path: root/kernel/power
2007-09-26hibernation doesn't even build on frv - tons of helpers are missingAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31PM: Fix dependencies of CONFIG_SUSPEND and CONFIG_HIBERNATIONRafael J. Wysocki
Dependencies of CONFIG_SUSPEND and CONFIG_HIBERNATION introduced by commit 296699de6bdc717189a331ab6bbe90e05c94db06 "Introduce CONFIG_SUSPEND for suspend-to-Ram and standby" are incorrect, as they don't cover the facts that (1) not all architectures support suspend and (2) SMP hibernation is only possible on X86 and PPC64 (if CONFIG_PPC64_SWSUSP is set). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11Hibernation: do not try to mark invalid PFNs as nosaveRafael J. Wysocki
On some systems some PFNs reported by the early initialization code as 'nosave' may be invalid. If we try to set the corresponding bits in the hibernation bitmap, BUG_ON() in memory_bm_find_bit() will be triggered and the system won't be able to boot (cf. https://bugzilla.novell.com/show_bug.cgi?id=296242). Prevent this from happening by verifying if the 'nosave' PFNs are valid in mark_nosave_pages(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Introduce CONFIG_SUSPEND for suspend-to-Ram and standbyRafael J. Wysocki
Introduce CONFIG_SUSPEND representing the ability to enter system sleep states, such as the ACPI S3 state, and allow the user to choose SUSPEND and HIBERNATION independently of each other. Make HOTPLUG_CPU be selected automatically if SUSPEND or HIBERNATION has been chosen and the kernel is intended for SMP systems. Also, introduce CONFIG_PM_SLEEP which is automatically selected if CONFIG_SUSPEND or CONFIG_HIBERNATION is set and use it to select the code needed for both suspend and hibernation. The top-level power management headers and the ACPI code related to suspend and hibernation are modified to use the new definitions (the changes in drivers/acpi/sleep/main.c are, mostly, moving code to reduce the number of ifdefs). There are many other files in which CONFIG_PM can be replaced with CONFIG_PM_SLEEP or even with CONFIG_SUSPEND, but they can be updated in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATIONRafael J. Wysocki
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid confusion (among other things, with CONFIG_SUSPEND introduced in the next patch). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26Fix ThinkPad T42 poweroff failure introduced by by "PM: Introduce ↵Rafael J. Wysocki
pm_power_off_prepare" Commit bd804eba1c8597cbb7cd5a5f9fe886aae16a079a ("PM: Introduce pm_power_off_prepare") caused problems in the poweroff path, as reported by YOSHIFUJI Hideaki / 吉藤英明. Generally, sysdev_shutdown() should be called after the ACPI preparation for powering the system off. To make it happen, we can separate sysdev_shutdown() from device_shutdown() and call it directly wherever necessary. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21x86: PM_TRACE supportNigel Cunningham
Signed-off-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Integrate beeping flag with existing acpi_sleep flagsPavel Machek
Move "debug during resume from s2ram" into the variable we already use for real-mode flags to simplify code. It also closes nasty trap for the user in acpi_sleep_setup; order of parameters actually mattered there, acpi_sleep=s3_bios,s3_mode doing something different from acpi_sleep=s3_mode,s3_bios. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Optional beeping during resume from suspend to RAMNigel Cunningham
Add a feature allowing the user to make the system beep during a resume from suspend to RAM, on x86_64 and i386. This is useful for the users with broken resume from RAM, so that they can verify if the control reaches the kernel after a wake-up event. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Reduce code duplication between main.c and user.cRafael J. Wysocki
The SNAPSHOT_S2RAM ioctl code is outdated and it should not duplicate the suspend code in kernel/power/main.c. Fix that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: introduce hibernation and suspend notifiersRafael J. Wysocki
Make it possible to register hibernation and suspend notifiers, so that subsystems can perform hibernation-related or suspend-related operations that should not be carried out by device drivers' .suspend() and .resume() routines. [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Freezer: remove redundant check in try_to_freeze_tasksRafael J. Wysocki
We don't need to check if todo is positive before calling time_after() in try_to_freeze_tasks(), because if todo is zero at this point, the loop will be broken anyway due to the while () condition being false. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Freezer: return int from freeze_processesRafael J. Wysocki
