path: root/kernel/sched.c
2011-11-17sched: Move all scheduler bits into kernel/sched/Peter Zijlstra
There's too many sched*.[ch] files in kernel/, give them their own directory. (No code changed, other than Makefile glue added.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-17sched: Make separate sched*.c translation unitsPeter Zijlstra
Since once needs to do something at conferences and fixing compile warnings doesn't actually require much if any attention I decided to break up the sched.c #include "*.c" fest. This further modularizes the scheduler code. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-x0fcd3mnp8f9c99grcpewmhi@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-16sched: Don't call task_group() too many times in set_task_rq()Andrew Vagin
It improves perfomance, especially if autogroup is enabled. The size of set_task_rq() was 0x180 and now it is 0xa0. Signed-off-by: Andrew Vagin <avagin@openvz.org> Acked-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1321020240-3874331-1-git-send-email-avagin@openvz.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-16sched, trivial: Initialize root cgroup's sibling listGlauber Costa
Even though there are no siblings, the list should be initialized to not contain bogus values. Signed-off-by: Glauber Costa <glommer@parallels.com> Acked-by: Paul Menage <paul@paulmenage.org> Acked-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1320182360-20043-2-git-send-email-glommer@parallels.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-16sched: Use jump labels to reduce overhead when bandwidth control is inactivePaul Turner
Now that the linkage of jump-labels has been fixed they show a measurable improvement in overhead for the enabled-but-unused case. Workload is: 'taskset -c 0 perf stat --repeat 50 -e instructions,cycles,branches bash -c "for ((i=0;i<5;i++)); do $(dirname $0)/pipe-test 20000; done"' There's a speedup for all situations: instructions cycles branches ------------------------------------------------------------------------- Intel Westmere base 806611770 745895590 146765378 +jumplabel 803090165 (-0.44%) 713381840 (-4.36%) 144561130 AMD Barcelona base 824657415 740055589 148855354 +jumplabel 821056910 (-0.44%) 737558389 (-0.34%) 146635229 Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111108042736.560831357@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-14sched: Set the command name of the idle tasks in SMP kernelsCarsten Emde
In UP systems, the idle task is initialized using the init_task structure from which the command name is taken (currently "swapper"). In SMP systems, one idle task per CPU is forked by the worker thread from which the task structure is copied. The command name is, therefore, "kworker/0:0" or "kworker/0:1", if not updated. Since such update was lacking, all idle tasks in SMP systems were incorrectly named. This longtime bug was not discovered immediately, because there is no /proc/0 entry - the bug only becomes apparent when tracing is enabled. This patch sets the command name of the idle tasks in SMP systems to the name that is used in the INIT_TASK structure suffixed by a slash and the number of the CPU. Signed-off-by: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111026211708.768925506@osadl.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-14sched: Document wait_for_completion_*() return valuesJ. Bruce Fields
The return-value convention for these functions varies depending on whether they're interruptible or can timeout. It can be a little confusing--document it. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111006192246.GB28026@fieldses.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits) powerpc/p3060qds: Add support for P3060QDS board powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX powerpc/85xx: Make kexec to interate over online cpus powerpc/fsl_booke: Fix comment in head_fsl_booke.S powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver powerpc/86xx: Correct Gianfar support for GE boards powerpc/cpm: Clear muram before it is in use. drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager powerpc/fsl_msi: add support for "msi-address-64" property powerpc/85xx: Setup secondary cores PIR with hard SMP id powerpc/fsl-booke: Fix settlbcam for 64-bit powerpc/85xx: Adding DCSR node to dtsi device trees powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards powerpc/85xx: fix PHYS_64BIT selection for P1022DS powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map powerpc: respect mem= setting for early memory limit setup powerpc: Update corenet64_smp_defconfig powerpc: Update mpc85xx/corenet 32-bit defconfigs ... Fix up trivial conflicts in: - arch/powerpc/configs/40x/hcu4_defconfig removed stale file, edited elsewhere - arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c: added opal and gelic drivers vs added ePAPR driver - drivers/tty/serial/8250.c moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
2011-10-26Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) llist: Add back llist_add_batch() and llist_del_first() prototypes sched: Don't use tasklist_lock for debug prints sched: Warn on rt throttling sched: Unify the ->cpus_allowed mask copy sched: Wrap scheduler p->cpus_allowed access sched: Request for idle balance during nohz idle load balance sched: Use resched IPI to kick off the nohz idle balance sched: Fix idle_cpu() llist: Remove cpu_relax() usage in cmpxchg loops sched: Convert to struct llist llist: Add llist_next() irq_work: Use llist in the struct irq_work logic llist: Return whether list is empty before adding in llist_add() llist: Move cpu_relax() to after the cmpxchg() llist: Remove the platform-dependent NMI checks llist: Make some llist functions inline sched, tracing: Show PREEMPT_ACTIVE state in trace_sched_switch sched: Remove redundant test in check_preempt_tick() sched: Add documentation for bandwidth control sched: Return unused runtime on group dequeue ...
