Although the RCU CPU stall warning messages are a very good way to alert
people to a problem, once alerted, it is sometimes helpful to shut them
off in order to avoid obscuring other messages that might be being used
to track down the problem. Although you can rebuild the kernel with
CONFIG_RCU_CPU_STALL_DETECTOR=n, this is sometimes inconvenient. This
commit therefore adds a boot parameter named "rcu_cpu_stall_suppress"
that shuts these messages off without requiring a rebuild (though a
reboot might be needed for those not brave enough to patch their kernel
while it is running).
This message-suppression was already in place for the panic case, so this
commit need only rename the variable and export it via module_param().
&percpu_data is compatible with allocated percpu data.
And we use it and remove the "->rda[NR_CPUS]" array, saving significant
storage on systems with large numbers of CPUs. This does add an additional
level of indirection and thus an additional cache line referenced, but
because ->rda is not used on the read side, this is OK.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Helps finding racy users of call_rcu(), which results in hangs because list
entries are overwritten and/or skipped.
Changelog since v4:
- Bissectability is now OK
- Now generate a WARN_ON_ONCE() for non-initialized rcu_head passed to
call_rcu(). Statically initialized objects are detected with
object_is_static().
- Rename rcu_head_init_on_stack to init_rcu_head_on_stack.
- Remove init_rcu_head() completely.
Changelog since v3:
- Include comments from Lai Jiangshan
This new patch version is based on the debugobjects with the newly introduced
"active state" tracker.
Non-initialized entries are all considered as "statically initialized". An
activation fixup (triggered by call_rcu()) takes care of performing the debug
object initialization without issuing any warning. Since we cannot increase the
size of struct rcu_head, I don't see much room to put an identifier for
statically initialized rcu_head structures. So for now, we have to live without
"activation without explicit init" detection. But the main purpose of this debug
option is to detect double-activations (double call_rcu() use of a rcu_head
before the callback is executed), which is correctly addressed here.
This also detects potential internal RCU callback corruption, which would cause
the callbacks to be executed twice.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
CC: David S. Miller <davem@davemloft.net>
CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
CC: akpm@linux-foundation.org
CC: mingo@elte.hu
CC: laijs@cn.fujitsu.com
CC: dipankar@in.ibm.com
CC: josh@joshtriplett.org
CC: dvhltc@us.ibm.com
CC: niv@us.ibm.com
CC: tglx@linutronix.de
CC: peterz@infradead.org
CC: rostedt@goodmis.org
CC: Valdis.Kletnieks@vt.edu
CC: dhowells@redhat.com
CC: eric.dumazet@gmail.com
CC: Alexey Dobriyan <adobriyan@gmail.com>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Remove all rcu head inits. We don't care about the RCU head state before passing
it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can
keep track of objects on stack.
Lai Jiangshan noted that up to 10% of the RCU_SOFTIRQ are spurious, and
traced this down to the fact that the current grace-period machinery
will uselessly raise RCU_SOFTIRQ when a given CPU needs to go through
a quiescent state, but has not yet done so. In this situation, there
might well be nothing that RCU_SOFTIRQ can do, and the overhead can be
worth worrying about in the ksoftirqd case. This patch therefore avoids
raising RCU_SOFTIRQ in this situation.
Changes since v1 (http://lkml.org/lkml/2010/3/30/122 from Lai Jiangshan):
o Omit the rcu_qs_pending() prechecks, as they aren't that
much less expensive than the quiescent-state checks.
o Merge with the set_need_resched() patch that reduces IPIs.
o Add the new n_rp_report_qs field to the rcu_pending tracing output.
o Update the tracing documentation accordingly.
TREE_RCU assumes that CPU numbering is contiguous, but some users need
large holes in the numbering to better map to hardware layout. This patch
makes TREE_RCU (and TREE_PREEMPT_RCU) tolerate large holes in the CPU
numbering. However, NR_CPUS must still be greater than the largest
CPU number.