Make try_to_freeze_tasks() and freeze_processes() return -EBUSY on failure instead of the number of unfrozen tasks (none of the callers actually uses this number). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Freezer: use __set_current_state in refrigeratorRafael J. Wysocki
Use __set_current_state() as appropriate in refrigerator() instead of accessing current->state directly. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Freezer: avoid freezing kernel threads prematurelyRafael J. Wysocki
Kernel threads should not have TIF_FREEZE set when user space processes are being frozen, since otherwise some of them might be frozen prematurely. To prevent this from happening we can (1) make exit_mm() unset TIF_FREEZE unconditionally just after clearing tsk->mm and (2) make try_to_freeze_tasks() check if p->mm is different from zero and PF_BORROWED_MM is unset in p->flags when user space processes are to be frozen. Namely, when user space processes are being frozen, we only should set TIF_FREEZE for tasks that have p->mm different from NULL and don't have PF_BORROWED_MM set in p->flags. For this reason task_lock() must be used to prevent try_to_freeze_tasks() from racing with use_mm()/unuse_mm(), in which p->mm and p->flags.PF_BORROWED_MM are changed under task_lock(p). Also, we need to prevent the following scenario from happening: * daemonize() is called by a task spawned from a user space code path * freezer checks if the task has p->mm set and the result is positive * task enters exit_mm() and clears its TIF_FREEZE * freezer sets TIF_FREEZE for the task * task calls try_to_freeze() and goes to the refrigerator, which is wrong at that point This requires us to acquire task_lock(p) before p->flags.PF_BORROWED_MM and p->mm are examined and release it after TIF_FREEZE is set for p (or it turns out that TIF_FREEZE should not be set). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Hibernation: prepare to enter the low power stateRafael J. Wysocki
During hibernation we call hibernation_ops->prepare() before creating the image, but then, before saving it, we cancel the power transition by calling hibernation_ops->finish(). Thus prior to calling hibernation_ops->enter() we should let the platform firmware know that we're going to enter the low power state after all. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19swsusp: fix hibernation code orderingRafael J. Wysocki
Change the code ordering so that hibernation_ops->prepare() is called after device_suspend(). This is needed so that we don't violate the ACPI specification, which states that the _PTS and _GTS system-control methods, executed from acpi_sleep_prepare(), ought to be called after devices have been put in low power states. The "Finish" label in hibernation_restore() is moved, because device_suspend() resumes devices if the suspending of them fails and the restore code ordering should reflect the hibernation code ordering. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19swsusp: introduce restore platform operationsRafael J. Wysocki
At least on some machines it is necessary to prepare the ACPI firmware for the restoration of the system memory state from the hibernation image if the "platform" mode of hibernation has been used. Namely, in that cases we need to disable the GPEs before replacing the "boot" kernel with the "frozen" kernel (cf. http://bugzilla.kernel.org/show_bug.cgi?id=7887). After the restore they will be re-enabled by hibernation_ops->finish(), but if the restore fails, they have to be re-enabled by the restore code explicitly. For this purpose we can introduce two additional hibernation operations, called pre_restore() and restore_cleanup() and call them from the restore code path. Still, they should be called if the "platform" mode of hibernation has been used, so we need to pass the information about the hibernation mode from the "frozen" kernel to the "boot" kernel in the image header. Apparently, we can't drop the disabling of GPEs before the restore because of Bug #7887 .  We also can't do it unconditionally, because the GPEs wouldn't have been enabled after a successful restore if the suspend had been done in the 'shutdown' or 'reboot' mode. In principle we could (and probably should) unconditionally disable the GPEs before each snapshot creation *and* before the restore, but then we'd have to unconditionally enable them after the snapshot creation as well as after the restore (or restore failure)   Still, for this purpose we'd need to modify acpi_enter_sleep_state_prep() and acpi_leave_sleep_state() and we'd have to introduce some mechanism synchronizing the disablind/enabling of the GPEs with the device drivers' .suspend()/.resume() routines and with disable_/enable_nonboot_cpus().  However, this would have affected the suspend (ie. s2ram) code as well as the hibernation, which I'd like to avoid in this patch series. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19swsusp: remove code duplication between disk.c and user.cRafael J. Wysocki
