debug se->vruntime fields.
Signed-off-by: Mike Galbraith <efault@gmx.de>
CPU load calculations are statistical anyway, and there's little benefit
from having it calculated on every scheduling event. So remove this code,
it gets rid of a divide from the scheduler wakeup and context-switch
fastpath.
track the maximum amount of time a task has executed while
the CPU load was at least 2x. (i.e. at least two nice-0
tasks were runnable)
small kernel/sched_debug.c cleanup - break up
multi-variable assignment.
no code changed:
38869 3550 24 42443 a5cb sched.o.before
38869 3550 24 42443 a5cb sched.o.after
when cleaning sched-stats also clear prev_sum_exec_runtime.
construct a more or less wall-clock time out of sched_clock(), by
using ACPI-idle's existing knowledge about how much time we spent
idling. This allows the rq clock to work around TSC-stops-in-C2,
TSC-gets-corrupted-in-C3 type of problems.
( Besides the scheduler's statistics this also benefits blktrace and
printk-timestamps as well. )
Furthermore, the precise before-C2/C3-sleep and after-C2/C3-wakeup
callbacks allow the scheduler to get out the most of the period where
the CPU has a reliable TSC. This results in slightly more precise
task statistics.
the ACPI bits were acked by Len.
Acked-by: Len Brown <len.brown@intel.com>
Arjan van de Ven pointed out that we should not print kernel addresses
in world-readable /proc files - fix that.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
remove the 'u64 now' parameter from sched_debug.c:print_task()/_rq().
( identity transformation that causes no change in functionality. )
remove the 'u64 now' parameter from print_cfs_rq().
C99 6.10.3[11]: preprocessing directive within the argument list of
macro invocation => undefined behaviour. Don't do that...
move the rest of the debugging/instrumentation code to under
CONFIG_SCHEDSTATS too. This reduces code size and speeds code up:
33044 4122 28 37194 914a sched.o.before
32708 4122 28 36858 8ffa sched.o.after
On every open/close one struct seq_operations leaks.
Kudos to /proc/slab_allocators.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Cc: <stable@kernel.org>
Only sched.c uses sysrq_sched_debug_show, and sched.c includes sched_debug.c,
so all uses of sysrq_sched_debug_show occur in the same source file.
Eliminates a sparse warning:
warning: symbol 'sysrq_sched_debug_show' was not declared. Should it be static?
Signed-off-by: Josh Triplett <josh@kernel.org>
kernel/sched_debug.c referred to CFS -v20, but there's no CFS versioning
needed within the upstream kernel.
scheduler debugging core: implement /proc/sched_debug and
/proc/<PID>/sched files for scheduler debugging.
