path: root/kernel/resource.c
2009-12-21resources: fix call to alignf() in allocate_resource()Dominik Brodowski
The second parameter to alignf() in allocate_resource() must reflect what new resource is attempted to be allocated, else functions like pcibios_align_resource() (at least on x86) or pcmcia_align() can't work correctly. Commit 1e5ad9679016275d422e36b12a98b0927d76f556 broke this by setting the "new" resource until we're about to return success. To keep the resource untouched when allocate_resource() fails, a "tmp" resource is introduced. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-04resources: when allocate_resource() fails, leave resource untouchedBjorn Helgaas
When "allocate_resource(root, new, size, ...)" fails, we currently clobber "new". This is inconvenient for the caller, who might care about the original contents of the resource. For example, when pci_bus_alloc_resource() fails, the "can't allocate mem resource %pR" message from pci_assign_resources() currently contains junk for the resource start/end. This patch delays the "new" update until we're about to return success. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-23walk system ram rangeKAMEZAWA Hiroyuki
Originally, walk_memory_resource() was introduced to traverse all memory of "System RAM" for detecting memory hotplug/unplug range. For doing so, flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for memory hotplug. But for using other purpose, /proc/kcore, this may includes some firmware area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the check strict to find out busy "System RAM". Note: PPC64 keeps their own walk_memory_resouce(), which walk through ppc64's lmb informaton. Because old kclist_add() is called per lmb, this patch makes no difference in behavior, finally. And this patch removes CONFIG_MEMORY_HOTPLUG check from this function. Because pfn_valid() just show "there is memmap or not* and cannot be used for "there is physical memory or not", this function is useful in generic to scan physical memory range. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30kernel/resource.c: fix sign extension in reserve_setup()Zhang Rui
When the 32-bit signed quantities get assigned to the u64 resource_size_t, they are incorrectly sign-extended. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13253 Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9905 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Reported-by: Leann Ogasawara <leann@ubuntu.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Reported-by: <pablomme@googlemail.com> Tested-by: <pablomme@googlemail.com> Cc: <stable@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-18Remove 'recurse into child resources' logic from 'reserve_region_with_split()'Linus Torvalds
This function is not actually used right now, since the original use case for it was done with insert_resource_expand_to_fit() instead. However, we now have another usage case that wants to basically do a "reserve IO resource, splitting around existing resources", however that one doesn't actually want the "recurse into the conflicting resource" logic at all. And since recursing into the conflicting resource was the most complex part, and isn't wanted, just remove it. Maybe we'll some day want both versions, but we can just resurrect the logic then. Tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15resources: fix parameter name and kernel-docRandy Dunlap
Fix __request_region() parameter kernel-doc notation and parameter name: Warning(linux-2.6.28-git10//kernel/resource.c:627): No description found for parameter 'flags' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07resource: allow MMIO exclusivity for device driversArjan van de Ven
Device drivers that use pci_request_regions() (and similar APIs) have a reasonable expectation that they are the only ones accessing their device. As part of the e1000e hunt, we were afraid that some userland (X or some bootsplash stuff) was mapping the MMIO region that the driver thought it had exclusively via /dev/mem or via various sysfs resource mappings. This patch adds the option for device drivers to cause their reserved regions to the "banned from /dev/mem use" list, so now both kernel memory and device-exclusive MMIO regions are banned. NOTE: This is only active when CONFIG_STRICT_DEVMEM is set. In addition to the config option, a kernel parameter iomem=relaxed is provided for the cases where developers want to diagnose, in the field, drivers issues from userspace. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-12-16resources: skip sanity check of busy resourcesArjan van de Ven
Impact: reduce false positives in iomem_map_sanity_check() Some drivers (vesafb) only map/reserve a portion of a resource. If then some other driver comes in and maps the whole resource, the current code WARN_ON's. This is not the intent of the checks in iomem_map_sanity_check(); rather these checks want to warn when crossing *hardware* resources only. This patch skips BUSY resources as suggested by Linus. Note: having two drivers talk to the same hardware at the same time is obviously not optimal behavior, but that's a separate story. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-01reserve_region_with_split: Fix GFP_KERNEL usage under spinlockLinus Torvalds
