This patch introduces generic code to perform PM domain look-up using
device tree and automatically bind devices to their PM domains.
Generic device tree bindings are introduced to specify PM domains of
devices in their device tree nodes.
Backwards compatibility with legacy Samsung-specific PM domain bindings
is provided, but for now the new code is not compiled when
CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code.
This will change as soon as the Exynos PM domain code gets converted to
use the generic framework in further patch.
This patch was originally submitted by Tomasz Figa when he was employed
by Samsung.
Link: http://marc.info/?l=linux-pm&m=139955349702152&w=2
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Rob Herring <robh@kernel.org>
Tested-by: Philipp Zabel <p.zabel@pengutronix.de>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
(cherry picked from commit aa42240ab2544a8bcb2efb400193826f57f3175e)
(cherry picked from commit 4a2d7a846761e3b86e08b903e5a1a088686e2181)
This reverts commit 4aa055cb0634bc8d0389070104fe6aa7cfa99b8c.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit e599f64de890a60a3b9884dd5838c43472f145e2)
This patch introduces generic code to perform power domain look-up using
device tree and automatically bind devices to their power domains.
Generic device tree binding is introduced to specify power domains of
Backwards compatibility with legacy Samsung-specific power domain
bindings is provided, but for now the new code is not compiled when
CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code. This
will change as soon as Exynos power domain code gets converted to use
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
Reviewed-by: Philipp Zabel <philipp.zabel@gmail.com>
[on i.MX6 GK802]
Tested-by: Philipp Zabel <philipp.zabel@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
[shawn.guo: http://thread.gmane.org/gmane.linux.kernel.samsung-soc/31029]
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
commit 94fb823fcb4892614f57e59601bb9d4920f24711 upstream.
If a device's dev_pm_ops::freeze callback fails during the QUIESCE
phase, we don't rollback things correctly calling the thaw and complete
callbacks. This could leave some devices in a suspended state in case of
an error during resuming from hibernation.
Signed-off-by: Imre Deak <imre.deak@intel.com>
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream.
PM freezer relies on having all tasks frozen by the time devices are
getting frozen so that no task will touch them while they are getting
frozen. But OOM killer is allowed to kill an already frozen task in
order to handle OOM situtation. In order to protect from late wake ups
OOM killer is disabled after all tasks are frozen. This, however, still
keeps a window open when a killed task didn't manage to die by the time
freeze_processes finishes.
Reduce the race window by checking all tasks after OOM killer has been
disabled. This is still not race free completely unfortunately because
oom_killer_disable cannot stop an already ongoing OOM killer so a task
might still wake up from the fridge and get killed without
freeze_processes noticing. Full synchronization of OOM and freezer is,
however, too heavy weight for this highly unlikely case.
Introduce and check oom_kills counter which gets incremented early when
the allocator enters __alloc_pages_may_oom path and only check all the
tasks if the counter changes during the freezing attempt. The counter
is updated so early to reduce the race window since allocator checked
oom_killer_disabled which is set by PM-freezing code. A false positive
will push the PM-freezer into a slow path but that is not a big deal.
Changes since v1
- push the re-check loop out of freeze_processes into
check_frozen_processes and invert the condition to make the code more
readable as per Rafael
Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring)
commit 43e8317b0bba1d6eb85f38a4a233d82d7c20d732 upstream.
Use the observation that, for platform-dependent sleep states
(PM_SUSPEND_STANDBY, PM_SUSPEND_MEM), a given state is either
always supported or always unsupported and store that information
in pm_states[] instead of calling valid_state() every time we
need to check it.
Also do not use valid_state() for PM_SUSPEND_FREEZE, which is always
valid, and move the pm_test_level validity check for PM_SUSPEND_FREEZE
directly into enter_state().
Cc: Brian Norris <computersforpeace@gmail.com>
commit 27ddcc6596e50cb8f03d2e83248897667811d8f6 upstream.
To allow sleep states corresponding to the "mem", "standby" and
"freeze" lables to be different from the pm_states[] indexes of
those strings, introduce struct pm_sleep_state, consisting of
a string label and a state number, and turn pm_states[] into an
array of objects of that type.
This modification should not lead to any functional changes.
commit 4320f6b1d9db4ca912c5eb6ecb328b2e090e1586 upstream.
The commit [247bc037: PM / Sleep: Mitigate race between the freezer
and request_firmware()] introduced the finer state control, but it
also leads to a new bug; for example, a bug report regarding the
firmware loading of intel BT device at suspend/resume:
https://bugzilla.novell.com/show_bug.cgi?id=873790
The root cause seems to be a small window between the process resume
and the clear of usermodehelper lock. The request_firmware() function
checks the UMH lock and gives up when it's in UMH_DISABLE state. This
is for avoiding the invalid f/w loading during suspend/resume phase.
The problem is, however, that usermodehelper_enable() is called at the
end of thaw_processes(). Thus, a thawed process in between can kick
off the f/w loader code path (in this case, via btusb_setup_intel())
even before the call of usermodehelper_enable(). Then
usermodehelper_read_trylock() returns an error and request_firmware()
spews WARN_ON() in the end.
