path: root/kernel/sched_debug.c
2011-11-17sched: Move all scheduler bits into kernel/sched/Peter Zijlstra
There's too many sched*.[ch] files in kernel/, give them their own directory. (No code changed, other than Makefile glue added.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-11-17sched: Make separate sched*.c translation unitsPeter Zijlstra
Since once needs to do something at conferences and fixing compile warnings doesn't actually require much if any attention I decided to break up the sched.c #include "*.c" fest. This further modularizes the scheduler code. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-x0fcd3mnp8f9c99grcpewmhi@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-24sched: Get rid of lock_depthJonathan Corbet
Neil Brown pointed out that lock_depth somehow escaped the BKL removal work. Let's get rid of it now. Note that the perf scripting utilities still have a bunch of code for dealing with common_lock_depth in tracepoints; I have left that in place in case anybody wants to use that code with older kernels. Suggested-by: Neil Brown <neilb@suse.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-14sched: Provide p->on_rqPeter Zijlstra
Provide a generic p->on_rq because the p->se.on_rq semantics are unfavourable for lockless wakeups but needed for sched_fair. In particular, p->on_rq is only cleared when we actually dequeue the task in schedule() and not on any random dequeue as done by things like __migrate_task() and __sched_setscheduler(). This also allows us to remove p->se usage from !sched_fair code. Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.949545047@chello.nl
2011-02-03sched: Use a buddy to implement yield_task_fair()Rik van Riel
Use the buddy mechanism to implement yield_task_fair. This allows us to skip onto the next highest priority se at every level in the CFS tree, unless doing so would introduce gross unfairness in CPU time distribution. We order the buddy selection in pick_next_entity to check yield first, then last, then next. We need next to be able to override yield, because it is possible for the "next" and "yield" task to be different processen in the same sub-tree of the CFS tree. When they are, we need to go into that sub-tree regardless of the "yield" hint, and pick the correct entity once we get to the right level. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110201095103.3a79e92a@annuminas.surriel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Replace rq->bkl_count with rq->rq_sched_info.bkl_countYong Zhang
Now rq->rq_sched_info.bkl_count is not used for rq, scroll rq->bkl_count into it. Thus we can save some space for rq. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294991859-13246-1-git-send-email-yong.zhang0@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Display autogroup names in /proc/sched_debugBharata B Rao
Add autogroup name to cfs_rq and tasks information to /proc/sched_debug. Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110111101257.GF4772@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Reinstate group names in /proc/sched_debugBharata B Rao
Displaying of group names in /proc/sched_debug was dropped in autogroup patches. Add group names while displaying cfs_rq and tasks information. Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110111101153.GE4772@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-30sched: Add 'autogroup' scheduling feature: automated per session task groupsMike Galbraith
A recurring complaint from CFS users is that parallel kbuild has a negative impact on desktop interactivity. This patch implements an idea from Linus, to automatically create task groups. Currently, only per session autogroups are implemented, but the patch leaves the way open for enhancement. Implementation: each task's signal struct contains an inherited pointer to a refcounted autogroup struct containing a task group pointer, the default for all tasks pointing to the init_task_group. When a task calls setsid(), a new task group is created, the process is moved into the new task group, and a reference to the preveious task group is dropped. Child processes inherit this task group thereafter, and increase it's refcount. When the last thread of a process exits, the process's reference is dropped, such that when the last process referencing an autogroup exits, the autogroup is destroyed. At runqueue selection time, IFF a task has no cgroup assignment, its current autogroup is used. Autogroup bandwidth is controllable via setting it's nice level through the proc filesystem: cat /proc/<pid>/autogroup Displays the task's group and the group's nice level. echo <nice level> > /proc/<pid>/autogroup Sets the task group's shares to the weight of nice <level> task. Setting nice level is rate limited for !admin users due to the abuse risk of task group locking. The feature is enabled from boot by default if CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via the boot option noautogroup, and can also be turned on/off on the fly via: echo [01] > /proc/sys/kernel/sched_autogroup_enabled ... which will automatically move tasks to/from the root task group. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Paul Turner <pjt@google.com> Cc: Oleg Nesterov <oleg@redhat.com> [ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-23sched: Add some clock info to sched_debugPeter Zijlstra
