path: root/kernel/sched_cpupri.h
2010-07-17sched: No need for bootmem special casesPekka Enberg
As of commit dcce284 ("mm: Extend gfp masking to the page allocator") and commit 7e85ee0 ("slab,slub: don't enable interrupts during early boot"), the slab allocator makes sure we don't attempt to sleep during boot. Therefore, remove bootmem special cases from the scheduler and use plain GFP_KERNEL instead. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1279225102-2572-1-git-send-email-penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14sched: Convert cpupri lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-03-30cpumask: remove cpumask_t from coreRusty Russell
Impact: cleanup struct cpumask is nicer, and we use it to make where we've made code safe for CONFIG_CPUMASK_OFFSTACK=y. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-11-24sched: convert struct cpupri_vec cpumask_var_t.Rusty Russell
Impact: stack usage reduction, (future) size reduction for large NR_CPUS. Dynamically allocating cpumasks (when CONFIG_CPUMASK_OFFSTACK) saves space for small nr_cpu_ids but big CONFIG_NR_CPUS. The fact cpupro_init is called both before and after the slab is available makes for an ugly parameter unfortunately. We also use cpumask_any_and to get rid of a temporary in cpupri_find. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-06sched: fix the cpuprio count reallyThomas Gleixner
Peter pointed out that the last version of the "fix" was still one off under certain circumstances. Use BITS_TO_LONG instead to get an accurate result. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-06sched: fix cpupri priocountGregory Haskins
A rounding error was pointed out by Peter Zijlstra which would result in the structure holding priorities to be off by one. Signed-off-by: Gregory Haskins <ghaskins@novell.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-06sched: use a 2-d bitmap for searching lowest-pri CPUGregory Haskins
The current code use a linear algorithm which causes scaling issues on larger SMP machines. This patch replaces that algorithm with a 2-dimensional bitmap to reduce latencies in the wake-up path. Signed-off-by: Gregory Haskins <ghaskins@novell.com> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
