Compute the time-average number of running tasks per run-queue for a
trailing window of a fixed time period. The detla add/sub to the
average value is weighted by the amount of time per nr_running value
relative to the total measurement period.
Change-Id: I076e24ff4ed65bed3b8dd8d2b279a503318071ff
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
(cherry picked from commit 3a12d7499cee352e8a46eaf700259ba3c733f0e3)
Reviewed-on: http://git-master/r/111635
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Neil Brown pointed out that lock_depth somehow escaped the BKL
removal work. Let's get rid of it now.
Note that the perf scripting utilities still have a bunch of
code for dealing with common_lock_depth in tracepoints; I have
left that in place in case anybody wants to use that code with
older kernels.
Suggested-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net
Provide a generic p->on_rq because the p->se.on_rq semantics are
unfavourable for lockless wakeups but needed for sched_fair.
In particular, p->on_rq is only cleared when we actually dequeue the
task in schedule() and not on any random dequeue as done by things
like __migrate_task() and __sched_setscheduler().
This also allows us to remove p->se usage from !sched_fair code.
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Link: http://lkml.kernel.org/r/20110405152728.949545047@chello.nl
Use the buddy mechanism to implement yield_task_fair. This
allows us to skip onto the next highest priority se at every
level in the CFS tree, unless doing so would introduce gross
unfairness in CPU time distribution.
We order the buddy selection in pick_next_entity to check
yield first, then last, then next. We need next to be able
to override yield, because it is possible for the "next" and
"yield" task to be different processen in the same sub-tree
of the CFS tree. When they are, we need to go into that
sub-tree regardless of the "yield" hint, and pick the correct
entity once we get to the right level.
Signed-off-by: Rik van Riel <riel@redhat.com>
LKML-Reference: <20110201095103.3a79e92a@annuminas.surriel.com>
Now rq->rq_sched_info.bkl_count is not used for rq, scroll
rq->bkl_count into it. Thus we can save some space for rq.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1294991859-13246-1-git-send-email-yong.zhang0@gmail.com>
Add autogroup name to cfs_rq and tasks information to /proc/sched_debug.
Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com>
LKML-Reference: <20110111101257.GF4772@in.ibm.com>
Displaying of group names in /proc/sched_debug was dropped in autogroup
patches. Add group names while displaying cfs_rq and tasks information.
LKML-Reference: <20110111101153.GE4772@in.ibm.com>
A recurring complaint from CFS users is that parallel kbuild has
a negative impact on desktop interactivity. This patch
implements an idea from Linus, to automatically create task
groups. Currently, only per session autogroups are implemented,
but the patch leaves the way open for enhancement.
Implementation: each task's signal struct contains an inherited
pointer to a refcounted autogroup struct containing a task group
pointer, the default for all tasks pointing to the
init_task_group. When a task calls setsid(), a new task group
is created, the process is moved into the new task group, and a
reference to the preveious task group is dropped. Child
processes inherit this task group thereafter, and increase it's
refcount. When the last thread of a process exits, the
process's reference is dropped, such that when the last process
referencing an autogroup exits, the autogroup is destroyed.
At runqueue selection time, IFF a task has no cgroup assignment,
its current autogroup is used.
Autogroup bandwidth is controllable via setting it's nice level
through the proc filesystem:
cat /proc/<pid>/autogroup
Displays the task's group and the group's nice level.
echo <nice level> > /proc/<pid>/autogroup
Sets the task group's shares to the weight of nice <level> task.
Setting nice level is rate limited for !admin users due to the
abuse risk of task group locking.
The feature is enabled from boot by default if
CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via
the boot option noautogroup, and can also be turned on/off on
the fly via:
echo [01] > /proc/sys/kernel/sched_autogroup_enabled
... which will automatically move tasks to/from the root task group.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Paul Turner <pjt@google.com>
[ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ]
LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net>
Add more clock information to /proc/sched_debug, Thomas wanted to see
the sched_clock_stable state.
Requested-by: Thomas Gleixner <tglx@linutronix.de>
LKML-Reference: <new-submission>
By tracking a per-cpu load-avg for each cfs_rq and folding it into a
global task_group load on each tick we can rework tg_shares_up to be
strictly per-cpu.
This should improve cpu-cgroup performance for smp systems
significantly.
[ Paul: changed to use queueing cfs_rq + bug fixes ]
Signed-off-by: Paul Turner <pjt@google.com>
LKML-Reference: <20101115234937.580480400@google.com>
The sched_child_runs_first value in /proc/sched_debug is
currently displayed using a macro meant to split ns time values.
This patch uses the correct macro to display it as a plain
decimal value.
