path: root/kernel/sched.c
2010-08-13sched: Revert nohz_ratelimit() for nowPeter Zijlstra
commit 396e894d289d69bacf5acd983c97cd6e21a14c08 upstream. Norbert reported that nohz_ratelimit() causes his laptop to burn about 4W (40%) extra. For now back out the change and see if we can adjust the power management code to make better decisions. Reported-by: Norbert Preining <preining@logic.at> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Mike Galbraith <efault@gmx.de> Cc: Arjan van de Ven <arjan@infradead.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-02Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Cure nr_iowait_cpu() users init: Fix comment init, sched: Fix race between init and kthreadd
2010-07-01sched: Cure nr_iowait_cpu() usersPeter Zijlstra
Commit 0224cf4c5e (sched: Intoduce get_cpu_iowait_time_us()) broke things by not making sure preemption was indeed disabled by the callers of nr_iowait_cpu() which took the iowait value of the current cpu. This resulted in a heap of preempt warnings. Cure this by making nr_iowait_cpu() take a cpu number and fix up the callers to pass in the right number. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Jiri Slaby <jslaby@suse.cz> Cc: linux-pm@lists.linux-foundation.org LKML-Reference: <1277968037.1868.120.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-28Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Prevent compiler from optimising the sched_avg_update() loop sched: Fix over-scheduling bug sched: Fix PROVE_RCU vs cpu_cgroup
2010-06-25sched: Prevent compiler from optimising the sched_avg_update() loopWill Deacon
GCC 4.4.1 on ARM has been observed to replace the while loop in sched_avg_update with a call to uldivmod, resulting in the following build failure at link-time: kernel/built-in.o: In function `sched_avg_update': kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod' kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod' make: *** [.tmp_vmlinux1] Error 1 This patch introduces a fake data hazard to the loop body to prevent the compiler optimising the loop away. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-23sched: silence PROVE_RCU in sched_fork()Peter Zijlstra
Because cgroup_fork() is ran before sched_fork() [ from copy_process() ] and the child's pid is not yet visible the child is pinned to its cgroup. Therefore we can silence this warning. A nicer solution would be moving cgroup_fork() to right after dup_task_struct() and exclude PF_STARTING from task_subsys_state(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-06-18sched: Fix over-scheduling bugAlex,Shi
Commit e70971591 ("sched: Optimize unused cgroup configuration") introduced an imbalanced scheduling bug. If we do not use CGROUP, function update_h_load won't update h_load. When the system has a large number of tasks far more than logical CPU number, the incorrect cfs_rq[cpu]->h_load value will cause load_balance() to pull too many tasks to the local CPU from the busiest CPU. So the busiest CPU keeps going in a round robin. That will hurt performance. The issue was found originally by a scientific calculation workload that developed by Yanmin. With that commit, the workload performance drops about 40%. CPU before after 00 : 2 : 7 01 : 1 : 7 02 : 11 : 6 03 : 12 : 7 04 : 6 : 6 05 : 11 : 7 06 : 10 : 6 07 : 12 : 7 08 : 11 : 6 09 : 12 : 6 10 : 1 : 6 11 : 1 : 6 12 : 6 : 6 13 : 2 : 6 14 : 2 : 6 15 : 1 : 6 Reviewed-by: Yanmin zhang <yanmin.zhang@intel.com> Signed-off-by: Alex Shi <alex.shi@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1276754893.9452.5442.camel@debian> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-08sched: Fix PROVE_RCU vs cpu_cgroupPeter Zijlstra