This oneliner patch fixes the issue just by setting to UMH_FREEZING
state again before restarting tasks, so that the call of
request_firmware() will be blocked until the end of this function
instead of returning an error.
Fixes: 247bc0374254 (PM / Sleep: Mitigate race between the freezer and request_firmware())
Link: https://bugzilla.novell.com/show_bug.cgi?id=873790
arch/arm/mach-tegra/pm.c, kernel/power/console.c and mm/vmpressure.c
were somehow getting slab.h indirectly through cgroup.h which in turn
was getting it indirectly through xattr.h. A scheduled cgroup change
drops xattr.h inclusion from cgroup.h and breaks compilation of these
three files. Add explicit slab.h includes to the three files.
A pending cgroup patch depends on this change and it'd be great if
this can be routed through cgroup/for-3.14-fixes branch.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: linux-tegra@vger.kernel.org
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: linux-pm@vger.kernel.org
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: cgroups@vger.kernel.org
Pull core block IO changes from Jens Axboe:
"The major piece in here is the immutable bio_ve series from Kent, the
rest is fairly minor. It was supposed to go in last round, but
various issues pushed it to this release instead. The pull request
contains:
- Various smaller blk-mq fixes from different folks. Nothing major
here, just minor fixes and cleanups.
- Fix for a memory leak in the error path in the block ioctl code
from Christian Engelmayer.
- Header export fix from CaiZhiyong.
- Finally the immutable biovec changes from Kent Overstreet. This
enables some nice future work on making arbitrarily sized bios
possible, and splitting more efficient. Related fixes to immutable
bio_vecs:
- dm-cache immutable fixup from Mike Snitzer.
- btrfs immutable fixup from Muthu Kumar.
- bio-integrity fix from Nic Bellinger, which is also going to stable"
* 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits)
xtensa: fixup simdisk driver to work with immutable bio_vecs
block/blk-mq-cpu.c: use hotcpu_notifier()
blk-mq: for_each_* macro correctness
block: Fix memory leak in rw_copy_check_uvector() handling
bio-integrity: Fix bio_integrity_verify segment start bug
block: remove unrelated header files and export symbol
blk-mq: uses page->list incorrectly
blk-mq: use __smp_call_function_single directly
btrfs: fix missing increment of bi_remaining
Revert "block: Warn and free bio if bi_end_io is not set"
blk-mq: fix initializing request's start time
block: blk-mq: don't export blk_mq_free_queue()
block: blk-mq: make blk_sync_queue support mq
block: blk-mq: support draining mq queue
dm cache: increment bi_remaining when bi_end_io is restored
block: fixup for generic bio chaining
block: Really silence spurious compiler warnings
block: Silence spurious compiler warnings
block: Kill bio_pair_split()
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
Switch to memblock interfaces for early memory allocator instead of
bootmem allocator. No functional change in beahvior than what it is in
current code from bootmem users points of view.
Archs already converted to NO_BOOTMEM now directly use memblock
interfaces instead of bootmem wrappers build on top of memblock. And
the archs which still uses bootmem, these new apis just fallback to
exiting bootmem APIs.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Since create_image() only executes platform_leave() if in_suspend is
not set, enable_nonboot_cpus() is run by it with EC transactions
blocked (on ACPI systems) in the image creation code path (that is,
for in_suspend set), which may cause CPU online to fail for the CPUs
in question. In particular, this causes the acpi_cpufreq driver's
initialization to fail for those CPUs on some systems with the
following dmesg:
cpufreq: adding CPU 1
acpi_cpufreq_cpu_init
cpufreq: FREQ: 1401000 - CPU: 0
ACPI Exception: AE_BAD_PARAMETER, Returned by Handler for [EmbeddedControl] (20130725/evregion-287)
ACPI Error: Method parse/execution failed [\_SB_.PCI0.LPC_.EC__.LPMD] (Node ffff88023249ab28), AE_BAD_PARAMETER (20130725/psparse-536)
ACPI Error: Method parse/execution failed [\_PR_.CPU0._PPC] (Node ffff88023270e3f8), AE_BAD_PARAMETER (20130725/psparse-536)
ACPI Error: Method parse/execution failed [\_PR_.CPU1._PPC] (Node ffff88023270e290), AE_BAD_PARAMETER (20130725/psparse-536)
ACPI Exception: AE_BAD_PARAMETER, Evaluating _PPC (20130725/processor_perflib-140)
cpufreq: initialization failed
CPU1 is up
To fix this problem, modify create_image() to execute platform_leave()
unconditionally. [rjw: This shouldn't lead to any significant side
effects on ACPI systems.]
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[rjw: Changelog]
Needed to bring blk-mq uptodate, since changes have been going in
since for-3.14/core was established.
