path: root/kernel/smpboot.c
2016-10-11kthread/smpboot: do not park in kthread_create_on_cpu()Petr Mladek
kthread_create_on_cpu() was added by the commit 2a1d446019f9a5983e ("kthread: Implement park/unpark facility"). It is currently used only when enabling new CPU. For this purpose, the newly created kthread has to be parked. The CPU binding is a bit tricky. The kthread is parked when the CPU has not been allowed yet. And the CPU is bound when the kthread is unparked. The function would be useful for more per-CPU kthreads, e.g. bnx2fc_thread, fcoethread. For this purpose, the newly created kthread should stay in the uninterruptible state. This patch moves the parking into smpboot. It binds the thread already when created. Then the function might be used universally. Also the behavior is consistent with kthread_create() and kthread_create_on_node(). Link: http://lkml.kernel.org/r/1470754545-17632-4-git-send-email-pmladek@suse.com Signed-off-by: Petr Mladek <pmladek@suse.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Borislav Petkov <bp@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-04Revert "sched/core: Do not use smp_processor_id() with preempt enabled in ↵Ingo Molnar
smpboot_thread_fn()" This reverts commit 4fa5cd5245b627db88c9ca08ae442373b02596b4. The original change widens a preempt-off section, to avoid a seemingly unsafe smp_processor_id() use. During review I overlooked two facts: - The code to calls a non-trivial function callback: ht->park(td->cpu); ... which might (and does occasionally) sleep, triggering the warning. - More importantly, as pointed out by Peter Zijlstra, using smp_processor_id() in that context is safe, if it's done from a kernel thread that is pinned to a single CPU - which is the case here. So revert to the original code that enables preemption sooner. Reported-by: kernel test robot <xiaolong.ye@intel.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Con Kolivas <kernel@kolivas.org> Cc: Alfred Chen <cchalpha@gmail.com> Link: http://lkml.kernel.org/r/20160930015102.GB20189@yexl-desktop Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-09-22sched/core: Do not use smp_processor_id() with preempt enabled in ↵Con Kolivas
smpboot_thread_fn() We should not be using smp_processor_id() with preempt enabled. Bug identified and fix provided by Alfred Chen. Reported-by: Alfred Chen <cchalpha@gmail.com> Signed-off-by: Con Kolivas <kernel@kolivas.org> Cc: Alfred Chen <cchalpha@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/2042051.3vvUWIM0vs@hex Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-01cpu/hotplug: Unpark smpboot threads from the state machineThomas Gleixner
Handle the smpboot threads in the state machine. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Rik van Riel <riel@redhat.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/r/20160226182341.295777684@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-20stop_machine: Kill smp_hotplug_thread->pre_unpark, introduce ↵Oleg Nesterov
stop_machine_unpark() 1. Change smpboot_unpark_thread() to check ->selfparking, just like smpboot_park_thread() does. 2. Introduce stop_machine_unpark() which sets ->enabled and calls kthread_unpark(). 3. Change smpboot_thread_call() and cpu_stop_init() to call stop_machine_unpark() by hand. This way: - IMO the ->selfparking logic becomes more consistent. - We can kill the smp_hotplug_thread->pre_unpark() method. - We can easily unpark the stopper thread earlier. Say, we can move stop_machine_unpark() from smpboot_thread_call() to sched_cpu_active() as Peter suggests. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: heiko.carstens@de.ibm.com Link: http://lkml.kernel.org/r/20151009160049.GA10166@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-04smpboot: allow passing the cpumask on per-cpu thread registrationFrederic Weisbecker
It makes the registration cheaper and simpler for the smpboot per-cpu kthread users that don't need to always update the cpumask after threads creation. [sfr@canb.auug.org.au: fix for allow passing the cpumask on per-cpu thread registration] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04smpboot: make cleanup to mirror setupFrederic Weisbecker