Add more clock information to /proc/sched_debug, Thomas wanted to see the sched_clock_stable state. Requested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18sched: Rewrite tg_shares_up)Peter Zijlstra
By tracking a per-cpu load-avg for each cfs_rq and folding it into a global task_group load on each tick we can rework tg_shares_up to be strictly per-cpu. This should improve cpu-cgroup performance for smp systems significantly. [ Paul: changed to use queueing cfs_rq + bug fixes ] Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101115234937.580480400@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-21sched: Use correct macro to display sched_child_runs_first in /proc/sched_debugJosh Hunt
The sched_child_runs_first value in /proc/sched_debug is currently displayed using a macro meant to split ns time values. This patch uses the correct macro to display it as a plain decimal value. Signed-off-by: Josh Hunt <johunt@akamai.com> Cc: peterz@infradead.org Cc: juhlenko@akamai.com Cc: efault@gmx.de LKML-Reference: <1279567876-25418-1-git-send-email-johunt@akamai.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-27proc_sched_show_task(): use get_nr_threads()Oleg Nesterov
Trivial, use get_nr_threads() helper to read signal->count which we are going to change. Like other callers, proc_sched_show_task() doesn't need the exactly precise nr_threads. David said: : Note that get_nr_threads() isn't completely equivalent (it can return 0 : where proc_sched_show_task() will display a 1). But I don't think this : should be a problem. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-18Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (49 commits) stop_machine: Move local variable closer to the usage site in cpu_stop_cpu_callback() sched, wait: Use wrapper functions sched: Remove a stale comment ondemand: Make the iowait-is-busy time a sysfs tunable ondemand: Solve a big performance issue by counting IOWAIT time as busy sched: Intoduce get_cpu_iowait_time_us() sched: Eliminate the ts->idle_lastupdate field sched: Fold updating of the last_update_time_info into update_ts_time_stats() sched: Update the idle statistics in get_cpu_idle_time_us() sched: Introduce a function to update the idle statistics sched: Add a comment to get_cpu_idle_time_us() cpu_stop: add dummy implementation for UP sched: Remove rq argument to the tracepoints rcu: need barrier() in UP synchronize_sched_expedited() sched: correctly place paranioa memory barriers in synchronize_sched_expedited() sched: kill paranoia check in synchronize_sched_expedited() sched: replace migration_thread with cpu_stop stop_machine: reimplement using cpu_stop cpu_stop: implement stop_cpu[s]() sched: Fix select_idle_sibling() logic in select_task_rq_fair() ...
2010-05-04sched: Fix an RCU warning in print_task()Li Zefan
With CONFIG_PROVE_RCU=y, a warning can be triggered: $ cat /proc/sched_debug ... kernel/cgroup.c:1649 invoked rcu_dereference_check() without protection! ... Both cgroup_path() and task_group() should be called with either rcu_read_lock or cgroup_mutex held. The rcu_dereference_check() does include cgroup_lock_is_held(), so we know that this lock is not held. Therefore, in a CONFIG_PREEMPT kernel, to say nothing of a CONFIG_PREEMPT_RT kernel, the original code could have ended up copying a string out of the freelist. This patch inserts RCU read-side primitives needed to prevent this scenario. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-04-15Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: merge the latest fixes, update to -rc4. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Remove remaining USER_SCHED codeLi Zefan
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"") Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Fix proc_sched_set_task()Mike Galbraith
Latencytop clearing sum_exec_runtime via proc_sched_set_task() breaks task_times(). Other places in kernel use nvcsw and nivcsw, which are being cleared as well, Clear task statistics only. Reported-by: Török Edwin <edwintorok@gmail.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1269940193.19286.14.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove avg_overlapMike Galbraith
