path: root/kernel/signal.c
2010-10-27signals: annotate lock context change on ptrace_stop()Namhyung Kim
ptrace_stop() releases and regrabs current->sighand->siglock but was missing proper annotation. Add it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27signals: annotate lock_task_sighand()Namhyung Kim
lock_task_sighand() grabs sighand->siglock in case of returning non-NULL but unlock_task_sighand() releases it unconditionally. This leads sparse to complain about the lock context imbalance. Rename and wrap lock_task_sighand() using __cond_lock() macro to make sparse happy. Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07HWPOISON: Copy si_addr_lsb to userAndi Kleen
The original hwpoison code added a new siginfo field si_addr_lsb to pass the granuality of the fault address to user space. Unfortunately this field was never copied to user space. Fix this here. I added explicit checks for the MCEERR codes to avoid having to patch all potential callers to initialize the field. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-04CRED: Fix RCU warning due to previous patch fixing __task_cred()'s checksDavid Howells
Commit 8f92054e7ca1 ("CRED: Fix __task_cred()'s lockdep check and banner comment") fixed the lockdep checks on __task_cred(). This has shown up a place in the signalling code where a lock should be held - namely that check_kill_permission() requires its callers to hold the RCU lock. Fix group_send_sig_info() to get the RCU read lock around its call to check_kill_permission(). Without this patch, the following warning can occur: =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- kernel/signal.c:660 invoked rcu_dereference_check() without protection! ... Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27exit: change zap_other_threads() to count sub-threadsOleg Nesterov
Change zap_other_threads() to return the number of other sub-threads found on ->thread_group list. Other changes are cosmetic: - change the code to use while_each_thread() helper - remove the obsolete comment about SIGKILL/SIGSTOP Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27signals: check_kill_permission(): don't check creds if same_thread_group()Oleg Nesterov
Andrew Tridgell reports that aio_read(SIGEV_SIGNAL) can fail if the notification from the helper thread races with setresuid(), see http://samba.org/~tridge/junkcode/aio_uid.c This happens because check_kill_permission() doesn't permit sending a signal to the task with the different cred->xids. But there is not any security reason to check ->cred's when the task sends a signal (private or group-wide) to its sub-thread. Whatever we do, any thread can bypass all security checks and send SIGKILL to all threads, or it can block a signal SIG and do kill(gettid(), SIG) to deliver this signal to another sub-thread. Not to mention that CLONE_THREAD implies CLONE_VM. Change check_kill_permission() to avoid the credentials check when the sender and the target are from the same thread group. Also, move "cred = current_cred()" down to avoid calling get_current() twice. Note: David Howells pointed out we could relax this even more, the CLONE_SIGHAND (without CLONE_THREAD) case probably does not need these checks too. Roland said: : The glibc (libpthread) that does set*id across threads has : been in use for a while (2.3.4?), probably in distro's using kernels as old : or older than any active -stable streams. In the race in question, this : kernel bug is breaking valid POSIX application expectations. Reported-by: Andrew Tridgell <tridge@samba.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Eric Paris <eparis@parisplace.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: <stable@kernel.org> [all kernel versions] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-20kdb: core for kgdb back end (2 of 2)Jason Wessel
This patch contains the hooks and instrumentation into kernel which live outside the kernel/debug directory, which the kdb core will call to run commands like lsmod, dmesg, bt etc... CC: linux-arch@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Martin Hicks <mort@sgi.com>
2010-03-06kernel core: use helpers for rlimitsJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-03Prioritize synchronous signals over 'normal' signalsLinus Torvalds