Fixup merge issues related to the immutable biovec changes.
block/blk-flush.c
fs/btrfs/check-integrity.c
fs/btrfs/extent_io.c
fs/btrfs/scrub.c
fs/logfs/dev_bdev.c
kmemleak reported a memory leak as below.
unreferenced object 0xffff880118f14700 (size 32):
comm "swapper/0", pid 1, jiffies 4294877401 (age 123.283s)
hex dump (first 32 bytes):
00 01 10 00 00 00 ad de 00 02 20 00 00 00 ad de .......... .....
00 d4 d2 18 01 88 ff ff 01 00 00 00 00 04 00 00 ................
backtrace:
[<ffffffff814edb1e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811889dc>] kmem_cache_alloc_trace+0x1ec/0x260
[<ffffffff810aba66>] pm_vt_switch_required+0x76/0xb0
[<ffffffff812f39f5>] register_framebuffer+0x195/0x320
[<ffffffff8130af18>] efifb_probe+0x718/0x780
[<ffffffff81391495>] platform_drv_probe+0x45/0xb0
[<ffffffff8138f407>] driver_probe_device+0x87/0x3a0
[<ffffffff8138f7f3>] __driver_attach+0x93/0xa0
[<ffffffff8138d413>] bus_for_each_dev+0x63/0xa0
[<ffffffff8138ee5e>] driver_attach+0x1e/0x20
[<ffffffff8138ea40>] bus_add_driver+0x180/0x250
[<ffffffff8138fe74>] driver_register+0x64/0xf0
[<ffffffff813913ba>] __platform_driver_register+0x4a/0x50
[<ffffffff8191e028>] efifb_driver_init+0x12/0x14
[<ffffffff8100214a>] do_one_initcall+0xfa/0x1b0
[<ffffffff818e40e0>] kernel_init_freeable+0x17b/0x201
In pm_vt_switch_required(), "entry" variable is allocated via kmalloc().
So, in pm_vt_switch_unregister(), it needs to call kfree() when object
is deleted from list.
Signed-off-by: Masami Ichikawa <masami256@gmail.com>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
To support the ability to implement PM hibernation code as modules
the hibernation_set_ops function requires to be exported.
Similar solution already available for suspend_set_ops
(please refer to commit a5e4fd8783a2bec861ecf1138cdc042269ff59aa).
Signed-off-by: Leonardo Potenza <leonardo.potenza@intel.com>
Signed-off-by: Edwin Verplanke <edwin.verplanke@intel.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Immutable biovecs are going to require an explicit iterator. To
implement immutable bvecs, a later patch is going to add a bi_bvec_done
member to this struct; for now, this patch effectively just renames
things.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Alex Elder <elder@inktank.com>
Cc: ceph-devel@vger.kernel.org
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: dm-devel@redhat.com
Cc: linux390@de.ibm.com
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: xfs@oss.sgi.com
Cc: Len Brown <len.brown@intel.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: "Roger Pau Monné" <roger.pau@citrix.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Jerome Marchand <jmarchand@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Peng Tao <tao.peng@emc.com>
Cc: Andy Adamson <andros@netapp.com>
Cc: fanchaoting <fanchaoting@cn.fujitsu.com>
Cc: Jie Liu <jeff.liu@oracle.com>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Pankaj Kumar <pankaj.km@samsung.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Mel Gorman <mgorman@suse.de>6
* pm-sleep:
PM / Hibernate: Do not crash kernel in free_basic_memory_bitmaps()
I have received a report about the BUG_ON() in free_basic_memory_bitmaps()
triggering mysteriously during an aborted s2disk hibernation attempt.
The only way I can explain that is that /dev/snapshot was first
opened for writing (resume mode), then closed and then opened again
for reading and closed again without freezing tasks. In that case
the first invocation of snapshot_open() would set the free_bitmaps
flag in snapshot_state, which is a static variable. That flag
wouldn't be cleared later and the second invocation of snapshot_open()
would just leave it like that, so the subsequent snapshot_release()
would see data->frozen set and free_basic_memory_bitmaps() would be
called unnecessarily.
To prevent that from happening clear data->free_bitmaps in
snapshot_open() when the file is being opened for reading (hibernate
mode).
In addition to that, replace the BUG_ON() in free_basic_memory_bitmaps()
with a WARN_ON() as the kernel can continue just fine if the condition
checked by that macro occurs.
Fixes: aab172891542 (PM / hibernate: Fix user space driven resume regression)
Reported-by: Oliver Lorenz <olli@olorenz.org>
Cc: 3.12+ <stable@vger.kernel.org> # 3.12+
* pm-sleep:
PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
When system has a lot of highmem (e.g. 16GiB using a 32 bits kernel),
the code to calculate how much memory we need to preallocate in
normal zone may cause overflow. As Leon has analysed:
It looks that during computing 'alloc' variable there is overflow:
alloc = (3943404 - 1970542) - 1978280 = -5418 (signed)
And this function goes to err_out.
Fix this by avoiding that overflow.
