commit f44310b98ddb7f0d06550d73ed67df5865e3eda5 upstream.
I get the following warning every day with v3.7, once or
twice a day:
[ 2235.186027] WARNING: at /mnt/sda7/kernel/linux/arch/x86/kernel/apic/ipi.c:109 default_send_IPI_mask_logical+0x2f/0xb8()
As explained by Linus as well:
| Once we've done the "list_add_rcu()" to add it to the
| queue, we can have (another) IPI to the target CPU that can
| now see it and clear the mask.
| So by the time we get to actually send the IPI, the mask might
| have been cleared by another IPI.
This patch also fixes a system hang problem, if the data->cpumask
gets cleared after passing this point:
if (WARN_ONCE(!mask, "empty IPI mask"))
return;
then the problem in commit 83d349f35e1a ("x86: don't send an IPI to
the empty set of CPU's") will happen again.
Signed-off-by: Wang YanQing <udknight@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Jan Beulich <jbeulich@suse.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: peterz@infradead.org
Cc: mina86@mina86.org
Cc: srivatsa.bhat@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/20130126075357.GA3205@udknight
[ Tidied up the changelog and the comment in the code. ]
There is no user of those APIs anymore, just remove it.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Cc: ralf@linux-mips.org
Cc: sshtylyov@mvista.com
Cc: david.daney@cavium.com
Cc: nikunj@linux.vnet.ibm.com
Cc: paulmck@linux.vnet.ibm.com
Cc: axboe@kernel.dk
Link: http://lkml.kernel.org/r/1338275765-3217-11-git-send-email-yong.zhang0@gmail.com
Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Will replace the misnomed cpu_idle_wait() function which is copied a
gazillion times all over arch/*
Link: http://lkml.kernel.org/r/20120507175652.049316594@linutronix.de
percpu areas are already allocated during boot for each possible cpu.
percpu idle threads can be considered as an extension of the percpu areas,
and allocate them for each possible cpu during boot.
This will eliminate the need for workqueue based idle thread allocation.
In future we can move the idle thread area into the percpu area too.
[ tglx: Moved the loop into smpboot.c and added an error check when
the init code failed to allocate an idle thread for a cpu which
should be onlined ]
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: venki@google.com
Link: http://lkml.kernel.org/r/1334966930.28674.245.camel@sbsiddha-desk.sc.intel.com
Add the on_each_cpu_cond() function that wraps on_each_cpu_mask() and
calculates the cpumask of cpus to IPI by calling a function supplied as a
parameter in order to determine whether to IPI each specific cpu.
The function works around allocation failure of cpumask variable in
CONFIG_CPUMASK_OFFSTACK=y by itereating over cpus sending an IPI a time
via smp_call_function_single().
The function is useful since it allows to seperate the specific code that
decided in each case whether to IPI a specific cpu for a specific request
from the common boilerplate code of handling creating the mask, handling
failures etc.
[akpm@linux-foundation.org: s/gfpflags/gfp_flags/]
[akpm@linux-foundation.org: avoid double-evaluation of `info' (per Michal), parenthesise evaluation of `cond_func']
[akpm@linux-foundation.org: s/CPU/CPUs, use all 80 cols in comment]
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Avi Kivity <avi@redhat.com>
Acked-by: Michal Nazarewicz <mina86@mina86.org>
Cc: Kosaki Motohiro <kosaki.motohiro@gmail.com>
Cc: Milton Miller <miltonm@bga.com>
Reviewed-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
We have lots of infrastructure in place to partition multi-core systems
such that we have a group of CPUs that are dedicated to specific task:
cgroups, scheduler and interrupt affinity, and cpuisol= boot parameter.
Still, kernel code will at times interrupt all CPUs in the system via IPIs
for various needs. These IPIs are useful and cannot be avoided
altogether, but in certain cases it is possible to interrupt only specific
CPUs that have useful work to do and not the entire system.
This patch set, inspired by discussions with Peter Zijlstra and Frederic
Weisbecker when testing the nohz task patch set, is a first stab at trying
to explore doing this by locating the places where such global IPI calls
are being made and turning the global IPI into an IPI for a specific group
of CPUs. The purpose of the patch set is to get feedback if this is the
right way to go for dealing with this issue and indeed, if the issue is
even worth dealing with at all. Based on the feedback from this patch set
I plan to offer further patches that address similar issue in other code
paths.
This patch creates an on_each_cpu_mask() and on_each_cpu_cond()
infrastructure API (the former derived from existing arch specific
versions in Tile and Arm) and uses them to turn several global IPI
invocation to per CPU group invocations.
Core kernel:
on_each_cpu_mask() calls a function on processors specified by cpumask,
which may or may not include the local processor.
