path: root/kernel/sys_ni.c
2015-04-15kernel: conditionally support non-root users, groups and capabilitiesIulia Manda
There are a lot of embedded systems that run most or all of their functionality in init, running as root:root. For these systems, supporting multiple users is not necessary. This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for non-root users, non-root groups, and capabilities optional. It is enabled under CONFIG_EXPERT menu. When this symbol is not defined, UID and GID are zero in any possible case and processes always have all capabilities. The following syscalls are compiled out: setuid, setregid, setgid, setreuid, setresuid, getresuid, setresgid, getresgid, setgroups, getgroups, setfsuid, setfsgid, capget, capset. Also, groups.c is compiled out completely. In kernel/capability.c, capable function was moved in order to avoid adding two ifdef blocks. This change saves about 25 KB on a defconfig build. The most minimal kernels have total text sizes in the high hundreds of kB rather than low MB. (The 25k goes down a bit with allnoconfig, but not that much. The kernel was booted in Qemu. All the common functionalities work. Adding users/groups is not possible, failing with -ENOSYS. Bloat-o-meter output: add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Iulia Manda <iulia.manda21@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13syscalls: implement execveat() system callDavid Drysdale
This patchset adds execveat(2) for x86, and is derived from Meredydd Luff's patch from Sept 2012 (https://lkml.org/lkml/2012/9/11/528). The primary aim of adding an execveat syscall is to allow an implementation of fexecve(3) that does not rely on the /proc filesystem, at least for executables (rather than scripts). The current glibc version of fexecve(3) is implemented via /proc, which causes problems in sandboxed or otherwise restricted environments. Given the desire for a /proc-free fexecve() implementation, HPA suggested (https://lkml.org/lkml/2006/7/11/556) that an execveat(2) syscall would be an appropriate generalization. Also, having a new syscall means that it can take a flags argument without back-compatibility concerns. The current implementation just defines the AT_EMPTY_PATH and AT_SYMLINK_NOFOLLOW flags, but other flags could be added in future -- for example, flags for new namespaces (as suggested at https://lkml.org/lkml/2006/7/11/474). Related history: - https://lkml.org/lkml/2006/12/27/123 is an example of someone realizing that fexecve() is likely to fail in a chroot environment. - http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=514043 covered documenting the /proc requirement of fexecve(3) in its manpage, to "prevent other people from wasting their time". - https://bugzilla.redhat.com/show_bug.cgi?id=241609 described a problem where a process that did setuid() could not fexecve() because it no longer had access to /proc/self/fd; this has since been fixed. This patch (of 4): Add a new execveat(2) system call. execveat() is to execve() as openat() is to open(): it takes a file descriptor that refers to a directory, and resolves the filename relative to that. In addition, if the filename is empty and AT_EMPTY_PATH is specified, execveat() executes the file to which the file descriptor refers. This replicates the functionality of fexecve(), which is a system call in other UNIXen, but in Linux glibc it depends on opening "/proc/self/fd/<fd>" (and so relies on /proc being mounted). The filename fed to the executed program as argv[0] (or the name of the script fed to a script interpreter) will be of the form "/dev/fd/<fd>" (for an empty filename) or "/dev/fd/<fd>/<filename>", effectively reflecting how the executable was found. This does however mean that execution of a script in a /proc-less environment won't work; also, script execution via an O_CLOEXEC file descriptor fails (as the file will not be accessible after exec). Based on patches by Meredydd Luff. Signed-off-by: David Drysdale <drysdale@google.com> Cc: Meredydd Luff <meredydd@senatehouse.org> Cc: Shuah Khan <shuah.kh@samsung.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rich Felker <dalias@aerifal.cx> Cc: Christoph Hellwig <hch@infradead.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-19s390/kernel: add system calls for PCI memory accessAlexey Ishchuk
Add the new __NR_s390_pci_mmio_write and __NR_s390_pci_mmio_read system calls to allow user space applications to access device PCI I/O memory pages on s390x platform. [ Martin Schwidefsky: some code beautification ] Signed-off-by: Alexey Ishchuk <aishchuk@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Most notable changes in here: 1) By far the biggest accomplishment, thanks to a large range of contributors, is the addition of multi-send for transmit. This is the result of discussions back in Chicago, and the hard work of several individuals. Now, when the ->ndo_start_xmit() method of a driver sees skb->xmit_more as true, it can choose to defer the doorbell telling the driver to start processing the new TX queue entires. skb->xmit_more means that the generic networking is guaranteed to call the driver immediately with another SKB to send. There is logic added to the qdisc layer to dequeue multiple packets at a time, and the handling mis-predicted offloads in software is now done with no locks held. Finally, pktgen is extended to have a "burst" parameter that can be used to test a multi-send implementation. Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4, virtio_net Adding support is almost trivial, so export more drivers to support this optimization soon. I want to thank, in no particular or implied order, Jesper Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann, David Tat, Hannes Frederic Sowa, and Rusty Russell. 2) PTP and timestamping support in bnx2x, from Michal Kalderon. 3) Allow adjusting the rx_copybreak threshold for a driver via ethtool, and add rx_copybreak support to enic driver. From Govindarajulu Varadarajan. 4) Significant enhancements to the generic PHY layer and the bcm7xxx driver in particular (EEE support, auto power down, etc.) from Florian Fainelli. 5) Allow raw buffers to be used for flow dissection, allowing drivers to determine the optimal "linear pull" size for devices that DMA into pools of pages. The objective is to get exactly the necessary amount of headers into the linear SKB area pre-pulled, but no more. The new interface drivers use is eth_get_headlen(). From WANG Cong, with driver conversions (several had their own by-hand duplicated implementations) by Alexander Duyck and Eric Dumazet. 6) Support checksumming more smoothly and efficiently for encapsulations, and add "foo over UDP" facility. From Tom Herbert. 7) Add Broadcom SF2 switch driver to DSA layer, from Florian Fainelli. 8) eBPF now can load programs via a system call and has an extensive testsuite. Alexei Starovoitov and Daniel Borkmann. 9) Major overhaul of the packet scheduler to use RCU in several major areas such as the classifiers and rate estimators. From John Fastabend. 10) Add driver for Intel FM10000 Ethernet Switch, from Alexander Duyck. 11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric Dumazet. 12) Add Datacenter TCP congestion control algorithm support, From Florian Westphal. 13) Reorganize sk_buff so that __copy_skb_header() is significantly faster. From Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits) netlabel: directly return netlbl_unlabel_genl_init() net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers net: description of dma_cookie cause make xmldocs warning cxgb4: clean up a type issue cxgb4: potential shift wrapping bug i40e: skb->xmit_more support net: fs_enet: Add NAPI TX net: fs_enet: Remove non NAPI RX r8169:add support for RTL8168EP net_sched: copy exts->type in tcf_exts_change() wimax: convert printk to pr_foo() af_unix: remove 0 assignment on static ipv6: Do not warn for informational ICMP messages, regardless of type. Update Intel Ethernet Driver maintainers list bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING tipc: fix bug in multicast congestion handling net: better IFF_XMIT_DST_RELEASE support net/mlx4_en: remove NETDEV_TX_BUSY 3c59x: fix bad split of cpu_to_le32(pci_map_single()) net: bcmgenet: fix Tx ring priority programming ...
2014-09-26bpf: enable bpf syscall on x64 and i386Alexei Starovoitov
done as separate commit to ease conflict resolution Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-17mm: Support compiling out madvise and fadviseJosh Triplett
Many embedded systems will not need these syscalls, and omitting them saves space. Add a new EXPERT config option CONFIG_ADVISE_SYSCALLS (default y) to support compiling them out. bloat-o-meter: add/remove: 0/3 grow/shrink: 0/0 up/down: 0/-2250 (-2250) function old new delta sys_fadvise64 57 - -57 sys_fadvise64_64 691 - -691 sys_madvise 1502 - -1502 Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2014-08-08kexec: new syscall kexec_file_load() declarationVivek Goyal
This is the new syscall kexec_file_load() declaration/interface. I have reserved the syscall number only for x86_64 so far. Other architectures (including i386) can reserve syscall number when they enable the support for this new syscall. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Borislav Petkov <bp@suse.de> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08shm: add memfd_create() syscallDavid Herrmann
memfd_create() is similar to mmap(MAP_ANON), but returns a file-descriptor that you can pass to mmap(). It can support sealing and avoids any connection to user-visible mount-points. Thus, it's not subject to quotas on mounted file-systems, but can be used like malloc()'ed memory, but with a file-descriptor to it. memfd_create() returns the raw shmem file, so calls like ftruncate() can be used to modify the underlying inode. Also calls like fstat() will return proper information and mark the file as regular file. If you want sealing, you can specify MFD_ALLOW_SEALING. Otherwise, sealing is not supported (like on all other regular files). Compared to O_TMPFILE, it does not require a tmpfs mount-point and is not subject to a filesystem size limit. It is still properly accounted to memcg limits, though, and to the same overcommit or no-overcommit accounting as all user memory. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-18seccomp: add "seccomp" syscallKees Cook