PROVE_RCU has a few issues with the cpu_cgroup because the scheduler typically holds rq->lock around the css rcu derefs but the generic cgroup code doesn't (and can't) know about that lock. Provide means to add extra checks to the css dereference and use that in the scheduler to annotate its users. The addition of rq->lock to these checks is correct because the cgroup_subsys::attach() method takes the rq->lock for each task it moves, therefore by holding that lock, we ensure the task is pinned to the current cgroup and the RCU derefence is valid. That leaves one genuine race in __sched_setscheduler() where we used task_group() without holding any of the required locks and thus raced with the cgroup code. Solve this by moving the check under the appropriate lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-01sched: Fix wake_affine() vs RT tasksPeter Zijlstra
Mike reports that since e9e9250b (sched: Scale down cpu_power due to RT tasks), wake_affine() goes funny on RT tasks due to them still having a !0 weight and wake_affine() still subtracts that from the rq weight. Since nobody should be using se->weight for RT tasks, set the value to zero. Also, since we now use ->cpu_power to normalize rq weights to account for RT cpu usage, add that factor into the imbalance computation. Reported-by: Mike Galbraith <efault@gmx.de> Tested-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1275316109.27810.22969.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: clean up on forwarded aborted mds request ceph: fix leak of osd authorizer ceph: close out mds, osd connections before stopping auth ceph: make lease code DN specific fs/ceph: Use ERR_CAST ceph: renew auth tickets before they expire ceph: do not resend mon requests on auth ticket renewal ceph: removed duplicated #includes ceph: avoid possible null dereference ceph: make mds requests killable, not interruptible sched: add wait_for_completion_killable_timeout
2010-05-29sched: add wait_for_completion_killable_timeoutSage Weil
Add missing _killable_timeout variant for wait_for_completion that will return when a timeout expires or the task is killed. CC: Ingo Molnar <mingo@elte.hu> CC: Andreas Herrmann <andreas.herrmann3@amd.com> CC: Thomas Gleixner <tglx@linutronix.de> CC: Mike Galbraith <efault@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-27signals: kill the awful task_rq_unlock_wait() hackOleg Nesterov
Now that task->signal can't go away we can revert the horrible hack added by ad474caca3e2a0550b7ce0706527ad5ab389a4d4 ("fix for account_group_exec_runtime(), make sure ->signal can't be freed under rq->lock"). And we can do more cleanups sched_stats.h/posix-cpu-timers.c later. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21Merge branch 'kdb-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'kdb-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: (25 commits) kdb,debug_core: Allow the debug core to receive a panic notification MAINTAINERS: update kgdb, kdb, and debug_core info debug_core,kdb: Allow the debug core to process a recursive debug entry printk,kdb: capture printk() when in kdb shell kgdboc,kdb: Allow kdb to work on a non open console port kgdb: Add the ability to schedule a breakpoint via a tasklet mips,kgdb: kdb low level trap catch and stack trace powerpc,kgdb: Introduce low level trap catching x86,kgdb: Add low level debug hook kgdb: remove post_primary_code references kgdb,docs: Update the kgdb docs to include kdb kgdboc,keyboard: Keyboard driver for kdb with kgdb kgdb: gdb "monitor" -> kdb passthrough sparc,sunzilog: Add console polling support for sunzilog serial driver sh,sh-sci: Use NO_POLL_CHAR in the SCIF polled console code kgdb,8250,pl011: Return immediately from console poll kgdb: core changes to support kdb kdb: core for kgdb back end (2 of 2) kdb: core for kgdb back end (1 of 2) kgdb,blackfin: Add in kgdb_arch_set_pc for blackfin ...
