path: root/kernel/power/power.h
2011-05-17PM / Hibernate: Add sysfs knob to control size of memory for driversRafael J. Wysocki
Martin reports that on his system hibernation occasionally fails due to the lack of memory, because the radeon driver apparently allocates too much of it during the device freeze stage. It turns out that the amount of memory allocated by radeon during hibernation (and presumably during system suspend too) depends on the utilization of the GPU (e.g. hibernating while there are two KDE 4 sessions with compositing enabled causes radeon to allocate more memory than for one KDE 4 session). In principle it should be possible to use image_size to make the memory preallocation mechanism free enough memory for the radeon driver, but in practice it is not easy to guess the right value because of the way the preallocation code uses image_size. For this reason, it seems reasonable to allow users to control the amount of memory reserved for driver allocations made after the hibernate preallocation, which currently is constant and amounts to 1 MB. Introduce a new sysfs file, /sys/power/reserved_size, whose value will be used as the amount of memory to reserve for the post-preallocation reservations made by device drivers, in bytes. For backwards compatibility, set its default (and initial) value to the currently used number (1 MB). References: https://bugzilla.kernel.org/show_bug.cgi?id=34102 Reported-and-tested-by: Martin Steigerwald <Martin@Lichtvoll.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM / Hibernate: Make default image size depend on total RAM sizeRafael J. Wysocki
The default hibernation image size is currently hard coded and euqal to 500 MB, which is not a reasonable default on many contemporary systems. Make it equal 2/5 of the total RAM size (this is slightly below the maximum, i.e. 1/2 of the total RAM size, and seems to be generally suitable). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: M. Vefa Bicakci <bicave@superonline.com>
2010-10-17PM / Hibernate: Compress hibernation image with LZOBojan Smojver
Compress hibernation image with LZO in order to save on I/O and therefore time to hibernate/thaw. [rjw: Added hibernate=nocompress command line option instead of just nocompress which would be confusing, fixed a couple of compiler warnings, fixed kerneldoc comments, minor cleanups.] Signed-off-by: Bojan Smojver <bojan@rexursive.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM / Hibernate: Separate block_ioJiri Slaby
Move block I/O operations to a separate file. It is because it will be used later not only by the swap writer. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM / Hibernate: Snapshot cleanupJiri Slaby
Remove support of reads with offset. This means snapshot_read/write_next now does not accept count parameter. It allows to clean up the functions and snapshot handle which no longer needs to care about offsets. /dev/snapshot handler is converted to simple_{read_from,write_to}_buffer which take care of offsets. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-09-14PM/Hibernate: Do not release preallocated memory unnecessarily (rev. 2)Rafael J. Wysocki
Since the hibernation code is now going to use allocations of memory to make enough room for the image, it can also use the page frames allocated at this stage as image page frames. The low-level hibernation code needs to be rearranged for this purpose, but it allows us to avoid freeing a great number of pages and allocating these same pages once again later, so it generally is worth doing. [rev. 2: Take highmem into account correctly.] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12PM/Hibernate: Rename disk.c to hibernate.cRafael J. Wysocki
Change the name of kernel/power/disk.c to kernel/power/hibernate.c in analogy with the file names introduced by the changes that separated the suspend to RAM and standby funtionality from the common PM functions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz>
2009-06-12PM: Separate suspend to RAM functionality from coreRafael J. Wysocki
Move the suspend to RAM and standby code from kernel/power/main.c to two separate files, kernel/power/suspend.c containing the basic functions and kernel/power/suspend_test.c containing the automatic suspend test facility based on the RTC clock alarm. There are no changes in functionality related to these modifications. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz>
2009-06-12PM/Hibernate: Move memory shrinking to snapshot.c (rev. 2)Rafael J. Wysocki
A future patch is going to modify the memory shrinking code so that it will make memory allocations to free memory instead of using an artificial memory shrinking mechanism for that. For this purpose it is convenient to move swsusp_shrink_memory() from kernel/power/swsusp.c to kernel/power/snapshot.c, because the new memory-shrinking code is going to use things that are local to kernel/power/snapshot.c . [rev. 2: Make some functions static and remove their headers from kernel/power/power.h] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Wu Fengguang <fengguang.wu@intel.com>