This adds the new "seccomp" syscall with both an "operation" and "flags" parameter for future expansion. The third argument is a pointer value, used with the SECCOMP_SET_MODE_FILTER operation. Currently, flags must be 0. This is functionally equivalent to prctl(PR_SET_SECCOMP, ...). In addition to the TSYNC flag later in this patch series, there is a non-zero chance that this syscall could be used for configuring a fixed argument area for seccomp-tracer-aware processes to pass syscall arguments in the future. Hence, the use of "seccomp" not simply "seccomp_add_filter" for this syscall. Additionally, this syscall uses operation, flags, and user pointer for arguments because strictly passing arguments via a user pointer would mean seccomp itself would be unable to trivially filter the seccomp syscall itself. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Andy Lutomirski <luto@amacapital.net>
2014-06-04sys_sgetmask/sys_ssetmask: add CONFIG_SGETMASK_SYSCALLFabian Frederick
sys_sgetmask and sys_ssetmask are obsolete system calls no longer supported in libc. This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert mode configuration.That option is enabled by default for those architectures. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Steven Miao <realmz6@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03fs, kernel: permit disabling the uselib syscallJosh Triplett
uselib hasn't been used since libc5; glibc does not use it. Support turning it off. When disabled, also omit the load_elf_library implementation from binfmt_elf.c, which only uselib invokes. bloat-o-meter: add/remove: 0/4 grow/shrink: 0/1 up/down: 0/-785 (-785) function old new delta padzero 39 36 -3 uselib_flags 20 - -20 sys_uselib 168 - -168 SyS_uselib 168 - -168 load_elf_library 426 - -426 The new CONFIG_USELIB defaults to `y'. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03sys_sysfs: Add CONFIG_SYSFS_SYSCALLFabian Frederick
sys_sysfs is an obsolete system call no longer supported by libc. - This patch adds a default CONFIG_SYSFS_SYSCALL=y - Option can be turned off in expert mode. - cond_syscall added to kernel/sys_ni.c [akpm@linux-foundation.org: tweak Kconfig help text] Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-09unify compat fanotify_mark(2), switch to COMPAT_SYSCALL_DEFINEAl Viro
2013-03-03merge compat sys_ipc instancesAl Viro
2013-03-03consolidate compat lookup_dcookie()Al Viro
2012-12-14module: add syscall to load module from fdKees Cook
As part of the effort to create a stronger boundary between root and kernel, Chrome OS wants to be able to enforce that kernel modules are being loaded only from our read-only crypto-hash verified (dm_verity) root filesystem. Since the init_module syscall hands the kernel a module as a memory blob, no reasoning about the origin of the blob can be made. Earlier proposals for appending signatures to kernel modules would not be useful in Chrome OS, since it would involve adding an additional set of keys to our kernel and builds for no good reason: we already trust the contents of our root filesystem. We don't need to verify those kernel modules a second time. Having to do signature checking on module loading would slow us down and be redundant. All we need to know is where a module is coming from so we can say yes/no to loading it. If a file descriptor is used as the source of a kernel module, many more things can be reasoned about. In Chrome OS's case, we could enforce that the module lives on the filesystem we expect it to live on. In the case of IMA (or other LSMs), it would be possible, for example, to examine extended attributes that may contain signatures over the contents of the module. This introduces a new syscall (on x86), similar to init_module, that has only two arguments. The first argument is used as a file descriptor to the module and the second argument is a pointer to the NULL terminated string of module arguments. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (merge fixes)
2012-05-31syscalls, x86: add __NR_kcmp syscallCyrill Gorcunov
While doing the checkpoint-restore in the user space one need to determine whether various kernel objects (like mm_struct-s of file_struct-s) are shared between tasks and restore this state. The 2nd step can be solved by using appropriate CLONE_ flags and the unshare syscall, while there's currently no ways for solving the 1st one. One of the ways for checking whether two tasks share e.g. mm_struct is to provide some mm_struct ID of a task to its proc file, but showing such info considered to be not that good for security reasons. Thus after some debates we end up in conclusion that using that named 'comparison' syscall might be the best candidate. So here is it -- __NR_kcmp. It takes up to 5 arguments - the pids of the two tasks (which characteristics should be compared), the comparison type and (in case of comparison of files) two file descriptors. Lookups for pids are done in the caller's PID namespace only. At moment only x86 is supported and tested. [akpm@linux-foundation.org: fix up selftests, warnings] [akpm@linux-foundation.org: include errno.h] [akpm@linux-foundation.org: tweak comment text] Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Glauber Costa <glommer@parallels.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tejun Heo <tj@kernel.org> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Valdis.Kletnieks@vt.edu Cc: Michal Marek <mmarek@suse.cz> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20ipc: Add missing sys_ni entries for ipc/compat.c functionsKevin Cernekee
