path: root/kernel/sysctl_binary.c
2014-12-10kernel: add panic_on_warnPrarit Bhargava
There have been several times where I have had to rebuild a kernel to cause a panic when hitting a WARN() in the code in order to get a crash dump from a system. Sometimes this is easy to do, other times (such as in the case of a remote admin) it is not trivial to send new images to the user. A much easier method would be a switch to change the WARN() over to a panic. This makes debugging easier in that I can now test the actual image the WARN() was seen on and I do not have to engage in remote debugging. This patch adds a panic_on_warn kernel parameter and /proc/sys/kernel/panic_on_warn calls panic() in the warn_slowpath_common() path. The function will still print out the location of the warning. An example of the panic_on_warn output: The first line below is from the WARN_ON() to output the WARN_ON()'s location. After that the panic() output is displayed. WARNING: CPU: 30 PID: 11698 at /home/prarit/dummy_module/dummy-module.c:25 init_dummy+0x1f/0x30 [dummy_module]() Kernel panic - not syncing: panic_on_warn set ... CPU: 30 PID: 11698 Comm: insmod Tainted: G W OE 3.17.0+ #57 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013 0000000000000000 000000008e3f87df ffff88080f093c38 ffffffff81665190 0000000000000000 ffffffff818aea3d ffff88080f093cb8 ffffffff8165e2ec ffffffff00000008 ffff88080f093cc8 ffff88080f093c68 000000008e3f87df Call Trace: [<ffffffff81665190>] dump_stack+0x46/0x58 [<ffffffff8165e2ec>] panic+0xd0/0x204 [<ffffffffa038e05f>] ? init_dummy+0x1f/0x30 [dummy_module] [<ffffffff81076b90>] warn_slowpath_common+0xd0/0xd0 [<ffffffffa038e040>] ? dummy_greetings+0x40/0x40 [dummy_module] [<ffffffff81076c8a>] warn_slowpath_null+0x1a/0x20 [<ffffffffa038e05f>] init_dummy+0x1f/0x30 [dummy_module] [<ffffffff81002144>] do_one_initcall+0xd4/0x210 [<ffffffff811b52c2>] ? __vunmap+0xc2/0x110 [<ffffffff810f8889>] load_module+0x16a9/0x1b30 [<ffffffff810f3d30>] ? store_uevent+0x70/0x70 [<ffffffff810f49b9>] ? copy_module_from_fd.isra.44+0x129/0x180 [<ffffffff810f8ec6>] SyS_finit_module+0xa6/0xd0 [<ffffffff8166cf29>] system_call_fastpath+0x12/0x17 Successfully tested by me. hpa said: There is another very valid use for this: many operators would rather a machine shuts down than being potentially compromised either functionally or security-wise. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-07Merge tag 'dmaengine-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine updates from Dan Williams: "Even though this has fixes marked for -stable, given the size and the needed conflict resolutions this is 3.18-rc1/merge-window material. These patches have been languishing in my tree for a long while. The fact that I do not have the time to do proper/prompt maintenance of this tree is a primary factor in the decision to step down as dmaengine maintainer. That and the fact that the bulk of drivers/dma/ activity is going through Vinod these days. The net_dma removal has not been in -next. It has developed simple conflicts against mainline and net-next (for-3.18). Continuing thanks to Vinod for staying on top of drivers/dma/. Summary: 1/ Step down as dmaengine maintainer see commit 08223d80df38 "dmaengine maintainer update" 2/ Removal of net_dma, as it has been marked 'broken' since 3.13 (commit 77873803363c "net_dma: mark broken"), without reports of performance regression. 3/ Miscellaneous fixes" * tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: net: make tcp_cleanup_rbuf private net_dma: revert 'copied_early' net_dma: simple removal dmaengine maintainer update dmatest: prevent memory leakage on error path in thread ioat: Use time_before_jiffies() dmaengine: fix xor sources continuation dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup() dma: mv_xor: Remove all callers of mv_xor_slot_cleanup() dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call ioat: Use pci_enable_msix_exact() instead of pci_enable_msix() drivers: dma: Include appropriate header file in dca.c drivers: dma: Mark functions as static in dma_v3.c dma: mv_xor: Add DMA API error checks ioat/dca: Use dev_is_pci() to check whether it is pci device
2014-09-28net_dma: simple removalDan Williams
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used and there is no plan to fix it. This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards. Reverting the remainder of the net_dma induced changes is deferred to subsequent patches. Marked for stable due to Roman's report of a memory leak in dma_pin_iovec_pages(): https://lkml.org/lkml/2014/9/3/177 Cc: Dave Jiang <dave.jiang@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: David Whipple <whipple@securedatainnovations.ch> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: <stable@vger.kernel.org> Reported-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2014-07-01ipv6: Allow accepting RA from local IP addresses.Ben Greear
This can be used in virtual networking applications, and may have other uses as well. The option is disabled by default. A specific use case is setting up virtual routers, bridges, and hosts on a single OS without the use of network namespaces or virtual machines. With proper use of ip rules, routing tables, veth interface pairs and/or other virtual interfaces, and applications that can bind to interfaces and/or IP addresses, it is possibly to create one or more virtual routers with multiple hosts attached. The host interfaces can act as IPv6 systems, with radvd running on the ports in the virtual routers. With the option provided in this patch enabled, those hosts can now properly obtain IPv6 addresses from the radvd. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-13kernel/sysctl_binary.c: use scnprintf() instead of snprintf()Chen Gang