You must not call this function with disabled interrupts or from a
hardware interrupt handler or from a bottom half handler.
arch/arm:
Note that the generic version is a little different then the Arm one:
1. It has the mask as first parameter
2. It calls the function on the calling CPU with interrupts disabled,
but this should be OK since the function is called on the other CPUs
with interrupts disabled anyway.
arch/tile:
The API is the same as the tile private one, but the generic version
also calls the function on the with interrupts disabled in UP case
This is OK since the function is called on the other CPUs
with interrupts disabled.
Reviewed-by: Christoph Lameter <cl@linux.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
The changed files were only including linux/module.h for the
EXPORT_SYMBOL infrastructure, and nothing else. Revector them
onto the isolated export header for faster compile times.
Nothing to see here but a whole lot of instances of:
-#include <linux/module.h>
+#include <linux/export.h>
This commit is only changing the kernel dir; next targets
will probably be mm, fs, the arch dirs, etc.
enabling interrupts
There is a problem that kdump(2nd kernel) sometimes hangs up due
to a pending IPI from 1st kernel. Kernel panic occurs because IPI
comes before call_single_queue is initialized.
To fix the crash, rename init_call_single_data() to call_function_init()
and call it in start_kernel() so that call_single_queue can be
initialized before enabling interrupts.
The details of the crash are:
(1) 2nd kernel boots up
(2) A pending IPI from 1st kernel comes when irqs are first enabled
in start_kernel().
(3) Kernel tries to handle the interrupt, but call_single_queue
is not initialized yet at this point. As a result, in the
generic_smp_call_function_single_interrupt(), NULL pointer
dereference occurs when list_replace_init() tries to access
&q->list.next.
Therefore this patch changes the name of init_call_single_data()
to call_function_init() and calls it before local_irq_enable()
in start_kernel().
Signed-off-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: kexec@lists.infradead.org
Link: http://lkml.kernel.org/r/D6CBEE2F420741indou.takao@jp.fujitsu.com
Move setup_nr_cpu_ids(), smp_init() and some other SMP boot parameter
setup functions from init/main.c to kenrel/smp.c, saves some #ifdef
CONFIG_SMP.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Use the newly added smp_call_func_t in smp_call_function_interrupt for
the func variable, and make the comment above the WARN more assertive
and explicit. Also, func is a function pointer and does not need an
offset, so use %pf not %pS.
Signed-off-by: Milton Miller <miltonm@bga.com>
Mike Galbraith reported finding a lockup ("perma-spin bug") where the
cpumask passed to smp_call_function_many was cleared by other cpu(s)
while a cpu was preparing its call_data block, resulting in no cpu to
clear the last ref and unlock the block.
Having cpus clear their bit asynchronously could be useful on a mask of
cpus that might have a translation context, or cpus that need a push to
complete an rcu window.
Instead of adding a BUG_ON and requiring yet another cpumask copy, just
detect the race and handle it.
Note: arch_send_call_function_ipi_mask must still handle an empty
cpumask because the data block is globally visible before the that arch
callback is made. And (obviously) there are no guarantees to which cpus
are notified if the mask is changed during the call; only cpus that were
online and had their mask bit set during the whole call are guaranteed
to be called.
Reported-by: Mike Galbraith <efault@gmx.de>
Reported-by: Jan Beulich <JBeulich@novell.com>
Acked-by: Jan Beulich <jbeulich@novell.com>
Cc: stable@kernel.org
Paul McKenney's review pointed out two problems with the barriers in the
2.6.38 update to the smp call function many code.
First, a barrier that would force the func and info members of data to
be visible before their consumption in the interrupt handler was
missing. This can be solved by adding a smp_wmb between setting the
func and info members and setting setting the cpumask; this will pair
with the existing and required smp_rmb ordering the cpumask read before
the read of refs. This placement avoids the need a second smp_rmb in
the interrupt handler which would be executed on each of the N cpus
executing the call request. (I was thinking this barrier was present
but was not).
Second, the previous write to refs (establishing the zero that we the
interrupt handler was testing from all cpus) was performed by a third
party cpu. This would invoke transitivity which, as a recient or
concurrent addition to memory-barriers.txt now explicitly states, would
require a full smp_mb().
However, we know the cpumask will only be set by one cpu (the data
owner) and any preivous iteration of the mask would have cleared by the
reading cpu. By redundantly writing refs to 0 on the owning cpu before
the smp_wmb, the write to refs will follow the same path as the writes
that set the cpumask, which in turn allows us to keep the barrier in the
interrupt handler a smp_rmb instead of promoting it to a smp_mb (which
will be be executed by N cpus for each of the possible M elements on the
list).