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits) USB: remove unused usb_buffer_alloc and usb_buffer_free macros usb: musb: update gfp/slab.h includes USB: ftdi_sio: fix legacy SIO-device header USB: kl5usb105: reimplement using generic framework USB: kl5usb105: minor clean ups USB: kl5usb105: fix memory leak USB: io_ti: use kfifo to implement write buffering USB: io_ti: remove unsused private counter USB: ti_usb: use kfifo to implement write buffering USB: ir-usb: fix incorrect write-buffer length USB: aircable: fix incorrect write-buffer length USB: safe_serial: straighten out read processing USB: safe_serial: reimplement read using generic framework USB: safe_serial: reimplement write using generic framework usb-storage: always print quirks USB: usb-storage: trivial debug improvements USB: oti6858: use port write fifo USB: oti6858: use kfifo to implement write buffering USB: cypress_m8: use kfifo to implement write buffering USB: cypress_m8: remove unused drain define ... Fix up conflicts (due to usb_buffer_alloc/free renaming) in drivers/input/tablet/acecad.c drivers/input/tablet/kbtab.c drivers/input/tablet/wacom_sys.c drivers/media/video/gspca/gspca.c sound/usb/usbaudio.c
2010-05-20kdb: core for kgdb back end (2 of 2)Jason Wessel
This patch contains the hooks and instrumentation into kernel which live outside the kernel/debug directory, which the kdb core will call to run commands like lsmod, dmesg, bt etc... CC: linux-arch@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Martin Hicks <mort@sgi.com>
2010-05-20wait_event_interruptible_locked() interfaceMichal Nazarewicz
New wait_event_interruptible{,_exclusive}_locked{,_irq} macros added. They work just like versions without _locked* suffix but require the wait queue's lock to be held. Also __wake_up_locked() is now exported as to pair it with the above macros. The use case of this new facility is when one uses wait queue's lock to protect a data structure. This may be advantageous if the structure needs to be protected by a spinlock anyway. In particular, with additional spinlock the following code has to be used to wait for a condition: spin_lock(&data.lock); ... for (ret = 0; !ret && !(condition); ) { spin_unlock(&data.lock); ret = wait_event_interruptible(data.wqh, (condition)); spin_lock(&data.lock); } ... spin_unlock(&data.lock); This looks bizarre plus wait_event_interruptible() locks the wait queue's lock anyway so there is a unlock+lock sequence where it could be avoided. To avoid those problems and benefit from wait queue's lock, a code similar to the following should be used: /* Waiting */ spin_lock(&data.wqh.lock); ... ret = wait_event_interruptible_locked(data.wqh, (condition)); ... spin_unlock(&data.wqh.lock); /* Waiting exclusively */ spin_lock(&data.whq.lock); ... ret = wait_event_interruptible_exclusive_locked(data.whq, (condition)); ... spin_unlock(&data.whq.lock); /* Waking up */ spin_lock(&data.wqh.lock); ... wake_up_locked(&data.wqh); ... spin_unlock(&data.wqh.lock); When spin_lock_irq() is used matching versions of macros need to be used (*_locked_irq()). Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Takashi Iwai <tiwai@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (49 commits) stop_machine: Move local variable closer to the usage site in cpu_stop_cpu_callback() sched, wait: Use wrapper functions sched: Remove a stale comment ondemand: Make the iowait-is-busy time a sysfs tunable ondemand: Solve a big performance issue by counting IOWAIT time as busy sched: Intoduce get_cpu_iowait_time_us() sched: Eliminate the ts->idle_lastupdate field sched: Fold updating of the last_update_time_info into update_ts_time_stats() sched: Update the idle statistics in get_cpu_idle_time_us() sched: Introduce a function to update the idle statistics sched: Add a comment to get_cpu_idle_time_us() cpu_stop: add dummy implementation for UP sched: Remove rq argument to the tracepoints rcu: need barrier() in UP synchronize_sched_expedited() sched: correctly place paranioa memory barriers in synchronize_sched_expedited() sched: kill paranoia check in synchronize_sched_expedited() sched: replace migration_thread with cpu_stop stop_machine: reimplement using cpu_stop cpu_stop: implement stop_cpu[s]() sched: Fix select_idle_sibling() logic in select_task_rq_fair() ...