2011-10-26Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) rcu: Move propagation of ->completed from rcu_start_gp() to rcu_report_qs_rsp() rcu: Remove rcu_needs_cpu_flush() to avoid false quiescent states rcu: Wire up RCU_BOOST_PRIO for rcutree rcu: Make rcu_torture_boost() exit loops at end of test rcu: Make rcu_torture_fqs() exit loops at end of test rcu: Permit rt_mutex_unlock() with irqs disabled rcu: Avoid having just-onlined CPU resched itself when RCU is idle rcu: Suppress NMI backtraces when stall ends before dump rcu: Prohibit grace periods during early boot rcu: Simplify unboosting checks rcu: Prevent early boot set_need_resched() from __rcu_pending() rcu: Dump local stack if cannot dump all CPUs' stacks rcu: Move __rcu_read_unlock()'s barrier() within if-statement rcu: Improve rcu_assign_pointer() and RCU_INIT_POINTER() documentation rcu: Make rcu_assign_pointer() unconditionally insert a memory barrier rcu: Make rcu_implicit_dynticks_qs() locals be correct size rcu: Eliminate in_irq() checks in rcu_enter_nohz() nohz: Remove nohz_cpu_mask rcu: Document interpretation of RCU-lockdep splats rcu: Allow rcutorture's stat_interval parameter to be changed at runtime ...
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-06sched: Don't use tasklist_lock for debug printsThomas Gleixner
Avoid taking locks from debug prints, this avoids latencies on -rt, and improves reliability of the debug code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-06sched: Unify the ->cpus_allowed mask copyPeter Zijlstra
Currently every sched_class::set_cpus_allowed() implementation has to copy the cpumask into task_struct::cpus_allowed, this is pointless, put this copy in the generic code. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-jhl5s9fckd9ptw1fzbqqlrd3@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-06sched: Wrap scheduler p->cpus_allowed accessPeter Zijlstra
This task is preparatory for the migrate_disable() implementation, but stands on its own and provides a cleanup. It currently only converts those sites required for task-placement. Kosaki-san once mentioned replacing cpus_allowed with a proper cpumask_t instead of the NR_CPUS sized array it currently is, that would also require something like this. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Link: http://lkml.kernel.org/n/tip-e42skvaddos99psip0vce41o@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-06sched: Request for idle balance during nohz idle load balanceSuresh Siddha
rq's idle_at_tick is set to idle/busy during the timer tick depending on the cpu was idle or not. This will be used later in the load balance that will be done in the softirq context (which is a process context in -RT kernels). For nohz kernels, for the cpu doing nohz idle load balance on behalf of all the idle cpu's, its rq->idle_at_tick might have a stale value (which is recorded when it got the timer tick presumably when it is busy). As the nohz idle load balancing is also being done at the same place as the regular load balancing, nohz idle load balancing was bailing out when it sees rq's idle_at_tick not set. Thus leading to poor system utilization. Rename rq's idle_at_tick to idle_balance and set it when someone requests for nohz idle balance on an idle cpu. Reported-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111003220934.892350549@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-06sched: Use resched IPI to kick off the nohz idle balanceSuresh Siddha
Current use of smp call function to kick the nohz idle balance can deadlock in this scenario. 1. cpu-A did a generic_exec_single() to cpu-B and after queuing its call single data (csd) to the call single queue, cpu-A took a timer interrupt. Actual IPI to cpu-B to process the call single queue is not yet sent. 2. As part of the timer interrupt handler, cpu-A decided to kick cpu-B for the idle load balancing (sets cpu-B's rq->nohz_balance_kick to 1) and __smp_call_function_single() with nowait will queue the csd to the cpu-B's queue. But the generic_exec_single() won't send an IPI to cpu-B as the call single queue was not empty. 3. cpu-A is busy with lot of interrupts 4. Meanwhile cpu-B is entering and exiting idle and noticed that it has it's rq->nohz_balance_kick set to '1'. So it will go ahead and do the idle load balancer and clear its rq->nohz_balance_kick. 5. At this point, csd queued as part of the step-2 above is still locked and waiting to be serviced on cpu-B. 6. cpu-A is still busy with interrupt load and now it got another timer interrupt and as part of it decided to kick cpu-B for another idle load balancing (as it finds cpu-B's rq->nohz_balance_kick cleared in step-4 above) and does __smp_call_function_single() with the same csd that is still locked. 