References: https://bugzilla.kernel.org/show_bug.cgi?id=60817
Reported-and-tested-by: Leon Drugi <eyak@wp.pl>
Cc: All applicable <stable@vger.kernel.org>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
* pm-sleep:
PM / Hibernate: Use bool for boolean fields of struct snapshot_data
PM / Sleep: Detect device suspend/resume lockup and log event
* pm-qos:
PM / QoS: simplify pm_qos_power_write()
software_resume is being called after deferred_probe_initcall in
drivers base. If the probing of the device that contains the resume
image is deferred, and the system has been instructed to wait for
it to show up, this wait will occur in software_resume. This causes
a deadlock.
Move software_resume into late_initcall_sync so that it happens
after all the other late_initcalls.
Signed-off-by: Russ Dill <Russ.Dill@ti.com>
Acked-by: Pavel Machek <Pavel@ucw.cz>
The snapshot_data structure used internally by the hibernate user
space interface code in user.c has three char fields that are used
to store boolean values. Change their data type to bool and use
true and false instead of 1 and 0, respectively, in assignments
involving those fields.
Rather than hard-lock the kernel, dump the suspend/resume thread stack
and panic() to capture a message in pstore when a driver takes too long
to suspend/resume. Default suspend/resume watchdog timeout is set to 12
seconds to be longer than the usbhid 10 second timeout, but could be
changed at compile time.
Exclude from the watchdog the time spent waiting for children that
are resumed asynchronously and time every device, whether or not they
resumed synchronously.
This patch is targeted for mobile devices where a suspend/resume lockup
could cause a system reboot. Information about failing device can be
retrieved in subsequent boot session by mounting pstore and inspecting
the log. Laptops with EFI-enabled pstore could also benefit from
this feature.
The hardware watchdog timer is likely suspended during this time and
couldn't be relied upon. The soft-lockup detector would eventually tell
that tasks are not scheduled, but would provide little context as to why.
The patch hence uses system timer and assumes it is still active while the
devices are suspended/resumed.
This feature can be enabled/disabled during kernel configuration.
This change is based on earlier work by San Mehat.
Signed-off-by: Benoit Goby <benoit@android.com>
Signed-off-by: Zoran Markovic <zoran.markovic@linaro.org>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Let kstrtos32_from_user() do the necessary calls and checks.
Recent commit 8fd37a4 (PM / hibernate: Create memory bitmaps after
freezing user space) broke the resume part of the user space driven
hibernation (s2disk), because I forgot that the resume utility
loaded the image into memory without freezing user space (it still
freezes tasks after loading the image). This means that during user
space driven resume we need to create the memory bitmaps at the
"device open" time rather than at the "freeze tasks" time, so make
that happen (that's a special case anyway, so it needs to be treated
in a special way).
Reported-and-tested-by: Ronald <ronald645@gmail.com>
Pull ACPI and power management fixes from Rafael Wysocki:
"All of these commits are fixes that have emerged recently and some of
them fix bugs introduced during this merge window.
Specifics:
1) ACPI-based PCI hotplug (ACPIPHP) fixes related to spurious events
After the recent ACPIPHP changes we've seen some interesting
breakage on a system that triggers device check notifications
during boot for non-existing devices. Although those
notifications are really spurious, we should be able to deal with
them nevertheless and that shouldn't introduce too much overhead.
Four commits to make that work properly.
2) Memory hotplug and hibernation mutual exclusion rework
This was maent to be a cleanup, but it happens to fix a classical
ABBA deadlock between system suspend/hibernation and ACPI memory
hotplug which is possible if they are started roughly at the same
time. Three commits rework memory hotplug so that it doesn't
acquire pm_mutex and make hibernation use device_hotplug_lock
which prevents it from racing with memory hotplug.
3) ACPI Intel LPSS (Low-Power Subsystem) driver crash fix
The ACPI LPSS driver crashes during boot on Apple Macbook Air with
Haswell that has slightly unusual BIOS configuration in which one
of the LPSS device's _CRS method doesn't return all of the
information expected by the driver. Fix from Mika Westerberg, for
stable.
4) ACPICA fix related to Store->ArgX operation
AML interpreter fix for obscure breakage that causes AML to be
executed incorrectly on some machines (observed in practice).
From Bob Moore.
5) ACPI core fix for PCI ACPI device objects lookup
There still are cases in which there is more than one ACPI device
object matching a given PCI device and we don't choose the one
that the BIOS expects us to choose, so this makes the lookup take
more criteria into account in those cases.
6) Fix to prevent cpuidle from crashing in some rare cases
If the result of cpuidle_get_driver() is NULL, which can happen on
some systems, cpuidle_driver_ref() will crash trying to use that
pointer and the Daniel Fu's fix prevents that from happening.
7) cpufreq fixes related to CPU hotplug
Stephen Boyd reported a number of concurrency problems with
cpufreq related to CPU hotplug which are addressed by a series of
fixes from Srivatsa S Bhat and Viresh Kumar.