When building with: CONFIG_64BIT=y CONFIG_MIPS32_COMPAT=y CONFIG_COMPAT=y CONFIG_MIPS32_O32=y CONFIG_MIPS32_N32=y CONFIG_SYSVIPC is not set (and implicitly: CONFIG_SYSVIPC_COMPAT is not set) the final link fails with unresolved symbols for: compat_sys_semctl, compat_sys_msgsnd, compat_sys_msgrcv, compat_sys_shmctl, compat_sys_msgctl, compat_sys_semtimedop The fix is to add cond_syscall declarations for all syscalls in ipc/compat.c Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-05net: Add sendmmsg socket system callAnton Blanchard
This patch adds a multiple message send syscall and is the send version of the existing recvmmsg syscall. This is heavily based on the patch by Arnaldo that added recvmmsg. I wrote a microbenchmark to test the performance gains of using this new syscall: http://ozlabs.org/~anton/junkcode/sendmmsg_test.c The test was run on a ppc64 box with a 10 Gbit network card. The benchmark can send both UDP and RAW ethernet packets. 64B UDP batch pkts/sec 1 804570 2 872800 (+ 8 %) 4 916556 (+14 %) 8 939712 (+17 %) 16 952688 (+18 %) 32 956448 (+19 %) 64 964800 (+20 %) 64B raw socket batch pkts/sec 1 1201449 2 1350028 (+12 %) 4 1461416 (+22 %) 8 1513080 (+26 %) 16 1541216 (+28 %) 32 1553440 (+29 %) 64 1557888 (+30 %) We see a 20% improvement in throughput on UDP send and 30% on raw socket send. [ Add sparc syscall entries. -DaveM ] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15vfs: Add open by file handle supportAneesh Kumar K.V
[AV: duplicate of open() guts removed; file_open_root() used instead] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15vfs: Add name to file handle conversion supportAneesh Kumar K.V
The syscall also return mount id which can be used to lookup file system specific information such as uuid in /proc/<pid>/mountinfo Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-23powerpc: define a compat_sys_recv cond_syscallStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-28fanotify: sys_fanotify_mark declartionEric Paris
This patch simply declares the new sys_fanotify_mark syscall int fanotify_mark(int fanotify_fd, unsigned int flags, u64_mask, int dfd const char *pathname) Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: fanotify_init syscall declarationEric Paris
This patch defines a new syscall fanotify_init() of the form: int sys_fanotify_init(unsigned int flags, unsigned int event_f_flags, unsigned int priority) This syscall is used to create and fanotify group. This is very similar to the inotify_init() syscall. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-06sysctl: Remove the cond_syscall entry for sys32_sysctlEric W. Biederman
Now that all architechtures are use compat_sys_sysctl and sys32_sysctl does not exist there is not point in retaining a cond_syscall entry for it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-12net: Introduce recvmmsg socket syscallArnaldo Carvalho de Melo
Meaning receive multiple messages, reducing the number of syscalls and net stack entry/exit operations. Next patches will introduce mechanisms where protocols that want to optimize this operation will provide an unlocked_recvmsg operation. This takes into account comments made by: . Paul Moore: sock_recvmsg is called only for the first datagram, sock_recvmsg_nosec is used for the rest. . Caitlin Bestler: recvmmsg now has a struct timespec timeout, that works in the same fashion as the ppoll one. If the underlying protocol returns a datagram with MSG_OOB set, this will make recvmmsg return right away with as many datagrams (+ the OOB one) it has received so far. . Rémi Denis-Courmont & Steven Whitehouse: If we receive N < vlen datagrams and then recvmsg returns an error, recvmmsg will return the successfully received datagrams, store the error and return it in the next call. This paves the way for a subsequent optimization, sk_prot->unlocked_recvmsg, where we will be able to acquire the lock only at batch start and end, not at every underlying recvmsg call. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/cpc-usb/TODO drivers/staging/cpc-usb/cpc-usb_drv.c drivers/staging/cpc-usb/cpc.h drivers/staging/cpc-usb/cpc_int.h drivers/staging/cpc-usb/cpcusb.h
2009-09-21net: fix CONFIG_NET=n build on sparc64Andrew Morton
sparc64 allnoconfig: arch/sparc/kernel/built-in.o(.text+0x134e0): In function `sys32_recvfrom': : undefined reference to `compat_sys_recvfrom' arch/sparc/kernel/built-in.o(.text+0x134e4): In function `sys32_recvfrom': : undefined reference to `compat_sys_recvfrom' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21Merge commit 'v2.6.29-rc2' into perfcounters/coreIngo Molnar
Conflicts: include/linux/syscalls.h
2009-01-14[CVE-2009-0029] Make sys_syslog a conditional system callHeiko Carstens
Remove the -ENOSYS implementation for !CONFIG_PRINTK and use the cond_syscall infrastructure instead. Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-12-08performance counters: core codeThomas Gleixner
