo pl > /sys/power/disk' activates the platform mode of hibernation). Fix it. Special thanks to Peter Moulder <Peter.Moulder@infotech.monash.edu.au> for pointing out the problem. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-16Fix ACPI suspend / device suspend ordering problemLinus Torvalds
In commit e3c7db621bed4afb8e231cb005057f2feb5db557 we fixed the resume ordering, so that the ACPI low-level resume code was called before the actual driver resume was called. However, that broke the nesting logic of suspend and resume, and we continued to suspend the devices _after_ we the ACPI device suspend code was called. That resulted in us saving PCI state for devices that had already been changed by ACPI, and in some cases disabled entirely (causing the PCI save_state to be all-ones). Which in turn caused the wrong state to be written back on resume. This moves the ACPI device suspend to after the device model per-device suspend() calls. This fixes the bogus state save. Thanks to Lukáš Hejtmánek for testing. Acked-by: Lukas Hejtmanek <xhejtman@ics.muni.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09PM: Separate hibernation code from suspend codeRafael J. Wysocki
[ With Johannes Berg <johannes@sipsolutions.net> ] Separate the hibernation (aka suspend to disk code) from the other suspend code. In particular: * Remove the definitions related to hibernation from include/linux/pm.h * Introduce struct hibernation_ops and a new hibernate() function to hibernate the system, defined in include/linux/suspend.h * Separate suspend code in kernel/power/main.c from hibernation-related code in kernel/power/disk.c and kernel/power/user.c (with the help of hibernation_ops) * Switch ACPI (the only user of pm_ops.pm_disk_mode) to hibernation_ops Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07remove software_suspend()Johannes Berg
Remove software_suspend() and all its users since pm_suspend(PM_SUSPEND_DISK) should be equivalent and there's no point in having two interfaces for the same thing. The patch also changes the valid_state function to return 0 (false) for PM_SUSPEND_DISK when SOFTWARE_SUSPEND is not configured instead of accepting it and having the whole thing fail later. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: do not use page flagsRafael J. Wysocki
Make swsusp use memory bitmaps instead of page flags for marking 'nosave' and free pages. This allows us to 'recycle' two page flags that can be used for other purposes. Also, the memory needed to store the bitmaps is allocated when necessary (ie. before the suspend) and freed after the resume which is more reasonable. The patch is designed to minimize the amount of changes and there are some nice simplifications and optimizations possible on top of it. I am going to implement them separately in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-30power management: force pm_ops.valid callback to be assignedJohannes Berg
This patch changes the docs and behaviour from "all states valid" to "no states valid" if no .valid callback is assigned. Users of pm_ops that only need mem sleep can assign pm_valid_only_mem without any overhead, others will require more elaborate callbacks. Now that all users of pm_ops have a .valid callback this is a safe thing to do and prevents things from getting messy again as they were before. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Looks-okay-to: Rafael J. Wysocki <rjw@sisk.pl> Cc: <linux-pm@lists.linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30power management: implement pm_ops.valid for everybodyJohannes Berg
Almost all users of pm_ops only support mem sleep, don't check in .valid and don't reject any others in .prepare so users can be confused if they check /sys/power/state, especially when new states are added (these would then result in s-t-r although they're supposed to be something different). This patch implements a generic pm_valid_only_mem function that is then exported for users and puts it to use in almost all existing pm_ops. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: linux-pm@lists.linux-foundation.org Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30rework pm_ops pm_disk_mode, kill misuseJohannes Berg
This patch series cleans up some misconceptions about pm_ops. Some users of the pm_ops structure attempt to use it to stop the user from entering suspend to disk, this, however, is not possible since the user can always use "shutdown" in /sys/power/disk and then the pm_ops are never invoked. Also, platforms that don't support suspend to disk simply should not allow configuring SOFTWARE_SUSPEND (read the help text on it, it only selects suspend to disk and nothing else, all the other stuff depends on PM). The pm_ops structure is actually intended to provide a way to enter platform-defined sleep states (currently supported states are "standby" and "mem" (suspend to ram)) and additionally (if SOFTWARE_SUSPEND is configured) allows a platform to support a platform