2008-10-21[PATCH] propagate mode through swsusp_close()Al Viro
2008-07-26kexec jump: save/restore device stateHuang Ying
This patch implements devices state save/restore before after kexec. This patch together with features in kexec_jump patch can be used for following: - A simple hibernation implementation without ACPI support. You can kexec a hibernating kernel, save the memory image of original system and shutdown the system. When resuming, you restore the memory image of original system via ordinary kexec load then jump back. - Kernel/system debug through making system snapshot. You can make system snapshot, jump back, do some thing and make another system snapshot. - Cooperative multi-kernel/system. With kexec jump, you can switch between several kernels/systems quickly without boot process except the first time. This appears like swap a whole kernel/system out/in. - A general method to call program in physical mode (paging turning off). This can be used to invoke BIOS code under Linux. The following user-space tools can be used with kexec jump: - kexec-tools needs to be patched to support kexec jump. The patches and the precompiled kexec can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-src_git_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-patches_git_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec_git_kh10 - makedumpfile with patches are used as memory image saving tool, it can exclude free pages from original kernel memory image file. The patches and the precompiled makedumpfile can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/makedumpfile/makedumpfile-src_cvs_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/makedumpfile/makedumpfile-patches_cvs_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/makedumpfile/makedumpfile_cvs_kh10 - An initramfs image can be used as the root file system of kexeced kernel. An initramfs image built with "BuildRoot" can be downloaded from the following URL: initramfs image: http://khibernation.sourceforge.net/download/release_v10/initramfs/rootfs_cvs_kh10.gz All user space tools above are included in the initramfs image. Usage example of simple hibernation: 1. Compile and install patched kernel with following options selected: CONFIG_X86_32=y CONFIG_RELOCATABLE=y CONFIG_KEXEC=y CONFIG_CRASH_DUMP=y CONFIG_PM=y CONFIG_HIBERNATION=y CONFIG_KEXEC_JUMP=y 2. Build an initramfs image contains kexec-tool and makedumpfile, or download the pre-built initramfs image, called rootfs.gz in following text. 3. Prepare a partition to save memory image of original kernel, called hibernating partition in following text. 4. Boot kernel compiled in step 1 (kernel A). 5. In the kernel A, load kernel compiled in step 1 (kernel B) with /sbin/kexec. The shell command line can be as follow: /sbin/kexec --load-preserve-context /boot/bzImage --mem-min=0x100000 --mem-max=0xffffff --initrd=rootfs.gz 6. Boot the kernel B with following shell command line: /sbin/kexec -e 7. The kernel B will boot as normal kexec. In kernel B the memory image of kernel A can be saved into hibernating partition as follow: jump_back_entry=`cat /proc/cmdline | tr ' ' '\n' | grep kexec_jump_back_entry | cut -d '='` echo $jump_back_entry > kexec_jump_back_entry cp /proc/vmcore dump.elf Then you can shutdown the machine as normal. 8. Boot kernel compiled in step 1 (kernel C). Use the rootfs.gz as root file system. 9. In kernel C, load the memory image of kernel A as follow: /sbin/kexec -l --args-none --entry=`cat kexec_jump_back_entry` dump.elf 10. Jump back to the kernel A as follow: /sbin/kexec -e Then, kernel A is resumed. Implementation point: To support jumping between two kernels, before jumping to (executing) the new kernel and jumping back to the original kernel, the devices are put into quiescent state, and the state of devices and CPU is saved. After jumping back from kexeced kernel and jumping to the new kernel, the state of devices and CPU are restored accordingly. The devices/CPU state save/restore code of software suspend is called to implement corresponding function. Known issues: - Because the segment number supported by sys_kexec_load is limited, hibernation image with many segments may not be load. This is planned to be eliminated by adding a new flag to sys_kexec_load to make a image can be loaded with multiple sys_kexec_load invoking. Now, only the i386 architecture is supported. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01Suspend: Add config option to disable the freezer if architecture wants thatJohannes Berg
This patch makes the freezer optional for suspend to allow the system to work (or not work) like the original PMU suspend. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Move low level resume to disk.cRafael J. Wysocki