The existing RCU CPU stall-warning messages can be confusing, especially
in the case where one CPU detects a single other stalled CPU. In addition,
the console messages did not say which flavor of RCU detected the stall,
which can make it difficult to work out exactly what is causing the stall.
This commit improves these messages.
Requested-by: Dhaval Giani <dhaval.giani@gmail.com>
Print boot-time messages if tracing is enabled, if fanout is set
to non-default values, if exact fanout is specified, if accelerated
dyntick-idle grace periods have been enabled, if RCU-lockdep is enabled,
if rcutorture has been boot-time enabled, if the CPU stall detector has
been disabled, or if four-level hierarchy has been enabled.
This is all for TREE_RCU and TREE_PREEMPT_RCU. TINY_RCU will be handled
separately, if at all.
Suggested-by: Josh Triplett <josh@joshtriplett.org>
The current RCU CPU stall warnings remain enabled even after a panic
occurs, which some people have found to be a bit counterproductive.
This patch therefore uses a notifier to disable stall warnings once a
panic occurs.
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC.
So conditionally compile rcu_scheduler_active in order to slim down
rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is
responsible for most of the slimming.
The addition of preemptible RCU to treercu resulted in a bit of
confusion and inefficiency surrounding the handling of context switches
for RCU-sched and for RCU-preempt. For RCU-sched, a context switch
is a quiescent state, pure and simple, just like it always has been.
For RCU-preempt, a context switch is in no way a quiescent state, but
special handling is required when a task blocks in an RCU read-side
critical section.
However, the callout from the scheduler and the outer loop in ksoftirqd
still calls something named rcu_sched_qs(), whose name is no longer
accurate. Furthermore, when rcu_check_callbacks() notes an RCU-sched
quiescent state, it ends up unnecessarily (though harmlessly, aside
from the performance hit) enqueuing the current task if it happens to
be running in an RCU-preempt read-side critical section. This not only
increases the maximum latency of scheduler_tick(), it also needlessly
increases the overhead of the next outermost rcu_read_unlock() invocation.
This patch addresses this situation by separating the notion of RCU's
context-switch handling from that of RCU-sched's quiescent states.
The context-switch handling is covered by rcu_note_context_switch() in
general and by rcu_preempt_note_context_switch() for preemptible RCU.
This permits rcu_sched_qs() to handle quiescent states and only quiescent
states. It also reduces the maximum latency of scheduler_tick(), though
probably by much less than a microsecond. Finally, it means that tasks
within preemptible-RCU read-side critical sections avoid incurring the
overhead of queuing unless there really is a context switch.
Suggested-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Shrink the RCU_INIT_FLAVOR() macro by moving all but the initialization
of the ->rda[] array to rcu_init_one(). The call to rcu_init_one()
can then be moved to the end of the RCU_INIT_FLAVOR() macro, which is
required because rcu_boot_init_percpu_data(), which is now called from
rcu_init_one(), depends on the initialization of the ->rda[] array.
cleanup: make dead code really dead
This patch adds a check to __rcu_pending() that does a local
set_need_resched() if the current CPU is holding up the current grace
period and if force_quiescent_state() will be called soon. The goal is
to reduce the probability that force_quiescent_state() will need to do
smp_send_reschedule(), which sends an IPI and is therefore more expensive
on most architectures.
Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
It is invalid to invoke __rcu_process_callbacks() with irqs
disabled, so do it indirectly via raise_softirq(). This
requires a state-machine implementation to cycle through the
grace-period machinery the required number of times.
Located-by: Ingo Molnar <mingo@elte.hu>
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1267231138-27856-1-git-send-email-paulmck@linux.vnet.ibm.com>
Before the scheduler starts, all tasks are non-preemptible by
definition. So, during that time, rcu_read_lock_sched_held()
needs to always return "true". This patch makes that be so.
