path: root/kernel/relay.c
2017-01-12relay: check array offset before using itDan Carpenter
commit 9a29d0fbc2d9ad99fb8a981ab72548cc360e9d4c upstream. Smatch complains that we started using the array offset before we checked that it was valid. Fixes: 017c59c042d0 ('relay: Use per CPU constructs for the relay channel buffer pointers') Link: http://lkml.kernel.org/r/20161013084947.GC16198@mwanda Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-11relay: Use irq_work instead of plain timer for deferred wakeupPeter Zijlstra
Relay avoids calling wake_up_interruptible() for doing the wakeup of readers/consumers, waiting for the generation of new data, from the context of a process which produced the data. This is apparently done to prevent the possibility of a deadlock in case Scheduler itself is is generating data for the relay, after acquiring rq->lock. The following patch used a timer (to be scheduled at next jiffy), for delegating the wakeup to another context. commit 7c9cb38302e78d24e37f7d8a2ea7eed4ae5f2fa7 Author: Tom Zanussi <zanussi@comcast.net> Date: Wed May 9 02:34:01 2007 -0700 relay: use plain timer instead of delayed work relay doesn't need to use schedule_delayed_work() for waking readers when a simple timer will do. Scheduling a plain timer, at next jiffies boundary, to do the wakeup causes a significant wakeup latency for the Userspace client, which makes relay less suitable for the high-frequency low-payload use cases where the data gets generated at a very high rate, like multiple sub buffers getting filled within a milli second. Moreover the timer is re-scheduled on every newly produced sub buffer so the timer keeps getting pushed out if sub buffers are filled in a very quick succession (less than a jiffy gap between filling of 2 sub buffers). As a result relay runs out of sub buffers to store the new data. By using irq_work it is ensured that wakeup of userspace client, blocked in the poll call, is done at earliest (through self IPI or next timer tick) enabling it to always consume the data in time. Also this makes relay consistent with printk & ring buffers (trace), as they too use irq_work for deferred wake up of readers. [arnd@arndb.de: select CONFIG_IRQ_WORK] Link: http://lkml.kernel.org/r/20160912154035.3222156-1-arnd@arndb.de [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/1472906487-1559-1-git-send-email-akash.goel@intel.com Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Akash Goel <akash.goel@intel.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07Merge branch 'work.splice_read' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS splice updates from Al Viro: "There's a bunch of branches this cycle, both mine and from other folks and I'd rather send pull requests separately. This one is the conversion of ->splice_read() to ITER_PIPE iov_iter (and introduction of such). Gets rid of a lot of code in fs/splice.c and elsewhere; there will be followups, but these are for the next cycle... Some pipe/splice-related cleanups from Miklos in the same branch as well" * 'work.splice_read' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: pipe: fix comment in pipe_buf_operations pipe: add pipe_buf_steal() helper pipe: add pipe_buf_confirm() helper pipe: add pipe_buf_release() helper pipe: add pipe_buf_get() helper relay: simplify relay_file_read() switch default_file_splice_read() to use of pipe-backed iov_iter switch generic_file_splice_read() to use of ->read_iter() new iov_iter flavour: pipe-backed fuse_dev_splice_read(): switch to add_to_pipe() skb_splice_bits(): get rid of callback new helper: add_to_pipe() splice: lift pipe_lock out of splice_to_pipe() splice: switch get_iovec_page_array() to iov_iter splice_to_pipe(): don't open-code wakeup_pipe_readers() consistent treatment of EFAULT on O_DIRECT read/write
2016-10-05relay: simplify relay_file_read()Al Viro
to hell with actors... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-06relayfs: Convert to hotplug state machineRichard Weinberger
Install the callbacks via the state machine. They are installed at run time but relay_prepare_cpu() does not need to be invoked by the boot CPU because relay_open() was not yet invoked and there are no pools that need to be created. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20160818125731.27256-3-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-06relay: Use per CPU constructs for the relay channel buffer pointersAkash Goel
relay essentially needs to maintain a per CPU array of channel buffer pointers but it manually creates that array. Instead its better to use the per CPU constructs, provided by the kernel, to allocate & access the array of pointer to channel buffers. Signed-off-by: Akash Goel <akash.goel@intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Link: http://lkml.kernel.org/r/1470909140-25919-1-git-send-email-akash.goel@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-08-02relay: add global mode support for buffer-only channelsAkash Goel