Signed-off-by: Josh Hunt <johunt@akamai.com>
Cc: peterz@infradead.org
Cc: juhlenko@akamai.com
Cc: efault@gmx.de
LKML-Reference: <1279567876-25418-1-git-send-email-johunt@akamai.com>
Trivial, use get_nr_threads() helper to read signal->count which we are
going to change.
Like other callers, proc_sched_show_task() doesn't need the exactly
precise nr_threads.
David said:
: Note that get_nr_threads() isn't completely equivalent (it can return 0
: where proc_sched_show_task() will display a 1). But I don't think this
: should be a problem.
Acked-by: Roland McGrath <roland@redhat.com>
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (49 commits)
stop_machine: Move local variable closer to the usage site in cpu_stop_cpu_callback()
sched, wait: Use wrapper functions
sched: Remove a stale comment
ondemand: Make the iowait-is-busy time a sysfs tunable
ondemand: Solve a big performance issue by counting IOWAIT time as busy
sched: Intoduce get_cpu_iowait_time_us()
sched: Eliminate the ts->idle_lastupdate field
sched: Fold updating of the last_update_time_info into update_ts_time_stats()
sched: Update the idle statistics in get_cpu_idle_time_us()
sched: Introduce a function to update the idle statistics
sched: Add a comment to get_cpu_idle_time_us()
cpu_stop: add dummy implementation for UP
sched: Remove rq argument to the tracepoints
rcu: need barrier() in UP synchronize_sched_expedited()
sched: correctly place paranioa memory barriers in synchronize_sched_expedited()
sched: kill paranoia check in synchronize_sched_expedited()
sched: replace migration_thread with cpu_stop
stop_machine: reimplement using cpu_stop
cpu_stop: implement stop_cpu[s]()
sched: Fix select_idle_sibling() logic in select_task_rq_fair()
With CONFIG_PROVE_RCU=y, a warning can be triggered:
$ cat /proc/sched_debug
kernel/cgroup.c:1649 invoked rcu_dereference_check() without protection!
Both cgroup_path() and task_group() should be called with either
rcu_read_lock or cgroup_mutex held.
The rcu_dereference_check() does include cgroup_lock_is_held(), so we
know that this lock is not held. Therefore, in a CONFIG_PREEMPT kernel,
to say nothing of a CONFIG_PREEMPT_RT kernel, the original code could
have ended up copying a string out of the freelist.
This patch inserts RCU read-side primitives needed to prevent this
scenario.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Merge reason: merge the latest fixes, update to -rc4.
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"")
Acked-by: Dhaval Giani <dhaval.giani@gmail.com>
LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com>
Latencytop clearing sum_exec_runtime via proc_sched_set_task() breaks
task_times(). Other places in kernel use nvcsw and nivcsw, which are
being cleared as well, Clear task statistics only.
Reported-by: Török Edwin <edwintorok@gmail.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <1269940193.19286.14.camel@marge.simson.net>
Both avg_overlap and avg_wakeup had an inherent problem in that their accuracy
was detrimentally affected by cross-cpu wakeups, this because we are missing
the necessary call to update_curr(). This can't be fixed without increasing
overhead in our already too fat fastpath.
Additionally, with recent load balancing changes making us prefer to place tasks
in an idle cache domain (which is good for compute bound loads), communicating
tasks suffer when a sync wakeup, which would enable affine placement, is turned
into a non-sync wakeup by SYNC_LESS. With one task on the runqueue, wake_affine()
rejects the affine wakeup request, leaving the unfortunate where placed, taking
frequent cache misses.
Remove it, and recover some fastpath cycles.
LKML-Reference: <1268301121.6785.30.camel@marge.simson.net>
Testing the load which led to this heuristic (nfs4 kbuild) shows that it has
outlived it's usefullness. With intervening load balancing changes, I cannot
see any difference with/without, so recover there fastpath cycles.
LKML-Reference: <1268301062.6785.29.camel@marge.simson.net>
Put all statistic fields of sched_entity in one struct, sched_statistics,
and embed it into sched_entity.
This change allows to memset the sched_statistics to 0 when needed (for
instance when forking), avoiding bugs of non initialized fields.
Signed-off-by: Lucas De Marchi <lucas.de.marchi@gmail.com>
LKML-Reference: <1268275065-18542-1-git-send-email-lucas.de.marchi@gmail.com>
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
This build warning:
kernel/sched.c: In function 'set_task_cpu':
kernel/sched.c:2070: warning: unused variable 'old_rq'
Made me realize that the forced2_migrations stat looks pretty
pointless (and a misnomer) - remove it.
As scaling now takes place on all kind of cpu add/remove events a user
that configures values via proc should be able to configure if his set
values are still rescaled or kept whatever happens.
As the comments state that log2 was just a second guess that worked the
interface is not just designed for on/off, but to choose a scaling type.