8) cpufreq fix for time conversion in time_in_state attribute
Time conversion carried out by cpufreq when user space attempts to
read /sys/devices/system/cpu/cpu*/cpufreq/stats/time_in_state
won't work correcty if cputime_t doesn't map directly to jiffies.
Fix from Andreas Schwab.
9) Revert of a troublesome cpufreq commit
Commit 7c30ed5 (cpufreq: make sure frequency transitions are
serialized) was intended to address some known concurrency
problems in cpufreq related to the ordering of transitions, but
unfortunately it introduced several problems of its own, so I
decided to revert it now and address the original problems later
in a more robust way.
10) Intel Haswell CPU models for intel_pstate from Nell Hardcastle.
11) cpufreq fixes related to system suspend/resume
The recent cpufreq changes that made it preserve CPU sysfs
attributes over suspend/resume cycles introduced a possible NULL
pointer dereference that caused it to crash during the second
attempt to suspend. Three commits from Srivatsa S Bhat fix that
problem and a couple of related issues.
12) cpufreq locking fix
cpufreq_policy_restore() should acquire the lock for reading, but
it acquires it for writing. Fix from Lan Tianyu"
* tag 'pm+acpi-fixes-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (25 commits)
cpufreq: Acquire the lock in cpufreq_policy_restore() for reading
cpufreq: Prevent problems in update_policy_cpu() if last_cpu == new_cpu
cpufreq: Restructure if/else block to avoid unintended behavior
cpufreq: Fix crash in cpufreq-stats during suspend/resume
intel_pstate: Add Haswell CPU models
Revert "cpufreq: make sure frequency transitions are serialized"
cpufreq: Use signed type for 'ret' variable, to store negative error values
cpufreq: Remove temporary fix for race between CPU hotplug and sysfs-writes
cpufreq: Synchronize the cpufreq store_*() routines with CPU hotplug
cpufreq: Invoke __cpufreq_remove_dev_finish() after releasing cpu_hotplug.lock
cpufreq: Split __cpufreq_remove_dev() into two parts
cpufreq: Fix wrong time unit conversion
cpufreq: serialize calls to __cpufreq_governor()
cpufreq: don't allow governor limits to be changed when it is disabled
ACPI / bind: Prefer device objects with _STA to those without it
ACPI / hotplug / PCI: Avoid parent bus rescans on spurious device checks
ACPI / hotplug / PCI: Use _OST to notify firmware about notify status
ACPI / hotplug / PCI: Avoid doing too much for spurious notifies
ACPICA: Fix for a Store->ArgX when ArgX contains a reference to a field.
ACPI / hotplug / PCI: Don't trim devices before scanning the namespace
Use "zone_end_pfn()" instead of "zone->zone_start_pfn + zone->spanned_pages".
Simplify the code, no functional change.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: Cody P Schafer <cody@linux.vnet.ibm.com>
* acpi-hotplug:
PM / hibernate / memory hotplug: Rework mutual exclusion
PM / hibernate: Create memory bitmaps after freezing user space
ACPI / scan: Change ordering of locks for device hotplug
Pull x86/asmlinkage changes from Ingo Molnar:
"As a preparation for Andi Kleen's LTO patchset (link time
optimizations using GCC's -flto which build time optimization has
steadily increased in quality over the past few years and might
eventually be usable for the kernel too) this tree includes a handful
of preparatory patches that make function calling convention
annotations consistent again:
- Mark every function without arguments (or 64bit only) that is used
by assembly code with asmlinkage()
- Mark every function with parameters or variables that is used by
assembly code as __visible.
For the vanilla kernel this has documentation, consistency and
debuggability advantages, for the time being"
* 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/asmlinkage: Fix warning in xen asmlinkage change
x86, asmlinkage, vdso: Mark vdso variables __visible
x86, asmlinkage, power: Make various symbols used by the suspend asm code visible
x86, asmlinkage: Make dump_stack visible
x86, asmlinkage: Make 64bit checksum functions visible
x86, asmlinkage, paravirt: Add __visible/asmlinkage to xen paravirt ops
x86, asmlinkage, apm: Make APM data structure used from assembler visible
x86, asmlinkage: Make syscall tables visible
x86, asmlinkage: Make several variables used from assembler/linker script visible
x86, asmlinkage: Make kprobes code visible and fix assembler code
x86, asmlinkage: Make various syscalls asmlinkage
x86, asmlinkage: Make 32bit/64bit __switch_to visible
x86, asmlinkage: Make _*_start_kernel visible
x86, asmlinkage: Make all interrupt handlers asmlinkage / __visible
x86, asmlinkage: Change dotraplinkage into __visible on 32bit
x86: Fix sys_call_table type in asm/syscall.h
Since all of the memory hotplug operations have to be carried out
under device_hotplug_lock, they won't need to acquire pm_mutex if
device_hotplug_lock is held around hibernation.
For this reason, make the hibernation code acquire
device_hotplug_lock after freezing user space processes and
release it before thawing them. At the same tim drop the
lock_system_sleep() and unlock_system_sleep() calls from
lock_memory_hotplug() and unlock_memory_hotplug(), respectively.