2010-05-18Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits) perf tools: Add mode to build without newt support perf symbols: symbol inconsistency message should be done only at verbose=1 perf tui: Add explicit -lslang option perf options: Type check all the remaining OPT_ variants perf options: Type check OPT_BOOLEAN and fix the offenders perf options: Check v type in OPT_U?INTEGER perf options: Introduce OPT_UINTEGER perf tui: Add workaround for slang < 2.1.4 perf record: Fix bug mismatch with -c option definition perf options: Introduce OPT_U64 perf tui: Add help window to show key associations perf tui: Make <- exit menus too perf newt: Add single key shortcuts for zoom into DSO and threads perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed perf newt: Fix the 'A'/'a' shortcut for annotate perf newt: Make <- exit the ui_browser x86, perf: P4 PMU - fix counters management logic perf newt: Make <- zoom out filters perf report: Report number of events, not samples perf hist: Clarify events_stats fields usage ... Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
2010-05-11sched, wait: Use wrapper functionsChangli Gao
epoll should not touch flags in wait_queue_t. This patch introduces a new function __add_wait_queue_exclusive(), for the users, who use wait queue as a LIFO queue. __add_wait_queue_tail_exclusive() is introduced too instead of add_wait_queue_exclusive_locked(). remove_wait_queue_locked() is removed, as it is a duplicate of __remove_wait_queue(), disliked by users, and with less users. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: <containers@lists.linux-foundation.org> LKML-Reference: <1273214006-2979-1-git-send-email-xiaosuo@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-10rcu: refactor RCU's context-switch handlingPaul E. McKenney
The addition of preemptible RCU to treercu resulted in a bit of confusion and inefficiency surrounding the handling of context switches for RCU-sched and for RCU-preempt. For RCU-sched, a context switch is a quiescent state, pure and simple, just like it always has been. For RCU-preempt, a context switch is in no way a quiescent state, but special handling is required when a task blocks in an RCU read-side critical section. However, the callout from the scheduler and the outer loop in ksoftirqd still calls something named rcu_sched_qs(), whose name is no longer accurate. Furthermore, when rcu_check_callbacks() notes an RCU-sched quiescent state, it ends up unnecessarily (though harmlessly, aside from the performance hit) enqueuing the current task if it happens to be running in an RCU-preempt read-side critical section. This not only increases the maximum latency of scheduler_tick(), it also needlessly increases the overhead of the next outermost rcu_read_unlock() invocation. This patch addresses this situation by separating the notion of RCU's context-switch handling from that of RCU-sched's quiescent states. The context-switch handling is covered by rcu_note_context_switch() in general and by rcu_preempt_note_context_switch() for preemptible RCU. This permits rcu_sched_qs() to handle quiescent states and only quiescent states. It also reduces the maximum latency of scheduler_tick(), though probably by much less than a microsecond. Finally, it means that tasks within preemptible-RCU read-side critical sections avoid incurring the overhead of queuing unless there really is a context switch. Suggested-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org>
2010-05-08Merge branch 'cpu_stop' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into sched/core
2010-05-07Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: Resolve patch dependency Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-07sched: Remove rq argument to the tracepointsPeter Zijlstra
struct rq isn't visible outside of sched.o so its near useless to expose the pointer, also there are no users of it, so remove it. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1272997616.1642.207.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-07rcu: need barrier() in UP synchronize_sched_expedited()Paul E. McKenney
If synchronize_sched_expedited() is ever to be called from within kernel/sched.c in a !SMP PREEMPT kernel, the !SMP implementation needs a barrier(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-05-06sched: correctly place paranioa memory barriers in synchronize_sched_expedited()Paul E. McKenney
The memory barriers must be in the SMP case, not in the !SMP case. Also add a barrier after the atomic_inc() in order to ensure that other CPUs see post-synchronize_sched_expedited() actions as following the expedited grace period. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-05-06sched: kill paranoia check in synchronize_sched_expedited()Tejun Heo
