Building with CONFIG_FAIR_GROUP_SCHED=y on UP results in an unused
cfs_rq_set_shares() reference. As nothing is using this dummy function
in the first place, just kill it off.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Kthreads that have called kthread_bind() are bound to specific cpus, so
other tasks should not be able to change their cpus_allowed from under
them. Otherwise, it is possible to move kthreads, such as the migration
or software watchdog threads, so they are not allowed access to the cpu
they work on.
Cc: Paul Menage <menage@google.com>
Cc: Paul Jackson <pj@sgi.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cliff Wickman wrote:
> I built an ia64 kernel from Andrew's tree (2.6.26-rc2-mm1)
> and get a very predictable hotplug cpu problem.
> billberry1:/tmp/cpw # ./dis
> disabled cpu 17
> enabled cpu 17
> disabled cpu 17
> enabled cpu 17
> The script that disables the cpu always hangs (unkillable)
> on the 3rd attempt.
> And a bit further:
> The kstopmachine thread always sits on the run queue (real time) for about
> 30 minutes before running.
this fix solves some (but not all) issues between CPU hotplug and
RT bandwidth throttling.
weighted_cpuload is only used on SMP. move it into the CONFIG_SMP
section.
kernel/cpu.c seems a more logical place for those maps since they do not really
have much to do with the scheduler these days.
kernel/cpu.c is now built for the UP kernel too, but it does not affect the size
the kernel sections.
$ size vmlinux
before
3313797 307060 310352 3931209 3bfc49 vmlinux
after
Signed-off-by: Max Krasnyansky <maxk@qualcomm.com>
Cc: pj@sgi.com
Cc: menage@google.com
Cc: rostedt@goodmis.org
Cc: mingo@elte.hu
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
cpusets
First issue is not related to the cpusets. We're simply leaking doms_cur.
It's allocated in arch_init_sched_domains() which is called for every
hotplug event. So we just keep reallocation doms_cur without freeing it.
I introduced free_sched_domains() function that cleans things up.
Second issue is that sched domains created by the cpusets are
completely destroyed by the CPU hotplug events. For all CPU hotplug
events scheduler attaches all CPUs to the NULL domain and then puts
them all into the single domain thereby destroying domains created
by the cpusets (partition_sched_domains).
The solution is simple, when cpusets are enabled scheduler should not
create default domain and instead let cpusets do that. Which is
exactly what the patch does.
Cc: pj@sgi.com
Cc: mingo@elte.hu
The RT folks over at RedHat found an issue w.r.t. hotplug support which
was traced to problems with the cpupri infrastructure in the scheduler:
https://bugzilla.redhat.com/show_bug.cgi?id=449676
This bug affects 23-rt12+, 24-rtX, 25-rtX, and sched-devel. This patch
applies to 25.4-rt4, though it should trivially apply to most cpupri enabled
kernels mentioned above.
It turned out that the issue was that offline cpus could get inadvertently
registered with cpupri so that they were erroneously selected during
migration decisions. The end result would be an OOPS as the offline cpu
had tasks routed to it.
This patch generalizes the old join/leave domain interface into an
online/offline interface, and adjusts the root-domain/hotplug code to
utilize it.
I was able to easily reproduce the issue prior to this patch, and am no
longer able to reproduce it after this patch. I can offline cpus
indefinately and everything seems to be in working order.
Thanks to Arnaldo (acme), Thomas, and Peter for doing the legwork to point
me in the right direction. Also thank you to Peter for reviewing the
early iterations of this patch.
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
While printing out the visual representation of the sched-domains, print
the level (MC, SMT, CPU, NODE, ... ) of each of the sched_domains.
Credit: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
make sched.c easier to read.
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
For the normal WARN_ON() etc we added a print-the-modules-list already,
which is very useful to figure out candidates for certain types of bugs.
This patch adds the same print to the "scheduling while atomic" BUG warning,
for the same reason: when we get here it's very useful to see which modules
are loaded, to narrow down the candidate code list.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: mingo@elte.hu
Fix this warning, which appears with !CONFIG_SMP:
kernel/sched.c:1216: warning: `init_hrtick' defined but not used
Signed-off-by: Rabin Vincent <rabin@rab.in>
Nothing really serious here, mainly just a matter of nit-picking :-/
From: Dmitry Adamushko <dmitry.adamushko@gmail.com>
For CONFIG_SCHED_DEBUG && CONFIG_SYSCT configs, sd->flags can be altered
while being manipulated in rebalance_domains(). Let's do an atomic check.
We rely here on the atomicity of read/write accesses for aligned words.
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
The current code use a linear algorithm which causes scaling issues
on larger SMP machines. This patch replaces that algorithm with a
2-dimensional bitmap to reduce latencies in the wake-up path.
