path: root/kernel/power
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-15Merge branch 'pm-domains' into for-linusRafael J. Wysocki
* pm-domains: (33 commits) ARM / shmobile: Return -EBUSY from A4LC power off if A3RV is active PM / Domains: Take .power_off() error code into account ARM / shmobile: Use genpd_queue_power_off_work() ARM / shmobile: Use pm_genpd_poweroff_unused() PM / Domains: Introduce function to power off all unused PM domains PM / Domains: Queue up power off work only if it is not pending PM / Domains: Improve handling of wakeup devices during system suspend PM / Domains: Do not restore all devices on power off error PM / Domains: Allow callbacks to execute all runtime PM helpers PM / Domains: Do not execute device callbacks under locks PM / Domains: Make failing pm_genpd_prepare() clean up properly PM / Domains: Set device state to "active" during system resume ARM: mach-shmobile: sh7372 A3RV requires A4LC PM / Domains: Export pm_genpd_poweron() in header ARM: mach-shmobile: sh7372 late pm domain off ARM: mach-shmobile: Runtime PM late init callback ARM: mach-shmobile: sh7372 D4 support ARM: mach-shmobile: sh7372 A4MP support ARM: mach-shmobile: sh7372: make sure that fsi is peripheral of spu2 ARM: mach-shmobile: sh7372 A3SG support ...
2011-07-15PM: Improve error code of pm_notifier_call_chain()Akinobu Mita
This enables pm_notifier_call_chain() to get the actual error code in the callback rather than always assume -EINVAL by converting all PM notifier calls to return encapsulate error code with notifier_from_errno(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-15PM / Suspend: Export suspend_set_ops, suspend_valid_only_memKevin Hilman
Some platforms wish to implement their PM core suspend code as modules. To do so, these functions need to be exported to modules. [rjw: Replaced EXPORT_SYMBOL with EXPORT_SYMBOL_GPL] Reported-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-15PM / Suspend: Add .suspend_again() callback to suspend_opsMyungJoo Ham
A system or a device may need to control suspend/wakeup events. It may want to wakeup the system after a predefined amount of time or at a predefined event decided while entering suspend for polling or delayed work. Then, it may want to enter suspend again if its predefined wakeup condition is the only wakeup reason and there is no outstanding events; thus, it does not wakeup the userspace unnecessary or unnecessary devices and keeps suspended as long as possible (saving the power). Enabling a system to wakeup after a specified time can be easily achieved by using RTC. However, to enter suspend again immediately without invoking userland and unrelated devices, we need additional features in the suspend framework. Such need comes from: 1. Monitoring a critical device status without interrupts that can wakeup the system. (in-suspend polling) An example is ambient temperature monitoring that needs to shut down the system or a specific device function if it is too hot or cold. The temperature of a specific device may be needed to be monitored as well; e.g., a charger monitors battery temperature in order to stop charging if overheated. 2. Execute critical "delayed work" at suspend. A driver or a system/board may have a delayed work (or any similar things) that it wants to execute at the requested time. For example, some chargers want to check the battery voltage some time (e.g., 30 seconds) after the battery is fully charged and the charger has stopped. Then, the charger restarts charging if the voltage has dropped more than a threshold, which is smaller than "restart-charger" voltage, which is a threshold to restart charging regardless of the time passed. This patch allows to add "suspend_again" callback at struct platform_suspend_ops and let the "suspend_again" callback return true if the system is required to enter suspend again after the current instance of wakeup. Device-wise suspend_again implemented at dev_pm_ops or syscore is not done because: a) suspend_again feature is usually under platform-wise decision and controls the behavior of the whole platform and b) There are very limited devices related to the usage cases of suspend_again; chargers and temperature sensors are mentioned so far. With suspend_again callback registered at struct platform_suspend_ops suspend_ops in kernel/power/suspend.c with suspend_set_ops by the platform, the suspend framework tries to enter suspend again by looping suspend_enter() if suspend_again has returned true and there has been no errors in the suspending sequence or pending wakeups (by pm_wakeup_pending). Tested at Exynos4-NURI. [rjw: Fixed up kerneldoc comment for suspend_enter().] Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-11doc: Konfig: Documentation/power/{pm => apm-acpi}.txtMichael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-06PM / Hibernate: Fix free_unnecessary_pages()Rafael J. Wysocki