Move the low level restore code to kernel/power/disk.c , since the corresponding low level hibernation code is already there. Make restore fail if device_power_down(PMSG_PRETHAW) returns an error. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PM: Convert PM notifiers to out-of-line codeAlan Stern
This patch (as1008b) converts the PM notifier routines from inline calls to out-of-line code. It also prevents pm_chain_head from being created when CONFIG_PM_SLEEP isn't enabled, and EXPORTs the notifier registration and unregistration routines. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: New testing facility (rev. 2)Rafael J. Wysocki
Make it possible to test the hibernation core code with the help of the /sys/power/pm_test attribute introduced for suspend testing in the previous patch. Writing an appropriate string to this file causes the hibernation code to work in one of the test modes defined as follows: freezer - test the freezing of processes devices - test the freezing of processes and suspending of devices platform - test the freezing of processes, suspending of devices and platform global   control methods(*) processors - test the freezing of processes, suspending of devices, platform global   control methods(*) and the disabling of nonboot CPUs core - test the freezing of processes, suspending of devices, platform global   control methods(*), the disabling of nonboot CPUs and suspending of   platform/system devices (*) - the platform global control methods are only available on ACPI systems       and are only tested if the hibernation mode is set to "platform" Then, if a hibernation is started by normal means, the hibernation core will perform its normal operations up to the point indicated by given test level. Next, it will wait for 5 seconds and carry out the resume operations needed to transition the system back to the fully functional state. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Suspend: Testing facility (rev. 2)Rafael J. Wysocki
Introduce sysfs attribute /sys/power/pm_test allowing one to test the suspend core code.  Namely, writing one of the strings: freezer devices platform processors core to this file causes the suspend code to work in one of the test modes defined as follows: freezer - test the freezing of processes devices - test the freezing of processes and suspending of devices platform - test the freezing of processes, suspending of devices and platform global   control methods(*) processors - test the freezing of processes, suspending of devices, platform global   control methods and the disabling of nonboot CPUs core - test the freezing of processes, suspending of devices, platform global   control methods, the disabling of nonboot CPUs and suspending of   platform/system devices (*) These are ACPI global control methods on ACPI systems Then, if a suspend is started by normal means, the suspend core will perform its normal operations up to the point indicated by given test level.  Next, it will wait for 5 seconds and carry out the resume operations needed to transition the system back to the fully functional state. Writing "none" to /sys/power/pm_test turns the testing off. When open for reading, /sys/power/pm_test contains a space-separated list of all available tests (including "none" that represents the normal functionality) in which the current test level is indicated by square brackets. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Move function prototypes to headerAdrian Bunk
This patch moves the prototypes of count_highmem_pages() and restore_highmem() to kernel/power/power.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Introduce exportable suspend ioctls header (rev. 2)Rafael J. Wysocki
Move the definitions of hibernation ioctls to a separate header file in include/linux, which can be exported to the user space. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Correct definitions of some ioctls (rev. 2)Rafael J. Wysocki
Three ioctl numbers belonging to the hibernation userland interface, SNAPSHOT_ATOMIC_SNAPSHOT, SNAPSHOT_AVAIL_SWAP, SNAPSHOT_GET_SWAP_PAGE, are defined in a wrong way (eg. not portable). Provide new ioctl numbers for these ioctls and mark the existing ones as deprecated. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Mark SNAPSHOT_SET_SWAP_FILE ioctl as deprecated (rev. 2)Rafael J. Wysocki
Mark the SNAPSHOT_SET_SWAP_FILE ioctl belonging to the hibernation userland interface as deprecated. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Rework platform support ioctls (rev. 2)Rafael J. Wysocki
Modify the hibernation userland interface by adding two new ioctls to it, SNAPSHOT_PLATFORM_SUPPORT and SNAPSHOT_POWER_OFF, that can be used, respectively, to switch the hibernation platform support on/off and to make the kernel transition the system to the hibernation state (eg. ACPI S4) using the platform (eg. ACPI) driver. These ioctls are intended to replace the misdesigned SNAPSHOT_PMOPS ioctl, which from now is regarded as obsolete and will be removed in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Introduce SNAPSHOT_GET_IMAGE_SIZE ioctlRafael J. Wysocki