Implement the core kernel bits of Performance Counters subsystem. The Linux Performance Counter subsystem provides an abstraction of performance counter hardware capabilities. It provides per task and per CPU counters, and it provides event capabilities on top of those. Performance counters are accessed via special file descriptors. There's one file descriptor per virtual counter used. The special file descriptor is opened via the perf_counter_open() system call: int perf_counter_open(u32 hw_event_type, u32 hw_event_period, u32 record_type, pid_t pid, int cpu); The syscall returns the new fd. The fd can be used via the normal VFS system calls: read() can be used to read the counter, fcntl() can be used to set the blocking mode, etc. Multiple counters can be kept open at a time, and the counters can be poll()ed. See more details in Documentation/perf-counters.txt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-19reintroduce accept4Ulrich Drepper
Introduce a new accept4() system call. The addition of this system call matches analogous changes in 2.6.27 (dup3(), evenfd2(), signalfd4(), inotify_init1(), epoll_create1(), pipe2()) which added new system calls that differed from analogous traditional system calls in adding a flags argument that can be used to access additional functionality. The accept4() system call is exactly the same as accept(), except that it adds a flags bit-mask argument. Two flags are initially implemented. (Most of the new system calls in 2.6.27 also had both of these flags.) SOCK_CLOEXEC causes the close-on-exec (FD_CLOEXEC) flag to be enabled for the new file descriptor returned by accept4(). This is a useful security feature to avoid leaking information in a multithreaded program where one thread is doing an accept() at the same time as another thread is doing a fork() plus exec(). More details here: http://udrepper.livejournal.com/20407.html "Secure File Descriptor Handling", Ulrich Drepper). The other flag is SOCK_NONBLOCK, which causes the O_NONBLOCK flag to be enabled on the new open file description created by accept4(). (This flag is merely a convenience, saving the use of additional calls fcntl(F_GETFL) and fcntl (F_SETFL) to achieve the same result. Here's a test program. Works on x86-32. Should work on x86-64, but I (mtk) don't have a system to hand to test with. It tests accept4() with each of the four possible combinations of SOCK_CLOEXEC and SOCK_NONBLOCK set/clear in 'flags', and verifies that the appropriate flags are set on the file descriptor/open file description returned by accept4(). I tested Ulrich's patch in this thread by applying against 2.6.28-rc2, and it passes according to my test program. /* test_accept4.c Copyright (C) 2008, Linux Foundation, written by Michael Kerrisk <mtk.manpages@gmail.com> Licensed under the GNU GPLv2 or later. */ #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> #include <sys/socket.h> #include <netinet/in.h> #include <stdlib.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #define PORT_NUM 33333 #define die(msg) do { perror(msg); exit(EXIT_FAILURE); } while (0) /**********************************************************************/ /* The following is what we need until glibc gets a wrapper for accept4() */ /* Flags for socket(), socketpair(), accept4() */ #ifndef SOCK_CLOEXEC #define SOCK_CLOEXEC O_CLOEXEC #endif #ifndef SOCK_NONBLOCK #define SOCK_NONBLOCK O_NONBLOCK #endif #ifdef __x86_64__ #define SYS_accept4 288 #elif __i386__ #define USE_SOCKETCALL 1 #define SYS_ACCEPT4 18 #else #error "Sorry -- don't know the syscall # on this architecture" #endif static int accept4(int fd, struct sockaddr *sockaddr, socklen_t *addrlen, int flags) { printf("Calling accept4(): flags = %x", flags); if (flags != 0) { printf(" ("); if (flags & SOCK_CLOEXEC) printf("SOCK_CLOEXEC"); if ((flags & SOCK_CLOEXEC) && (flags & SOCK_NONBLOCK)) printf(" "); if (flags & SOCK_NONBLOCK) printf("SOCK_NONBLOCK"); printf(")"); } printf("\n"); #if USE_SOCKETCALL long args[6]; args[0] = fd; args[1] = (long) sockaddr; args[2] = (long) addrlen; args[3] = flags; return syscall(SYS_socketcall, SYS_ACCEPT4, args); #else return syscall(SYS_accept4, fd, sockaddr, addrlen, flags); #endif } /**********************************************************************/ static int do_test(int lfd, struct sockaddr_in *conn_addr, int closeonexec_flag, int nonblock_flag) { int connfd, acceptfd; int fdf, flf, fdf_pass, flf_pass; struct sockaddr_in claddr; socklen_t addrlen; printf("=======================================\n"); connfd = socket(AF_INET, SOCK_STREAM, 0); if (connfd == -1) die("socket"); if (connect(connfd, (struct sockaddr *) conn_addr, sizeof(struct sockaddr_in)) == -1) die("connect"); addrlen = sizeof(struct sockaddr_in); acceptfd = accept4(lfd, (struct sockaddr *) &claddr, &addrlen, closeonexec_flag | nonblock_flag); if (acceptfd == -1) { perror("accept4()"); close(connfd); return 0; } fdf = fcntl(acceptfd, F_GETFD); if (fdf == -1) die("fcntl:F_GETFD"); fdf_pass = ((fdf & FD_CLOEXEC) != 0) == ((closeonexec_flag & SOCK_CLOEXEC) != 0); printf("Close-on-exec flag is %sset (%s); ", (fdf & FD_CLOEXEC) ? "" : "not ", fdf_pass ? "OK" : "failed"); flf = fcntl(acceptfd, F_GETFL); if (flf == -1) die("fcntl:F_GETFD"); flf_pass = ((flf & O_NONBLOCK) != 0) == ((nonblock_flag & SOCK_NONBLOCK) !