path: root/kernel/taskstats.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-18const: struct nla_policyAlexey Dobriyan
Make remaining netlink policies as const. Fixup coding style where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12genetlink: make netns awareJohannes Berg
This makes generic netlink network namespace aware. No generic netlink families except for the controller family are made namespace aware, they need to be checked one by one and then set the family->netnsok member to true. A new function genlmsg_multicast_netns() is introduced to allow sending a multicast message in a given namespace, for example when it applies to an object that lives in that namespace, a new function genlmsg_multicast_allns() to send a message to all network namespaces (for objects that do not have an associated netns). The function genlmsg_multicast() is changed to multicast the message in just init_net, which is currently correct for all generic netlink families since they only work in init_net right now. Some will later want to work in all net namespaces because they do not care about the netns at all -- those will have to be converted to use one of the new functions genlmsg_multicast_allns() or genlmsg_multicast_netns() whenever they are made netns aware in some way. After this patch families can easily decide whether or not they should be available in all net namespaces. Many genl families us it for objects not related to networking and should therefore be available in all namespaces, but that will have to be done on a per family basis. Note that this doesn't touch on the checkpoint/restart problem where network namespaces could be used, genl families and multicast groups are numbered globally and I see no easy way of changing that, especially since it must be possible to multicast to all network namespaces for those families that do not care about netns. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-01cpumask: convert rest of files in kernel/Rusty Russell
Impact: Reduce stack usage, use new cpumask API. Mainly changing cpumask_t to 'struct cpumask' and similar simple API conversion. Two conversions worth mentioning: 1) we use cpumask_any_but to avoid a temporary in kernel/softlockup.c, 2) Use cpumask_var_t in taskstats_user_cmd(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com>
2008-12-13cpumask: change cpumask_scnprintf, cpumask_parse_user, cpulist_parse, and ↵Rusty Russell
cpulist_scnprintf to take pointers. Impact: change calling convention of existing cpumask APIs Most cpumask functions started with cpus_: these have been replaced by cpumask_ ones which take struct cpumask pointers as expected. These four functions don't have good replacement names; fortunately they're rarely used, so we just change them over. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: paulus@samba.org Cc: mingo@redhat.com Cc: tony.luck@intel.com Cc: ralf@linux-mips.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: cl@linux-foundation.org Cc: srostedt@redhat.com
2008-07-25taskstats: remove initialization of static per-cpu variableVegard Nossum
Cc: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23core: use performance variant for_each_cpu_mask_nrMike Travis
Change references from for_each_cpu_mask to for_each_cpu_mask_nr where appropriate Reviewed-by: Paul Jackson <pj@sgi.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30Use find_task_by_vpid in taskstatsPavel Emelyanov
The pid to lookup a task by is passed inside taskstats code via genetlink message. Since netlink packets are now processed in the context of the sending task, this is correct to lookup the task with find_task_by_vpid() here. Besides, I fix the call to fill_pid() from taskstats_exit(), since the tsk->pid is not required in fill_pid() in this case, and the pid field on task_struct is going to be deprecated as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Jonathan Lim <jlim@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14kernel/taskstats.c: fix bogus nlmsg_free()Adrian Bunk
We'd better not nlmsg_free on a pointer containing an undefined value (and without having anything allocated). Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Balbir Singh <balbir@linux.vnet.ibm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Add cgroupstatsBalbir Singh
This patch is inspired by the discussion at http://lkml.org/lkml/2007/4/11/187 and implements per cgroup statistics as suggested by Andrew Morton in http://lkml.org/lkml/2007/4/11/263. The patch is on top of 2.6.21-mm1 with Paul's cgroups v9 patches (forward ported) This patch implements per cgroup statistics infrastructure and re-uses code from the taskstats interface. A new set of cgroup operations are registered with commands and attributes. It should be very easy to *extend* per cgroup statistics, by adding members to the cgroupstats structure. The current model for cgroupstats is a pull, a push model (to post statistics on interesting events), should be very easy to add. Currently user space requests for statistics by passing the cgroup file descriptor. Statistics about the state of all the tasks in the cgroup is returned to user space. TODO's/NOTE: This patch provides an infrastructure for implementing cgroup statistics. Based on the needs of each controller, we can incrementally add more statistics, event based support for notification of statistics, accumulation of taskstats into cgroup statistics in the future. Sample output # ./cgroupstats -C /cgroup/a sleeping 2, blocked 0, running 1, stopped 0, uninterruptible 0 # ./cgroupstats -C /cgroup/ sleeping 154, blocked 0, running 0, stopped 0, uninterruptible 0 If the approach looks good, I'll enhance and post the user space utility for the same Feedback, comments, test results are always welcome! [akpm@linux-foundation.org: build fix] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Clean up duplicate includes in kernel/Jesper Juhl