Acked-by: Toshi Kani <toshi.kani@hp.com>
The hibernation core uses special memory bitmaps during image
creation and restoration and traditionally those bitmaps are
allocated before freezing tasks, because in the past GFP_KERNEL
allocations might not work after all tasks had been frozen.
However, this is an anachronism, because hibernation_snapshot()
now calls hibernate_preallocate_memory() which allocates memory
for the image upfront anyway, so the memory bitmaps may be
allocated after freezing user space safely.
For this reason, move all of the create_basic_memory_bitmaps()
calls after freeze_processes() and all of the corresponding
free_basic_memory_bitmaps() calls before thaw_processes().
This will allow us to hold device_hotplug_lock around hibernation
without the need to worry about freezing issues with user space
processes attempting to acquire it via sysfs attributes after the
creation of memory bitmaps and before the freezing of tasks.
* pm-sleep:
PM / Sleep: new trace event to print device suspend and resume times
PM / Sleep: increase ftrace coverage in suspend/resume
pm_qos_update_request_timeout() updates a qos and then schedules
a delayed work item to bring the qos back down to the default
after the timeout. When the work item runs, pm_qos_work_fn() will
call pm_qos_update_request() and deadlock because it tries to
cancel itself via cancel_delayed_work_sync(). Future callers of
that qos will also hang waiting to cancel the work that is
canceling itself. Let's extract the little bit of code that does
the real work of pm_qos_update_request() and call it from the
work function so that we don't deadlock.
Before ed1ac6e (PM: don't use [delayed_]work_pending()) this didn't
happen because the work function wouldn't try to cancel itself.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
visible
Link: http://lkml.kernel.org/r/1375740170-7446-16-git-send-email-andi@firstfloor.org
Calling freeze_processes sets a global flag that will cause any
process that calls try_to_freeze to enter the refrigerator. It
skips sending a signal to the current task, but if the current
task ever hits try_to_freeze, all threads will be frozen and the
system will deadlock.
Set a new flag, PF_SUSPEND_TASK, on the task that calls
freeze_processes. The flag notifies the freezer that the thread
is involved in suspend and should not be frozen. Also add a
WARN_ON in thaw_processes if the caller does not have the
PF_SUSPEND_TASK flag set to catch if a different task calls
thaw_processes than the one that called freeze_processes, leaving
a task with PF_SUSPEND_TASK permanently set on it.
Threads that spawn off a task with PF_SUSPEND_TASK set (which
swsusp does) will also have PF_SUSPEND_TASK set, preventing them
from freezing while they are helping with suspend, but they need
to be dead by the time suspend is triggered, otherwise they may
run when userspace is expected to be frozen. Add a WARN_ON in
thaw_processes if more than one thread has the PF_SUSPEND_TASK
flag set.
Reported-and-tested-by: Michael Leun <lkml20130126@newton.leun.net>
Signed-off-by: Colin Cross <ccross@android.com>
Change where ftrace is disabled and re-enabled during system
suspend/resume to allow tracing of device driver pm callbacks.
Ftrace will now be turned off when suspend reaches
disable_nonboot_cpus() instead of at the very beginning of system
suspend.
Ftrace was disabled during suspend/resume back in 2008 by
Steven Rostedt as he discovered there was a conflict in the
enable_nonboot_cpus() call (see commit f42ac38 "ftrace: disable
tracing for suspend to ram"). This change preserves his fix by
disabling ftrace, but only at the function where it is known
to cause problems.
The new change allows tracing of the device level code for better
debug.
[rjw: Changelog]
Signed-off-by: Todd Brandt <todd.e.brandt@intel.com>
Prevent automatic system suspend from happening during system
shutdown by making try_to_suspend() check system_state and return
immediately if it is not SYSTEM_RUNNING.
This prevents the following breakage from happening (scenario from
Zhang Yanmin):
Kernel starts shutdown and calls all device driver's shutdown
callback. When a driver's shutdown is called, the last wakelock is
released and suspend-to-ram starts. However, as some driver's shut
down callbacks already shut down devices and disabled runtime pm,
the suspend-to-ram calls driver's suspend callback without noticing
that device is already off and causes crash.
[rjw: Changelog]
Signed-off-by: Liu ShuoX <shuox.liu@intel.com>
Cc: 3.5+ <stable@vger.kernel.org>
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
The global variable num_physpages is scheduled to be removed, so use
totalram_pages instead of num_physpages at runtime.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Pull power management and ACPI updates from Rafael Wysocki:
"This time the total number of ACPI commits is slightly greater than
the number of cpufreq commits, but Viresh Kumar (who works on cpufreq)
remains the most active patch submitter.
To me, the most significant change is the addition of offline/online
device operations to the driver core (with the Greg's blessing) and
the related modifications of the ACPI core hotplug code. Next are the
freezer updates from Colin Cross that should make the freezing of
tasks a bit less heavy weight.
We also have a couple of regression fixes, a number of fixes for
issues that have not been identified as regressions, two new drivers
and a bunch of cleanups all over.