Currently this allows none, log and linear, but more important it allwos
us to keep the interface even if someone has an even better idea how to
scale the values.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
LKML-Reference: <1259579808-11357-3-git-send-email-ehrhardt@linux.vnet.ibm.com>
WAKEUP_RUNNING was an experiment, not sure why that ever ended up being
merged...
Rate limit newidle to migration_cost. It's a win for all
stages of sysbench oltp tests.
Create a new wakeup preemption mode, preempt towards tasks that run
shorter on avg. It sets next buddy to be sure we actually run the task
we preempted for.
Test results:
root@twins:~# while :; do :; done &
[1] 6537
[2] 6538
[3] 6539
[4] 6540
root@twins:/home/peter# ./latt -c4 sleep 4
Entries: 48 (clients=4)
Averages:
Max 4750 usec
Avg 497 usec
Stdev 737 usec
root@twins:/home/peter# echo WAKEUP_RUNNING > /debug/sched_features
Averages:
Max 14 usec
Avg 5 usec
Stdev 3 usec
Disabled by default - needs more testing.
Acked-by: Mike Galbraith <efault@gmx.de>
For counting how long an application has been waiting for
(disk) IO, there currently is only the HZ sample driven
information available, while for all other counters in this
class, a high resolution version is available via
CONFIG_SCHEDSTATS.
In order to make an improved bootchart tool possible, we also
need a higher resolution version of the iowait time.
This patch below adds this scheduler statistic to the kernel.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <4A64B813.1080506@linux.intel.com>
There are some points which refer the per-cpu value "runqueues" directly.
sched.c provides nice abstraction, such as cpu_rq() and this_rq(),
so we should use these macros when looking runqueues.
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
LKML-Reference: <20090617.222055.374768827975756908.mitake@dcl.info.waseda.ac.jp>
Impact: cleanup, new schedstat ABI
Since they are used on in statistics and are always set to zero, the
following fields from struct rq have been removed: yld_exp_empty,
yld_act_empty and yld_both_empty.
Both Sched Debug and SCHEDSTAT_VERSION versions has also been
incremented since ABIs have been changed.
The schedtop tool has been updated to properly handle new version of
schedstat:
http://rt.wiki.kernel.org/index.php/Schedtop_utility
Signed-off-by: Luis Henriques <henrix@sapo.pt>
Acked-by: Gregory Haskins <ghaskins@novell.com>
LKML-Reference: <20090324221002.GA10061@hades.domain.com>
The jiffies value was being printed for each CPU, which does not seem to make
sense. Moved jiffies to system section.
LKML-Reference: <20090318000425.GA2228@hades.domain.com>
Introduce a new avg_wakeup statistic.
avg_wakeup is a measure of how frequently a task wakes up other tasks, it
represents the average time between wakeups, with a limit of avg_runtime
for when it doesn't wake up anybody.
Impact: avoid accessing NULL tg.css->cgroup
In commit 0a0db8f5c9d4bbb9bbfcc2b6cb6bce2d0ef4d73d, I removed checking
NULL tg.css->cgroup, but I realized I was wrong when I found reading
/proc/sched_debug can race with cgroup_create().
Impact: extend information in /proc/sched_debug
This patch adds uid information in sched_debug for CONFIG_USER_SCHED
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com>
kernel/Makefile
Luis Henriques reported that with CONFIG_PREEMPT=y + CONFIG_PREEMPT_DEBUG=y +
CONFIG_SCHED_DEBUG=y + CONFIG_LATENCYTOP=y enabled, the following warning
triggers when using latencytop:
> [ 775.663239] BUG: using smp_processor_id() in preemptible [00000000] code: latencytop/6585
> [ 775.663303] caller is native_sched_clock+0x3a/0x80
> [ 775.663314] Pid: 6585, comm: latencytop Tainted: G W 2.6.28-rc4-00355-g9c7c354 #1
> [ 775.663322] Call Trace:
> [ 775.663343] [<ffffffff803a94e4>] debug_smp_processor_id+0xe4/0xf0
> [ 775.663356] [<ffffffff80213f7a>] native_sched_clock+0x3a/0x80
> [ 775.663368] [<ffffffff80213e19>] sched_clock+0x9/0x10
> [ 775.663381] [<ffffffff8024550d>] proc_sched_show_task+0x8bd/0x10e0
> [ 775.663395] [<ffffffff8034466e>] sched_show+0x3e/0x80
> [ 775.663408] [<ffffffff8031039b>] seq_read+0xdb/0x350
> [ 775.663421] [<ffffffff80368776>] ? security_file_permission+0x16/0x20
> [ 775.663435] [<ffffffff802f4198>] vfs_read+0xc8/0x170
> [ 775.663447] [<ffffffff802f4335>] sys_read+0x55/0x90
> [ 775.663460] [<ffffffff8020c67a>] system_call_fastpath+0x16/0x1b
This breakage was caused by me via:
7cbaef9: sched: optimize sched_clock() a bit
Change the calls to cpu_clock().