Both avg_overlap and avg_wakeup had an inherent problem in that their accuracy was detrimentally affected by cross-cpu wakeups, this because we are missing the necessary call to update_curr(). This can't be fixed without increasing overhead in our already too fat fastpath. Additionally, with recent load balancing changes making us prefer to place tasks in an idle cache domain (which is good for compute bound loads), communicating tasks suffer when a sync wakeup, which would enable affine placement, is turned into a non-sync wakeup by SYNC_LESS. With one task on the runqueue, wake_affine() rejects the affine wakeup request, leaving the unfortunate where placed, taking frequent cache misses. Remove it, and recover some fastpath cycles. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301121.6785.30.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove avg_wakeupMike Galbraith
Testing the load which led to this heuristic (nfs4 kbuild) shows that it has outlived it's usefullness. With intervening load balancing changes, I cannot see any difference with/without, so recover there fastpath cycles. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301062.6785.29.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Implement group scheduler statistics in one structLucas De Marchi
Put all statistic fields of sched_entity in one struct, sched_statistics, and embed it into sched_entity. This change allows to memset the sched_statistics to 0 when needed (for instance when forking), avoiding bugs of non initialized fields. Signed-off-by: Lucas De Marchi <lucas.de.marchi@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268275065-18542-1-git-send-email-lucas.de.marchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14sched: Convert rq->lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-10sched: Remove forced2_migrations statsIngo Molnar
This build warning: kernel/sched.c: In function 'set_task_cpu': kernel/sched.c:2070: warning: unused variable 'old_rq' Made me realize that the forced2_migrations stat looks pretty pointless (and a misnomer) - remove it. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09sched: Make tunable scaling style configurableChristian Ehrhardt
As scaling now takes place on all kind of cpu add/remove events a user that configures values via proc should be able to configure if his set values are still rescaled or kept whatever happens. As the comments state that log2 was just a second guess that worked the interface is not just designed for on/off, but to choose a scaling type. Currently this allows none, log and linear, but more important it allwos us to keep the interface even if someone has an even better idea how to scale the values. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1259579808-11357-3-git-send-email-ehrhardt@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09sched: Discard some old bitsPeter Zijlstra
WAKEUP_RUNNING was an experiment, not sure why that ever ended up being merged... Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-04sched: Rate-limit newidleMike Galbraith
Rate limit newidle to migration_cost. It's a win for all stages of sysbench oltp tests. Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-17sched: Add new wakeup preemption mode: WAKEUP_RUNNINGPeter Zijlstra
Create a new wakeup preemption mode, preempt towards tasks that run shorter on avg. It sets next buddy to be sure we actually run the task we preempted for. Test results: root@twins:~# while :; do :; done & [1] 6537 root@twins:~# while :; do :; done & [2] 6538 root@twins:~# while :; do :; done & [3] 6539 root@twins:~# while :; do :; done & [4] 6540 root@twins:/home/peter# ./latt -c4 sleep 4 Entries: 48 (clients=4) Averages: ------------------------------ Max 4750 usec Avg 497 usec Stdev 737 usec root@twins:/home/peter# echo WAKEUP_RUNNING > /debug/sched_features root@twins:/home/peter# ./latt -c4 sleep 4 Entries: 48 (clients=4) Averages: ------------------------------ Max 14 usec Avg 5 usec Stdev 3 usec Disabled by default - needs more testing. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <new-submission>
2009-09-02sched: Provide iowait countersArjan van de Ven
For counting how long an application has been waiting for (disk) IO, there currently is only the HZ sample driven information available, while for all other counters in this class, a high resolution version is available via CONFIG_SCHEDSTATS. In order to make an improved bootchart tool possible, we also need a higher resolution version of the iowait time. This patch below adds this scheduler statistic to the kernel. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4A64B813.1080506@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-17sched: Hide runqueues from direct refer at source code levelHitoshi Mitake