=0); printf("nonblock flag is %sset (%s)\n", (flf & O_NONBLOCK) ? "" : "not ", flf_pass ? "OK" : "failed"); close(acceptfd); close(connfd); printf("Test result: %s\n", (fdf_pass && flf_pass) ? "PASS" : "FAIL"); return fdf_pass && flf_pass; } static int create_listening_socket(int port_num) { struct sockaddr_in svaddr; int lfd; int optval; memset(&svaddr, 0, sizeof(struct sockaddr_in)); svaddr.sin_family = AF_INET; svaddr.sin_addr.s_addr = htonl(INADDR_ANY); svaddr.sin_port = htons(port_num); lfd = socket(AF_INET, SOCK_STREAM, 0); if (lfd == -1) die("socket"); optval = 1; if (setsockopt(lfd, SOL_SOCKET, SO_REUSEADDR, &optval, sizeof(optval)) == -1) die("setsockopt"); if (bind(lfd, (struct sockaddr *) &svaddr, sizeof(struct sockaddr_in)) == -1) die("bind"); if (listen(lfd, 5) == -1) die("listen"); return lfd; } int main(int argc, char *argv[]) { struct sockaddr_in conn_addr; int lfd; int port_num; int passed; passed = 1; port_num = (argc > 1) ? atoi(argv[1]) : PORT_NUM; memset(&conn_addr, 0, sizeof(struct sockaddr_in)); conn_addr.sin_family = AF_INET; conn_addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); conn_addr.sin_port = htons(port_num); lfd = create_listening_socket(port_num); if (!do_test(lfd, &conn_addr, 0, 0)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, 0)) passed = 0; if (!do_test(lfd, &conn_addr, 0, SOCK_NONBLOCK)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, SOCK_NONBLOCK)) passed = 0; close(lfd); exit(passed ? EXIT_SUCCESS : EXIT_FAILURE); } [mtk.manpages@gmail.com: rewrote changelog, updated test program] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Configure out AIO supportThomas Petazzoni
This patchs adds the CONFIG_AIO option which allows to remove support for asynchronous I/O operations, that are not necessarly used by applications, particularly on embedded devices. As this is a size-reduction option, it depends on CONFIG_EMBEDDED. It allows to save ~7 kilobytes of kernel code/data: text data bss dec hex filename 1115067 119180 217088 1451335 162547 vmlinux 1108025 119048 217088 1444161 160941 vmlinux.new -7042 -132 0 -7174 -1C06 +/- This patch has been originally written by Matt Mackall <mpm@selenic.com>, and is part of the Linux Tiny project. [randy.dunlap@oracle.com: build fix] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-29Configure out file locking featuresThomas Petazzoni
This patch adds the CONFIG_FILE_LOCKING option which allows to remove support for advisory locks. With this patch enabled, the flock() system call, the F_GETLK, F_SETLK and F_SETLKW operations of fcntl() and NFS support are disabled. These features are not necessarly needed on embedded systems. It allows to save ~11 Kb of kernel code and data: text data bss dec hex filename 1125436 118764 212992 1457192 163c28 vmlinux.old 1114299 118564 212992 1445855 160fdf vmlinux -11137 -200 0 -11337 -2C49 +/- This patch has originally been written by Matt Mackall <mpm@selenic.com>, and is part of the Linux Tiny project. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: matthew@wil.cx Cc: linux-fsdevel@vger.kernel.org Cc: mpm@selenic.com Cc: akpm@linux-foundation.org Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-25signalfd: fix undefined reference to `compat_sys_signalfd4' when ↵Ingo Molnar
!CONFIG_SIGNALFD fix: arch/x86/ia32/built-in.o: In function `ia32_sys_call_table': (.rodata+0xa38): undefined reference to `compat_sys_signalfd4' on !CONFIG_SIGNALFD. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25flag parameters: fix compile error of sys_epoll_create1Wang Chen
GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD vmlinux arch/x86/kernel/built-in.o: In function `sys_call_table': (.rodata+0x8a4): undefined reference to `sys_epoll_create1' make: *** [vmlinux] Error 1 Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: inotify_initUlrich Drepper
This patch introduces the new syscall inotify_init1 (note: the 1 stands for the one parameter the syscall takes, as opposed to no parameter before). The values accepted for this parameter are function-specific and defined in the inotify.h header. Here the values must match the O_* flags, though. In this patch CLOEXEC support is introduced. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_inotify_init1 # ifdef __x86_64__ # define __NR_inotify_init1 294 # elif defined __i386__ # define __NR_inotify_init1 332 # else # error "need __NR_inotify_init1" # endif #endif #define IN_CLOEXEC O_CLOEXEC int main (void) { int fd; fd = syscall (__NR_inotify_init1, 0); if (fd == -1) { puts ("inotify_init1(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("inotify_init1(0) set close-on-exit"); return 1; } close (fd); fd = syscall (__NR_inotify_init1, IN_CLOEXEC); if (fd == -1) { puts ("inotify_init1(IN_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("inotify_init1(O_CLOEXEC) does not set close-on-exit"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: eventfdUlrich Drepper