snprintf() will return the 'ideal' length which may be larger than real buffer length, if we only want to use real length, need use scnprintf() instead of. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-26kernel: remove unnecessary head fileJunweiZhang
ip_vs.h is not necessary for sysctl_binary.c. prepare for the next patch to avoid compile issue. Signed-off-by: JunweiZhang <junwei.zhang@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Reviewed-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2013-05-09switch compat_sys_sysctl to COMPAT_SYSCALL_DEFINEAl Viro
2013-02-27sysctl: fix null checking in bin_dn_node_address()Xi Wang
The null check of `strchr() + 1' is broken, which is always non-null, leading to OOB read. Instead, check the result of strchr(). Signed-off-by: Xi Wang <xi.wang@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26export kernel_write(), convert open-coded instancesAl Viro
2013-02-05tcp: remove Appropriate Byte Count supportStephen Hemminger
TCP Appropriate Byte Count was added by me, but later disabled. There is no point in maintaining it since it is a potential source of bugs and Linux already implements other better window protection heuristics. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-19pidns: Use task_active_pid_ns where appropriateEric W. Biederman
The expressions tsk->nsproxy->pid_ns and task_active_pid_ns aka ns_of_pid(task_pid(tsk)) should have the same number of cache line misses with the practical difference that ns_of_pid(task_pid(tsk)) is released later in a processes life. Furthermore by using task_active_pid_ns it becomes trivial to write an unshare implementation for the the pid namespace. So I have used task_active_pid_ns everywhere I can. In fork since the pid has not yet been attached to the process I use ns_of_pid, to achieve the same effect. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-31mm: prepare for removal of obsolete /proc/sys/vm/nr_pdflush_threadsWanpeng Li
Since per-BDI flusher threads were introduced in 2.6, the pdflush mechanism is not used any more. But the old interface exported through /proc/sys/vm/nr_pdflush_threads still exists and is obviously useless. For back-compatibility, printk warning information and return 2 to notify the users that the interface is removed. Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-20binary_sysctl(): fix memory leakMichel Lespinasse
binary_sysctl() calls sysctl_getname() which allocates from names_cache slab usin __getname() The matching function to free the name is __putname(), and not putname() which should be used only to match getname() allocations. This is because when auditing is enabled, putname() calls audit_putname *instead* (not in addition) to __putname(). Then, if a syscall is in progress, audit_putname does not release the name - instead, it expects the name to get released when the syscall completes, but that will happen only if audit_getname() was called previously, i.e. if the name was allocated with getname() rather than the naked __getname(). So, __getname() followed by putname() ends up leaking memory. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Eric Paris <eparis@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-03ipv4: NET_IPV4_ROUTE_GC_INTERVAL removalVasily Averin
removing obsoleted sysctl, ip_rt_gc_interval variable no longer used since 2.6.38 Signed-off-by: Vasily Averin <vvs@sw.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-03-14open-style analog of vfs_path_lookup()Al Viro
new function: file_open_root(dentry, mnt, name, flags) opens the file vfs_path_lookup would arrive to. Note that name can be empty; in that case the usual requirement that dentry should be a directory is lifted. open-coded equivalents switched to it, may_open() got down exactly one caller and became static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-12-10x86, NMI: Add back unknown_nmi_panic and nmi_watchdog sysctlsDon Zickus
Originally adapted from Huang Ying's patch which moved the unknown_nmi_panic to the traps.c file. Because the old nmi watchdog was deleted before this change happened, the unknown_nmi_panic sysctl was lost. This re-adds it. Also, the nmi_watchdog sysctl was re-implemented and its documentation updated accordingly. Patch-inspired-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Don Zickus <dzickus@redhat.com> Reviewed-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: fweisbec@gmail.com LKML-Reference: <1291068437-5331-3-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-25sysctl: don't use own implementation of hex_to_bin()Andy Shevchenko
Remove own implementation of hex_to_bin(). Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-08ipv4: remove ip_rt_secret timer (v4)Neil Horman
A while back there was a discussion regarding the rt_secret_interval timer. Given that we've had the ability to do emergency route cache rebuilds for awhile now, based on a statistical analysis of the various hash chain lengths in the cache, the use of the flush timer is somewhat redundant. This patch removes the rt_secret_interval sysctl, allowing us to rely solely on the statistical analysis mechanism to determine the need for route cache flushes. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Switch may_open() and break_lease() to passing O_...Al Viro
... instead of mixing FMODE_ and O_ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-23SYSCTL: Print binary sysctl warnings (nearly) only onceAndi Kleen