7. And we get a deadlock waiting for the csd_lock() in the __smp_call_function_single(). Main issue here is that cpu-B can service the idle load balancer kick request from cpu-A even with out receiving the IPI and this lead to doing multiple __smp_call_function_single() on the same csd leading to deadlock. To kick a cpu, scheduler already has the reschedule vector reserved. Use that mechanism (kick_process()) instead of using the generic smp call function mechanism to kick off the nohz idle load balancing and avoid the deadlock. [ This issue is present from 2.6.35+ kernels, but marking it -stable only from v3.0+ as the proposed fix depends on the scheduler_ipi() that is introduced recently. ] Reported-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: stable@kernel.org # v3.0+ Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111003220934.834943260@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-04sched: Fix idle_cpu()Thomas Gleixner
On -rt we observed hackbench waking all 400 tasks to a single cpu. This is because of select_idle_sibling()'s interaction with the new ipi based wakeup scheme. The existing idle_cpu() test only checks to see if the current task on that cpu is the idle task, it does not take already queued tasks into account, nor does it take queued to be woken tasks into account. If the remote wakeup IPIs come hard enough, there won't be time to schedule away from the idle task, and would thus keep thinking the cpu was in fact idle, regardless of the fact that there were already several hundred tasks runnable. We couldn't reproduce on mainline, but there's no reason it couldn't happen. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-3o30p18b2paswpc9ohy2gltp@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-04sched: Convert to struct llistPeter Zijlstra
Use the generic llist primitives. We had a private lockless list implementation in the scheduler in the wake-list code, now that we have a generic llist implementation that provides all required operations, switch to it. This patch is not expected to change any behavior. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Huang Ying <ying.huang@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1315836353.26517.42.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-04Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: pick up the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-30posix-cpu-timers: Cure SMP wobblesPeter Zijlstra
David reported: Attached below is a watered-down version of rt/tst-cpuclock2.c from GLIBC. Just build it with "gcc -o test test.c -lpthread -lrt" or similar. Run it several times, and you will see cases where the main thread will measure a process clock difference before and after the nanosleep which is smaller than the cpu-burner thread's individual thread clock difference. This doesn't make any sense since the cpu-burner thread is part of the top-level process's thread group. I've reproduced this on both x86-64 and sparc64 (using both 32-bit and 64-bit binaries). For example: [davem@boricha build-x86_64-linux]$ ./test process: before(0.001221967) after(0.498624371) diff(497402404) thread: before(0.000081692) after(0.498316431) diff(498234739) self: before(0.001223521) after(0.001240219) diff(16698) [davem@boricha build-x86_64-linux]$ The diff of 'process' should always be >= the diff of 'thread'. I make sure to wrap the 'thread' clock measurements the most tightly around the nanosleep() call, and that the 'process' clock measurements are the outer-most ones. --- #include <unistd.h> #include <stdio.h> #include <stdlib.h> #include <time.h> #include <fcntl.h> #include <string.h> #include <errno.h> #include <pthread.h> static pthread_barrier_t barrier; static void *chew_cpu(void *arg) { pthread_barrier_wait(&barrier); while (1) __asm__ __volatile__("" : : : "memory"); return NULL; } int main(void) { clockid_t process_clock, my_thread_clock, th_clock; struct timespec process_before, process_after; struct timespec me_before, me_after; struct timespec th_before, th_after; struct timespec sleeptime; unsigned long diff; pthread_t th; int err; err = clock_getcpuclockid(0, &process_clock); if (err) return 1; err = pthread_getcpuclockid(pthread_self(), &my_thread_clock); if (err) return 1; pthread_barrier_init(&barrier, NULL, 2); err = pthread_create(&th, NULL, chew_cpu, NULL); if (err) return 1; err = pthread_getcpuclockid(th, &th_clock); if (err) return 1; pthread_barrier_wait(&barrier); err = clock_gettime(process_clock, &process_before); if (err) return 1; err = clock_gettime(my_thread_clock, &me_before); if (err) return 1; err = clock_gettime(th_clock, &th_before); if (err) return 1; sleeptime.tv_sec = 0; sleeptime.tv_nsec = 500000000; nanosleep(&sleeptime, NULL); err = clock_gettime(th_clock, &th_after); if (err) return 1; err = clock_gettime(my_thread_clock, &me_after); if (err) return 1; err = clock_gettime(process_clock, &process_after); if (err) return 1; diff = process_after.tv_nsec - process_before.tv_nsec; printf("process: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n", process_before.tv_sec, process_before.tv_nsec, process_after.tv_sec, process_after.tv_nsec, diff); diff = th_after.tv_nsec - th_before.tv_nsec; printf("thread: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n", th_before.tv_sec, th_before.tv_nsec, th_after.tv_sec, th_after.tv_nsec, diff); diff = me_after.tv_nsec - me_before.tv_nsec; printf("self: before(%lu.