I moved and expanded the comment about our (ab)use of the rcu list
primitives for the concurrent walk earlier into this function. I
considered moving the first two paragraphs to the queue list head and
lock, but felt it would have been too disconected from the code.
Cc: Paul McKinney <paulmck@linux.vnet.ibm.com>
Cc: stable@kernel.org (2.6.32 and later)
Peter pointed out there was nothing preventing the list_del_rcu in
smp_call_function_interrupt from running before the list_add_rcu in
smp_call_function_many.
Fix this by not setting refs until we have gotten the lock for the list.
Take advantage of the wmb in list_add_rcu to save an explicit additional
one.
I tried to force this race with a udelay before the lock & list_add and
by mixing all 64 online cpus with just 3 random cpus in the mask, but
was unsuccessful. Still, inspection shows a valid race, and the fix is
a extension of the existing protection window in the current code.
Cc: stable@kernel.org (v2.6.32 and later)
Reported-by: Peter Zijlstra <peterz@infradead.org>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
smp: Allow on_each_cpu() to be called while early_boot_irqs_disabled status to init/main.c
lockdep: Move early boot local IRQ enable/disable status to init/main.c
We have to test the cpu mask in the interrupt handler before checking the
refs, otherwise we can start to follow an entry before its deleted and
find it partially initailzed for the next trip. Presently we also clear
the cpumask bit before executing the called function, which implies
getting write access to the line. After the function is called we then
decrement refs, and if they go to zero we then unlock the structure.
However, this implies getting write access to the call function data
before and after another the function is called. If we can assert that no
smp_call_function execution function is allowed to enable interrupts, then
we can move both writes to after the function is called, hopfully allowing
both writes with one cache line bounce.
On a 256 thread system with a kernel compiled for 1024 threads, the time
to execute testcase in the "smp_call_function_many race" changelog was
reduced by about 30-40ms out of about 545 ms.
I decided to keep this as WARN because its now a buggy function, even
though the stack trace is of no value -- a simple printk would give us the
information needed.
Raw data:
Without patch:
ipi_test startup took 1219366ns complete 539819014ns total 541038380ns
ipi_test startup took 1695754ns complete 543439872ns total 545135626ns
ipi_test startup took 7513568ns complete 539606362ns total 547119930ns
ipi_test startup took 13304064ns complete 533898562ns total 547202626ns
ipi_test startup took 8668192ns complete 544264074ns total 552932266ns
ipi_test startup took 4977626ns complete 548862684ns total 553840310ns
ipi_test startup took 2144486ns complete 541292318ns total 543436804ns
ipi_test startup took 21245824ns complete 530280180ns total 551526004ns
With patch:
ipi_test startup took 5961748ns complete 500859628ns total 506821376ns
ipi_test startup took 8975996ns complete 495098924ns total 504074920ns
ipi_test startup took 19797750ns complete 492204740ns total 512002490ns
ipi_test startup took 14824796ns complete 487495878ns total 502320674ns
ipi_test startup took 11514882ns complete 494439372ns total 505954254ns
ipi_test startup took 8288084ns complete 502570774ns total 510858858ns
ipi_test startup took 6789954ns complete 493388112ns total 500178066ns
#include <linux/init.h>
#include <linux/sched.h> /* sched clock */
#define ITERATIONS 100
static void do_nothing_ipi(void *dummy)
static void do_ipis(struct work_struct *dummy)
int i;
for (i = 0; i < ITERATIONS; i++)
smp_call_function(do_nothing_ipi, NULL, 1);
printk(KERN_DEBUG "cpu %d finished\n", smp_processor_id());
static struct work_struct work[NR_CPUS];
static int __init testcase_init(void)
int cpu;
u64 start, started, done;
start = local_clock();
for_each_online_cpu(cpu) {
INIT_WORK(&work[cpu], do_ipis);
schedule_work_on(cpu, &work[cpu]);
started = local_clock();
flush_work(&work[cpu]);
done = local_clock();
pr_info("ipi_test startup took %lldns complete %lldns total %lldns\n",
started-start, done-started, done-start);
return 0;
static void __exit testcase_exit(void)
module_init(testcase_init)
module_exit(testcase_exit)
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Anton Blanchard");
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
I noticed a failure where we hit the following WARN_ON in
generic_smp_call_function_interrupt:
if (!cpumask_test_and_clear_cpu(cpu, data->cpumask))
continue;
data->csd.func(data->csd.info);
refs = atomic_dec_return(&data->refs);
WARN_ON(refs < 0); <-------------------------
We atomically tested and cleared our bit in the cpumask, and yet the
number of cpus left (ie refs) was 0. How can this be?
It turns out commit 54fdade1c3332391948ec43530c02c4794a38172
("generic-ipi: make struct call_function_data lockless") is at fault. It
removes locking from smp_call_function_many and in doing so creates a
rather complicated race.