The paranoid check which verifies that the cpu_stop callback is actually called on all online cpus is completely superflous. It's guaranteed by cpu_stop facility and if it didn't work as advertised other things would go horribly wrong and trying to recover using synchronize_sched() wouldn't be very meaningful. Kill the paranoid check. Removal of this feature is done as a separate step so that it can serve as a bisection point if something actually goes wrong. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Josh Triplett <josh@freedesktop.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-05-06sched: replace migration_thread with cpu_stopTejun Heo
Currently migration_thread is serving three purposes - migration pusher, context to execute active_load_balance() and forced context switcher for expedited RCU synchronize_sched. All three roles are hardcoded into migration_thread() and determining which job is scheduled is slightly messy. This patch kills migration_thread and replaces all three uses with cpu_stop. The three different roles of migration_thread() are splitted into three separate cpu_stop callbacks - migration_cpu_stop(), active_load_balance_cpu_stop() and synchronize_sched_expedited_cpu_stop() - and each use case now simply asks cpu_stop to execute the callback as necessary. synchronize_sched_expedited() was implemented with private preallocated resources and custom multi-cpu queueing and waiting logic, both of which are provided by cpu_stop. synchronize_sched_expedited_count is made atomic and all other shared resources along with the mutex are dropped. synchronize_sched_expedited() also implemented a check to detect cases where not all the callback got executed on their assigned cpus and fall back to synchronize_sched(). If called with cpu hotplug blocked, cpu_stop already guarantees that and the condition cannot happen; otherwise, stop_machine() would break. However, this patch preserves the paranoid check using a cpumask to record on which cpus the stopper ran so that it can serve as a bisection point if something actually goes wrong theree. Because the internal execution state is no longer visible, rcu_expedited_torture_stats() is removed. This patch also renames cpu_stop threads to from "stopper/%d" to "migration/%d". The names of these threads ultimately don't matter and there's no reason to make unnecessary userland visible changes. With this patch applied, stop_machine() and sched now share the same resources. stop_machine() is faster without wasting any resources and sched migration users are much cleaner. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Josh Triplett <josh@freedesktop.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-04-30rcu: Fix RCU lockdep splat in set_task_cpu on fork pathPeter Zijlstra
Add an RCU read-side critical section to suppress this false positive. Located-by: Eric Paris <eparis@parisplace.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: eric.dumazet@gmail.com LKML-Reference: <1271880131-3951-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: merge the latest fixes, update to latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23sched: Pre-compute cpumask_weight(sched_domain_span(sd))Peter Zijlstra
Dave reported that his large SPARC machines spend lots of time in hweight64(), try and optimize some of those needless cpumask_weight() invocations (esp. with the large offstack cpumasks these are very expensive indeed). Reported-by: David Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23sched: Cure load average vs NO_HZ woesPeter Zijlstra
Chase reported that due to us decrementing calc_load_task prematurely (before the next LOAD_FREQ sample), the load average could be scewed by as much as the number of CPUs in the machine. This patch, based on Chase's patch, cures the problem by keeping the delta of the CPU going into NO_HZ idle separately and folding that in on the next LOAD_FREQ update. This restores the balance and we get strict LOAD_FREQ period samples. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chase Douglas <chase.douglas@canonical.com> LKML-Reference: <1271934490.1776.343.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23mutex: Don't spin when the owner CPU is offline or other weird casesBenjamin Herrenschmidt
Due to recent load-balancer changes that delay the task migration to the next wakeup, the adaptive mutex spinning ends up in a live lock when the owner's CPU gets offlined because the cpu_online() check lives before the owner running check. This patch changes mutex_spin_on_owner() to return 0 (don't spin) in any case where we aren't sure about the owner struct validity or CPU number, and if the said CPU is offline. There is no point going back & re-evaluate spinning in corner cases like that, let's just go to sleep. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1271212509.13059.135.camel@pasglop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-15sched: Fix UP update_avg() build warningMike Galbraith