The per-cpu kthread cleanup() callback is the mirror of the setup() callback. When the per-cpu kthread is started, it first calls setup() to initialize the resources which are then released by cleanup() when the kthread exits. Now since the introduction of a per-cpu kthread cpumask, the kthreads excluded by the cpumask on boot may happen to be parked immediately after their creation without taking the setup() stage, waiting to be asked to unpark to do so. Then when smpboot_unregister_percpu_thread() is later called, the kthread is stopped without having ever called setup(). But this triggers a bug as the kthread unconditionally calls cleanup() on exit but this doesn't mirror any setup(). Thus the kernel crashes because we try to free resources that haven't been initialized, as in the watchdog case: WATCHDOG disable 0 WATCHDOG disable 1 WATCHDOG disable 2 BUG: unable to handle kernel NULL pointer dereference at (null) IP: hrtimer_active+0x26/0x60 [...] Call Trace: hrtimer_try_to_cancel+0x1c/0x280 hrtimer_cancel+0x1d/0x30 watchdog_disable+0x56/0x70 watchdog_cleanup+0xe/0x10 smpboot_thread_fn+0x23c/0x2c0 kthread+0xf8/0x110 ret_from_fork+0x3f/0x70 This bug is currently masked with explicit kthread unparking before kthread_stop() on smpboot_destroy_threads(). This forces a call to setup() and then unpark(). We could fix this by unconditionally calling setup() on kthread entry. But setup() isn't always cheap. In the case of watchdog it launches hrtimer, perf events, etc... So we may as well like to skip it if there are chances the kthread will never be used, as in a reduced cpumask value. So let's simply do a state machine check before calling cleanup() that makes sure setup() has been called before mirroring it. And remove the nasty hack workaround. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04smpboot: fix memory leak on error handlingFrederic Weisbecker
The cpumask is allocated before threads get created. If the latter step fails, we need to free the cpumask. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Chris Metcalf <cmetcalf@ezchip.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24watchdog: add watchdog_cpumask sysctl to assist nohzChris Metcalf
Change the default behavior of watchdog so it only runs on the housekeeping cores when nohz_full is enabled at build and boot time. Allow modifying the set of cores the watchdog is currently running on with a new kernel.watchdog_cpumask sysctl. In the current system, the watchdog subsystem runs a periodic timer that schedules the watchdog kthread to run. However, nohz_full cores are designed to allow userspace application code running on those cores to have 100% access to the CPU. So the watchdog system prevents the nohz_full application code from being able to run the way it wants to, thus the motivation to suppress the watchdog on nohz_full cores, which this patchset provides by default. However, if we disable the watchdog globally, then the housekeeping cores can't benefit from the watchdog functionality. So we allow disabling it only on some cores. See Documentation/lockup-watchdogs.txt for more information. [jhubbard@nvidia.com: fix a watchdog crash in some configurations] Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Acked-by: Don Zickus <dzickus@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: John Hubbard <jhubbard@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24smpboot: allow excluding cpus from the smpboot threadsChris Metcalf
This patch series allows the watchdog to run by default only on the housekeeping cores when nohz_full is in effect; this seems to be a good compromise short of turning it off completely (since the nohz_full cores can't tolerate a watchdog). To provide customizability, we add /proc/sys/kernel/watchdog_cpumask so that the set of cores running the watchdog can be tuned to different values after bootup. To implement this customizability, we add a new smpboot_update_cpumask_percpu_thread() API to the smpboot_thread subsystem that lets us park or unpark "unwanted" threads. And now that threads can be parked for long periods of time, we tweak the /proc/<pid>/stat and /proc/<pid>/status code so parked threads aren't reported as running, which is otherwise confusing. This patch (of 3): This change allows some cores to be excluded from running the smp_hotplug_thread tasks. The following commit to update kernel/watchdog.c to use this functionality is the motivating example, and more information on the motivation is provided there. A new smp_hotplug_thread field is introduced, "cpumask", which is cpumask field managed by the smpboot subsystem that indicates whether or not the given smp_hotplug_thread should run on that core; the cpumask is checked when deciding whether to unpark the thread. To limit the cpumask to less than cpu_possible, you must call smpboot_update_cpumask_percpu_thread() after registering. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Ulrich Obergfell <uobergfe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-11smpboot: Add common code for notification from dying CPUPaul E. McKenney
