Christoph Hellwig suggested a slightly different path for handling
backwards compatibility with the 32-bit time_t based system calls:
Rather than simply reusing the compat_sys_* entry points on 32-bit
architectures unchanged, we get rid of those entry points and the
compat_time types by renaming them to something that makes more sense
on 32-bit architectures (which don't have a compat mode otherwise),
and then share the entry points under the new name with the 64-bit
architectures that use them for implementing the compatibility.
The following types and interfaces are renamed here, and moved
from linux/compat_time.h to linux/time32.h:
old new
compat_time_t old_time32_t
struct compat_timeval struct old_timeval32
struct compat_timespec struct old_timespec32
struct compat_itimerspec struct old_itimerspec32
ns_to_compat_timeval() ns_to_old_timeval32()
get_compat_itimerspec64() get_old_itimerspec32()
put_compat_itimerspec64() put_old_itimerspec32()
compat_get_timespec64() get_old_timespec32()
compat_put_timespec64() put_old_timespec32()
As we already have aliases in place, this patch addresses only the
instances that are relevant to the system call interface in particular,
not those that occur in device drivers and other modules. Those
will get handled separately, while providing the 64-bit version
of the respective interfaces.
I'm not renaming the timex, rusage and itimerval structures, as we are
still debating what the new interface will look like, and whether we
will need a replacement at all.
This also doesn't change the names of the syscall entry points, which can
be done more easily when we actually switch over the 32-bit architectures
to use them, at that point we need to change COMPAT_SYSCALL_DEFINEx to
SYSCALL_DEFINEx with a new name, e.g. with a _time32 suffix.
Suggested-by: Christoph Hellwig <hch@infradead.org>
Link: https://lore.kernel.org/lkml/20180705222110.GA5698@infradead.org/
Merge more updates from Andrew Morton:
- the rest of MM
- procfs updates
- various misc things
- more y2038 fixes
- get_maintainer updates
- lib/ updates
- checkpatch updates
- various epoll updates
- autofs updates
- hfsplus
- some reiserfs work
- fatfs updates
- signal.c cleanups
- ipc/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (166 commits)
ipc/util.c: update return value of ipc_getref from int to bool
ipc/util.c: further variable name cleanups
ipc: simplify ipc initialization
ipc: get rid of ids->tables_initialized hack
lib/rhashtable: guarantee initial hashtable allocation
lib/rhashtable: simplify bucket_table_alloc()
ipc: drop ipc_lock()
ipc/util.c: correct comment in ipc_obtain_object_check
ipc: rename ipcctl_pre_down_nolock()
ipc/util.c: use ipc_rcu_putref() for failues in ipc_addid()
ipc: reorganize initialization of kern_ipc_perm.seq
ipc: compute kern_ipc_perm.id under the ipc lock
init/Kconfig: remove EXPERT from CHECKPOINT_RESTORE
fs/sysv/inode.c: use ktime_get_real_seconds() for superblock stamp
adfs: use timespec64 for time conversion
kernel/sysctl.c: fix typos in comments
drivers/rapidio/devices/rio_mport_cdev.c: remove redundant pointer md
fork: don't copy inconsistent signal handler state to child
signal: make get_signal() return bool
signal: make sigkill_pending() return bool
make get_signal() already behaves like a boolean function. Let's actually
declare it as such too.
Link: http://lkml.kernel.org/r/20180602103653.18181-18-christian@brauner.io
Signed-off-by: Christian Brauner <christian@brauner.io>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: James Morris <james.morris@microsoft.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
sigkill_pending() already behaves like a boolean function. Let's actually
Link: http://lkml.kernel.org/r/20180602103653.18181-17-christian@brauner.io
legacy_queue() already behaves like a boolean function. Let's actually
Link: http://lkml.kernel.org/r/20180602103653.18181-16-christian@brauner.io
wants_signal() already behaves like a boolean function. Let's actually
Link: http://lkml.kernel.org/r/20180602103653.18181-15-christian@brauner.io
The return value of flush_sigqueue_mask() is never checked anywhere.
Link: http://lkml.kernel.org/r/20180602103653.18181-14-christian@brauner.io
unhandled_signal() already behaves like a boolean function. Let's
actually declare it as such too. All callers treat it as such too.