This one apparently doesn't generate any warnings, because the function is only used during system bootup, when the warnings are disabled. But it's still very wrong. The __reserve_region_with_split() function is called with the resource_lock held for writing, so it must only ever do GFP_ATOMIC allocations. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-28resources: fix x86info results ioremap.c:226 __ioremap_caller+0xf2/0x2d6() ↵Suresh Siddha
WARNINGs Impact: avoid false-positive WARN_ON() Andi Kleen reported: > When running x86info on a 2.6.27-git8 system I get > > resource map sanity check conflict: 0x9e000 0x9efff 0x10000 0x9e7ff System RAM > ------------[ cut here ]------------ > WARNING: at /home/lsrc/linux/arch/x86/mm/ioremap.c:226 __ioremap_caller+0xf2/0x2d6() > ... Some of the pages below the 1MB ISA addresses will be shared typically by both BIOS and system usable RAM. For example: BIOS-e820: 0000000000000000 - 000000000009f800 (usable) BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved) x86info reads the low physical address using /dev/mem, which internally uses ioremap() for accessing non RAM pages. ioremap() of such low pages conflicts with multiple resource entities leading to the above warning. Change the iomem_map_sanity_check() to allow mapping a page spanning multiple resource entities (minimum granularity that one can map is a page anyhow). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-23kernel/resource: fix reserve_region_with_split() section mismatchPaul Mundt
Impact: cleanup, small kernel text size reduction, no functionality changed reserve_region_with_split() calls in to __reserve_region_with_split(), which is an __init function. The only caller of reserve_region_with_split() is an __init function, so make it __init too. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16Merge branch 'core-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: do_generic_file_read: s/EINTR/EIO/ if lock_page_killable() fails softirq, warning fix: correct a format to avoid a warning softirqs, debug: preemption check x86, pci-hotplug, calgary / rio: fix EBDA ioremap() IO resources, x86: ioremap sanity check to catch mapping requests exceeding, fix IO resources, x86: ioremap sanity check to catch mapping requests exceeding the BAR sizes softlockup: Documentation/sysctl/kernel.txt: fix softlockup_thresh description dmi scan: warn about too early calls to dmi_check_system() generic: redefine resource_size_t as phys_addr_t generic: make PFN_PHYS explicitly return phys_addr_t generic: add phys_addr_t for holding physical addresses softirq: allocate less vectors IO resources: fix/remove printk printk: robustify printk, update comment printk: robustify printk, fix #2 printk: robustify printk, fix printk: robustify printk Fixed up conflicts in: arch/powerpc/include/asm/types.h arch/powerpc/platforms/Kconfig.cputype manually.
2008-10-16resources: tidy __request_region()Bjorn Helgaas
No functional change. Just return NULL for kzalloc failure immediately, rather than wrapping the whole function body in the body of an "if". Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-26IO resources, x86: ioremap sanity check to catch mapping requests exceeding, fixIngo Molnar
fix this build error: kernel/resource.c: In function 'iomem_map_sanity_check': kernel/resource.c:842: error: implicit declaration of function 'r_next' kernel/resource.c:842: warning: assignment makes pointer from integer without a cast r_next() was only available if CONFIG_PROCFS was enabled. and fix this build warning: kernel/resource.c:855: warning: format '%llx' expects type 'long long unsigned int', but argument 2 has type 'resource_size_t' kernel/resource.c:855: warning: format '%llx' expects type 'long long unsigned int', but argument 3 has type 'long unsigned int' kernel/resource.c:855: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'resource_size_t' kernel/resource.c:855: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'resource_size_t' resource_t can be 32 bits. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-26IO resources, x86: ioremap sanity check to catch mapping requests exceeding ↵Suresh Siddha
the BAR sizes Go through the iomem resource tree to check if any of the ioremap() requests span more than any slot in the iomem resource tree and do a WARN_ON() if we hit this check. This will raise a red-flag, if some driver is mapping more than what is needed. And hopefully identify possible corruptions much earlier. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-04IO resources: fix/remove printkIngo Molnar