This makes sure that we pick the synchronous signals caused by a processor fault over any pending regular asynchronous signals sent to use by [t]kill(). This is not strictly required semantics, but it makes it _much_ easier for programs like Wine that expect to find the fault information in the signal stack. Without this, if a non-synchronous signal gets picked first, the delayed asynchronous signal will have its signal context pointing to the new signal invocation, rather than the instruction that caused the SIGSEGV or SIGBUS in the first place. This is not all that pretty, and we're discussing making the synchronous signals more explicit rather than have these kinds of implicit preferences of SIGSEGV and friends. See for example http://bugzilla.kernel.org/show_bug.cgi?id=15395 for some of the discussion. But in the meantime this is a simple and fairly straightforward work-around, and the whole if (x & Y) x &= Y; thing can be compiled into (and gcc does do it) just three instructions: movq %rdx, %rax andl $Y, %eax cmovne %rax, %rdx so it is at least a simple solution to a subtle issue. Reported-and-tested-by: Pavel Vilim <wylda@volny.cz> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11kernel/signal.c: fix kernel information leak with print-fatal-signals=1Andi Kleen
When print-fatal-signals is enabled it's possible to dump any memory reachable by the kernel to the log by simply jumping to that address from user space. Or crash the system if there's some hardware with read side effects. The fatal signals handler will dump 16 bytes at the execution address, which is fully controlled by ring 3. In addition when something jumps to a unmapped address there will be up to 16 additional useless page faults, which might be potentially slow (and at least is not very efficient) Fortunately this option is off by default and only there on i386. But fix it by checking for kernel addresses and also stopping when there's a page fault. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-19Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sys: Fix missing rcu protection for __task_cred() access signals: Fix more rcu assumptions signal: Fix racy access to __task_cred in kill_pid_info_as_uid()
2009-12-16signals: check ->group_stop_count after tracehook_get_signal()Oleg Nesterov
Move the call to do_signal_stop() down, after tracehook call. This makes ->group_stop_count condition visible to tracers before do_signal_stop() will participate in this group-stop. Currently the patch has no effect, tracehook_get_signal() always returns 0. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16signals: kill force_sig_specific()Oleg Nesterov
Kill force_sig_specific(), this trivial wrapper has no callers. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16signals: cosmetic, collect_signal: use SI_USEROleg Nesterov
Trivial, s/0/SI_USER/ in collect_signal() for grep. This is a bit confusing, we don't know the source of this signal. But we don't care, and "info->si_code = 0" is imho worse. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16signals: send_signal: use si_fromuser() to detect from_ancestor_nsOleg Nesterov
Change send_signal() to use si_fromuser(). From now SEND_SIG_NOINFO triggers the "from_ancestor_ns" check. This fixes reparent_thread()->group_send_sig_info(pdeath_signal) behaviour, before this patch send_signal() does not detect the cross-namespace case when the child of the dying parent belongs to the sub-namespace. This patch can affect the behaviour of send_sig(), kill_pgrp() and kill_pid() when the caller sends the signal to the sub-namespace with "priv == 0" but surprisingly all callers seem to use them correctly, including disassociate_ctty(on_exit). Except: drivers/staging/comedi/drivers/addi-data/*.c incorrectly use send_sig(priv => 0). But his is minor and should be fixed anyway. Reported-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Reviewed-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16signals: SEND_SIG_NOINFO should be considered as SI_FROMUSER()Oleg Nesterov
No changes in compiled code. The patch adds the new helper, si_fromuser() and changes check_kill_permission() to use this helper. The real effect of this patch is that from now we "officially" consider SEND_SIG_NOINFO signal as "from user-space" signals. This is already true if we look at the code which uses SEND_SIG_NOINFO, except __send_signal() has another opinion - see the next patch. The naming of these special SEND_SIG_XXX siginfo's is really bad imho. From __send_signal()'s pov they mean SEND_SIG_NOINFO from user SEND_SIG_PRIV from kernel SEND_SIG_FORCED no info Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Reviewed-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10signals: Fix more rcu assumptionsThomas Gleixner
1) Remove the misleading comment in __sigqueue_alloc() which claims that holding a spinlock is equivalent to rcu_read_lock(). 2) Add a rcu_read_lock/unlock around the __task_cred() access in __sigqueue_alloc() This needs to be revisited to remove the remaining users of read_lock(&tasklist_lock) but that's outside the scope of this patch. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <20091210004703.269843657@linutronix.de>