This patch cleans up duplicate includes in kernel/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16taskstats: add context-switch countersMaxim Uvarov
Make available to the user the following task and process performance statistics: * Involuntary Context Switches (task_struct->nivcsw) * Voluntary Context Switches (task_struct->nvcsw) Statistics information is available from: 1. taskstats interface (Documentation/accounting/) 2. /proc/PID/status (task only). This data is useful for detecting hyperactivity patterns between processes. [akpm@linux-foundation.org: cleanup] Signed-off-by: Maxim Uvarov <muvarov@ru.mvista.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Jonathan Lim <jlim@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07KMEM_CACHE(): simplify slab cache creationChristoph Lameter
This patch provides a new macro KMEM_CACHE(<struct>, <flags>) to simplify slab creation. KMEM_CACHE creates a slab with the name of the struct, with the size of the struct and with the alignment of the struct. Additional slab flags may be specified if necessary. Example struct test_slab { int a,b,c; struct list_head; } __cacheline_aligned_in_smp; test_slab_cache = KMEM_CACHE(test_slab, SLAB_PANIC) will create a new slab named "test_slab" of the size sizeof(struct test_slab) and aligned to the alignment of test slab. If it fails then we panic. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[NETLINK]: Introduce nlmsg_hdr() helperArnaldo Carvalho de Melo
For the common "(struct nlmsghdr *)skb->data" sequence, so that we reduce the number of direct accesses to skb->data and for consistency with all the other cast skb member helpers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-07[PATCH] taskstats: cleanup reply assemblingOleg Nesterov
Thomas Graf wrote: > > nla_nest_start() may return NULL, either rely on prepare_reply() to be > correct and BUG() on failure or do proper error handling for all > functions. nla_put() in taskstat.c can fail only if the 'size' argument of alloc_skb() was not right. This is a kernel bug, we should not hide it. So add 'BUG()' on error path and check for 'na == NULL'. > genlmsg_cancel() is only required in error paths for dumping > procedures. So we can remove 'genlmsg_cancel()' calls and 'void *reply' (saves 227 bytes). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Thomas Graf <tgraf@suug.ch> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] taskstats: use nla_reserve() for reply assemblingOleg Nesterov
Currently taskstats_user_cmd()/taskstats_exit() do: 1) allocate stats 2) fill stats 3) make a temporary copy on stack (236 bytes) 4) copy that copy to skb 5) free stats With the help of nla_reserve() we can operate on skb->data directly, thus avoiding all these steps except 2). So, before this patch: // copy *stats to skb->data int mk_reply(skb, ..., struct taskstats *stats); fill_pid(stats); mk_reply(skb, ..., stats); After: // return a pointer to skb->data struct taskstats *mk_reply(skb, ...); stat = mk_reply(skb, ...); fill_pid(stats); Shrinks taskatsks.o by 162 bytes. A stupid benchmark (send one million TASKSTATS_CMD_ATTR_PID) shows the real user sys before: 4.02 0.06 3.96 4.02 0.04 3.98 4.02 0.04 3.97 after: 3.86 0.08 3.78 3.88 0.10 3.77 3.89 0.09 3.80 but this looks suspiciously good. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] taskstats: factor out reply assemblingOleg Nesterov
Introduce mk_reply() helper which does all nla_put()s on reply. Saves 453 bytes and a preparation for the next patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] taskstats: cleanup ->signal->stats allocationOleg Nesterov
Allocate ->signal->stats on demand in taskstats_exit(), this allows us to remove taskstats_tgid_alloc() (the last non-trivial inline) from taskstat's public interface. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] taskstats: cleanup do_exit() pathOleg Nesterov
do_exit: taskstats_exit_alloc() ... taskstats_exit_send() taskstats_exit_free() I think this is not good, let it be a single function exported to the core kernel, taskstats_exit(), which does alloc + send + free itself. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] taskstats_exit_alloc: optimize/simplifyOleg Nesterov
If there are no listeners, every task does unneeded kmem_cache alloc/free on exit. We don't need listeners->sem for 'if (!list_empty())' check. Yes, we may have a false positive, but this doesn't differ from the case when the listener is unregistered after we drop the semaphore. So we don't need to do allocation beforehand. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Acked-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[GENL]: Add genlmsg_put_reply() to simplify building reply headersThomas Graf