Andrew Morton noticed that the printk in kernel/resource.c was buggy: | start and end have type resource_size_t. Such types CANNOT be printed | unless cast to a known type. | | Because there is a %s following an incorrect %lld, the above code will | crash the machine. ... and it's probably quite unneeded as well, so remove it. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-04IO resources: add reserve_region_with_split()Yinghai Lu
add reserve_region_with_split() to not lose e820 reserved entries if they overlap with existing IO regions: with test case by extend 0xe0000000 - 0xeffffff to 0xdd800000 - we get: e0000000-efffffff : PCI MMCONFIG 0 e0000000-efffffff : reserved and in /proc/iomem we get: found conflict for reserved [dd800000, efffffff], try to reserve with split __reserve_region_with_split: (PCI Bus #80) [dd000000, ddffffff], res: (reserved) [dd800000, efffffff] __reserve_region_with_split: (PCI Bus #00) [de000000, dfffffff], res: (reserved) [de000000, efffffff] initcall pci_subsys_init+0x0/0x121 returned 0 after 381 msecs in dmesg various fixes and improvements suggested by Linus. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-02kernel/resource.c: fix new kernel-doc warningRandy Dunlap
Fix kernel-doc warning for new function: Warning(linux-2.6.27-rc5-git2//kernel/resource.c:448): No description found for parameter 'root' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-29Resource handling: add 'insert_resource_expand_to_fit()' functionLinus Torvalds
Not used anywhere yet, but this complements the existing plain 'insert_resource()' functionality with a version that can expand the resource we are adding in order to fix up any conflicts it has with existing resources. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30resource: add resource_size()Magnus Damm
Avoid one-off errors by introducing a resource_size() function. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20PCI: clean up resource alignment managementIvan Kokshaysky
Done per Linus' request and suggestions. Linus has explained that better than I'll be able to explain: On Thu, Mar 27, 2008 at 10:12:10AM -0700, Linus Torvalds wrote: > Actually, before we go any further, there might be a less intrusive > alternative: add just a couple of flags to the resource flags field (we > still have something like 8 unused bits on 32-bit), and use those to > implement a generic "resource_alignment()" routine. > > Two flags would do it: > > - IORESOURCE_SIZEALIGN: size indicates alignment (regular PCI device > resources) > > - IORESOURCE_STARTALIGN: start field is alignment (PCI bus resources > during probing) > > and then the case of both flags zero (or both bits set) would actually be > "invalid", and we would also clear the IORESOURCE_STARTALIGN flag when we > actually allocate the resource (so that we don't use the "start" field as > alignment incorrectly when it no longer indicates alignment). > > That wouldn't be totally generic, but it would have the nice property of > automatically at least add sanity checking for that whole "res->start has > the odd meaning of 'alignment' during probing" and remove the need for a > new field, and it would allow us to have a generic "resource_alignment()" > routine that just gets a resource pointer. Besides, I removed IORESOURCE_BUS_HAS_VGA flag which was unused for ages. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-08[POWERPC] Add arch-specific walk_memory_remove() for 64-bit powerpcBadari Pulavarty
walk_memory_resource() verifies if there are holes in a given memory range, by checking against /proc/iomem. On x86/ia64 system memory is represented in /proc/iomem. On powerpc, we don't show system memory as IO resource in /proc/iomem - instead it's maintained in /proc/device-tree. This provides a way for an architecture to provide its own walk_memory_resource() function. On powerpc, the memory region is small (16MB), contiguous and non-overlapping. So extra checking against the device-tree is not needed. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-14Add IORESOUCE_BUSY flag for System RAMYasunori Goto
i386 and x86-64 registers System RAM as IORESOURCE_MEM | IORESOURCE_BUSY. But ia64 registers it as IORESOURCE_MEM only. In addition, memory hotplug code registers new memory as IORESOURCE_MEM too. This difference causes a failure of memory unplug of x86-64. This patch fixes it. This patch adds IORESOURCE_BUSY to avoid potential overlap mapping by PCI device. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Luck, Tony" <tony.luck@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: memory hotplug cleanupKAMEZAWA Hiroyuki
A clean up patch for "scanning memory resource [start, end)" operation. Now, find_next_system_ram() function is used in memory hotplug, but this interface is not easy to use and codes are complicated. This patch adds walk_memory_resouce(start,len,arg,func) function. The function 'func' is called per valid memory resouce range in [start,pfn). [pbadari@us.ibm.com: Error handling in walk_memory_resource()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-28libata/IDE: remove combined mode quirkJeff Garzik