2009-12-10signal: Fix racy access to __task_cred in kill_pid_info_as_uid()Thomas Gleixner
kill_pid_info_as_uid() accesses __task_cred() without being in a RCU read side critical section. tasklist_lock is not protecting that when CONFIG_TREE_PREEMPT_RCU=y. Convert the whole tasklist_lock section to rcu and use lock_task_sighand to prevent the exit race. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <20091210004703.232302055@linutronix.de> Acked-by: Oleg Nesterov <oleg@redhat.com>
2009-12-05Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (470 commits) x86: Fix comments of register/stack access functions perf tools: Replace %m with %a in sscanf hw-breakpoints: Keep track of user disabled breakpoints tracing/syscalls: Make syscall events print callbacks static tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbook perf: Don't free perf_mmap_data until work has been done perf_event: Fix compile error perf tools: Fix _GNU_SOURCE macro related strndup() build error trace_syscalls: Remove unused syscall_name_to_nr() trace_syscalls: Simplify syscall profile trace_syscalls: Remove duplicate init_enter_##sname() trace_syscalls: Add syscall_nr field to struct syscall_metadata trace_syscalls: Remove enter_id exit_id trace_syscalls: Set event_enter_##sname->data to its metadata trace_syscalls: Remove unused event_syscall_enter and event_syscall_exit perf_event: Initialize data.period in perf_swevent_hrtimer() perf probe: Simplify event naming perf probe: Add --list option for listing current probe events perf probe: Add argv_split() from lib/argv_split.c perf probe: Move probe event utility functions to probe-event.c ...
2009-11-26tracepoint: Add signal loss eventsMasami Hiramatsu
Add signal_overflow_fail and signal_lose_info tracepoints for signal-lost events. Changes in v3: - Add docbook style comments Changes in v2: - Use siginfo string macro Suggested-by: Roland McGrath <roland@redhat.com> Reviewed-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Oleg Nesterov <oleg@redhat.com> LKML-Reference: <20091124215658.30449.9934.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-26tracepoint: Add signal deliver eventMasami Hiramatsu
Add a tracepoint where a process gets a signal. This tracepoint shows signal-number, sa-handler and sa-flag. Changes in v3: - Add docbook style comments Changes in v2: - Add siginfo argument - Fix comment Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Reviewed-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Oleg Nesterov <oleg@redhat.com> LKML-Reference: <20091124215651.30449.20926.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-26tracepoint: Move signal sending tracepoint to events/signal.hMasami Hiramatsu
Move signal sending event to events/signal.h. This patch also renames sched_signal_send event to signal_generate. Changes in v4: - Fix a typo of task_struct pointer. Changes in v3: - Add docbook style comments Changes in v2: - Add siginfo argument - Add siginfo storing macro Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Reviewed-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Oleg Nesterov <oleg@redhat.com> LKML-Reference: <20091124215645.30449.60208.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-09signal: Print warning message when dropping signalsNaohiro Ooiwa
When the system has too many timers or too many aggregate queued signals, the EAGAIN error is returned to application from kernel, including timer_create() [POSIX.1b]. It means that the app exceeded the limit of pending signals, but in general application writers do not expect this outcome and the current silent failure can cause rare app failures under very high load. This patch adds a new message when we reach the limit and if print_fatal_signals is enabled: task/1234: reached RLIMIT_SIGPENDING, dropping signal If you see this message and your system behaved unexpectedly, you can run following command to lift the limit: # ulimit -i unlimited With help from Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>. Signed-off-by: Naohiro Ooiwa <nooiwa@miraclelinux.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Roland McGrath <roland@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: oleg@redhat.com LKML-Reference: <4AF6E7E2.9080406@miraclelinux.com> [ Modified a few small details, gave surrounding code some love. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24signals: inline __fatal_signal_pendingRoland McGrath