There is a bug in free_unnecessary_pages() that causes it to attempt to free too many pages in some cases, which triggers the BUG_ON() in memory_bm_clear_bit() for copy_bm. Namely, if count_data_pages() is initially greater than alloc_normal, we get to_free_normal equal to 0 and "save" greater from 0. In that case, if the sum of "save" and count_highmem_pages() is greater than alloc_highmem, we subtract a positive number from to_free_normal. Hence, since to_free_normal was 0 before the subtraction and is an unsigned int, the result is converted to a huge positive number that is used as the number of pages to free. Fix this bug by checking if to_free_normal is actually greater than or equal to the number we're going to subtract from it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Matthew Garrett <mjg@redhat.com> Cc: stable@kernel.org
2011-07-02PM: Allow the clocks management code to be used during system suspendRafael J. Wysocki
The common clocks management code in drivers/base/power/clock_ops.c is going to be used during system-wide power transitions as well as for runtime PM, so it shouldn't depend on CONFIG_PM_RUNTIME. However, the suspend/resume functions provided by it for CONFIG_PM_RUNTIME unset, to be used during system-wide power transitions, should not behave in the same way as their counterparts defined for CONFIG_PM_RUNTIME set, because in that case the clocks are managed differently at run time. The names of the functions still contain the word "runtime" after this change, but that is going to be modified by a separate patch later. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-07-02PM / Domains: Support for generic I/O PM domains (v8)Rafael J. Wysocki
Introduce common headers, helper functions and callbacks allowing platforms to use simple generic power domains for runtime power management. Introduce struct generic_pm_domain to be used for representing power domains that each contain a number of devices and may be parent domains or subdomains with respect to other power domains. Among other things, this structure includes callbacks to be provided by platforms for performing specific tasks related to power management (i.e. ->stop_device() may disable a device's clocks, while ->start_device() may enable them, ->power_off() is supposed to remove power from the entire power domain and ->power_on() is supposed to restore it). Introduce functions that can be used as power domain runtime PM callbacks, pm_genpd_runtime_suspend() and pm_genpd_runtime_resume(), as well as helper functions for the initialization of a power domain represented by a struct generic_power_domain object, adding a device to or removing a device from it and adding or removing subdomains. Introduce configuration option CONFIG_PM_GENERIC_DOMAINS to be selected by the platforms that want to use the new code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-21PM: Free memory bitmaps if opening /dev/snapshot failsMichal Kubecek
When opening /dev/snapshot device, snapshot_open() creates memory bitmaps which are freed in snapshot_release(). But if any of the callbacks called by pm_notifier_call_chain() returns NOTIFY_BAD, open() fails, snapshot_release() is never called and bitmaps are not freed. Next attempt to open /dev/snapshot then triggers BUG_ON() check in create_basic_memory_bitmaps(). This happens e.g. when vmwatchdog module is active on s390x. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2011-05-24PM / Hibernate: Update kerneldoc comments in hibernate.cRafael J. Wysocki
Some of the kerneldoc comments in kernel/power/hibernate.c are outdated and some of them don't adhere to the kernel's standards. Update them and make them look in a consistent way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-05-24PM / Hibernate: Remove arch_prepare_suspend()Rafael J. Wysocki
All architectures supporting hibernation define arch_prepare_suspend() as an empty function, so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-24PM / Hibernate: Update some comments in core hibernate codeRafael J. Wysocki