RCU ignores offlined CPUs, so they cannot safely run RCU read-side code. (They -can- use SRCU, but not RCU.) This means that any use of RCU during or after the call to arch_cpu_idle_dead(). Unfortunately, commit 2ed53c0d6cc99 added a complete() call, which will contain RCU read-side critical sections if there is a task waiting to be awakened. Which, as it turns out, there almost never is. In my qemu/KVM testing, the to-be-awakened task is not yet asleep more than 99.5% of the time. In current mainline, failure is even harder to reproduce, requiring a virtualized environment that delays the outgoing CPU by at least three jiffies between the time it exits its stop_machine() task at CPU_DYING time and the time it calls arch_cpu_idle_dead() from the idle loop. However, this problem really can occur, especially in virtualized environments, and therefore really does need to be fixed This suggests moving back to the polling loop, but using a much shorter wait, with gentle exponential backoff instead of the old 100-millisecond wait. Most of the time, the loop will exit without waiting at all, and almost all of the remaining uses will wait only five microseconds. If the outgoing CPU is preempted, a loop will wait one jiffy, then increase the wait by a factor of 11/10ths, rounding up. As before, there is a five-second timeout. This commit therefore provides common-code infrastructure to do the dying-to-surviving CPU handoff in a safe manner. This code also provides an indication at CPU-online of whether the CPU to be onlined previously timed out on offline. The new cpu_check_up_prepare() function returns -EBUSY if this CPU previously took more than five seconds to go offline, or -EAGAIN if it has not yet managed to go offline. The rationale for -EAGAIN is that it might still be preempted, so an additional wait might well find it correctly offlined. Architecture-specific code can decide how to handle these conditions. Systems in which CPUs take themselves completely offline might respond to an -EBUSY return as if it was a zero (success) return. Systems in which the surviving CPU must take some action might take it at this time, or might simply mark the other CPU as unusable. Note that architectures that take the easy way out and simply pass the -EBUSY and -EAGAIN upwards will change the sysfs API. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> [ paulmck: Fixed state machine for architectures that don't check earlier CPU-hotplug results as suggested by James Hogan. ]
2015-01-23smpboot: Add missing get_online_cpus() in smpboot_register_percpu_thread()Lai Jiangshan
The following race exists in the smpboot percpu threads management: CPU0 CPU1 cpu_up(2) get_online_cpus(); smpboot_create_threads(2); smpboot_register_percpu_thread(); for_each_online_cpu(); __smpboot_create_thread(); __cpu_up(2); This results in a missing per cpu thread for the newly onlined cpu2 and in a NULL pointer dereference on a consecutive offline of that cpu. Proctect smpboot_register_percpu_thread() with get_online_cpus() to prevent that. [ tglx: Massaged changelog and removed the change in smpboot_unregister_percpu_thread() because that's an optimization and therefor not stable material. ] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1406777421-12830-1-git-send-email-laijs@cn.fujitsu.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-28sched, smp: Correctly deal with nested sleepsPeter Zijlstra
smp_hotplug_thread::{setup,unpark} functions can sleep too, so be consistent and do the same for all callbacks. __might_sleep+0x74/0x80 kmem_cache_alloc_trace+0x4e/0x1c0 perf_event_alloc+0x55/0x450 perf_event_create_kernel_counter+0x2f/0x100 watchdog_nmi_enable+0x8d/0x160 watchdog_enable+0x45/0x90 smpboot_thread_fn+0xec/0x2b0 kthread+0xe4/0x100 ret_from_fork+0x7c/0xb0 Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: tglx@linutronix.de Cc: ilya.dryomov@inktank.com Cc: umgwanakikbuti@gmail.com Cc: oleg@redhat.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140924082242.392279328@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-14kernel: delete __cpuinit usage from all core kernel filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the uses of the __cpuinit macros from C files in the core kernel directories (kernel, init, lib, mm, and include) that don't really have a specific maintainer. [1] https://lkml.org/lkml/2013/5/20/589 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-04-12kthread: Prevent unpark race which puts threads on the wrong cpuThomas Gleixner