__fatal_signal_pending inlines to one instruction on x86, probably two instructions on other machines. It takes two longer x86 instructions just to call it and test its return value, not to mention the function itself. On my random x86_64 config, this saved 70 bytes of text (59 of those being __fatal_signal_pending itself). Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24signals: introduce do_send_sig_info() helperOleg Nesterov
Introduce do_send_sig_info() and convert group_send_sig_info(), send_sig_info(), do_send_specific() to use this helper. Hopefully it will have more users soon, it allows to specify specific/group behaviour via "bool group" argument. Shaves 80 bytes from .text. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stephane eranian <eranian@googlemail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24signals: tracehook_notify_jctl changeRoland McGrath
This changes tracehook_notify_jctl() so it's called with the siglock held, and changes its argument and return value definition. These clean-ups make it a better fit for what new tracing hooks need to check. Tracing needs the siglock here, held from the time TASK_STOPPED was set, to avoid potential SIGCONT races if it wants to allow any blocking in its tracing hooks. This also folds the finish_stop() function into its caller do_signal_stop(). The function is short, called only once and only unconditionally. It aids readability to fold it in. [oleg@redhat.com: do not call tracehook_notify_jctl() in TASK_STOPPED state] [oleg@redhat.com: introduce tracehook_finish_jctl() helper] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24ptrace: __ptrace_detach: do __wake_up_parent() if we reap the traceeOleg Nesterov
The bug is old, it wasn't cause by recent changes. Test case: static void *tfunc(void *arg) { int pid = (long)arg; assert(ptrace(PTRACE_ATTACH, pid, NULL, NULL) == 0); kill(pid, SIGKILL); sleep(1); return NULL; } int main(void) { pthread_t th; long pid = fork(); if (!pid) pause(); signal(SIGCHLD, SIG_IGN); assert(pthread_create(&th, NULL, tfunc, (void*)pid) == 0); int r = waitpid(-1, NULL, __WNOTHREAD); printf("waitpid: %d %m\n", r); return 0; } Before the patch this program hangs, after this patch waitpid() correctly fails with errno == -ECHILD. The problem is, __ptrace_detach() reaps the EXIT_ZOMBIE tracee if its ->real_parent is our sub-thread and we ignore SIGCHLD. But in this case we should wake up other threads which can sleep in do_wait(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Vitaly Mayatskikh <vmayatsk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-01do_sigaltstack: small cleanupsLinus Torvalds
The previous commit ("do_sigaltstack: avoid copying 'stack_t' as a structure to user space") fixed a real bug. This one just cleans up the copy from user space to that gcc can generate better code for it (and so that it looks the same as the later copy back to user space). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-01do_sigaltstack: avoid copying 'stack_t' as a structure to user spaceLinus Torvalds
Ulrich Drepper correctly points out that there is generally padding in the structure on 64-bit hosts, and that copying the structure from kernel to user space can leak information from the kernel stack in those padding bytes. Avoid the whole issue by just copying the three members one by one instead, which also means that the function also can avoid the need for a stack frame. This also happens to match how we copy the new structure from user space, so it all even makes sense. [ The obvious solution of adding a memset() generates horrid code, gcc does really stupid things. ] Reported-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ptrace: do_notify_parent_cldstop: fix the wrong ->nsproxy usageOleg Nesterov
If the non-traced sub-thread calls do_notify_parent_cldstop(), we send the notification to group_leader->real_parent and we report group_leader's pid. But, if group_leader is traced we use the wrong ->parent->nsproxy->pid_ns, the tracer and parent can live in different namespaces. Change the code to use "parent" instead of tsk->parent. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ptrace: do not use task->ptrace directly in core kernelOleg Nesterov
No functional changes. - Nobody except ptrace.c & co should use ptrace flags directly, we have task_ptrace() for that. - No need to specially check PT_PTRACED, we must not have other PT_ bits set without PT_PTRACED. And no need to know this flag exists. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15signal: fix __send_signal() false positive kmemcheck warningVegard Nossum
This false positive is due to field padding in struct sigqueue. When this dynamically allocated structure is copied to the stack (in arch- specific delivery code), kmemcheck sees a read from the padding, which is, naturally, uninitialized. Hide the false positive using the __GFP_NOTRACK_FALSE_POSITIVE flag. Also made the rlimit override code a bit clearer by introducing a new variable. Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-05-08Merge branch 'master' into nextJames Morris