Some comments in the core hibernate code are outdated, some aren't necessary any more and at least one of them is plain wrong. Remove those comments or update them. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-17PM: Allow drivers to allocate memory from .prepare() callbacks safelyRafael J. Wysocki
If device drivers allocate substantial amounts of memory (above 1 MB) in their hibernate .freeze() callbacks (or in their legacy suspend callbcks during hibernation), the subsequent creation of hibernate image may fail due to the lack of memory. This is the case, because the drivers' .freeze() callbacks are executed after the hibernate memory preallocation has been carried out and the preallocated amount of memory may be too small to cover the new driver allocations. Unfortunately, the drivers' .prepare() callbacks also are executed after the hibernate memory preallocation has completed, so they are not suitable for allocating additional memory either. Thus the only way a driver can safely allocate memory during hibernation is to use a hibernate/suspend notifier. However, the notifiers are called before the freezing of user space and the drivers wanting to use them for allocating additional memory may not know how much memory needs to be allocated at that point. To let device drivers overcome this difficulty rework the hibernation sequence so that the memory preallocation is carried out after the drivers' .prepare() callbacks have been executed, so that the .prepare() callbacks can be used for allocating additional memory to be used by the drivers' .freeze() callbacks. Update documentation to match the new behavior of the code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-17PM: Remove CONFIG_PM_VERBOSERafael J. Wysocki
Now that we have CONFIG_DYNAMIC_DEBUG there is no need for yet another flag causing dev_dbg() and pr_debug() statements in the core PM code to produce output. Moreover, CONFIG_PM_VERBOSE causes so much output to be generated that it's not really useful and almost no one sets it. References: https://bugzilla.kernel.org/show_bug.cgi?id=23182 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-17Merge branch 'power-domains' into for-linusRafael J. Wysocki
* power-domains: PM: Fix build issue in clock_ops.c for CONFIG_PM_RUNTIME unset PM: Revert "driver core: platform_bus: allow runtime override of dev_pm_ops" OMAP1 / PM: Use generic clock manipulation routines for runtime PM PM / Runtime: Generic clock manipulation rountines for runtime PM (v6) PM / Runtime: Add subsystem data field to struct dev_pm_info OMAP2+ / PM: move runtime PM implementation to use device power domains PM / Platform: Use generic runtime PM callbacks directly shmobile: Use power domains for platform runtime PM PM: Export platform bus type's default PM callbacks PM: Make power domain callbacks take precedence over subsystem ones
2011-05-17Merge branch 'syscore' into for-linusRafael J. Wysocki
* syscore: PM: Remove sysdev suspend, resume and shutdown operations PM / PowerPC: Use struct syscore_ops instead of sysdevs for PM PM / UNICORE32: Use struct syscore_ops instead of sysdevs for PM PM / AVR32: Use struct syscore_ops instead of sysdevs for PM PM / Blackfin: Use struct syscore_ops instead of sysdevs for PM ARM / Samsung: Use struct syscore_ops for "core" power management ARM / PXA: Use struct syscore_ops for "core" power management ARM / SA1100: Use struct syscore_ops for "core" power management ARM / Integrator: Use struct syscore_ops for core PM ARM / OMAP: Use struct syscore_ops for "core" power management ARM: Use struct syscore_ops instead of sysdevs for PM in common code
2011-05-17Revert "PM / Hibernate: Reduce autotuned default image size"Rafael J. Wysocki
This reverts commit bea3864fb627d110933cfb8babe048b63c4fc76e (PM / Hibernate: Reduce autotuned default image size), because users are now able to resolve the issue this commit was supposed to address in a different way (i.e. by using the new /sys/power/reserved_size interface). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-17PM / Hibernate: Add sysfs knob to control size of memory for driversRafael J. Wysocki
