- CPU_DYING should not be handled in sleepable context
Signed-off-by: Minho Ban <mhban@samsung.com>
Signed-off-by: San Mehat <san@google.com>
If idx was non-zero and the log had wrapped, len did not get truncated
to stop at the last byte written to the log.
This reverts commit acff181d3574244e651913df77332e897b88bff4.
Makes low-level printk work.
It seems that 7bf693951a8e ("console: allow to retain boot console via
boot option keep_bootcon") doesn't always achieve what it aims, as when
printk_late_init() runs it unconditionally turns off all boot consoles.
With this patch, I am able to see more messages on the boot console in
KVM guests than I can without, when keep_bootcon is specified.
I think it is appropriate for the relevant -stable trees. However, it's
more of an annoyance than a serious bug (ideally you don't need to keep
the boot console around as console handover should be working -- I was
encountering a situation where the console handover wasn't working and
not having the boot console available meant I couldn't see why).
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg KH <gregkh@suse.de>
Acked-by: Fabio M. Di Nitto <fdinitto@redhat.com>
Cc: <stable@kernel.org> [2.6.39.x, 3.0.x]
syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that
CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG
was introduced (2010-11-25) they have triggered a warning.
Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now")
improved matters a little by making syslog-ng work again, just keeping
the WARN_ONCE(). But still, this is a warning that writes a stack trace
we don't care about to syslog, sets a taint flag, and alarms sysadmins
when nothing worse has happened than use of an old userspace with a
recent kernel.
Convert the WARN_ONCE to a printk_once to avoid that while continuing to
give userspace developers a hint that this is an unwanted
backward-compatibility feature and won't be around forever.
Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de>
Reported-by: Niels <zorglub_olsen@hotmail.com>
Reported-by: Paweł Sikora <pluto@agmk.net>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Liked-by: Gergely Nagy <algernon@madhouse-project.org>
Acked-by: Serge Hallyn <serge@hallyn.com>
Acked-by: James Morris <jmorris@namei.org>
Fix up the fallout from commit 0b5e1c5255 ("printk: Release
console_sem after logbuf_lock").
The reason for unlocking the console_sem under the logbuf_lock
is that a concurrent printk() might fill up the buffer but fail
to acquire the console sem, resulting in a missed write to the
console until a subsequent console_sem acquire/release cycle.
Cc: efault@gmx.de
Link: http://lkml.kernel.org/r/1308734409.1022.14.camel@twins
Release console_sem after unlocking the logbuf_lock so that we don't
generate wakeups while holding logbuf_lock. This avoids some lock
inversion troubles once we remove the lockdep_off bits between
logbuf_lock and rq->lock (prints while holding rq->lock vs doing
wakeups while holding logbuf_lock).
There's of course still an actual deadlock where the printk()s under
rq->lock will issue a wakeup from the up() call, but lockdep won't
warn about that since semaphores are not tracked.
Link: http://lkml.kernel.org/n/tip-j8swthl12u73h4znbvitljzd@git.kernel.org
On larger systems, because of the numerous ACPI, Bootmem and EFI messages,
the static log buffer overflows before the larger one specified by the
log_buf_len param is allocated. Minimize the overflow by allocating the
new log buffer as soon as possible.
On kernels without memblock, a later call to setup_log_buf from
kernel/init.c is the fallback.
[akpm@linux-foundation.org: fix CONFIG_PRINTK=n build]
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Jack Steiner <steiner@sgi.com>
We've been burned by regressions/bugs which we later realized could have
been triaged quicker if only we'd paid closer attention to dmesg. To make
it easier to audit dmesg, we'd like to make DEFAULT_MESSAGE_LEVEL
Kconfig-settable. That way we can set it to KERN_NOTICE and audit any
messages <= KERN_WARNING.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Joe Perches <joe@perches.com>
Cc: Olof Johansson <olofj@chromium.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
For a platform with many consoles like:
"console=tty1 console=ttyMFD2 console=ttyS0 earlyprintk=mrst"
Each time when the non "selected_console" (tty1 and ttyMFD2 here) get
registered, the existing kernel message will be printed out on registered
consoles again, the "mrst" early console will get some same message for 3
times, and "tty1" will get some for twice.