Link: http://lkml.kernel.org/r/20180602103653.18181-13-christian@brauner.io
recalc_sigpending_tsk() already behaves like a boolean function. Let's
Link: http://lkml.kernel.org/r/20180602103653.18181-12-christian@brauner.io
has_pending_signals() already behaves like a boolean function. Let's
Link: http://lkml.kernel.org/r/20180602103653.18181-11-christian@brauner.io
sig_ignored() already behaves like a boolean function. Let's actually
Link: http://lkml.kernel.org/r/20180602103653.18181-10-christian@brauner.io
sig_task_ignored() already behaves like a boolean function. Let's
Link: http://lkml.kernel.org/r/20180602103653.18181-9-christian@brauner.io
sig_handler_ignored() already behaves like a boolean function. Let's
Link: http://lkml.kernel.org/r/20180602103653.18181-8-christian@brauner.io
kill_ok_by_cred() already behaves like a boolean function. Let's actually
Link: http://lkml.kernel.org/r/20180602103653.18181-7-christian@brauner.io
The goto is not needed and does not add any clarity. Simply return
-EINVAL on unexpected sigset_t struct size directly.
Link: http://lkml.kernel.org/r/20180602103653.18181-6-christian@brauner.io
Acked-by: Oleg Nesterov <oleg@redhat.com>
do_sigpending() returned 0 unconditionally so it doesn't make sense to
have it return at all. This allows us to simplify a bunch of syscall
callers.
Link: http://lkml.kernel.org/r/20180602103653.18181-5-christian@brauner.io
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
may_ptrace_stop() already behaves like a boolean function. Let's actually
Link: http://lkml.kernel.org/r/20180602103653.18181-4-christian@brauner.io
kill_as_cred_perm() already behaves like a boolean function. Let's
Link: http://lkml.kernel.org/r/20180602103653.18181-3-christian@brauner.io
Patch series "signal: refactor some functions", v3.
This series refactors a bunch of functions in signal.c to simplify parts
of the code.
The greatest single change is declaring the static do_sigpending() helper
as void which makes it possible to remove a bunch of unnecessary checks in
the syscalls later on.
This patch (of 17):
force_sigsegv() returned 0 unconditionally so it doesn't make sense to have
it return at all. In addition, there are no callers that check
force_sigsegv()'s return value.
Link: http://lkml.kernel.org/r/20180602103653.18181-2-christian@brauner.io
Wen Yang <wen.yang99@zte.com.cn> and majiang <ma.jiang@zte.com.cn>
report that a periodic signal received during fork can cause fork to
continually restart preventing an application from making progress.
The code was being overly pessimistic. Fork needs to guarantee that a
signal sent to multiple processes is logically delivered before the
fork and just to the forking process or logically delivered after the
fork to both the forking process and it's newly spawned child. For
signals like periodic timers that are always delivered to a single
process fork can safely complete and let them appear to logically
delivered after the fork().
While examining this issue I also discovered that fork today will miss
signals delivered to multiple processes during the fork and handled by
another thread. Similarly the current code will also miss blocked
signals that are delivered to multiple process, as those signals will
not appear pending during fork.
Add a list of each thread that is currently forking, and keep on that
list a signal set that records all of the signals sent to multiple
processes. When fork completes initialize the new processes
shared_pending signal set with it. The calculate_sigpending function
will see those signals and set TIF_SIGPENDING causing the new task to
take the slow path to userspace to handle those signals. Making it
appear as if those signals were received immediately after the fork.
It is not possible to send real time signals to multiple processes and
exceptions don't go to multiple processes, which means that that are
no signals sent to multiple processes that require siginfo. This
means it is safe to not bother collecting siginfo on signals sent
during fork.
The sigaction of a child of fork is initially the same as the
sigaction of the parent process. So a signal the parent ignores the
child will also initially ignore. Therefore it is safe to ignore
signals sent to multiple processes and ignored by the forking process.
Signals sent to only a single process or only a single thread and delivered
during fork are treated as if they are received after the fork, and generally
not dealt with. They won't cause any problems.
V2: Added removal from the multiprocess list on failure.
V3: Use -ERESTARTNOINTR directly
V4: - Don't queue both SIGCONT and SIGSTOP
- Initialize signal_struct.multiprocess in init_task
- Move setting of shared_pending to before the new task
is visible to signals. This prevents signals from comming
in before shared_pending.signal is set to delayed.signal
and being lost.