Martin reports that on his system hibernation occasionally fails due to the lack of memory, because the radeon driver apparently allocates too much of it during the device freeze stage. It turns out that the amount of memory allocated by radeon during hibernation (and presumably during system suspend too) depends on the utilization of the GPU (e.g. hibernating while there are two KDE 4 sessions with compositing enabled causes radeon to allocate more memory than for one KDE 4 session). In principle it should be possible to use image_size to make the memory preallocation mechanism free enough memory for the radeon driver, but in practice it is not easy to guess the right value because of the way the preallocation code uses image_size. For this reason, it seems reasonable to allow users to control the amount of memory reserved for driver allocations made after the hibernate preallocation, which currently is constant and amounts to 1 MB. Introduce a new sysfs file, /sys/power/reserved_size, whose value will be used as the amount of memory to reserve for the post-preallocation reservations made by device drivers, in bytes. For backwards compatibility, set its default (and initial) value to the currently used number (1 MB). References: https://bugzilla.kernel.org/show_bug.cgi?id=34102 Reported-and-tested-by: Martin Steigerwald <Martin@Lichtvoll.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-17PM / Suspend: Do not ignore error codes returned by suspend_enter()MyungJoo Ham
The current implementation of suspend-to-RAM returns 0 if there is an error from suspend_enter(), because suspend_devices_and_enter() ignores the return value from suspend_enter(). This patch addresses this issue and properly keep the error return from suspend_enter() and let suspend_devices_and_enter relay the error return. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-11PM: Remove sysdev suspend, resume and shutdown operationsRafael J. Wysocki
Since suspend, resume and shutdown operations in struct sysdev_class and struct sysdev_driver are not used any more, remove them. Also drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used for executing those operations and modify all of their users accordingly. This reduces kernel code size quite a bit and reduces its complexity. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-11PM / Hibernate: Fix ioctl SNAPSHOT_S2RAMRafael J. Wysocki
The SNAPSHOT_S2RAM ioctl used for implementing the feature allowing one to suspend to RAM after creating a hibernation image is currently broken, because it doesn't clear the "ready" flag in the struct snapshot_data object handled by it. As a result, the SNAPSHOT_UNFREEZE doesn't work correctly after SNAPSHOT_S2RAM has returned and the user space hibernate task cannot thaw the other processes as appropriate. Make SNAPSHOT_S2RAM clear data->ready to fix this problem. Tested-by: Alexandre Felipe Muller de Souza <alexandrefm@mandriva.com.br> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2011-05-11PM / Hibernate: Make snapshot_release() restore GFP maskRafael J. Wysocki
If the process using the hibernate user space interface closes /dev/snapshot after creating a hibernation image without thawing tasks, snapshot_release() should call pm_restore_gfp_mask() to restore the GFP mask used before the creation of the image. Make that happen. Tested-by: Alexandre Felipe Muller de Souza <alexandrefm@mandriva.com.br> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2011-05-11PM: Fix warning in pm_restrict_gfp_mask() during SNAPSHOT_S2RAM ioctlRafael J. Wysocki
A warning is printed by pm_restrict_gfp_mask() while the SNAPSHOT_S2RAM ioctl is being executed after creating a hibernation image, because pm_restrict_gfp_mask() has been called once already before the image creation and suspend_devices_and_enter() calls it once again. This happens after commit 452aa6999e6703ffbddd7f6ea124d3 (mm/pm: force GFP_NOIO during suspend/hibernation and resume). To avoid this issue, move pm_restrict_gfp_mask() and pm_restore_gfp_mask() from suspend_devices_and_enter() to its caller in kernel/power/suspend.c. Reported-by: Alexandre Felipe Muller de Souza <alexandrefm@mandriva.com.br> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2011-04-30PM / Runtime: Generic clock manipulation rountines for runtime PM (v6)Rafael J. Wysocki
Many different platforms and subsystems may want to disable device clocks during suspend and enable them during resume which is going to be done in a very similar way in all those cases. For this reason, provide generic routines for the manipulation of device clocks during suspend and resume. Convert the ARM shmobile platform to using the new routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-04-18PM: Fix error code paths executed after failing syscore_suspend()Rafael J. Wysocki