As suggested by Andrew Morton, every time a new console is registered, it
will be set as the "exclusive" console which will dump the already
existing kernel messages.
Signed-off-by: Feng Tang <feng.tang@intel.com>
On some architectures, the boot process involves de-registering the boot
console (early boot), initialize drivers and then re-register the console.
This mechanism introduces a window in which no printk can happen on the
console and messages are buffered and then printed once the new console is
available.
If a kernel crashes during this window, all it's left on the boot console
is "console [foo] enabled, bootconsole disabled" making debug of the crash
rather 'interesting'.
By adding "keep_bootcon" option, do not unregister the boot console, that
will allow to printk everything that is happening up to the crash.
The option is clearly meant only for debugging purposes as it introduces
lots of duplicated info printed on console, but will make bug report from
users easier as it doesn't require a kernel build just to figure out where
we crash.
Signed-off-by: Fabio M. Di Nitto <fabbione@fabbione.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits)
printk: do not mangle valid userspace syslog prefixes
efivars: Add Documentation
efivars: Expose efivars functionality to external drivers.
efivars: Parameterize operations.
efivars: Split out variable registration
efivars: parameterize efivars
efivars: Make efivars bin_attributes dynamic
efivars: move efivars globals into struct efivars
drivers:misc: ti-st: fix debugging code
kref: Fix typo in kref documentation
UIO: add PRUSS UIO driver support
Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches
firmware: Fix unaligned memory accesses in dmi-sysfs
firmware: Add documentation for /sys/firmware/dmi
firmware: Expose DMI type 15 System Event Log
firmware: Break out system_event_log in dmi-sysfs
firmware: Basic dmi-sysfs support
firmware: Add DMI entry types to the headers
Driver core: convert platform_{get,set}_drvdata to static inline functions
Translate linux-2.6/Documentation/magic-number.txt into Chinese
printk: do not mangle valid userspace syslog prefixes with /dev/kmsg
Log messages passed to the kernel log by using /dev/kmsg or /dev/ttyprintk
might contain a syslog prefix including the syslog facility value.
This makes printk to recognize these headers properly, extract the real log
level from it to use, and add the prefix as a proper prefix to the
log buffer, instead of wrongly printing it as the log message text.
Before:
$ echo '<14>text' > /dev/kmsg
$ dmesg -r
<4>[135159.594810] <14>text
After:
$ dmesg -r
<14>[ 50.750654] text
Cc: Lennart Poettering <lennart@poettering.net>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
In commit ce6ada35bdf7 ("security: Define CAP_SYSLOG") Serge Hallyn
introduced CAP_SYSLOG, but broke backwards compatibility by no longer
accepting CAP_SYS_ADMIN as an override (it would cause a warning and
then reject the operation).
Re-instate CAP_SYS_ADMIN - but keeping the warning - as an acceptable
capability until any legacy applications have been updated. There are
apparently applications out there that drop all capabilities except for
CAP_SYS_ADMIN in order to access the syslog.
(This is a re-implementation of a patch by Serge, cleaning the logic up
and making the code more readable)
Reviewed-by: James Morris <jmorris@namei.org>
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
dump_list_lock is used to protect dump_list in kmsg_dumper implementation,
kmsg_dump() uses it to traverse dump_list too. But if there is contention
on the lock, kmsg_dump() will fail, and the valuable kernel message may be
lost.
This patch solves this issue with RCU. Because kmsg_dump() only read the
list, no lock is needed in kmsg_dump(). So that kmsg_dump() will never
fail because of lock contention.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
emergency_restart paths
We need to know the reason why system rebooted in support service.