The problem comes about because:
- The smp_call_function_many interrupt handler walks call_function.queue
without any locking.
- We reuse a percpu data structure in smp_call_function_many.
- We do not wait for any RCU grace period before starting the next
Imagine a scenario where CPU A does two smp_call_functions back to back,
and CPU B does an smp_call_function in between. We concentrate on how CPU
C handles the calls:
CPU A CPU B CPU C CPU D
smp_call_function
walks
call_function.queue sees
data from CPU A on list
smp_call_function
walks
(stale) CPU A on list
smp_call_function int
clears last ref on A
list_del_rcu, unlock
smp_call_function reuses
percpu *data A
data->cpumask sees and
clears bit in cpumask
might be using old or new fn!
decrements refs below 0
set data->refs (too late!)
The important thing to note is since the interrupt handler walks a
potentially stale call_function.queue without any locking, then another
cpu can view the percpu *data structure at any time, even when the owner
is in the process of initialising it.
The following test case hits the WARN_ON 100% of the time on my PowerPC
box (having 128 threads does help :)
int i;
int cpu;
return 0;
I tried to fix it by ordering the read and the write of ->cpumask and
->refs. In doing so I missed a critical case but Paul McKenney was able
to spot my bug thankfully :) To ensure we arent viewing previous
iterations the interrupt handler needs to read ->refs then ->cpumask then
->refs _again_.
Thanks to Milton Miller and Paul McKenney for helping to debug this issue.
[miltonm@bga.com: add WARN_ON and BUG_ON, remove extra read of refs before initial read of mask that doesn't help (also noted by Peter Zijlstra), adjust comments, hopefully clarify scenario ]
[miltonm@bga.com: remove excess tests]
Cc: <stable@kernel.org> [2.6.32+]
to init/main.c
percpu may end up calling vfree() during early boot which in
turn may call on_each_cpu() for TLB flushes. The function of
on_each_cpu() can be done safely while IRQ is disabled during
early boot but it assumed that the function is always called
with local IRQ enabled which ended up enabling local IRQ
prematurely during boot and triggering a couple of warnings.
This patch updates on_each_cpu() and smp_call_function_many()
such on_each_cpu() can be used safely while
early_boot_irqs_disabled is set.
Acked-by: Pekka Enberg <penberg@kernel.org>
LKML-Reference: <20110120110713.GC6036@htj.dyndns.org>
Reported-by: Ingo Molnar <mingo@elte.hu>
For arch which needs USE_GENERIC_SMP_HELPERS, it has to select
USE_GENERIC_SMP_HELPERS, rather than leaving a choice to user, since they
don't provide their own implementions.
Also, move on_each_cpu() to kernel/smp.c, it is strange to put it in
kernel/softirq.c.
For arch which doesn't use USE_GENERIC_SMP_HELPERS, e.g. blackfin, only
on_each_cpu() is compiled.
Signed-off-by: Amerigo Wang <amwang@redhat.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Typedef the pointer to the function to be called by smp_call_function() and
friends:
typedef void (*smp_call_func_t)(void *info);
as it is used in a fair number of places.
cc: linux-arch@vger.kernel.org
Just got my 6 way machine to a state where cpu 0 is in an
endless loop within __smp_call_function_single.
All other cpus are idle.
The call trace on cpu 0 looks like this:
scheduler_tick
update_process_times
tick_sched_timer
__run_hrtimer
hrtimer_interrupt
clock_comparator_work
do_extint
ext_int_handler
----> timer irq
cpu_idle
__smp_call_function_single() got called from nohz_balancer_kick()
(inlined) with the remote cpu being 1, wait being 0 and the per
cpu variable remote_sched_softirq_cb (call_single_data) of the
current cpu (0).
Then it loops forever when it tries to grab the lock of the
call_single_data, since it is already locked and enqueued on cpu 0.
My theory how this could have happened: for some reason the
scheduler decided to call __smp_call_function_single() on it's own
cpu, and sends an IPI to itself. The interrupt stays pending
since IRQs are disabled. If then the hypervisor schedules the
cpu away it might happen that upon rescheduling both the IPI and
the timer IRQ are pending. If then interrupts are enabled again
it depends which one gets scheduled first.
If the timer interrupt gets delivered first we end up with the
local deadlock as seen in the calltrace above.
Let's make __smp_call_function_single() check if the target cpu is
the current cpu and execute the function immediately just like
smp_call_function_single does. That should prevent at least the
scenario described here.
It might also be that the scheduler is not supposed to call
__smp_call_function_single with the remote cpu being the current
cpu, but that is a different issue.