Reported-by: Luis Henriques <henrix@sapo.pt>
Impact: extend /proc/sched_debug info
Since the statistics of a group entity isn't exported directly from the
kernel, it becomes difficult to obtain some of the group statistics.
For example, the current method to obtain exec time of a group entity
is not always accurate. One has to read the exec times of all
the tasks(/proc/<pid>/sched) in the group and add them. This method
fails (or becomes difficult) if we want to collect stats of a group over
a duration where tasks get created and terminated.
This patch makes it easier to obtain group stats by directly including
them in /proc/sched_debug. Stats like group exec time would help user
programs (like LTP) to accurately measure the group fairness.
An example output of group stats from /proc/sched_debug:
cfs_rq[3]:/3/a/1
.exec_clock : 89.598007
.MIN_vruntime : 0.000001
.min_vruntime : 256300.970506
.max_vruntime : 0.000001
.spread : 0.000000
.spread0 : -25373.372248
.nr_running : 0
.load : 0
.yld_exp_empty : 0
.yld_act_empty : 0
.yld_both_empty : 0
.yld_count : 4474
.sched_switch : 0
.sched_count : 40507
.sched_goidle : 12686
.ttwu_count : 15114
.ttwu_local : 11950
.bkl_count : 67
.nr_spread_over : 0
.shares : 0
.se->exec_start : 113676.727170
.se->vruntime : 1592.612714
.se->sum_exec_runtime : 89.598007
.se->wait_start : 0.000000
.se->sleep_start : 0.000000
.se->block_start : 0.000000
.se->sleep_max : 0.000000
.se->block_max : 0.000000
.se->exec_max : 1.000282
.se->slice_max : 1.999750
.se->wait_max : 54.981093
.se->wait_sum : 217.610521
.se->wait_count : 50
.se->load.weight : 2
Acked-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Impact: clean up and fix debug info printout
While looking over the sched_debug code I noticed that we printed the rq
schedstats for every cfs_rq, ammend this.
Also change nr_spead_over into an int, and fix a little buglet in
min_vruntime printing.
Impact: cleanup
cfs->tg is initialized in init_tg_cfs_entry() with tg != NULL, and
will never be invalidated to NULL. And the underlying cgroup of a
valid task_group is always valid.
Same for rt->tg.
Impact: change /proc/sched/debug from rw-r--r-- to r--r--r--
/proc/sched_debug is read-only.
rcu_read_lock()
lock_task_sighand() make sure task->sighand is being protected,
so we do not need rcu_read_lock().
[ exec() will get task->sighand->siglock before change task->sighand! ]
But code using rcu_read_lock() _just_ to protect lock_task_sighand()
only appear in procfs. (and some code in procfs use lock_task_sighand()
without such redundant protection.)
Other subsystem may put lock_task_sighand() into rcu_read_lock()
critical region, but these rcu_read_lock() are used for protecting
"for_each_process()", "find_task_by_vpid()" etc. , not for protecting
lock_task_sighand().
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
[ok from Oleg]
show all the schedstats in /debug/sched_debug as well.
Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Try again..
Initial commit: 18d95a2832c1392a2d63227a7a6d433cb9f2037e
Revert: 6363ca57c76b7b83639ca8c83fc285fa26a7880e
Cc: "Daniel K." <dk@uw.no>
Yanmin Zhang reported:
Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1.
It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito.
With bisect, I located the following patch:
| 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit
| commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e
| Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
| Date: Sat Apr 19 19:45:00 2008 +0200
| sched: fair-group: SMP-nice for group scheduling
Revert it so that we get v2.6.25 behavior.
Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
this replaces the rq->clock stuff (and possibly cpu_clock()).
- architectures that have an 'imperfect' hardware clock can set
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
- the 'jiffie' window might be superfulous when we update tick_gtod
before the __update_sched_clock() call in sched_clock_tick()
- cpu_clock() might be implemented as:
sched_clock_cpu(smp_processor_id())
if the accuracy proves good enough - how far can TSC drift in a
single jiffie when considering the filtering and idle hooks?
[ mingo@elte.hu: various fixes and cleanups ]
Rename div64_64 to div64_u64 to make it consistent with the other divide
functions, so it clearly includes the type of the divide. Move its definition
to math64.h as currently no architecture overrides the generic implementation.
They can still override it of course, but the duplicated declarations are
avoided.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Patrick McHardy <kaber@trash.net>
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Add some extra debug output so we can get a better overview of the
full hierarchy.
We print the cgroup path after each cfs_rq, so we can see what group
we're looking at.
it's unused.