specific way to enter low-power mode once everything has been saved to disk. This is currently only used by ACPI (S4). This patch: The pm_ops.pm_disk_mode is used in totally bogus ways since nobody really seems to understand what it actually does. This patch clarifies the pm_disk_mode description. It also removes all the arm and sh users that think they can veto suspend to disk via pm_ops; not so since the user can always do echo shutdown > /sys/power/disk, they need to find a better way involving Kconfig or such. ACPI is the only user left with a non-zero pm_disk_mode. The patch also sets the default mode to shutdown again, but when a new pm_ops is registered its pm_disk_mode is selected as default, that way the default stays for ACPI where it is apparently required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: <linux-pm@lists.linux-foundation.org> Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27s2ram: add arch irq disable/enable hooksJohannes Berg
After some more discussion this patch replaces it: From: Johannes Berg <johannes@sipsolutions.net> Subject: suspend: add arch irq disable/enable hooks For powermac, we need to do some things between suspending devices and device_power_off, for example setting the decrementer. This patch allows architectures to define arch_s2ram_{en,dis}able_irqs in their asm/suspend.h to have control over this step. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23power management: no valid states w/o pm_opsJohannes Berg
Change /sys/power/state to not advertise any valid states (except for disk if SOFTWARE_SUSPEND is enabled) when no pm_ops have been set so userspace can easily discover what states should be available. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Macheck <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-11[PATCH] PM: Change code ordering in main.cRafael J. Wysocki
As indicated in a recent thread on Linux-PM, it's necessary to call pm_ops->finish() before devce_resume(), but enable_nonboot_cpus() has to be called before pm_ops->finish() (cf. http://lists.osdl.org/pipermail/linux-pm/2006-November/004164.html). For consistency, it seems reasonable to call disable_nonboot_cpus() after device_suspend(). This way the suspend code will remain symmetrical with respect to the resume code and it may allow us to speed up things in the future by suspending and resuming devices and/or saving the suspend image in many threads. The following series of patches reorders the suspend and resume code so that nonboot CPUs are disabled after devices have been suspended and enabled before the devices are resumed. It also causes pm_ops->finish() to be called after enable_nonboot_cpus() wherever necessary. This patch: Change the ordering of code in kernel/power/main.c so that device_suspend() is called before disable_nonboot_cpus() and pm_ops->finish() is called after enable_nonboot_cpus() and before device_resume(), as indicated by recent discussion on Linux-PM (cf. http://lists.osdl.org/pipermail/linux-pm/2006-November/004164.html). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Greg KH <greg@kroah.com> Cc: Nigel Cunningham <nigel@suspend2.net> Cc: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop free_pages()Christoph Lameter
nr_free_pages is now a simple access to a global variable. Make it a macro instead of a function. The nr_free_pages now requires vmstat.h to be included. There is one occurrence in power management where we need to add the include. Directly refrer to global_page_state() there to clarify why the #include was added. [akpm@osdl.org: arm build fix] [akpm@osdl.org: sparc64 build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-16Pull bugfix into test branchLen Brown
Conflicts: kernel/power/disk.c
2006-12-07[PATCH] Export pm_suspend for the shared APM emulationRalf Baechle
The new shared APM emulation just like its ARM and MIPS predecessors uses pm_suspend() which was only exported on SH. Move export to close to it's definition where it really should be anyway. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] convert pm_sem to a mutexStephen Hemminger
The power management semaphore is only used as mutex, so convert it. [akpm@osdl.org: fix rotten bug] Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-01ACPI: S4: Use "platform" rather than "shutdown" mode by defaultRafael J. Wysocki
It has been reported that on some systems the functionality after a resume from disk is limited if the system is simply powered off during the suspend instead of using the ACPI S4 suspend (aka platform mode). Unfortunately the default is currently to power off the system during the suspend so the users of these systems experience problems after the resume if they don't switch to the platform mode explicitly. This patch makes swsusp use the platform mode by default to avoid such situations. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Stefan Seyfried <seife@suse.de> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