Currently, much of the code in kernel/power/disk.c is duplicated in kernel/power/user.c , mainly for historical reasons. By eliminating this code duplication we can reduce the size of user.c quite substantially and remove the maintenance difficulty resulting from it. [bunk@stusta.de: kernel/power/disk.c: make code static] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19swsusp: remove incorrect code from user.cRafael J. Wysocki
In the face of the recent change of suspend code ordering (cf. http://marc.info/?l=linux-acpi&m=117938245931603&w=2) we should also modify the code ordering in swsusp so that hibernation_ops->prepare() is executed after device_suspend(). However, for this purpose it seems reasonable to eliminate the code duplication between kernel/power/disk.c and kernel/power/user.c first. By eliminating it we can reduce the size of user.c quite substantially and remove the maintenance difficulty with making essentially the same changes in two different places. Moreover, we should also remove the calls to "platform" functions from the restore code path, since it doesn't carry out any power transition of the system, but we generally need to disable the GPEs before the restore if the 'platform' hibernation mode has been used. To do this, we can introduce two new hibernation_ops to be used in the restore code. This patch: Make the code hibernation code in kernel/power/user.c be functionally equivalent to the corresponding code in kernel/power/disk.c , as it should be. The calls to the platform functions removed by this patch are incorrect. They should be replaced with some other "platform" invocations that will be introduced in one of the subsequent patches. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Do not require dev spew to get PM_DEBUGBen Collins
In order to enable things like PM_TRACE, you're required to enable PM_DEBUG, which sends a large spew of messages on boot, and often times can overflow dmesg buffer. Create new PM_VERBOSE and shift that to be the option that enables drivers/base/power's messages. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19freezer: run show_state() when freezing times outAndrew Morton
To see which tasks are stuck where. Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18PM: Remove deprecated sysfs filesAlan Stern
This patch (as932) removes the deprecated sysfs .../power/state attribute files. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-01PM: introduce set_target method in pm_opsRafael J. Wysocki
Commit 52ade9b3b97fd3bea42842a056fe0786c28d0555 changed the suspend code ordering to execute pm_ops->prepare() after the device model per-device .suspend() calls in order to fix some ACPI-related issues. Unfortunately, it broke the at91 platform which assumed that pm_ops->prepare() would be called before suspending devices. at91 used pm_ops->prepare() to get notified of the target system sleep state, so that it could use this information while suspending devices. However, with the current suspend code ordering pm_ops->prepare() is called too late for this purpose. Thus, at91 needs an additional method in 'struct pm_ops' that will be used for notifying the platform of the target system sleep state. Moreover, in the future such a method will also be needed by ACPI. This patch adds the .set_target() method to 'struct pm_ops' and makes the suspend code call it, if implemented, before executing the device model per-device .suspend() calls. It also modifies the at91 code to use pm_ops->set_target() instead of pm_ops->prepare(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16swsusp: Fix userland interfaceRafael J. Wysocki
Fix oops caused by 'cat /dev/snapshot', reported by Arkadiusz Miskiewicz, and make it impossible to thaw tasks with the help of the swsusp userland interface while there is a snapshot image ready to save. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23power: Fix sizeof(PAGE_SIZE) typoOGAWA Hirofumi
Fix sizeof(PAGE_SIZE) typo. It should be just PAGE_SIZE for zeroing the swsusp_header. Signed-off-by: OGAWA Hirofumi <hogawa@miraclelinux.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23recalc_sigpending_tsk fixesRoland McGrath