Commit 20d8b67c06fa ("relay: add buffer-only channels; useful for early logging") added support to use channels with no associated files. This is useful when the exact location of relay file is not known or the the parent directory of relay file is not available, while creating the channel and the logging has to start right from the boot. But there was no provision to use global mode with buffer-only channels, which is added by this patch, without modifying the interface where initially there will be a dummy invocation of create_buf_file callback through which kernel client can convey the need of a global buffer. For the use case where drivers/kernel clients want a simple interface for the userspace, which enables them to capture data/logs from relay file inorder & without any post processing, support of Global buffer mode is warranted. Modules, like i915, using relay_open() in early init would have to later register their buffer-only relays, once debugfs is available, by calling relay_late_setup_files(). Hence relay_late_setup_files() symbol also needs to be exported. Link: http://lkml.kernel.org/r/1468404563-11653-1-git-send-email-akash.goel@intel.com Signed-off-by: Akash Goel <akash.goel@intel.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-09kernel/relay.c: fix potential memory leakZhouyi Zhou
When relay_open_buf() fails in relay_open(), code will goto free_bufs, but chan is nowhere freed. Link: http://lkml.kernel.org/r/1464777927-19675-1-git-send-email-yizhouzhou@ict.ac.cn Signed-off-by: Zhouyi Zhou <zhouzhouyi@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-30kernel/relay.c: use kvfree() in relay_free_page_array()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: kernel/: d_inode() annotationsDavid Howells
relayfs and tracefs are dealing with inodes of their own; those two act as filesystem drivers Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-12missing bits of "splice: fix racy pipe->buffers uses"Al Viro
that commit has fixed only the parts of that mess in fs/splice.c itself; there had been more in several other ->splice_read() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01pipe: kill ->map() and ->unmap()Al Viro
all pipe_buffer_operations have the same instances of those... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-02-19treewide: Fix typo in Documentation/DocBookMasanari Iida
This patch fix spelling typo in Documentation/DocBook. It is because .html and .xml files are generated by make htmldocs, I have to fix a typo within the source files. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-14kernel: delete __cpuinit usage from all core kernel filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the uses of the __cpuinit macros from C files in the core kernel directories (kernel, init, lib, mm, and include) that don't really have a specific maintainer. [1] https://lkml.org/lkml/2013/5/20/589 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-05-08Merge branch 'for-3.10/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core updates from Jens Axboe: - Major bit is Kents prep work for immutable bio vecs. - Stable candidate fix for a scheduling-while-atomic in the queue bypass operation. - Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging discard bios. - Tejuns changes to convert the writeback thread pool to the generic workqueue mechanism. - Runtime PM framework, SCSI patches exists on top of these in James' tree. - A few random fixes. * 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits) relay: move remove_buf_file inside relay_close_buf partitions/efi.c: replace useless kzalloc's by kmalloc's fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read() block: fix max discard sectors limit blkcg: fix "scheduling while atomic" in blk_queue_bypass_start Documentation: cfq-iosched: update documentation help for cfq tunables writeback: expose the bdi_wq workqueue writeback: replace custom worker pool implementation with unbound workqueue writeback: remove unused bdi_pending_list aoe: Fix unitialized var usage bio-integrity: Add explicit field for owner of bip_buf block: Add an explicit bio flag for bios that own their bvec block: Add bio_alloc_pages() block: Convert some code to bio_for_each_segment_all() block: Add bio_for_each_segment_all() bounce: Refactor __blk_queue_bounce to not use bi_io_vec raid1: use bio_copy_data() pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage pktcdvd: use bio_copy_data() block: Add bio_copy_data() ...