Add a new ioctl, SNAPSHOT_GET_IMAGE_SIZE, returning the size of the (just created) hibernation image, to the hibernation userland interface. This ioctl is necessary so that the userland utilities using the interface need not access the hibernation image header, owned by the kernel, in order to obtain the size of the image. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-01-24Driver Core: switch all dynamic ksets to kobj_sysfs_opsKay Sievers
Switch all dynamically created ksets, that export simple attributes, to kobj_attribute from subsys_attribute. Struct subsys_attribute will be removed. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mike Halcrow <mhalcrow@us.ibm.com> Cc: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/power to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename power_subsys to power_kset to catch all users of the variable and we properly export it so that people don't have to guess that it really is present in the system. The pseries code is wierd, why is it createing /sys/power if CONFIG_PM is disabled? Oh well, stupid big boxes ignoring config options... Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-18Hibernation: Check if ACPI is enabled during restore in the right placeRafael J. Wysocki
The following scenario leads to total confusion of the platform firmware on some boxes (eg. HPC nx6325): * Hibernate with ACPI enabled * Resume passing "acpi=off" to the boot kernel To prevent this from happening it's necessary to check if ACPI is enabled (and enable it if that's not the case) _right_ _after_ control has been transfered from the boot kernel to the image kernel, before device_power_up() is called (ie. with interrupts disabled).  Enabling ACPI after calling device_power_up() turns out to be insufficient. For this reason, introduce new hibernation callback ->leave() that will be executed before device_power_up() by the restored image kernel.  To make it work, it also is necessary to move swsusp_suspend() from swsusp.c to disk.c (it's name is changed to "create_image", which is more up to the point). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Hibernation: Arbitrary boot kernel support - generic codeRafael J. Wysocki
Add the bits needed for supporting arbitrary boot kernels to the common hibernation code. To support arbitrary boot kernels, make it possible to replace the 'struct new_utsname' and the kernel version in the hibernation image header by some architecture specific data that will be used to verify if the image is valid and to restore the image. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Introduce CONFIG_SUSPEND for suspend-to-Ram and standbyRafael J. Wysocki
Introduce CONFIG_SUSPEND representing the ability to enter system sleep states, such as the ACPI S3 state, and allow the user to choose SUSPEND and HIBERNATION independently of each other. Make HOTPLUG_CPU be selected automatically if SUSPEND or HIBERNATION has been chosen and the kernel is intended for SMP systems. Also, introduce CONFIG_PM_SLEEP which is automatically selected if CONFIG_SUSPEND or CONFIG_HIBERNATION is set and use it to select the code needed for both suspend and hibernation. The top-level power management headers and the ACPI code related to suspend and hibernation are modified to use the new definitions (the changes in drivers/acpi/sleep/main.c are, mostly, moving code to reduce the number of ifdefs). There are many other files in which CONFIG_PM can be replaced with CONFIG_PM_SLEEP or even with CONFIG_SUSPEND, but they can be updated in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATIONRafael J. Wysocki
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid confusion (among other things, with CONFIG_SUSPEND introduced in the next patch). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Reduce code duplication between main.c and user.cRafael J. Wysocki
The SNAPSHOT_S2RAM ioctl code is outdated and it should not duplicate the suspend code in kernel/power/main.c. Fix that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: introduce hibernation and suspend notifiersRafael J. Wysocki
Make it possible to register hibernation and suspend notifiers, so that subsystems can perform hibernation-related or suspend-related operations that should not be carried out by device drivers' .suspend() and .resume() routines. [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19swsusp: introduce restore platform operationsRafael J. Wysocki