%.9lu) after(%lu.%.9lu) diff(%lu)\n", me_before.tv_sec, me_before.tv_nsec, me_after.tv_sec, me_after.tv_nsec, diff); return 0; } This is due to us using p->se.sum_exec_runtime in thread_group_cputime() where we iterate the thread group and sum all data. This does not take time since the last schedule operation (tick or otherwise) into account. We can cure this by using task_sched_runtime() at the cost of having to take locks. This also means we can (and must) do away with thread_group_sched_runtime() since the modified thread_group_cputime() is now more accurate and would deadlock when called from thread_group_sched_runtime(). Aside of that it makes the function safe on 32 bit systems. The old code added t->se.sum_exec_runtime unprotected. sum_exec_runtime is a 64bit value and could be changed on another cpu at the same time. Reported-by: David Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1314874459.7945.22.camel@twins Tested-by: David Miller <davem@davemloft.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-09-28nohz: Remove nohz_cpu_maskShi, Alex
RCU no longer uses this global variable, nor does anyone else. This commit therefore removes this variable. This reduces memory footprint and also removes some atomic instructions and memory barriers from the dyntick-idle path. Signed-off-by: Alex Shi <alex.shi@intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Restore checks for blocking in RCU read-side critical sectionsPaul E. McKenney
Long ago, using TREE_RCU with PREEMPT would result in "scheduling while atomic" diagnostics if you blocked in an RCU read-side critical section. However, PREEMPT now implies TREE_PREEMPT_RCU, which defeats this diagnostic. This commit therefore adds a replacement diagnostic based on PROVE_RCU. Because rcu_lockdep_assert() and lockdep_rcu_dereference() are now being used for things that have nothing to do with rcu_dereference(), rename lockdep_rcu_dereference() to lockdep_rcu_suspicious() and add a third argument that is a string indicating what is suspicious. This third argument is passed in from a new third argument to rcu_lockdep_assert(). Update all calls to rcu_lockdep_assert() to add an informative third argument. Also, add a pair of rcu_lockdep_assert() calls from within rcu_note_context_switch(), one complaining if a context switch occurs in an RCU-bh read-side critical section and another complaining if a context switch occurs in an RCU-sched read-side critical section. These are present only if the PROVE_RCU kernel parameter is enabled. Finally, fix some checkpatch whitespace complaints in lockdep.c. Again, you must enable PROVE_RCU to see these new diagnostics. But you are enabling PROVE_RCU to check out new RCU uses in any case, aren't you? Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-27treewide: Correct spelling of successfully in commentsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-26sched: Fix up wchan borkageSimon Kirby
Commit c259e01a1ec ("sched: Separate the scheduler entry for preemption") contained a boo-boo wrecking wchan output. It forgot to put the new schedule() function in the __sched section and thereby doesn't get properly ignored for things like wchan. Tested-by: Simon Kirby <sim@hostway.ca> Cc: stable@kernel.org # 2.6.39+ Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110923000346.GA25425@hostway.ca Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-20sched: Allow SD_NODES_PER_DOMAIN to be overriddenAnton Blanchard
We want to override the default value of SD_NODES_PER_DOMAIN on ppc64, so move it into linux/topology.h. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-09-18Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: We are queueing up a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-07Merge branch 'sched-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tipLinus Torvalds
* 'sched-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip: sched: Fix a memory leak in __sdt_free() sched: Move blk_schedule_flush_plug() out of __schedule() sched: Separate the scheduler entry for preemption
2011-08-29perf events: Fix slow and broken cgroup context switch codeStephane Eranian