Steve Hawkes discovered a problem where recalc_sigpending_tsk was called in do_sigaction but no signal_wake_up call was made, preventing later signals from waking up blocked threads with TIF_SIGPENDING already set. In fact, the few other calls to recalc_sigpending_tsk outside the signals code are also subject to this problem in other race conditions. This change makes recalc_sigpending_tsk private to the signals code. It changes the outside calls, as well as do_sigaction, to use the new recalc_sigpending_and_wake instead. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: <Steve.Hawkes@motorola.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: move frozen_process() to kernel/power/process.cGautham R Shenoy
Other than refrigerator, no one else calls frozen_process(). So move it from include/linux/freezer.h to kernel/power/process.c. Also, since a task can be marked as frozen by itself, we don't need to pass the (struct task_struct *p) parameter to frozen_process(). Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: take kernel_execve into considerationRafael J. Wysocki
Kernel threads can become userland processes by calling kernel_execve(). In particular, this may happen right after the try_to_freeze_tasks() called with FREEZER_USER_SPACE has returned, so try_to_freeze_tasks() needs to take userspace processes into consideration even if it is called with FREEZER_KERNEL_THREADS. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: fix vfork problemRafael J. Wysocki
Currently try_to_freeze_tasks() has to wait until all of the vforked processes exit and for this reason every user can make it fail. To fix this problem we can introduce the additional process flag PF_FREEZER_SKIP to be used by tasks that do not want to be counted as freezable by the freezer and want to have TIF_FREEZE set nevertheless. Then, this flag can be set by tasks using sys_vfork() before they call wait_for_completion(&vfork) and cleared after they have woken up. After clearing it, the tasks should call try_to_freeze() as soon as possible. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: close potential race between refrigerator and thaw_tasksRafael J. Wysocki
If the freezing of tasks fails and a task is preempted in refrigerator() before calling frozen_process(), then thaw_tasks() may run before this task is frozen. In that case the task will freeze and no one will thaw it. To fix this race we can call freezing(current) in refrigerator() along with frozen_process(current) under the task_lock() which also should be taken in the error path of try_to_freeze_tasks() as well as in thaw_process(). Moreover, if thaw_process() additionally clears TIF_FREEZE for tasks that are not frozen, we can be sure that all tasks are thawed and there are no pending "freeze" requests after thaw_tasks() has run. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17swsusp: fix sysfs interfaceRafael J. Wysocki
The sysfs files /sys/power/disk and /sys/power/state do not work as documented, since they allow the user to write only a few initial characters of the input string to trigger the option (eg. 'echo pl > /sys/power/disk' activates the platform mode of hibernation). Fix it. Special thanks to Peter Moulder <Peter.Moulder@infotech.monash.edu.au> for pointing out the problem. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-16Fix ACPI suspend / device suspend ordering problemLinus Torvalds
In commit e3c7db621bed4afb8e231cb005057f2feb5db557 we fixed the resume ordering, so that the ACPI low-level resume code was called before the actual driver resume was called. However, that broke the nesting logic of suspend and resume, and we continued to suspend the devices _after_ we the ACPI device suspend code was called. That resulted in us saving PCI state for devices that had already been changed by ACPI, and in some cases disabled entirely (causing the PCI save_state to be all-ones). Which in turn caused the wrong state to be written back on resume. This moves the ACPI device suspend to after the device model per-device suspend() calls. This fixes the bogus state save. Thanks to Lukáš Hejtmánek for testing. Acked-by: Lukas Hejtmanek <xhejtman@ics.muni.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Further fixes for the removal of 4level-fixup hack from ppc32 [POWERPC] EEH: log all PCI-X and PCI-E AER registers [POWERPC] EEH: capture and log pci state on error [POWERPC] EEH: Split up long error msg [POWERPC] EEH: log error only after driver notification. [POWERPC] fsl_soc: Make mac_addr const in fs_enet_of_init(). [POWERPC] Don't use SLAB/SLUB for PTE pages [POWERPC] Spufs support for 64K LS mappings on 4K kernels [POWERPC] Add ability to 4K kernel to hash in 64K pages [POWERPC] Introduce address space "slices" [POWERPC] Small fixes & cleanups in segment page size demotion [POWERPC] iSeries: Make HVC_ISERIES the default [POWERPC] iSeries: suppress build warning in lparmap.c [POWERPC] Mark pages that don't exist as nosave [POWERPC] swsusp: Introduce register_nosave_region_late
2007-05-09PM: Separate hibernation code from suspend codeRafael J. Wysocki