At least on some machines it is necessary to prepare the ACPI firmware for the restoration of the system memory state from the hibernation image if the "platform" mode of hibernation has been used. Namely, in that cases we need to disable the GPEs before replacing the "boot" kernel with the "frozen" kernel (cf. http://bugzilla.kernel.org/show_bug.cgi?id=7887). After the restore they will be re-enabled by hibernation_ops->finish(), but if the restore fails, they have to be re-enabled by the restore code explicitly. For this purpose we can introduce two additional hibernation operations, called pre_restore() and restore_cleanup() and call them from the restore code path. Still, they should be called if the "platform" mode of hibernation has been used, so we need to pass the information about the hibernation mode from the "frozen" kernel to the "boot" kernel in the image header. Apparently, we can't drop the disabling of GPEs before the restore because of Bug #7887 .  We also can't do it unconditionally, because the GPEs wouldn't have been enabled after a successful restore if the suspend had been done in the 'shutdown' or 'reboot' mode. In principle we could (and probably should) unconditionally disable the GPEs before each snapshot creation *and* before the restore, but then we'd have to unconditionally enable them after the snapshot creation as well as after the restore (or restore failure)   Still, for this purpose we'd need to modify acpi_enter_sleep_state_prep() and acpi_leave_sleep_state() and we'd have to introduce some mechanism synchronizing the disablind/enabling of the GPEs with the device drivers' .suspend()/.resume() routines and with disable_/enable_nonboot_cpus().  However, this would have affected the suspend (ie. s2ram) code as well as the hibernation, which I'd like to avoid in this patch series. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19swsusp: remove code duplication between disk.c and user.cRafael J. Wysocki
Currently, much of the code in kernel/power/disk.c is duplicated in kernel/power/user.c , mainly for historical reasons. By eliminating this code duplication we can reduce the size of user.c quite substantially and remove the maintenance difficulty resulting from it. [bunk@stusta.de: kernel/power/disk.c: make code static] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09PM: Separate hibernation code from suspend codeRafael J. Wysocki
[ With Johannes Berg <johannes@sipsolutions.net> ] Separate the hibernation (aka suspend to disk code) from the other suspend code. In particular: * Remove the definitions related to hibernation from include/linux/pm.h * Introduce struct hibernation_ops and a new hibernate() function to hibernate the system, defined in include/linux/suspend.h * Separate suspend code in kernel/power/main.c from hibernation-related code in kernel/power/disk.c and kernel/power/user.c (with the help of hibernation_ops) * Switch ACPI (the only user of pm_ops.pm_disk_mode) to hibernation_ops Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: free more memoryRafael J. Wysocki
Move the definition of PAGES_FOR_IO to kernel/power/power.h and introduce SPARE_PAGES representing the number of pages that should be freed by the swsusp's memory shrinker in addition to PAGES_FOR_IO so that device drivers can allocate some memory (up to 1 MB total) in their .suspend() routines without causing the suspend to fail. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: use rbtree for tracking allocated swapRafael J. Wysocki
Make swsusp use extents instead of a bitmap to trace swap pages allocated for saving the image (the tracking is only needed in case there's an error, so that the allocated swap pages can be released). This should allow us to reduce the memory usage, practically always, and improve performance. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: use GFP_KERNEL for creating basic data structuresRafael J. Wysocki
Make swsusp call create_basic_memory_bitmaps() before processes are frozen, so that GFP_KERNEL allocations can be made in it. Additionally, ensure that the swsusp's userland interface won't be used while either pm_suspend_disk() or software_resume() is being executed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: do not use page flagsRafael J. Wysocki
Make swsusp use memory bitmaps instead of page flags for marking 'nosave' and free pages. This allows us to 'recycle' two page flags that can be used for other purposes. Also, the memory needed to store the bitmaps is allocated when necessary (ie. before the suspend) and freed after the resume which is more reasonable. The patch is designed to minimize the amount of changes and there are some nice simplifications and optimizations possible on top of it. I am going to implement them separately in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-05Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (231 commits) [PATCH] i386: Don't delete cpu_devs data to identify different x86 types in late_initcall [PATCH] i386: type may be unused [PATCH] i386: Some additional chipset register values validation. [PATCH] i386: Add missing !X86_PAE dependincy to the 2G/2G split. [PATCH] x86-64: Don't exclude asm-offsets.c in Documentation/dontdiff [PATCH] i386: avoid redundant preempt_disable in __unlazy_fpu [PATCH] i386: white space fixes in i387.h [PATCH] i386: Drop noisy e820 debugging printks [PATCH] x86-64: Fix allnoconfig error in genapic_flat.c [PATCH] x86-64: Shut up warnings for vfat compat ioctls on other file systems [PATCH] x86-64: Share identical video.S between i386 and x86-64 [PATCH] x86-64: Remove CONFIG_REORDER [PATCH] x86-64: Print type and size correctly for unknown compat ioctls [PATCH] i386: Remove copy_*_user BUG_ONs for (size < 0) [PATCH] i386: Little cleanups in smpboot.c [PATCH] x86-64: Don't enable NUMA for a single node in K8 NUMA scanning [PATCH] x86: Use RDTSCP for synchronous get_cycles if possible [PATCH] i386: Add X86_FEATURE_RDTSCP [PATCH] i386: Implement X86_FEATURE_SYNC_RDTSC on i386 [PATCH] i386: Implement alternative_io for i386 ... Fix up trivial conflict in include/linux/highmem.h manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02[PATCH] x86: Move swsusp __pa() dependent code to arch portionVivek Goyal
o __pa() should be used only on kernel linearly mapped virtual addresses and not on kernel text and data addresses. o Hibernation code needs to determine the physical address associated with kernel symbol to mark a section boundary which contains pages which don't have to be saved and restored during hibernate/resume operation. o Move this piece of code in arch dependent section. So that architectures which don't have kernel text/data mapped into kernel linearly mapped region can come up with their own ways of determining physical addresses associated with a kernel text. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] convert pm_sem to a mutexStephen Hemminger
The power management semaphore is only used as mutex, so convert it. [akpm@osdl.org: fix rotten bug] Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] swsusp: Measure memory shrinking timeRafael J. Wysocki
Make swsusp measure and print the time needed to shrink memory during the suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@suspend2.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] swsusp: Improve handling of highmemRafael J. Wysocki
Currently swsusp saves the contents of highmem pages by copying them to the normal zone which is quite inefficient (eg. it requires two normal pages to be used for saving one highmem page). This may be improved by using highmem for saving the contents of saveable highmem pages. Namely, during the suspend phase of the suspend-resume cycle we try to allocate as many free highmem pages as there are saveable highmem pages. If there are not enough highmem image pages to store the contents of all of the saveable highmem pages, some of them will be stored in the "normal" memory. Next, we allocate as many free "normal" pages as needed to store the (remaining) image data. We use a memory bitmap to mark the allocated free pages (ie. highmem as well as "normal" image pages). Now, we use another memory bitmap to mark all of the saveable pages (highmem as well as "normal") and the contents of the saveable pages are copied into the image pages. Then, the second bitmap is used to save the pfns corresponding to the saveable pages and the first one is used to save their data. During the resume phase the pfns of the pages that were saveable during the suspend are loaded from the image and used to mark the "unsafe" page frames. Next, we try to allocate as many free highmem page frames as to load all of the image data that had been in the highmem before the suspend and we allocate so many free "normal" page frames that the total number of allocated free pages (highmem and "normal") is equal to the size of the image. While doing this we have to make sure that there will be some extra free "normal" and "safe" page frames for two lists of PBEs constructed later. Now, the image data are loaded, if possible, into their "original" page frames. The image data that cannot be written into their "original" page frames are loaded into "safe" page frames and their "original" kernel virtual addresses, as well as the addresses of the "safe" pages containing their copies, are stored in one of two lists of PBEs. One list of PBEs is for the copies of "normal" suspend pages (ie. "normal" pages that were saveable during the suspend) and it is used in the same way as previously (ie. by the architecture-dependent parts of swsusp). The other list of PBEs is for the copies of highmem suspend pages. The pages in this list are restored (in a reversible way) right before the arch-dependent code is called. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] swsusp: add ioctl for swap files supportRafael J. Wysocki
To be able to use swap files as suspend storage from the userland suspend tools we need an additional ioctl() that will allow us to provide the kernel with both the swap header's offset and the identification of the resume partition. The new ioctl() should be regarded as a replacement for the SNAPSHOT_SET_SWAP_FILE ioctl() that from now on will be considered as obsolete, but has to stay for backwards compatibility of the interface. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] swsusp: add resume_offset command line parameterRafael J. Wysocki