Cc: niv@us.ibm.com
LKML-Reference: <1267135607-7056-2-git-send-email-paulmck@linux.vnet.ibm.com>
When RCU detects a grace-period stall, it currently just prints
out the PID of any tasks doing the stalling. This patch adds
RCU_CPU_STALL_VERBOSE, which enables the more-verbose reporting
from sched_show_task().
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-21-git-send-email-paulmck@linux.vnet.ibm.com>
Under TREE_PREEMPT_RCU, print_other_cpu_stall() invokes
rcu_print_task_stall() with the root rcu_node structure's ->lock
held, and rcu_print_task_stall() acquires that same lock for
self-deadlock. Fix this by removing the lock acquisition from
rcu_print_task_stall(), and making all callers acquire the lock
instead.
Tested-by: John Kacur <jkacur@redhat.com>
Tested-by: Thomas Gleixner <tglx@linutronix.de>
Located-by: Thomas Gleixner <tglx@linutronix.de>
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-19-git-send-email-paulmck@linux.vnet.ibm.com>
The spinlocks in rcutree need to be real spinlocks in
preempt-rt. Convert them to raw_spinlocks.
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-18-git-send-email-paulmck@linux.vnet.ibm.com>
The C standard does not specify the result of an operation that
overflows a signed integer, so such operations need to be
avoided. This patch changes the type of several fields from
"long" to "unsigned long" and adjusts operations as needed.
ULONG_CMP_GE() and ULONG_CMP_LT() macros are introduced to do
the modular comparisons that are appropriate given that overflow
is an expected event.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-17-git-send-email-paulmck@linux.vnet.ibm.com>
Currently, rcu_needs_cpu() simply checks whether the current CPU
has an outstanding RCU callback, which means that the last CPU
to go into dyntick-idle mode might wait a few ticks for the
relevant grace periods to complete. However, if all the other
CPUs are in dyntick-idle mode, and if this CPU is in a quiescent
state (which it is for RCU-bh and RCU-sched any time that we are
considering going into dyntick-idle mode), then the grace period
is instantly complete.
This patch therefore repeatedly invokes the RCU grace-period
machinery in order to force any needed grace periods to complete
quickly. It does so a limited number of times in order to
prevent starvation by an RCU callback function that might pass
itself to call_rcu().
However, if any CPU other than the current one is not in
dyntick-idle mode, fall back to simply checking (with fix to bug
noted by Lai Jiangshan). Also, take advantage of last
grace-period forcing, the opportunity to do so noted by Steve
Rostedt. And apply simplified #ifdef condition suggested by
Frederic Weisbecker.
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-15-git-send-email-paulmck@linux.vnet.ibm.com>
Rename local variable "i" in rcu_init() to avoid conflict with
RCU_INIT_FLAVOR(), restrict the scope of RCU_TREE_NONCORE, and
make __synchronize_srcu() static.
Cc: niv@us.ibm.com
LKML-Reference: <12635142581560-git-send-email->
Previously, each level of the rcu_node hierarchy had the same
rather unimaginative name: "&rcu_node_class[i]". This makes
lockdep diagnostics involving these lockdep classes less helpful
than would be nice. This patch fixes this by giving each level
of the rcu_node hierarchy a distinct name: "rcu_node_level_0",
"rcu_node_level_1", and so on. This version of the patch
includes improved diagnostics suggested by Josh Triplett and
Peter Zijlstra.
Cc: niv@us.ibm.com
LKML-Reference: <12626498421830-git-send-email->
Add force_quiescent_state() testing to rcutorture, with a
separate thread that repeatedly invokes force_quiescent_state()
in bursts. This can greatly increase the probability of
encountering certain types of race conditions.
Cc: niv@us.ibm.com
LKML-Reference: <1262646551116-git-send-email->
Grace periods cannot be started while force_quiescent_state() is
active. This is OK in that the affected CPUs will try again
later, but it does induce needless grace-period delays. This
patch causes rcu_start_gp() to record a failed attempt to start
a grace period. When force_quiescent_state() prepares to return,
it then starts the grace period if there was such a failed
attempt.