Acked-by: Steven Rostedt <srostedt@redhat.com>
it is safe to ignore timers and flags when the feature is disabled.
Dmitry Adamushko pointed out a known flaw in the rt-balancing algorithm
that could allow suboptimal balancing if a non-migratable task gets
queued behind a running migratable one. It is discussed in this thread:
http://lkml.org/lkml/2008/4/22/296
This issue has been further exacerbated by a recent checkin to
sched-devel (git-id 5eee63a5ebc19a870ac40055c0be49457f3a89a3).
>From a pure priority standpoint, the run-queue is doing the "right"
thing. Using Dmitry's nomenclature, if T0 is on cpu1 first, and T1
wakes up at equal or lower priority (affined only to cpu1) later, it
*should* wait for T0 to finish. However, in reality that is likely
suboptimal from a system perspective if there are other cores that
could allow T0 and T1 to run concurrently. Since T1 can not migrate,
the only choice for higher concurrency is to try to move T0. This is
not something we addessed in the recent rt-balancing re-work.
This patch tries to enhance the balancing algorithm by accomodating this
scenario. It accomplishes this by incorporating the migratability of a
task into its priority calculation. Within a numerical tsk->prio, a
non-migratable task is logically higher than a migratable one. We
maintain this by introducing a new per-priority queue (xqueue, or
exclusive-queue) for holding non-migratable tasks. The scheduler will
draw from the xqueue over the standard shared-queue (squeue) when
available.
There are several details for utilizing this properly.
1) During task-wake-up, we not only need to check if the priority
preempts the current task, but we also need to check for this
non-migratable condition. Therefore, if a non-migratable task wakes
up and sees an equal priority migratable task already running, it
will attempt to preempt it *if* there is a likelyhood that the
current task will find an immediate home.
2) Tasks only get this non-migratable "priority boost" on wake-up. Any
requeuing will result in the non-migratable task being queued to the
end of the shared queue. This is an attempt to prevent the system
from being completely unfair to migratable tasks during things like
SCHED_RR timeslicing.
I am sure this patch introduces potentially "odd" behavior if you
concoct a scenario where a bunch of non-migratable threads could starve
migratable ones given the right pattern. I am not yet convinced that
this is a problem since we are talking about tasks of equal RT priority
anyway, and there never is much in the way of guarantees against
starvation under that scenario anyway. (e.g. you could come up with a
similar scenario with a specific timing environment verses an affinity
environment). I can be convinced otherwise, but for now I think this is
"ok".
CC: Dmitry Adamushko <dmitry.adamushko@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
Yanmin Zhang reported:
Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1.
It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito.
With bisect, I located the following patch:
| 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit
| commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e
| Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
| Date: Sat Apr 19 19:45:00 2008 +0200
| sched: fair-group: SMP-nice for group scheduling
Revert it so that we get v2.6.25 behavior.
Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Removes obfuscation and may improve assembly.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Comparing with kernel 2.6.25, sysbench+mysql(oltp, readonly) has many
regressions with 2.6.26-rc1:
1) 8-core stoakley: 28%;
2) 16-core tigerton: 20%;
3) Itanium Montvale: 50%.
Bisect located this patch:
| 8f1bc385cfbab474db6c27b5af1e439614f3025c is first bad commit
| commit 8f1bc385cfbab474db6c27b5af1e439614f3025c
| sched: fair: weight calculations
Revert it to the 2.6.25 state.
Return type of cpu_rt_runtime_write() should be int instead of ssize_t.
Signed-off-by: Mirco Tischler <mt-ml@gmx.de>
Acked-by: Paul Menage <menage@google.com>
It acts exactly like a regular 'cond_resched()', but will not get
optimized away when CONFIG_PREEMPT is set.
Normal kernel code is already preemptable in the presense of
CONFIG_PREEMPT, so cond_resched() is optimized away (see commit
02b67cc3ba36bdba351d6c3a00593f4ec550d9d3 "sched: do not do
cond_resched() when CONFIG_PREEMPT").
But when wanting to conditionally reschedule while holding a lock, you
need to use "cond_sched_lock(lock)", and the new function is the BKL
equivalent of that.
Also make fs/locks.c use it.
The generic semaphore rewrite had a huge performance regression on AIM7
(and potentially other BKL-heavy benchmarks) because the generic
semaphores had been rewritten to be simple to understand and fair. The
latter, in particular, turns a semaphore-based BKL implementation into a
mess of scheduling.
The attempt to fix the performance regression failed miserably (see the
previous commit 00b41ec2611dc98f87f30753ee00a53db648d662 'Revert
"semaphore: fix"'), and so for now the simple and sane approach is to
instead just go back to the old spinlock-based BKL implementation that
never had any issues like this.