V5: - rework list add and delete to account for idle threads
v6: - Use sigdelsetmask when removing stop signals
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200447
Reported-by: Wen Yang <wen.yang99@zte.com.cn> and
Reported-by: majiang <ma.jiang@zte.com.cn>
Fixes: 4a2c7a7837da ("[PATCH] make fork() atomic wrt pgrp/session signals")
There are only two signals that are delivered to every member of a
signal group: SIGSTOP and SIGKILL. Signal delivery requires every
signal appear to be delivered either before or after a clone syscall.
SIGKILL terminates the clone so does not need to be considered. Which
leaves only SIGSTOP that needs to be considered when creating new
threads.
Today in the event of a group stop TIF_SIGPENDING will get set and the
fork will restart ensuring the fork syscall participates in the group
stop.
A fork (especially of a process with a lot of memory) is one of the
most expensive system so we really only want to restart a fork when
necessary.
It is easy so check to see if a SIGSTOP is ongoing and have the new
thread join it immediate after the clone completes. Making it appear
the clone completed happened just before the SIGSTOP.
The calculate_sigpending function will see the bits set in jobctl and
set TIF_SIGPENDING to ensure the new task takes the slow path to userspace.
V2: The call to task_join_group_stop was moved before the new task is
added to the thread group list. This should not matter as
sighand->siglock is held over both the addition of the threads,
the call to task_join_group_stop and do_signal_stop. But the change
is trivial and it is one less thing to worry about when reading
the code.
Add a function calculate_sigpending to test to see if any signals are
pending for a new task immediately following fork. Signals have to
happen either before or after fork. Today our practice is to push
all of the signals to before the fork, but that has the downside that
frequent or periodic signals can make fork take much much longer than
normal or prevent fork from completing entirely.
So we need move signals that we can after the fork to prevent that.
This updates the code to set TIF_SIGPENDING on a new task if there
are signals or other activities that have moved so that they appear
to happen after the fork.
As the code today restarts if it sees any such activity this won't
immediately have an effect, as there will be no reason for it
to set TIF_SIGPENDING immediately after the fork.
Adding calculate_sigpending means the code in fork can safely be
changed to not always restart if a signal is pending.
The new calculate_sigpending function sets sigpending if there
are pending bits in jobctl, pending signals, the freezer needs
to freeze the new task or the live kernel patching framework
need the new thread to take the slow path to userspace.
I have verified that setting TIF_SIGPENDING does make a new process
take the slow path to userspace before it executes it's first userspace
instruction.
I have looked at the callers of signal_wake_up and the code paths
setting TIF_SIGPENDING and I don't see anything else that needs to be
handled. The code probably doesn't need to set TIF_SIGPENDING for the
kernel live patching as it uses a separate thread flag as well. But
at this point it seems safer reuse the recalc_sigpending logic and get
the kernel live patching folks to sort out their story later.
V2: I have moved the test into schedule_tail where siglock can
be grabbed and recalc_sigpending can be reused directly.
Further as the last action of setting up a new task this
guarantees that TIF_SIGPENDING will be properly set in the
new process.
The helper calculate_sigpending takes the siglock and
uncontitionally sets TIF_SIGPENDING and let's recalc_sigpending
clear TIF_SIGPENDING if it is unnecessary. This allows reusing
the existing code and keeps maintenance of the conditions simple.
Oleg Nesterov <oleg@redhat.com> suggested the movement
and pointed out the need to take siglock if this code
was going to be called while the new task is discoverable.
This is the bottom and by pushing this down it simplifies the callers
and otherwise leaves things as is. This is in preparation for allowing
fork to implement better handling of signals set to groups of processes.
This information is already available in the callers and by pushing it
down it makes the code a little clearer, and allows implementing
better handling of signales set to a group of processes in fork.
down it makes the code a little clearer, and allows better group
signal behavior in fork.
This passes the information we already have at the call sight into
do_send_sig_info. Ultimately allowing for better handling of signals
sent to a group of processes during fork.
into group_send_sig_info. Ultimatelly allowing for to better handle
signals sent to a group of processes.
Make the code more maintainable by performing more of the signal
related work in send_sigqueue.