By modyfing genlmsg_put() to take a genl_family and by adding genlmsg_put_reply() the process of constructing the netlink and generic netlink headers is simplified. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[GENL]: Add genlmsg_new() to allocate generic netlink messagesThomas Graf
2006-12-02[NETLINK]: Do precise netlink message allocations where possibleThomas Graf
Account for the netlink message header size directly in nlmsg_new() instead of relying on the caller calculate it correctly. Replaces error handling of message construction functions when constructing notifications with bug traps since a failure implies a bug in calculating the size of the skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-31[PATCH] taskstats: fix sub-threads accountingOleg Nesterov
If there are no listeners, taskstats_exit_send() just returns because taskstats_exit_alloc() didn't allocate *tidstats. This is wrong, each sub-thread should do fill_tgid_exit() on exit, otherwise its ->delays is not recorded in ->signal->stats and lost. Q: We don't send TASKSTATS_TYPE_AGGR_TGID when single-threaded process exits. Is it good? How can the listener figure out that it was actually a process exit, not sub-thread? Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Acked-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] taskstats: fix sk_buff size calculationOleg Nesterov
prepare_reply() adds GENL_HDRLEN to the payload (genlmsg_total_size()), but then it does genlmsg_put()->nlmsg_put(). This means we forget to reserve a room for 'struct nlmsghdr'. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Thomas Graf <tgraf@suug.ch> Cc: Andrew Morton <akpm@osdl.org> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] taskstats: fix sk_buff leakOleg Nesterov
'return genlmsg_cancel()' in taskstats_user_cmd/taskstats_exit_send potentially leaks a skb. Unless we pass 'rep_skb' to the netlink layer we own sk_buff. This means we should always do kfree_skb() on failure. [ Thomas acked and pointed out missing return value in original version ] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Thomas Graf <tgraf@suug.ch> Cc: Andrew Morton <akpm@osdl.org> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] fill_tgid: cleanup delays accountingOleg Nesterov
fill_tgid() should skip not only an already exited group leader. If the task has ->exit_state != 0 it already did exit_notify(), so it also did fill_tgid_exit()->delayacct_add_tsk(->signal->stats) and we should skip it to avoid a double accounting. This patch doesn't close the race completely, but it cleanups the code. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats: don't use tasklist_lockOleg Nesterov
Remove tasklist_lock from taskstats.c. find_task_by_pid() is rcu-safe. ->siglock allows us to traverse subthread without tasklist. Q: delay accounting looks wrong to me. If sub-thread has already called taskstats_exit_send() but didn't call release_task(self) yet it will be accounted twice. The window is big. No? Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats: kill ->taskstats_lock in favor of ->siglockOleg Nesterov
signal_struct is (mostly) protected by ->sighand->siglock, I think we don't need ->taskstats_lock to protect ->stats. This also allows us to simplify the locking in fill_tgid(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] fill_tgid: fix task_struct leak and possible oopsOleg Nesterov
1. fill_tgid() forgets to do put_task_struct(first). 2. release_task(first) can happen after fill_tgid() drops tasklist_lock, it is unsafe to dereference first->signal. This is a temporary fix, imho the locking should be reworked. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: Extended system accounting over taskstatsJay Lan
Add extended system accounting handling over taskstats interface. A CONFIG_TASK_XACCT flag is created to enable the extended accounting code. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: basic accounting over taskstatsJay Lan
Add some basic accounting fields to the taskstats struct, add a new kernel/tsacct.c to handle basic accounting data handling upon exit. A handle is added to taskstats.c to invoke the basic accounting data handling. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: "Michal Piotrowski" <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Fix taskstats size calculation (use the new genetlink utility functions)Balbir Singh
The addition of the CSA patch pushed the size of struct taskstats to 256 bytes. This exposed a problem with prepare_reply(), we were not allocating space for the netlink and genetlink header. It worked earlier because alloc_skb() would align the skb to SMP_CACHE_BYTES, which added some additonal bytes. Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jamal Hadi <hadi@cyberus.ca> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Thomas Graf <tgraf@suug.ch> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[NETLINK]: Extend netlink messaging interfaceThomas Graf