If syscore_suspend() fails in suspend_enter(), create_image() or resume_target_kernel(), it is necessary to call sysdev_resume(), because sysdev_suspend() has been called already and succeeded and we are going to abort the transition. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-11fix XEN_SAVE_RESTORE Kconfig dependenciesShriram Rajagopalan
Make XEN_SAVE_RESTORE select HIBERNATE_CALLBACKS. Remove XEN_SAVE_RESTORE dependency from PM_SLEEP. Signed-off-by: Shriram Rajagopalan <rshriram@cs.ubc.ca> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-04-11PM / Hibernate: Introduce CONFIG_HIBERNATE_CALLBACKSRafael J. Wysocki
Xen save/restore is going to use hibernate device callbacks for quiescing devices and putting them back to normal operations and it would need to select CONFIG_HIBERNATION for this purpose. However, that also would cause the hibernate interfaces for user space to be enabled, which might confuse user space, because the Xen kernels don't support hibernation. Moreover, it would be wasteful, as it would make the Xen kernels include a substantial amount of code that they would never use. To address this issue introduce new power management Kconfig option CONFIG_HIBERNATE_CALLBACKS, such that it will only select the code that is necessary for the hibernate device callbacks to work and make CONFIG_HIBERNATION select it. Then, Xen save/restore will be able to select CONFIG_HIBERNATE_CALLBACKS without dragging the entire hibernate code along with it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Shriram Rajagopalan <rshriram@cs.ubc.ca>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17kernel: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-15PM / Hibernate: Reduce autotuned default image sizeRafael J. Wysocki
The hibernate image size autotuning mechanism sets the default image size to 5/2 of the total system RAM, but it is reported that on some systems device drivers allocate substantial amounts of memory during suspend and the creation of the image fails as a result (too little memory is preallocated). Modify the autotuning mechanism to use 1/3 instead of 2/5 of RAM as the default image size, which is reported to be sufficient for the affected systems. References: https://bugzilla.kernel.org/show_bug.cgi?id=30482 Reported-and-tested-by: Martin Steigerwald <Martin@Lichtvoll.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM / Core: Introduce struct syscore_ops for core subsystems PMRafael J. Wysocki
Some subsystems need to carry out suspend/resume and shutdown operations with one CPU on-line and interrupts disabled. The only way to register such operations is to define a sysdev class and a sysdev specifically for this purpose which is cumbersome and inefficient. Moreover, the arguments taken by sysdev suspend, resume and shutdown callbacks are practically never necessary. For this reason, introduce a simpler interface allowing subsystems to register operations to be executed very late during system suspend and shutdown and very early during resume in the form of strcut syscore_ops objects. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-15PM: Simplify kernel/power/KconfigJan Beulich
'n' defaults are pretty pointless and actually bogus when used with prompt-less config options. The "bool"/"default y" pair with no prompt can be expressed more compactly using def_bool. [rjw: Rebased on top of earlier patches modifying this file.] Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Drop pm_flags that is not necessaryRafael J. Wysocki
The variable pm_flags is used to prevent APM from being enabled along with ACPI, which would lead to problems. However, acpi_init() is always called before apm_init() and after acpi_init() has returned, it is known whether or not ACPI will be used. Namely, if acpi_disabled is not set after acpi_init() has returned, this means that ACPI is enabled. Thus, it is sufficient to check acpi_disabled in apm_init() to prevent APM from being enabled in parallel with ACPI. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Len Brown <len.brown@intel.com>
2011-03-15PM: Clean up PM_TRACE dependencies and drop unnecessary Kconfig optionRafael J. Wysocki