The smpboot threads rely on the park/unpark mechanism which binds per cpu threads on a particular core. Though the functionality is racy: CPU0 CPU1 CPU2 unpark(T) wake_up_process(T) clear(SHOULD_PARK) T runs leave parkme() due to !SHOULD_PARK bind_to(CPU2) BUG_ON(wrong CPU) We cannot let the tasks move themself to the target CPU as one of those tasks is actually the migration thread itself, which requires that it starts running on the target cpu right away. The solution to this problem is to prevent wakeups in park mode which are not from unpark(). That way we can guarantee that the association of the task to the target cpu is working correctly. Add a new task state (TASK_PARKED) which prevents other wakeups and use this state explicitly for the unpark wakeup. Peter noticed: Also, since the task state is visible to userspace and all the parked tasks are still in the PID space, its a good hint in ps and friends that these tasks aren't really there for the moment. The migration thread has another related issue. CPU0 CPU1 Bring up CPU2 create_thread(T) park(T) wait_for_completion() parkme() complete() sched_set_stop_task() schedule(TASK_PARKED) The sched_set_stop_task() call is issued while the task is on the runqueue of CPU1 and that confuses the hell out of the stop_task class on that cpu. So we need the same synchronizaion before sched_set_stop_task(). Reported-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Dave Hansen <dave@sr71.net> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Acked-by: Peter Ziljstra <peterz@infradead.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: dhillf@gmail.com Cc: Ingo Molnar <mingo@kernel.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1304091635430.21884@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-03-08Revert parts of "hlist: drop the node parameter from iterators"Arnd Bergmann
Commit b67bfe0d42ca ("hlist: drop the node parameter from iterators") did a lot of nice changes but also contains two small hunks that seem to have slipped in accidentally and have no apparent connection to the intent of the patch. This reverts the two extraneous changes. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Peter Senna Tschudin <peter.senna@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-05Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smpboot bugfix from Thomas Gleixner: "A single bugfix for a regression introduced with the conversion of the stop machine threads to the generic smpboot thread management facility" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: stop_machine: Mark per cpu stopper enabled early
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26stop_machine: Mark per cpu stopper enabled earlyThomas Gleixner
commit 14e568e78 (stop_machine: Use smpboot threads) introduced the following regression: Before this commit the stopper enabled bit was set in the online notifier. CPU0 CPU1 cpu_up cpu online hotplug_notifier(ONLINE) stopper(CPU1)->enabled = true; ... stop_machine() The conversion to smpboot threads moved the enablement to the wakeup path of the parked thread. The majority of users seem to have the following working order: CPU0 CPU1 cpu_up cpu online unpark_threads() wakeup(stopper[CPU1]) .... stopper thread runs stopper(CPU1)->enabled = true; stop_machine() But Konrad and Sander have observed: CPU0 CPU1 cpu_up cpu online unpark_threads() wakeup(stopper[CPU1]) .... stop_machine() stopper thread runs stopper(CPU1)->enabled = true; Now the stop machinery kicks CPU0 into the stop loop, where it gets stuck forever because the queue code saw stopper(CPU1)->enabled == false, so CPU0 waits for CPU1 to enter stomp_machine, but the CPU1 stopper work got discarded due to enabled == false. Add a pre_unpark function to the smpboot thread descriptor and call it before waking the thread. This fixes the problem at hand, but the stop_machine code should be more robust. The stopper->enabled flag smells fishy at best. Thanks to Konrad for going through a loop of debug patches and providing the information to decode this issue. Reported-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reported-and-tested-by: Sander Eikelenboom <linux@eikelenboom.it> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1302261843240.22263@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-14smpboot: Allow selfparking per cpu threadsThomas Gleixner
The stop machine threads are still killed when a cpu goes offline. The reason is that the thread is used to bring the cpu down, so it can't be parked along with the other per cpu threads. Allow a per cpu thread to be excluded from automatic parking, so it can park itself once it's done Add a create callback function as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Arjan van de Veen <arjan@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Richard Weinberger <rw@linutronix.de> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130131120741.553993267@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-08-13hotplug: Fix UP bug in smpboot hotplug codePaul E. McKenney
