path: root/kernel/time.c
2006-01-31Don't try to "validate" a non-existing timeval.Linus Torvalds
settime() with a NULL timeval is silly but legal. Noticed by Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Remove getnstimestamp()Matt Helsley
Remove getnstimestamp() in favor of ktime.h's ktime_get_ts() Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: introduce nsec_t type and conversion functionsThomas Gleixner
- introduce the nsec_t type - basic nsec conversion routines: timespec_to_ns(), timeval_to_ns(), ns_to_timespec(), ns_to_timeval(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: validate timespec of do_sys_settimeofdayThomas Gleixner
Check if the timespec which is provided from user space is normalized. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: export deinlined mktimeAndrew Morton
This is now uninlined, but some modules use it. Make it a non-GPL export, since the inlined mktime() was also available that way. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: clean up mktime and make arguments constIngo Molnar
add 'const' to mktime arguments, and clean it up a bit Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: deinline mktime and set_normalized_timespecThomas Gleixner
mktime() and set_normalized_timespec() are large inline functions used in many places: deinline them. From: George Anzinger, off-by-1 bugfix Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] Add getnstimestamp functionMatt Helsley
There are several functions that might seem appropriate for a timestamp: get_cycles() current_kernel_time() do_gettimeofday() <read jiffies/jiffies_64> Each has problems with combinations of SMP-safety, low resolution, and monotonicity. This patch adds a new function that returns a monotonic SMP-safe timestamp with nanosecond resolution where available. Changes: Split timestamp into separate patch Moved to kernel/time.c Renamed to getnstimestamp Fixed unintended-pointer-arithmetic bug Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] NTP shift_right cleanupjohn stultz
Create a macro shift_right() that avoids the numerous ugly conditionals in the NTP code that look like: if(a < 0) b = -(-a >> shift); else b = a >> shift; Replacing it with: b = shift_right(a, shift); This should have zero effect on the logic, however it should probably have a bit of testing just to be sure. Also replace open-coded min/max with the macros. Signed-off-by : John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] missing exports of do_settimeofday() variantsAl Viro
frv, sh64, ia64 and sparc64 do not have do_settimeofday() exported (the last two are using variant in kernel/time.c). Exports added to match the rest of architectures. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-14[PATCH] Add missing export of getnstimeofday()Takashi Iwai
Adds the missing EXPORT_SYMBOL_GPL for getnstimeofday() when CONFIG_TIME_INTERPOLATION isn't set. Needed by drivers/char/mmtimer.c Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-28[PATCH] time interpolator: Fix settimeofday inaccuracyChristoph Lameter
settimeofday will set the time a little bit too early on systems using time interpolation since it subtracts the current interpolator offset from the time. This used to be necessary with the code in 2.6.9 and earlier but the new code resets the time interpolator after setting the time. Thus the time is set too early and gettimeofday will return a time slightly before the time specified with settimeofday if invoked immeditely after settimeofday. This removes the obsolete subtraction of the time interpolator offset and makes settimeofday set the time accurately. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