This patch also has the advantage of being reported to fix the
regression completely according to Yanmin Zhang, unlike the semaphore
hack which still left a couple percentage point regression.
As a spinlock, the BKL obviously has the potential to be a latency
issue, but it's not really any different from any other spinlock in that
respect. We do want to get rid of the BKL asap, but that has been the
plan for several years.
These days, the biggest users are in the tty layer (open/release in
particular) and Alan holds out some hope:
"tty release is probably a few months away from getting cured - I'm
afraid it will almost certainly be the very last user of the BKL in
tty to get fixed as it depends on everything else being sanely locked."
so while we're not there yet, we do have a plan of action.
Tested-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Alexander Viro <viro@ftp.linux.org.uk>
this replaces the rq->clock stuff (and possibly cpu_clock()).
- architectures that have an 'imperfect' hardware clock can set
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
- the 'jiffie' window might be superfulous when we update tick_gtod
before the __update_sched_clock() call in sched_clock_tick()
- cpu_clock() might be implemented as:
sched_clock_cpu(smp_processor_id())
if the accuracy proves good enough - how far can TSC drift in a
single jiffie when considering the filtering and idle hooks?
[ mingo@elte.hu: various fixes and cleanups ]
David Miller pointed it out that nothing in cpu_clock() sets
prev_cpu_time. This caused __sync_cpu_clock() to be called
all the time - against the intention of this code.
The result was that in practice we hit a global spinlock every
time cpu_clock() is called - which - even though cpu_clock()
is used for tracing and debugging, is suboptimal.
While at it, also:
- move the irq disabling to the outest layer,
this should make cpu_clock() warp-free when called with irqs
enabled.
- use long long instead of cycles_t - for platforms where cycles_t
is 32-bit.
Reported-by: David Miller <davem@davemloft.net>
When I echoed 0 into the "cpu.shares" file, a Div0 error occured.
We found it is caused by the following calling.
sched_group_set_shares(tg, shares)
set_se_shares(tg->se[i], shares/nr_cpu_ids)
__set_se_shares(se, shares)
div64_64((1ULL<<32), shares)
When the echoed value was less than the number of processores, the result of the
sentence "shares/nr_cpu_ids" was 0, and then the system called div64() to divide
the result, the Div0 error occured.
It is unnecessary that the shares value is divided by nr_cpu_ids, I think.
Because in the function __update_group_shares_cpu() and init_tg_cfs_entry(),
the shares value isn't divided by nr_cpu_ids when setting shares of the sched
entity.
This patch fixes this bug. And echoing ULONG_MAX value into cpu.shares also
causes Div0 error, so we set a macro MAX_SHARES to limit the max value of
shares.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Concurrent calls to detach_destroy_domains and arch_init_sched_domains
were prevented by the old scheduler subsystem cpu hotplug mutex. When
this got converted to get_online_cpus() the locking got broken.
Unlike before now several processes can concurrently enter the critical
sections that were protected by the old lock.
So use the already present doms_cur_mutex to protect these sections again.
Cc: Gautham R Shenoy <ego@in.ibm.com>
make time_sync_thresh tunable to architecture code.
http://bugzilla.kernel.org/show_bug.cgi?id=10545
sched_stats.h says that __sched_info_switch is "called when prev !=
next" in the comment. sched.c should therefore do that.
Gautham R Shenoy reported:
> While running the usual CPU-Hotplug stress tests on linux-2.6.25,
> I noticed the following in the console logs.
> This is a wee bit difficult to reproduce. In the past 10 runs I hit this
> only once.
> ------------[ cut here ]------------
> WARNING: at kernel/sched.c:962 hrtick+0x2e/0x65()
> Just wondering if we are doing a good job at handling the cancellation
> of any per-cpu scheduler timers during CPU-Hotplug.
This looks like its indeed not cancelled at all and migrates the it to
another cpu. Fix it via a proper hotplug notifier mechanism.
Reported-by: Gautham R Shenoy <ego@in.ibm.com>
Cc: stable@kernel.org
Noticed by sparse:
kernel/sched.c:760:20: warning: symbol 'sched_feat_names' was not declared. Should it be static?
kernel/sched.c:767:5: warning: symbol 'sched_feat_open' was not declared. Should it be static?
kernel/sched_fair.c:845:3: warning: returning void-valued expression
kernel/sched.c:4386:3: warning: returning void-valued expression
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: "Justin Mattock" <justinmattock@gmail.com>
Joel noticed that the !lw->inv_weight contition isn't unlikely anymore so
remove the unlikely annotation. Also, remove the two div64_u64() inv_weight
calculations, which makes them rely on the calc_delta_mine() path as well.