Cc: niv@us.ibm.com
LKML-Reference: <12626465501854-git-send-email->
The rcu_process_dyntick() function checks twice for the end of
the current grace period. However, it holds the current
rcu_node structure's ->lock field throughout, and doesn't get to
the second call to rcu_gp_in_progress() unless there is at least
one CPU corresponding to this rcu_node structure that has not
yet checked in for the current grace period, which would prevent
the current grace period from ending. So the current grace
period cannot have ended, and the second check is redundant, so
remove it.
Also, given that this function is used even with !CONFIG_NO_HZ,
its name is quite misleading. Change from rcu_process_dyntick()
to force_qs_rnp().
Cc: niv@us.ibm.com
LKML-Reference: <1262646550562-git-send-email->
The comparisons of rsp->gpnum nad rsp->completed in
rcu_process_dyntick() and force_quiescent_state() can be
replaced by the much more clear rcu_gp_in_progress() predicate
function. After doing this, it becomes clear that the
RCU_SAVE_COMPLETED leg of the force_quiescent_state() function's
switch statement is almost completely a no-op. A small change
to the RCU_SAVE_DYNTICK leg renders it a complete no-op, after
which it can be removed. Doing so also eliminates the forcenow
local variable from force_quiescent_state().
Cc: niv@us.ibm.com
LKML-Reference: <12626465501781-git-send-email->
Because a new grace period cannot start while we are executing
within the force_quiescent_state() function's switch statement,
if any test within that switch statement or within any function
called from that switch statement shows that the current grace
period has ended, we can safely re-do that test any time before
we leave the switch statement. This means that we no longer
need a return value from rcu_process_dyntick(), as we can simply
invoke rcu_gp_in_progress() to check whether the old grace
period has finished -- there is no longer any need to worry
about whether or not a new grace period has been started.
Cc: niv@us.ibm.com
LKML-Reference: <12626465501857-git-send-email->
At this point, the second argument to all calls to
rcu_process_dyntick() is a function of the same field of the
structure passed in as the first argument, namely, rsp->gpnum-1.
So propagate rsp->gpnum-1 to all uses of the second argument
within rcu_process_dyntick() and then eliminate the second
argument.
Cc: niv@us.ibm.com
LKML-Reference: <12626465503786-git-send-email->
Because rsp->fqs_active is set to 1 across
force_quiescent_state()'s switch statement, rcu_start_gp() will
refrain from starting a new grace period during this time.
Therefore, rsp->gpnum is constant, and can be propagated to all
uses of lastcomp, eliminating this local variable.
Cc: niv@us.ibm.com
LKML-Reference: <12626465502985-git-send-email->
Because the root rcu_node lock is held across entry to the
switch statement in force_quiescent_state(), it is no longer
necessary to snapshot rsp->signaled to a local variable.
Eliminate both the snapshotting and the local variable.
Cc: niv@us.ibm.com
LKML-Reference: <1262646550602-git-send-email->
Reduce the number and variety of race conditions by prohibiting
the start of a new grace period while force_quiescent_state() is
active. A new fqs_active flag in the rcu_state structure is used
to trace whether or not force_quiescent_state() is active, and
this new flag is tested by rcu_start_gp(). If the CPU that
closed out the last grace period needs another grace period,
this new grace period may be delayed up to one scheduling-clock
tick, but it will eventually get started.
Cc: niv@us.ibm.com
LKML-Reference: <126264655052-git-send-email->
This patch releases rnp->lock after the end of
force_quiescent_state()'s switch statement. This is a second
step towards prohibiting starting grace periods while
force_quiescent_state() is executing, which will reduce the
number and complexity of races that force_quiescent_state() is
involved in.