Acked-by: Jens Axboe <jaxboe@fusionio.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <20100910114729.GB2827@osiris.boeblingen.de.ibm.com>
By the previous modification, the cpu notifier can return encapsulate
errno value. This converts the cpu notifiers for kernel/*.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
IPI data
The smp ipi data is passed around and given write access by
other cpus and should be separated from per-cpu data consumed by
this cpu.
Looking for hot lines, I saw call_function_data shared with
tick_cpu_sched.
Acked-by: Anton Blanchard <anton@samba.org>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Cc: : Nick Piggin <npiggin@suse.de>
LKML-Reference: <20100118020051.GR12666@kryten>
The change in acpi_cpufreq to use smp_call_function_any causes a warning
when it is called since the function erroneously passes the cpu id to
cpumask_of_node rather than the node that the cpu is on. Fix this.
cpumask_of_node(3): node > nr_node_ids(1)
Pid: 1, comm: swapper Not tainted 2.6.33-rc3-00097-g2c1f189 #223
Call Trace:
[<ffffffff81028bb3>] cpumask_of_node+0x23/0x58
[<ffffffff81061f51>] smp_call_function_any+0x65/0xfa
[<ffffffff810160d1>] ? do_drv_read+0x0/0x2f
[<ffffffff81015fba>] get_cur_val+0xb0/0x102
[<ffffffff81016080>] get_cur_freq_on_cpu+0x74/0xc5
[<ffffffff810168a7>] acpi_cpufreq_cpu_init+0x417/0x515
[<ffffffff81562ce9>] ? __down_write+0xb/0xd
[<ffffffff8148055e>] cpufreq_add_dev+0x278/0x922
Signed-off-by: David John <davidjon@xenontk.org>
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits)
clockevents: Convert to raw_spinlock
clockevents: Make tick_device_lock static
debugobjects: Convert to raw_spinlocks
perf_event: Convert to raw_spinlock
hrtimers: Convert to raw_spinlocks
genirq: Convert irq_desc.lock to raw_spinlock
smp: Convert smplocks to raw_spinlocks
rtmutes: Convert rtmutex.lock to raw_spinlock
sched: Convert pi_lock to raw_spinlock
sched: Convert cpupri lock to raw_spinlock
sched: Convert rt_runtime_lock to raw_spinlock
sched: Convert rq->lock to raw_spinlock
plist: Make plist debugging raw_spinlock aware
bkl: Fixup core_lock fallout
locking: Cleanup the name space completely
locking: Further name space cleanups
alpha: Fix fallout from locking changes
locking: Implement new raw_spinlock
locking: Convert raw_rwlock functions to arch_rwlock
locking: Convert raw_rwlock to arch_rwlock
Use smp_processor_id() instead of get_cpu() and put_cpu() in
generic_smp_call_function_interrupt(), It's no need to disable preempt,
because we must call generic_smp_call_function_interrupt() with interrupts
disabled.
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Andrew points out that acpi-cpufreq uses cpumask_any, when it really
would prefer to use the same CPU if possible (to avoid an IPI). In
general, this seems a good idea to offer.
[ tglx: Documented selection preference and Inlined the UP case to
avoid the copy of smp_call_function_single() and the extra
EXPORT ]
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Zhao Yakui <yakui.zhao@intel.com>
Cc: Dave Jones <davej@redhat.com>
Cc: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
After commit:8969a5ede0f9e17da4b943712429aef2c9bcd82b
"generic-ipi: remove kmalloc()", wait = 0 can be guaranteed.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Cc: Nick Piggin <npiggin@suse.de>
LKML-Reference: <1256210374-25354-1-git-send-email-sheng@linux.intel.com>
Now everyone is converted to arch_send_call_function_ipi_mask, remove
the shim and the #defines.
This patch can remove spinlock from struct call_function_data, the
reasons are below:
1: add a new interface for cpumask named cpumask_test_and_clear_cpu(),
it can atomically test and clear specific cpu, we can use it instead
of cpumask_test_cpu() and cpumask_clear_cpu() and no need data->lock
to protect those in generic_smp_call_function_interrupt().
2: in smp_call_function_many(), after csd_lock() return, the current's
cfd_data is deleted from call_function list, so it not have race
between other cpus, then cfs_data is only used in
smp_call_function_many() that must disable preemption and not from
a hardware interrupthandler or from a bottom half handler to call,
only the correspond cpu can use it, so it not have race in current
cpu, no need cfs_data->lock to protect it.
3: after 1 and 2, cfs_data->lock is only use to protect cfs_data->refs in
generic_smp_call_function_interrupt(), so we can define cfs_data->refs
to atomic_t, and no need cfs_data->lock any more.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
[akpm@linux-foundation.org: use atomic_dec_return()]
Reason: Change to is_new_memtype_allowed() in x86/urgent
Resolved semantic conflicts in:
arch/x86/mm/pat.c
arch/x86/mm/ioremap.c
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
disabled
Because of deadlock possiblities smp_call_function() is not allowed to
be called with interrupts disabled. Add an exception for the cpu not
yet online, as no one else can send smp call function interrupt to this
cpu that is not yet online and as such deadlock condition is not possible.