This patch adds the new eventfd2 syscall. It extends the old eventfd syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is EFD_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name EFD_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_eventfd2 # ifdef __x86_64__ # define __NR_eventfd2 290 # elif defined __i386__ # define __NR_eventfd2 328 # else # error "need __NR_eventfd2" # endif #endif #define EFD_CLOEXEC O_CLOEXEC int main (void) { int fd = syscall (__NR_eventfd2, 1, 0); if (fd == -1) { puts ("eventfd2(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("eventfd2(0) sets close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_eventfd2, 1, EFD_CLOEXEC); if (fd == -1) { puts ("eventfd2(EFD_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("eventfd2(EFD_CLOEXEC) does not set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: signalfdUlrich Drepper
This patch adds the new signalfd4 syscall. It extends the old signalfd syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is SFD_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name SFD_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_signalfd4 # ifdef __x86_64__ # define __NR_signalfd4 289 # elif defined __i386__ # define __NR_signalfd4 327 # else # error "need __NR_signalfd4" # endif #endif #define SFD_CLOEXEC O_CLOEXEC int main (void) { sigset_t ss; sigemptyset (&ss); sigaddset (&ss, SIGUSR1); int fd = syscall (__NR_signalfd4, -1, &ss, 8, 0); if (fd == -1) { puts ("signalfd4(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("signalfd4(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_CLOEXEC); if (fd == -1) { puts ("signalfd4(SFD_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("signalfd4(SFD_CLOEXEC) does not set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: pacceptUlrich Drepper
This patch is by far the most complex in the series. It adds a new syscall paccept. This syscall differs from accept in that it adds (at the userlevel) two additional parameters: - a signal mask - a flags value The flags parameter can be used to set flag like SOCK_CLOEXEC. This is imlpemented here as well. Some people argued that this is a property which should be inherited from the file desriptor for the server but this is against POSIX. Additionally, we really want the signal mask parameter as well (similar to pselect, ppoll, etc). So an interface change in inevitable. The flag value is the same as for socket and socketpair. I think diverging here will only create confusion. Similar to the filesystem interfaces where the use of the O_* constants differs, it is acceptable here. The signal mask is handled as for pselect etc. The mask is temporarily installed for the thread and removed before the call returns. I modeled the code after pselect. If there is a problem it's likely also in pselect. For architectures which use socketcall I maintained this interface instead of adding a system call. The symmetry shouldn't be broken. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <errno.h> #include <fcntl.h> #include <pthread.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <netinet/in.h> #include <sys/socket.h> #include <sys/syscall.h> #ifndef __NR_paccept # ifdef __x86_64__ # define __NR_paccept 288 # elif defined __i386__ # define SYS_PACCEPT 18 # define USE_SOCKETCALL 1 # else # error "need __NR_paccept" # endif #endif #ifdef USE_SOCKETCALL # define paccept(fd, addr, addrlen, mask, flags) \ ({ long args[6] = { \ (long) fd, (long) addr, (long) addrlen, (long) mask, 8, (long) flags }; \ syscall (__NR_socketcall, SYS_PACCEPT, args); }) #else # define paccept(fd, addr, addrlen, mask, flags) \ syscall (__NR_paccept, fd, addr, addrlen, mask, 8, flags) #endif #define PORT 57392 #define SOCK_CLOEXEC O_CLOEXEC static pthread_barrier_t b; static void * tf (void *arg) { pthread_barrier_wait (&b); int s = socket (AF_INET, SOCK_STREAM, 0); struct sockaddr_in sin; sin.sin_family = AF_INET; sin.sin_addr.s_addr = htonl (INADDR_LOOPBACK); sin.sin_port = htons (PORT); connect (s, (const struct sockaddr *) &sin, sizeof (sin)); close (s); pthread_barrier_wait (&b); s = socket (AF_INET, SOCK_STREAM, 0); sin.sin_port = htons (PORT); connect (s, (const struct sockaddr *) &sin, sizeof (sin)); close (s); pthread_barrier_wait (&b); pthread_barrier_wait (&b); sleep (2); pthread_kill ((pthread_t) arg, SIGUSR1); return NULL; } static void handler (int s) { } int main (void) { pthread_barrier_init (&b, NULL, 2); struct sockaddr_in sin; pthread_t th; if (pthread_create (&th, NULL, tf, (void *) pthread_self ()) != 0) { puts ("pthread_create failed"); return 1; } int s = socket (AF_INET, SOCK_STREAM, 0); int reuse = 1; setsockopt (s, SOL_SOCKET, SO_REUSEADDR, &reuse, sizeof (reuse)); sin.sin_family = AF_INET; sin.sin_addr.s_addr = htonl (INADDR_LOOPBACK); sin.sin_port = htons (PORT); bind (s, (struct sockaddr *) &sin, sizeof (sin)); listen (s, SOMAXCONN); pthread_barrier_wait (&b); int s2 = paccept (s, NULL, 0, NULL, 0); if (s2 < 0) { puts ("paccept(0) failed"); return 1; } int coe = fcntl (s2, F_GETFD); if (coe & FD_CLOEXEC) { puts ("paccept(0) set close-on-exec-flag"); return 1; } close (s2); pthread_barrier_wait (&b); s2 = paccept (s, NULL, 0, NULL, SOCK_CLOEXEC); if (s2 < 0) { puts ("paccept(SOCK_CLOEXEC) failed"); return 1; } coe = fcntl (s2, F_GETFD); if ((coe & FD_CLOEXEC) == 0) { puts ("paccept(SOCK_CLOEXEC) does not set close-on-exec flag"); return 1; } close (s2); pthread_barrier_wait (&b); struct sigaction sa; sa.sa_handler = handler; sa.sa_flags = 0; sigemptyset (&sa.sa_mask); sigaction (SIGUSR1, &sa, NULL); sigset_t ss; pthread_sigmask (SIG_SETMASK, NULL, &ss); sigaddset (&ss, SIGUSR1); pthread_sigmask (SIG_SETMASK, &ss, NULL); sigdelset (&ss, SIGUSR1); alarm (4); pthread_barrier_wait (&b); errno = 0 ; s2 = paccept (s, NULL, 0, &ss, 0); if (s2 != -1 || errno != EINTR) { puts ("paccept did not fail with EINTR"); return 1; } close (s); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: make it compile] [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roland McGrath <roland@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22Fix build on COMPAT platforms when CONFIG_EPOLL is disabledAtsushi Nemoto