2009-04-30signals: implement sys_rt_tgsigqueueinfoThomas Gleixner
sys_kill has the per thread counterpart sys_tgkill. sigqueueinfo is missing a thread directed counterpart. Such an interface is important for migrating applications from other OSes which have the per thread delivery implemented. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Ulrich Drepper <drepper@redhat.com>
2009-04-30signals: split do_tkillThomas Gleixner
Split out the code from do_tkill to make it reusable by the follow up patch which implements sys_rt_tgsigqueueinfo Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Oleg Nesterov <oleg@redhat.com>
2009-04-30SELinux: Don't flush inherited SIGKILL during execve()David Howells
Don't flush inherited SIGKILL during execve() in SELinux's post cred commit hook. This isn't really a security problem: if the SIGKILL came before the credentials were changed, then we were right to receive it at the time, and should honour it; if it came after the creds were changed, then we definitely should honour it; and in any case, all that will happen is that the process will be scrapped before it ever returns to userspace. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-02signals: SI_USER: Masquerade si_pid when crossing pid ns boundarySukadev Bhattiprolu
When sending a signal to a descendant namespace, set ->si_pid to 0 since the sender does not have a pid in the receiver's namespace. Note: - If rt_sigqueueinfo() sets si_code to SI_USER when sending a signal across a pid namespace boundary, the value in ->si_pid will be cleared to 0. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: protect cinit from blocked fatal signalsSukadev Bhattiprolu
Normally SIG_DFL signals to global and container-init are dropped early. But if a signal is blocked when it is posted, we cannot drop the signal since the receiver may install a handler before unblocking the signal. Once this signal is queued however, the receiver container-init has no way of knowing if the signal was sent from an ancestor or descendant namespace. This patch ensures that contianer-init drops all SIG_DFL signals in get_signal_to_deliver() except SIGKILL/SIGSTOP. If SIGSTOP/SIGKILL originate from a descendant of container-init they are never queued (i.e dropped in sig_ignored() in an earler patch). If SIGSTOP/SIGKILL originate from parent namespace, the signal is queued and container-init processes the signal. IOW, if get_signal_to_deliver() sees a sig_kernel_only() signal for global or container-init, the signal must have been generated internally or must have come from an ancestor ns and we process the signal. Further, the signal_group_exit() check was needed to cover the case of a multi-threaded init sending SIGKILL to other threads when doing an exit() or exec(). But since the new sig_kernel_only() check covers the SIGKILL, the signal_group_exit() check is no longer needed and can be removed. Finally, now that we have all pieces in place, set SIGNAL_UNKILLABLE for container-inits. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: protect cinit from unblocked SIG_DFL signalsSukadev Bhattiprolu
Drop early any SIG_DFL or SIG_IGN signals to container-init from within the same container. But queue SIGSTOP and SIGKILL to the container-init if they are from an ancestor container. Blocked, fatal signals (i.e when SIG_DFL is to terminate) from within the container can still terminate the container-init. That will be addressed in the next patch. Note: To be bisect-safe, SIGNAL_UNKILLABLE will be set for container-inits in a follow-on patch. Until then, this patch is just a preparatory step. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: add from_ancestor_ns parameter to send_signal()Sukadev Bhattiprolu
send_signal() (or its helper) needs to determine the pid namespace of the sender. But a signal sent via kill_pid_info_as_uid() comes from within the kernel and send_signal() does not need to determine the pid namespace of the sender. So define a helper for send_signal() which takes an additional parameter, 'from_ancestor_ns' and have kill_pid_info_as_uid() use that helper directly. The 'from_ancestor_ns' parameter will be used in a follow-on patch. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: protect init from unwanted signals moreOleg Nesterov