However, we can't inform our customers of the reason because final
messages are lost on current Linux kernel.
This patch improves the situation above because the final messages are
saved by adding kmsg_dump() to reboot, halt, poweroff and
emergency_restart path.
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Marco Stornelli <marco.stornelli@gmail.com>
Reviewed-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
security/smack/smack_lsm.c
Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au>
Ok'd by Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits)
serial: apbuart: Fixup apbuart_console_init()
TTY: Add tty ioctl to figure device node of the system console.
tty: add 'active' sysfs attribute to tty0 and console device
drivers: serial: apbuart: Handle OF failures gracefully
Serial: Avoid unbalanced IRQ wake disable during resume
tty: fix typos/errors in tty_driver.h comments
pch_uart : fix warnings for 64bit compile
8250: fix uninitialized FIFOs
ip2: fix compiler warning on ip2main_pci_tbl
specialix: fix compiler warning on specialix_pci_tbl
rocket: fix compiler warning on rocket_pci_ids
8250: add a UPIO_DWAPB32 for 32 bit accesses
8250: use container_of() instead of casting
serial: omap-serial: Add support for kernel debugger
serial: fix pch_uart kconfig & build
drivers: char: hvc: add arm JTAG DCC console support
RS485 documentation: add 16C950 UART description
serial: ifx6x60: fix memory leak
serial: ifx6x60: free IRQ on error
Serial: EG20T: add PCH_UART driver
Fixed up conflicts in drivers/serial/apbuart.c with evil merge that
makes the code look fairly sane (unlike either side).
Userspace can query the actual virtual console, and the configured
console devices behind /dev/tt0 and /dev/console.
The last entry in the list of devices is the active device, analog
to the console= kernel command line option.
The attribute supports poll(), which is raised when the virtual
console is changed or /dev/console is reconfigured.
index 0000000..b138b66
Eric Paris pointed out that it doesn't make sense to require
both CAP_SYS_ADMIN and CAP_SYSLOG for certain syslog actions.
So require CAP_SYSLOG, not CAP_SYS_ADMIN, when dmesg_restrict
is set.
(I'm also consolidating the now common error path)
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Acked-by: Eric Paris <eparis@redhat.com>
Acked-by: Kees Cook <kees.cook@canonical.com>
__get_cpu_var() is a bit inefficient, lets use __this_cpu_read() and
__this_cpu_write() to manipulate printk_pending.
printk_needs_cpu(cpu) is called only for the current cpu :
Use faster __this_cpu_read().
Remove the redundant unlikely on (cpu_is_offline(cpu)) test:
# size kernel/printk.o*
9942 756 263488 274186 42f0a kernel/printk.o.new
9990 756 263488 274234 42f3a kernel/printk.o.old
Cc: Christoph Lameter <cl@linux.com>
LKML-Reference: <1290788536.2855.237.camel@edumazet-laptop>
Privileged syslog operations currently require CAP_SYS_ADMIN. Split
this off into a new CAP_SYSLOG privilege which we can sanely take away
from a container through the capability bounding set.
With this patch, an lxc container can be prevented from messing with
the host's syslog (i.e. dmesg -c).
Changelog: mar 12 2010: add selinux capability2:cap_syslog perm
Changelog: nov 22 2010:
. port to new kernel
. add a WARN_ONCE if userspace isn't using CAP_SYSLOG
Signed-off-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Acked-by: Andrew G. Morgan <morgan@kernel.org>
Acked-By: Kees Cook <kees.cook@canonical.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: "Christopher J. PeBenito" <cpebenito@tresys.com>
Cc: Eric Paris <eparis@parisplace.org>
This patch fixes a hang observed with 2.6.32 kernels where timers got enqueued
on offline cpus.
printk_needs_cpu() may return 1 if called on offline cpus. When a cpu gets
offlined it schedules the idle process which, before killing its own cpu, will
call tick_nohz_stop_sched_tick(). That function in turn will call
printk_needs_cpu() in order to check if the local tick can be disabled. On
offline cpus this function should naturally return 0 since regardless if the
tick gets disabled or not the cpu will be dead short after. That is besides the
fact that __cpu_disable() should already have made sure that no interrupts on
the offlined cpu will be delivered anyway.