Cc: niv@us.ibm.com
LKML-Reference: <12626465501994-git-send-email->
This causes rnp->lock to be held on entry to
force_quiescent_state()'s switch statement. This is a first
involved in.
Cc: niv@us.ibm.com
LKML-Reference: <12626465501455-git-send-email->
Implement an synchronize_rcu_expedited() for preemptible RCU
that actually is expedited. This uses
synchronize_sched_expedited() to force all threads currently
running in a preemptible-RCU read-side critical section onto the
appropriate ->blocked_tasks[] list, then takes a snapshot of all
of these lists and waits for them to drain.
Cc: niv@us.ibm.com
LKML-Reference: <1259784616158-git-send-email->
Enable a fourth level of rcu_node hierarchy for TREE_RCU and
TREE_PREEMPT_RCU. This is for stress-testing and experiemental
purposes only, although in theory this would enable 16,777,216
CPUs on 64-bit systems, though only 1,048,576 CPUs on 32-bit
systems. Normal experimental use of this fourth level will
normally set CONFIG_RCU_FANOUT=2, requiring a 16-CPU system,
though the more adventurous (and more fortunate) experimenters
may wish to chose CONFIG_RCU_FANOUT=3 for 81-CPU systems or even
CONFIG_RCU_FANOUT=4 for 256-CPU systems.
Acked-by: Josh Triplett <josh@joshtriplett.org>
Cc: niv@us.ibm.com
LKML-Reference: <12597846161257-git-send-email->
The number of "quiet" functions has grown recently, and the
names are no longer very descriptive. The point of all of these
functions is to do some portion of the task of reporting a
quiescent state, so rename them accordingly:
o cpu_quiet() becomes rcu_report_qs_rdp(), which reports a
quiescent state to the per-CPU rcu_data structure. If this
turns out to be a new quiescent state for this grace period,
then rcu_report_qs_rnp() will be invoked to propagate the
quiescent state up the rcu_node hierarchy.
o cpu_quiet_msk() becomes rcu_report_qs_rnp(), which reports
a quiescent state for a given CPU (or possibly a set of CPUs)
o cpu_quiet_msk_finish() becomes rcu_report_qs_rsp(), which
reports a full set of quiescent states to the global rcu_state
structure.
o task_quiet() becomes rcu_report_unblock_qs_rnp(), which reports
a quiescent state due to a task exiting an RCU read-side critical
section that had previously blocked in that same critical section.
As indicated by the new name, this type of quiescent state is
reported up the rcu_node hierarchy (using rcu_report_qs_rnp()
to do so).
Cc: niv@us.ibm.com
LKML-Reference: <12597846163698-git-send-email->
Remove #ifdefs from kernel/rcupdate.c and
include/linux/rcupdate.h by moving code to
include/linux/rcutiny.h, include/linux/rcutree.h, and
kernel/rcutree.c.
Also remove some definitions that are no longer used.
Cc: niv@us.ibm.com
LKML-Reference: <1258908830885-git-send-email->
The functions rcu_init() is a wrapper for __rcu_init(), and also
sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug().
But TINY_RCU doesn't need CPU-hotplug notification, and the
rcu_barrier_cpu_hotplug() is a simple wrapper for
rcu_cpu_notify().
So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c
and get rid of the wrapper function rcu_barrier_cpu_hotplug().
Cc: niv@us.ibm.com
LKML-Reference: <12589088302320-git-send-email->
When the last CPU of a given leaf rcu_node structure goes
offline, all of the tasks queued on that leaf rcu_node structure
(due to having blocked in their current RCU read-side critical
sections) are requeued onto the root rcu_node structure. This
requeuing is carried out by rcu_preempt_offline_tasks().