(This is a modified version of the patch submitted by Oleg Nesterov http://lkml.org/lkml/2008/11/18/249 and tries to address comments that came up in that discussion) init ignores the SIG_DFL signals but we queue them anyway, including SIGKILL. This is mostly OK, the signal will be dropped silently when dequeued, but the pending SIGKILL has 2 bad implications: - it implies fatal_signal_pending(), so we confuse things like wait_for_completion_killable/lock_page_killable. - for the sub-namespace inits, the pending SIGKILL can mask (legacy_queue) the subsequent SIGKILL from the parent namespace which must kill cinit reliably. (preparation, cinits don't have SIGNAL_UNKILLABLE yet) The patch can't help when init is ptraced, but ptracing of init is not "safe" anyway. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: remove 'handler' parameter to tracehook functionsOleg Nesterov
Container-init must behave like global-init to processes within the container and hence it must be immune to unhandled fatal signals from within the container (i.e SIG_DFL signals that terminate the process). But the same container-init must behave like a normal process to processes in ancestor namespaces and so if it receives the same fatal signal from a process in ancestor namespace, the signal must be processed. Implementing these semantics requires that send_signal() determine pid namespace of the sender but since signals can originate from workqueues/ interrupt-handlers, determining pid namespace of sender may not always be possible or safe. This patchset implements the design/simplified semantics suggested by Oleg Nesterov. The simplified semantics for container-init are: - container-init must never be terminated by a signal from a descendant process. - container-init must never be immune to SIGKILL from an ancestor namespace (so a process in parent namespace must always be able to terminate a descendant container). - container-init may be immune to unhandled fatal signals (like SIGUSR1) even if they are from ancestor namespace. SIGKILL/SIGSTOP are the only reliable signals to a container-init from ancestor namespace. This patch: Based on an earlier patch submitted by Oleg Nesterov and comments from Roland McGrath (http://lkml.org/lkml/2008/11/19/258). The handler parameter is currently unused in the tracehook functions. Besides, the tracehook functions are called with siglock held, so the functions can check the handler if they later need to. Removing the parameter simiplifies changes to sig_ignored() in a follow-on patch. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-23fix ptrace slownessMiklos Szeredi
This patch fixes bug #12208: Bug-Entry : http://bugzilla.kernel.org/show_bug.cgi?id=12208 Subject : uml is very slow on 2.6.28 host This turned out to be not a scheduler regression, but an already existing problem in ptrace being triggered by subtle scheduler changes. The problem is this: - task A is ptracing task B - task B stops on a trace event - task A is woken up and preempts task B - task A calls ptrace on task B, which does ptrace_check_attach() - this calls wait_task_inactive(), which sees that task B is still on the runq - task A goes to sleep for a jiffy - ... Since UML does lots of the above sequences, those jiffies quickly add up to make it slow as hell. This patch solves this by not rescheduling in read_unlock() after ptrace_stop() has woken up the tracer. Thanks to Oleg Nesterov and Ingo Molnar for the feedback. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05signal: re-add dead task accumulation stats.Peter Zijlstra
We're going to split the process wide cpu accounting into two parts: - clocks; which can take all the time they want since they run from user context. - timers; which need constant time tracing but can affort the overhead because they're default off -- and rare. The clock readout will go back to a full sum of the thread group, for this we need to re-add the exit stats that were removed in the initial itimer rework (f06febc9: timers: fix itimer/many thread hang). Furthermore, since that full sum can be rather slow for large thread groups and we have the complete dead task stats, revert the do_notify_parent time computation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-27signals, debug: fix BUG: using smp_processor_id() in preemptible code in ↵Ed Swierk
print_fatal_signal() With print-fatal-signals=1 on a kernel with CONFIG_PREEMPT=y, sending an unexpected signal to a process causes a BUG: using smp_processor_id() in preemptible code. get_signal_to_deliver() releases the siglock before calling print_fatal_signal(), which calls show_regs(), which calls smp_processor_id(), which is not supposed to be called from a preemptible thread. Make sure show_regs() runs with preemption disabled. Signed-off-by: Ed Swierk <eswierk@aristanetworks.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14[CVE-2009-0029] System call wrappers part 32Heiko Carstens