There are some points which refer the per-cpu value "runqueues" directly. sched.c provides nice abstraction, such as cpu_rq() and this_rq(), so we should use these macros when looking runqueues. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> LKML-Reference: <20090617.222055.374768827975756908.mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24sched: remove unused fields from struct rqLuis Henriques
Impact: cleanup, new schedstat ABI Since they are used on in statistics and are always set to zero, the following fields from struct rq have been removed: yld_exp_empty, yld_act_empty and yld_both_empty. Both Sched Debug and SCHEDSTAT_VERSION versions has also been incremented since ABIs have been changed. The schedtop tool has been updated to properly handle new version of schedstat: http://rt.wiki.kernel.org/index.php/Schedtop_utility Signed-off-by: Luis Henriques <henrix@sapo.pt> Acked-by: Gregory Haskins <ghaskins@novell.com> Acked-by: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20090324221002.GA10061@hades.domain.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-18sched: jiffies not printed per CPULuis Henriques
The jiffies value was being printed for each CPU, which does not seem to make sense. Moved jiffies to system section. Signed-off-by: Luis Henriques <henrix@sapo.pt> Acked-by: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20090318000425.GA2228@hades.domain.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-15sched: introduce avg_wakeupPeter Zijlstra
Introduce a new avg_wakeup statistic. avg_wakeup is a measure of how frequently a task wakes up other tasks, it represents the average time between wakeups, with a limit of avg_runtime for when it doesn't wake up anybody. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11sched: partly revert "sched debug: remove NULL checking in print_cfs_rt_rq()"Li Zefan
Impact: avoid accessing NULL tg.css->cgroup In commit 0a0db8f5c9d4bbb9bbfcc2b6cb6bce2d0ef4d73d, I removed checking NULL tg.css->cgroup, but I realized I was wrong when I found reading /proc/sched_debug can race with cgroup_create(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-01sched: add uid information to sched_debug for CONFIG_USER_SCHEDArun R Bharadwaj
Impact: extend information in /proc/sched_debug This patch adds uid information in sched_debug for CONFIG_USER_SCHED Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-19Merge branch 'linus' into sched/coreIngo Molnar
Conflicts: kernel/Makefile
2008-11-16sched: fix kernel warning on /proc/sched_debug accessIngo Molnar
Luis Henriques reported that with CONFIG_PREEMPT=y + CONFIG_PREEMPT_DEBUG=y + CONFIG_SCHED_DEBUG=y + CONFIG_LATENCYTOP=y enabled, the following warning triggers when using latencytop: > [ 775.663239] BUG: using smp_processor_id() in preemptible [00000000] code: latencytop/6585 > [ 775.663303] caller is native_sched_clock+0x3a/0x80 > [ 775.663314] Pid: 6585, comm: latencytop Tainted: G W 2.6.28-rc4-00355-g9c7c354 #1 > [ 775.663322] Call Trace: > [ 775.663343] [<ffffffff803a94e4>] debug_smp_processor_id+0xe4/0xf0 > [ 775.663356] [<ffffffff80213f7a>] native_sched_clock+0x3a/0x80 > [ 775.663368] [<ffffffff80213e19>] sched_clock+0x9/0x10 > [ 775.663381] [<ffffffff8024550d>] proc_sched_show_task+0x8bd/0x10e0 > [ 775.663395] [<ffffffff8034466e>] sched_show+0x3e/0x80 > [ 775.663408] [<ffffffff8031039b>] seq_read+0xdb/0x350 > [ 775.663421] [<ffffffff80368776>] ? security_file_permission+0x16/0x20 > [ 775.663435] [<ffffffff802f4198>] vfs_read+0xc8/0x170 > [ 775.663447] [<ffffffff802f4335>] sys_read+0x55/0x90 > [ 775.663460] [<ffffffff8020c67a>] system_call_fastpath+0x16/0x1b > ... This breakage was caused by me via: 7cbaef9: sched: optimize sched_clock() a bit Change the calls to cpu_clock(). Reported-by: Luis Henriques <henrix@sapo.pt>
2008-11-11sched: include group statistics in /proc/sched_debugBharata B Rao
