path: root/kernel/sched/loadavg.c
2017-07-05sched/loadavg: Avoid loadavg spikes caused by delayed NO_HZ accountingMatt Fleming
commit 6e5f32f7a43f45ee55c401c0b9585eb01f9629a8 upstream. If we crossed a sample window while in NO_HZ we will add LOAD_FREQ to the pending sample window time on exit, setting the next update not one window into the future, but two. This situation on exiting NO_HZ is described by: this_rq->calc_load_update < jiffies < calc_load_update In this scenario, what we should be doing is: this_rq->calc_load_update = calc_load_update [ next window ] But what we actually do is: this_rq->calc_load_update = calc_load_update + LOAD_FREQ [ next+1 window ] This has the effect of delaying load average updates for potentially up to ~9seconds. This can result in huge spikes in the load average values due to per-cpu uninterruptible task counts being out of sync when accumulated across all CPUs. It's safe to update the per-cpu active count if we wake between sample windows because any load that we left in 'calc_load_idle' will have been zero'd when the idle load was folded in calc_global_load(). This issue is easy to reproduce before, commit 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking") just by forking short-lived process pipelines built from ps(1) and grep(1) in a loop. I'm unable to reproduce the spikes after that commit, but the bug still seems to be present from code review. Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vincent Guittot <vincent.guittot@linaro.org> Fixes: commit 5167e8d ("sched/nohz: Rewrite and fix load-avg computation -- again") Link: http://lkml.kernel.org/r/20170217120731.11868-2-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-13sched/core: Correct off by one bug in load migration calculationThomas Gleixner
The move of calc_load_migrate() from CPU_DEAD to CPU_DYING did not take into account that the function is now called from a thread running on the outgoing CPU. As a result a cpu unplug leakes a load of 1 into the global load accounting mechanism. Fix it by adjusting for the currently running thread which calls calc_load_migrate(). Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Cc: rt@linutronix.de Cc: shreyas@linux.vnet.ibm.com Fixes: e9cd8fa4fcfd: ("sched/migration: Move calc_load_migrate() into CPU_DYING") Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1607121744350.4083@nanos Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-12sched/loadavg: Fix loadavg artifacts on fully idle and on fully loaded systemsVik Heyndrickx
Systems show a minimal load average of 0.00, 0.01, 0.05 even when they have no load at all. Uptime and /proc/loadavg on all systems with kernels released during the last five years up until kernel version 4.6-rc5, show a 5- and 15-minute minimum loadavg of 0.01 and 0.05 respectively. This should be 0.00 on idle systems, but the way the kernel calculates this value prevents it from getting lower than the mentioned values. Likewise but not as obviously noticeable, a fully loaded system with no processes waiting, shows a maximum 1/5/15 loadavg of 1.00, 0.99, 0.95 (multiplied by number of cores). Once the (old) load becomes 93 or higher, it mathematically can never get lower than 93, even when the active (load) remains 0 forever. This results in the strange 0.00, 0.01, 0.05 uptime values on idle systems. Note: 93/2048 = 0.0454..., which rounds up to 0.05. It is not correct to add a 0.5 rounding (=1024/2048) here, since the result from this function is fed back into the next iteration again, so the result of that +0.5 rounding value then gets multiplied by (2048-2037), and then rounded again, so there is a virtual "ghost" load created, next to the old and active load terms. By changing the way the internally kept value is rounded, that internal value equivalent now can reach 0.00 on idle, and 1.00 on full load. Upon increasing load, the internally kept load value is rounded up, when the load is decreasing, the load value is rounded down. The modified code was tested on nohz=off and nohz kernels. It was tested on vanilla kernel 4.6-rc5 and on centos 7.1 kernel 3.10.0-327. It was tested on single, dual, and octal cores system. It was tested on virtual hosts and bare hardware. No unwanted effects have been observed, and the problems that the patch intended to fix were indeed gone. Tested-by: Damien Wyart <damien.wyart@free.fr> Signed-off-by: Vik Heyndrickx <vik.heyndrickx@veribox.net> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Doug Smythies <dsmythies@telus.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 0f004f5a696a ("sched: Cure more NO_HZ load average woes") Link: http://lkml.kernel.org/r/e8d32bff-d544-7748-72b5-3c86cc71f09f@veribox.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-08sched: Move the loadavg code to a more obvious locationPeter Zijlstra
I could not find the loadavg code.. turns out it was hidden in a file called proc.c. It further got mingled up with the cruft per rq load indexes (which we really want to get rid of). Move the per rq load indexes into the fair.c load-balance code (that's the only thing that uses them) and rename proc.c to loadavg.c so we can find it again. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> [ Did minor cleanups to the code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