[ With Johannes Berg <johannes@sipsolutions.net> ] Separate the hibernation (aka suspend to disk code) from the other suspend code. In particular: * Remove the definitions related to hibernation from include/linux/pm.h * Introduce struct hibernation_ops and a new hibernate() function to hibernate the system, defined in include/linux/suspend.h * Separate suspend code in kernel/power/main.c from hibernation-related code in kernel/power/disk.c and kernel/power/user.c (with the help of hibernation_ops) * Switch ACPI (the only user of pm_ops.pm_disk_mode) to hibernation_ops Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09swsusp: clean up printkAndrew Morton
Remove an inexplicable / Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09[POWERPC] swsusp: Introduce register_nosave_region_lateJohannes Berg
This patch introduces a new register_nosave_region_late function that can be called from initcalls when register_nosave_region can no longer be used because it uses bootmem. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08freezer: task->exit_state should be treated as boleanOleg Nesterov
Except for BUG_ON() checks, we should not use EXIT_XXXX defines outside of exit/wait paths. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'linux-2.6'Paul Mackerras
2007-05-07swsusp: free more memoryRafael J. Wysocki
Move the definition of PAGES_FOR_IO to kernel/power/power.h and introduce SPARE_PAGES representing the number of pages that should be freed by the swsusp's memory shrinker in addition to PAGES_FOR_IO so that device drivers can allocate some memory (up to 1 MB total) in their .suspend() routines without causing the suspend to fail. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: fix snapshot_releaseRafael J. Wysocki
Remove the leftover enable_nonboot_cpus() from snapshot_release(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07kconfig: mention 'hibernation' not just swsuspDavid Brownell
Clarify that "software suspend" is what's called "hibernation" in most user interfaces, shrinking a terminology gap. (Examples include Gnome and MS-Windows.) Also provide a more succinct description of what it does, so you won't have to read the whole novel in Kconfig; and highlights just why the lack of BIOS requirements for swsusp are a big deal. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07power management: change /sys/power/disk displayJohannes Berg
Change /sys/power/disk to display all valid modes as well as the currently selected one in a fashion known from the LED subsystem. This changes userspace API, but it is apparently not used much (we asked some userspace developers) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07remove software_suspend()Johannes Berg
Remove software_suspend() and all its users since pm_suspend(PM_SUSPEND_DISK) should be equivalent and there's no point in having two interfaces for the same thing. The patch also changes the valid_state function to return 0 (false) for PM_SUSPEND_DISK when SOFTWARE_SUSPEND is not configured instead of accepting it and having the whole thing fail later. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: use rbtree for tracking allocated swapRafael J. Wysocki
Make swsusp use extents instead of a bitmap to trace swap pages allocated for saving the image (the tracking is only needed in case there's an error, so that the allocated swap pages can be released). This should allow us to reduce the memory usage, practically always, and improve performance. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: use GFP_KERNEL for creating basic data structuresRafael J. Wysocki
Make swsusp call create_basic_memory_bitmaps() before processes are frozen, so that GFP_KERNEL allocations can be made in it. Additionally, ensure that the swsusp's userland interface won't be used while either pm_suspend_disk() or software_resume() is being executed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: fix error paths in snapshot_openRafael J. Wysocki
We forget to increase device_available if there's an error in snapshot_open(), so the snapshot device cannot be open at all after snapshot_open() has returned an error. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: do not use page flagsRafael J. Wysocki
Make swsusp use memory bitmaps instead of page flags for marking 'nosave' and free pages. This allows us to 'recycle' two page flags that can be used for other purposes. Also, the memory needed to store the bitmaps is allocated when necessary (ie. before the suspend) and freed after the resume which is more reasonable. The patch is designed to minimize the amount of changes and there are some nice simplifications and optimizations possible on top of it. I am going to implement them separately in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