The current cgroup context switch code was incorrect leading to bogus counts. Furthermore, as soon as there was an active cgroup event on a CPU, the context switch cost on that CPU would increase by a significant amount as demonstrated by a simple ping/pong example: $ ./pong Both processes pinned to CPU1, running for 10s 10684.51 ctxsw/s Now start a cgroup perf stat: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100 $ ./pong Both processes pinned to CPU1, running for 10s 6674.61 ctxsw/s That's a 37% penalty. Note that pong is not even in the monitored cgroup. The results shown by perf stat are bogus: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 100 Performance counter stats for 'sleep 100': CPU1 <not counted> cycles test CPU1 16,984,189,138 cycles # 0.000 GHz The second 'cycles' event should report a count @ CPU clock (here 2.4GHz) as it is counting across all cgroups. The patch below fixes the bogus accounting and bypasses any cgroup switches in case the outgoing and incoming tasks are in the same cgroup. With this patch the same test now yields: $ ./pong Both processes pinned to CPU1, running for 10s 10775.30 ctxsw/s Start perf stat with cgroup: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 10 Run pong outside the cgroup: $ /pong Both processes pinned to CPU1, running for 10s 10687.80 ctxsw/s The penalty is now less than 2%. And the results for perf stat are correct: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 10 Performance counter stats for 'sleep 10': CPU1 <not counted> cycles test # 0.000 GHz CPU1 23,933,981,448 cycles # 0.000 GHz Now perf stat reports the correct counts for for the non cgroup event. If we run pong inside the cgroup, then we also get the correct counts: $ perf stat -e cycles,cycles -A -a -G test -C 1 -- sleep 10 Performance counter stats for 'sleep 10': CPU1 22,297,726,205 cycles test # 0.000 GHz CPU1 23,933,981,448 cycles # 0.000 GHz 10.001457237 seconds time elapsed Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110825135803.GA4697@quad Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-29sched: Fix a memory leak in __sdt_free()WANG Cong
This patch fixes the following memory leak: unreferenced object 0xffff880107266800 (size 512): comm "sched-powersave", pid 3718, jiffies 4323097853 (age 27495.450s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff81133940>] create_object+0x187/0x28b [<ffffffff814ac103>] kmemleak_alloc+0x73/0x98 [<ffffffff811232ba>] __kmalloc_node+0x104/0x159 [<ffffffff81044b98>] kzalloc_node.clone.97+0x15/0x17 [<ffffffff8104cb90>] build_sched_domains+0xb7/0x7f3 [<ffffffff8104d4df>] partition_sched_domains+0x1db/0x24a [<ffffffff8109ee4a>] do_rebuild_sched_domains+0x3b/0x47 [<ffffffff810a00c7>] rebuild_sched_domains+0x10/0x12 [<ffffffff8104d5ba>] sched_power_savings_store+0x6c/0x7b [<ffffffff8104d5df>] sched_mc_power_savings_store+0x16/0x18 [<ffffffff8131322c>] sysdev_class_store+0x20/0x22 [<ffffffff81193876>] sysfs_write_file+0x108/0x144 [<ffffffff81135b10>] vfs_write+0xaf/0x102 [<ffffffff81135d23>] sys_write+0x4d/0x74 [<ffffffff814c8a42>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org # 3.0 Link: http://lkml.kernel.org/r/1313671017-4112-1-git-send-email-amwang@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-29sched: Move blk_schedule_flush_plug() out of __schedule()Thomas Gleixner
There is no real reason to run blk_schedule_flush_plug() with interrupts and preemption disabled. Move it into schedule() and call it when the task is going voluntarily to sleep. There might be false positives when the task is woken between that call and actually scheduling, but that's not really different from being woken immediately after switching away. This fixes a deadlock in the scheduler where the blk_schedule_flush_plug() callchain enables interrupts and thereby allows a wakeup to happen of the task that's going to sleep. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: stable@kernel.org # 2.6.39+ Link: http://lkml.kernel.org/n/tip-dwfxtra7yg1b5r65m32ywtct@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-29sched: Separate the scheduler entry for preemptionThomas Gleixner
Block-IO and workqueues call into notifier functions from the scheduler core code with interrupts and preemption disabled. These calls should be made before entering the scheduler core. To simplify this, separate the scheduler core code into __schedule(). __schedule() is directly called from the places which set PREEMPT_ACTIVE and from schedule(). This allows us to add the work checks into schedule(), so they are only called when a task voluntary goes to sleep. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: stable@kernel.org # 2.6.39+ Link: http://lkml.kernel.org/r/20110622174918.813258321@linutronix.de Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Return unused runtime on group dequeuePaul Turner