When printing legacy sysctls print the warning message for each of them only once. This way there is a guarantee the syslog won't be flooded for any sane program. The original attempt at this made the tables non const and stored the flag inline. Linus suggested using a separate hash table for this, this is based on a code snippet from him. The hash implies this is not exact and can sometimes not print a new sysctl due to a hash collision, but in practice this should not be a problem I used a FNV32 hash over the binary string with a 32byte bitmap. This gives relatively little collisions when all the predefined binary sysctls are hashed: size 256 bucket length number 0: [25] 1: [67] 2: [88] 3: [47] 4: [22] 5: [6] 6: [1] The worst case is a single collision of 6 hash values. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16[sysctl] Fix breakage on systems with older glibcAndi Kleen
As predicted during code review, the sysctl(2) changes made systems with old glibc nearly unusable. About every command gives a: warning: process `ls' used the deprecated sysctl system call with 1.4 warning in the log. I see this on a SUSE 10.0 system with glibc 2.3.5. Don't warn for this common case. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12sysctl binary: Reorder the tests to process wild card entries first.Eric W. Biederman
A malicious user could have passed in a ctl_name of 0 and triggered the well know ctl_name to procname mapping code, instead of the wild card matching code. This is a slight problem as wild card entries don't have procnames, and because in some alternate universe a network device might have ifindex 0. So test for and handle wild card entries first. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl: sysctl_binary.c Fix compilation when !CONFIG_NETEric W. Biederman
dev_get_by_index does not exist when the network stack is not compiled in, so only include the code to follow wild card paths when the network stack is present. I have shuffled the code around a little to make it clear that dev_put is called after dev_get_by_index showing that there is no leak. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-11sysctl: Warn about all uses of sys_sysctl.Eric W. Biederman
Now that the glibc pthread implemenation no longers uses sysctl() users of sysctl are as rare as hen's teeth. So remove the glibc exception from the warning, and use the standard printk_ratelimit instead of rolling our own. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-11sysctl: Reduce sys_sysctl to a compatibility wrapper around /proc/sysEric W. Biederman
To simply maintenance and to be able to remove all of the binary sysctl support from various subsystems I have rewritten the binary sysctl code as a compatibility wrapper around proc/sys. The code is built around a hard coded table based on the table in sysctl_check.c that lists all of our current binary sysctls and provides enough information to convert from the sysctl binary input into into ascii and back again. New in this patch is the realization that the only dynamic entries that need to be handled have ifname as the asscii string and ifindex as their ctl_name. When a sys_sysctl is called the code now looks in the translation table converting the binary name to the path under /proc where the value is to be found. Opens that file, and calls into a format conversion wrapper that calls fop->read and then fop->write as appropriate. Since in practice the practically no one uses or tests sys_sysctl rewritting the code to be beautiful is a little silly. The redeeming merit of this work is it allows us to rip out all of the binary sysctl syscall support from everywhere else in the tree. Allowing us to remove a lot of dead (after this patch) and barely maintained code. In addition it becomes much easier to optimize the sysctl implementation for being the backing store of /proc/sys, without having to worry about sys_sysctl. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-06sysctl: Make do_sysctl staticEric W. Biederman
Now that all of the architectures use compat_sys_sysctl do_sysctl can become static. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-06sysctl: Introduce a generic compat sysctl sysctlEric W. Biederman
This uses compat_alloc_userspace to remove the various hacks to allow do_sysctl to write to throuh oldlenp. The rest of our mature compat syscall helper facitilies are used as well to ensure we have a nice clean maintainable compat syscall that can be used on all architectures. The motiviation for a generic compat sysctl (besides the obvious hack removal) is to reduce the number of compat sysctl defintions out there so I can refactor the binary sysctl implementation. ppc already used the name compat_sys_sysctl so I remove the ppcs version here. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-06sysctl: Refactor the binary sysctl handling to remove duplicate codeEric W. Biederman
Read in the binary sysctl path once, instead of reread it from user space each time the code needs to access a path element. The deprecated sysctl warning is moved to do_sysctl so that the compat_sysctl entries syscalls will also warn. The return of -ENOSYS when !CONFIG_SYSCTL_SYSCALL is moved to binary_sysctl. Always leaving a do_sysctl available that handles !CONFIG_SYSCTL_SYSCALL and printing the deprecated sysctl warning allows for a single defitition of the sysctl syscall. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-06sysctl: Separate the binary sysctl logic into it's own file.Eric W. Biederman
In preparation for more invasive cleanups separate the core binary sysctl logic into it's own file. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