Acked-by: Nick Piggin <npiggin@suse.de>
Use CONFIG_HOTPLUG_CPU, not CONFIG_CPU_HOTPLUG
When hot-unpluging a cpu, it will leak memory allocated at cpu hotplug,
but only if CPUMASK_OFFSTACK=y, which is default to n.
The bug was introduced by 8969a5ede0f9e17da4b943712429aef2c9bcd82b
("generic-ipi: remove kmalloc()").
These are defined as static cpumask_var_t so if MAXSMP is not used,
they are cleared already. Avoid surprises when MAXSMP is enabled.
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
Do not output smp-call related warnings in the oops/panic codepath.
Reported-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <49B91A7E.76E4.0078.0@novell.com>
Andrew pointed out that there's some small amount of
style rot in kernel/smp.c.
Clean it up.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Oleg noticed that we don't strictly need CSD_FLAG_WAIT, rework
the code so that we can use CSD_FLAG_LOCK for both purposes.
Remove the use of kmalloc() from the smp_call_function_*()
calls.
Steven's generic-ipi patch (d7240b98: generic-ipi: use per cpu
data for single cpu ipi calls) started the discussion on the use
of kmalloc() in this code and fixed the
smp_call_function_single(.wait=0) fallback case.
In this patch we complete this by also providing means for the
_many() call, which fully removes the need for kmalloc() in this
code.
The problem with the _many() call is that other cpus might still
be observing our entry when we're done with it. It solved this
by dynamically allocating data elements and RCU-freeing it.
We solve it by using a single per-cpu entry which provides
static storage and solves one half of the problem (avoiding
referencing freed data).
The other half, ensuring the queue iteration it still possible,
is done by placing re-used entries at the head of the list. This
means that if someone was still iterating that entry when it got
moved, he will now re-visit the entries on the list he had
already seen, but avoids skipping over entries like would have
happened had we placed the new entry at the end.
Furthermore, visiting entries twice is not a problem, since we
remove our cpu from the entry's cpumask once its called.
Many thanks to Oleg for his suggestions and him poking holes in
my earlier attempts.
Simplify the barriers in generic remote function call interrupt
code.
Firstly, just unconditionally take the lock and check the list
in the generic_call_function_single_interrupt IPI handler. As
we've just taken an IPI here, the chances are fairly high that
there will be work on the list for us, so do the locking
unconditionally. This removes the tricky lockless list_empty
check and dubious barriers. The change looks bigger than it is
because it is just removing an outer loop.
Secondly, clarify architecture specific IPI locking rules.
Generic code has no tools to impose any sane ordering on IPIs if
they go outside normal cache coherency, ergo the arch code must
make them appear to obey cache coherency as a "memory operation"
to initiate an IPI, and a "memory operation" to receive one.
This way at least they can be reasoned about in generic code,
and smp_mb used to provide ordering.
The combination of these two changes means that explict barriers
can be taken out of queue handling for the single case -- shared
data is explicitly locked, and ipi ordering must conform to
that, so no barriers needed. An extra barrier is needed in the
many handler, so as to ensure we load the list element after the
IPI is received.
Does any architecture actually *need* these barriers? For the
initiator I could see it, but for the handler I would be
surprised. So the other thing we could do for simplicity is just
to require that, rather than just matching with cache coherency,
we just require a full barrier before generating an IPI, and
after receiving an IPI. In which case, the smp_mb()s can go
away. But just for now, we'll be on the safe side and use the
barriers (they're in the slow case anyway).
Signed-off-by: Nick Piggin <npiggin@suse.de>
The smp_call_function can be passed a wait parameter telling it to
wait for all the functions running on other CPUs to complete before
returning, or to return without waiting. Unfortunately, this is
currently just a suggestion and not manditory. That is, the
smp_call_function can decide not to return and wait instead.
The reason for this is because it uses kmalloc to allocate storage
to send to the called CPU and that CPU will free it when it is done.
But if we fail to allocate the storage, the stack is used instead.
This means we must wait for the called CPU to finish before
continuing.
Unfortunatly, some callers do no abide by this hint and act as if
the non-wait option is mandatory. The MTRR code for instance will
deadlock if the smp_call_function is set to wait. This is because
the smp_call_function will wait for the other CPUs to finish their
called functions, but those functions are waiting on the caller to
continue.