In this case it prevents tick_nohz_stop_sched_tick() to call
select_nohz_load_balancer(). No idea if that really is a problem. However what
made me debug this is that on 2.6.32 the function get_nohz_load_balancer() is
used within __mod_timer() to select a cpu on which a timer gets enqueued. If
printk_needs_cpu() returns 1 then the nohz_load_balancer cpu doesn't get
updated when a cpu gets offlined. It may contain the cpu number of an offline
cpu. In turn timers get enqueued on an offline cpu and not very surprisingly
they never expire and cause system hangs.
This has been observed 2.6.32 kernels. On current kernels __mod_timer() uses
get_nohz_timer_target() which doesn't have that problem. However there might be
other problems because of the too early exit tick_nohz_stop_sched_tick() in
case a cpu goes offline.
Easiest way to fix this is just to test if the current cpu is offline and call
printk_tick() directly which clears the condition.
Alternatively I tried a cpu hotplug notifier which would clear the condition,
however between calling the notifier function and printk_needs_cpu() something
could have called printk() again and the problem is back again. This seems to
be the safest fix.
Cc: stable@kernel.org
LKML-Reference: <20101126120235.406766476@de.ibm.com>
wake_up_klogd() may get called from preemptible context but uses
__raw_get_cpu_var() to write to a per cpu variable. If it gets preempted
between getting the address and writing to it, the cpu in question could be
offline if the process gets scheduled back and hence writes to the per cpu data
of an offline cpu.
This buggy behaviour was introduced with fa33507a "printk: robustify
printk, fix #2" which was supposed to fix a "using smp_processor_id() in
preemptible" warning.
Let's use this_cpu_write() instead which disables preemption and makes sure
that the outlined scenario cannot happen.
LKML-Reference: <20101126124247.GC7023@osiris.boeblingen.de.ibm.com>
Move it out of printk.c so that we can use it all over the code. There
are some potential users which will be converted to that macro in next
patches.
The addition of CONFIG_SECURITY_DMESG_RESTRICT resulted in a build
failure when CONFIG_PRINTK=n. This is because the capabilities code
which used the new option was built even though the variable in question
didn't exist.
The patch here fixes this by moving the capabilities checks out of the
LSM and into the caller. All (known) LSMs should have been calling the
capabilities hook already so it actually makes the code organization
better to eliminate the hook altogether.
Signed-off-by: Eric Paris <eparis@redhat.com>
The kernel syslog contains debugging information that is often useful
during exploitation of other vulnerabilities, such as kernel heap
addresses. Rather than futilely attempt to sanitize hundreds (or
thousands) of printk statements and simultaneously cripple useful
debugging functionality, it is far simpler to create an option that
prevents unprivileged users from reading the syslog.
This patch, loosely based on grsecurity's GRKERNSEC_DMESG, creates the
dmesg_restrict sysctl. When set to "0", the default, no restrictions are
enforced. When set to "1", only users with CAP_SYS_ADMIN can read the
kernel syslog via dmesg(8) or other mechanisms.
[akpm@linux-foundation.org: explain the config option in kernel.txt]
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Eugene Teo <eugeneteo@kernel.org>
get_option() takes its 2nd arg as int * so passing boot_delay to it
caused following warnings from sparse:
kernel/printk.c:223:27: warning: incorrect type in argument 2 (different signedness)
kernel/printk.c:223:27: expected int *pint
kernel/printk.c:223:27: got unsigned int static [toplevel] *<noident>
Since boot_delay can't grow more than 10,000 changing it to 'int *'
will not produce any problem.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
acquire_console_semaphore_for_printk() releases logbuf_lock but
was missing proper annotation. Add it.