However, it is possible that these queued tasks are the only
thing preventing the leaf rcu_node structure from reporting a
quiescent state up the rcu_node hierarchy. Unfortunately, the
old code would fail to do this reporting, resulting in a
grace-period stall given the following sequence of events:
1. Kernel built for more than 32 CPUs on 32-bit systems or for more
than 64 CPUs on 64-bit systems, so that there is more than one
rcu_node structure. (Or CONFIG_RCU_FANOUT is artificially set
to a number smaller than CONFIG_NR_CPUS.)
2. The kernel is built with CONFIG_TREE_PREEMPT_RCU.
3. A task running on a CPU associated with a given leaf rcu_node
structure blocks while in an RCU read-side critical section
-and- that CPU has not yet passed through a quiescent state
for the current RCU grace period. This will cause the task
to be queued on the leaf rcu_node's blocked_tasks[] array, in
particular, on the element of this array corresponding to the
4. Each of the remaining CPUs corresponding to this same leaf rcu_node
structure pass through a quiescent state. However, the task is
still in its RCU read-side critical section, so these quiescent
states cannot be reported further up the rcu_node hierarchy.
Nevertheless, all bits in the leaf rcu_node structure's ->qsmask
field are now zero.
5. Each of the remaining CPUs go offline. (The events in step
#4 and #5 can happen in any order as long as each CPU passes
through a quiescent state before going offline.)
6. When the last CPU goes offline, __rcu_offline_cpu() will invoke
rcu_preempt_offline_tasks(), which will move the task to the
root rcu_node structure, but without reporting a quiescent state
up the rcu_node hierarchy (and this failure to report a quiescent
state is the bug).
But because this leaf rcu_node structure's ->qsmask field is
already zero and its ->block_tasks[] entries are all empty,
force_quiescent_state() will skip this rcu_node structure.
Therefore, grace periods are now hung.
This patch abstracts some code out of rcu_read_unlock_special(),
calling the result task_quiet() by analogy with cpu_quiet(), and
invokes task_quiet() from both rcu_read_lock_special() and
__rcu_offline_cpu(). Invoking task_quiet() from
__rcu_offline_cpu() reports the quiescent state up the rcu_node
hierarchy, fixing the bug. This ends up requiring a separate
lock_class_key per level of the rcu_node hierarchy, which this
patch also provides.
Cc: niv@us.ibm.com
LKML-Reference: <12589088301770-git-send-email->
Now that there are both ->gpnum and ->completed fields in the
rcu_node structure, __rcu_pending() should check rdp->gpnum and
rdp->completed against rnp->gpnum and rdp->completed, respectively,
instead of the prior comparison against the rcu_state fields
rsp->gpnum and rsp->completed.
Given the old comparison, __rcu_pending() could return 1, resulting
in a needless raise_softirq(RCU_SOFTIRQ). This useless work would
happen if RCU responded to a scheduling-clock interrupt after the
rcu_state fields had been updated, but before the rcu_node fields
had been updated.
Changing the comparison from the rcu_state fields to the rcu_node
fields prevents this useless work from happening.
Cc: niv@us.ibm.com
LKML-Reference: <12581706991966-git-send-email->
Now that a copy of the rsp->completed flag is available in all
rcu_node structures, make full use of it. It is still
legitimate to access rsp->completed while holding the root
rcu_node structure's lock, however.
Also, tighten up force_quiescent_state()'s checks for end of
Cc: niv@us.ibm.com
LKML-Reference: <1258170699933-git-send-email->
The force_quiescent_state() function also took a snapshot
of the ->completed field, which was as obnoxious as it was in
rcu_sched_qs() and friends. So snapshot ->gpnum-1.
Also, since the dyntick_record_completed() and
dyntick_recall_completed() functions are now simple assignments
that are independent of CONFIG_NO_HZ, and since their names are
now misleading, get rid of them.
Cc: niv@us.ibm.com
LKML-Reference: <12580941042308-git-send-email->
An earlier fix for a race resulted in a situation where the CPUs
other than the CPU that detected the end of the grace period would
not process their callbacks until the next grace period started.