update_avg() is only used for SMP builds, move it to the nearest SMP block. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1271309399.14779.17.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-15Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: merge the latest fixes, update to -rc4. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-08Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix sched_getaffinity()
2010-04-08Merge branch 'linus' into perf/coreIngo Molnar
Semantic conflict: arch/x86/kernel/cpu/perf_event_intel_ds.c Merge reason: pick up latest fixes, fix the conflict Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-06sched: Fix sched_getaffinity()Anton Blanchard
taskset on 2.6.34-rc3 fails on one of my ppc64 test boxes with the following error: sched_getaffinity(0, 16, 0x10029650030) = -1 EINVAL (Invalid argument) This box has 128 threads and 16 bytes is enough to cover it. Commit cd3d8031eb4311e516329aee03c79a08333141f1 (sched: sched_getaffinity(): Allow less than NR_CPUS length) is comparing this 16 bytes agains nr_cpu_ids. Fix it by comparing nr_cpu_ids to the number of bits in the cpumask we pass in. Signed-off-by: Anton Blanchard <anton@samba.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Sharyathi Nagesh <sharyath@in.ibm.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Russ Anderson <rja@sgi.com> Cc: Mike Travis <travis@sgi.com> LKML-Reference: <20100406070218.GM5594@kryten> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-04-02sched: Add enqueue/dequeue flagsPeter Zijlstra
In order to reduce the dependency on TASK_WAKING rework the enqueue interface to support a proper flags field. Replace the int wakeup, bool head arguments with an int flags argument and create the following flags: ENQUEUE_WAKEUP - the enqueue is a wakeup of a sleeping task, ENQUEUE_WAKING - the enqueue has relative vruntime due to having sched_class::task_waking() called, ENQUEUE_HEAD - the waking task should be places on the head of the priority queue (where appropriate). For symmetry also convert sched_class::dequeue() to a flags scheme. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Fix nr_uninterruptible countPeter Zijlstra
The cpuload calculation in calc_load_account_active() assumes rq->nr_uninterruptible will not change on an offline cpu after migrate_nr_uninterruptible(). However the recent migrate on wakeup changes broke that and would result in decrementing the offline cpu's rq->nr_uninterruptible. Fix this by accounting the nr_uninterruptible on the waking cpu. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Optimize task_rq_lock()Peter Zijlstra
Now that we hold the rq->lock over set_task_cpu() again, we can do away with most of the TASK_WAKING checks and reduce them again to set_cpus_allowed_ptr(). Removes some conditionals from scheduling hot-paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Fix TASK_WAKING vs fork deadlockPeter Zijlstra
Oleg noticed a few races with the TASK_WAKING usage on fork. - since TASK_WAKING is basically a spinlock, it should be IRQ safe - since we set TASK_WAKING (*) without holding rq->lock it could be there still is a rq->lock holder, thereby not actually providing full serialization. (*) in fact we clear PF_STARTING, which in effect enables TASK_WAKING. Cure the second issue by not setting TASK_WAKING in sched_fork(), but only temporarily in wake_up_new_task() while calling select_task_rq(). Cure the first by holding rq->lock around the select_task_rq() call, this will disable IRQs, this however requires that we push down the rq->lock release into select_task_rq_fair()'s cgroup stuff. Because select_task_rq_fair() still needs to drop the rq->lock we cannot fully get rid of TASK_WAKING. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Make select_fallback_rq() cpuset friendlyOleg Nesterov
Introduce cpuset_cpus_allowed_fallback() helper to fix the cpuset problems with select_fallback_rq(). It can be called from any context and can't use any cpuset locks including task_lock(). It is called when the task doesn't have online cpus in ->cpus_allowed but ttwu/etc must be able to find a suitable cpu. I am not proud of this patch. Everything which needs such a fat comment can't be good even if correct. But I'd prefer to not change the locking rules in the code I hardly understand, and in any case I believe this simple change make the code much more correct compared to deadlocks we currently have. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091027.GA9155@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: _cpu_down(): Don't play with current->cpus_allowedOleg Nesterov