A quick inspection of do_timer_create will show that this code path
does not lookup a thread group by a thread's pid. Making it safe
to find the task pointed to by it_pid with "pid_task(it_pid, type)";
This supports the changes needed in fork to tell if a signal was sent
to a single process or a group of processes.
Having the pid to task transition in signal.c will also make it easier
to sort out races with de_thread and and the thread group leader
exiting when it comes time to address that.
Commit a841796f11c9 ("signal: align __lock_task_sighand() irq disabling and
RCU") introduced a rcu read side critical section with interrupts
disabled. The changelog suggested that a better long-term fix would be "to
make rt_mutex_unlock() disable irqs when acquiring the rt_mutex structure's
->wait_lock".
This long-term fix has been made in commit b4abf91047cf ("rtmutex: Make
wait_lock irq safe") for a different reason.
Therefore revert commit a841796f11c9 ("signal: align >
__lock_task_sighand() irq disabling and RCU") as the interrupt disable
dance is not longer required.
The change was tested on the base of b4abf91047cf ("rtmutex: Make wait_lock
irq safe") with a four hour run of rcutorture scenario TREE03 with lockdep
enabled as suggested by Paul McKenney.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: bigeasy@linutronix.de
Link: https://lkml.kernel.org/r/20180525090507.22248-3-anna-maria@linutronix.de
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull siginfo updates from Eric Biederman:
"This set of changes close the known issues with setting si_code to an
invalid value, and with not fully initializing struct siginfo. There
remains work to do on nds32, arc, unicore32, powerpc, arm, arm64, ia64
and x86 to get the code that generates siginfo into a simpler and more
maintainable state. Most of that work involves refactoring the signal
handling code and thus careful code review.
Also not included is the work to shrink the in kernel version of
struct siginfo. That depends on getting the number of places that
directly manipulate struct siginfo under control, as it requires the
introduction of struct kernel_siginfo for the in kernel things.
Overall this set of changes looks like it is making good progress, and
with a little luck I will be wrapping up the siginfo work next
development cycle"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits)
signal/sh: Stop gcc warning about an impossible case in do_divide_error
signal/mips: Report FPE_FLTUNK for undiagnosed floating point exceptions
signal/um: More carefully relay signals in relay_signal.
signal: Extend siginfo_layout with SIL_FAULT_{MCEERR|BNDERR|PKUERR}
signal: Remove unncessary #ifdef SEGV_PKUERR in 32bit compat code
signal/signalfd: Add support for SIGSYS
signal/signalfd: Remove __put_user from signalfd_copyinfo
signal/xtensa: Use force_sig_fault where appropriate
signal/xtensa: Consistenly use SIGBUS in do_unaligned_user
signal/um: Use force_sig_fault where appropriate
signal/sparc: Use force_sig_fault where appropriate
signal/sparc: Use send_sig_fault where appropriate
signal/sh: Use force_sig_fault where appropriate
signal/s390: Use force_sig_fault where appropriate
signal/riscv: Replace do_trap_siginfo with force_sig_fault
signal/riscv: Use force_sig_fault where appropriate
signal/parisc: Use force_sig_fault where appropriate
signal/parisc: Use force_sig_mceerr where appropriate
signal/openrisc: Use force_sig_fault where appropriate
signal/nios2: Use force_sig_fault where appropriate
Gaurav reported a perceived problem with TASK_PARKED, which turned out
to be a broken wait-loop pattern in __kthread_parkme(), but the
reported issue can (and does) in fact happen for states that do not do
condition based sleeps.
When the 'current->state = TASK_RUNNING' store of a previous
(concurrent) try_to_wake_up() collides with the setting of a 'special'
sleep state, we can loose the sleep state.
Normal condition based wait-loops are immune to this problem, but for
sleep states that are not condition based are subject to this problem.
There already is a fix for TASK_DEAD. Abstract that and also apply it
to TASK_STOPPED and TASK_TRACED, both of which are also without
condition based wait-loop.
Reported-by: Gaurav Kohli <gkohli@codeaurora.org>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Update the siginfo_layout function and enum siginfo_layout to represent
all of the possible field layouts of struct siginfo.
This allows the uses of siginfo_layout in um and arm64 where they are testing
for SIL_FAULT to be more accurate as this rules out the other cases.