When a local cfs_rq blocks we return the majority of its remaining quota to the global bandwidth pool for use by other runqueues. We do this only when the quota is current and there is more than min_cfs_rq_quota [1ms by default] of runtime remaining on the rq. In the case where there are throttled runqueues and we have sufficient bandwidth to meter out a slice, a second timer is kicked off to handle this delivery, unthrottling where appropriate. Using a 'worst case' antagonist which executes on each cpu for 1ms before moving onto the next on a fairly large machine: no quota generations: 197.47 ms /cgroup/a/cpuacct.usage 199.46 ms /cgroup/a/cpuacct.usage 205.46 ms /cgroup/a/cpuacct.usage 198.46 ms /cgroup/a/cpuacct.usage 208.39 ms /cgroup/a/cpuacct.usage Since we are allowed to use "stale" quota our usage is effectively bounded by the rate of input into the global pool and performance is relatively stable. with quota generations [1s increments]: 119.58 ms /cgroup/a/cpuacct.usage 119.65 ms /cgroup/a/cpuacct.usage 119.64 ms /cgroup/a/cpuacct.usage 119.63 ms /cgroup/a/cpuacct.usage 119.60 ms /cgroup/a/cpuacct.usage The large deficit here is due to quota generations (/intentionally/) preventing us from now using previously stranded slack quota. The cost is that this quota becomes unavailable. with quota generations and quota return: 200.09 ms /cgroup/a/cpuacct.usage 200.09 ms /cgroup/a/cpuacct.usage 198.09 ms /cgroup/a/cpuacct.usage 200.09 ms /cgroup/a/cpuacct.usage 200.06 ms /cgroup/a/cpuacct.usage By returning unused quota we're able to both stably consume our desired quota and prevent unintentional overages due to the abuse of slack quota from previous quota periods (especially on a large machine). Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184758.306848658@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Add exports tracking cfs bandwidth control statisticsNikhil Rao
This change introduces statistics exports for the cpu sub-system, these are added through the use of a stat file similar to that exported by other subsystems. The following exports are included: nr_periods: number of periods in which execution occurred nr_throttled: the number of periods above in which execution was throttle throttled_time: cumulative wall-time that any cpus have been throttled for this group Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Nikhil Rao <ncrao@google.com> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184758.198901931@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Migrate throttled tasks on HOTPLUGPaul Turner
Throttled tasks are invisisble to cpu-offline since they are not eligible for selection by pick_next_task(). The regular 'escape' path for a thread that is blocked at offline is via ttwu->select_task_rq, however this will not handle a throttled group since there are no individual thread wakeups on an unthrottle. Resolve this by unthrottling offline cpus so that threads can be migrated. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.989000590@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Prevent interactions with throttled entitiesPaul Turner
From the perspective of load-balance and shares distribution, throttled entities should be invisible. However, both of these operations work on 'active' lists and are not inherently aware of what group hierarchies may be present. In some cases this may be side-stepped (e.g. we could sideload via tg_load_down in load balance) while in others (e.g. update_shares()) it is more difficult to compute without incurring some O(n^2) costs. Instead, track hierarchicaal throttled state at time of transition. This allows us to easily identify whether an entity belongs to a throttled hierarchy and avoid incorrect interactions with it. Also, when an entity leaves a throttled hierarchy we need to advance its time averaging for shares averaging so that the elapsed throttled time is not considered as part of the cfs_rq's operation. We also use this information to prevent buddy interactions in the wakeup and yield_to() paths. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.777916795@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Allow for positional tg_tree walksPaul Turner
Extend walk_tg_tree to accept a positional argument static int walk_tg_tree_from(struct task_group *from, tg_visitor down, tg_visitor up, void *data) Existing semantics are preserved, caller must hold rcu_lock() or sufficient analogue. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.677889157@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Add support for unthrottling group entitiesPaul Turner
At the start of each period we refresh the global bandwidth pool. At this time we must also unthrottle any cfs_rq entities who are now within bandwidth once more (as quota permits). Unthrottled entities have their corresponding cfs_rq->throttled flag cleared and their entities re-enqueued. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.574628950@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Add support for throttling group entitiesPaul Turner