This patch changes the generic smp_call_function code to use per cpu
variables if the allocation of the data fails for a single CPU call. The
smp_call_function_many will fall back to the smp_call_function_single
if it fails its alloc. The smp_call_function_single is modified
to not force the wait state.
Since we now are using a single data per cpu we must synchronize the
callers to prevent a second caller modifying the data before the
first called IPI functions complete. To do so, I added a flag to
the call_single_data called CSD_FLAG_LOCK. When the single CPU is
called (which can be called when a many call fails an alloc), we
set the LOCK bit on this per cpu data. When the caller finishes
it clears the LOCK bit.
The caller must wait till the LOCK bit is cleared before setting
it. When it is cleared, there is no IPI function using it.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Impact: cleanup
In future, all cpumask ops will only be valid (in general) for bit
numbers < nr_cpu_ids. So use that instead of NR_CPUS in iterators
and other comparisons.
This is always safe: no cpu number can be >= nr_cpu_ids, and
nr_cpu_ids is initialized to NR_CPUS at boot.
Signed-off-by: Mike Travis <travis@sgi.com>
Acked-by: James Morris <jmorris@namei.org>
Cc: Eric Biederman <ebiederm@xmission.com>
Impact: new API to reduce stack usage
We're weaning the core code off handing cpumask's around on-stack.
This introduces arch_send_call_function_ipi_mask().
Impact: Implementation change to remove cpumask_t from stack.
Actually change smp_call_function_mask() to smp_call_function_many().
We avoid cpumasks on the stack in this version.
(S390 has its own version, but that's going away apparently).
We have to do some dancing to figure out if 0 or 1 other cpus are in
the mask supplied and the online mask without allocating a tmp
cpumask. It's still fairly cheap.
We allocate the cpumask at the end of the call_function_data
structure: if allocation fails we fallback to smp_call_function_single
rather than using the baroque quiescing code (which needs a cpumask on
stack).
(Thanks to Hiroshi Shimamoto for spotting several bugs in previous versions!)
Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
Cc: npiggin@suse.de
Cc: axboe@kernel.dk
smp_mb() is needed (to make the memory operations visible globally) before
sending the ipi on the sender and the receiver (on Alpha atleast) needs
smp_read_barrier_depends() in the handler before reading the call_single_queue
list in a lock-free fashion.
On x86, x2apic mode register accesses for sending IPI's don't have serializing
semantics. So the need for smp_mb() before sending the IPI becomes more
critical in x2apic mode.
Remove the unnecessary smp_mb() in csd_flag_wait(), as the presence of that
smp_mb() doesn't mean anything on the sender, when the ipi receiver is not
doing any thing special (like memory fence) after clearing the CSD_FLAG_WAIT.
Have smp_call_function_single() return invalid CPU indicies and return
-ENXIO. This function is already executed inside a
get_cpu()..put_cpu() which locks out CPU removal, so rather than
having the higher layers doing another layer of locking to guard
against unplugged CPUs do the test here.
> > Nick Piggin (1):
> > generic-ipi: fix stack and rcu interaction bug in
> I'm still not 100% sure that I have this patch right... I might have seen
> a lockup trace implicating the smp call function path... which may have
> been due to some other problem or a different bug in the new call function
> code, but if some more people can take a look at it before merging?
OK indeed it did have a couple of bugs. Firstly, I wasn't freeing the
data properly in the alloc && wait case. Secondly, I wasn't resetting
CSD_FLAG_WAIT in the for each cpu loop (so only the first CPU would
wait).
After those fixes, the patch boots and runs with the kmalloc commented
out (so it always executes the slowpath).
* Venki Pallipadi <venkatesh.pallipadi@intel.com> wrote:
> Found a OOPS on a big SMP box during an overnight reboot test with
> upstream git.
> Suresh and I looked at the oops and looks like the root cause is in
> generic_smp_call_function_interrupt() and smp_call_function_mask() with
> wait parameter.