Further this allows the switch statements on siginfo_layout to be simpler
if perhaps a little more wordy. Making it easier to understand what is
actually going on.
As SIL_FAULT_BNDERR and SIL_FAULT_PKUERR are never expected to appear
in signalfd just treat them as SIL_FAULT. To include them would take
20 extra bytes an pretty much fill up what is left of
signalfd_siginfo.
The only architecture that does not support SEGV_PKUERR is ia64 and
ia64 has not had 32bit support since some time in 2008. Therefore
copy_siginfo_to_user32 and copy_siginfo_from_user32 do not need to
include support for a missing SEGV_PKUERR.
Compile test on ia64.
With the recent architecture cleanups these si_codes are always
defined so there is no need to test for them.
After the last round of cleanups to siginfo.h SEGV_BNDERR is defined
on all architectures so testing to see if it is defined is unnecessary.
After more experience with the cases where no one the si_code of 0
is used both as a signal specific si_code, and as SI_USER it appears
that no one cares about the signal specific si_code case and the
good solution is to just fix the architectures by using
a different si_code.
In none of the conversations has anyone even suggested that
anything depends on the signal specific redefinition of SI_USER.
There are at least test cases that care when si_code as 0 does
not work as si_user.
So make things simple and keep the generic code from introducing
problems by removing the special casing of TRAP_FIXME and FPE_FIXME.
This will ensure the generic case of sending a signal with
kill will always set SI_USER and work.
The architecture specific, and signal specific overloads that
set si_code to 0 will now have problems with signalfd and
the 32bit compat versions of siginfo copying. At least
until they are fixed.
Now that every instance of struct siginfo is now initialized it is no
longer necessary to copy struct siginfo piece by piece to userspace
but instead the entire structure can be copied.
As well as making the code simpler and more efficient this means that
copy_sinfo_to_user no longer cares which union member of struct
siginfo is in use.
In practice this means that all 32bit architectures that define
FPE_FIXME will handle properly send SI_USER when kill(SIGFPE) is sent.
While still performing their historic architectural brokenness when 0
is used a floating pointer signal. This matches the current behavior
of 64bit architectures that define FPE_FIXME who get lucky and an
overloaded SI_USER has continuted to work through copy_siginfo_to_user
because the 8 byte si_addr occupies the same bytes in struct siginfo
as the 4 byte si_pid and the 4 byte si_uid.
Problematic architectures still need to fix their ABI so that signalfd
and 32bit compat code will work properly.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull general security layer updates from James Morris:
- Convert security hooks from list to hlist, a nice cleanup, saving
about 50% of space, from Sargun Dhillon.
- Only pass the cred, not the secid, to kill_pid_info_as_cred and
security_task_kill (as the secid can be determined from the cred),
from Stephen Smalley.
- Close a potential race in kernel_read_file(), by making the file
unwritable before calling the LSM check (vs after), from Kees Cook.
* 'next-general' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
security: convert security hooks to use hlist
exec: Set file unwritable before LSM check
usb, signal, security: only pass the cred, not the secid, to kill_pid_info_as_cred and security_task_kill
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"Nothing particularly stands out here, probably because people were
tied up with spectre/meltdown stuff last time around. Still, the main
pieces are:
- Rework of our CPU features framework so that we can whitelist CPUs
that don't require kpti even in a heterogeneous system
- Support for the IDC/DIC architecture extensions, which allow us to
elide instruction and data cache maintenance when writing out
instructions
- Removal of the large memory model which resulted in suboptimal
codegen by the compiler and increased the use of literal pools,
which could potentially be used as ROP gadgets since they are
mapped as executable
- Rework of forced signal delivery so that the siginfo_t is
well-formed and handling of show_unhandled_signals is consolidated
and made consistent between different fault types
- More siginfo cleanup based on the initial patches from Eric
Biederman
- Workaround for Cortex-A55 erratum #1024718
- Some small ACPI IORT updates and cleanups from Lorenzo Pieralisi
- Misc cleanups and non-critical fixes"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (70 commits)
arm64: uaccess: Fix omissions from usercopy whitelist
arm64: fpsimd: Split cpu field out from struct fpsimd_state
arm64: tlbflush: avoid writing RES0 bits
arm64: cmpxchg: Include linux/compiler.h in asm/cmpxchg.h
arm64: move percpu cmpxchg implementation from cmpxchg.h to percpu.h
arm64: cmpxchg: Include build_bug.h instead of bug.h for BUILD_BUG
arm64: lse: Include compiler_types.h and export.h for out-of-line LL/SC
arm64: fpsimd: include <linux/init.h> in fpsimd.h
drivers/perf: arm_pmu_platform: do not warn about affinity on uniprocessor
perf: arm_spe: include linux/vmalloc.h for vmap()
Revert "arm64: Revert L1_CACHE_SHIFT back to 6 (64-byte cache line size)"
arm64: cpufeature: Avoid warnings due to unused symbols
arm64: Add work around for Arm Cortex-A55 Erratum 1024718
arm64: Delay enabling hardware DBM feature
arm64: Add MIDR encoding for Arm Cortex-A55 and Cortex-A35
arm64: capabilities: Handle shared entries
arm64: capabilities: Add support for checks based on a list of MIDRs
arm64: Add helpers for checking CPU MIDR against a range
arm64: capabilities: Clean up midr range helpers
arm64: capabilities: Change scope of VHE to Boot CPU feature
syscall
Using this helper allows us to avoid the in-kernel call to the
compat_sys_sigaltstack() syscall.