Now that consumption is tracked (via update_curr()) we add support to throttle group entities (and their corresponding cfs_rqs) in the case where this is no run-time remaining. Throttled entities are dequeued to prevent scheduling, additionally we mark them as throttled (using cfs_rq->throttled) to prevent them from becoming re-enqueued until they are unthrottled. A list of a task_group's throttled entities are maintained on the cfs_bandwidth structure. Note: While the machinery for throttling is added in this patch the act of throttling an entity exceeding its bandwidth is deferred until later within the series. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.480608533@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Expire invalid runtimePaul Turner
Since quota is managed using a global state but consumed on a per-cpu basis we need to ensure that our per-cpu state is appropriately synchronized. Most importantly, runtime that is state (from a previous period) should not be locally consumable. We take advantage of existing sched_clock synchronization about the jiffy to efficiently detect whether we have (globally) crossed a quota boundary above. One catch is that the direction of spread on sched_clock is undefined, specifically, we don't know whether our local clock is behind or ahead of the one responsible for the current expiration time. Fortunately we can differentiate these by considering whether the global deadline has advanced. If it has not, then we assume our clock to be "fast" and advance our local expiration; otherwise, we know the deadline has truly passed and we expire our local runtime. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.379275352@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Add a timer to handle CFS bandwidth refreshPaul Turner
This patch adds a per-task_group timer which handles the refresh of the global CFS bandwidth pool. Since the RT pool is using a similar timer there's some small refactoring to share this support. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.277271273@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Accumulate per-cfs_rq cpu usage and charge against bandwidthPaul Turner
Account bandwidth usage on the cfs_rq level versus the task_groups to which they belong. Whether we are tracking bandwidth on a given cfs_rq is maintained under cfs_rq->runtime_enabled. cfs_rq's which belong to a bandwidth constrained task_group have their runtime accounted via the update_curr() path, which withdraws bandwidth from the global pool as desired. Updates involving the global pool are currently protected under cfs_bandwidth->lock, local runtime is protected by rq->lock. This patch only assigns and tracks quota, no action is taken in the case that cfs_rq->runtime_used exceeds cfs_rq->runtime_assigned. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Nikhil Rao <ncrao@google.com> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.179386821@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Validate CFS quota hierarchiesPaul Turner
Add constraints validation for CFS bandwidth hierarchies. Validate that: max(child bandwidth) <= parent_bandwidth In a quota limited hierarchy, an unconstrained entity (e.g. bandwidth==RUNTIME_INF) inherits the bandwidth of its parent. This constraint is chosen over sum(child_bandwidth) as notion of over-commit is valuable within SCHED_OTHER. Some basic code from the RT case is re-factored for reuse. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.083774572@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Introduce primitives to account for CFS bandwidth trackingPaul Turner
In this patch we introduce the notion of CFS bandwidth, partitioned into globally unassigned bandwidth, and locally claimed bandwidth. - The global bandwidth is per task_group, it represents a pool of unclaimed bandwidth that cfs_rqs can allocate from. - The local bandwidth is tracked per-cfs_rq, this represents allotments from the global pool bandwidth assigned to a specific cpu. Bandwidth is managed via cgroupfs, adding two new interfaces to the cpu subsystem: - cpu.cfs_period_us : the bandwidth period in usecs - cpu.cfs_quota_us : the cpu bandwidth (in usecs) that this tg will be allowed to consume over period above. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Nikhil Rao <ncrao@google.com> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184756.972636699@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Implement hierarchical task accounting for SCHED_OTHERPaul Turner