Highlights:
- Hotplug changes to support graceful hot-removal failures.
It sometimes is necessary to fail device hot-removal operations
gracefully if they cannot be carried out completely. For example,
if memory from a memory module being hot-removed has been allocated
for the kernel's own use and cannot be moved elsewhere, it's
desirable to fail the hot-removal operation in a graceful way
rather than to crash the kernel, but currenty a success or a kernel
crash are the only possible outcomes of an attempted memory
hot-removal. Needless to say, that is not a very attractive
alternative and it had to be addressed.
However, in order to make it work for memory, I first had to make
it work for CPUs and for this purpose I needed to modify the ACPI
processor driver. It's been split into two parts, a resident one
handling the low-level initialization/cleanup and a modular one
playing the actual driver's role (but it binds to the CPU system
device objects rather than to the ACPI device objects representing
processors). That's been sort of like a live brain surgery on a
patient who's riding a bike.
So this is a little scary, but since we found and fixed a couple of
regressions it caused to happen during the early linux-next testing
(a month ago), nobody has complained.
As a bonus we remove some duplicated ACPI hotplug code, because the
ACPI-based CPU hotplug is now going to use the common ACPI hotplug
code.
- Lighter weight freezing of tasks.
These changes from Colin Cross and Mandeep Singh Baines are
targeted at making the freezing of tasks a bit less heavy weight
operation. They reduce the number of tasks woken up every time
during the freezing, by using the observation that the freezer
simply doesn't need to wake up some of them and wait for them all
to call refrigerator(). The time needed for the freezer to decide
to report a failure is reduced too.
Also reintroduced is the check causing a lockdep warining to
trigger when try_to_freeze() is called with locks held (which is
generally unsafe and shouldn't happen).
- cpufreq updates
First off, a commit from Srivatsa S Bhat fixes a resume regression
introduced during the 3.10 cycle causing some cpufreq sysfs
attributes to return wrong values to user space after resume. The
fix is kind of fresh, but also it's pretty obvious once Srivatsa
has identified the root cause.
Second, we have a new freqdomain_cpus sysfs attribute for the
acpi-cpufreq driver to provide information previously available via
related_cpus. From Lan Tianyu.
Finally, we fix a number of issues, mostly related to the
CPUFREQ_POSTCHANGE notifier and cpufreq Kconfig options and clean
up some code. The majority of changes from Viresh Kumar with bits
from Jacob Shin, Heiko Stübner, Xiaoguang Chen, Ezequiel Garcia,
Arnd Bergmann, and Tang Yuantian.
- ACPICA update
A usual bunch of updates from the ACPICA upstream.
During the 3.4 cycle we introduced support for ACPI 5 extended
sleep registers, but they are only supposed to be used if the
HW-reduced mode bit is set in the FADT flags and the code attempted
to use them without checking that bit. That caused suspend/resume
regressions to happen on some systems. Fix from Lv Zheng causes
those registers to be used only if the HW-reduced mode bit is set.
Apart from this some other ACPICA bugs are fixed and code cleanups
are made by Bob Moore, Tomasz Nowicki, Lv Zheng, Chao Guan, and
Zhang Rui.
- cpuidle updates
New driver for Xilinx Zynq processors is added by Michal Simek.
Multidriver support simplification, addition of some missing
kerneldoc comments and Kconfig-related fixes come from Daniel
Lezcano.
- ACPI power management updates
Changes to make suspend/resume work correctly in Xen guests from
Konrad Rzeszutek Wilk, sparse warning fix from Fengguang Wu and
cleanups and fixes of the ACPI device power state selection
routine.
- ACPI documentation updates
Some previously missing pieces of ACPI documentation are added by
Lv Zheng and Aaron Lu (hopefully, that will help people to
uderstand how the ACPI subsystem works) and one outdated doc is
updated by Hanjun Guo.
- Assorted ACPI updates
We finally nailed down the IA-64 issue that was the reason for
reverting commit 9f29ab11ddbf ("ACPI / scan: do not match drivers
against objects having scan handlers"), so we can fix it and move
the ACPI scan handler check added to the ACPI video driver back to
the core.
A mechanism for adding CMOS RTC address space handlers is
introduced by Lan Tianyu to allow some EC-related breakage to be
fixed on some systems.
A spec-compliant implementation of acpi_os_get_timer() is added by
Mika Westerberg.
The evaluation of _STA is added to do_acpi_find_child() to avoid
situations in which a pointer to a disabled device object is
returned instead of an enabled one with the same _ADR value. From
Jeff Wu.
Intel BayTrail PCH (Platform Controller Hub) support is added to
the ACPI driver for Intel Low-Power Subsystems (LPSS) and that
driver is modified to work around a couple of known BIOS issues.
Changes from Mika Westerberg and Heikki Krogerus.
The EC driver is fixed by Vasiliy Kulikov to use get_user() and
put_user() instead of dereferencing user space pointers blindly.