Adds: nlmsg_get_pos() return current position in message nlmsg_trim() trim part of message nla_reserve_nohdr(skb, len) reserve room for an attribute w/o hdr nla_put_nohdr(skb, len, data) add attribute w/o hdr nla_find_nested() find attribute in nested attributes Fixes nlmsg_new() to take allocation flags and consider size. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-31[PATCH] taskstats: free skb, avoid returns in send_cpu_listenersShailabh Nagar
Add a missing freeing of skb in the case there are no listeners at all. Also remove the returning of error values by the function as it is unused by the sole caller. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] make taskstats sending completely independent of delay accounting ↵Shailabh Nagar
on/off status Complete the separation of delay accounting and taskstats by ignoring the return value of delay accounting functions that fill in parts of taskstats before it is sent out (either in response to a command or as part of a task exit). Also make delayacct_add_tsk return silently when delay accounting is turned off rather than treat it as an error. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] Remove down_write() from taskstats code invoked on the exit() pathShailabh Nagar
In send_cpu_listeners(), which is called on the exit path, a down_write() was protecting operations like skb_clone() and genlmsg_unicast() that do GFP_KERNEL allocations. If the oom-killer decides to kill tasks to satisfy the allocations,the exit of those tasks could block on the same semphore. The down_write() was only needed to allow removal of invalid listeners from the listener list. The patch converts the down_write to a down_read and defers the removal to a separate critical region. This ensures that even if the oom-killer is called, no other task's exit is blocked as it can still acquire another down_read. Thanks to Andrew Morton & Herbert Xu for pointing out the oom related pitfalls, and to Chandra Seetharaman for suggesting this fix instead of using something more complex like RCU. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task delay accounting taskstats interface: control exit data ↵Shailabh Nagar
through cpumasks On systems with a large number of cpus, with even a modest rate of tasks exiting per cpu, the volume of taskstats data sent on thread exit can overflow a userspace listener's buffers. One approach to avoiding overflow is to allow listeners to get data for a limited and specific set of cpus. By scaling the number of listeners and/or the cpus they monitor, userspace can handle the statistical data overload more gracefully. In this patch, each listener registers to listen to a specific set of cpus by specifying a cpumask. The interest is recorded per-cpu. When a task exits on a cpu, its taskstats data is unicast to each listener interested in that cpu. Thanks to Andrew Morton for pointing out the various scalability and general concerns of previous attempts and for suggesting this design. [akpm@osdl.org: build fix] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] delay accounting taskstats interface send tgid onceShailabh Nagar
Send per-tgid data only once during exit of a thread group instead of once with each member thread exit. Currently, when a thread exits, besides its per-tid data, the per-tgid data of its thread group is also sent out, if its thread group is non-empty. The per-tgid data sent consists of the sum of per-tid stats for all *remaining* threads of the thread group. This patch modifies this sending in two ways: - the per-tgid data is sent only when the last thread of a thread group exits. This cuts down heavily on the overhead of sending/receiving per-tgid data, especially when other exploiters of the taskstats interface aren't interested in per-tgid stats - the semantics of the per-tgid data sent are changed. Instead of being the sum of per-tid data for remaining threads, the value now sent is the true total accumalated statistics for all threads that are/were part of the thread group. The patch also addresses a minor issue where failure of one accounting subsystem to fill in the taskstats structure was causing the send of taskstats to not be sent at all. The patch has been tested for stability and run cerberus for over 4 hours on an SMP. [akpm@osdl.org: bugfixes] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: delay accounting usage of taskstats interfaceShailabh Nagar
Usage of taskstats interface by delay accounting. Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: taskstats interfaceShailabh Nagar
Create a "taskstats" interface based on generic netlink (NETLINK_GENERIC family), for getting statistics of tasks and thread groups during their lifetime and when they exit. The interface is intended for use by multiple accounting packages though it is being created in the context of delay accounting. This patch creates the interface without populating the fields of the data that is sent to the user in response to a command or upon the exit of a task. Each accounting package interested in using taskstats has to provide an additional patch to add its stats to the common structure. [akpm@osdl.org: cleanups, Kconfig fix] Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