Impact: extend /proc/sched_debug info Since the statistics of a group entity isn't exported directly from the kernel, it becomes difficult to obtain some of the group statistics. For example, the current method to obtain exec time of a group entity is not always accurate. One has to read the exec times of all the tasks(/proc/<pid>/sched) in the group and add them. This method fails (or becomes difficult) if we want to collect stats of a group over a duration where tasks get created and terminated. This patch makes it easier to obtain group stats by directly including them in /proc/sched_debug. Stats like group exec time would help user programs (like LTP) to accurately measure the group fairness. An example output of group stats from /proc/sched_debug: cfs_rq[3]:/3/a/1 .exec_clock : 89.598007 .MIN_vruntime : 0.000001 .min_vruntime : 256300.970506 .max_vruntime : 0.000001 .spread : 0.000000 .spread0 : -25373.372248 .nr_running : 0 .load : 0 .yld_exp_empty : 0 .yld_act_empty : 0 .yld_both_empty : 0 .yld_count : 4474 .sched_switch : 0 .sched_count : 40507 .sched_goidle : 12686 .ttwu_count : 15114 .ttwu_local : 11950 .bkl_count : 67 .nr_spread_over : 0 .shares : 0 .se->exec_start : 113676.727170 .se->vruntime : 1592.612714 .se->sum_exec_runtime : 89.598007 .se->wait_start : 0.000000 .se->sleep_start : 0.000000 .se->block_start : 0.000000 .se->sleep_max : 0.000000 .se->block_max : 0.000000 .se->exec_max : 1.000282 .se->slice_max : 1.999750 .se->wait_max : 54.981093 .se->wait_sum : 217.610521 .se->wait_count : 50 .se->load.weight : 2 Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Acked-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-10sched: clean up debug infoPeter Zijlstra
Impact: clean up and fix debug info printout While looking over the sched_debug code I noticed that we printed the rq schedstats for every cfs_rq, ammend this. Also change nr_spead_over into an int, and fix a little buglet in min_vruntime printing. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04sched debug: remove NULL checking in print_cfs/rt_rq()Li Zefan
Impact: cleanup cfs->tg is initialized in init_tg_cfs_entry() with tg != NULL, and will never be invalidated to NULL. And the underlying cgroup of a valid task_group is always valid. Same for rt->tg. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-30sched: change sched_debug's mode to 0444Li Zefan
Impact: change /proc/sched/debug from rw-r--r-- to r--r--r-- /proc/sched_debug is read-only. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10[PATCH] signal, procfs: some lock_task_sighand() users do not need ↵Lai Jiangshan
rcu_read_lock() lock_task_sighand() make sure task->sighand is being protected, so we do not need rcu_read_lock(). [ exec() will get task->sighand->siglock before change task->sighand! ] But code using rcu_read_lock() _just_ to protect lock_task_sighand() only appear in procfs. (and some code in procfs use lock_task_sighand() without such redundant protection.) Other subsystem may put lock_task_sighand() into rcu_read_lock() critical region, but these rcu_read_lock() are used for protecting "for_each_process()", "find_task_by_vpid()" etc. , not for protecting lock_task_sighand(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> [ok from Oleg] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-06-27sched: add full schedstats to /proc/sched_debugPeter Zijlstra
show all the schedstats in /debug/sched_debug as well. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: revert revert of: fair-group: SMP-nice for group schedulingPeter Zijlstra
Try again.. Initial commit: 18d95a2832c1392a2d63227a7a6d433cb9f2037e Revert: 6363ca57c76b7b83639ca8c83fc285fa26a7880e Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20sched: debug: add some rt debug outputPeter Zijlstra
Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Daniel K." <dk@uw.no> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29revert ("sched: fair-group: SMP-nice for group scheduling")Ingo Molnar
Yanmin Zhang reported: Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1. It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito. With bisect, I located the following patch: | 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit | commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair-group: SMP-nice for group scheduling Revert it so that we get v2.6.25 behavior. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-05sched: add optional support for CONFIG_HAVE_UNSTABLE_SCHED_CLOCKPeter Zijlstra
this replaces the rq->clock stuff (and possibly cpu_clock()). - architectures that have an 'imperfect' hardware clock can set CONFIG_HAVE_UNSTABLE_SCHED_CLOCK - the 'jiffie' window might be superfulous when we update tick_gtod before the __update_sched_clock() call in sched_clock_tick() - cpu_clock() might be implemented as: sched_clock_cpu(smp_processor_id()) if the accuracy proves good enough - how far can TSC drift in a single jiffie when considering the filtering and idle hooks? [ mingo@elte.hu: various fixes and cleanups ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19sched: build fixIngo Molnar
2008-04-19sched: debug: add some debug code to handle the full hierarchyPeter Zijlstra
Add some extra debug output so we can get a better overview of the full hierarchy. We print the cgroup path after each cfs_rq, so we can see what group we're looking at. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