2013-04-30relay: use macro PAGE_ALIGN instead of FIX_SIZEzhangwei(Jovi)
Macro FIX_SIZE is same as PAGE_ALIGN at present, so use PAGE_ALIGN instead. Thanks Andrew found this. Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/relay.c: move FIX_SIZE macro into relay.czhangwei(Jovi)
It's better to place FIX_SIZE macro in relay.c, instead of relay.h Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/relay.c: remove unused function argument actorzhangwei(Jovi)
Currently argument `actor' is never used in the relay reading path, so remove it. Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30relay: move remove_buf_file inside relay_close_bufDmitry Monakhov
Currently remove_buf_file callback is called from from kobject release method. This result in follow issue: # blktrace -d /dev/sda1 -d /dev/sda -o test blktrace_setup() dir = create_dir() rchan = relay_open(dir,...) ->create_buf_file_callback buf_file = debugfs_create_file(dir, ) Userspace will open buf_file. Later we make a decision to stop tracing blktrace_down() relay_close(rhcan) /* just decrement kobj reference */ /* since it is not zero then callback not called */ debugfs_remove(dir) /* FAIL due to non empty dir */ Later user space will close the file and file will be deleted, but directory still exist. user_space_close() ->file_release ->release_buf_file_callback ->debugfs_remove(buf_file ## TESTCASE: # blktrace -d /dev/sda1 -d /dev/sda -o test # After that blktrace infrastructure will remain broken in # an unusable state so: blktrace -d /dev/sda1 will not work. In fact this is general issue, blktrace is just one of examples. We can not reliably remove parent dir until all users close the buf_file. Solution: We don't have to wait that long. File should be deleted inside relay_close_buf(). Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-22new helper: file_inode(file)Al Viro
2012-06-13splice: fix racy pipe->buffers usesEric Dumazet
Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered by splice_shrink_spd() called from vmsplice_to_pipe() commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes) added capability to adjust pipe->buffers. Problem is some paths don't hold pipe mutex and assume pipe->buffers doesn't change for their duration. Fix this by adding nr_pages_max field in struct splice_pipe_desc, and use it in place of pipe->buffers where appropriate. splice_shrink_spd() loses its struct pipe_inode_info argument. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Tom Herbert <therbert@google.com> Cc: stable <stable@vger.kernel.org> # 2.6.35 Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-10relay: prevent integer overflow in relay_open()Dan Carpenter
"subbuf_size" and "n_subbufs" come from the user and they need to be capped to prevent an integer overflow. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-03switch debugfs to umode_tAl Viro
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-11-05Clean up relay_alloc_page_array() slightly by using vzalloc rather than ↵Jesper Juhl
vmalloc and memset We can optimize kernel/relay.c::relay_alloc_page_array() slightly by using vzalloc. The patch makes these changes: - use vzalloc instead of vmalloc+memset. - remove redundant local variable 'array'. - declare local 'pa_size' as const. Cuts down nicely on both source and object-code size. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27kernel/: convert cpu notifier to return encapsulate errno valueAkinobu Mita
By the previous modification, the cpu notifier can return encapsulate errno value. This converts the cpu notifiers for kernel/*.c Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21pipe: add support for shrinking and growing pipesJens Axboe
This patch adds F_GETPIPE_SZ and F_SETPIPE_SZ fcntl() actions for growing and shrinking the size of a pipe and adjusts pipe.c and splice.c (and relay and network splice) usage to work with these larger (or smaller) pipes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-06splice: comparing unsigned int < 0Dan Carpenter
"ret" needs to be signed or the error handling for splice_to_pipe() won't work correctly. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Tom Zanussi <zanussi@comcast.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16const: constify remaining pipe_buf_operationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-02relay: fix for possible loss/corruption of produced subbufsAravind Srinivasan
Fix possible loss/corruption of produced subbufs in relay_subbufs_consumed(). When buf->subbufs_produced wraps around after UINT_MAX and buf->subbufs_consumed is still < UINT_MAX, the condition if (buf->subbufs_consumed > buf->subbufs_produced) will be true even for certain valid values of subbufs_consumed. This may lead to loss or corruption of produced subbufs. Signed-off-by: Aravind Srinivasan <raa.aars@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-02-18timers: add mod_timer_pending()Ingo Molnar
Impact: new timer API Based on an idea from Martin Josefsson with the help of Patrick McHardy and Stephen Hemminger: introduce the mod_timer_pending() API which is a mod_timer() offspring that is an invariant on already removed timers. (regular mod_timer() re-activates non-pending timers.) This is useful for the networking code in that it can allow unserialized mod_timer_pending() timer-forwarding calls, but a single del_timer*() will stop the timer from being reactivated again. Also while at it: - optimize the regular mod_timer() path some more, the timer-stat and a debug check was needlessly duplicated in __mod_timer(). - make the exports come straight after the function, as most other exports in timer.c already did. - eliminate __mod_timer() as an external API, change the users to mod_timer(). The regular mod_timer() code path is not impacted significantly, due to inlining optimizations and due to the simplifications. Based-on-patch-from: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: netdev@vger.kernel.org Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-03Merge branches 'tracing/ftrace', 'tracing/kmemtrace' and 'linus' into ↵Ingo Molnar