This means that these other CPUs would unnecessarily demand that an
extra grace period be started.
This patch eliminates this extra grace period and speeds callback
processing by propagating rsp->completed to the rcu_node structures
in the case where the CPU detecting the end of the grace period
sees no reason to start a new grace period.
Cc: niv@us.ibm.com
LKML-Reference: <1258094104417-git-send-email->
The rdp->passed_quiesc_completed fields are used to properly
associate the recorded quiescent state with a grace period. It
is OK to wrongly associate a given quiescent state with a
preceding grace period, but it is fatal to associate a given
quiescent state with a grace period that begins after the
quiescent state occurred. Grace periods are numbered, and the
following fields track them:
o ->gpnum is the number of the grace period currently in
progress, or the number of the last grace period to
complete if no grace period is currently in progress.
o ->completed is the number of the last grace period to
have completed.
These two fields are equal if there is no grace period in
progress, otherwise ->gpnum is one greater than ->completed.
But the rdp->passed_quiesc_completed field compared against
->completed, and if equal, the quiescent state is presumed to
count against the current grace period.
The earlier code copied rdp->completed to
rdp->passed_quiesc_completed, which has been made to work, but
is error-prone. In contrast, copying one less than rdp->gpnum
is guaranteed safe, because rdp->gpnum is not incremented until
after the start of the corresponding grace period. At the end of
the grace period, when ->completed has incremented, then any
quiescent periods recorded previously will be discarded.
Cc: niv@us.ibm.com
LKML-Reference: <12578890421011-git-send-email->
This field is used whether or not CONFIG_NO_HZ is set, so the
old name of ->dynticks_completed is quite misleading.
Change to ->completed_fqs, given that it the value that
force_quiescent_state() is trying to drive the ->completed field
away from.
Cc: niv@us.ibm.com
LKML-Reference: <12578890423298-git-send-email->
Impose a clear locking design on the note_new_gpnum()
function's use of the ->gpnum counter. This is done by updating
rdp->gpnum only from the corresponding leaf rcu_node structure's
rnp->gpnum field, and even then only under the protection of
that same rcu_node structure's ->lock field. Performance and
scalability are maintained using a form of double-checked
locking, and excessive spinning is avoided by use of the
spin_trylock() function. The use of spin_trylock() is safe due
to the fact that CPUs who fail to acquire this lock will try
again later. The hierarchical nature of the rcu_node data
structure limits contention (which could be limited further if
need be using the RCU_FANOUT kernel parameter).
Without this patch, obscure but quite possible races could
result in a quiescent state that occurred during one grace
period to be accounted to the following grace period, causing
this following grace period to end prematurely. Not good!
Cc: niv@us.ibm.com
Cc: <stable@kernel.org> # .32.x
LKML-Reference: <12571987492350-git-send-email->
Impose a clear locking design on the rcu_process_gp_end()
function's use of the ->completed counter. This is done by
creating a ->completed field in the rcu_node structure, which
can safely be accessed under the protection of that structure's
lock. Performance and scalability are maintained by using a
form of double-checked locking, so that rcu_process_gp_end()
only acquires the leaf rcu_node structure's ->lock if a grace
period has recently ended.
This fix reduces rcutorture failure rate by at least two orders
of magnitude under heavy stress with force_quiescent_state()
being invoked artificially often. Without this fix,
unsynchronized access to the ->completed field can cause
rcu_process_gp_end() to advance callbacks whose grace period has
not yet expired. (Bad idea!)
Cc: niv@us.ibm.com
LKML-Reference: <12571987494069-git-send-email->
->completed counter
Impose a clear locking design on non-NO_HZ handling of the
->completed counter. This increases the distance between the
RCU and the CPU-hotplug mechanisms.
Cc: niv@us.ibm.com
LKML-Reference: <12571987491353-git-send-email->
Merge reason: Pick up RCU fixlet to base further commits on.