Both old-IDE and libata should be able handle all controllers and devices found using normal resource reservation methods. This eliminates the awful, low-performing split-driver configuration where old-IDE drove the PATA portion of a PCI device, in PIO-only mode, and libata drove the SATA portion of the /same/ PCI device, in DMA mode. Typically vendors would ship SATA hard drive / PATA optical configuration, which would lend itself to slow (PIO-only) CD-ROM performance. For Intel users running in combined mode, it is now wholly dependent on your driver choice (potentially link order, if you compile both drivers in) whether old-IDE or libata will drive your hardware. In either case, you will get full performance from both SATA and PATA ports now, without having to pass a kernel command line parameter. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] kernel-doc for kernel/resource.cRandy Dunlap
Add kernel-doc function headers in kernel/resource.c and use them in DocBook. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Resources: insert identical resources above existing resourcesMatthew Wilcox
If you have two resources which aree exactly the same size, insert_resource() currently inserts the new one below the existing one. This is wrong because there's no way to insert a resource of the same size above an existing one. I took this opportunity to rewrite the initial loop to be a for-loop instead of a goto-loop and fix the documentation. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06[PATCH] memory hotadd fixes: find_next_system_ram catch range fixKAMEZAWA Hiroyuki
find_next_system_ram() is used to find available memory resource at onlining newly added memory. This patch fixes following problem. find_next_system_ram() cannot catch this case. Resource: (start)-------------(end) Section : (start)-------------(end) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: change find_next_system_ram's return value mannerKAMEZAWA Hiroyuki
find_next_system_ram() returns valid memory range which meets requested area, only used by memory-hot-add. This function always rewrite requested resource even if returned area is not fully fit in requested one. And sometimes the returnd resource is larger than requested area. This annoyes the caller. This patch changes the returned value to fit in requested area. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-12[PATCH] The scheduled unexport of insert_resourceAdrian Bunk
Implement the scheduled unexport of insert_resource. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-27[PATCH] catch valid mem range at onlining memoryKAMEZAWA Hiroyuki
This patch allows hot-add memory which is not aligned to section. Now, hot-added memory has to be aligned to section size. Considering big section sized archs, this is not useful. When hot-added memory is registerd as iomem resoruce by iomem resource patch, we can make use of that information to detect valid memory range. Note: With this, not-aligned memory can be registerd. To allow hot-add memory with holes, we have to do more work around add_memory(). (It doesn't allows add memory to already existing mem section.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit Resource: finally enable 64bit resource sizesGreg Kroah-Hartman
Introduce the Kconfig entry and actually switch to a 64bit value, if wanted, for resource_size_t. Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: change resource core to use resource_size_tGreg Kroah-Hartman
2006-06-27[PATCH] 64bit resource: fix up printks for resources in arch and core codeGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> and Andrew Morton. (tweaked by Andy Isaacson <adi@hexapodia.org>) Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andy Isaacson <adi@hexapodia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] kernel/resource.c: __check_region(): remove pointless __deprecatedAdrian Bunk
If a __deprecated is desired it should go to the prototype in the header (where it currently isn't). But at this place it's pointless. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] introduce and use kzallocPekka J Enberg
This patch introduces a kzalloc wrapper and converts kernel/ to use it. It saves a little program text. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Use ALIGN to remove duplicate codeNick Wilson
This patch makes use of ALIGN() to remove duplicate round-up code. Signed-off-by: Nick Wilson <njw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] pci enumeration on ixp2000: overflow in kernel/resource.cLennert Buytenhek
IXP2000 (ARM-based) platforms use a separate 'struct resource' for PCI MEM space. Resource allocation for PCI BARs always fails because the 'root' resource (the IXP2000 PCI MEM resource) always has the entire address space (00000000-ffffffff) free, and find_resource() calculates the size of that range as ffffffff-00000000+1=0, so all allocations fail because it thinks there is no space. (akpm: pls. double-check) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