Add missing cond_syscall() entry for compat_sys_epoll_pwait. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: new timerfd APIDavide Libenzi
This is the new timerfd API as it is implemented by the following patch: int timerfd_create(int clockid, int flags); int timerfd_settime(int ufd, int flags, const struct itimerspec *utmr, struct itimerspec *otmr); int timerfd_gettime(int ufd, struct itimerspec *otmr); The timerfd_create() API creates an un-programmed timerfd fd. The "clockid" parameter can be either CLOCK_MONOTONIC or CLOCK_REALTIME. The timerfd_settime() API give new settings by the timerfd fd, by optionally retrieving the previous expiration time (in case the "otmr" parameter is not NULL). The time value specified in "utmr" is absolute, if the TFD_TIMER_ABSTIME bit is set in the "flags" parameter. Otherwise it's a relative time. The timerfd_gettime() API returns the next expiration time of the timer, or {0, 0} if the timerfd has not been set yet. Like the previous timerfd API implementation, read(2) and poll(2) are supported (with the same interface). Here's a simple test program I used to exercise the new timerfd APIs: http://www.xmailserver.org/timerfd-test2.c [akpm@linux-foundation.org: coding-style cleanups] [akpm@linux-foundation.org: fix ia64 build] [akpm@linux-foundation.org: fix m68k build] [akpm@linux-foundation.org: fix mips build] [akpm@linux-foundation.org: fix alpha, arm, blackfin, cris, m68k, s390, sparc and sparc64 builds] [heiko.carstens@de.ibm.com: fix s390] [akpm@linux-foundation.org: fix powerpc build] [akpm@linux-foundation.org: fix sparc64 more] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24[POWERPC] Provide a way to protect 4k subpages when using 64k pagesPaul Mackerras
Using 64k pages on 64-bit PowerPC systems makes life difficult for emulators that are trying to emulate an ISA, such as x86, which use a smaller page size, since the emulator can no longer use the MMU and the normal system calls for controlling page protections. Of course, the emulator can emulate the MMU by checking and possibly remapping the address for each memory access in software, but that is pretty slow. This provides a facility for such programs to control the access permissions on individual 4k sub-pages of 64k pages. The idea is that the emulator supplies an array of protection masks to apply to a specified range of virtual addresses. These masks are applied at the level where hardware PTEs are inserted into the hardware page table based on the Linux PTEs, so the Linux PTEs are not affected. Note that this new mechanism does not allow any access that would otherwise be prohibited; it can only prohibit accesses that would otherwise be allowed. This new facility is only available on 64-bit PowerPC and only when the kernel is configured for 64k pages. The masks are supplied using a new subpage_prot system call, which takes a starting virtual address and length, and a pointer to an array of protection masks in memory. The array has a 32-bit word per 64k page to be protected; each 32-bit word consists of 16 2-bit fields, for which 0 allows any access (that is otherwise allowed), 1 prevents write accesses, and 2 or 3 prevent any access. Implicit in this is that the regions of the address space that are protected are switched to use 4k hardware pages rather than 64k hardware pages (on machines with hardware 64k page support). In fact the whole process is switched to use 4k hardware pages when the subpage_prot system call is used, but this could be improved in future to switch only the affected segments. The subpage protection bits are stored in a 3 level tree akin to the page table tree. The top level of this tree is stored in a structure that is appended to the top level of the page table tree, i.e., the pgd array. Since it will often only be 32-bit addresses (below 4GB) that are protected, the pointers to the first four bottom level pages are also stored in this structure (each bottom level page contains the protection bits for 1GB of address space), so the protection bits for addresses below 4GB can be accessed with one fewer loads than those for higher addresses. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-30[COMPAT]: Fix build on COMPAT platforms when CONFIG_NET is disabled.David S. Miller
Add some missing cond_syscall() entries for this case. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17kernel/sys_ni.c: add dummy sys_ni_syscall() prototypeAdrian Bunk
kernel/sys_ni.c can't #include <linux/syscalls.h> due to cond_syscall(), but let's tell gcc to not warn with -Wmissing-prototypes. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
