path: root/kernel/sched/cpuacct.h
2016-03-21sched/cpuacct: Simplify the cpuacct codeZhao Lei
- Use for() instead of while() loop in some functions to make the code simpler. - Use this_cpu_ptr() instead of per_cpu_ptr() to make the code cleaner and a bit faster. Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Tejun Heo <htejun@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/d8a7ef9592f55224630cb26dea239f05b6398a4e.1458187654.git.zhaolei@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched/cpuacct: Initialize root cpuacct earlierLi Zefan
Now we don't need cpuacct_init(), and instead we just initialize root_cpuacct when it's defined. Signed-off-by: Li Zefan <lizefan@huawei.com> Cc: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/51553834.9090701@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched/cpuacct: Clean up cpuacct.hLi Zefan
Now most of the code in cpuacct.h can be moved to cpuacct.c Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/515536D5.2080401@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field()Li Zefan
This is a micro optimazation for a hot path. - We don't need to check if @ca returned from task_ca() is NULL. - We don't need to check if @ca returned from parent_ca() is NULL. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/515536B7.6060602@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched/cpuacct: Remove redundant NULL checks in cpuacct_charge()Li Zefan
This is a micro optimization for the hot path. - We don't need to check if @ca is NULL in parent_ca(). - We don't need to check if @ca is NULL in the beginning of the for loop. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/515536A9.5000700@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched/cpuacct: Add cpuacct_acount_field()Li Zefan
So we can remove open-coded cpuacct code in cputime.c. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/51553692.9060008@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched/cpuacct: Add cpuacct_init()Li Zefan
So we don't open-coded initialization of cpuacct in core.c. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/51553687.1060906@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-10sched: Split cpuacct code out of sched.hLi Zefan
Add cpuacct.h and let sched.h include it. Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/5155367B.2060506@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