CONFIG_PM_SLEEP_ADVANCED_DEBUG is not used any more, so drop it and CONFIG_CAN_PM_TRACE need not depend on EXPERIMENTAL, so remove that dependency. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Reorder power management Kconfig optionsRafael J. Wysocki
Reorder configuration options in kernel/power/Kconfig so that the options depended on are at the top of the list. This patch doesn't introduce any functional changes. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Make CONFIG_PM depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME)Rafael J. Wysocki
From the users' point of view CONFIG_PM is really only used for making it possible to set CONFIG_SUSPEND, CONFIG_HIBERNATION, CONFIG_PM_RUNTIME and (surprisingly enough) CONFIG_XEN_SAVE_RESTORE (CONFIG_PM_OPP also depends on CONFIG_PM, but quite artificially). However, both CONFIG_SUSPEND and CONFIG_HIBERNATION require platform support (independent of CONFIG_PM) and it is not quite obvious that CONFIG_PM has to be set for CONFIG_XEN_SAVE_RESTORE to be available. Thus, from the users' point of view, it would be more logical to automatically select CONFIG_PM if any of the above options depending on it are set. Make CONFIG_PM depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME), which will cause it to be selected when any of CONFIG_SUSPEND, CONFIG_HIBERNATION, CONFIG_PM_RUNTIME, CONFIG_XEN_SAVE_RESTORE is set and will clarify its meaning. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM / ACPI: Remove references to pm_flags from bus.cRafael J. Wysocki
If direct references to pm_flags are removed from drivers/acpi/bus.c, CONFIG_ACPI will not need to depend on CONFIG_PM any more. Make that happen. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Len Brown <len.brown@intel.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-18Merge branch 'fixes-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq * 'fixes-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: make sure MAYDAY_INITIAL_TIMEOUT is at least 2 jiffies long workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable' workqueue: wake up a worker when a rescuer is leaving a gcwq
2011-02-16PM / Hibernate: Return error code when alloc_image_page() failsStanislaw Gruszka
Currently we return 0 in swsusp_alloc() when alloc_image_page() fails. Fix that. Also remove unneeded "error" variable since the only useful value of error is -ENOMEM. [rjw: Fixed up the changelog and changed subject.] Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Cc: stable@kernel.org Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-16workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'Tejun Heo
There are two spellings in use for 'freeze' + 'able' - 'freezable' and 'freezeable'. The former is the more prominent one. The latter is mostly used by workqueue and in a few other odd places. Unify the spelling to 'freezable'. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Steven Whitehouse <swhiteho@redhat.com>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: spi / PM: Support dev_pm_ops PM: Prototype the pm_generic_ operations PM / Runtime: Generic resume shouldn't set RPM_ACTIVE unconditionally PM: Use dev_name() in core device suspend and resume routines PM: Permit registration of parentless devices during system suspend PM: Replace the device power.status field with a bit field PM: Remove redundant checks from core device resume routines PM: Use a different list of devices for each stage of device suspend PM: Avoid compiler warning in pm_noirq_op() PM: Use pm_wakeup_pending() in __device_suspend() PM / Wakeup: Replace pm_check_wakeup_events() with pm_wakeup_pending() PM: Prevent dpm_prepare() from returning errors unnecessarily PM: Fix references to basic-pm-debugging.txt in drivers-testing.txt PM / Runtime: Add synchronous runtime interface for interrupt handlers (v3) PM / Hibernate: When failed, in_suspend should be reset PM / Hibernate: hibernation_ops->leave should be checked too Freezer: Fix a race during freezing of TASK_STOPPED tasks PM: Use proper ccflag flag in kernel/power/Makefile PM / Runtime: Fix comments to match runtime callback code
2011-01-07PM / ACPI: Move NVS saving and restoring code to drivers/acpiRafael J. Wysocki
The saving of the ACPI NVS area during hibernation and suspend and restoring it during the subsequent resume is entirely specific to ACPI, so move it to drivers/acpi and drop the CONFIG_SUSPEND_NVS configuration option which is redundant. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