This patch is part of a series which removes in-kernel calls to syscalls.
On this basis, the syscall entry path can be streamlined. For details, see
http://lkml.kernel.org/r/20180325162527.GA17492@light.dominikbrodowski.net
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
A similar but not fully equivalent code path is already open-coded
three times (in sys_rt_sigpending and in the two compat stubs), so
do it a fourth time here.
Currently, as reported by Eric, an invalid si_code value 0 is
passed in many signals delivered to userspace in response to faults
and other kernel errors. Typically 0 is passed when the fault is
insufficiently diagnosable or when there does not appear to be any
sensible alternative value to choose.
This appears to violate POSIX, and is intuitively wrong for at
least two reasons arising from the fact that 0 == SI_USER:
1) si_code is a union selector, and SI_USER (and si_code <= 0 in
general) implies the existence of a different set of fields
(siginfo._kill) from that which exists for a fault signal
(siginfo._sigfault). However, the code raising the signal
typically writes only the _sigfault fields, and the _kill
fields make no sense in this case.
Thus when userspace sees si_code == 0 (SI_USER) it may
legitimately inspect fields in the inactive union member _kill
and obtain garbage as a result.
There appears to be software in the wild relying on this,
albeit generally only for printing diagnostic messages.
2) Software that wants to be robust against spurious signals may
discard signals where si_code == SI_USER (or <= 0), or may
filter such signals based on the si_uid and si_pid fields of
siginfo._sigkill. In the case of fault signals, this means
that important (and usually fatal) error conditions may be
silently ignored.
In practice, many of the faults for which arm64 passes si_code == 0
are undiagnosable conditions such as exceptions with syndrome
values in ESR_ELx to which the architecture does not yet assign any
meaning, or conditions indicative of a bug or error in the kernel
or system and thus that are unrecoverable and should never occur in
normal operation.
The approach taken in this patch is to translate all such
undiagnosable or "impossible" synchronous fault conditions to
SIGKILL, since these are at least probably localisable to a single
process. Some of these conditions should really result in a kernel
panic, but due to the lack of diagnostic information it is
difficult to be certain: this patch does not add any calls to
panic(), but this could change later if justified.
Although si_code will not reach userspace in the case of SIGKILL,
it is still desirable to pass a nonzero value so that the common
siginfo handling code can detect incorrect use of si_code == 0
without false positives. In this case the si_code dependent
siginfo fields will not be correctly initialised, but since they
are not passed to userspace I deem this not to matter.
A few faults can reasonably occur in realistic userspace scenarios,
and _should_ raise a regular, handleable (but perhaps not
ignorable/blockable) signal: for these, this patch attempts to
choose a suitable standard si_code value for the raised signal in
each case instead of 0.
arm64 was the only arch to define a BUS_FIXME code, so after this
patch nobody defines it. This patch therefore also removes the
relevant code from siginfo_layout().