Introduce hierarchical task accounting for the group scheduling case in CFS, as well as promoting the responsibility for maintaining rq->nr_running to the scheduling classes. The primary motivation for this is that with scheduling classes supporting bandwidth throttling it is possible for entities participating in throttled sub-trees to not have root visible changes in rq->nr_running across activate and de-activate operations. This in turn leads to incorrect idle and weight-per-task load balance decisions. This also allows us to make a small fixlet to the fastpath in pick_next_task() under group scheduling. Note: this issue also exists with the existing sched_rt throttling mechanism. This patch does not address that. Signed-off-by: Paul Turner <pjt@google.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184756.878333391@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: fix broken SCHED_RESET_ON_FORK handlingMike Galbraith
Setting child->prio = current->normal_prio _after_ SCHED_RESET_ON_FORK has been handled for an RT parent gives birth to a deranged mutant child with non-RT policy, but RT prio and sched_class. Move PI leakage protection up, always set priorities and weight, and if the child is leaving RT class, reset rt_priority to the proper value. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1311779695.8691.2.camel@marge.simson.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-14sched: Remove rq->avg_load_per_taskJan H. Schönherr
Since commit a2d47777 ("sched: fix stale value in average load per task") the variable rq->avg_load_per_task is no longer required. Remove it. Signed-off-by: Jan H. Schönherr <schnhrr@cs.tu-berlin.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1312189408-17172-1-git-send-email-schnhrr@cs.tu-berlin.de Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24Merge branch 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) KVM: IOMMU: Disable device assignment without interrupt remapping KVM: MMU: trace mmio page fault KVM: MMU: mmio page fault support KVM: MMU: reorganize struct kvm_shadow_walk_iterator KVM: MMU: lockless walking shadow page table KVM: MMU: do not need atomicly to set/clear spte KVM: MMU: introduce the rules to modify shadow page table KVM: MMU: abstract some functions to handle fault pfn KVM: MMU: filter out the mmio pfn from the fault pfn KVM: MMU: remove bypass_guest_pf KVM: MMU: split kvm_mmu_free_page KVM: MMU: count used shadow pages on prepareing path KVM: MMU: rename 'pt_write' to 'emulate' KVM: MMU: cleanup for FNAME(fetch) KVM: MMU: optimize to handle dirty bit KVM: MMU: cache mmio info on page fault path KVM: x86: introduce vcpu_mmio_gva_to_gpa to cleanup the code KVM: MMU: do not update slot bitmap if spte is nonpresent KVM: MMU: fix walking shadow page table KVM guest: KVM Steal time registration ...
2011-07-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) sched: Cleanup duplicate local variable in [enqueue|dequeue]_task_fair sched: Replace use of entity_key() sched: Separate group-scheduling code more clearly sched: Reorder root_domain to remove 64 bit alignment padding sched: Do not attempt to destroy uninitialized rt_bandwidth sched: Remove unused function cpu_cfs_rq() sched: Fix (harmless) typo 'CONFG_FAIR_GROUP_SCHED' sched, cgroup: Optimize load_balance_fair() sched: Don't update shares twice on on_rq parent sched: update correct entity's runtime in check_preempt_wakeup() xtensa: Use generic config PREEMPT definition h8300: Use generic config PREEMPT definition m32r: Use generic PREEMPT config sched: Skip autogroup when looking for all rt sched groups sched: Simplify mutex_spin_on_owner() sched: Remove rcu_read_lock() from wake_affine() sched: Generalize sleep inside spinlock detection sched: Make sleeping inside spinlock detection working in !CONFIG_PREEMPT sched: Isolate preempt counting in its own config option sched: Remove pointless in_atomic() definition check ...
2011-07-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits) perf: Remove the nmi parameter from the oprofile_perf backend x86, perf: Make copy_from_user_nmi() a library function perf: Remove perf_event_attr::type check x86, perf: P4 PMU - Fix typos in comments and style cleanup perf tools: Make test use the preset debugfs path perf tools: Add automated tests for events parsing perf tools: De-opt the parse_events function perf script: Fix display of IP address for non-callchain path perf tools: Fix endian conversion reading event attr from file header perf tools: Add missing 'node' alias to the hw_cache[] array perf probe: Support adding probes on offline kernel modules perf probe: Add probed module in front of function perf probe: Introduce debuginfo to encapsulate dwarf information perf-probe: Move dwarf library routines to dwarf-aux.{c, h} perf probe: Remove redundant dwarf functions perf probe: Move strtailcmp to string.c perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END tracing/kprobe: Update symbol reference when loading module tracing/kprobes: Support module init function probing kprobes: Return -ENOENT if probe point doesn't exist ...