CC: Joel Schopp <jschopp@austin.ibm.com>
Rename div64_64 to div64_u64 to make it consistent with the other divide
functions, so it clearly includes the type of the divide. Move its definition
to math64.h as currently no architecture overrides the generic implementation.
They can still override it of course, but the duplicated declarations are
avoided.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Patrick McHardy <kaber@trash.net>
This removes some filesystem boilerplate from the CFS cgroup subsystem.
Signed-off-by: Paul Menage <menage@google.com>
Several people have justifiably complained that the "_uint" suffix is
inappropriate for functions that handle u64 values, so this patch just renames
all these functions and their users to have the suffic _u64.
[peterz@infradead.org: build fix]
Cc: "Li Zefan" <lizf@cn.fujitsu.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: "YAMAMOTO Takashi" <yamamoto@valinux.co.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[PATCH] Build fix for CONFIG_NUMA=y && CONFIG_SMP=n
[IA64] fix bootmem regression on Altix
git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-fixes
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-fixes:
sched: fix share (re)distribution
softlockup: fix NOHZ wakeup
seqlock: livelock fix
There is no guarantee that there is physical ram below 4GB, and in
fact many boxes don't have exactly that.
fix __aggregate_redistribute_shares() related lockup reported by
David S. Miller.
The problem this code tries to solve is 'accurately' calculating the 'fair'
share of the group weight for each cpu. The current code falls back to a global
group rebalance in case the sched_domain's span it looks at has no shares, but
does have tasks.
The reason it gets stuck here, is because its inherently racy - if someone
steals the last task after we compute the agg->rq_weight, but before we
rebalance, we'll never get out of the loop.
We could of course go fix that, but while looking at this issue I found that
this 'fallback' wasn't nearly as rare as I'd hoped it to be. In fact its quite
common - and given it walks the whole machine, thats very bad.
The new approach is simple (why didn't I think of it before?), we set the
aggregate shares to the full task group weight, and each larger sched domain
that encounters an aggregate shares larger than the weight, clips it (it
already re-distributes anyway).
This nicely converges to the desired global picture where the sum of all
shares equals the task group weight.
Regression caused by 434d53b00d6bb7be0a1d3dcc0d0d5df6c042e164
Signed-off-by: Mike Travis <travis@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
A recent change prevents SGI Altix from booting.
This patch fixes the problem.
The regresson was introduced in commit 434d53b00d6bb7be0a1d3dcc0d0d5df6c042e164
Signed-off-by: Russ Anderson <rja@sgi.com>
Add missing kernel-doc in kernel/sched.c:
Warning(linux-2.6.25-git3//kernel/sched.c:7044): No description found for parameter 'span'
provide a text based interface to the scheduler features; this saves the
'user' from setting bits using decimal arithmetic.
unused at the moment.
In order to level the hierarchy, we need to calculate load based on the
root view. That is, each task's load is in the same unit.
A
B 1
2 3
To compute 1's load we do:
weight(1)
rq_weight(A)
To compute 2's load we do:
weight(2) weight(B)
rq_weight(B) rw_weight(A)
This yields load fractions in comparable units.
The consequence is that it changes virtual time. We used to have:
time_{i}
vtime_{i} = ------------
weight_{i}
vtime = \Sum vtime_{i} = time / rq_weight.
But with the new way of load calculation we get that vtime equals time.
De-couple load-balancing from the rb-trees, so that I can change their
organization.
Implement SMP nice support for the full group hierarchy.
On each load-balance action, compile a sched_domain wide view of the full
task_group tree. We compute the domain wide view when walking down the
hierarchy, and readjust the weights when walking back up.
After collecting and readjusting the domain wide view, we try to balance the
tasks within the task_groups. The current approach is a naively balance each
task group until we've moved the targeted amount of load.
Inspired by Srivatsa Vaddsgiri's previous code and Abhishek Chandra's H-SMP
paper.
XXX: there will be some numerical issues due to the limited nature of
SCHED_LOAD_SCALE wrt to representing a task_groups influence on the
total weight. When the tree is deep enough, or the task weight small
enough, we'll run out of bits.
CC: Abhishek Chandra <chandra@cs.umn.edu>
CC: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
[rebased for sched-devel/latest]
- Add a new cpuset file, having levels:
sched_relax_domain_level
- Modify partition_sched_domains() and build_sched_domains()
to take attributes parameter passed from cpuset.
- Fill newidle_idx for node domains which currently unused but
might be required if sched_relax_domain_level become higher.
- We can change the default level by boot option 'relax_domain_level='.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