Cc: James Morse <james.morse@arm.com>
Reported-by: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
commit d178bc3a708f39cbfefc3fab37032d3f2511b4ec ("user namespace: usb:
make usb urbs user namespace aware (v2)") changed kill_pid_info_as_uid
to kill_pid_info_as_cred, saving and passing a cred structure instead of
uids. Since the secid can be obtained from the cred, drop the secid fields
from the usb_dev_state and async structures, and drop the secid argument to
kill_pid_info_as_cred. Replace the secid argument to security_task_kill
with the cred. Update SELinux, Smack, and AppArmor to use the cred, which
avoids the need for Smack and AppArmor to use a secid at all in this hook.
Further changes to Smack might still be required to take full advantage of
this change, since it should now be possible to perform capability
checking based on the supplied cred. The changes to Smack and AppArmor
have only been compile-tested.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Paul Moore <paul@paul-moore.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: John Johansen <john.johansen@canonical.com>
Signed-off-by: James Morris <james.morris@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
Pull livepatching updates from Jiri Kosina:
- handle 'infinitely'-long sleeping tasks, from Miroslav Benes
- remove 'immediate' feature, as it turns out it doesn't provide the
originally expected semantics, and brings more issues than value
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: add locking to force and signal functions
livepatch: Remove immediate feature
livepatch: force transition to finish
livepatch: send a fake signal to all blocking tasks
There are so many places that build struct siginfo by hand that at
least one of them is bound to get it wrong. A handful of cases in the
kernel arguably did just that when using the errno field of siginfo to
pass no errno values to userspace. The usage is limited to a single
si_code so at least does not mess up anything else.
Encapsulate this questionable pattern in a helper function so
that the userspace ABI is preserved.
Update all of the places that use this pattern to use the new helper
function.
The helpers added are:
send_sig_mceerr
force_sig_mceerr
force_sig_bnderr
force_sig_pkuerr
Filling out siginfo properly can ge tricky. Especially for these
specialized cases where the temptation is to share code with other
cases which use a different subset of siginfo fields. Unfortunately
that code sharing frequently results in bugs with the wrong siginfo
fields filled in, and makes it harder to verify that the siginfo
structure was properly initialized.
Provide these helpers instead that get all of the details right, and
guarantee that siginfo is properly initialized.
send_sig_mceerr and force_sig_mceer are a little special as two si
codes BUS_MCEERR_AO and BUS_MCEER_AR both use the same extended
signinfo layout.
The vast majority of signals sent from architecture specific code are
simple faults. Encapsulate this reality with two helper functions so
that the nit-picky implementation of preparing a siginfo does not need
to be repeated many times on each architecture.
As only some architectures support the trapno field, make the trapno
arguement only present on those architectures.
Similary as ia64 has three fields: imm, flags, and isr that
are specific to it. Have those arguments always present on ia64
and no where else.
This ensures the architecture specific code always remembers which
fields it needs to pass into the siginfo structure.
The siginfo structure has all manners of holes with the result that a
structure initializer is not guaranteed to initialize all of the bits.
As we have to copy the structure to userspace don't even try to use
a structure initializer. Instead use clear_siginfo followed by initializing
selected fields. This gives a guarantee that uninitialized kernel memory
is not copied to userspace.
Among the existing architecture specific versions of
copy_siginfo_to_user32 there are several different implementation
problems. Some architectures fail to handle all of the cases in in
the siginfo union. Some architectures perform a blind copy of the
siginfo union when the si_code is negative. A blind copy suggests the
data is expected to be in 32bit siginfo format, which means that
receiving such a signal via signalfd won't work, or that the data is
in 64bit siginfo and the code is copying nonsense to userspace.
Create a single instance of copy_siginfo_to_user32 that all of the
architectures can share, and teach it to handle all of the cases in
the siginfo union correctly, with the assumption that siginfo is
stored internally to the kernel is 64bit siginfo format.
A special case is made for x86 x32 format. This is needed as presence
of both x32 and ia32 on x86_64 results in two different 32bit signal
formats. By allowing this small special case there winds up being
exactly one code base that needs to be maintained between all of the
architectures. Vastly increasing the testing base and the chances of
finding bugs.
As the x86 copy of copy_siginfo_to_user32 the call of the x86
signal_compat_build_tests were moved into sigaction_compat_abi, so
that they will keep running.
The new unified copy_siginfo_from_user32 takes care of this.