Move redundant 'const' after '*' to make pointer itself const
It needs to be investigated whether it can be replaced by a real
mutex, but that needs more thought.
LKML-Reference: <20100907125057.179587334@linutronix.de>
kmsg_dump takes care to sample the global variables
inside a spinlock, but then goes on to use the same
variables outside the spinlock region too.
Use the correct variable. This will make the race
window smaller.
Found by gcc 4.6's new warnings.
When a secondary CPU is being brought up, it is not uncommon for
printk() to be invoked when cpu_online(smp_processor_id()) == 0. The
case that I witnessed personally was on MIPS:
http://lkml.org/lkml/2010/5/30/4
If (can_use_console() == 0), printk() will spool its output to log_buf
and it will be visible in "dmesg", but that output will NOT be echoed to
the console until somebody calls release_console_sem() from a CPU that
is online. Therefore, the boot time messages from the new CPU can get
stuck in "limbo" for a long time, and might suddenly appear on the
screen when a completely unrelated event (e.g. "eth0: link is down")
occurs.
This patch modifies the console code so that any pending messages are
automatically flushed out to the console whenever a CPU hotplug
operation completes successfully or aborts.
The issue was seen on 2.6.34.
Original patch by Kevin Cernekee with cleanups by akpm and additional fixes
by Santosh Shilimkar. This patch superseeds
https://patchwork.linux-mips.org/patch/1357/.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
To: <mingo@elte.hu>
To: <akpm@linux-foundation.org>
To: <simon.kagstrom@netinsight.net>
To: <David.Woodhouse@intel.com>
To: <lethal@linux-sh.org>
Cc: <linux-kernel@vger.kernel.org>
Cc: <linux-mips@linux-mips.org>
Reviewed-by: Paul Mundt <lethal@linux-sh.org>
Patchwork: https://patchwork.linux-mips.org/patch/1534/
LKML-Reference: <ede63b5a20af951c755736f035d1e787772d7c28@localhost>
LKML-Reference: <EAF47CD23C76F840A9E7FCE10091EFAB02C5DB6D1F@dbde02.ent.ti.com>
Certain calls from the kdb shell will call out to printk(), and any of
these calls should get vectored back to the kdb_printf() so that the
kdb pager and processing can be used, as well as to properly channel
I/O to the polled I/O devices.
CC: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
This patch contains the hooks and instrumentation into kernel which
live outside the kernel/debug directory, which the kdb core
will call to run commands like lsmod, dmesg, bt etc...
CC: linux-arch@vger.kernel.org
Signed-off-by: Martin Hicks <mort@sgi.com>
kernel/printk.c:72: warning: `saved_console_loglevel' defined but not used
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Right now the syslog "type" action are just raw numbers which makes
the source difficult to follow. This patch replaces the raw numbers
with defined constants for some level of sanity.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Acked-by: John Johansen <john.johansen@canonical.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
This allows the LSM to distinguish between syslog functions originating
from /proc/kmsg access and direct syscalls. By default, the commoncaps
will now no longer require CAP_SYS_ADMIN to read an opened /proc/kmsg
file descriptor. For example the kernel syslog reader can now drop
privileges after opening /proc/kmsg, instead of staying privileged with
CAP_SYS_ADMIN. MAC systems that implement security_syslog have unchanged
behavior.
* git://git.infradead.org/~dwmw2/mtd-2.6.33:
mtd: tests: fix read, speed and stress tests on NOR flash
mtd: Really add ARM pismo support
kmsg_dump: Dump on crash_kexec as well
crash_kexec gets called before kmsg_dump(KMSG_DUMP_OOPS) if
panic_on_oops is set, so the kernel log buffer is not stored
for this case.
This patch adds a KMSG_DUMP_KEXEC dump type which gets called
when crash_kexec() is invoked. To avoid getting double dumps,
the old KMSG_DUMP_PANIC is moved below crash_kexec(). The
mtdoops driver is modified to handle KMSG_DUMP_KEXEC in the
same way as a panic.
Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Fix kernel-doc warnings in printk.c:
Warning(kernel/printk.c:1422): No description found for parameter 'dumper'
Warning(kernel/printk.c:1422): Excess function parameter 'dump' description in 'kmsg_dump_register'
Warning(kernel/printk.c:1451): No description found for parameter 'dumper'
Warning(kernel/printk.c:1451): Excess function parameter 'dump' description in 'kmsg_dump_unregister'
* git://git.infradead.org/mtd-2.6: (90 commits)
jffs2: Fix long-standing bug with symlink garbage collection.
mtd: OneNAND: Fix test of unsigned in onenand_otp_walk()
mtd: cfi_cmdset_0002, fix lock imbalance
Revert "mtd: move mxcnd_remove to .exit.text"
mtd: m25p80: add support for Macronix MX25L4005A
kmsg_dump: fix build for CONFIG_PRINTK=n
mtd: nandsim: add support for 4KiB pages
mtd: mtdoops: refactor as a kmsg_dumper
mtd: mtdoops: make record size configurable
mtd: mtdoops: limit the maximum mtd partition size
mtd: mtdoops: keep track of used/unused pages in an array
mtd: mtdoops: several minor cleanups
core: Add kernel message dumper to call on oopses and panics
mtd: add ARM pismo support
mtd: pxa3xx_nand: Fix PIO data transfer
mtd: nand: fix multi-chip suspend problem
mtd: add support for switching old SST chips into QRY mode
mtd: fix M29W800D dev_id and uaddr
mtd: don't use PF_MEMALLOC
mtd: Add bad block table overrides to Davinci NAND driver
Fixed up conflicts (mostly trivial) in
drivers/mtd/devices/m25p80.c
drivers/mtd/maps/pcmciamtd.c
drivers/mtd/nand/pxa3xx_nand.c
kernel/printk.c
* 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ratelimit: Make suppressed output messages more useful
printk: Remove ratelimit.h from kernel.h
ratelimit: Fix/allow use in atomic contexts
ratelimit: Use per ratelimit context locking
kmsg_dump() fails to build when CONFIG_PRINTK=n; provide stubs
for the kmsg_dump*() functions when CONFIG_PRINTK=n.
kernel/printk.c: In function 'kmsg_dump':
kernel/printk.c:1501: error: 'log_buf_len' undeclared (first use in this function)
kernel/printk.c:1502: error: 'logged_chars' undeclared (first use in this function)
kernel/printk.c:1506: error: 'log_buf' undeclared (first use in this function)
The core functionality is implemented as per Linus suggestion from
http://lists.infradead.org/pipermail/linux-mtd/2009-October/027620.html
(with the kmsg_dump implementation by Linus). A struct kmsg_dumper has
been added which contains a callback to dump the kernel log buffers on
crashes. The kmsg_dump function gets called from oops_exit() and panic()
and invokes this callbacks with the crash reason.
[dwmw2: Fix log_end handling]
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Reviewed-by: Anders Grafstrom <anders.grafstrom@netinsight.net>
Reviewed-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Today I got:
[39648.224782] Registered led device: iwl-phy0::TX
[40676.545099] __ratelimit: 246 callbacks suppressed
[40676.545103] abcdef[23675]: segfault at 0 ...
as you can see the ratelimit message contains a function prefix.
Since this is always __ratelimit, this wont help much.
This patch changes __ratelimit and printk_ratelimit to print the
function name that calls ratelimit.
This will pinpoint the responsible function, as long as not several
different places call ratelimit with the same ratelimit state at
the same time. In that case we catch only one random function that
calls ratelimit after the wait period.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
CC: Andrew Morton <akpm@linux-foundation.org>
LKML-Reference: <200910231458.11832.borntraeger@de.ibm.com>