tracing/core
2009-01-18relay: fix lock imbalance in relay_late_setup_filesJiri Slaby
One fail path in relay_late_setup_files() omits mutex_unlock(&relay_channels_mutex); Add it. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-30relayfs: replace BUG() with WARN_ON() in relay_late_setup_files()Ingo Molnar
Impact: turn boot crash into boot warning This BUG() can trigger: [ 16.684131] initcall fail_page_alloc_debugfs+0x0/0xc1 returned 0 after 0 usecs [ 16.692035] calling kmemtrace_setup_late+0x0/0xd5 @ 1 [ 16.700087] relay_late_setup_files: CPU 1 has no buffer, it must have! [ 16.704044] ------------[ cut here ]------------ [ 16.708030] kernel BUG at kernel/relay.c:680! [ 16.708030] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC [ 16.708030] last sysfs file: [ 16.708030] [ 16.708030] Pid: 1, comm: swapper Not tainted (2.6.28-tip-03903-g9a39f58-dirty #13207) System Product Name [ 16.708030] EIP: 0060:[<c01604ae>] EFLAGS: 00010246 CPU: 1 [ 16.708030] EIP is at relay_late_setup_files+0x8c/0x176 Reduce it to a more reportable WARN_ONCE(). Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-10relayfs: fix infinite loop with splice()Tom Zanussi
Running kmemtraced, which uses splice() on relayfs, causes a hard lock on x86-64 SMP. As described by Tom Zanussi: It looks like you hit the same problem as described here: commit 8191ecd1d14c6914c660dfa007154860a7908857 splice: fix infinite loop in generic_file_splice_read() relay uses the same loop but it never got noticed or fixed. Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Tested-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-18relay: fix cpu offline problemLai Jiangshan
relay_open() will close allocated buffers when failed. but if cpu offlined, some buffer will not be closed. this patch fixed it. and did cleanup for relay_reset() too. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-05relay: fix "full buffer with exactly full last subbuffer" accounting problemTom Zanussi
In relay's current read implementation, if the buffer is completely full but hasn't triggered the buffer-full condition (i.e. the last write didn't cross the subbuffer boundary) and the last subbuffer is exactly full, the subbuffer accounting code erroneously finds nothing available. This patch fixes the problem. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mathieu Desnoyers <compudj@krystal.dyndns.org> Cc: Andrea Righi <righi.andrea@gmail.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26relay: add buffer-only channels; useful for early loggingEduard - Gabriel Munteanu
Allows one to create and use a channel with no associated files. Files can be initialized later. This is useful in scenarios such as logging in early code, before VFS is up. Therefore, such channels can be created and used as soon as kmem_cache_init() completed. This is needed by kmemtrace to do tracing in early kernel code. [kosaki.motohiro@jp.fujitsu.com: build fix] Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28splice: fix sendfile() issue with relayTom Zanussi
Splice isn't always incrementing the ppos correctly, which broke relay splice. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-08Revert "relay: fix splice problem"Jens Axboe
This reverts commit c3270e577c18b3d0e984c3371493205a4807db9d.
2008-04-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Skip I/O merges when disabled block: add large command support block: replace sizeof(rq->cmd) with BLK_MAX_CDB ide: use blk_rq_init() to initialize the request block: use blk_rq_init() to initialize the request block: rename and export rq_init() block: no need to initialize rq->cmd with blk_get_request block: no need to initialize rq->cmd in prepare_flush_fn hook block/blk-barrier.c:blk_ordered_cur_seq() mustn't be inline block/elevator.c:elv_rq_merge_ok() mustn't be inline block: make queue flags non-atomic block: add dma alignment and padding support to blk_rq_map_kern unexport blk_max_pfn ps3disk: Remove superfluous cast block: make rq_init() do a full memset() relay: fix splice problem
2008-04-29relayfs: support larger relay bufferMasami Hiramatsu
Use vmalloc() and memset() instead of kcalloc() to allocate a page* array when the array size is bigger than one page. This enables relayfs to support bigger relay buffers than 64MB on 4k-page system, 512MB on 16k-page system. [akpm@linux-foundation.org: cleanup] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: David Wilder <dwilder@us.ibm.com> Reviewed-by: Tom Zanussi <zanussi@comcast.net> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29relay: fix splice problemTom Zanussi
Splice isn't always incrementing the ppos correctly, which broke relay splice. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-26relay: set an spd_release() hook for spliceJens Axboe
relay doesn't reference the pages it adds, however we need a non-NULL hook or splice_to_pipe() can oops. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-26set relay file can not be read by pread(2)Lai Jiangshan
I found that relay files can be read by pread(2). I fix it, for relay files are not capable of seeking. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