_cpu_down() changes the current task's affinity and then recovers it at the end. The problems are well known: we can't restore old_allowed if it was bound to the now-dead-cpu, and we can race with the userspace which can change cpu-affinity during unplug. _cpu_down() should not play with current->cpus_allowed at all. Instead, take_cpu_down() can migrate the caller of _cpu_down() after __cpu_disable() removes the dying cpu from cpu_online_mask. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091023.GA9148@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: sched_exec(): Remove the select_fallback_rq() logicOleg Nesterov
sched_exec()->select_task_rq() reads/updates ->cpus_allowed lockless. This can race with other CPUs updating our ->cpus_allowed, and this looks meaningless to me. The task is current and running, it must have online cpus in ->cpus_allowed, the fallback mode is bogus. And, if ->sched_class returns the "wrong" cpu, this likely means we raced with set_cpus_allowed() which was called for reason, why should sched_exec() retry and call ->select_task_rq() again? Change the code to call sched_class->select_task_rq() directly and do nothing if the returned cpu is wrong after re-checking under rq->lock. From now task_struct->cpus_allowed is always stable under TASK_WAKING, select_fallback_rq() is always called under rq-lock or the caller or the caller owns TASK_WAKING (select_task_rq). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091019.GA9141@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: move_task_off_dead_cpu(): Remove retry logicOleg Nesterov
The previous patch preserved the retry logic, but it looks unneeded. __migrate_task() can only fail if we raced with migration after we dropped the lock, but in this case the caller of set_cpus_allowed/etc must initiate migration itself if ->on_rq == T. We already fixed p->cpus_allowed, the changes in active/online masks must be visible to racer, it should migrate the task to online cpu correctly. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091014.GA9138@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: move_task_off_dead_cpu(): Take rq->lock around select_fallback_rq()Oleg Nesterov
move_task_off_dead_cpu()->select_fallback_rq() reads/updates ->cpus_allowed lockless. We can race with set_cpus_allowed() running in parallel. Change it to take rq->lock around select_fallback_rq(). Note that it is not trivial to move this spin_lock() into select_fallback_rq(), we must recheck the task was not migrated after we take the lock and other callers do not need this lock. To avoid the races with other callers of select_fallback_rq() which rely on TASK_WAKING, we also check p->state != TASK_WAKING and do nothing otherwise. The owner of TASK_WAKING must update ->cpus_allowed and choose the correct CPU anyway, and the subsequent __migrate_task() is just meaningless because p->se.on_rq must be false. Alternatively, we could change select_task_rq() to take rq->lock right after it calls sched_class->select_task_rq(), but this looks a bit ugly. Also, change it to not assume irqs are disabled and absorb __migrate_task_irq(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091010.GA9131@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Kill the broken and deadlockable ↵Oleg Nesterov
cpuset_lock/cpuset_cpus_allowed_locked code This patch just states the fact the cpusets/cpuhotplug interaction is broken and removes the deadlockable code which only pretends to work. - cpuset_lock() doesn't really work. It is needed for cpuset_cpus_allowed_locked() but we can't take this lock in try_to_wake_up()->select_fallback_rq() path. - cpuset_lock() is deadlockable. Suppose that a task T bound to CPU takes callback_mutex. If cpu_down(CPU) happens before T drops callback_mutex stop_machine() preempts T, then migration_call(CPU_DEAD) tries to take cpuset_lock() and hangs forever because CPU is already dead and thus T can't be scheduled. - cpuset_cpus_allowed_locked() is deadlockable too. It takes task_lock() which is not irq-safe, but try_to_wake_up() can be called from irq. Kill them, and change select_fallback_rq() to use cpu_possible_mask, like we currently do without CONFIG_CPUSETS. Also, with or without this patch, with or without CONFIG_CPUSETS, the callers of select_fallback_rq() can race with each other or with set_cpus_allowed() pathes. The subsequent patches try to to fix these problems. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100315091003.GA9123@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: set_cpus_allowed_ptr(): Don't use rq->migration_thread after unlockOleg Nesterov
Trivial typo fix. rq->migration_thread can be NULL after task_rq_unlock(), this is why we have "mt" which should be used instead. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100330165829.GA18284@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: update to latest upstream Signed-off-by: Ingo Molnar <mingo@elte.hu>