Code cleanups are made by Bjorn Helgaas, Nicholas Mazzuca and Toshi
Kani.
- Assorted power management updates
The "runtime idle" helper routine is changed to take the return
values of the callbacks executed by it into account and to call
rpm_suspend() if they return 0, which allows us to reduce the
overall code bloat a bit (by dropping some code that's not
necessary any more after that modification).
The runtime PM documentation is updated by Alan Stern (to reflect
the "runtime idle" behavior change).
New trace points for PM QoS are added by Sahara
(<keun-o.park@windriver.com>).
PM QoS documentation is updated by Lan Tianyu.
Code cleanups are made and minor issues are addressed by Bernie
Thompson, Bjorn Helgaas, Julius Werner, and Shuah Khan.
- devfreq updates
New driver for the Exynos5-bus device from Abhilash Kesavan.
Minor cleanups, fixes and MAINTAINERS update from MyungJoo Ham,
Abhilash Kesavan, Paul Bolle, Rajagopal Venkat, and Wei Yongjun.
- OMAP power management updates
Adaptive Voltage Scaling (AVS) SmartReflex voltage control driver
updates from Andrii Tseglytskyi and Nishanth Menon."
* tag 'pm+acpi-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits)
cpufreq: Fix cpufreq regression after suspend/resume
ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state()
PM / Sleep: Warn about system time after resume with pm_trace
cpufreq: don't leave stale policy pointer in cdbs->cur_policy
acpi-cpufreq: Add new sysfs attribute freqdomain_cpus
ACPI: implement acpi_os_get_timer() according the spec
ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan
ACPI: Add CMOS RTC Operation Region handler support
ACPI / processor: Drop unused variable from processor_perflib.c
cpufreq: tegra: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: s3c64xx: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: omap: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: imx6q: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: exynos: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: dbx500: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: davinci: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: arm-big-little: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: powernow-k8: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: pcc: call CPUFREQ_POSTCHANGE notfier in error cases
Pull workqueue changes from Tejun Heo:
"Surprisingly, Lai and I didn't break too many things implementing
custom pools and stuff last time around and there aren't any follow-up
changes necessary at this point.
The only change in this pull request is Viresh's patches to make some
per-cpu workqueues to behave as unbound workqueues dependent on a boot
param whose default can be configured via a config option. This leads
to higher processing overhead / lower bandwidth as more work items are
bounced across CPUs; however, it can lead to noticeable powersave in
certain configurations - ~10% w/ idlish constant workload on a
big.LITTLE configuration according to Viresh.
This is because per-cpu workqueues interfere with how the scheduler
perceives whether or not each CPU is idle by forcing pinned tasks on
them, which makes the scheduler's power-aware scheduling decisions
less effective.
Its effectiveness is likely less pronounced on homogenous
configurations and this type of optimization can probably be made
automatic; however, the changes are pretty minimal and the affected
workqueues are clearly marked, so it's an easy gain for some
configurations for the time being with pretty unintrusive changes."
* 'for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
fbcon: queue work on power efficient wq
block: queue work on power efficient wq
PHYLIB: queue work on system_power_efficient_wq
workqueue: Add system wide power_efficient workqueues
workqueues: Introduce new flag WQ_POWER_EFFICIENT for power oriented workqueues
* pm-assorted:
* pm-assorted:
PM / QoS: Add pm_qos and dev_pm_qos to events-power.txt
PM / QoS: Add dev_pm_qos_request tracepoints
PM / QoS: Add pm_qos_request tracepoints
PM / QoS: Add pm_qos_update_target/flags tracepoints
PM / QoS: Update Documentation/power/pm_qos_interface.txt
PM / Sleep: Print last wakeup source on failed wakeup_count write
PM / QoS: correct the valid range of pm_qos_class
PM / wakeup: Adjust messaging for wake events during suspend
PM / Runtime: Update .runtime_idle() callback documentation
PM / Runtime: Rework the "runtime idle" helper routine
PM / Hibernate: print physical addresses consistently with other parts of kernel
pm_trace uses the system's Real Time Clock (RTC) to save the magic
number. The reason for this is that the RTC is the only reliably
available piece of hardware during resume operations where a value
can be set that will survive a reboot.
Consequence is that after a resume (even if it is successful) your
system clock will have a value corresponding to the magic number
instead of the correct date/time! It is therefore advisable to use
a program like ntp-date or rdate to reset the correct date/time from
an external time source when using this trace option.
There is no run-time message to warn users of the consequences of
enabling pm_trace. Adding a warning message to pm_trace_store()
will serve as a reminder to users to set the system date and time
after resume.
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Adds tracepoints to pm_qos_add_request, pm_qos_update_request,
pm_qos_remove_request, and pm_qos_update_request_timeout.
It's useful for checking pm_qos_class, value, and timeout_us.
Signed-off-by: Sahara <keun-o.park@windriver.com>
This patch adds tracepoints to pm_qos_update_target and
pm_qos_update_flags. It's useful for checking pm qos action,
previous value and current value.