> The actual oops looked like
> [ 11.277260] BUG: unable to handle kernel paging request at ffff8802ffffffff
> [ 11.277815] IP: [<ffff8802ffffffff>] 0xffff8802ffffffff
> [ 11.278155] PGD 202063 PUD 0
> [ 11.278576] Oops: 0010 [1] SMP
> [ 11.279006] CPU 5
> [ 11.279336] Modules linked in:
> [ 11.279752] Pid: 0, comm: swapper Not tainted 2.6.27-rc2-00020-g685d87f #290
> [ 11.280039] RIP: 0010:[<ffff8802ffffffff>] [<ffff8802ffffffff>] 0xffff8802ffffffff
> [ 11.280692] RSP: 0018:ffff88027f1f7f70 EFLAGS: 00010086
> [ 11.280976] RAX: 00000000ffffffff RBX: 0000000000000000 RCX: 0000000000000000
> [ 11.281264] RDX: 0000000000004f4e RSI: 0000000000000001 RDI: 0000000000000000
> [ 11.281624] RBP: ffff88027f1f7f98 R08: 0000000000000001 R09: ffffffff802509af
> [ 11.281925] R10: ffff8800280c2780 R11: 0000000000000000 R12: ffff88027f097d48
> [ 11.282214] R13: ffff88027f097d70 R14: 0000000000000005 R15: ffff88027e571000
> [ 11.282502] FS: 0000000000000000(0000) GS:ffff88027f1c3340(0000) knlGS:0000000000000000
> [ 11.283096] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
> [ 11.283382] CR2: ffff8802ffffffff CR3: 0000000000201000 CR4: 00000000000006e0
> [ 11.283760] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
> [ 11.284048] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
> [ 11.284337] Process swapper (pid: 0, threadinfo ffff88027f1f2000, task ffff88027f1f0640)
> [ 11.284936] Stack: ffffffff80250963 0000000000000212 0000000000ee8c78 0000000000ee8a66
> [ 11.285802] ffff88027e571550 ffff88027f1f7fa8 ffffffff8021adb5 ffff88027f1f3e40
> [ 11.286599] ffffffff8020bdd6 ffff88027f1f3e40 <EOI> ffff88027f1f3ef8 0000000000000000
> [ 11.287120] Call Trace:
> [ 11.287768] <IRQ> [<ffffffff80250963>] ? generic_smp_call_function_interrupt+0x61/0x12c
> [ 11.288354] [<ffffffff8021adb5>] smp_call_function_interrupt+0x17/0x27
> [ 11.288744] [<ffffffff8020bdd6>] call_function_interrupt+0x66/0x70
> [ 11.289030] <EOI> [<ffffffff8024ab3b>] ? clockevents_notify+0x19/0x73
> [ 11.289380] [<ffffffff803b9b75>] ? acpi_idle_enter_simple+0x18b/0x1fa
> [ 11.289760] [<ffffffff803b9b6b>] ? acpi_idle_enter_simple+0x181/0x1fa
> [ 11.290051] [<ffffffff8053aeca>] ? cpuidle_idle_call+0x70/0xa2
> [ 11.290338] [<ffffffff80209f61>] ? cpu_idle+0x5f/0x7d
> [ 11.290723] [<ffffffff8060224a>] ? start_secondary+0x14d/0x152
> [ 11.291010]
> [ 11.291287]
> [ 11.291654] Code: Bad RIP value.
> [ 11.292041] RIP [<ffff8802ffffffff>] 0xffff8802ffffffff
> [ 11.292380] RSP <ffff88027f1f7f70>
> [ 11.292741] CR2: ffff8802ffffffff
> [ 11.310951] ---[ end trace 137c54d525305f1c ]---
> The problem is with the following sequence of events:
> - CPU A calls smp_call_function_mask() for CPU B with wait parameter
> - CPU A sets up the call_function_data on the stack and does an rcu add to
> call_function_queue
> - CPU A waits until the WAIT flag is cleared
> - CPU B gets the call function interrupt and starts going through the
> call_function_queue
> - CPU C also gets some other call function interrupt and starts going through
> the call_function_queue
> - CPU C, which is also going through the call_function_queue, starts referencing
> CPU A's stack, as that element is still in call_function_queue
> - CPU B finishes the function call that CPU A set up and as there are no other
> references to it, rcu deletes the call_function_data (which was from CPU A
> stack)
> - CPU B sees the wait flag and just clears the flag (no call_rcu to free)
> - CPU A which was waiting on the flag continues executing and the stack
> contents change
> - CPU C is still in rcu_read section accessing the CPU A's stack sees
> inconsistent call_funation_data and can try to execute
> function with some random pointer, causing stack corruption for A
> (by clearing the bits in mask field) and oops.
Nice debugging work.
I'd suggest something like the attached (boot tested) patch as the simple
fix for now.
I expect the benefits from the less synchronized, multiple-in-flight-data
global queue will still outweigh the costs of dynamic allocations. But
if worst comes to worst then we just go back to a globally synchronous
one-at-a-time implementation, but that would be pretty sad!
A previous patch added the early_initcall(), to allow a cleaner hooking of
pre-SMP initcalls. Now we remove the older interface, converting all
existing users to the new one.
[akpm@linux-foundation.org: cleanups]
[akpm@linux-foundation.org: build fix]
[kosaki.motohiro@jp.fujitsu.com: warning fix]
Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Tom Zanussi <tzanussi@gmail.com>
When a GFP_ATOMIC allocation fails, it falls back to allocating the
data on the stack and converting it to a waiting call.
Make sure we actually wait in this case.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