Because kernel subsystems need their per-CPU kthreads on UP systems as well as on SMP systems, the smpboot hotplug kthread functions must be provided in UP builds as well as in SMP builds. This commit therefore adds smpboot.c to UP builds and excludes irrelevant code via #ifdef. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-08-13smpboot: Provide infrastructure for percpu hotplug threadsThomas Gleixner
Provide a generic interface for setting up and tearing down percpu threads. On registration the threads for already online cpus are created and started. On deregistration (modules) the threads are stoppped. During hotplug operations the threads are created, started, parked and unparked. The datastructure for registration provides a pointer to percpu storage space and optional setup, cleanup, park, unpark functions. These functions are called when the thread state changes. Each implementation has to provide a function which is queried and returns whether the thread should run and the thread function itself. The core code handles all state transitions and avoids duplicated code in the call sites. [ paulmck: Preemption leak fix ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20120716103948.352501068@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-24smpboot, idle: Fix comment mismatch over idle_threads_init()Srivatsa S. Bhat
The comment over idle_threads_init() really talks about the functionality of idle_init(). Move that comment to idle_init(), and add a suitable comment over idle_threads_init(). Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: suresh.b.siddha@intel.com Cc: venki@google.com Cc: nikunj@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20120524151100.2549.66501.stgit@srivatsabhat.in.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-24smpboot, idle: Optimize calls to smp_processor_id() in idle_threads_init()Srivatsa S. Bhat
While trying to initialize idle threads for all cpus, idle_threads_init() calls smp_processor_id() in a loop, which is unnecessary. The intent is to initialize idle threads for all non-boot cpus. So just use a variable to note the boot cpu and use it in the loop. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: suresh.b.siddha@intel.com Cc: venki@google.com Cc: nikunj@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20120524151055.2549.64309.stgit@srivatsabhat.in.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-03smp, idle: Allocate idle thread for each possible cpu during bootSuresh Siddha
percpu areas are already allocated during boot for each possible cpu. percpu idle threads can be considered as an extension of the percpu areas, and allocate them for each possible cpu during boot. This will eliminate the need for workqueue based idle thread allocation. In future we can move the idle thread area into the percpu area too. [ tglx: Moved the loop into smpboot.c and added an error check when the init code failed to allocate an idle thread for a cpu which should be onlined ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: venki@google.com Link: http://lkml.kernel.org/r/1334966930.28674.245.camel@sbsiddha-desk.sc.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-26smp: Provide generic idle thread allocationThomas Gleixner
All SMP architectures have magic to fork the idle task and to store it for reusage when cpu hotplug is enabled. Provide a generic infrastructure for it. Create/reinit the idle thread for the cpu which is brought up in the generic code and hand the thread pointer to the architecture code via __cpu_up(). Note, that fork_idle() is called via a workqueue, because this guarantees that the idle thread does not get a reference to a user space VM. This can happen when the boot process did not bring up all possible cpus and a later cpu_up() is initiated via the sysfs interface. In that case fork_idle() would be called in the context of the user space task and take a reference on the user space VM. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Acked-by: Venkatesh Pallipadi <venki@google.com> Link: http://lkml.kernel.org/r/20120420124557.102478630@linutronix.de
2012-04-26smp: Add generic smpboot facilityThomas Gleixner
Start a new file, which will hold SMP and CPU hotplug related generic infrastructure. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20120420124557.035417523@linutronix.de