Add the kernel command line parameter "resume_offset=" allowing us to specify the offset, in <PAGE_SIZE> units, from the beginning of the partition pointed to by the "resume=" parameter at which the swap header is located. This offset can be determined, for example, by an application using the FIBMAP ioctl to obtain the swap header's block number for given file. [akpm@osdl.org: we don't know what type sector_t is] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] swsusp: use block device offsets to identify swap locationsRafael J. Wysocki
Make swsusp use block device offsets instead of swap offsets to identify swap locations and make it use the same code paths for writing as well as for reading data. This allows us to use the same code for handling swap files and swap partitions and to simplify the code, eg. by dropping rw_swap_page_sync(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uswsusp: add pmops->{prepare,enter,finish} support (aka "platform mode")Stefan Seyfried
Add an ioctl to the userspace swsusp code that enables the usage of the pmops->prepare, pmops->enter and pmops->finish methods (the in-kernel suspend knows these as "platform method"). These are needed on many machines to (among others) speed up resuming by letting the BIOS skip some steps or let my hp nx5000 recognise the correct ac_adapter state after resume again. It also ensures on many machines, that changed hardware (unplugged AC adapters) gets correctly detected and that kacpid does not run wild after resume. Signed-off-by: Stefan Seyfried <seife@suse.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] swsusp: Use memory bitmaps during resumeRafael J. Wysocki
Make swsusp use memory bitmaps to store its internal information during the resume phase of the suspend-resume cycle. If the pfns of saveable pages are saved during the suspend phase instead of the kernel virtual addresses of these pages, we can use them during the resume phase directly to set the corresponding bits in a memory bitmap. Then, this bitmap is used to mark the page frames corresponding to the pages that were saveable before the suspend (aka "unsafe" page frames). Next, we allocate as many page frames as needed to store the entire suspend image and make sure that there will be some extra free "safe" page frames for the list of PBEs constructed later. Subsequently, the image is loaded and, if possible, the data loaded from it are written into their "original" page frames (ie. the ones they had occupied before the suspend). The image data that cannot be written into their "original" page frames are loaded into "safe" page frames and their "original" kernel virtual addresses, as well as the addresses of the "safe" pages containing their copies, are stored in a list of PBEs. Finally, the list of PBEs is used to copy the remaining image data into their "original" page frames (this is done atomically, by the architecture-dependent parts of swsusp). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] swsusp: Introduce memory bitmapsRafael J. Wysocki
Introduce the memory bitmap data structure and make swsusp use in the suspend phase. The current swsusp's internal data structure is not very efficient from the memory usage point of view, so it seems reasonable to replace it with a data structure that will require less memory, such as a pair of bitmaps. The idea is to use bitmaps that may be allocated as sets of individual pages, so that we can avoid making allocations of order greater than 0. For this reason the memory bitmap structure consists of several linked lists of objects that contain pointers to memory pages with the actual bitmap data. Still, for a typical system all of these lists fit in a single page, so it's reasonable to introduce an additional mechanism allowing us to allocate all of them efficiently without sacrificing the generality of the design. This is done with the help of the chain_allocator structure and associated functions. We need to use two memory bitmaps during the suspend phase of the suspend-resume cycle. One of them is necessary for marking the saveable pages, and the second is used to mark the pages in which to store the copies of them (aka image pages). First, the bitmaps are created and we allocate as many image pages as needed (the corresponding bits in the second bitmap are set as soon as the pages are allocated). Second, the bits corresponding to the saveable pages are set in the first bitmap and the saveable pages are copied to the image pages. Finally, the first bitmap is used to save the kernel virtual addresses of the saveable pages and the second one is used to save the contents of the image pages. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Change the name of pagedir_nosaveRafael J. Wysocki
The name of the pagedir_nosave variable does not make sense any more, so it seems reasonable to change it to something more meaningful. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
